Nadogradnja Fluxbox-a
Moderators: Sinisa, Urednik
Post Napisano: 24 Mar 2013, 02:07
Ono što će obradovati korisnike Fluxbox okruženja jeste da je nadogradnja na poslednju stabilnu verziju krajnje jednostavna ;)
Uz Slackware 14 dolazi Fluxbox 1.3.2 a najnovija verzija ima oznaku 1.3.5 i to je verzija koja je već u -current grani.
Za početak preuzeti Fluxbox source sa sledeće adrese http://sourceforge.net/projects/fluxbox ... .5.tar.bz2" onclick="window.open(this.href);return false;
Zatim preuzeti fluxbox.Slackbuild iz Slackware 14 instalacionog DVD-a. Nalazi se u source/xap/fluxbox/
Fluxbox.Slackbuild treba napraviti izvršnim komandom
# chmod +x fluxbox.SlackBuild
slede komande
# ./fluxbox.SlackBuild
# upgradepkg /tmp/fluxbox-1.3.5-x86_64-4.txz
Proveru nove verzije možemo uraditi putem komande
fluxbox -v
Da vidimo sad korisne adrese :)
Matična stranica - http://fluxbox.org/" onclick="window.open(this.href);return false;
Preuzimanje - http://fluxbox.org/download/" onclick="window.open(this.href);return false;
Još samo da nađem neki change log da se vide promene prema novijoj verziji...
Verzija 1.3.3:
This is mostly a bug fix release. For a more complete list and detailed
description of them see the documentation and ChangeLog.
General:
* Added 'NearestCorner', 'NearestEdge' and 'NearestCornerOrEdge' resize
methods
* Added percentage values for commands such as ResizeWindow
* Added style ressources 'menu.hilite.font', 'menu.hilite.justify'
* Added 'OnTab' modifier for keys file
* Added _MOTIF_WM_INFO atom to advertise motif capabilities
* Added 'fullscreen', 'maximizedhorizontal', 'maximizedvertical' tests to
client patterns
* Added option to revert focus to previous window only on current head in
a multi-monitor setup
* Rewrite of FbTk::TextureRenderer (simpler code)
* Improved building on Microsoft Windows
Critical Bugfixes in 1.3.3:
* Use of monotonic increasing clock for timer, not affected by leap seconds etc.
Other Bugfixes:
* Fixed placement off transient windows in a multi-monitor setup with 'holes'
* Fixed usage of '~' as part of style filenames
* Replaced (deprecated) XKeycodeToKeysym() with XkbKeycodeToKeysym()
* Improved vertical alignment of text in decorations
* Fixed compiler and code style issues
* Updated italian translations
Fluxbox 1.3.4
General:
* Added 'LHalf' / 'RHalf' titlebar buttons
* Added 'ClientPatternTest' command for testing clientpatterns via
fluxbox-remote
* Added 'he_IL' translations
Critical Bugfixes in 1.3.4:
* All timer based problems are fixed now
* Fixed integer overflows for some gradient textures
* Fixed compile issue on MacOS
Other Bugfixes:
* Correct renderinger of 'sunken' textures
* Move windows without the lagging-behind-effect on slower machines
* Improved color brightening in textures
* Memory and other code improvements in texture rendering code
* Fix build-system issues
I Fluxbox 1.3.5
Version 1.3.5 is a bug fix release.
Critical Bugfixes in 1.3.5:
* Reenabled 'If' 'Or' 'And' actions again
Eto :grin:
E sad još i screenshot
Fluxbox 1.3.5
Post Napisano: 24 Mar 2013, 09:39
Stereo, da li upgrade menja postojeće postavke okruženja? (barem da uradim backup, mada kad bolje razmislim svakako ću ga uraditi menjao postavke ili ne).
Još jedno pitanjce. Ne ide mi za rukom nikako da ubacim xfce4-mixer u systray.
Stavio sam ga u .fluxbox.startup ali se ne pokreće.
Kada ga pokrenem na run, samo mi otvori xfce4-mixer bez ikonice u systray-u. Imaš li neki hint slučajno?
Post Napisano: 24 Mar 2013, 10:35
Nisam primetio nikakve promene nakon nadogradnje, bar ne što se vizuelnog dela tiče. Još uvek proveravam u realnom radu kako ide i sve je dobro za sad.
A što se tiče volume mixera, taj xfce4-mixer nemoj da se mučiš, probaj Volti (http://slackbuilds.org/repository/14.0/audio/volti/" onclick="window.open(this.href);return false;). Taj je i kod mene i postavi samo
volti &
u .fluxbox/startup i radiće svaki put kad pokreneš sistem.
Post Napisano: 24 Mar 2013, 11:14
Odlicno, volti radi kako valja :beer:
Hvala Stereo. :beer:
Krecem jos malo da uradim upgrade Fluxa.
Dodatak
Nadogradjem Flux na verziju 1.3.5. :beer:
Post Napisano: 24 Mar 2013, 13:55
stereo wrote: Zatim preuzeti fluxbox.Slackbuild iz Slackware 14 instalacionog DVD-a. Nalazi se u source/xap/fluxbox/
Napomenuo bih samo da sa ove lokacije treba preuzeti sve fajlove koji se tamo nalaze, ne samo fluxbox.SlackBuild da bi kompajliranje i pokretanje okruženja bilo uspešno.
Hvala @Broker for the tip ;)
