Slackware 14
Post Napisano: 28 Sep 2012, 22:53
Konačno, izašla je nova verzija Slacka :) Uživajte!!!
Wed Sep 26 01:10:42 UTC 2012
Slackware 14.0 x86_64 stable is released!
We're perfectionists here at Slackware, so this release has been a long
time a-brewing. But we think you'll agree that it was worth the wait.
Slackware 14.0 combines modern components, ease of use, and flexible
configuration... our "KISS" philosophy demands it.
The ISOs are off to be replicated, a 6 CD-ROM 32-bit set and a dual-sided
32-bit/64-bit x86/x86_64 DVD. Please consider supporting the Slackware
project by picking up a copy from store.slackware.com. We're taking
pre-orders now, and offer a discount if you sign up for a subscription.
Thanks to everyone who helped make this happen. The Slackware team, the
upstream developers, and (of course) the awesome Slackware user community.
Have fun! :-)
http://www.slackware.com/changelog/curr ... cpu=x86_64" onclick="window.open(this.href);return false;
Slackware 14.0 is released!
That's right, the long wait is finally over and a new stable release of Slackware has arrived! Since our last stable release, a lot has changed in the Linux and FOSS world. The kernel has moved on to major version 3 (we're using the long term supported 3.2.29 kernel for this release), X.org has released X11R7.7, and Firefox has had a whopping *11* major releases to arrive at version 15.0.1! We've brought together the best of these and other modern components and worked our magic on them. You'll find new compilers (including the LLVM/clang compiler that's becoming a popular alternative to gcc), development tools, libraries, and applications throughout, all prepared with our careful and rigourous testing. If you've used Slackware before, you'll find the system feels like home. But we've also added new features such as NetworkManager for easy setup and management of wired and wireless networking (or, you can still use the traditional network setup if you prefer). And, we've updated the desktops and window managers to recent versions as well..
http://www.slackware.com/index.php" onclick="window.open(this.href);return false;
Post Napisano: 29 Sep 2012, 00:03
Koji KDE koristi ? :)
Post Napisano: 29 Sep 2012, 00:24
KDE 4.8.5. 4.9+ je dostupan kod AlienBoba.
Post Napisano: 29 Sep 2012, 00:32
Ok. Hvala na informaciji :)
Edit: Da li moze link od ftp-a na privatnu ? :)
Post Napisano: 29 Sep 2012, 00:42
Za Slack ili KDE 4.9? :)
Ako je ovo prvo u pitanju, mirror odakle ga lično trenutno skidam je sa slackware.org.uk:
http://slackware.org.uk/slackware/slackware-14.0-iso/" onclick="window.open(this.href);return false;
KDE 4.9.1 je dostupan sa:
http://alien.slackbook.org/ktown/current/4.9.1/" onclick="window.open(this.href);return false;
Nadam se da to odgovara na pitanje. :)
Post Napisano: 29 Sep 2012, 01:01
Za KDE mi je trebalo... Hvala :)
Jos malo radim instalaciju Slackware 14 pa KDE 4.9.1 i javljam utiske i dajem skrinove :)
Post Napisano: 29 Sep 2012, 10:12
Važi. :)
Elem, informacija koja bi nekima mogla biti korisna (brok, gde si?). :) U x86 verziji (32-bita) podrazumevani huge-smp kernel sada dolazi sa PAE podrškom, dok je huge kernel kompajliran bez PAE podrške.
Post Napisano: 29 Sep 2012, 11:38
Postoji li mogućnost apgrejda sa verzije 13.37, ili se preporučuje nova instalacija?
Post Napisano: 29 Sep 2012, 11:42
Postoji mogućnost upgrade-a. Koji sistem koristiš, 32bit ili 64bit?
Post Napisano: 29 Sep 2012, 11:49
32bit
