Locked
Post Napisano: 08 Aug 2020, 19:59
31.07.2020.
Sveži mozilla-thunderbird paketi za Slackware 14.2 i -current:
patches/packages/mozilla-thunderbird-68.11.0-i686-1_slack14.2.txz:  Upgraded.
    https://www.mozilla.org/en-US/thunderbird/68.11.0/releasenotes/
    https://www.mozilla.org/en-US/security/advisories/mfsa2020-35/
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-15652
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-6514
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-6463
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-15659
Post Napisano: 22 Aug 2020, 13:43
19.08.2020.
patches/packages/curl-7.72.0-i586-1_slack14.2.txz:  Upgraded.
  libcurl: wrong connect-only connection [98]
    https://curl.haxx.se/docs/CVE-2020-8231.html
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-8231
Post Napisano: 22 Aug 2020, 13:44
21.08.2020.
patches/packages/bind-9.11.22-i586-1_slack14.2.txz:  Upgraded.
  This update fixes three security issues:
  "update-policy" rules of type "subdomain" were incorrectly treated as
  "zonesub" rules, which allowed keys used in "subdomain" rules to update
  names outside of the specified subdomains. The problem was fixed by making
  sure "subdomain" rules are again processed as described in the ARM.
  When BIND 9 was compiled with native PKCS#11 support, it was possible to
  trigger an assertion failure in code determining the number of bits in the
  PKCS#11 RSA public key with a specially crafted packet.
  It was possible to trigger an assertion failure when verifying the response
  to a TSIG-signed request.
    https://kb.isc.org/docs/cve-2020-8624
    https://kb.isc.org/docs/cve-2020-8623
    https://kb.isc.org/docs/cve-2020-8622
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-8624
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-8623
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-8622
Post Napisano: 02 Sep 2020, 15:24
24.08.2020.
patches/packages/mozilla-firefox-68.12.0esr-i686-1_slack14.2.txz:  Upgraded.
    https://www.mozilla.org/en-US/firefox/68.12.0/releasenotes/
Post Napisano: 20 Sep 2020, 13:14
04.09.2020.
Sveži gnutls paketi za Slackware 14.2 i -current:
patches/packages/gnutls-3.6.15-i586-1_slack14.2.txz:  Upgraded.
  libgnutls: Fixed "no_renegotiation" alert handling at incorrect timing,
  which could lead to an application crash.
  [GNUTLS-SA-2020-09-04, CVSS: medium]
Post Napisano: 20 Sep 2020, 13:15
12.09.2020.
Sveži Mozilla-Thunderbird paketi za Slackware 14.2 i -current:
patches/packages/mozilla-thunderbird-68.12.0-i686-1_slack14.2.txz:  Upgraded.
    https://www.mozilla.org/en-US/thunderbird/68.12.0/releasenotes/
    https://www.mozilla.org/en-US/security/advisories/mfsa2020-40/
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-15663
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-15664
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-15669
Post Napisano: 17 Oct 2020, 19:47
22.09.2020.
Sveži seamonkey paketi za Slackware 14.2 i -current:
patches/packages/seamonkey-2.53.4-i686-1_slack14.2.txz:  Upgraded.
    https://www.seamonkey-project.org/releases/seamonkey2.53.4
Post Napisano: 25 Oct 2020, 18:06
20.10.2020.
Sveži freetype paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/freetype-2.6.3-i586-3_slack14.2.txz:  Rebuilt.
  Fix heap buffer overflow in embedded PNG bitmap handling.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-15999
Post Napisano: 25 Oct 2020, 18:09
21.10.2020.
Svež kernel za Slackware 14.2:
patches/packages/linux-4.4.240/*:  Upgraded.
  These updates fix various bugs and security issues, including the recently
  discovered "Bleeding Tooth" vulnerability in the Bluetooth subsystem
  (CVE-2020-12351, CVE-2020-12352, and CVE-2020-24490).
    Fixed in 4.4.228:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-20810
    Fixed in 4.4.229:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-12771
    Fixed in 4.4.230:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-15393
    Fixed in 4.4.232:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-10323
    Fixed in 4.4.233:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-26088
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-19054
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-25212
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-9445
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-13094
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-8043
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-16166
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-14331
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-19448
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-19074
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-19073
    Fixed in 4.4.234:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-14314
    Fixed in 4.4.236:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-25285
    Fixed in 4.4.237:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-25284
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-14390
    Fixed in 4.4.238:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-25643
    Fixed in 4.4.239:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-25211
    Fixed in 4.4.240:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-12351
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-12352
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-24490
Locked
