Novosti u *current* -u
Post Napisano: 26 Nov 2017, 18:49
Slackware 64-bit
Sat Nov 25 07:44:07 UTC 2017
a/kernel-firmware-20171124git-noarch-1.txz: Upgraded.
a/kernel-generic-4.14.2-x86_64-1.txz: Upgraded.
a/kernel-huge-4.14.2-x86_64-1.txz: Upgraded.
a/kernel-modules-4.14.2-x86_64-1.txz: Upgraded.
ap/hplip-3.17.11-x86_64-1.txz: Upgraded.
d/kernel-headers-4.14.2-x86-1.txz: Upgraded.
d/rust-1.22.1-x86_64-1.txz: Upgraded.
k/kernel-source-4.14.2-noarch-1.txz: Upgraded.
l/libclc-20171115_3d994f2-x86_64-1.txz: Upgraded.
l/libfakekey-0.3-x86_64-1.txz: Upgraded.
xap/mozilla-thunderbird-52.5.0-x86_64-1.txz: Upgraded.
isolinux/initrd.img: Rebuilt.
kernels/*: Upgraded.
Slackware 32-bit
a/kernel-generic-4.14.2-i586-1.txz: Upgraded.
a/kernel-generic-smp-4.14.2_smp-i686-1.txz: Upgraded.
a/kernel-huge-4.14.2-i586-1.txz: Upgraded.
a/kernel-huge-smp-4.14.2_smp-i686-1.txz: Upgraded.
a/kernel-modules-4.14.2-i586-1.txz: Upgraded.
a/kernel-modules-smp-4.14.2_smp-i686-1.txz: Upgraded.
ap/hplip-3.17.11-i586-1.txz: Upgraded.
d/kernel-headers-4.14.2_smp-x86-1.txz: Upgraded.
d/rust-1.22.1-i686-1.txz: Upgraded.
k/kernel-source-4.14.2_smp-noarch-1.txz: Upgraded.
l/libclc-20171115_3d994f2-i586-1.txz: Upgraded.
l/libfakekey-0.3-i586-1.txz: Upgraded.
xap/mozilla-thunderbird-52.5.0-i586-1.txz: Upgraded.
extra/linux-4.14.2-nosmp-sdk/*: Upgraded.
Post Napisano: 29 Nov 2017, 18:28
Slackware 64-bit
Wed Nov 29 08:15:09 UTC 2017
a/coreutils-8.28-x86_64-2.txz: Rebuilt.
       Removed ancient (1992) aliases "dir, vdir, d, v" from the profile scripts.
a/lzlib-1.9-x86_64-1.txz: Added.
a/plzip-1.6-x86_64-1.txz: Added.
ap/man-1.6g-x86_64-3.txz: Removed.
ap/man-db-2.7.6.1-x86_64-1.txz: Added.
       This package replaces the good old man package. Thanks to B. Watson.
ap/man-pages-4.14-noarch-2.txz: Rebuilt.
       Don't ship a whatis database, since man-db doesn't need one.
ap/mariadb-10.2.11-x86_64-1.txz: Upgraded.
d/git-2.15.1-x86_64-1.txz: Upgraded.
d/python-setuptools-38.2.3-x86_64-1.txz: Upgraded.
x/libXcursor-1.1.15-x86_64-1.txz: Upgraded.
       Fix heap overflows when parsing malicious files. (CVE-2017-16612)
       It is possible to trigger heap overflows due to an integer overflow
       while parsing images and a signedness issue while parsing comments.
       The integer overflow occurs because the chosen limit 0x10000 for
       dimensions is too large for 32 bit systems, because each pixel takes
       4 bytes. Properly chosen values allow an overflow which in turn will
       lead to less allocated memory than needed for subsequent reads.
       The signedness bug is triggered by reading the length of a comment
       as unsigned int, but casting it to int when calling the function
       XcursorCommentCreate. Turning length into a negative value allows the
       check against XCURSOR_COMMENT_MAX_LEN to pass, and the following
       addition of sizeof (XcursorComment) + 1 makes it possible to allocate
       less memory than needed for subsequent reads.
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-16612
x/libXfont-1.5.3-x86_64-1.txz: Removed.
x/libXfont2-2.0.3-x86_64-1.txz: Upgraded.
       Open files with O_NOFOLLOW. (CVE-2017-16611)
       A non-privileged X client can instruct X server running under root
       to open any file by creating own directory with "fonts.dir",
       "fonts.alias" or any font file being a symbolic link to any other
       file in the system. X server will then open it. This can be issue
       with special files such as /dev/watchdog (which could then reboot
       the system).
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-16611
x/xfs-1.2.0-x86_64-1.txz: Upgraded.
testing/packages/php-7.1.12-x86_64-2.txz: Rebuilt.
       Load mysqlnd.so before mysqli.so in etc/php.ini*. Thanks to KewlCat.
       Load libphp7.so in mod_php.conf.example. Thanks to Willy Sudiarto Raharjo.
Tue Nov 28 06:20:03 UTC 2017
a/eudev-3.2.5-x86_64-1.txz: Upgraded.
a/kernel-firmware-20171126git-noarch-1.txz: Upgraded.
       Remove /lib/firmware/iwlwifi-*-34.ucode until after the next kernel release.
a/usbutils-009-x86_64-1.txz: Upgraded.
ap/hplip-3.17.11-x86_64-2.txz: Rebuilt.
       Fixed a few Python scripts that did not have a proper python3 shebang.
       Thanks to dugan.
ap/lxc-2.0.9-x86_64-1.txz: Upgraded.
ap/man-pages-4.14-noarch-1.txz: Upgraded.
ap/mc-4.8.20-x86_64-1.txz: Upgraded.
ap/nano-2.9.1-x86_64-1.txz: Upgraded.
kde/konsole-4.14.3-x86_64-3.txz: Rebuilt.
       Fixed scrollUp behavior. Thanks to Andrzej Telszewski.
l/QScintilla-2.10.2-x86_64-1.txz: Upgraded.
l/ffmpeg-3.4-x86_64-2.txz: Rebuilt.
       Recompiled against libva.so.2.0.0.
l/sip-4.19.6-x86_64-1.txz: Upgraded.
l/talloc-2.1.10-x86_64-1.txz: Added.
l/tdb-1.3.15-x86_64-1.txz: Added.
l/tevent-0.9.34-x86_64-1.txz: Added.
n/cyrus-sasl-2.1.26-x86_64-3.txz: Rebuilt.
       Use /dev/urandom rather than /dev/random to avoid entropy starvation.
       Thanks to mr.spuratic.
n/dhcpcd-6.11.5-x86_64-2.txz: Rebuilt.
       Use hostname_short in dhcpcd.conf. Thanks to KewlCat.
n/network-scripts-15.0-noarch-4.txz: Rebuilt.
       Script cleanups from Jakub Jankowski:
       netconfig: Add comment to netconfig-generated rc.inet1.conf
       rc.inet1: Check for iface in /sys/class/net, not /proc/net/dev
       rc.inet1: Remove unnecessary unset num
       rc.inet1: Factor DEBUG_ETH_UP logging to a separate function
       rc.inet1: Use ${array[*]} not ${array[@]} to produce a string
       rc.inet1: Avoid de-/configuring ifaces with indexes >=MAXNICS
       rc.inet1: Avoid code duplication by combining case/esac
       rc.inet1: Add missing 'dev' keyword
       rc.inet1: Remove unnecessary $(echo)
       rc.inet1*: Simplify virtif_* code, add note to example config
       rc.inet1: Test for loopback being "state UNKNOWN" too.
       rc.inet1: Use simple test (-n/-z) for non-empty/empty
       rc.inet1: Replace [ test1 -a test2 ] with [ test1 ] && [ test2 ]
n/openldap-client-2.4.45-x86_64-1.txz: Upgraded.
n/samba-4.7.3-x86_64-1.txz: Upgraded.
       This is a security release in order to address the following defects:
       CVE-2017-14746 (Use-after-free vulnerability.)
       All versions of Samba from 4.0.0 onwards are vulnerable to a use after
       free vulnerability, where a malicious SMB1 request can be used to
       control the contents of heap memory via a deallocated heap pointer. It
       is possible this may be used to compromise the SMB server.
       CVE-2017-15275 (Server heap memory information leak.)
       All versions of Samba from 3.6.0 onwards are vulnerable to a heap
       memory information leak, where server allocated heap memory may be
       returned to the client without being cleared.
       https://www.samba.org/samba/security/CVE-2017-14746.html
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-14746
       https://www.samba.org/samba/security/CVE-2017-15275.html
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-15275
x/intel-vaapi-driver-2.0.0-x86_64-1.txz: Added.
       This is the replacement for libva-intel-driver (renamed upstream).
x/libva-2.0.0-x86_64-1.txz: Upgraded.
x/libva-intel-driver-1.7.3-x86_64-1.txz: Removed.
x/libva-utils-2.0.0-x86_64-1.txz: Added.
x/mesa-17.2.6-x86_64-1.txz: Upgraded.
x/xkeyboard-config-2.22-noarch-1.txz: Upgraded.
xap/gparted-0.30.0-x86_64-1.txz: Upgraded.
xap/xine-lib-1.2.8-x86_64-4.txz: Rebuilt.
xfce/Thunar-1.6.13-x86_64-1.txz: Upgraded.
testing/packages/php-7.1.12-x86_64-1.txz: Added.
Slackware 32-bit
a/coreutils-8.28-i586-2.txz: Rebuilt.
a/lzlib-1.9-i586-1.txz: Added.
a/plzip-1.6-i586-1.txz: Added.
ap/man-1.6g-i586-3.txz: Removed.
ap/man-db-2.7.6.1-i586-1.txz: Added.
ap/mariadb-10.2.11-i586-1.txz: Upgraded.
d/git-2.15.1-i586-1.txz: Upgraded.
d/python-setuptools-38.2.3-i586-1.txz: Upgraded.
x/libXcursor-1.1.15-i586-1.txz: Upgraded.
x/libXfont-1.5.3-i586-1.txz: Removed.
x/libXfont2-2.0.3-i586-1.txz: Upgraded.
       the system).
x/xfs-1.2.0-i586-1.txz: Upgraded.
testing/packages/php-7.1.12-i586-2.txz: Rebuilt.
a/eudev-3.2.5-i586-1.txz: Upgraded.
a/usbutils-009-i586-1.txz: Upgraded.
ap/hplip-3.17.11-i586-2.txz: Rebuilt.
       Thanks to dugan.
ap/lxc-2.0.9-i586-1.txz: Upgraded.
ap/mc-4.8.20-i586-1.txz: Upgraded.
ap/nano-2.9.1-i586-1.txz: Upgraded.
kde/konsole-4.14.3-i586-3.txz: Rebuilt.
l/QScintilla-2.10.2-i586-1.txz: Upgraded.
l/ffmpeg-3.4-i586-2.txz: Rebuilt.
l/sip-4.19.6-i586-1.txz: Upgraded.
l/talloc-2.1.10-i586-1.txz: Added.
l/tdb-1.3.15-i586-1.txz: Added.
l/tevent-0.9.34-i586-1.txz: Added.
n/cyrus-sasl-2.1.26-i586-3.txz: Rebuilt.
n/dhcpcd-6.11.5-i586-2.txz: Rebuilt.
n/openldap-client-2.4.45-i586-1.txz: Upgraded.
n/samba-4.7.3-i586-1.txz: Upgraded.
x/intel-vaapi-driver-2.0.0-i586-1.txz: Added.
x/libva-2.0.0-i586-1.txz: Upgraded.
x/libva-intel-driver-1.7.3-i586-1.txz: Removed.
x/libva-utils-2.0.0-i586-1.txz: Added.
x/mesa-17.2.6-i586-1.txz: Upgraded.
xap/gparted-0.30.0-i586-1.txz: Upgraded.
xap/xine-lib-1.2.8-i586-4.txz: Rebuilt.
xfce/Thunar-1.6.13-i586-1.txz: Upgraded.
testing/packages/php-7.1.12-i586-1.txz: Added.
Post Napisano: 30 Nov 2017, 10:05
Slackware 64-bit
Wed Nov 29 21:48:33 UTC 2017
n/curl-7.57.0-x86_64-1.txz: Upgraded.
       SSL out of buffer access
       FTP wildcard out of bounds read
       NTLM buffer overflow via integer overflow
       https://curl.haxx.se/docs/adv_2017-af0a.html
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-8818
       https://curl.haxx.se/docs/adv_2017-ae72.html
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-8817
       https://curl.haxx.se/docs/adv_2017-12e7.html
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-8816
Slackware 32-bit
n/curl-7.57.0-i586-1.txz: Upgraded.
Post Napisano: 03 Dec 2017, 12:17
02.12.2017.
Slackware 64bit:
We're moving back to the 4.9.x kernel series in the main tree until we can
figure out a fix for unstable 4.14.x kernels (especially on 32-bit). Guessing
it's probably going to be fixable with .config changes, since a greatly
simplified .config is stable. Meanwhile, the latest 4.14.x kernels can now be
found in the testing/ directory.
a/kernel-firmware-20171130git-noarch-1.txz: Upgraded.
a/kernel-generic-4.9.66-x86_64-1.txz: Upgraded.
a/kernel-huge-4.9.66-x86_64-1.txz: Upgraded.
a/kernel-modules-4.9.66-x86_64-1.txz: Upgraded.
ap/soma-2.12.3-noarch-1.txz: Upgraded.
d/gdb-8.0.1-x86_64-3.txz: Rebuilt.
       Compiled --without-guile until guile-2.2 support is fixed.
d/guile-2.2.3-x86_64-1.txz: Upgraded.
d/kernel-headers-4.9.66-x86-1.txz: Upgraded.
d/make-4.2.1-x86_64-2.txz: Rebuilt.
       Recompiled against libguile-2.2.
d/mercurial-4.4.2-x86_64-1.txz: Upgraded.
k/kernel-source-4.9.66-noarch-1.txz: Upgraded.
l/adwaita-icon-theme-3.26.1-noarch-1.txz: Upgraded.
l/fftw-3.3.7-x86_64-1.txz: Upgraded.
l/libunistring-0.9.8-x86_64-1.txz: Upgraded.
l/libzip-1.3.2-x86_64-2.txz: Rebuilt.
       Restored missing zipconf.h. Thanks to orbea.
n/gnutls-3.6.1-x86_64-2.txz: Rebuilt.
n/stunnel-5.44-x86_64-1.txz: Upgraded.
x/xf86-video-vboxvideo-1.0.0-x86_64-1.txz: Added.
xap/mozilla-firefox-57.0.1-x86_64-1.txz: Upgraded.
testing/packages/linux-4.14.3/kernel-generic-4.14.3-x86_64-1.txz: Added.
testing/packages/linux-4.14.3/kernel-headers-4.14.3-x86-1.txz: Added.
testing/packages/linux-4.14.3/kernel-huge-4.14.3-x86_64-1.txz: Added.
testing/packages/linux-4.14.3/kernel-modules-4.14.3-x86_64-1.txz: Added.
testing/packages/linux-4.14.3/kernel-source-4.14.3-noarch-1.txz: Added.
testing/packages/php-7.2.0-x86_64-1.txz: Upgraded.
Slackware 32bit:
a/kernel-generic-4.9.66-i586-1.txz: Upgraded.
a/kernel-generic-smp-4.9.66_smp-i686-1.txz: Upgraded.
a/kernel-huge-4.9.66-i586-1.txz: Upgraded.
a/kernel-huge-smp-4.9.66_smp-i686-1.txz: Upgraded.
a/kernel-modules-4.9.66-i586-1.txz: Upgraded.
a/kernel-modules-smp-4.9.66_smp-i686-1.txz: Upgraded.
d/gdb-8.0.1-i586-3.txz: Rebuilt.
d/guile-2.2.3-i586-1.txz: Upgraded.
d/kernel-headers-4.9.66_smp-x86-1.txz: Upgraded.
d/make-4.2.1-i586-2.txz: Rebuilt.
d/mercurial-4.4.2-i586-1.txz: Upgraded.
k/kernel-source-4.9.66_smp-noarch-1.txz: Upgraded.
l/fftw-3.3.7-i586-1.txz: Upgraded.
l/libunistring-0.9.8-i586-1.txz: Upgraded.
l/libzip-1.3.2-i586-2.txz: Rebuilt.
n/gnutls-3.6.1-i586-2.txz: Rebuilt.
n/stunnel-5.44-i586-1.txz: Upgraded.
x/xf86-video-vboxvideo-1.0.0-i586-1.txz: Added.
xap/mozilla-firefox-57.0.1-i686-1.txz: Upgraded.
extra/linux-4.9.66-nosmp-sdk/*: Upgraded.
testing/packages/linux-4.14.3/kernel-generic-4.14.3-i586-1.txz: Added.
testing/packages/linux-4.14.3/kernel-generic-smp-4.14.3_smp-i686-1.txz: Added.
testing/packages/linux-4.14.3/kernel-headers-4.14.3_smp-x86-1.txz: Added.
testing/packages/linux-4.14.3/kernel-huge-4.14.3-i586-1.txz: Added.
testing/packages/linux-4.14.3/kernel-huge-smp-4.14.3_smp-i686-1.txz: Added.
testing/packages/linux-4.14.3/kernel-modules-4.14.3-i586-1.txz: Added.
testing/packages/linux-4.14.3/kernel-modules-smp-4.14.3_smp-i686-1.txz: Added.
testing/packages/linux-4.14.3/kernel-source-4.14.3_smp-noarch-1.txz: Added.
testing/packages/php-7.2.0-i586-1.txz: Upgraded.
Post Napisano: 04 Dec 2017, 22:35
Slackware 64-bit
Mon Dec 4 14:04:45 UTC 2017
xap/pan-0.143-x86_64-1.txz: Upgraded.
Sun Dec 3 22:42:47 UTC 2017
a/btrfs-progs-v4.14-x86_64-1.txz: Upgraded.
a/logrotate-3.13.0-x86_64-1.txz: Upgraded.
a/pciutils-3.5.6-x86_64-1.txz: Upgraded.
a/reiserfsprogs-3.6.27-x86_64-1.txz: Upgraded.
a/xfsprogs-4.14.0-x86_64-1.txz: Upgraded.
ap/itstool-2.0.4-x86_64-1.txz: Upgraded.
ap/mariadb-10.2.11-x86_64-2.txz: Rebuilt.
       Removed a Darwin-only symbol from the TOKUDB_OK cmake test to fix TokuDB.
ap/mpg123-1.25.8-x86_64-1.txz: Upgraded.
ap/xfsdump-3.1.8-x86_64-1.txz: Upgraded.
d/nasm-2.13.02-x86_64-1.txz: Upgraded.
l/M2Crypto-0.27.0-x86_64-1.txz: Upgraded.
l/babl-0.1.38-x86_64-1.txz: Upgraded.
l/python-six-1.11.0-x86_64-1.txz: Upgraded.
l/shared-mime-info-1.9-x86_64-1.txz: Upgraded.
n/autofs-5.1.3-x86_64-1.txz: Upgraded.
n/getmail-5.4-x86_64-1.txz: Upgraded.
n/sshfs-2.10-x86_64-1.txz: Upgraded.
n/traceroute-2.1.0-x86_64-1.txz: Upgraded.
xfce/xfce4-terminal-0.8.6-x86_64-2.txz: Rebuilt.
       Applied upstream patch to add utempter support. Thanks to Robby Workman.
Slackware 32-bit
xap/pan-0.143-i586-1.txz: Upgraded.
a/btrfs-progs-v4.14-i586-1.txz: Upgraded.
a/logrotate-3.13.0-i586-1.txz: Upgraded.
a/pciutils-3.5.6-i586-1.txz: Upgraded.
a/reiserfsprogs-3.6.27-i586-1.txz: Upgraded.
a/xfsprogs-4.14.0-i586-1.txz: Upgraded.
ap/itstool-2.0.4-i586-1.txz: Upgraded.
ap/mariadb-10.2.11-i586-2.txz: Rebuilt.
ap/mpg123-1.25.8-i586-1.txz: Upgraded.
ap/xfsdump-3.1.8-i586-1.txz: Upgraded.
d/nasm-2.13.02-i586-1.txz: Upgraded.
l/M2Crypto-0.27.0-i586-1.txz: Upgraded.
l/babl-0.1.38-i586-1.txz: Upgraded.
l/python-six-1.11.0-i586-1.txz: Upgraded.
l/shared-mime-info-1.9-i586-1.txz: Upgraded.
n/autofs-5.1.3-i586-1.txz: Upgraded.
n/getmail-5.4-i586-1.txz: Upgraded.
n/sshfs-2.10-i586-1.txz: Upgraded.
n/traceroute-2.1.0-i586-1.txz: Upgraded.
xfce/xfce4-terminal-0.8.6-i586-2.txz: Rebuilt.
Post Napisano: 06 Dec 2017, 21:57
Slackware 64-bit
Wed Dec 6 14:13:48 UTC 2017
a/kernel-generic-4.9.67-x86_64-1.txz: Upgraded.
a/kernel-huge-4.9.67-x86_64-1.txz: Upgraded.
a/kernel-modules-4.9.67-x86_64-1.txz: Upgraded.
ap/cups-filters-1.17.9-x86_64-2.txz: Rebuilt.
       Recompiled against poppler-0.62.0.
ap/sqlite-3.21.0-x86_64-2.txz: Rebuilt.
       Recompiled against icu4c-60.1.
d/kernel-headers-4.9.67-x86-1.txz: Upgraded.
d/python-setuptools-38.2.4-x86_64-1.txz: Upgraded.
d/subversion-1.9.7-x86_64-2.txz: Rebuilt.
k/kernel-source-4.9.67-noarch-1.txz: Upgraded.
kde/calligra-2.9.11-x86_64-17.txz: Rebuilt.
       Recompiled against icu4c-60.1 and poppler-0.62.0.
kde/kdepimlibs-4.14.10-x86_64-4.txz: Rebuilt.
       Recompiled against libical-3.0.1.
l/apr-util-1.6.1-x86_64-2.txz: Rebuilt.
l/boost-1.65.1-x86_64-2.txz: Rebuilt.
l/eigen3-3.2.10-x86_64-1.txz: Upgraded.
l/gmime-3.0.5-x86_64-1.txz: Upgraded.
l/gvfs-1.34.1-x86_64-2.txz: Rebuilt.
l/harfbuzz-1.7.2-x86_64-1.txz: Upgraded.
       Compiled against icu4c-60.1.
l/icu4c-60.1-x86_64-1.txz: Upgraded.
l/libgpod-0.8.3-x86_64-3.txz: Rebuilt.
l/libical-3.0.1-x86_64-1.txz: Upgraded.
l/libsodium-1.0.15-x86_64-1.txz: Added.
l/libvisio-0.1.6-x86_64-1.txz: Upgraded.
l/poppler-0.62.0-x86_64-1.txz: Upgraded.
l/raptor2-2.0.15-x86_64-3.txz: Rebuilt.
n/NetworkManager-1.10.0-x86_64-2.txz: Rebuilt.
n/autofs-5.1.3-x86_64-2.txz: Rebuilt.
       Fixed incorrect /etc/default/autofs.{,new}. Thanks to alienBOB.
n/bluez-5.47-x86_64-2.txz: Rebuilt.
n/dovecot-2.2.33.2-x86_64-3.txz: Rebuilt.
n/httpd-2.4.29-x86_64-2.txz: Rebuilt.
n/php-7.2.0-x86_64-2.txz: Upgraded.
       Upgraded from php-5.6.32.
       Compiled against libsodium-1.0.15.
n/postfix-3.2.4-x86_64-3.txz: Rebuilt.
n/tin-2.4.1-x86_64-2.txz: Rebuilt.
n/whois-5.2.18-x86_64-2.txz: Rebuilt.
       Ship the mkpasswd program. Thanks to Adrien Nader.
t/texlive-2017.171108-x86_64-2.txz: Rebuilt.
tcl/expect-5.45.3-x86_64-2.txz: Rebuilt.
       Don't install the mkpasswd example program, which is inferior to the
       version shipped with the whois sources.
xap/network-manager-applet-1.8.6-x86_64-2.txz: Rebuilt.
xap/pan-0.143-x86_64-2.txz: Rebuilt.
       Recompiled against gmime-3.0.5.
xfce/orage-4.12.1-x86_64-4.txz: Rebuilt.
xfce/tumbler-0.2.0-x86_64-3.txz: Rebuilt.
xfce/xfce4-screenshooter-1.8.2-x86_64-3.txz: Rebuilt.
xfce/xfce4-weather-plugin-0.8.10-x86_64-2.txz: Rebuilt.
testing/packages/linux-4.14.4/kernel-generic-4.14.4-x86_64-1.txz: Upgraded.
testing/packages/linux-4.14.4/kernel-headers-4.14.4-x86-1.txz: Upgraded.
testing/packages/linux-4.14.4/kernel-huge-4.14.4-x86_64-1.txz: Upgraded.
testing/packages/linux-4.14.4/kernel-modules-4.14.4-x86_64-1.txz: Upgraded.
testing/packages/linux-4.14.4/kernel-source-4.14.4-noarch-1.txz: Upgraded.
Slackware 32-bit
a/kernel-generic-4.9.67-i586-1.txz: Upgraded.
a/kernel-generic-smp-4.9.67_smp-i686-1.txz: Upgraded.
a/kernel-huge-4.9.67-i586-1.txz: Upgraded.
a/kernel-huge-smp-4.9.67_smp-i686-1.txz: Upgraded.
a/kernel-modules-4.9.67-i586-1.txz: Upgraded.
a/kernel-modules-smp-4.9.67_smp-i686-1.txz: Upgraded.
ap/cups-filters-1.17.9-i586-2.txz: Rebuilt.
ap/sqlite-3.21.0-i586-2.txz: Rebuilt.
d/kernel-headers-4.9.67_smp-x86-1.txz: Upgraded.
d/python-setuptools-38.2.4-i586-1.txz: Upgraded.
d/subversion-1.9.7-i586-2.txz: Rebuilt.
k/kernel-source-4.9.67_smp-noarch-1.txz: Upgraded.
kde/calligra-2.9.11-i586-17.txz: Rebuilt.
kde/kdepimlibs-4.14.10-i586-4.txz: Rebuilt.
l/apr-util-1.6.1-i586-2.txz: Rebuilt.
l/boost-1.65.1-i586-2.txz: Rebuilt.
l/eigen3-3.2.10-i586-1.txz: Upgraded.
l/gmime-3.0.5-i586-1.txz: Upgraded.
l/gvfs-1.34.1-i586-2.txz: Rebuilt.
l/harfbuzz-1.7.2-i586-1.txz: Upgraded.
l/icu4c-60.1-i586-1.txz: Upgraded.
l/libgpod-0.8.3-i586-3.txz: Rebuilt.
l/libical-3.0.1-i586-1.txz: Upgraded.
l/libsodium-1.0.15-i586-1.txz: Added.
l/libvisio-0.1.6-i586-1.txz: Upgraded.
l/poppler-0.62.0-i586-1.txz: Upgraded.
l/raptor2-2.0.15-i586-3.txz: Rebuilt.
n/NetworkManager-1.10.0-i586-2.txz: Rebuilt.
n/autofs-5.1.3-i586-2.txz: Rebuilt.
n/bluez-5.47-i586-2.txz: Rebuilt.
n/dovecot-2.2.33.2-i586-3.txz: Rebuilt.
n/httpd-2.4.29-i586-2.txz: Rebuilt.
n/php-7.2.0-i586-2.txz: Upgraded.
n/postfix-3.2.4-i586-3.txz: Rebuilt.
n/tin-2.4.1-i586-2.txz: Rebuilt.
n/whois-5.2.18-i586-2.txz: Rebuilt.
t/texlive-2017.171108-i586-2.txz: Rebuilt.
tcl/expect-5.45.3-i586-2.txz: Rebuilt.
xap/network-manager-applet-1.8.6-i586-2.txz: Rebuilt.
xap/pan-0.143-i586-2.txz: Rebuilt.
xfce/orage-4.12.1-i586-4.txz: Rebuilt.
xfce/tumbler-0.2.0-i586-3.txz: Rebuilt.
xfce/xfce4-screenshooter-1.8.2-i586-3.txz: Rebuilt.
xfce/xfce4-weather-plugin-0.8.10-i586-2.txz: Rebuilt.
extra/linux-4.9.67-nosmp-sdk/*: Upgraded.
testing/packages/linux-4.14.4/kernel-generic-4.14.4-i586-1.txz: Upgraded.
testing/packages/linux-4.14.4/kernel-generic-smp-4.14.4_smp-i686-1.txz: Upgraded.
testing/packages/linux-4.14.4/kernel-headers-4.14.4_smp-x86-1.txz: Upgraded.
testing/packages/linux-4.14.4/kernel-huge-4.14.4-i586-1.txz: Upgraded.
testing/packages/linux-4.14.4/kernel-huge-smp-4.14.4_smp-i686-1.txz: Upgraded.
testing/packages/linux-4.14.4/kernel-modules-4.14.4-i586-1.txz: Upgraded.
testing/packages/linux-4.14.4/kernel-modules-smp-4.14.4_smp-i686-1.txz: Upgraded.
testing/packages/linux-4.14.4/kernel-source-4.14.4_smp-noarch-1.txz: Upgraded.
Post Napisano: 08 Dec 2017, 20:15
Slackware 64-bit
Fri Dec 8 05:54:21 UTC 2017
l/cairo-1.14.12-x86_64-1.txz: Upgraded.
l/qt-4.8.7-x86_64-8.txz: Rebuilt.
       Don't warn if libicu* appears to be missing at runtime.
x/motif-2.3.8-x86_64-1.txz: Upgraded.
xap/mozilla-firefox-57.0.2-x86_64-1.txz: Upgraded.
Slackware 32-bit
l/cairo-1.14.12-i586-1.txz: Upgraded.
l/qt-4.8.7-i586-8.txz: Rebuilt.
x/motif-2.3.8-i586-1.txz: Upgraded.
xap/mozilla-firefox-57.0.2-i686-1.txz: Upgraded.
Post Napisano: 10 Dec 2017, 22:40
Slackware 64-bit
Sat Dec 9 00:02:28 UTC 2017
a/openssl-solibs-1.0.2n-x86_64-1.txz: Upgraded.
n/openssl-1.0.2n-x86_64-1.txz: Upgraded.
       Read/write after SSL object in error state
       rsaz_1024_mul_avx2 overflow bug on x86_64
       https://www.openssl.org/news/secadv/20171207.txt
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-3737
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-3738
Slackware 32-bit
a/openssl-solibs-1.0.2n-i586-1.txz: Upgraded.
n/openssl-1.0.2n-i586-1.txz: Upgraded.
Post Napisano: 15 Dec 2017, 19:43
Slackware 64-bit
Thu Dec 14 23:27:14 UTC 2017
l/gst-plugins-base-1.12.4-x86_64-1.txz: Upgraded.
l/gst-plugins-good-1.12.4-x86_64-1.txz: Upgraded.
l/gst-plugins-libav-1.12.4-x86_64-1.txz: Upgraded.
l/gstreamer-1.12.4-x86_64-1.txz: Upgraded.
l/libsodium-1.0.16-x86_64-1.txz: Upgraded.
n/wpa_supplicant-2.6-x86_64-3.txz: Rebuilt.
       Added options and patches from Fedora that may help with reconnection
       issues. Thanks to Robby Workman.
x/mesa-17.2.7-x86_64-1.txz: Upgraded.
xfce/xfce4-panel-4.12.2-x86_64-1.txz: Upgraded.
Slackware 32-bit
l/gst-plugins-base-1.12.4-i586-1.txz: Upgraded.
l/gst-plugins-good-1.12.4-i586-1.txz: Upgraded.
l/gst-plugins-libav-1.12.4-i586-1.txz: Upgraded.
l/gstreamer-1.12.4-i586-1.txz: Upgraded.
l/libsodium-1.0.16-i586-1.txz: Upgraded.
n/wpa_supplicant-2.6-i586-3.txz: Rebuilt.
x/mesa-17.2.7-i586-1.txz: Upgraded.
xfce/xfce4-panel-4.12.2-i586-1.txz: Upgraded.
Post Napisano: 20 Dec 2017, 18:34
Slackware 64-bit
Wed Dec 20 03:05:58 UTC 2017
ap/pamixer-1.3.1-x86_64-5.txz: Rebuilt.
       Recompiled against boost-1.66.0.
ap/vim-8.0.1415-x86_64-1.txz: Upgraded.
d/meson-0.44.0-x86_64-1.txz: Upgraded.
d/python3-3.6.4-x86_64-1.txz: Upgraded.
d/ruby-2.4.3-x86_64-1.txz: Upgraded.
       Net::FTP#get, getbinaryfile, gettextfile, put, putbinaryfile, and puttextfile
       use Kernel#open to open a local file. If the localfile argument starts with
       the pipe character "|", the command following the pipe character is executed.
       The default value of localfile is File.basename(remotefile), so malicious FTP
       servers could cause arbitrary command execution.
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-17405
kde/calligra-2.9.11-x86_64-18.txz: Rebuilt.
kde/kig-4.14.3-x86_64-7.txz: Rebuilt.
l/LibRaw-0.18.6-x86_64-1.txz: Upgraded.
l/akonadi-1.13.0-x86_64-8.txz: Rebuilt.
l/boost-1.66.0-x86_64-1.txz: Upgraded.
l/gmime-2.6.23-x86_64-2.txz: Upgraded.
       Revert to gmime-2 until the issues with pan are worked out. Nothing else in
       Slackware is using this library.
l/lcms2-2.9-x86_64-1.txz: Upgraded.
l/libogg-1.3.3-x86_64-1.txz: Upgraded.
l/librsvg-2.40.20-x86_64-1.txz: Upgraded.
l/pygobject-2.28.7-x86_64-1.txz: Upgraded.
n/NetworkManager-1.10.2-x86_64-1.txz: Upgraded.
n/gpgme-1.10.0-x86_64-1.txz: Upgraded.
n/libassuan-2.5.1-x86_64-1.txz: Upgraded.
n/libgcrypt-1.8.2-x86_64-1.txz: Upgraded.
n/mutt-1.9.2-x86_64-1.txz: Upgraded.
n/pinentry-1.1.0-x86_64-1.txz: Upgraded.
xap/network-manager-applet-1.8.10-x86_64-1.txz: Upgraded.
xap/pan-0.143-x86_64-3.txz: Rebuilt.
       Recompiled against gmime-2.
xap/vim-gvim-8.0.1415-x86_64-1.txz: Upgraded.
xfce/xfce4-notifyd-0.4.1-x86_64-1.txz: Upgraded.
testing/packages/linux-4.14.7/kernel-generic-4.14.7-x86_64-1.txz: Upgraded.
testing/packages/linux-4.14.7/kernel-headers-4.14.7-x86-1.txz: Upgraded.
testing/packages/linux-4.14.7/kernel-huge-4.14.7-x86_64-1.txz: Upgraded.
testing/packages/linux-4.14.7/kernel-modules-4.14.7-x86_64-1.txz: Upgraded.
testing/packages/linux-4.14.7/kernel-source-4.14.7-noarch-1.txz: Upgraded.
       These sources have been patched with two patches that have been submitted
       upstream but have yet to appear in the mainline or stable kernels. With the
       patches applied this kernel seems stable now on both 32 and 64-bit x86.
       Thanks to Michele Ballabio for reporting the issue to the upstream kernel
       developers, and to Ming Lei for the fix. Once these patches appear in the
       4.14.x kernel series (and barring any other major regressions), we'll be
       moving these kernels back into the main tree.
Slackware 32-bit
ap/pamixer-1.3.1-i586-5.txz: Rebuilt.
ap/vim-8.0.1415-i586-1.txz: Upgraded.
d/meson-0.44.0-i586-1.txz: Upgraded.
d/python3-3.6.4-i586-1.txz: Upgraded.
d/ruby-2.4.3-i586-1.txz: Upgraded.
kde/calligra-2.9.11-i586-18.txz: Rebuilt.
kde/kig-4.14.3-i586-7.txz: Rebuilt.
l/LibRaw-0.18.6-i586-1.txz: Upgraded.
l/akonadi-1.13.0-i586-8.txz: Rebuilt.
l/boost-1.66.0-i586-1.txz: Upgraded.
l/gmime-2.6.23-i586-2.txz: Upgraded.
l/lcms2-2.9-i586-1.txz: Upgraded.
l/libogg-1.3.3-i586-1.txz: Upgraded.
l/librsvg-2.40.20-i586-1.txz: Upgraded.
l/pygobject-2.28.7-i586-1.txz: Upgraded.
n/NetworkManager-1.10.2-i586-1.txz: Upgraded.
n/gpgme-1.10.0-i586-1.txz: Upgraded.
n/libassuan-2.5.1-i586-1.txz: Upgraded.
n/libgcrypt-1.8.2-i586-1.txz: Upgraded.
n/mutt-1.9.2-i586-1.txz: Upgraded.
n/pinentry-1.1.0-i586-1.txz: Upgraded.
xap/network-manager-applet-1.8.10-i586-1.txz: Upgraded.
xap/pan-0.143-i586-3.txz: Rebuilt.
xap/vim-gvim-8.0.1415-i586-1.txz: Upgraded.
xfce/xfce4-notifyd-0.4.1-i586-1.txz: Upgraded.
testing/packages/linux-4.14.7/kernel-generic-4.14.7-i586-1.txz: Upgraded.
testing/packages/linux-4.14.7/kernel-generic-smp-4.14.7_smp-i686-1.txz: Upgraded.
testing/packages/linux-4.14.7/kernel-headers-4.14.7_smp-x86-1.txz: Upgraded.
testing/packages/linux-4.14.7/kernel-huge-4.14.7-i586-1.txz: Upgraded.
testing/packages/linux-4.14.7/kernel-huge-smp-4.14.7_smp-i686-1.txz: Upgraded.
testing/packages/linux-4.14.7/kernel-modules-4.14.7-i586-1.txz: Upgraded.
testing/packages/linux-4.14.7/kernel-modules-smp-4.14.7_smp-i686-1.txz: Upgraded.
testing/packages/linux-4.14.7/kernel-source-4.14.7_smp-noarch-1.txz: Upgraded.
       moving these kernels back into the main tree.[code]
