Sta kaze!
iptables v1.2.2: can't initialize iptables table `filter': iptables who? (do you need to insmod?)
Perhaps iptables or your kernel needs to be upgraded.
Hvala svima na pomoci!
Ok. Koji kernel koristiš? Koji distro?ferguson wrote:mnogo mi onda komplikuje stvar sada... ali to je vazno da radi ova komanda!Code: Select all
iptables v1.2.2: can't initialize iptables table `filter': iptables who? (do you need to insmod?) Perhaps iptables or your kernel needs to be upgraded.
modprobe iptable_filter
modprobe: Can't open dependencies file /lib/modules/2.2.20/modules.dep (No such file or directory)
We have a problem.ferguson wrote: Ukuca sam i ovo mi je javio:
... i ... sta je "distro"?Code: Select all
Kernel je valjda ovo sto pise... 2.2.20? Zar ne?
Ja ti to toplo preporučujem. Koja je to distribucija u pitanju? Slackware 4? 3??ferguson wrote: A o update kernela da i ne razmisljam, zar ne? ;D
make mrproper
make menuconfig
make
make modules_install
cp ovo
cp ono
cat slackware-version
8.0.0 (åtta)
Znači osmica. Okej. Jesi li razmišljao o upgrade-u?ferguson wrote: Hm...
pise:
A kada uradim update kernela, gubim li neke podatke, neka stelovanja...Code: Select all
cat slackware-version 8.0.0 (åtta)
Meni je server nastelovan da se podize sve automatski, pa ako bi se to sjebalo... mnogo bi mi bilo zajebano!
Uh...ferguson wrote: Kako to sve lepo zvuci kada ti pricas!
Ali ja nemam pojma kako to da uradim... jedino da otvorim novu temu pa korak po korak...
Veruj mi... update kernela ili novi kernel je spansko selo za mene!
image = /boot/vmlinuz-2.4.20
root = /dev/hda1 # <-OVDE STAVI SVOJU ROOT PARTICIJU
label = slack24
read-only
Users browsing this forum: No registered users and 24 guests
