Gnome Slackbuild (GSB) 3.2
Moderators: Sinisa, Urednik
Post Napisano: 03 Feb 2012, 13:18
Prije podizanja sistema, kad ti prikaže LILO, pritisni tipku TAB. Onda kucaj "Linux 3", pa Enter. Ovo je pod pretpostavkom da ti je unos u meniju kad podižeš Slack - "Linux". Ako si to promjenio, kucaj taj drugi naziv, pa razmak, pa 3. Tako ćeš podići sistem u runlevel-u 3.
Šta dalje? Možeš opet pokušati ono sa vesa drajverom, pa nam dostaviti logove i xorg.conf za fglrx. Jesi li pokretao "aticonfig --initial"? Malo kasnije ću vidjeti da ti sastavim jedan minimalni xorg.conf za fglrx, pa da pokušamo sa tim. Noviji Xorg bi i trebao tako da se konfiguriše, čak i piše nešto na temu toga u CHANGES_AND_HINTS.TXT.
The version of Xorg in Slackware 13.37 will not (in most cases) require an
/etc/X11/xorg.conf file. Input hotplugging is no longer done using hal;
instead, it now uses udev for input device detection and keyboard mapping.
/usr/share/X11/xorg.conf.d/ is the "packaged" configuration directory; all
files ending with ".conf" in this directory are used by the X server
unless there is an identically-named file in the local sysadmin directory.
The local sysadmin config directory is /etc/X11/xorg.conf.d/ - all files
ending with ".conf" in this directory are parsed.
There are several default config files in /usr/share/X11/xorg.conf.d/:
* 10-evdev.conf
a "catchall" file for input devices using the evdev driver; this
should work for most hardware in the absence of a better driver
* 50-synaptics.conf
overrides the earlier 10-evdev.conf file and uses the synaptics
driver for all touchpads
* 50-wacom.conf
overrides the earlier 10-evdev.conf file and uses the wacom driver
for Wacom tablets
* 90-keyboard-layout.conf
this sample ("normal" en layout) keeps the "old" default of
allowing Zap'ing the Xserver.
If you need to modify any of these defaults, then copy the relevant file
from /usr/share/X11/xorg.conf.d/ to /etc/X11/xorg.conf.d/ and edit the
copy.
You can still create an xorg.conf file if you wish, or you can create some
minimal xorg.conf snippets with only the specific contents that you wish
to override
(as an example, to use a binary-only video driver) as separate
files in the /etc/X11/xorg.conf.d/ directory.
Regardless of your chipset (though it seems more common with intel), if KDE
crashes on startup, try disabling the Composite extension (which will also
disable all of the fancy desktop effects). Place the following content in
a file at /etc/X11/xorg.conf.d/disable-composite.conf:
Section "Extensions"
Option "Composite" "Disable"
EndSection
Now that KMS (Kernel Mode Setting) for graphics cards has (mostly) stabilized,
it is enabled by default for intel, ati, and nvidia graphics chipsets. It
is possible to disable it use "nomodeset" as a kernel append in lilo.conf,
but Xorg will not work at all on intel and ati chips if you do that.
If you want to change the resolution of the KMS console, that can be done
with something like this as a kernel append in lilo.conf:
append="video=1024x768"
Speaking of lilo.conf and KMS, make sure you use either vga=normal or
vga=extended -- some of the framebuffers don't like KMS very much...
Npr. ovo što sa boldovao...
Taj fglrx je uvijek bio g... :exclaim: Zato sam ti i savjetovao u onoj temi prije prelaska na phpBB da se držiš open-source ATI drajvera, naravno ako ti slabije performanse ne predstavljaju problem. Jako je dobar i ne pravi probleme.
Post Napisano: 04 Feb 2012, 10:55
Prvo da ti se zahvalim na strpljenju, cim sve sredim javljam se (danas radim popodne a mora i sneg da se cisti).
Da posle instaliranja pokrenuo sam aticonfig --initial.
Kada sam pogledao u xorg.conf falio je unos u sekciji module (sekcija je postojala ali nikakav unos nije bio ispod) i falila je sekcija dri (uopste nije bila upisana) bar po onom tutorijalu koji sam pratio trebalo je da bude posle aticonfig --initial.
Dodao sam one redove koji su falili (tako je i pisalo u tutorijalu) mozda je tu greska?!
Post Napisano: 04 Feb 2012, 11:07
Kod novijih Xorg servera nije potreban xorg.conf. Samo se naprave parcijalne datoteke za potrebni deo u /etc/X11/xorg.conf.d/.
Na primer kod mene:
$ ls -1 /etc/X11/xorg.conf.d/
00-files.conf
01-mouse.conf
02-keyboard.conf
03-device.conf
04-monitor.conf
Mada mi nije sve ovo potrebno. Ali volim da imam malo veću kontrolu pa sam ručno specifikovao parametre. :)
Post Napisano: 04 Feb 2012, 11:09
Da li možeš da okačiš taj xorg.conf? Mislim da je qki to već tražio ranije u temi. ;)
Post Napisano: 04 Feb 2012, 11:30
Ko sisa sneg, cisticemo... evo ga taj izmenjeni xorg.conf.
Kao sto sam i napisao dodao sam celu dri sekciju i dodao ovo sto pise u sekciji module.
xorg.txt
(911 Bytes) Downloaded 361 times
Post Napisano: 04 Feb 2012, 11:43
Ok, neka qki to pogleda, pa ćemo odvojiti šta treba. Ne mogu tu mnogo da ti pomognem. Imam Nvidiu.
Post Napisano: 04 Feb 2012, 11:46
Btw, možda da probaš sa OSS drajverom kao što je qki predložio?
Post Napisano: 04 Feb 2012, 11:57
Mislim da je onaj ATI HowTo malo zastario. Ja sam obećao svašta napisati na temu te dokumentacije, ali nikako da stignem. Uglavnom, neka stoji da sam voljan :cheesy: ažurirati taj članak.
OSS drajver je odličan, moj predlog i dalje stoji. Međutim, kad smo već započeli ovo, ipak da mi to pokušamo rješiti. Bocke, s obzirom da je ovo vezano za hardver, šta misliš da se formira nova tema i prebaci ova prepiska ili kad završimo?
Ja bih preimenovao taj xorg.conf i napravio minimalni snippet po bocke-tovom kalupu.
# mv /etc/X11/xorg.conf /etc/X11/xorg.conf.fglrx-bak
# touch /etc/X11/xorg.conf.d/03-device.conf
Onda u ovaj /etc/X11/xorg.conf.d/03-device.conf ubaci samo ovo:
Section "Device"
	Identifier  "aticonfig-Device[0]-0"
	Driver      "fglrx"
	BusID       "PCI:2:0:0"
EndSection
Ostalo pusti xorg.conf da konfiguriše.
Poslije ćemo ubaciti za monitor i screen, ako bude bilo potrebe.
Post Napisano: 04 Feb 2012, 12:07
Posto trenutno koristim xorg.conf-vesa, a xorg.conf mi je preimenovan u .bak da vratim sve na pocetno rucnim preimenovanjem odradim ovo sto si napisao i uradim aticonfig --initial?
Post Napisano: 04 Feb 2012, 12:26
Postojeći xorg.conf preimenuj kako god želiš. Bitno je da u /etc/X11 ne postoji daoteka koja se zove samo "xorg.conf".
Znači, može i:
# cd /etc/X11
# mv xorg.conf xorg.conf-sinisa
Nemoj pokretati aticonfig, jer će ti on opet generisati ovaj xorg.conf. Samo napravi novu datoteku (to radi ona komanda touch) i u nju ubaci ono što sam stavio.
Users browsing this forum: No registered users and 31 guests
