Mate 1.5 je razvojno izdanje koje predhodi konačnom cilju a to je MATE 1.6.MATE 1.5 is a development release, which will eventually lead to the 1.6 stable release. It is not complete yet, some parts are still missing. The most important is probably mate-terminal 1.5 which has not been released yet, but you all probably have alternatives for that. Once the MATE developers release a working tarball, I'll add this to the packages that I'm providing. Otherwise, MATE 1.5 seems to work fine here, no obvious problems that I can find until now. You can install these packages if you want to have a peek at what the 1.6 version will bring and report any issues you might have to the MATE developers, so that the 1.6 release will be the best that it can be.
Instalaciju je najlakše uraditi preko slap-get ili gslap alata.
U /etc/slapt-getrc treba dodati sledeće linije u zavisnosti od arhitekture računara
32bit
SOURCE=http://slackware.org.uk/salix/i486/14.0/:PREFERRED
SOURCE=http://people.salixos.org/gapan/mate_1.5_for_slack14.0/i486/:CUSTOM
SOURCE=http://slackware.org.uk/salix/x86_64/14.0/:PREFERRED
SOURCE=http://people.salixos.org/gapan/mate_1.5_for_slack14.0/x86_64/:CUSTOM
slapt-get --install-set mate
Izvor: http://www.linuxquestions.org/questions ... ost4849959" onclick="window.open(this.href);return false;
Inače Mate 1.5 radi dosta dobro. ps
Bilo bi dobro preći na runlevel 4.
