Locked
Post Napisano: 14 Jan 2018, 11:13
19.12.2017.
Sveži ruby paket za Slackware 14.2 i -current:
patches/packages/ruby-2.2.9-i586-1_slack14.2.txz:  Upgraded.
  Net::FTP#get, getbinaryfile, gettextfile, put, putbinaryfile, and puttextfile
  use Kernel#open to open a local file. If the localfile argument starts with
  the pipe character "|", the command following the pipe character is executed.
  The default value of localfile is File.basename(remotefile), so malicious FTP
  servers could cause arbitrary command execution.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-17405
22.12.2017.
Sveži mozilla-thunderbird paket za Slackware 14.2 i -current:
patches/packages/mozilla-thunderbird-52.5.2-i586-1_slack14.2.txz:  Upgraded.
    https://www.mozilla.org/en-US/thunderbird/52.5.2/releasenotes/
Post Napisano: 14 Jan 2018, 11:14
08.01.2018.
Sveži irssi paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/irssi-1.0.6-i586-1_slack14.2.txz:  Upgraded.
  This update fixes multiple security vulnerabilities.
    https://irssi.org/security/irssi_sa_2018_01.txt
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-5205
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-5206
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-5207
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-5208
Post Napisano: 18 Jan 2018, 19:16
15.01.2018.
Sveži kernel paketi za Slackware 14.0 i 14.2:
patches/packages/linux-4.4.111/*:  Upgraded.
  This kernel includes mitigations for the Spectre (variant 2) and Meltdown
  speculative side channel attacks.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-5715
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-5754
Post Napisano: 18 Jan 2018, 19:17
17.01.2018.
Sveži bind paketi za Slackware 13.0, 13.1, 13.37, 14.0, 14.1, 14.2 i -current:
patches/packages/bind-9.10.6_P1-i586-1_slack14.2.txz:  Upgraded.
  This update fixes a high severity security issue:
  Improper sequencing during cleanup can lead to a use-after-free error,
  triggering an assertion failure and crash in named.
    https://kb.isc.org/article/AA-01542
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-3145
Post Napisano: 28 Jan 2018, 22:45
20.01.2018.
patches/packages/mozilla-firefox-52.6.0esr-i586-1_slack14.2.txz:  Upgraded.
  Specifically, this update contains performance.now() mitigations for Spectre.
    https://blog.mozilla.org/security/2018/01/03/mitigations-landing-new-class-timing-attack/
Post Napisano: 28 Jan 2018, 22:46
24.01.2018.
patches/packages/curl-7.58.0-i586-1_slack14.2.txz:  Upgraded.
  HTTP authentication leak in redirects
  HTTP/2 trailer out-of-bounds read
    https://curl.haxx.se/docs/adv_2018-b3bf.html
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1000007
    https://curl.haxx.se/docs/adv_2018-824a.html
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1000005
Post Napisano: 28 Jan 2018, 22:47
25.01.2018.
Sveži mozilla-thunderbird paketi za Slackware 14.2 i -current:
patches/packages/mozilla-thunderbird-52.6.0-i586-1_slack14.2.txz:  Upgraded.
    https://www.mozilla.org/en-US/thunderbird/52.6.0/releasenotes/
Post Napisano: 04 Feb 2018, 13:01
01.02.2018.
Sveži rsync paketi za Slackware 13.0, 13.1, 13.37, 14.0, 14.1, 14.2 i -current:
patches/packages/rsync-3.1.3-i586-1_slack14.2.txz:  Upgraded.
  Fixed a buffer overrun in the protocol's handling of xattr names and
  ensure that the received name is null terminated.
  Fix an issue with --protect-args where the user could specify the arg in
  the protected-arg list and short-circuit some of the arg-sanitizing code.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-16548
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-5764
Sveži mariadb paketi za Slackware 14.1, 14.2 i -current:
patches/packages/mariadb-10.0.34-i586-1_slack14.2.txz:  Upgraded.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-2562
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-2622
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-2640
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-2665
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-2668
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-2612
Post Napisano: 04 Feb 2018, 13:02
03.02.2018.
Sveži php paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/php-5.6.33-i586-1_slack14.2.txz:  Upgraded.
  This update fixes bugs and security issues, including:
  Potential infinite loop in gdImageCreateFromGifCtx.
  Reflected XSS in .phar 404 page.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-5711
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-5712
Locked
