Napisano: 04 Nov 2020, 23:42
Slackware 32-bit
Wed Nov 4 19:33:47 UTC 2020
ap/mariadb-10.5.7-i586-1.txz: Upgraded.
l/libcap-2.45-i586-1.txz: Upgraded.
l/poppler-data-0.4.10-noarch-1.txz: Upgraded.
n/samba-4.13.2-i586-1.txz: Upgraded.
x/libdrm-2.4.103-i586-1.txz: Upgraded.
packages/vtown/kde/sddm-0.18.1-i586-1_vtown_2.txz: Rebuilt.
Fixed installation of pam.d files. Thanks to alienBOB.
Tue Nov 3 22:32:22 UTC 2020
Welcome to vtown, volkerdi's friendly takeover of alienBOB's ktown Plasma 5
packages! Enormous thanks are due to alienBOB for maintaining and leading
testing of Plasma 5 on the side, even as I wore out his patience (and likely
others as well). But now this has made it into /testing and it won't be all
that long before it'll hit the main tree, so test it out and let me know if
anything broke. Several packages have been given back their upstream names
since there's no real reason to do otherwise unless we were going to support
installing KDE4 at the same time, and we aren't. Qt4 won't even be sticking
around, but probably slackbuilds.org will take it up. I dropped kaudiocreator
(won't build), ktuberling and klettres (rather bloated for the probably limited
appeal), user-manager (seems to have been dropped by upstream), kdelibs (KDE4
library, not going to support that), kwebkitpart, and kpat (not adding three
new dependencies only used for a solitaire game). In addition, it's probable
that digikam and its dependencies will be dropped. It's a great program, but
in my opinion it's just a little too big (especially the source) to ship by
default. To install the vtown packages, first you'll want to remove any KDE4
packages (the KDE and KDEI series in the main tree), any previous ktown packages
from alienBOB, and then install all of the packages in vtown/deps and vtown/kde
using upgradepkg --install-new. The previous advice on ConsoleKit2 was to remove
it since we've switched to elogind, but if you've got the latest rc.M it
shouldn't matter since ConsoleKit2 will not be started if elogind is installed.
Speaking of elogind, you'll probably notice that once elogind is installed X
or Wayland sessions will launch in the current console rather than on console 7.
Regarding the build numbers, the one before _vtown_ is the build number that
will be used when the merge to the main tree happens, and the one after _vtown_
is used in case any rebuilds need to happen while vtown is in /testing. That's
about it for the notes on this one. Thanks again to alienBOB, and to my friends
in the US - don't forget to vote. :-)
l/poppler-20.11.0-i586-1.txz: Upgraded.
x/libinput-1.16.3-i586-1.txz: Upgraded.
testing/packages/vtown/deps/QtAV-20200910_2a470d2a-i586-1_vtown_1.txz: Added.
testing/packages/vtown/deps/accountsservice-0.6.55-i586-1_vtown_1.txz: Added.
testing/packages/vtown/deps/cfitsio-3.49-i586-1_vtown_1.txz: Added.
testing/packages/vtown/deps/cryfs-0.10.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/deps/cryptopp-8.2.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/deps/dbus-1.12.20-i586-2_vtown_1.txz: Rebuilt.
testing/packages/vtown/deps/dotconf-1.3-i586-1_vtown_1.txz: Added.
testing/packages/vtown/deps/dvdauthor-0.7.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/deps/eigen3-3.3.7-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/deps/elogind-243.7-i586-1_vtown_1.txz: Added.
testing/packages/vtown/deps/frei0r-plugins-1.7.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/deps/grantlee-5.2.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/deps/kdsoap-1.9.1-i586-1_vtown_1.txz: Added.
testing/packages/vtown/deps/lensfun-0.3.95-i586-1_vtown_1.txz: Added.
testing/packages/vtown/deps/libappindicator-12.10.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/deps/libburn-1.5.2.pl01-i586-1_vtown_1.txz: Added.
testing/packages/vtown/deps/libdbusmenu-16.04.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/deps/libdbusmenu-qt-0.9.3+16.04.20160218-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/deps/libdmtx-0.7.5-i586-1_vtown_1.txz: Added.
testing/packages/vtown/deps/libindicator-12.10.1-i586-1_vtown_1.txz: Added.
testing/packages/vtown/deps/libqalculate-3.14.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/deps/libsass-3.6.4-i586-1_vtown_1.txz: Added.
testing/packages/vtown/deps/mlt-6.22.1-i586-1_vtown_1.txz: Added.
testing/packages/vtown/deps/opencv-4.5.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/deps/phonon-4.11.1-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/deps/phonon-backend-gstreamer-4.10.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/deps/pipewire-0.3.13-i586-1_vtown_1.txz: Added.
testing/packages/vtown/deps/polkit-0.118-i586-2_vtown_1.txz: Rebuilt.
testing/packages/vtown/deps/polkit-qt-1-0.113.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/deps/qrencode-4.1.1-i586-1_vtown_1.txz: Added.
testing/packages/vtown/deps/qtkeychain-0.11.1-i586-1_vtown_1.txz: Added.
testing/packages/vtown/deps/quazip-1.1-i586-1_vtown_1.txz: Added.
testing/packages/vtown/deps/rttr-0.9.6-i586-1_vtown_1.txz: Added.
testing/packages/vtown/deps/sassc-3.6.1-i586-1_vtown_1.txz: Added.
testing/packages/vtown/deps/speech-dispatcher-0.8.8-i586-1_vtown_1.txz: Added.
testing/packages/vtown/deps/vid.stab-20200916_e851e7b-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/akonadi-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/akonadi-calendar-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/akonadi-calendar-tools-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/akonadi-contacts-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/akonadi-import-wizard-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/akonadi-mime-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/akonadi-notes-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/akonadi-search-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/akonadiconsole-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/akregator-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/alkimia-8.0.4-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/analitza-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ark-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/artikulate-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/attica-5.75.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/audiocd-kio-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/baloo-5.75.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/baloo-widgets-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/blinken-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/bluedevil-5.20.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/bluez-qt-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/bomber-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/bovo-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/breeze-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/breeze-grub-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/breeze-gtk-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/breeze-icons-5.75.0-noarch-1_vtown_1.txz: Added.
testing/packages/vtown/kde/calendarsupport-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/calligra-3.2.1-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/calligraplan-3.2.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/cantor-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/cervisia-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/digikam-7.1.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/dolphin-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/dolphin-plugins-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/dragon-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/drkonqi-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/elisa-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/eventviews-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/extra-cmake-modules-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/falkon-3.1.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/ffmpegthumbs-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/filelight-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/frameworkintegration-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/granatier-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/grantlee-editor-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/grantleetheme-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/gwenview-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/incidenceeditor-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/juk-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/k3b-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kactivities-5.75.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kactivities-stats-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kactivitymanagerd-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kaddressbook-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kalarm-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kalarmcal-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kalgebra-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kalzium-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kamera-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kamoso-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kanagram-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kapidox-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kapman-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kapptemplate-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/karchive-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kate-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/katomic-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kauth-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kbackup-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kblackbox-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kblocks-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kbookmarks-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kbounce-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kbreakout-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kbruch-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kcachegrind-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kcalc-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kcalendarcore-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kcalutils-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kcharselect-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kcmutils-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kcodecs-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kcolorchooser-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kcompletion-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kconfig-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kconfigwidgets-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kcontacts-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kcoreaddons-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kcrash-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kcron-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdav-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kdbusaddons-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kde-cli-tools-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kde-dev-scripts-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kde-dev-utils-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kde-gtk-config-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kdebugsettings-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kdeclarative-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kdeconnect-kde-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdecoration-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kded-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kdeedu-data-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kdegraphics-mobipocket-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdegraphics-thumbnailers-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdelibs4support-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kdenetwork-filesharing-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdenlive-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kdepim-addons-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kdepim-apps-libs-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kdepim-runtime-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdeplasma-addons-5.20.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdesdk-kioslaves-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdesdk-thumbnailers-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdesignerplugin-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kdesu-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kdev-php-5.6.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kdev-python-5.6.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdevelop-5.6.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdevelop-pg-qt-2.2.1-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdewebkit-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kdf-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdiagram-2.7.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kdialog-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kdiamond-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdnssd-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kdoctools-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/keditbookmarks-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kemoticons-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kfilemetadata-5.75.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kfind-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kfloppy-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kfourinline-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kgamma5-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kgeography-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kget-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kglobalaccel-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kgoldrunner-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kgpg-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kguiaddons-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/khangman-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/khelpcenter-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kholidays-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/khotkeys-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/khtml-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/ki18n-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kiconthemes-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kid3-3.8.4-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kidentitymanagement-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kidletime-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kig-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kigo-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kile-2.9.93-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/killbots-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kimageformats-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kimagemapeditor-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kimap-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kinfocenter-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kinit-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kio-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kio-extras-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kio-gdrive-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kipi-plugins-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kirigami-gallery-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kirigami2-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kiriki-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kitemmodels-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kitemviews-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kiten-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kitinerary-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kjobwidgets-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kjots-20200924_355b642-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kjs-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kjsembed-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kjumpingcube-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kldap-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kleopatra-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/klickety-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/klines-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmag-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmahjongg-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmail-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kmail-account-wizard-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kmailtransport-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kmbox-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kmediaplayer-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kmenuedit-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kmime-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kmines-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmix-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmousetool-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmouth-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmplot-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmymoney-5.1.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/knavalbattle-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/knetwalk-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/knewstuff-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/knights-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/knotes-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/knotifications-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/knotifyconfig-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kolf-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kollision-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kolourpaint-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kompare-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/konqueror-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/konquest-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/konsole-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kontact-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kontactinterface-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kopete-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/korganizer-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kpackage-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kparts-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kpeople-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kpeoplevcard-0.1-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kpimtextedit-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kpkpass-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kplotting-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kpmcore-4.2.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kpty-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kqtquickcharts-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kquickcharts-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/krdc-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/krename-5.0.1-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kreversi-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/krfb-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/krita-4.4.1-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kross-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kross-interpreters-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kruler-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/krunner-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/krusader-2.7.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kscreen-5.20.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kscreenlocker-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kservice-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kshisen-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ksirk-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ksmtp-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ksnakeduel-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kspaceduel-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ksquares-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ksshaskpass-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kstars-3.4.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ksudoku-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ksysguard-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/ksystemlog-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kteatime-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ktexteditor-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/ktextwidgets-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/ktimer-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ktimetracker-5.0.1-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/ktnef-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/ktorrent-5.2.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ktouch-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kturtle-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kubrick-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kunitconversion-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kwallet-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kwallet-pam-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kwalletmanager-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kwave-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kwayland-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kwayland-integration-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kwayland-server-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kwidgetsaddons-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kwin-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kwindowsystem-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kwordquiz-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kwrited-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kxmlgui-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/kxmlrpcclient-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/latte-dock-0.9.11-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/libgravatar-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/libkcddb-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkcompactdisc-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkdcraw-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkdegames-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkdepim-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/libkeduvocdocument-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/libkexiv2-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkgapi-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/libkgeomap-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/libkipi-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkleo-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/libkmahjongg-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkomparediff2-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libksane-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkscreen-5.20.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libksieve-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/libksysguard-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/libktorrent-2.2.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/lokalize-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/lskat-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/mailcommon-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/mailimporter-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/marble-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/mbox-importer-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/messagelib-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/milou-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/minuet-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/modemmanager-qt-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/networkmanager-qt-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/okteta-0.26.4-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/okular-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/oxygen-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/oxygen-fonts-5.4.3-noarch-1_vtown_1.txz: Added.
testing/packages/vtown/kde/oxygen-gtk2-1.4.6-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/oxygen-icons5-5.75.0-noarch-1_vtown_1.txz: Added.
testing/packages/vtown/kde/palapeli-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/parley-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/partitionmanager-4.2.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/picmi-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/pim-data-exporter-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/pim-sieve-editor-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/pimcommon-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/plasma-browser-integration-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/plasma-desktop-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/plasma-disks-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/plasma-framework-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/plasma-integration-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/plasma-nm-5.20.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/plasma-pa-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/plasma-sdk-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/plasma-vault-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/plasma-wayland-protocols-1.1.1-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/plasma-workspace-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/plasma-workspace-wallpapers-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/polkit-kde-agent-1-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/powerdevil-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/poxml-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/print-manager-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/prison-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/pulseaudio-qt-1.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/purpose-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/qqc2-desktop-style-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/rocs-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/sddm-0.18.1-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/sddm-kcm-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/skanlite-2.2.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/solid-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/sonnet-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/spectacle-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/step-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/svgpart-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/sweeper-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/syndication-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/syntax-highlighting-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/systemsettings-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/threadweaver-5.75.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/umbrello-20.08.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/wacomtablet-20201030_417d9d9-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/xdg-desktop-portal-kde-5.20.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/yakuake-20.08.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/zeroconf-ioslave-20.08.2-i586-1_vtown_1.txz: Upgraded.
Napisano: 09 Nov 2020, 11:43
Slackware 64-bit
Sun Nov 8 22:14:40 UTC 2020
n/mutt-2.0.0-x86_64-1.txz: Upgraded.
n/ntp-4.2.8p15-x86_64-4.txz: Rebuilt.
Make a /usr/bin/ntpdate symlink so that Plasma 5 can find it.
Thanks to alienBOB.
n/postfix-3.5.8-x86_64-1.txz: Upgraded.
Sun Nov 8 02:43:44 UTC 2020
l/libsecret-0.20.4-x86_64-1.txz: Upgraded.
n/alpine-2.24-x86_64-1.txz: Upgraded.
x/mesa-20.2.2-x86_64-1.txz: Upgraded.
Fri Nov 6 21:25:18 UTC 2020
d/rust-1.47.0-x86_64-2.txz: Rebuilt.
Switch back to Rust 1.47.0 now that patches are available to fix Firefox
and Thunderbird.
xap/mozilla-thunderbird-78.4.1-x86_64-1.txz: Upgraded.
This is a bugfix release.
https://www.mozilla.org/en-US/thunderbird/78.4.1/releasenotes/
Thu Nov 5 20:40:51 UTC 2020
a/hwdata-0.341-noarch-1.txz: Upgraded.
a/kernel-generic-5.4.75-x86_64-1.txz: Upgraded.
a/kernel-huge-5.4.75-x86_64-1.txz: Upgraded.
a/kernel-modules-5.4.75-x86_64-1.txz: Upgraded.
d/kernel-headers-5.4.75-x86-1.txz: Upgraded.
k/kernel-source-5.4.75-noarch-1.txz: Upgraded.
l/oniguruma-6.9.6-x86_64-1.txz: Upgraded.
l/openal-soft-1.21.0-x86_64-1.txz: Upgraded.
n/ca-certificates-20201105-noarch-1.txz: Upgraded.
This update provides the latest CA certificates to check for the
authenticity of SSL connections.
x/libwacom-1.6-x86_64-1.txz: Upgraded.
x/xkbcomp-1.4.4-x86_64-1.txz: Upgraded.
isolinux/initrd.img: Rebuilt.
kernels/*: Upgraded.
testing/packages/vtown/kde/sddm-0.18.1-x86_64-1_vtown_3.txz: Rebuilt.
Fixed man page installation directory. Thanks to chrisretusn.
Xsetup: include comments.
Create /var/lib/sddm at build time.
Generate /etc/sddm.conf at build time.
Do not mess with users/groups in doinst.sh. These are expected to exist.
Do not add MinimumVT=7 to sddm.conf, as it is already included by default.
Slackware 32-bit
n/mutt-2.0.0-i586-1.txz: Upgraded.
n/ntp-4.2.8p15-i586-4.txz: Rebuilt.
Thanks to alienBOB.
n/postfix-3.5.8-i586-1.txz: Upgraded.
l/libsecret-0.20.4-i586-1.txz: Upgraded.
n/alpine-2.24-i586-1.txz: Upgraded.
x/mesa-20.2.2-i586-1.txz: Upgraded.
d/rust-1.47.0-i686-2.txz: Rebuilt.
and Thunderbird.
xap/mozilla-thunderbird-78.4.1-i686-1.txz: Upgraded.
a/kernel-generic-5.4.75-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.4.75_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.4.75-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.4.75_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.4.75-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.4.75_smp-i686-1.txz: Upgraded.
d/kernel-headers-5.4.75_smp-x86-1.txz: Upgraded.
k/kernel-source-5.4.75_smp-noarch-1.txz: Upgraded.
l/oniguruma-6.9.6-i586-1.txz: Upgraded.
l/openal-soft-1.21.0-i586-1.txz: Upgraded.
x/libwacom-1.6-i586-1.txz: Upgraded.
x/xkbcomp-1.4.4-i586-1.txz: Upgraded.
extra/linux-5.4.75-nosmp-sdk/*: Upgraded.
testing/packages/vtown/kde/sddm-0.18.1-i586-1_vtown_3.txz: Rebuilt.
Napisano: 10 Nov 2020, 17:21
Slackware 64-bit
Mon Nov 9 20:12:22 UTC 2020
a/grep-3.6-x86_64-1.txz: Upgraded.
ap/vim-8.2.1969-x86_64-1.txz: Upgraded.
l/imagemagick-7.0.10_37-x86_64-1.txz: Upgraded.
l/python-certifi-2020.11.8-x86_64-1.txz: Upgraded.
xap/mozilla-firefox-78.4.1esr-x86_64-1.txz: Upgraded.
This release contains a security fix:
In certain circumstances, the MCallGetProperty opcode can be emitted with
unmet assumptions resulting in an exploitable use-after-free condition.
https://www.mozilla.org/en-US/firefox/78.4.1/releasenotes/
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-26950
xap/vim-gvim-8.2.1969-x86_64-1.txz: Upgraded.
testing/packages/vtown/kde/akonadi-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/akonadi-calendar-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/akonadi-calendar-tools-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/akonadi-contacts-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/akonadi-import-wizard-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/akonadi-mime-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/akonadi-notes-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/akonadi-search-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/akonadiconsole-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/akregator-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/analitza-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ark-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/artikulate-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/audiocd-kio-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/baloo-widgets-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/blinken-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/bomber-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/bovo-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/calendarsupport-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/cantor-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/cervisia-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/dolphin-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/dolphin-plugins-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/dragon-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/elisa-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/eventviews-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ffmpegthumbs-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/filelight-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/granatier-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/grantlee-editor-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/grantleetheme-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/gwenview-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/incidenceeditor-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/juk-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/k3b-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kaddressbook-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kalarm-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kalarmcal-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kalgebra-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kalzium-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kamera-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kamoso-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kanagram-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kapman-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kapptemplate-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kate-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/katomic-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kbackup-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kblackbox-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kblocks-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kbounce-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kbreakout-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kbruch-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kcachegrind-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kcalc-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kcalutils-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kcharselect-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kcolorchooser-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kcron-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kde-dev-scripts-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kde-dev-utils-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdebugsettings-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdeconnect-kde-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdeedu-data-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdegraphics-mobipocket-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdegraphics-thumbnailers-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdenetwork-filesharing-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdenlive-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdepim-addons-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdepim-apps-libs-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdepim-runtime-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdesdk-kioslaves-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdesdk-thumbnailers-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdf-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdialog-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdiamond-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/keditbookmarks-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kfind-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kfloppy-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kfourinline-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kgeography-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kget-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kgoldrunner-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kgpg-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/khangman-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/khelpcenter-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kidentitymanagement-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kig-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kigo-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/killbots-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kimagemapeditor-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kimap-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kio-extras-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kio-gdrive-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kipi-plugins-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kirigami-gallery-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kiriki-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kiten-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kitinerary-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kjumpingcube-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kldap-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kleopatra-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/klickety-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/klines-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmag-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmahjongg-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmail-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmail-account-wizard-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmailtransport-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmbox-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmime-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmines-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmix-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmousetool-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmouth-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmplot-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/knavalbattle-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/knetwalk-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/knights-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/knotes-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kolf-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kollision-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kolourpaint-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kompare-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/konqueror-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/konquest-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/konsole-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kontact-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kontactinterface-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kopete-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/korganizer-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kpimtextedit-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kpkpass-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kqtquickcharts-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/krdc-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kreversi-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/krfb-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kross-interpreters-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kruler-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kshisen-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ksirk-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ksmtp-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ksnakeduel-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kspaceduel-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ksquares-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ksudoku-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ksystemlog-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kteatime-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ktimer-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ktnef-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ktouch-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kturtle-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kubrick-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kwalletmanager-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kwave-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kwordquiz-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libgravatar-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkcddb-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkcompactdisc-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkdcraw-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkdegames-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkdepim-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkeduvocdocument-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkexiv2-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkgapi-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkgeomap-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkipi-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkleo-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkmahjongg-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkomparediff2-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libksane-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libksieve-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/lokalize-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/lskat-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/mailcommon-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/mailimporter-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/marble-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/mbox-importer-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/messagelib-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/minuet-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/okular-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/palapeli-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/parley-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/picmi-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/pim-data-exporter-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/pim-sieve-editor-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/pimcommon-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/poxml-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/print-manager-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/rocs-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/spectacle-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/step-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/svgpart-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/sweeper-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/umbrello-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/yakuake-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/zeroconf-ioslave-20.08.3-x86_64-1_vtown_1.txz: Upgraded.
Slackware 32-bit
a/grep-3.6-i586-1.txz: Upgraded.
ap/vim-8.2.1969-i586-1.txz: Upgraded.
l/imagemagick-7.0.10_37-i586-1.txz: Upgraded.
l/python-certifi-2020.11.8-i586-1.txz: Upgraded.
xap/mozilla-firefox-78.4.1esr-i686-1.txz: Upgraded.
xap/vim-gvim-8.2.1969-i586-1.txz: Upgraded.
testing/packages/vtown/kde/akonadi-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/akonadi-calendar-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/akonadi-calendar-tools-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/akonadi-contacts-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/akonadi-import-wizard-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/akonadi-mime-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/akonadi-notes-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/akonadi-search-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/akonadiconsole-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/akregator-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/analitza-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ark-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/artikulate-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/audiocd-kio-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/baloo-widgets-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/blinken-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/bomber-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/bovo-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/calendarsupport-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/cantor-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/cervisia-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/dolphin-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/dolphin-plugins-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/dragon-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/elisa-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/eventviews-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ffmpegthumbs-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/filelight-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/granatier-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/grantlee-editor-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/grantleetheme-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/gwenview-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/incidenceeditor-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/juk-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/k3b-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kaddressbook-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kalarm-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kalarmcal-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kalgebra-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kalzium-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kamera-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kamoso-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kanagram-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kapman-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kapptemplate-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kate-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/katomic-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kbackup-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kblackbox-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kblocks-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kbounce-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kbreakout-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kbruch-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kcachegrind-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kcalc-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kcalutils-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kcharselect-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kcolorchooser-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kcron-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kde-dev-scripts-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kde-dev-utils-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdebugsettings-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdeconnect-kde-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdeedu-data-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdegraphics-mobipocket-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdegraphics-thumbnailers-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdenetwork-filesharing-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdenlive-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdepim-addons-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdepim-apps-libs-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdepim-runtime-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdesdk-kioslaves-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdesdk-thumbnailers-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdf-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdialog-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdiamond-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/keditbookmarks-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kfind-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kfloppy-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kfourinline-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kgeography-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kget-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kgoldrunner-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kgpg-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/khangman-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/khelpcenter-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kidentitymanagement-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kig-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kigo-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/killbots-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kimagemapeditor-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kimap-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kio-extras-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kio-gdrive-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kipi-plugins-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kirigami-gallery-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kiriki-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kiten-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kitinerary-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kjumpingcube-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kldap-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kleopatra-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/klickety-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/klines-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmag-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmahjongg-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmail-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmail-account-wizard-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmailtransport-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmbox-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmime-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmines-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmix-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmousetool-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmouth-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmplot-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/knavalbattle-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/knetwalk-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/knights-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/knotes-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kolf-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kollision-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kolourpaint-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kompare-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/konqueror-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/konquest-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/konsole-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kontact-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kontactinterface-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kopete-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/korganizer-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kpimtextedit-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kpkpass-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kqtquickcharts-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/krdc-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kreversi-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/krfb-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kross-interpreters-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kruler-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kshisen-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ksirk-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ksmtp-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ksnakeduel-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kspaceduel-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ksquares-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ksudoku-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ksystemlog-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kteatime-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ktimer-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ktnef-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ktouch-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kturtle-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kubrick-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kwalletmanager-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kwave-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kwordquiz-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libgravatar-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkcddb-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkcompactdisc-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkdcraw-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkdegames-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkdepim-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkeduvocdocument-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkexiv2-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkgapi-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkgeomap-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkipi-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkleo-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkmahjongg-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkomparediff2-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libksane-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libksieve-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/lokalize-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/lskat-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/mailcommon-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/mailimporter-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/marble-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/mbox-importer-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/messagelib-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/minuet-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/okular-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/palapeli-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/parley-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/picmi-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/pim-data-exporter-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/pim-sieve-editor-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/pimcommon-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/poxml-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/print-manager-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/rocs-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/spectacle-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/step-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/svgpart-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/sweeper-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/umbrello-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/yakuake-20.08.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/zeroconf-ioslave-20.08.3-i586-1_vtown_1.txz: Upgraded.
Napisano: 16 Nov 2020, 23:58
Slackware 64-bit
Mon Nov 16 21:23:09 UTC 2020
a/util-linux-2.36.1-x86_64-1.txz: Upgraded.
l/imagemagick-7.0.10_38-x86_64-1.txz: Upgraded.
l/lz4-1.9.3-x86_64-1.txz: Upgraded.
l/mozjs78-78.5.0esr-x86_64-1.txz: Upgraded.
n/ModemManager-1.14.8-x86_64-1.txz: Upgraded.
n/mutt-2.0.1-x86_64-1.txz: Upgraded.
xap/mozilla-firefox-78.5.0esr-x86_64-1.txz: Upgraded.
https://www.mozilla.org/en-US/firefox/78.5.0/releasenotes/
Sun Nov 15 00:02:28 UTC 2020
a/inotify-tools-3.20.11.0-x86_64-1.txz: Upgraded.
d/bison-3.7.4-x86_64-1.txz: Upgraded.
l/gmp-6.2.1-x86_64-1.txz: Upgraded.
l/mozilla-nss-3.59-x86_64-1.txz: Upgraded.
xap/seamonkey-2.53.5-x86_64-1.txz: Upgraded.
https://www.seamonkey-project.org/releases/seamonkey2.53.5
testing/packages/vtown/kde/attica-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/baloo-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/bluez-qt-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/breeze-icons-5.76.0-noarch-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/digikam-7.1.0-x86_64-1_vtown_2.txz: Rebuilt.
Moved to the correct directory. :-)
testing/packages/vtown/kde/extra-cmake-modules-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/frameworkintegration-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kactivities-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kactivities-stats-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kapidox-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/karchive-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kauth-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kbookmarks-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kcalendarcore-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kcmutils-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kcodecs-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kcompletion-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kconfig-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kconfigwidgets-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kcontacts-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kcoreaddons-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kcrash-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdav-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdbusaddons-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdeclarative-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kded-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdelibs4support-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdesignerplugin-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdesu-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdewebkit-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdnssd-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdoctools-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kemoticons-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kfilemetadata-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kglobalaccel-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kguiaddons-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kholidays-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/khtml-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ki18n-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kiconthemes-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kidletime-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kimageformats-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kinit-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kio-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kirigami2-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kitemmodels-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kitemviews-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kjobwidgets-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kjs-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kjsembed-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmediaplayer-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/knewstuff-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/knotifications-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/knotifyconfig-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kpackage-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kparts-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kpeople-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kplotting-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kpty-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kquickcharts-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kross-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/krunner-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kservice-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ktexteditor-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ktextwidgets-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kunitconversion-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kwallet-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kwayland-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kwidgetsaddons-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kwindowsystem-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kxmlgui-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kxmlrpcclient-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/modemmanager-qt-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/networkmanager-qt-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/oxygen-icons5-5.76.0-noarch-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/plasma-framework-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/prison-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/purpose-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/qqc2-desktop-style-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/solid-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/sonnet-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/syndication-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/syntax-highlighting-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/threadweaver-5.76.0-x86_64-1_vtown_1.txz: Upgraded.
Sat Nov 14 02:43:46 UTC 2020
a/kernel-firmware-20201113_2ea8667-noarch-1.txz: Upgraded.
d/gcc-9.3.0-x86_64-3.txz: Rebuilt.
Recompiled against isl-0.23.
d/gcc-brig-9.3.0-x86_64-3.txz: Rebuilt.
d/gcc-g++-9.3.0-x86_64-3.txz: Rebuilt.
d/gcc-gdc-9.3.0-x86_64-3.txz: Rebuilt.
d/gcc-gfortran-9.3.0-x86_64-3.txz: Rebuilt.
d/gcc-gnat-9.3.0-x86_64-3.txz: Rebuilt.
d/gcc-go-9.3.0-x86_64-3.txz: Rebuilt.
d/gcc-objc-9.3.0-x86_64-3.txz: Rebuilt.
l/isl-0.23-x86_64-1.txz: Upgraded.
l/python-urllib3-1.26.2-x86_64-1.txz: Upgraded.
n/gpgme-1.15.0-x86_64-1.txz: Upgraded.
n/openssh-8.4p1-x86_64-3.txz: Rebuilt.
Fix ssh-copy-id EOF bug. Thanks to OldHolborn.
n/php-7.4.12-x86_64-3.txz: Rebuilt.
Don't include c-client information in php-config output.
Thanks to Chalapticus.
xap/xine-lib-1.2.10-x86_64-4.txz: Rebuilt.
Recompiled against imagemagick-7.0.10_37. Thanks to RandomTroll.
extra/pure-alsa-system/xine-lib-1.2.10-x86_64-4_alsa.txz: Rebuilt.
testing/packages/gcc10/gcc-10.2.0-x86_64-2.txz: Rebuilt.
testing/packages/gcc10/gcc-brig-10.2.0-x86_64-2.txz: Rebuilt.
testing/packages/gcc10/gcc-g++-10.2.0-x86_64-2.txz: Rebuilt.
testing/packages/gcc10/gcc-gdc-10.2.0-x86_64-2.txz: Rebuilt.
testing/packages/gcc10/gcc-gfortran-10.2.0-x86_64-2.txz: Rebuilt.
testing/packages/gcc10/gcc-gnat-10.2.0-x86_64-2.txz: Rebuilt.
testing/packages/gcc10/gcc-go-10.2.0-x86_64-2.txz: Rebuilt.
testing/packages/gcc10/gcc-objc-10.2.0-x86_64-2.txz: Rebuilt.
testing/packages/vtown/deps/dvdauthor-0.7.2-x86_64-1_vtown_2.txz: Rebuilt.
testing/source/vtown/kde/digikam-7.1.0-x86_64-1_vtown_2.txz: Rebuilt.
Recompiled against imagemagick-7.0.10_37. Thanks to etienne.
Thu Nov 12 21:20:07 UTC 2020
d/perl-5.32.0-x86_64-3.txz: Rebuilt.
Upgraded: MIME-Base64-3.16, URI-5.05.
Added: Module-Runtime-0.016, Moo-2.004000, Path-Tiny-0.114,
Sub-Quote-2.006006, Template-Toolkit-3.009.
d/rinutils-0.6.0-x86_64-1.txz: Added.
Needed for freecell-solver.
l/freecell-solver-6.2.0-x86_64-1.txz: Added.
Needed for kpat.
l/libunwind-1.5.0-x86_64-1.txz: Upgraded.
l/python-pysol_cards-0.10.1-x86_64-1.txz: Added.
l/python-random2-1.0.1-x86_64-1.txz: Added.
l/python-requests-2.25.0-x86_64-1.txz: Upgraded.
l/python-urllib3-1.26.1-x86_64-1.txz: Upgraded.
x/xterm-362-x86_64-1.txz: Upgraded.
testing/packages/vtown/kde/kpat-20.08.3-x86_64-1_vtown_1.txz: Added.
This seems to be getting a lot of love on LQ, so I'll add it in spite of
(or perhaps because of) the effort required to prop it up.
Digikam is still too big though.
Wed Nov 11 23:10:59 UTC 2020
a/kernel-generic-5.4.77-x86_64-1.txz: Upgraded.
a/kernel-huge-5.4.77-x86_64-1.txz: Upgraded.
a/kernel-modules-5.4.77-x86_64-1.txz: Upgraded.
ap/lsof-4.94.0-x86_64-1.txz: Upgraded.
ap/mariadb-10.5.8-x86_64-1.txz: Upgraded.
d/gnucobol-3.1-x86_64-1.txz: Upgraded.
d/kernel-headers-5.4.77-x86-1.txz: Upgraded.
k/kernel-source-5.4.77-noarch-1.txz: Upgraded.
l/python-urllib3-1.26.0-x86_64-1.txz: Upgraded.
n/openldap-2.4.56-x86_64-1.txz: Upgraded.
xap/mozilla-thunderbird-78.4.3-x86_64-1.txz: Upgraded.
https://www.mozilla.org/en-US/thunderbird/78.4.3/releasenotes/
testing/packages/vtown/kde/sddm-0.19.0-x86_64-1_vtown_1.txz: Upgraded.
Wed Nov 11 04:04:47 UTC 2020
testing/packages/vtown/kde/bluedevil-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/breeze-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/breeze-grub-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/breeze-gtk-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/drkonqi-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kactivitymanagerd-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kde-cli-tools-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kde-gtk-config-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdecoration-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdeplasma-addons-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kgamma5-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/khotkeys-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kinfocenter-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmenuedit-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kscreen-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kscreenlocker-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ksshaskpass-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ksysguard-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kwallet-pam-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kwayland-integration-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kwayland-server-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kwin-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kwrited-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkscreen-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libksysguard-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/milou-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/oxygen-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/plasma-browser-integration-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/plasma-desktop-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/plasma-disks-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/plasma-integration-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/plasma-nm-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/plasma-pa-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/plasma-sdk-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/plasma-vault-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/plasma-workspace-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/plasma-workspace-wallpapers-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/polkit-kde-agent-1-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/powerdevil-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/sddm-kcm-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/systemsettings-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/xdg-desktop-portal-kde-5.20.3-x86_64-1_vtown_1.txz: Upgraded.
Tue Nov 10 20:57:47 UTC 2020
a/kernel-generic-5.4.76-x86_64-1.txz: Upgraded.
a/kernel-huge-5.4.76-x86_64-1.txz: Upgraded.
a/kernel-modules-5.4.76-x86_64-1.txz: Upgraded.
a/quota-4.06-x86_64-1.txz: Upgraded.
d/kernel-headers-5.4.76-x86-1.txz: Upgraded.
k/kernel-source-5.4.76-noarch-1.txz: Upgraded.
l/libspectre-0.2.9-x86_64-2.txz: Rebuilt.
Recompiled against ghostscript-9.53.3 to fix okular and others.
Thanks to Toutatis.
l/mozjs78-78.4.1esr-x86_64-1.txz: Upgraded.
n/getmail-6.9-x86_64-1.txz: Upgraded.
n/sshfs-3.7.1-x86_64-1.txz: Upgraded.
xap/mozilla-thunderbird-78.4.2-x86_64-1.txz: Upgraded.
Slackware 32-bit
a/util-linux-2.36.1-i586-1.txz: Upgraded.
l/imagemagick-7.0.10_38-i586-1.txz: Upgraded.
l/lz4-1.9.3-i586-1.txz: Upgraded.
l/mozjs78-78.5.0esr-i586-1.txz: Upgraded.
n/ModemManager-1.14.8-i586-1.txz: Upgraded.
n/mutt-2.0.1-i586-1.txz: Upgraded.
xap/mozilla-firefox-78.5.0esr-i686-1.txz: Upgraded.
a/inotify-tools-3.20.11.0-i586-1.txz: Upgraded.
d/bison-3.7.4-i586-1.txz: Upgraded.
l/gmp-6.2.1-i586-1.txz: Upgraded.
l/mozilla-nss-3.59-i586-1.txz: Upgraded.
xap/seamonkey-2.53.5-i686-1.txz: Upgraded.
testing/packages/vtown/kde/attica-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/baloo-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/bluez-qt-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/extra-cmake-modules-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/frameworkintegration-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kactivities-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kactivities-stats-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kapidox-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/karchive-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kauth-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kbookmarks-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kcalendarcore-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kcmutils-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kcodecs-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kcompletion-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kconfig-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kconfigwidgets-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kcontacts-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kcoreaddons-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kcrash-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdav-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdbusaddons-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdeclarative-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kded-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdelibs4support-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdesignerplugin-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdesu-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdewebkit-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdnssd-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdoctools-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kemoticons-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kfilemetadata-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kglobalaccel-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kguiaddons-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kholidays-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/khtml-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ki18n-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kiconthemes-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kidletime-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kimageformats-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kinit-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kio-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kirigami2-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kitemmodels-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kitemviews-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kjobwidgets-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kjs-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kjsembed-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmediaplayer-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/knewstuff-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/knotifications-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/knotifyconfig-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kpackage-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kparts-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kpeople-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kplotting-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kpty-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kquickcharts-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kross-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/krunner-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kservice-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ktexteditor-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ktextwidgets-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kunitconversion-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kwallet-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kwayland-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kwidgetsaddons-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kwindowsystem-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kxmlgui-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kxmlrpcclient-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/modemmanager-qt-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/networkmanager-qt-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/plasma-framework-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/prison-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/purpose-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/qqc2-desktop-style-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/solid-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/sonnet-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/syndication-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/syntax-highlighting-5.76.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/threadweaver-5.76.0-i586-1_vtown_1.txz: Upgraded.
d/gcc-9.3.0-i586-3.txz: Rebuilt.
d/gcc-brig-9.3.0-i586-3.txz: Rebuilt.
d/gcc-g++-9.3.0-i586-3.txz: Rebuilt.
d/gcc-gdc-9.3.0-i586-3.txz: Rebuilt.
d/gcc-gfortran-9.3.0-i586-3.txz: Rebuilt.
d/gcc-gnat-9.3.0-i586-3.txz: Rebuilt.
d/gcc-go-9.3.0-i586-3.txz: Rebuilt.
d/gcc-objc-9.3.0-i586-3.txz: Rebuilt.
l/isl-0.23-i586-1.txz: Upgraded.
l/python-urllib3-1.26.2-i586-1.txz: Upgraded.
n/gpgme-1.15.0-i586-1.txz: Upgraded.
n/openssh-8.4p1-i586-3.txz: Rebuilt.
n/php-7.4.12-i586-3.txz: Rebuilt.
xap/xine-lib-1.2.10-i586-4.txz: Rebuilt.
extra/pure-alsa-system/xine-lib-1.2.10-i586-4_alsa.txz: Rebuilt.
testing/packages/gcc10/gcc-10.2.0-i586-2.txz: Rebuilt.
testing/packages/gcc10/gcc-brig-10.2.0-i586-2.txz: Rebuilt.
testing/packages/gcc10/gcc-g++-10.2.0-i586-2.txz: Rebuilt.
testing/packages/gcc10/gcc-gdc-10.2.0-i586-2.txz: Rebuilt.
testing/packages/gcc10/gcc-gfortran-10.2.0-i586-2.txz: Rebuilt.
testing/packages/gcc10/gcc-gnat-10.2.0-i586-2.txz: Rebuilt.
testing/packages/gcc10/gcc-go-10.2.0-i586-2.txz: Rebuilt.
testing/packages/gcc10/gcc-objc-10.2.0-i586-2.txz: Rebuilt.
testing/packages/vtown/deps/dvdauthor-0.7.2-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/digikam-7.1.0-i586-1_vtown_2.txz: Rebuilt.
d/perl-5.32.0-i586-3.txz: Rebuilt.
d/rinutils-0.6.0-i586-1.txz: Added.
l/freecell-solver-6.2.0-i586-1.txz: Added.
Needed for kpat.
l/libunwind-1.5.0-i586-1.txz: Upgraded.
l/python-pysol_cards-0.10.1-i586-1.txz: Added.
l/python-random2-1.0.1-i586-1.txz: Added.
l/python-requests-2.25.0-i586-1.txz: Upgraded.
l/python-urllib3-1.26.1-i586-1.txz: Upgraded.
x/xterm-362-i586-1.txz: Upgraded.
testing/packages/vtown/kde/kpat-20.08.3-i586-1_vtown_1.txz: Added.
a/kernel-generic-5.4.77-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.4.77_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.4.77-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.4.77_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.4.77-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.4.77_smp-i686-1.txz: Upgraded.
ap/lsof-4.94.0-i586-1.txz: Upgraded.
ap/mariadb-10.5.8-i586-1.txz: Upgraded.
d/gnucobol-3.1-i586-1.txz: Upgraded.
d/kernel-headers-5.4.77_smp-x86-1.txz: Upgraded.
k/kernel-source-5.4.77_smp-noarch-1.txz: Upgraded.
l/python-urllib3-1.26.0-i586-1.txz: Upgraded.
n/openldap-2.4.56-i586-1.txz: Upgraded.
xap/mozilla-thunderbird-78.4.3-i686-1.txz: Upgraded.
extra/linux-5.4.77-nosmp-sdk/*: Upgraded.
testing/packages/vtown/kde/sddm-0.19.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/bluedevil-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/breeze-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/breeze-grub-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/breeze-gtk-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/drkonqi-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kactivitymanagerd-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kde-cli-tools-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kde-gtk-config-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdecoration-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kdeplasma-addons-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kgamma5-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/khotkeys-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kinfocenter-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kmenuedit-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kscreen-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kscreenlocker-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ksshaskpass-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ksysguard-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kwallet-pam-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kwayland-integration-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kwayland-server-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kwin-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/kwrited-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libkscreen-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/libksysguard-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/milou-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/oxygen-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/plasma-browser-integration-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/plasma-desktop-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/plasma-disks-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/plasma-integration-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/plasma-nm-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/plasma-pa-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/plasma-sdk-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/plasma-vault-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/plasma-workspace-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/plasma-workspace-wallpapers-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/polkit-kde-agent-1-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/powerdevil-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/sddm-kcm-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/systemsettings-5.20.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/xdg-desktop-portal-kde-5.20.3-i586-1_vtown_1.txz: Upgraded.
a/kernel-generic-5.4.76-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.4.76_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.4.76-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.4.76_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.4.76-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.4.76_smp-i686-1.txz: Upgraded.
a/quota-4.06-i586-1.txz: Upgraded.
d/kernel-headers-5.4.76_smp-x86-1.txz: Upgraded.
k/kernel-source-5.4.76_smp-noarch-1.txz: Upgraded.
l/libspectre-0.2.9-i586-2.txz: Rebuilt.
Thanks to Toutatis.
l/mozjs78-78.4.1esr-i586-1.txz: Upgraded.
n/getmail-6.9-i586-1.txz: Upgraded.
n/sshfs-3.7.1-i586-1.txz: Upgraded.
xap/mozilla-thunderbird-78.4.2-i686-1.txz: Upgraded.
https://www.mozilla.org/en-US/thunderbird/78.4.1/releasenotes/
extra/linux-5.4.76-nosmp-sdk/*: Upgraded.
isolinux/initrd.img: Rebuilt.
kernels/*: Upgraded.
Napisano: 22 Nov 2020, 09:44
Slackware 64-bit
Fri Nov 20 02:37:23 UTC 2020
a/kernel-firmware-20201119_54c797a-noarch-1.txz: Upgraded.
a/tcsh-6.22.03-x86_64-1.txz: Upgraded.
d/automake-1.16.3-noarch-1.txz: Upgraded.
d/rust-1.48.0-x86_64-1.txz: Upgraded.
l/libcap-ng-0.8.1-x86_64-1.txz: Upgraded.
n/libksba-1.5.0-x86_64-1.txz: Upgraded.
Wed Nov 18 21:40:31 UTC 2020
a/kernel-generic-5.4.78-x86_64-1.txz: Upgraded.
a/kernel-huge-5.4.78-x86_64-1.txz: Upgraded.
a/kernel-modules-5.4.78-x86_64-1.txz: Upgraded.
d/cmake-3.19.0-x86_64-1.txz: Upgraded.
d/kernel-headers-5.4.78-x86-1.txz: Upgraded.
k/kernel-source-5.4.78-noarch-1.txz: Upgraded.
l/imagemagick-7.0.10_39-x86_64-1.txz: Upgraded.
l/libjpeg-turbo-2.0.6-x86_64-1.txz: Upgraded.
n/gnupg2-2.2.24-x86_64-1.txz: Upgraded.
xap/mozilla-thunderbird-78.5.0-x86_64-1.txz: Upgraded.
https://www.mozilla.org/en-US/thunderbird/78.5.0/releasenotes/
https://www.mozilla.org/en-US/security/advisories/mfsa2020-52/
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-26951
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-16012
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-26953
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-26956
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-26958
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-26968
xap/ssr-0.4.2-x86_64-2.txz: Rebuilt.
Recompiled to use Qt5 instead of Qt4.
xfce/thunar-1.8.16-x86_64-1.txz: Upgraded.
Slackware 32-bit
a/tcsh-6.22.03-i586-1.txz: Upgraded.
d/rust-1.48.0-i686-1.txz: Upgraded.
l/libcap-ng-0.8.1-i586-1.txz: Upgraded.
n/libksba-1.5.0-i586-1.txz: Upgraded.
a/kernel-generic-5.4.78-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.4.78_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.4.78-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.4.78_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.4.78-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.4.78_smp-i686-1.txz: Upgraded.
d/cmake-3.19.0-i586-1.txz: Upgraded.
d/kernel-headers-5.4.78_smp-x86-1.txz: Upgraded.
k/kernel-source-5.4.78_smp-noarch-1.txz: Upgraded.
l/imagemagick-7.0.10_39-i586-1.txz: Upgraded.
l/libjpeg-turbo-2.0.6-i586-1.txz: Upgraded.
n/gnupg2-2.2.24-i586-1.txz: Upgraded.
xap/mozilla-thunderbird-78.5.0-i686-1.txz: Upgraded.
xap/ssr-0.4.2-i586-2.txz: Rebuilt.
xfce/thunar-1.8.16-i586-1.txz: Upgraded.
extra/linux-5.4.78-nosmp-sdk/*: Upgraded.
Napisano: 24 Nov 2020, 19:38
Slackware 64-bit
Mon Nov 23 21:29:14 UTC 2020
As an article I was reading recently says, the golden age of SCIM is over, so
we added fcitx and ibus input methods to vtown - thanks to Heinz Wiesinger!
If you're using vtown, the scim-* packages can be removed.
Qt5 was upgraded to version 5.15.2 which required a few patches where the API
for QPrinter/QPageLayout has changed. Just to make sure, all of Plasma 5 was
recompiled against it.
Added a couple more vtown deps - SDL2 (using the new input methods), and
upower. The new upower won't work with the Xfce in the main tree, but I suspect
most vtown testers aren't using Xfce anyway. And we will take care of that
situation pretty soon. Enjoy! :-)
a/hdparm-9.60-x86_64-1.txz: Upgraded.
a/kernel-firmware-20201120_bc9cd0b-noarch-1.txz: Upgraded.
a/kernel-generic-5.4.79-x86_64-1.txz: Upgraded.
a/kernel-huge-5.4.79-x86_64-1.txz: Upgraded.
a/kernel-modules-5.4.79-x86_64-1.txz: Upgraded.
ap/sysstat-12.5.1-x86_64-1.txz: Upgraded.
d/ccache-4.1-x86_64-1.txz: Upgraded.
d/kernel-headers-5.4.79-x86-1.txz: Upgraded.
d/parallel-20201122-noarch-1.txz: Upgraded.
k/kernel-source-5.4.79-noarch-1.txz: Upgraded.
l/imagemagick-7.0.10_41-x86_64-1.txz: Upgraded.
l/libxkbcommon-1.0.3-x86_64-1.txz: Upgraded.
l/qt5-5.15.2-x86_64-1.txz: Upgraded.
n/gnupg2-2.2.25-x86_64-1.txz: Upgraded.
n/ipset-7.9-x86_64-1.txz: Upgraded.
n/krb5-1.18.3-x86_64-1.txz: Upgraded.
n/mutt-2.0.2-x86_64-1.txz: Upgraded.
x/libX11-1.7.0-x86_64-1.txz: Upgraded.
x/xprop-1.2.5-x86_64-1.txz: Upgraded.
extra/pure-alsa-system/qt5-5.15.2-x86_64-1_alsa.txz: Upgraded.
testing/packages/vtown/deps/SDL2-2.0.12-x86_64-2_vtown_1.txz: Rebuilt.
Recompiled to pick up fcitx and ibus support.
testing/packages/vtown/deps/qt5-5.15.2-x86_64-2_vtown_1.txz: Rebuilt.
Recompiled to pick up speech-dispatcher support.
testing/packages/vtown/deps/upower-0.99.11-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/input-methods/OpenCC-1.1.1-x86_64-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/cldr-emoji-annotation-37.0_13.0_0_2-noarch-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/fcitx-4.2.9.8-x86_64-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/fcitx-anthy-0.2.3-x86_64-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/fcitx-configtool-0.4.9-x86_64-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/fcitx-hangul-0.3.1-x86_64-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/fcitx-kkc-0.1.4-x86_64-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/fcitx-libpinyin-0.5.3-x86_64-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/fcitx-m17n-0.2.4-x86_64-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/fcitx-qt5-1.2.5-x86_64-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/fcitx-sayura-0.1.2-x86_64-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/fcitx-table-extra-0.3.8-x86_64-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/fcitx-table-other-0.2.4-x86_64-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/fcitx-unikey-0.2.7-x86_64-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/ibus-1.5.23-x86_64-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/ibus-anthy-1.5.11-x86_64-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/ibus-hangul-1.5.4-x86_64-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/ibus-kkc-1.5.22-x86_64-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/ibus-libpinyin-1.11.1-x86_64-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/ibus-m17n-1.4.3-x86_64-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/ibus-table-1.12.1-x86_64-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/ibus-unikey-0.6.1-x86_64-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/kcm-fcitx-0.5.6-x86_64-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/libgee-0.20.1-x86_64-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/libkkc-0.3.5-x86_64-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/libkkc-data-0.2.7-x86_64-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/libpinyin-2.3.0-x86_64-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/marisa-0.2.4-x86_64-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/skkdic-20200128-noarch-1_vtown_1.txz: Added.
testing/packages/vtown/kde/akonadi-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/akonadi-calendar-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/akonadi-calendar-tools-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/akonadi-contacts-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/akonadi-import-wizard-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/akonadi-mime-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/akonadi-notes-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/akonadi-search-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/akonadiconsole-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/akregator-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/alkimia-8.0.4-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/analitza-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ark-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/artikulate-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/attica-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/audiocd-kio-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/baloo-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/baloo-widgets-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/blinken-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/bluedevil-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/bluez-qt-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/bomber-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/bovo-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/breeze-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/breeze-grub-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/breeze-gtk-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/breeze-icons-5.76.0-noarch-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/calendarsupport-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/calligra-3.2.1-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/calligraplan-3.2.2-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/cantor-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/cervisia-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/digikam-7.1.0-x86_64-1_vtown_3.txz: Rebuilt.
testing/packages/vtown/kde/dolphin-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/dolphin-plugins-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/dragon-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/drkonqi-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/elisa-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/eventviews-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/extra-cmake-modules-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/falkon-3.1.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ffmpegthumbs-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/filelight-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/frameworkintegration-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/granatier-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/grantlee-editor-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/grantleetheme-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/gwenview-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/incidenceeditor-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/juk-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/k3b-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kactivities-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kactivities-stats-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kactivitymanagerd-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kaddressbook-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kalarm-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kalarmcal-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kalgebra-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kalzium-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kamera-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kamoso-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kanagram-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kapidox-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kapman-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kapptemplate-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/karchive-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kate-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/katomic-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kauth-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kbackup-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kblackbox-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kblocks-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kbookmarks-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kbounce-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kbreakout-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kbruch-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kcachegrind-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kcalc-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kcalendarcore-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kcalutils-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kcharselect-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kcmutils-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kcodecs-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kcolorchooser-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kcompletion-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kconfig-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kconfigwidgets-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kcontacts-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kcoreaddons-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kcrash-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kcron-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdav-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdbusaddons-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kde-cli-tools-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kde-dev-scripts-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kde-dev-utils-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kde-gtk-config-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdebugsettings-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdeclarative-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdeconnect-kde-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdecoration-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kded-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdeedu-data-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdegraphics-mobipocket-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdegraphics-thumbnailers-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdelibs4support-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdenetwork-filesharing-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdenlive-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdepim-addons-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdepim-apps-libs-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdepim-runtime-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdeplasma-addons-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdesdk-kioslaves-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdesdk-thumbnailers-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdesignerplugin-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdesu-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdev-php-5.6.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdev-python-5.6.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdevelop-5.6.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdevelop-pg-qt-2.2.1-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdewebkit-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdf-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdiagram-2.7.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdialog-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdiamond-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdnssd-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdoctools-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/keditbookmarks-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kemoticons-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kfilemetadata-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kfind-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kfloppy-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kfourinline-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kgamma5-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kgeography-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kget-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kglobalaccel-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kgoldrunner-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kgpg-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kguiaddons-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/khangman-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/khelpcenter-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kholidays-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/khotkeys-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/khtml-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ki18n-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kiconthemes-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kid3-3.8.4-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kidentitymanagement-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kidletime-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kig-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kigo-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kile-2.9.93-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/killbots-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kimageformats-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kimagemapeditor-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kimap-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kinfocenter-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kinit-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kio-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kio-extras-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kio-gdrive-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kipi-plugins-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kirigami-gallery-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kirigami2-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kiriki-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kitemmodels-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kitemviews-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kiten-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kitinerary-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kjobwidgets-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kjots-20200924_355b642-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kjs-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kjsembed-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kjumpingcube-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kldap-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kleopatra-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/klickety-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/klines-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kmag-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kmahjongg-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kmail-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kmail-account-wizard-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kmailtransport-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kmbox-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kmediaplayer-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kmenuedit-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kmime-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kmines-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kmix-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kmousetool-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kmouth-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kmplot-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kmymoney-5.1.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/knavalbattle-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/knetwalk-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/knewstuff-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/knights-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/knotes-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/knotifications-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/knotifyconfig-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kolf-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kollision-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kolourpaint-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kompare-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/konqueror-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/konquest-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/konsole-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kontact-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kontactinterface-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kopete-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/korganizer-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kpackage-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kparts-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kpat-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kpeople-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kpeoplevcard-0.1-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kpimtextedit-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kpkpass-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kplotting-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kpmcore-4.2.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kpty-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kqtquickcharts-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kquickcharts-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/krdc-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/krename-5.0.1-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kreversi-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/krfb-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/krita-4.4.1-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kross-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kross-interpreters-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kruler-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/krunner-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/krusader-2.7.2-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kscreen-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kscreenlocker-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kservice-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kshisen-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ksirk-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ksmtp-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ksnakeduel-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kspaceduel-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ksquares-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ksshaskpass-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kstars-3.5.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ksudoku-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ksysguard-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ksystemlog-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kteatime-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ktexteditor-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ktextwidgets-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ktimer-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ktimetracker-5.0.1-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ktnef-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ktorrent-5.2.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ktouch-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kturtle-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kubrick-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kunitconversion-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kwallet-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kwallet-pam-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kwalletmanager-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kwave-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kwayland-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kwayland-integration-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kwayland-server-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kwidgetsaddons-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kwin-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kwindowsystem-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kwordquiz-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kwrited-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kxmlgui-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kxmlrpcclient-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/latte-dock-0.9.11-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libgravatar-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libkcddb-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libkcompactdisc-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libkdcraw-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libkdegames-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libkdepim-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libkeduvocdocument-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libkexiv2-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libkgapi-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libkgeomap-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libkipi-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libkleo-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libkmahjongg-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libkomparediff2-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libksane-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libkscreen-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libksieve-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libksysguard-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libktorrent-2.2.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/lokalize-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/lskat-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/mailcommon-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/mailimporter-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/marble-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/mbox-importer-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/messagelib-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/milou-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/minuet-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/modemmanager-qt-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/networkmanager-qt-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/okteta-0.26.4-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/okular-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/oxygen-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/oxygen-fonts-5.4.3-noarch-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/oxygen-gtk2-1.4.6-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/oxygen-icons5-5.76.0-noarch-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/palapeli-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/parley-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/partitionmanager-4.2.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/picmi-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/pim-data-exporter-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/pim-sieve-editor-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/pimcommon-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/plasma-browser-integration-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/plasma-desktop-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
Remove Discover and Konqueror icons from the taskbar. Thanks to alienBOB.
testing/packages/vtown/kde/plasma-disks-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/plasma-framework-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/plasma-integration-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/plasma-nm-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/plasma-pa-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/plasma-sdk-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/plasma-vault-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/plasma-wayland-protocols-1.1.1-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/plasma-workspace-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/plasma-workspace-wallpapers-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/polkit-kde-agent-1-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/powerdevil-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/poxml-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/print-manager-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/prison-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/pulseaudio-qt-1.2-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/purpose-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/qqc2-desktop-style-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/rocs-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/sddm-0.19.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/sddm-kcm-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/skanlite-2.2.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/solid-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/sonnet-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/spectacle-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/step-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/svgpart-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/sweeper-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/syndication-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/syntax-highlighting-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/systemsettings-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/threadweaver-5.76.0-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/umbrello-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/wacomtablet-20201030_417d9d9-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/xdg-desktop-portal-kde-5.20.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/yakuake-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/zeroconf-ioslave-20.08.3-x86_64-1_vtown_2.txz: Rebuilt.
Napisano: 24 Nov 2020, 19:39
Slackware 32-bit
a/hdparm-9.60-i586-1.txz: Upgraded.
a/kernel-generic-5.4.79-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.4.79_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.4.79-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.4.79_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.4.79-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.4.79_smp-i686-1.txz: Upgraded.
ap/sysstat-12.5.1-i586-1.txz: Upgraded.
d/ccache-4.1-i586-1.txz: Upgraded.
d/kernel-headers-5.4.79_smp-x86-1.txz: Upgraded.
k/kernel-source-5.4.79_smp-noarch-1.txz: Upgraded.
l/imagemagick-7.0.10_41-i586-1.txz: Upgraded.
l/libxkbcommon-1.0.3-i586-1.txz: Upgraded.
l/qt5-5.15.2-i586-1.txz: Upgraded.
n/gnupg2-2.2.25-i586-1.txz: Upgraded.
n/ipset-7.9-i586-1.txz: Upgraded.
n/krb5-1.18.3-i586-1.txz: Upgraded.
n/mutt-2.0.2-i586-1.txz: Upgraded.
x/libX11-1.7.0-i586-1.txz: Upgraded.
x/xprop-1.2.5-i586-1.txz: Upgraded.
extra/linux-5.4.79-nosmp-sdk/*: Upgraded.
extra/pure-alsa-system/qt5-5.15.2-i586-1_alsa.txz: Upgraded.
testing/packages/vtown/deps/SDL2-2.0.12-i586-2_vtown_1.txz: Rebuilt.
testing/packages/vtown/deps/qt5-5.15.2-i586-2_vtown_1.txz: Rebuilt.
testing/packages/vtown/deps/upower-0.99.11-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/input-methods/OpenCC-1.1.1-i586-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/fcitx-4.2.9.8-i586-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/fcitx-anthy-0.2.3-i586-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/fcitx-configtool-0.4.9-i586-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/fcitx-hangul-0.3.1-i586-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/fcitx-kkc-0.1.4-i586-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/fcitx-libpinyin-0.5.3-i586-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/fcitx-m17n-0.2.4-i586-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/fcitx-qt5-1.2.5-i586-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/fcitx-sayura-0.1.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/fcitx-table-extra-0.3.8-i586-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/fcitx-table-other-0.2.4-i586-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/fcitx-unikey-0.2.7-i586-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/ibus-1.5.23-i586-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/ibus-anthy-1.5.11-i586-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/ibus-hangul-1.5.4-i586-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/ibus-kkc-1.5.22-i586-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/ibus-libpinyin-1.11.1-i586-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/ibus-m17n-1.4.3-i586-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/ibus-table-1.12.1-i586-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/ibus-unikey-0.6.1-i586-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/kcm-fcitx-0.5.6-i586-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/libgee-0.20.1-i586-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/libkkc-0.3.5-i586-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/libkkc-data-0.2.7-i586-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/libpinyin-2.3.0-i586-1_vtown_1.txz: Added.
testing/packages/vtown/input-methods/marisa-0.2.4-i586-1_vtown_1.txz: Added.
testing/packages/vtown/kde/akonadi-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/akonadi-calendar-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/akonadi-calendar-tools-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/akonadi-contacts-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/akonadi-import-wizard-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/akonadi-mime-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/akonadi-notes-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/akonadi-search-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/akonadiconsole-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/akregator-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/alkimia-8.0.4-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/analitza-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ark-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/artikulate-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/attica-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/audiocd-kio-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/baloo-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/baloo-widgets-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/blinken-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/bluedevil-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/bluez-qt-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/bomber-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/bovo-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/breeze-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/breeze-grub-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/breeze-gtk-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/calendarsupport-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/calligra-3.2.1-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/calligraplan-3.2.2-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/cantor-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/cervisia-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/digikam-7.1.0-i586-1_vtown_3.txz: Rebuilt.
testing/packages/vtown/kde/dolphin-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/dolphin-plugins-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/dragon-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/drkonqi-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/elisa-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/eventviews-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/extra-cmake-modules-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/falkon-3.1.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ffmpegthumbs-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/filelight-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/frameworkintegration-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/granatier-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/grantlee-editor-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/grantleetheme-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/gwenview-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/incidenceeditor-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/juk-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/k3b-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kactivities-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kactivities-stats-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kactivitymanagerd-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kaddressbook-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kalarm-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kalarmcal-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kalgebra-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kalzium-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kamera-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kamoso-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kanagram-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kapidox-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kapman-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kapptemplate-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/karchive-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kate-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/katomic-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kauth-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kbackup-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kblackbox-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kblocks-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kbookmarks-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kbounce-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kbreakout-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kbruch-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kcachegrind-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kcalc-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kcalendarcore-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kcalutils-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kcharselect-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kcmutils-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kcodecs-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kcolorchooser-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kcompletion-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kconfig-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kconfigwidgets-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kcontacts-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kcoreaddons-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kcrash-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kcron-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdav-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdbusaddons-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kde-cli-tools-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kde-dev-scripts-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kde-dev-utils-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kde-gtk-config-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdebugsettings-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdeclarative-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdeconnect-kde-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdecoration-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kded-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdeedu-data-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdegraphics-mobipocket-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdegraphics-thumbnailers-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdelibs4support-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdenetwork-filesharing-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdenlive-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdepim-addons-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdepim-apps-libs-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdepim-runtime-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdeplasma-addons-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdesdk-kioslaves-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdesdk-thumbnailers-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdesignerplugin-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdesu-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdev-php-5.6.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdev-python-5.6.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdevelop-5.6.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdevelop-pg-qt-2.2.1-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdewebkit-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdf-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdiagram-2.7.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdialog-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdiamond-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdnssd-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kdoctools-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/keditbookmarks-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kemoticons-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kfilemetadata-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kfind-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kfloppy-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kfourinline-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kgamma5-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kgeography-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kget-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kglobalaccel-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kgoldrunner-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kgpg-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kguiaddons-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/khangman-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/khelpcenter-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kholidays-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/khotkeys-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/khtml-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ki18n-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kiconthemes-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kid3-3.8.4-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kidentitymanagement-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kidletime-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kig-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kigo-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kile-2.9.93-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/killbots-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kimageformats-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kimagemapeditor-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kimap-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kinfocenter-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kinit-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kio-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kio-extras-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kio-gdrive-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kipi-plugins-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kirigami-gallery-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kirigami2-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kiriki-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kitemmodels-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kitemviews-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kiten-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kitinerary-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kjobwidgets-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kjots-20200924_355b642-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kjs-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kjsembed-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kjumpingcube-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kldap-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kleopatra-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/klickety-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/klines-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kmag-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kmahjongg-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kmail-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kmail-account-wizard-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kmailtransport-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kmbox-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kmediaplayer-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kmenuedit-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kmime-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kmines-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kmix-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kmousetool-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kmouth-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kmplot-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kmymoney-5.1.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/knavalbattle-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/knetwalk-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/knewstuff-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/knights-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/knotes-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/knotifications-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/knotifyconfig-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kolf-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kollision-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kolourpaint-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kompare-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/konqueror-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/konquest-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/konsole-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kontact-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kontactinterface-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kopete-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/korganizer-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kpackage-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kparts-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kpat-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kpeople-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kpeoplevcard-0.1-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kpimtextedit-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kpkpass-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kplotting-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kpmcore-4.2.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kpty-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kqtquickcharts-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kquickcharts-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/krdc-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/krename-5.0.1-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kreversi-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/krfb-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/krita-4.4.1-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kross-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kross-interpreters-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kruler-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/krunner-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/krusader-2.7.2-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kscreen-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kscreenlocker-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kservice-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kshisen-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ksirk-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ksmtp-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ksnakeduel-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kspaceduel-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ksquares-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ksshaskpass-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kstars-3.5.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/kde/ksudoku-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ksysguard-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ksystemlog-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kteatime-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ktexteditor-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ktextwidgets-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ktimer-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ktimetracker-5.0.1-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ktnef-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ktorrent-5.2.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/ktouch-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kturtle-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kubrick-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kunitconversion-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kwallet-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kwallet-pam-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kwalletmanager-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kwave-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kwayland-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kwayland-integration-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kwayland-server-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kwidgetsaddons-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kwin-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kwindowsystem-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kwordquiz-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kwrited-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kxmlgui-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/kxmlrpcclient-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/latte-dock-0.9.11-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libgravatar-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libkcddb-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libkcompactdisc-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libkdcraw-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libkdegames-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libkdepim-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libkeduvocdocument-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libkexiv2-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libkgapi-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libkgeomap-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libkipi-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libkleo-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libkmahjongg-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libkomparediff2-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libksane-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libkscreen-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libksieve-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libksysguard-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/libktorrent-2.2.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/lokalize-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/lskat-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/mailcommon-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/mailimporter-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/marble-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/mbox-importer-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/messagelib-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/milou-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/minuet-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/modemmanager-qt-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/networkmanager-qt-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/okteta-0.26.4-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/okular-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/oxygen-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/oxygen-gtk2-1.4.6-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/palapeli-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/parley-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/partitionmanager-4.2.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/picmi-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/pim-data-exporter-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/pim-sieve-editor-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/pimcommon-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/plasma-browser-integration-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/plasma-desktop-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/plasma-disks-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/plasma-framework-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/plasma-integration-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/plasma-nm-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/plasma-pa-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/plasma-sdk-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/plasma-vault-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/plasma-wayland-protocols-1.1.1-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/plasma-workspace-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/plasma-workspace-wallpapers-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/polkit-kde-agent-1-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/powerdevil-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/poxml-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/print-manager-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/prison-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/pulseaudio-qt-1.2-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/purpose-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/qqc2-desktop-style-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/rocs-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/sddm-0.19.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/sddm-kcm-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/skanlite-2.2.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/solid-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/sonnet-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/spectacle-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/step-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/svgpart-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/sweeper-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/syndication-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/syntax-highlighting-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/systemsettings-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/threadweaver-5.76.0-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/umbrello-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/wacomtablet-20201030_417d9d9-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/xdg-desktop-portal-kde-5.20.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/yakuake-20.08.3-i586-1_vtown_2.txz: Rebuilt.
testing/packages/vtown/kde/zeroconf-ioslave-20.08.3-i586-1_vtown_2.txz: Rebuilt.
Napisano: 29 Nov 2020, 18:14
Slackware 64-bit
Sat Nov 28 19:21:58 UTC 2020
a/sysvinit-2.98-x86_64-1.txz: Upgraded.
d/ninja-1.10.2-x86_64-1.txz: Upgraded.
l/glibmm-2.64.4-x86_64-1.txz: Upgraded.
Fri Nov 27 20:40:32 UTC 2020
a/dialog-1.3_20201126-x86_64-1.txz: Upgraded.
l/adwaita-icon-theme-3.38.0-noarch-1.txz: Upgraded.
l/gsettings-desktop-schemas-3.38.0-x86_64-1.txz: Upgraded.
l/gtk+3-3.24.23-x86_64-2.txz: Rebuilt.
Applied upstream patch to fix middle click pasting between GTK+ and KDE apps
on Wayland. Thanks to Heinz Wiesinger.
l/gtksourceview3-3.24.11-x86_64-2.txz: Rebuilt.
Get rid of stray .la file.
l/libwmf-0.2.12-x86_64-1.txz: Upgraded.
l/utf8proc-2.6.0-x86_64-1.txz: Upgraded.
n/fetchmail-6.4.14-x86_64-1.txz: Upgraded.
n/php-7.4.13-x86_64-1.txz: Upgraded.
x/libinput-1.16.4-x86_64-1.txz: Upgraded.
Fri Nov 27 06:21:11 UTC 2020
Moved a few dependencies from vtown into the main tree, updated much of the
GNOME stack, and Xfce 4.14 appears in vtown! Thanks much to Robby Workman.
Hope everyone had a good day. Enjoy! :-)
a/upower-0.99.11-x86_64-1.txz: Upgraded.
d/sassc-3.6.1-x86_64-1.txz: Added.
d/vala-0.50.2-x86_64-1.txz: Upgraded.
l/at-spi2-atk-2.38.0-x86_64-1.txz: Upgraded.
l/at-spi2-core-2.38.0-x86_64-1.txz: Upgraded.
l/brotli-1.0.9-x86_64-3.txz: Rebuilt.
Get rid of unrecognized -R in the pkg-config files.
l/dconf-0.38.0-x86_64-1.txz: Upgraded.
l/dconf-editor-3.38.2-x86_64-1.txz: Upgraded.
l/gcr-3.38.0-x86_64-1.txz: Upgraded.
l/gdk-pixbuf2-2.42.0-x86_64-1.txz: Upgraded.
l/gdk-pixbuf2-xlib-2.40.2-x86_64-1.txz: Added.
l/gjs-1.66.1-x86_64-1.txz: Added.
l/glade-3.38.2-x86_64-1.txz: Added.
l/glib-networking-2.66.0-x86_64-1.txz: Upgraded.
l/glib2-2.66.3-x86_64-1.txz: Upgraded.
l/gobject-introspection-1.66.1-x86_64-1.txz: Upgraded.
l/gtksourceview3-3.24.11-x86_64-1.txz: Added.
l/gvfs-1.46.1-x86_64-1.txz: Upgraded.
l/json-glib-1.6.0-x86_64-1.txz: Upgraded.
l/librsvg-2.50.2-x86_64-1.txz: Upgraded.
l/libsass-3.6.4-x86_64-1.txz: Added.
l/libsoup-2.72.0-x86_64-1.txz: Upgraded.
l/libwnck3-3.36.0-x86_64-1.txz: Added.
l/pango-1.48.0-x86_64-1.txz: Upgraded.
l/pygobject3-3.38.0-x86_64-1.txz: Upgraded.
l/vte-0.62.1-x86_64-1.txz: Upgraded.
testing/packages/vtown/deps/libsass-3.6.4-x86_64-1_vtown_1.txz: Removed.
testing/packages/vtown/deps/sassc-3.6.1-x86_64-1_vtown_1.txz: Removed.
testing/packages/vtown/deps/upower-0.99.11-x86_64-1_vtown_1.txz: Removed.
testing/packages/vtown/xfce/Greybird-3.22.12-noarch-1_vtown_1.txz: Added.
testing/packages/vtown/xfce/elementary-xfce-0.15.1-x86_64-1_vtown_1.txz: Added.
testing/packages/vtown/xfce/exo-0.12.11-x86_64-2_vtown_1.txz: Rebuilt.
testing/packages/vtown/xfce/garcon-0.6.4-x86_64-2_vtown_1.txz: Rebuilt.
testing/packages/vtown/xfce/libxfce4ui-4.14.1-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/libxfce4util-4.14.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/mousepad-0.4.2-x86_64-1_vtown_1.txz: Added.
testing/packages/vtown/xfce/thunar-1.8.16-x86_64-2_vtown_1.txz: Rebuilt.
testing/packages/vtown/xfce/thunar-volman-0.9.5-x86_64-2_vtown_1.txz: Rebuilt.
testing/packages/vtown/xfce/tumbler-0.2.9-x86_64-2_vtown_1.txz: Rebuilt.
testing/packages/vtown/xfce/xfce4-appfinder-4.14.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/xfce4-clipman-plugin-1.6.1-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/xfce4-dev-tools-4.14.0-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/xfce4-notifyd-0.6.2-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/xfce4-panel-4.14.4-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/xfce4-panel-profiles-1.0.10-x86_64-1_vtown_1.txz: Added.
testing/packages/vtown/xfce/xfce4-power-manager-1.6.6-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/xfce4-pulseaudio-plugin-0.4.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/xfce4-screensaver-0.1.11-x86_64-1_vtown_1.txz: Added.
testing/packages/vtown/xfce/xfce4-screenshooter-1.9.7-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/xfce4-session-4.14.2-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/xfce4-settings-4.14.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/xfce4-systemload-plugin-1.2.3-x86_64-2_vtown_1.txz: Rebuilt.
testing/packages/vtown/xfce/xfce4-taskmanager-1.2.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/xfce4-terminal-0.8.9.2-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/xfce4-weather-plugin-0.10.2-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/xfce4-whiskermenu-plugin-2.4.6-x86_64-1_vtown_1.txz: Added.
testing/packages/vtown/xfce/xfconf-4.14.4-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/xfdesktop-4.14.3-x86_64-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/xfwm4-4.14.6-x86_64-1_vtown_1.txz: Upgraded.
Wed Nov 25 23:25:45 UTC 2020
ap/qpdf-10.0.4-x86_64-1.txz: Upgraded.
d/cmake-3.19.1-x86_64-1.txz: Upgraded.
n/bind-9.16.9-x86_64-1.txz: Upgraded.
This update fixes bugs, including a denial-of-service security issue:
After a Negative Trust Anchor (NTA) is added, BIND performs periodic
checks to see if it is still necessary. If BIND encountered a failure
while creating a query to perform such a check, it attempted to
dereference a NULL pointer, resulting in a crash. [GL #2244]
n/cifs-utils-6.11-x86_64-2.txz: Rebuilt.
Patched to fix mounting CIFS shares when linked with libcap-ng-0.8.1.
Thanks to marrowsuck.
Wed Nov 25 02:29:14 UTC 2020
a/kernel-firmware-20201124_b362fd4-noarch-1.txz: Upgraded.
a/kernel-generic-5.4.80-x86_64-1.txz: Upgraded.
a/kernel-huge-5.4.80-x86_64-1.txz: Upgraded.
a/kernel-modules-5.4.80-x86_64-1.txz: Upgraded.
d/kernel-headers-5.4.80-x86-1.txz: Upgraded.
k/kernel-source-5.4.80-noarch-1.txz: Upgraded.
l/djvulibre-3.5.28-x86_64-1.txz: Upgraded.
l/imagemagick-7.0.10_43-x86_64-1.txz: Upgraded.
l/pulseaudio-14.0-x86_64-1.txz: Upgraded.
n/nghttp2-1.42.0-x86_64-1.txz: Upgraded.
x/mesa-20.2.3-x86_64-1.txz: Upgraded.
isolinux/initrd.img: Rebuilt.
kernels/*: Upgraded.
testing/packages/vtown/input-methods/ibus-1.5.23-x86_64-1_vtown_2.txz: Rebuilt.
Install ibus-autostart-plasma.desktop. Thanks to Heinz Wiesinger.
Slackware 32-bit
a/sysvinit-2.98-i586-1.txz: Upgraded.
d/ninja-1.10.2-i586-1.txz: Upgraded.
l/glibmm-2.64.4-i586-1.txz: Upgraded.
a/dialog-1.3_20201126-i586-1.txz: Upgraded.
l/gsettings-desktop-schemas-3.38.0-i586-1.txz: Upgraded.
l/gtk+3-3.24.23-i586-2.txz: Rebuilt.
l/gtksourceview3-3.24.11-i586-2.txz: Rebuilt.
l/libwmf-0.2.12-i586-1.txz: Upgraded.
l/utf8proc-2.6.0-i586-1.txz: Upgraded.
n/fetchmail-6.4.14-i586-1.txz: Upgraded.
n/php-7.4.13-i586-1.txz: Upgraded.
x/libinput-1.16.4-i586-1.txz: Upgraded.
a/upower-0.99.11-i586-1.txz: Upgraded.
d/sassc-3.6.1-i586-1.txz: Added.
d/vala-0.50.2-i586-1.txz: Upgraded.
l/at-spi2-atk-2.38.0-i586-1.txz: Upgraded.
l/at-spi2-core-2.38.0-i586-1.txz: Upgraded.
l/brotli-1.0.9-i586-3.txz: Rebuilt.
l/dconf-0.38.0-i586-1.txz: Upgraded.
l/dconf-editor-3.38.2-i586-1.txz: Upgraded.
l/gcr-3.38.0-i586-1.txz: Upgraded.
l/gdk-pixbuf2-2.42.0-i586-1.txz: Upgraded.
l/gdk-pixbuf2-xlib-2.40.2-i586-1.txz: Added.
l/gjs-1.66.1-i586-1.txz: Added.
l/glade-3.38.2-i586-1.txz: Added.
l/glib-networking-2.66.0-i586-1.txz: Upgraded.
l/glib2-2.66.3-i586-1.txz: Upgraded.
l/gobject-introspection-1.66.1-i586-1.txz: Upgraded.
l/gtksourceview3-3.24.11-i586-1.txz: Added.
l/gvfs-1.46.1-i586-1.txz: Upgraded.
l/json-glib-1.6.0-i586-1.txz: Upgraded.
l/librsvg-2.50.2-i586-1.txz: Upgraded.
l/libsass-3.6.4-i586-1.txz: Added.
l/libsoup-2.72.0-i586-1.txz: Upgraded.
l/libwnck3-3.36.0-i586-1.txz: Added.
l/pango-1.48.0-i586-1.txz: Upgraded.
l/pygobject3-3.38.0-i586-1.txz: Upgraded.
l/vte-0.62.1-i586-1.txz: Upgraded.
testing/packages/vtown/deps/libsass-3.6.4-i586-1_vtown_1.txz: Removed.
testing/packages/vtown/deps/sassc-3.6.1-i586-1_vtown_1.txz: Removed.
testing/packages/vtown/deps/upower-0.99.11-i586-1_vtown_1.txz: Removed.
testing/packages/vtown/xfce/elementary-xfce-0.15.1-i586-1_vtown_1.txz: Added.
testing/packages/vtown/xfce/exo-0.12.11-i586-2_vtown_1.txz: Rebuilt.
testing/packages/vtown/xfce/garcon-0.6.4-i586-2_vtown_1.txz: Rebuilt.
testing/packages/vtown/xfce/libxfce4ui-4.14.1-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/libxfce4util-4.14.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/mousepad-0.4.2-i586-1_vtown_1.txz: Added.
testing/packages/vtown/xfce/thunar-1.8.16-i586-2_vtown_1.txz: Rebuilt.
testing/packages/vtown/xfce/thunar-volman-0.9.5-i586-2_vtown_1.txz: Rebuilt.
testing/packages/vtown/xfce/tumbler-0.2.9-i586-2_vtown_1.txz: Rebuilt.
testing/packages/vtown/xfce/xfce4-appfinder-4.14.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/xfce4-clipman-plugin-1.6.1-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/xfce4-dev-tools-4.14.0-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/xfce4-notifyd-0.6.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/xfce4-panel-4.14.4-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/xfce4-panel-profiles-1.0.10-i586-1_vtown_1.txz: Added.
testing/packages/vtown/xfce/xfce4-power-manager-1.6.6-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/xfce4-pulseaudio-plugin-0.4.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/xfce4-screensaver-0.1.11-i586-1_vtown_1.txz: Added.
testing/packages/vtown/xfce/xfce4-screenshooter-1.9.7-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/xfce4-session-4.14.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/xfce4-settings-4.14.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/xfce4-systemload-plugin-1.2.3-i586-2_vtown_1.txz: Rebuilt.
testing/packages/vtown/xfce/xfce4-taskmanager-1.2.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/xfce4-terminal-0.8.9.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/xfce4-weather-plugin-0.10.2-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/xfce4-whiskermenu-plugin-2.4.6-i586-1_vtown_1.txz: Added.
testing/packages/vtown/xfce/xfconf-4.14.4-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/xfdesktop-4.14.3-i586-1_vtown_1.txz: Upgraded.
testing/packages/vtown/xfce/xfwm4-4.14.6-i586-1_vtown_1.txz: Upgraded.
ap/qpdf-10.0.4-i586-1.txz: Upgraded.
d/cmake-3.19.1-i586-1.txz: Upgraded.
n/bind-9.16.9-i586-1.txz: Upgraded.
n/cifs-utils-6.11-i586-2.txz: Rebuilt.
a/kernel-generic-5.4.80-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.4.80_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.4.80-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.4.80_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.4.80-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.4.80_smp-i686-1.txz: Upgraded.
d/kernel-headers-5.4.80_smp-x86-1.txz: Upgraded.
k/kernel-source-5.4.80_smp-noarch-1.txz: Upgraded.
l/djvulibre-3.5.28-i586-1.txz: Upgraded.
l/imagemagick-7.0.10_43-i586-1.txz: Upgraded.
l/pulseaudio-14.0-i586-1.txz: Upgraded.
n/nghttp2-1.42.0-i586-1.txz: Upgraded.
x/mesa-20.2.3-i586-1.txz: Upgraded.
extra/linux-5.4.80-nosmp-sdk/*: Upgraded.
testing/packages/vtown/input-methods/ibus-1.5.23-i586-1_vtown_2.txz: Rebuilt.
Napisano: 02 Dec 2020, 20:41
Slackware 64-bit
Tue Dec 1 20:18:01 UTC 2020
a/hwdata-0.342-noarch-1.txz: Upgraded.
a/pam-1.5.1-x86_64-1.txz: Upgraded.
ap/sqlite-3.34.0-x86_64-1.txz: Upgraded.
l/libarchive-3.5.0-x86_64-1.txz: Upgraded.
x/fontconfig-2.13.92-x86_64-1.txz: Upgraded.
I'm pretty sure there was a good reason to switch to 2.13.92 on the devel
release path, but I'm not sure the same can be said about 2.13.93. We'll
stick with this one for now until there's a stable release or another good
reason to bump it.
x/xorg-server-1.20.10-x86_64-1.txz: Upgraded.
x/xorg-server-xephyr-1.20.10-x86_64-1.txz: Upgraded.
x/xorg-server-xnest-1.20.10-x86_64-1.txz: Upgraded.
x/xorg-server-xvfb-1.20.10-x86_64-1.txz: Upgraded.
x/xorg-server-xwayland-1.20.10-x86_64-1.txz: Upgraded.
xap/gnuplot-5.4.1-x86_64-1.txz: Upgraded.
Mon Nov 30 20:03:36 UTC 2020
a/kernel-firmware-20201130_7455a36-noarch-1.txz: Upgraded.
ap/sudo-1.9.4-x86_64-1.txz: Upgraded.
d/python-pip-20.3-x86_64-1.txz: Upgraded.
d/rinutils-0.8.0-x86_64-1.txz: Upgraded.
l/imagemagick-7.0.10_45-x86_64-1.txz: Upgraded.
n/cyrus-sasl-2.1.27-x86_64-5.txz: Rebuilt.
rc.saslauthd: start with -a pam -c
Rebuilt with --with-ldap and include LDAP_SASLAUTHD documentation.
Thanks to voegelas.
Sun Nov 29 20:52:56 UTC 2020
ap/vim-8.2.2069-x86_64-1.txz: Upgraded.
e/emacspeak-53.0-x86_64-1.txz: Upgraded.
x/fontconfig-2.13.93-x86_64-1.txz: Upgraded.
xap/vim-gvim-8.2.2069-x86_64-1.txz: Upgraded.
Slackware 32-bit
a/pam-1.5.1-i586-1.txz: Upgraded.
ap/sqlite-3.34.0-i586-1.txz: Upgraded.
l/libarchive-3.5.0-i586-1.txz: Upgraded.
x/fontconfig-2.13.92-i586-1.txz: Upgraded.
reason to bump it.
x/xorg-server-1.20.10-i586-1.txz: Upgraded.
x/xorg-server-xephyr-1.20.10-i586-1.txz: Upgraded.
x/xorg-server-xnest-1.20.10-i586-1.txz: Upgraded.
x/xorg-server-xvfb-1.20.10-i586-1.txz: Upgraded.
x/xorg-server-xwayland-1.20.10-i586-1.txz: Upgraded.
xap/gnuplot-5.4.1-i586-1.txz: Upgraded.
ap/sudo-1.9.4-i586-1.txz: Upgraded.
d/python-pip-20.3-i586-1.txz: Upgraded.
d/rinutils-0.8.0-i586-1.txz: Upgraded.
l/imagemagick-7.0.10_45-i586-1.txz: Upgraded.
n/cyrus-sasl-2.1.27-i586-5.txz: Rebuilt.
Thanks to voegelas.
ap/vim-8.2.2069-i586-1.txz: Upgraded.
e/emacspeak-53.0-i586-1.txz: Upgraded.
x/fontconfig-2.13.93-i586-1.txz: Upgraded.
xap/vim-gvim-8.2.2069-i586-1.txz: Upgraded.
Napisano: 05 Dec 2020, 15:32
Slackware 64-bit
Fri Dec 4 21:30:08 UTC 2020
l/pcre2-10.36-x86_64-1.txz: Upgraded.
l/poppler-20.12.0-x86_64-1.txz: Upgraded.
n/libtirpc-1.3.1-x86_64-1.txz: Upgraded.
x/libva-2.10.0-x86_64-1.txz: Upgraded.
Thu Dec 3 23:52:38 UTC 2020
a/kernel-generic-5.4.81-x86_64-1.txz: Upgraded.
a/kernel-huge-5.4.81-x86_64-1.txz: Upgraded.
a/kernel-modules-5.4.81-x86_64-1.txz: Upgraded.
ap/cups-filters-1.28.6-x86_64-1.txz: Upgraded.
ap/nano-5.4-x86_64-1.txz: Upgraded.
d/binutils-2.35.1-x86_64-1.txz: Upgraded.
d/gcc-10.2.0-x86_64-2.txz: Rebuilt.
These are the same GCC packages that were previously in /testing.
d/gcc-brig-10.2.0-x86_64-2.txz: Rebuilt.
d/gcc-g++-10.2.0-x86_64-2.txz: Rebuilt.
d/gcc-gdc-10.2.0-x86_64-2.txz: Rebuilt.
d/gcc-gfortran-10.2.0-x86_64-2.txz: Rebuilt.
d/gcc-gnat-10.2.0-x86_64-2.txz: Rebuilt.
d/gcc-go-10.2.0-x86_64-2.txz: Rebuilt.
d/gcc-objc-10.2.0-x86_64-2.txz: Rebuilt.
d/kernel-headers-5.4.81-x86-1.txz: Upgraded.
d/libtool-2.4.6-x86_64-14.txz: Rebuilt.
Recompiled to update embedded GCC version number.
d/mercurial-5.6.1-x86_64-1.txz: Upgraded.
d/oprofile-1.4.0-x86_64-2.txz: Rebuilt.
d/python-pip-20.3.1-x86_64-1.txz: Upgraded.
k/kernel-source-5.4.81-noarch-1.txz: Upgraded.
GCC_VERSION 90300 -> 100200
l/PyQt5-5.15.2-x86_64-1.txz: Upgraded.
l/glibmm-2.64.5-x86_64-1.txz: Upgraded.
x/mesa-20.3.0-x86_64-1.txz: Upgraded.
xap/geeqie-1.6-x86_64-1.txz: Upgraded.
xap/mozilla-thunderbird-78.5.1-x86_64-1.txz: Upgraded.
https://www.mozilla.org/en-US/thunderbird/78.5.1/releasenotes/
https://www.mozilla.org/en-US/security/advisories/mfsa2020-53/
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-26970
Slackware 32-bit
l/pcre2-10.36-i586-1.txz: Upgraded.
l/poppler-20.12.0-i586-1.txz: Upgraded.
n/libtirpc-1.3.1-i586-1.txz: Upgraded.
x/libva-2.10.0-i586-1.txz: Upgraded.
a/kernel-generic-5.4.81-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.4.81_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.4.81-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.4.81_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.4.81-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.4.81_smp-i686-1.txz: Upgraded.
ap/cups-filters-1.28.6-i586-1.txz: Upgraded.
ap/nano-5.4-i586-1.txz: Upgraded.
d/binutils-2.35.1-i586-1.txz: Upgraded.
d/gcc-10.2.0-i586-2.txz: Rebuilt.
d/gcc-brig-10.2.0-i586-2.txz: Rebuilt.
d/gcc-g++-10.2.0-i586-2.txz: Rebuilt.
d/gcc-gdc-10.2.0-i586-2.txz: Rebuilt.
d/gcc-gfortran-10.2.0-i586-2.txz: Rebuilt.
d/gcc-gnat-10.2.0-i586-2.txz: Rebuilt.
d/gcc-go-10.2.0-i586-2.txz: Rebuilt.
d/gcc-objc-10.2.0-i586-2.txz: Rebuilt.
d/kernel-headers-5.4.81_smp-x86-1.txz: Upgraded.
d/libtool-2.4.6-i586-14.txz: Rebuilt.
d/mercurial-5.6.1-i586-1.txz: Upgraded.
d/oprofile-1.4.0-i586-2.txz: Rebuilt.
d/python-pip-20.3.1-i586-1.txz: Upgraded.
k/kernel-source-5.4.81_smp-noarch-1.txz: Upgraded.
l/PyQt5-5.15.2-i586-1.txz: Upgraded.
l/glibmm-2.64.5-i586-1.txz: Upgraded.
x/mesa-20.3.0-i586-1.txz: Upgraded.
xap/geeqie-1.6-i586-1.txz: Upgraded.
xap/mozilla-thunderbird-78.5.1-i686-1.txz: Upgraded.
extra/linux-5.4.81-nosmp-sdk/*: Upgraded.
