Em je film Sfera jako dobar (po mom ukusu
Screenshots:
Ko nije gledao film (obavezno da ga pogleda
Ajmo da vidimo gde se pojavljuju u igranim filmovima još OS Linuxu/UNIX, a ima ih.
guest@d18 4% >pwd
/usr/people/guest
>user lono logged off...system opera
>su
root@d18 1%>ascii tty mode ENABLED
(user)
>RLOGIN:Guest@remotehost:/d18
/bin/chmod -r-r-w
guest@d18>
$BSD = -f '/vmunix'; if ($BSD) {system 'BIN
cbreak /dev/tty 2>&1'; '
(outout of binary data -- total mismatch w/ the decimal data shown earlier)
(numeric garbage)
sub set_cbreak { = &set_cbreak(1) or
&set_cbreak(0)
local($on) = $_[0],
local($sgttyb,@ary),
require 'sys/ioctl.ph',
$sgttyb_t = 'C# $' unless
$sgttyb_t; #c2ph:
&sgttyb'typedef()
@d18 command> ./GO
Hvala.qki wrote: Odlična tema, Brok.Veliki sam filmofil.
Ista stvar - obavezno vraćam neku scenu gdje se pojavljuje neki Unix-like sistemi, pa pauziram i zagledam.Broker wrote: Isrto sam i ja filmofil, i obraćam uvek pažnju na sisteme u filmovima.
Isto.Samo od kada sam instalirao Slackware nešto se i ne stiže da se nešto pogleda.
http://www.imdb.com/title/tt0107290/triviaThe park software is written in Pascal; a program is clearly visible in one of the monitor close-ups on the UNIX system. The graphical interface recognized as a UNIX system was the experimental Silicon Graphics 3D File System Navigator. The version number of the Silicon Graphics UNIX Operating System is 4.0.5 and is visible in one of the close-ups in the operating system's shell window (command program).
