Napisano: 16 Dec 2020, 16:28
24.11.2020.
Sveži mutt paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/mutt-1.10.1-i586-2_slack14.2.txz: Rebuilt.
Mutt had incorrect error handling when initially connecting to an IMAP
server, which could result in an attempt to authenticate without enabling TLS.
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-28896
Napisano: 16 Dec 2020, 16:29
25.11.2020.
patches/packages/bind-9.11.25-i586-1_slack14.2.txz: Upgraded.
This update fixes bugs, including a denial-of-service security issue:
After a Negative Trust Anchor (NTA) is added, BIND performs periodic
checks to see if it is still necessary. If BIND encountered a failure
while creating a query to perform such a check, it attempted to
dereference a NULL pointer, resulting in a crash. [GL #2244]
Napisano: 16 Dec 2020, 16:30
07.12.2020.
Sveži seamonkey paketi za Slackware 14.2 i -current:
patches/packages/seamonkey-2.53.5.1-i686-1_slack14.2.txz: Upgraded.
https://www.seamonkey-project.org/releases/seamonkey2.53.5.1
Napisano: 16 Dec 2020, 16:31
09.12.2020.
patches/packages/curl-7.74.0-i586-1_slack14.2.txz: Upgraded.
This release includes the following security related bugfixes:
Inferior OCSP verification [93]
FTP wildcard stack overflow [95]
Trusting FTP PASV responses [97]
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-8286
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-8285
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-8284
Napisano: 16 Dec 2020, 16:32
12.12.2020.
Sveži p11-kit paketi za Slackware 14.2 i -current:
patches/packages/p11-kit-0.23.22-i586-1_slack14.2.txz: Upgraded.
Fix memory-safety issues that affect the RPC protocol.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-29361
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-29362
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-29363
Napisano: 13 Feb 2021, 20:30
11.01.2021.
Sveži sudo paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/sudo-1.9.5-i586-1_slack14.2.txz: Upgraded.
Potential information leak in sudoedit that could be used to test for
the existence of directories not normally accessible to the user.
Flaw in the temporary file handling of sudoedit's SELinux RBAC support.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-23239
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-23240
Napisano: 13 Feb 2021, 20:31
14.01.2021.
Sveži wavpack paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/wavpack-5.4.0-i586-1_slack14.2.txz: Upgraded.
WavPack 5.4.0 fixes an issue where a specially crafted WAV file could cause
the wavpack command-line program to crash with an out-of-bounds write.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-35738
Napisano: 13 Feb 2021, 20:32
24.01.2021
patches/packages/seamonkey-2.53.6-i686-1_slack14.2.txz: Upgraded.
https://www.seamonkey-project.org/releases/seamonkey2.53.6
Napisano: 13 Feb 2021, 20:33
26.01.2021.
patches/packages/sudo-1.9.5p2-i586-1_slack14.2.txz: Upgraded.
When invoked as sudoedit, the same set of command line options
are now accepted as for "sudo -e". The -H and -P options are
now rejected for sudoedit and "sudo -e" which matches the sudo
1.7 behavior. This is part of the fix for CVE-2021-3156.
Fixed a potential buffer overflow when unescaping backslashes
in the command's arguments. Normally, sudo escapes special
characters when running a command via a shell (sudo -s or sudo
-i). However, it was also possible to run sudoedit with the -s
or -i flags in which case no escaping had actually been done,
making a buffer overflow possible. This fixes CVE-2021-3156.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-3156
Napisano: 13 Feb 2021, 20:34
09.02.2021.
Sveži dnsmasq paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/dnsmasq-2.84-i586-1_slack14.2.txz: Upgraded.
This update fixes bugs and remotely exploitable security issues:
Use the values of --min-port and --max-port in outgoing
TCP connections to upstream DNS servers.
Fix a remote buffer overflow problem in the DNSSEC code. Any
dnsmasq with DNSSEC compiled in and enabled is vulnerable to this,
referenced by CVE-2020-25681, CVE-2020-25682, CVE-2020-25683
CVE-2020-25687.
Be sure to only accept UDP DNS query replies at the address
from which the query was originated. This keeps as much entropy
in the {query-ID, random-port} tuple as possible, to help defeat
cache poisoning attacks. Refer: CVE-2020-25684.
Use the SHA-256 hash function to verify that DNS answers
received are for the questions originally asked. This replaces
the slightly insecure SHA-1 (when compiled with DNSSEC) or
the very insecure CRC32 (otherwise). Refer: CVE-2020-25685.
Handle multiple identical near simultaneous DNS queries better.
Previously, such queries would all be forwarded
independently. This is, in theory, inefficent but in practise
not a problem, _except_ that is means that an answer for any
of the forwarded queries will be accepted and cached.
An attacker can send a query multiple times, and for each repeat,
another {port, ID} becomes capable of accepting the answer he is
sending in the blind, to random IDs and ports. The chance of a
succesful attack is therefore multiplied by the number of repeats
of the query. The new behaviour detects repeated queries and
merely stores the clients sending repeats so that when the
first query completes, the answer can be sent to all the
clients who asked. Refer: CVE-2020-25686.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-25681
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-25682
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-25683
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-25684
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-25685
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-25686
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-25687
Users browsing this forum: No registered users and 37 guests
