[CALC] Streaming + bandwith calc
Post Napisano: 18 Jul 2012, 00:48
vjerujem da su se svi susretali sa ovim problemom pa da malo pojasnim.
Streaming:
192 KBps / 8 = 24 KB/s
24577 * 3600= 84 MB/h
Sto znaci da stream od 192 Kbps generise oko 84 MB za jedan sat.
Bandwith:
recimo da imamo 100 MBps. Koliko bi to bilo paketa ?
8300 * 1500 * 8 = 99.6 MBps
Kako napraviti ovako nesto ?
Na PC2:
netsniff-ng -s -d eth0
na PC1 (saljemo 100 paketa da provjerimo rad):
ping -c 100 -q -s 1472 -f <IP PC2> &  # << ovo cemo da vratimo u pozadinu
na PC2 (ctrl+c) dobijamo:
captured frames: 203, captured bytes: 303016 [295 KB, 0 MB, 0 GB]
Ako ovo prodje ok, pokrenucemo nekoliko instanci pinga i to ovako:
ping -q -s 1472 -f <IP PC2> & # (uradite nekoliko puta)
ili
#!/bin/bash
#-------------- scripta za testiranje
#za 1 GBps je broj 100 ok , za 100 mbps bi trebalo oko 20
for i in {1..100}
do
   ping -q -s 1472 -f <IP PC2> >> /dev/null &
done
# 200 sek flooda
sleep 200
killall -HUP ping
# pobij stoku
Kao sto vidimo , mozemo koristiti i ovako.
Na drugoj strani pokrecemo:
i kad odradi ping uradite sljedece:
CTRL+c i dobijete
netsniff-ng 0.5.4.2 -- pid (1754)
nice (-20), scheduler (1 prio 99)
1 of 1 CPUs online, affinity bitstring (1)
No filter applied. Sniffing all traffic.
128.00 MB allocated for rx ring
 [ 8192 blocks, 65536 frames ]
 [ 8 frames per block ]
 [ framesize: 2048 bytes, blocksize: 16384 bytes ]
^Ccaught SIGINT! ... bye bye
203 frames incoming
203 frames passed filter
0 frames failed filter (due to out of space)
captured frames: 202, captured bytes: 302962 [295 KB, 0 MB, 0 GB]
A inace 100 MBps je 104 857 600 bytes
(104 857 600 / 1500) / 8 = 8 738.13333
mada je otp do 8300 packeta neki maksimum.
guglajte packet generatori: hping3, i sl
Reason: BBkod.
