Locked
Post Napisano: 08 Aug 2020, 19:21
03.06.2020.
Sveži gnutls paketi za Slackware 14.2 i -current:
patches/packages/gnutls-3.6.14-i586-1_slack14.2.txz:  Upgraded.
  Fixed insecure session ticket key construction, since 3.6.4. The TLS server
  would not bind the session ticket encryption key with a value supplied by
  the application until the initial key rotation, allowing attacker to bypass
  authentication in TLS 1.3 and recover previous conversations in TLS 1.2.
  [GNUTLS-SA-2020-06-03, CVSS: high]
Post Napisano: 08 Aug 2020, 19:22
04.06.2020.
Sveži mozilla-thunderbird paketi za Slackware 14.2 i -current:
patches/packages/mozilla-thunderbird-68.9.0-i686-1_slack14.2.txz:  Upgraded.
    https://www.mozilla.org/en-US/thunderbird/68.9.0/releasenotes/
    https://www.mozilla.org/en-US/security/advisories/mfsa2020-22/
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-12399
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-12405
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-12406
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-12410
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-12398
Post Napisano: 08 Aug 2020, 19:23
11.06.2020.
Sveži kernel stigao za Slackware 14.2:
patches/packages/linux-4.4.227/*:  Upgraded.
  These updates fix various bugs and security issues, including a mitigation
  for SRBDS (Special Register Buffer Data Sampling). SRBDS is an MDS-like
  speculative side channel that can leak bits from the random number generator
  (RNG) across cores and threads.
    Fixed in 4.4.218:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-11668
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-11608
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-11609
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-10942
    Fixed in 4.4.219:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-11494
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-11565
    Fixed in 4.4.220:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-12826
    Fixed in 4.4.221:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-19319
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-12464
    Fixed in 4.4.222:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-10751
    Fixed in 4.4.224:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-10711
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-1749
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-12769
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-10690
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-13143
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-19768
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-12770
    Fixed in 4.4.225:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-9517
    Fixed in 4.4.226:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-10732
    Fixed in 4.4.227:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-0543
Post Napisano: 08 Aug 2020, 19:24
18.06.2020.
patches/packages/bind-9.11.20-i586-1_slack14.2.txz:  Upgraded.
  It was possible to trigger an INSIST in lib/dns/rbtdb.c:new_reference() with
  a particular zone content and query patterns.
    https://kb.isc.org/docs/cve-2020-8619
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-8619
Post Napisano: 08 Aug 2020, 19:26
23.06.2020.
Sveži ntp paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/ntp-4.2.8p15-i586-1_slack14.2.txz:  Upgraded.
  This release fixes one vulnerability: Associations that use CMAC
  authentication between ntpd from versions 4.2.8p11/4.3.97 and
  4.2.8p14/4.3.100 will leak a small amount of memory for each packet.
  Eventually, ntpd will run out of memory and abort.
Post Napisano: 08 Aug 2020, 19:32
24.06.2020.
patches/packages/curl-7.71.0-i586-1_slack14.2.txz:  Upgraded.
  curl overwrite local file with -J [111]
  Partial password leak over DNS on HTTP redirect [48]
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-8177
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-8169
Sveži libjpeg-turbo paketi za Slackware 14.2 i -current:
patches/packages/libjpeg-turbo-2.0.5-i586-1_slack14.2.txz:  Upgraded.
  This update fixes bugs and a security issue:
  Fixed an issue in the PPM reader that caused a buffer overrun in cjpeg,
  TJBench, or the `tjLoadImage()` function if one of the values in a binary
  PPM/PGM input file exceeded the maximum value defined in the file's header
  and that maximum value was less than 255.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-13790
Post Napisano: 08 Aug 2020, 19:33
29.06.2020.
patches/packages/mozilla-firefox-68.10.0esr-i686-1_slack14.2.txz:  Upgraded.
    https://www.mozilla.org/en-US/firefox/68.10.0/releasenotes/
Post Napisano: 08 Aug 2020, 19:56
04.07.2020.
Sveži libvorbis paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/libvorbis-1.3.7-i586-1_slack14.2.txz:  Upgraded.
  Fix out-of-bounds read encoding very low sample rates.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-10393
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-14160
Post Napisano: 08 Aug 2020, 19:57
07.07.2020.
Sveži seamonkey paketi za Slackware 14.2 i -current:
patches/packages/seamonkey-2.53.3-i686-1_slack14.2.txz:  Upgraded.
    https://www.seamonkey-project.org/releases/seamonkey2.53.3
Post Napisano: 08 Aug 2020, 19:58
27.07.2020.
patches/packages/mozilla-firefox-68.11.0esr-i686-1_slack14.2.txz:  Upgraded.
    https://www.mozilla.org/en-US/firefox/68.11.0/releasenotes/
Locked
