Locked
Post Napisano: 25 Feb 2018, 18:52
06.02.2018.
Sveži kernel paketi za Slackware 14.2 u cilju sprečavanja Spectra V2 napada:
patches/packages/linux-4.4.115/*:  Upgraded.
  This kernel includes full retpoline mitigation for the Spectre (variant 2)
  speculative side channel attack.
  Please note that this kernel was compiled with gcc-5.5.0, also provided as
  an update for Slackware 14.2. You'll need to install the updated gcc in order
  to compile kernel modules that will load into this updated kernel.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-5715
Post Napisano: 25 Feb 2018, 18:54
15.02.2018.
Sveži irssi paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/irssi-1.0.7-i586-1_slack14.2.txz:  Upgraded.
    https://irssi.org/security/html/irssi_sa_2018_02
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-7054
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-7053
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-7050
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-7052
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-7051
Post Napisano: 04 Mar 2018, 00:20
26.02.2018.
patches/packages/linux-4.4.118/*:  Upgraded.
  This kernel includes __user pointer sanitization mitigation for the Spectre
  (variant 1) speculative side channel attack.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-5753
Post Napisano: 04 Mar 2018, 00:22
01.03.2018.
Sveži dhcp paketi za Slackware 13.0, 13.1, 13.37, 14.0, 14.1, 14.2 i -current:
patches/packages/dhcp-4.4.1-i586-1_slack14.2.txz:  Upgraded.
    Corrected an issue where large sized 'X/x' format options were causing
  option handling logic to overwrite memory when expanding them to human
  readable form. Reported by Felix Wilhelm, Google Security Team.
    Option reference count was not correctly decremented in error path
  when parsing buffer for options. Reported by Felix Wilhelm, Google
  Security Team.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-5732
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-5733
Post Napisano: 04 Mar 2018, 00:23
01.03.2018.
Sveži ntp paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/ntp-4.2.8p11-i586-1_slack14.2.txz:  Upgraded.
  This release addresses five security issues in ntpd:
  * LOW/MEDIUM: Sec 3012 / CVE-2016-1549 / VU#961909: Sybil vulnerability:
    ephemeral association attack. While fixed in ntp-4.2.8p7, there are
    significant additional protections for this issue in 4.2.8p11.
    Reported by Matt Van Gundy of Cisco.
  * INFO/MEDIUM: Sec 3412 / CVE-2018-7182 / VU#961909: ctl_getitem(): buffer
    read overrun leads to undefined behavior and information leak.
    Reported by Yihan Lian of Qihoo 360.
  * LOW: Sec 3415 / CVE-2018-7170 / VU#961909: Multiple authenticated
    ephemeral associations. Reported on the questions@ list.
  * LOW: Sec 3453 / CVE-2018-7184 / VU#961909: Interleaved symmetric mode
    cannot recover from bad state. Reported by Miroslav Lichvar of Red Hat.
  * LOW/MEDIUM: Sec 3454 / CVE-2018-7185 / VU#961909: Unauthenticated packet
    can reset authenticated interleaved association.
    http://support.ntp.org/bin/view/Main/SecurityNotice#February_2018_ntp_4_2_8p11_NTP_S
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-1549
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-7182
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-7170
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-7184
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-7185
Post Napisano: 17 Mar 2018, 08:42
08.03.2018.
Sveži openssh paketi za Slackware 13.0, 13.1, 13.37, 14.0, 14.1 i 14.2:
patches/packages/openssh-7.4p1-i586-2_slack14.2.txz:  Rebuilt.
  sftp-server: in read-only mode, sftp-server was incorrectly permitting
  creation of zero-length files. Reported by Michal Zalewski.
  Thanks to arny (of Bluewhite64 fame) for the heads-up.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-15906
Sveži php paketi za Slackware 14.0, 14.1, 14.2, and -current:
patches/packages/php-5.6.34-i586-1_slack14.2.txz:  Upgraded.
  This update fixes a stack buffer overflow vulnerability.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-7584
Post Napisano: 17 Mar 2018, 08:45
13.03.2018.
patches/packages/mozilla-firefox-52.7.0esr-i586-1_slack14.2.txz:  Upgraded.
    https://www.mozilla.org/en-US/security/advisories/mfsa2018-07/
Sveži samba paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/samba-4.4.16-i586-3_slack14.2.txz:  Rebuilt.
  This is a security update in order to patch the following defect:
    On a Samba 4 AD DC the LDAP server in all versions of Samba from
  4.0.0 onwards incorrectly validates permissions to modify passwords
  over LDAP allowing authenticated users to change any other users`
  passwords, including administrative users.
    https://www.samba.org/samba/security/CVE-2018-1057.html
    https://wiki.samba.org/index.php/CVE-2018-1057
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1057
Post Napisano: 17 Mar 2018, 08:47
15.03.2018.
patches/packages/curl-7.59.0-i586-1_slack14.2.txz:  Upgraded.
  FTP path trickery leads to NIL byte out of bounds write
  LDAP NULL pointer dereference
  RTSP RTP buffer over-read
    https://curl.haxx.se/docs/adv_2018-9cd6.html
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1000120
    https://curl.haxx.se/docs/adv_2018-97a2.html
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1000121
    https://curl.haxx.se/docs/adv_2018-b047.html
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1000122
Post Napisano: 17 Mar 2018, 08:49
16.03.2018.
patches/packages/mozilla-firefox-52.7.2esr-i586-1_slack14.2.txz:  Upgraded.
    https://www.mozilla.org/en-US/security/advisories/mfsa2018-08/
Post Napisano: 01 Apr 2018, 08:48
17.03.2018.
Sveži libvorbis paketi za Slackware 13.37, 14.0, 14.1, 14.2 i -current:
patches/packages/libvorbis-1.3.6-i586-1_slack14.2.txz:  Upgraded.
  This release fixes security issues.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-14632
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-14633
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-5146
Locked
