Novosti u *current* -u
Post Napisano: 11 Dec 2020, 15:50
Slackware 64-bit
Wed Dec 9 21:10:40 UTC 2020
a/elogind-243.7-x86_64-2.txz: Rebuilt.
       Moved default udev rules to /lib/udev/rules.d/. Thanks to Robby Workman.
       Added /usr/share/polkit-1/rules.d/10-enable-session-power.rules.
a/glibc-zoneinfo-2020d-noarch-2.txz: Rebuilt.
       Make /etc/localtime a symlink pointing into /usr/share/zoneinfo. If you
       have /usr on a separate partition, this might cause time problems prior
       to /usr being mounted (I recommend *not* making /usr a separate partition).
       But if you insist for some reason, you can probably work around it by
       adding the pointed-to directory and timezone file to your empty pre-mounted
       /usr directory.
a/upower-0.99.11-x86_64-2.txz: Rebuilt.
       Added /usr/share/polkit-1/rules.d/10-enable-upower-suspend.rules.
d/autoconf-2.70-noarch-1.txz: Upgraded.
d/gnucobol-3.1.1-x86_64-1.txz: Upgraded.
kde/powerdevil-5.20.4-x86_64-2.txz: Rebuilt.
       Moved 10-enable-powerdevil-discrete-gpu.rules.new to
       /usr/share/polkit-1/rules.d/. Thanks to Robby Workman.
       Moved 10-enable-session-power.rules to the elogind package.
       Moved 10-enable-upower-suspend.rules to the upower package.
       Thanks to GazL.
l/jasper-2.0.23-x86_64-1.txz: Upgraded.
       Fix heap-overflow in cp_create() in jpc_enc.c.
       https://github.com/jasper-software/jasper/issues/252
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-27828
l/sbc-1.5-x86_64-1.txz: Upgraded.
n/curl-7.74.0-x86_64-1.txz: Upgraded.
       This release includes the following security related bugfixes:
       Inferior OCSP verification [93]
       FTP wildcard stack overflow [95]
       Trusting FTP PASV responses [97]
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-8286
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-8285
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-8284
xap/xscreensaver-5.45-x86_64-1.txz: Upgraded.
xfce/Greybird-3.22.13-noarch-1.txz: Upgraded.
Tue Dec 8 19:29:55 UTC 2020
a/kernel-generic-5.4.82-x86_64-1.txz: Upgraded.
a/kernel-huge-5.4.82-x86_64-1.txz: Upgraded.
a/kernel-modules-5.4.82-x86_64-1.txz: Upgraded.
a/openssl-solibs-1.1.1i-x86_64-1.txz: Upgraded.
ap/gutenprint-5.3.4-x86_64-1.txz: Upgraded.
ap/htop-3.0.3-x86_64-1.txz: Upgraded.
d/kernel-headers-5.4.82-x86-1.txz: Upgraded.
d/python3-3.9.1-x86_64-1.txz: Upgraded.
k/kernel-source-5.4.82-noarch-1.txz: Upgraded.
l/M2Crypto-0.37.1-x86_64-1.txz: Upgraded.
l/gdk-pixbuf2-2.42.2-x86_64-1.txz: Upgraded.
l/imagemagick-7.0.10_46-x86_64-1.txz: Upgraded.
l/mlt-6.24.0-x86_64-1.txz: Upgraded.
l/pipewire-0.3.17-x86_64-1.txz: Upgraded.
n/openssl-1.1.1i-x86_64-1.txz: Upgraded.
       This fixes a denial-of-service security issue.
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-1971
x/fcitx-configtool-0.4.10-x86_64-1.txz: Upgraded.
x/libgee-0.20.3-x86_64-1.txz: Upgraded.
x/marisa-0.2.6-x86_64-1.txz: Upgraded.
isolinux/initrd.img: Rebuilt.
kernels/*: Upgraded.
Mon Dec 7 21:49:58 UTC 2020
Goodbye vtown... we hardly knew you.
It is indeed the day of the Big Merge(tm) leaving nothing left in /testing (but
I'll try to work on that soon). In addition to merging packages from /testing,
Qt4 and related packages have gone away, along with some other libraries that
were only used by KDE4. Perhaps someone will want to take up maintenance of Qt4
(but I'm also pretty sure that SBo wouldn't touch that build script with a ten
foot pole). ConsoleKit2 is gone, replaced by elogind (which also takes over for
cgmanager and pm-utils).
Huge thanks to Eric Hameleers, Heinz Wiesinger, and Robby Workman for all the
help making this possible.
There's still more cleanup to do here, but that'll be easier with everything in
the main tree instead of maintaining side installs running the /testing
packages.
I'll look into what can be done about extra/pure-alsa-system/ soon.
Enjoy! :-)
a/aaa_elflibs-15.0-x86_64-28.txz: Rebuilt.
       Upgraded: libcap.so.2.45, libelf-0.182.so, libglib-2.0.so.0.6600.3,
       libgmodule-2.0.so.0.6600.3, libgmp.so.10.4.1, libgmpxx.so.4.6.1,
       libgobject-2.0.so.0.6600.3, libgthread-2.0.so.0.6600.3, libhistory.so.8.1,
       libisl.so.23.0.0, liblber-2.4.so.2.11.4, libldap-2.4.so.2.11.4,
       libpcre2-8.so.0.10.1, libreadline.so.8.1.
       Removed: libHalf.so.12.0.0, libIex-2_2.so.12.0.0, libIexMath-2_2.so.12.0.0,
       libIlmImf-2_2.so.22.0.0, libIlmImfUtil-2_2.so.22.0.0,
       libIlmThread-2_2.so.12.0.0, libImath-2_2.so.12.0.0, libexiv2.so.26.0.0,
       libpoppler-qt4.so.4.11.0, libpoppler.so.79.0.0, libraw.so.16.0.0,
       libraw_r.so.16.0.0.
a/bash-5.1.000-x86_64-1.txz: Upgraded.
a/dbus-1.12.20-x86_64-2.txz: Rebuilt.
a/elogind-243.7-x86_64-1.txz: Added.
a/eudev-3.2.9-x86_64-2.txz: Rebuilt.
       Applied Pavilion 13 x360 keys patch from upstream git.
a/procps-ng-3.3.16-x86_64-3.txz: Rebuilt.
       Recompiled using --with-elogind.
ap/cgmanager-0.42-x86_64-1.txz: Removed.
ap/pm-utils-1.4.1-x86_64-6.txz: Removed.
ap/vim-8.2.2105-x86_64-1.txz: Upgraded.
d/python-setuptools-51.0.0-x86_64-1.txz: Upgraded.
kde/akonadi-20.08.3-x86_64-1.txz: Upgraded.
kde/akonadi-calendar-20.08.3-x86_64-1.txz: Added.
kde/akonadi-calendar-tools-20.08.3-x86_64-1.txz: Added.
kde/akonadi-contacts-20.08.3-x86_64-1.txz: Added.
kde/akonadi-import-wizard-20.08.3-x86_64-1.txz: Added.
kde/akonadi-mime-20.08.3-x86_64-1.txz: Added.
kde/akonadi-notes-20.08.3-x86_64-1.txz: Added.
kde/akonadi-search-20.08.3-x86_64-1.txz: Added.
kde/akonadiconsole-20.08.3-x86_64-1.txz: Added.
kde/akregator-20.08.3-x86_64-1.txz: Added.
kde/alkimia-8.0.4-x86_64-1.txz: Added.
kde/amarok-2.9.0-x86_64-3.txz: Removed.
kde/amor-4.14.3-x86_64-3.txz: Removed.
kde/analitza-20.08.3-x86_64-1.txz: Upgraded.
kde/ark-20.08.3-x86_64-1.txz: Upgraded.
kde/artikulate-20.08.3-x86_64-1.txz: Upgraded.
kde/attica-5.76.0-x86_64-1.txz: Upgraded.
kde/audiocd-kio-20.08.3-x86_64-1.txz: Upgraded.
kde/baloo-5.76.0-x86_64-1.txz: Upgraded.
kde/baloo-widgets-20.08.3-x86_64-1.txz: Upgraded.
kde/blinken-20.08.3-x86_64-1.txz: Upgraded.
kde/bluedevil-5.20.4-x86_64-1.txz: Upgraded.
kde/bluez-qt-5.76.0-x86_64-1.txz: Added.
kde/bomber-20.08.3-x86_64-1.txz: Upgraded.
kde/bovo-20.08.3-x86_64-1.txz: Upgraded.
kde/breeze-5.20.4-x86_64-1.txz: Added.
kde/breeze-grub-5.20.4-x86_64-1.txz: Added.
kde/breeze-gtk-5.20.4-x86_64-1.txz: Added.
kde/breeze-icons-5.76.0-noarch-1.txz: Added.
kde/calendarsupport-20.08.3-x86_64-1.txz: Added.
kde/calligra-3.2.1-x86_64-1.txz: Upgraded.
kde/calligraplan-3.2.2-x86_64-1.txz: Added.
kde/cantor-20.08.3-x86_64-1.txz: Upgraded.
kde/cervisia-20.08.3-x86_64-1.txz: Upgraded.
kde/digikam-7.1.0-x86_64-1.txz: Added.
kde/dolphin-20.08.3-x86_64-1.txz: Added.
kde/dolphin-plugins-20.08.3-x86_64-1.txz: Upgraded.
kde/dragon-20.08.3-x86_64-1.txz: Upgraded.
kde/drkonqi-5.20.4-x86_64-1.txz: Added.
kde/elisa-20.08.3-x86_64-1.txz: Added.
kde/eventviews-20.08.3-x86_64-1.txz: Added.
kde/extra-cmake-modules-5.76.0-x86_64-1.txz: Added.
kde/falkon-3.1.0-x86_64-1.txz: Added.
kde/ffmpegthumbs-20.08.3-x86_64-1.txz: Added.
kde/filelight-20.08.3-x86_64-1.txz: Upgraded.
kde/frameworkintegration-5.76.0-x86_64-1.txz: Added.
kde/granatier-20.08.3-x86_64-1.txz: Upgraded.
kde/grantlee-editor-20.08.3-x86_64-1.txz: Added.
kde/grantleetheme-20.08.3-x86_64-1.txz: Added.
kde/gwenview-20.08.3-x86_64-1.txz: Upgraded.
kde/incidenceeditor-20.08.3-x86_64-1.txz: Added.
kde/juk-20.08.3-x86_64-1.txz: Upgraded.
kde/k3b-20.08.3-x86_64-1.txz: Upgraded.
kde/kaccessible-4.14.3-x86_64-3.txz: Removed.
kde/kactivities-5.76.0-x86_64-1.txz: Upgraded.
kde/kactivities-stats-5.76.0-x86_64-1.txz: Added.
kde/kactivitymanagerd-5.20.4-x86_64-1.txz: Added.
kde/kaddressbook-20.08.3-x86_64-1.txz: Added.
kde/kajongg-4.14.3-x86_64-3.txz: Removed.
kde/kalarm-20.08.3-x86_64-1.txz: Added.
kde/kalarmcal-20.08.3-x86_64-1.txz: Added.
kde/kalgebra-20.08.3-x86_64-1.txz: Upgraded.
kde/kalzium-20.08.3-x86_64-1.txz: Upgraded.
kde/kamera-20.08.3-x86_64-1.txz: Upgraded.
kde/kamoso-20.08.3-x86_64-1.txz: Added.
kde/kanagram-20.08.3-x86_64-1.txz: Upgraded.
kde/kapidox-5.76.0-x86_64-1.txz: Added.
kde/kapman-20.08.3-x86_64-1.txz: Upgraded.
kde/kapptemplate-20.08.3-x86_64-1.txz: Upgraded.
kde/karchive-5.76.0-x86_64-1.txz: Added.
kde/kate-20.08.3-x86_64-1.txz: Upgraded.
kde/katomic-20.08.3-x86_64-1.txz: Upgraded.
kde/kaudiocreator-1.3-x86_64-3.txz: Removed.
kde/kauth-5.76.0-x86_64-1.txz: Added.
kde/kbackup-20.08.3-x86_64-1.txz: Added.
kde/kblackbox-20.08.3-x86_64-1.txz: Upgraded.
kde/kblocks-20.08.3-x86_64-1.txz: Upgraded.
kde/kbookmarks-5.76.0-x86_64-1.txz: Added.
kde/kbounce-20.08.3-x86_64-1.txz: Upgraded.
kde/kbreakout-20.08.3-x86_64-1.txz: Upgraded.
kde/kbruch-20.08.3-x86_64-1.txz: Upgraded.
kde/kcachegrind-20.08.3-x86_64-1.txz: Upgraded.
kde/kcalc-20.08.3-x86_64-1.txz: Upgraded.
kde/kcalendarcore-5.76.0-x86_64-1.txz: Added.
kde/kcalutils-20.08.3-x86_64-1.txz: Added.
kde/kcharselect-20.08.3-x86_64-1.txz: Upgraded.
kde/kcm-fcitx-0.5.6-x86_64-1.txz: Added.
kde/kcmutils-5.76.0-x86_64-1.txz: Added.
kde/kcodecs-5.76.0-x86_64-1.txz: Added.
kde/kcolorchooser-20.08.3-x86_64-1.txz: Upgraded.
kde/kcompletion-5.76.0-x86_64-1.txz: Added.
kde/kconfig-5.76.0-x86_64-1.txz: Added.
kde/kconfigwidgets-5.76.0-x86_64-1.txz: Added.
kde/kcontacts-5.76.0-x86_64-1.txz: Added.
kde/kcoreaddons-5.76.0-x86_64-1.txz: Added.
kde/kcrash-5.76.0-x86_64-1.txz: Added.
kde/kcron-20.08.3-x86_64-1.txz: Upgraded.
kde/kdav-5.76.0-x86_64-1.txz: Added.
kde/kdbusaddons-5.76.0-x86_64-1.txz: Added.
kde/kde-base-artwork-4.14.3-x86_64-3.txz: Removed.
kde/kde-baseapps-4.14.3-x86_64-3.txz: Removed.
kde/kde-cli-tools-5.20.4-x86_64-1.txz: Added.
kde/kde-dev-scripts-20.08.3-x86_64-1.txz: Upgraded.
kde/kde-dev-utils-20.08.3-x86_64-1.txz: Upgraded.
kde/kde-gtk-config-5.20.4-x86_64-1.txz: Added.
kde/kde-runtime-4.14.3-x86_64-8.txz: Removed.
kde/kde-wallpapers-4.14.3-noarch-2.txz: Removed.
kde/kde-workspace-4.11.22-x86_64-9.txz: Removed.
kde/kdeartwork-4.14.3-x86_64-3.txz: Removed.
kde/kdebugsettings-20.08.3-x86_64-1.txz: Added.
kde/kdeclarative-5.76.0-x86_64-1.txz: Added.
kde/kdeconnect-kde-20.08.3-x86_64-1.txz: Upgraded.
kde/kdecoration-5.20.4-x86_64-1.txz: Added.
kde/kded-5.76.0-x86_64-1.txz: Added.
kde/kdeedu-data-20.08.3-x86_64-1.txz: Added.
kde/kdegraphics-mobipocket-20.08.3-x86_64-1.txz: Upgraded.
kde/kdegraphics-strigi-analyzer-4.14.3-x86_64-3.txz: Removed.
kde/kdegraphics-thumbnailers-20.08.3-x86_64-1.txz: Upgraded.
kde/kdelibs-4.14.38-x86_64-8.txz: Removed.
kde/kdelibs4support-5.76.0-x86_64-1.txz: Added.
kde/kdenetwork-filesharing-20.08.3-x86_64-1.txz: Upgraded.
kde/kdenetwork-strigi-analyzers-4.14.3-x86_64-3.txz: Removed.
kde/kdenlive-20.08.3-x86_64-1.txz: Added.
kde/kdepim-4.14.10-x86_64-5.txz: Removed.
kde/kdepim-addons-20.08.3-x86_64-1.txz: Added.
kde/kdepim-apps-libs-20.08.3-x86_64-1.txz: Added.
kde/kdepim-runtime-20.08.3-x86_64-1.txz: Upgraded.
kde/kdepimlibs-4.14.10-x86_64-9.txz: Removed.
kde/kdeplasma-addons-5.20.4-x86_64-1.txz: Upgraded.
kde/kdesdk-kioslaves-20.08.3-x86_64-1.txz: Upgraded.
kde/kdesdk-strigi-analyzers-4.14.3-x86_64-3.txz: Removed.
kde/kdesdk-thumbnailers-20.08.3-x86_64-1.txz: Upgraded.
kde/kdesignerplugin-5.76.0-x86_64-1.txz: Added.
kde/kdesu-5.76.0-x86_64-1.txz: Added.
kde/kdev-php-5.6.0-x86_64-1.txz: Added.
kde/kdev-python-5.6.0-x86_64-1.txz: Upgraded.
kde/kdevelop-5.6.0-x86_64-1.txz: Upgraded.
kde/kdevelop-pg-qt-2.2.1-x86_64-1.txz: Upgraded.
kde/kdevelop-php-1.7.4-x86_64-2.txz: Removed.
kde/kdevelop-php-docs-1.7.4-x86_64-2.txz: Removed.
kde/kdevplatform-1.7.4-x86_64-2.txz: Removed.
kde/kdewebdev-4.14.3-x86_64-3.txz: Removed.
kde/kdewebkit-5.76.0-x86_64-1.txz: Added.
kde/kdf-20.08.3-x86_64-1.txz: Upgraded.
kde/kdiagram-2.7.0-x86_64-1.txz: Added.
kde/kdialog-20.08.3-x86_64-1.txz: Added.
kde/kdiamond-20.08.3-x86_64-1.txz: Upgraded.
kde/kdnssd-5.76.0-x86_64-1.txz: Added.
kde/kdoctools-5.76.0-x86_64-1.txz: Added.
kde/keditbookmarks-20.08.3-x86_64-1.txz: Added.
kde/kemoticons-5.76.0-x86_64-1.txz: Added.
kde/kfilemetadata-5.76.0-x86_64-1.txz: Upgraded.
kde/kfind-20.08.3-x86_64-1.txz: Added.
kde/kfloppy-20.08.3-x86_64-1.txz: Upgraded.
kde/kfourinline-20.08.3-x86_64-1.txz: Upgraded.
kde/kgamma-4.14.3-x86_64-3.txz: Removed.
kde/kgamma5-5.20.4-x86_64-1.txz: Added.
kde/kgeography-20.08.3-x86_64-1.txz: Upgraded.
kde/kget-20.08.3-x86_64-1.txz: Upgraded.
kde/kglobalaccel-5.76.0-x86_64-1.txz: Added.
kde/kgoldrunner-20.08.3-x86_64-1.txz: Upgraded.
kde/kgpg-20.08.3-x86_64-1.txz: Upgraded.
kde/kguiaddons-5.76.0-x86_64-1.txz: Added.
kde/khangman-20.08.3-x86_64-1.txz: Upgraded.
kde/khelpcenter-20.08.3-x86_64-1.txz: Added.
kde/kholidays-5.76.0-x86_64-1.txz: Added.
kde/khotkeys-5.20.4-x86_64-1.txz: Added.
kde/khtml-5.76.0-x86_64-1.txz: Added.
kde/ki18n-5.76.0-x86_64-1.txz: Added.
kde/kiconthemes-5.76.0-x86_64-1.txz: Added.
kde/kid3-3.8.4-x86_64-1.txz: Added.
kde/kidentitymanagement-20.08.3-x86_64-1.txz: Added.
kde/kidletime-5.76.0-x86_64-1.txz: Added.
kde/kig-20.08.3-x86_64-1.txz: Upgraded.
kde/kigo-20.08.3-x86_64-1.txz: Upgraded.
kde/kile-2.9.93-x86_64-1.txz: Added.
kde/killbots-20.08.3-x86_64-1.txz: Upgraded.
kde/kimageformats-5.76.0-x86_64-1.txz: Added.
kde/kimagemapeditor-20.08.3-x86_64-1.txz: Added.
kde/kimap-20.08.3-x86_64-1.txz: Added.
kde/kinfocenter-5.20.4-x86_64-1.txz: Added.
kde/kinit-5.76.0-x86_64-1.txz: Added.
kde/kio-5.76.0-x86_64-1.txz: Added.
kde/kio-extras-20.08.3-x86_64-1.txz: Added.
kde/kio-gdrive-20.08.3-x86_64-1.txz: Added.
kde/kio-mtp-2063e75_20131020git-x86_64-4.txz: Removed.
kde/kipi-plugins-20.08.3-x86_64-1.txz: Added.
kde/kirigami-gallery-20.08.3-x86_64-1.txz: Added.
kde/kirigami2-5.76.0-x86_64-1.txz: Added.
kde/kiriki-20.08.3-x86_64-1.txz: Upgraded.
kde/kitemmodels-5.76.0-x86_64-1.txz: Added.
kde/kitemviews-5.76.0-x86_64-1.txz: Added.
kde/kiten-20.08.3-x86_64-1.txz: Upgraded.
kde/kitinerary-20.08.3-x86_64-1.txz: Added.
kde/kjobwidgets-5.76.0-x86_64-1.txz: Added.
kde/kjots-20200924_355b642-x86_64-1.txz: Added.
kde/kjs-5.76.0-x86_64-1.txz: Added.
kde/kjsembed-5.76.0-x86_64-1.txz: Added.
kde/kjumpingcube-20.08.3-x86_64-1.txz: Upgraded.
kde/kldap-20.08.3-x86_64-1.txz: Added.
kde/kleopatra-20.08.3-x86_64-1.txz: Added.
kde/klettres-4.14.3-x86_64-3.txz: Removed.
kde/klickety-20.08.3-x86_64-1.txz: Upgraded.
kde/klines-20.08.3-x86_64-1.txz: Upgraded.
kde/kmag-20.08.3-x86_64-1.txz: Upgraded.
kde/kmahjongg-20.08.3-x86_64-1.txz: Upgraded.
kde/kmail-20.08.3-x86_64-1.txz: Added.
kde/kmail-account-wizard-20.08.3-x86_64-1.txz: Added.
kde/kmailtransport-20.08.3-x86_64-1.txz: Added.
kde/kmbox-20.08.3-x86_64-1.txz: Added.
kde/kmediaplayer-5.76.0-x86_64-1.txz: Added.
kde/kmenuedit-5.20.4-x86_64-1.txz: Added.
kde/kmime-20.08.3-x86_64-1.txz: Added.
kde/kmines-20.08.3-x86_64-1.txz: Upgraded.
kde/kmix-20.08.3-x86_64-1.txz: Upgraded.
kde/kmousetool-20.08.3-x86_64-1.txz: Upgraded.
kde/kmouth-20.08.3-x86_64-1.txz: Upgraded.
kde/kmplot-20.08.3-x86_64-1.txz: Upgraded.
kde/kmymoney-5.1.0-x86_64-1.txz: Added.
kde/knavalbattle-20.08.3-x86_64-1.txz: Upgraded.
kde/knetwalk-20.08.3-x86_64-1.txz: Upgraded.
kde/knewstuff-5.76.0-x86_64-1.txz: Added.
kde/knights-20.08.3-x86_64-1.txz: Added.
kde/knotes-20.08.3-x86_64-1.txz: Added.
kde/knotifications-5.76.0-x86_64-1.txz: Added.
kde/knotifyconfig-5.76.0-x86_64-1.txz: Added.
kde/kolf-20.08.3-x86_64-1.txz: Upgraded.
kde/kollision-20.08.3-x86_64-1.txz: Upgraded.
kde/kolourpaint-20.08.3-x86_64-1.txz: Upgraded.
kde/kompare-20.08.3-x86_64-1.txz: Upgraded.
kde/konqueror-20.08.3-x86_64-1.txz: Added.
kde/konquest-20.08.3-x86_64-1.txz: Upgraded.
kde/konsole-20.08.3-x86_64-1.txz: Upgraded.
kde/kontact-20.08.3-x86_64-1.txz: Added.
kde/kontactinterface-20.08.3-x86_64-1.txz: Added.
kde/kopete-20.08.3-x86_64-1.txz: Upgraded.
kde/korganizer-20.08.3-x86_64-1.txz: Added.
kde/korundum-4.14.3-x86_64-8.txz: Removed.
kde/kpackage-5.76.0-x86_64-1.txz: Added.
kde/kparts-5.76.0-x86_64-1.txz: Added.
kde/kpat-20.08.3-x86_64-1.txz: Upgraded.
kde/kpeople-5.76.0-x86_64-1.txz: Added.
kde/kpeoplevcard-0.1-x86_64-1.txz: Added.
kde/kpimtextedit-20.08.3-x86_64-1.txz: Added.
kde/kpkpass-20.08.3-x86_64-1.txz: Added.
kde/kplayer-0.7.2-x86_64-3.txz: Removed.
kde/kplotting-5.76.0-x86_64-1.txz: Added.
kde/kpmcore-4.2.0-x86_64-1.txz: Added.
kde/kppp-4.14.3-x86_64-3.txz: Removed.
kde/kpty-5.76.0-x86_64-1.txz: Added.
kde/kqtquickcharts-20.08.3-x86_64-1.txz: Upgraded.
kde/kquickcharts-5.76.0-x86_64-1.txz: Added.
kde/krdc-20.08.3-x86_64-1.txz: Upgraded.
kde/kremotecontrol-4.14.3-x86_64-3.txz: Removed.
kde/krename-5.0.1-x86_64-1.txz: Added.
kde/kreversi-20.08.3-x86_64-1.txz: Upgraded.
kde/krfb-20.08.3-x86_64-1.txz: Upgraded.
kde/krita-4.4.1-x86_64-1.txz: Added.
kde/kross-5.76.0-x86_64-1.txz: Added.
kde/kross-interpreters-20.08.3-x86_64-1.txz: Upgraded.
kde/kruler-20.08.3-x86_64-1.txz: Upgraded.
kde/krunner-5.76.0-x86_64-1.txz: Added.
kde/krusader-2.7.2-x86_64-1.txz: Added.
kde/ksaneplugin-4.14.3-x86_64-3.txz: Removed.
kde/kscreen-5.20.4-x86_64-1.txz: Upgraded.
kde/kscreenlocker-5.20.4-x86_64-1.txz: Added.
kde/kservice-5.76.0-x86_64-1.txz: Added.
kde/kshisen-20.08.3-x86_64-1.txz: Upgraded.
kde/ksirk-20.08.3-x86_64-1.txz: Upgraded.
kde/ksmtp-20.08.3-x86_64-1.txz: Added.
kde/ksnakeduel-20.08.3-x86_64-1.txz: Upgraded.
kde/ksnapshot-4.14.3-x86_64-3.txz: Removed.
kde/kspaceduel-20.08.3-x86_64-1.txz: Upgraded.
kde/ksquares-20.08.3-x86_64-1.txz: Upgraded.
kde/ksshaskpass-5.20.4-x86_64-1.txz: Added.
kde/kstars-3.5.0-x86_64-1.txz: Upgraded.
kde/ksudoku-20.08.3-x86_64-1.txz: Upgraded.
kde/ksysguard-5.20.4-x86_64-1.txz: Added.
kde/ksystemlog-20.08.3-x86_64-1.txz: Upgraded.
kde/kteatime-20.08.3-x86_64-1.txz: Upgraded.
kde/ktexteditor-5.76.0-x86_64-1.txz: Added.
kde/ktextwidgets-5.76.0-x86_64-1.txz: Added.
kde/ktimer-20.08.3-x86_64-1.txz: Upgraded.
kde/ktimetracker-5.0.1-x86_64-1.txz: Added.
kde/ktnef-20.08.3-x86_64-1.txz: Added.
kde/ktorrent-5.2.0-x86_64-1.txz: Upgraded.
kde/ktouch-20.08.3-x86_64-1.txz: Upgraded.
kde/ktuberling-4.14.3-x86_64-3.txz: Removed.
kde/kturtle-20.08.3-x86_64-1.txz: Upgraded.
kde/ktux-4.14.3-x86_64-3.txz: Removed.
kde/kubrick-20.08.3-x86_64-1.txz: Upgraded.
kde/kunitconversion-5.76.0-x86_64-1.txz: Added.
kde/kuser-4.14.3-x86_64-3.txz: Removed.
kde/kwallet-5.76.0-x86_64-1.txz: Added.
kde/kwallet-pam-5.20.4-x86_64-1.txz: Added.
kde/kwalletmanager-20.08.3-x86_64-1.txz: Upgraded.
kde/kwave-20.08.3-x86_64-1.txz: Added.
kde/kwayland-5.76.0-x86_64-1.txz: Added.
kde/kwayland-integration-5.20.4-x86_64-1.txz: Added.
kde/kwayland-server-5.20.4-x86_64-1.txz: Added.
kde/kwebkitpart-1.3.4-x86_64-3.txz: Removed.
kde/kwidgetsaddons-5.76.0-x86_64-1.txz: Added.
kde/kwin-5.20.4-x86_64-1.txz: Added.
kde/kwindowsystem-5.76.0-x86_64-1.txz: Added.
kde/kwordquiz-20.08.3-x86_64-1.txz: Upgraded.
kde/kwrited-5.20.4-x86_64-1.txz: Added.
kde/kxmlgui-5.76.0-x86_64-1.txz: Added.
kde/kxmlrpcclient-5.76.0-x86_64-1.txz: Added.
kde/latte-dock-0.9.11-x86_64-1.txz: Added.
kde/libgravatar-20.08.3-x86_64-1.txz: Added.
kde/libkcddb-20.08.3-x86_64-1.txz: Upgraded.
kde/libkcompactdisc-20.08.3-x86_64-1.txz: Upgraded.
kde/libkdcraw-20.08.3-x86_64-1.txz: Upgraded.
kde/libkdeedu-4.14.3-x86_64-3.txz: Removed.
kde/libkdegames-20.08.3-x86_64-1.txz: Upgraded.
kde/libkdepim-20.08.3-x86_64-1.txz: Added.
kde/libkeduvocdocument-20.08.3-x86_64-1.txz: Added.
kde/libkexiv2-20.08.3-x86_64-1.txz: Upgraded.
kde/libkgapi-20.08.3-x86_64-1.txz: Added.
kde/libkgeomap-20.08.3-x86_64-1.txz: Added.
kde/libkipi-20.08.3-x86_64-1.txz: Upgraded.
kde/libkleo-20.08.3-x86_64-1.txz: Added.
kde/libkmahjongg-20.08.3-x86_64-1.txz: Upgraded.
kde/libkomparediff2-20.08.3-x86_64-1.txz: Upgraded.
kde/libksane-20.08.3-x86_64-1.txz: Upgraded.
kde/libkscreen-5.20.4-x86_64-1.txz: Upgraded.
kde/libksieve-20.08.3-x86_64-1.txz: Added.
kde/libksysguard-5.20.4-x86_64-1.txz: Added.
kde/libktorrent-2.2.0-x86_64-1.txz: Upgraded.
kde/libmm-qt-1.0.1-x86_64-3.txz: Removed.
kde/libnm-qt-0.9.8.4-x86_64-1.txz: Removed.
kde/lokalize-20.08.3-x86_64-1.txz: Upgraded.
kde/lskat-20.08.3-x86_64-1.txz: Upgraded.
kde/mailcommon-20.08.3-x86_64-1.txz: Added.
kde/mailimporter-20.08.3-x86_64-1.txz: Added.
kde/marble-20.08.3-x86_64-1.txz: Upgraded.
kde/mbox-importer-20.08.3-x86_64-1.txz: Added.
kde/messagelib-20.08.3-x86_64-1.txz: Added.
kde/milou-5.20.4-x86_64-1.txz: Added.
kde/minuet-20.08.3-x86_64-1.txz: Added.
kde/modemmanager-qt-5.76.0-x86_64-1.txz: Added.
kde/mplayerthumbs-4.14.3-x86_64-3.txz: Removed.
kde/nepomuk-core-4.14.3-x86_64-5.txz: Removed.
kde/nepomuk-widgets-4.14.3-x86_64-3.txz: Removed.
kde/networkmanager-qt-5.76.0-x86_64-1.txz: Added.
kde/okteta-0.26.4-x86_64-1.txz: Upgraded.
kde/okular-20.08.3-x86_64-1.txz: Upgraded.
kde/oxygen-5.20.4-x86_64-1.txz: Added.
kde/oxygen-fonts-5.4.3-noarch-1.txz: Added.
kde/oxygen-gtk2-1.4.6-x86_64-1.txz: Upgraded.
kde/oxygen-icons-4.14.3-x86_64-3.txz: Removed.
kde/oxygen-icons5-5.76.0-noarch-1.txz: Added.
kde/pairs-4.14.3-x86_64-3.txz: Removed.
kde/palapeli-20.08.3-x86_64-1.txz: Upgraded.
kde/parley-20.08.3-x86_64-1.txz: Upgraded.
kde/partitionmanager-4.2.0-x86_64-1.txz: Upgraded.
kde/perlkde-4.14.3-x86_64-10.txz: Removed.
kde/perlqt-4.14.3-x86_64-11.txz: Removed.
kde/picmi-20.08.3-x86_64-1.txz: Upgraded.
kde/pim-data-exporter-20.08.3-x86_64-1.txz: Added.
kde/pim-sieve-editor-20.08.3-x86_64-1.txz: Added.
kde/pimcommon-20.08.3-x86_64-1.txz: Added.
kde/plasma-browser-integration-5.20.4-x86_64-1.txz: Added.
kde/plasma-desktop-5.20.4-x86_64-1.txz: Added.
kde/plasma-disks-5.20.4-x86_64-1.txz: Added.
kde/plasma-framework-5.76.0-x86_64-1.txz: Added.
kde/plasma-integration-5.20.4-x86_64-1.txz: Added.
kde/plasma-nm-5.20.4-x86_64-1.txz: Upgraded.
kde/plasma-pa-5.20.4-x86_64-1.txz: Added.
kde/plasma-sdk-5.20.4-x86_64-1.txz: Added.
kde/plasma-vault-5.20.4-x86_64-1.txz: Added.
kde/plasma-wayland-protocols-1.1.1-x86_64-1.txz: Added.
kde/plasma-workspace-5.20.4-x86_64-1.txz: Added.
kde/plasma-workspace-wallpapers-5.20.4-x86_64-1.txz: Added.
kde/polkit-kde-agent-1-5.20.4-x86_64-1.txz: Upgraded.
kde/polkit-kde-kcmodules-1-001bdf7_20120111git-x86_64-3.txz: Removed.
kde/powerdevil-5.20.4-x86_64-1.txz: Added.
kde/poxml-20.08.3-x86_64-1.txz: Upgraded.
kde/print-manager-20.08.3-x86_64-1.txz: Upgraded.
kde/prison-5.76.0-x86_64-1.txz: Added.
kde/pulseaudio-qt-1.2-x86_64-1.txz: Added.
kde/purpose-5.76.0-x86_64-1.txz: Added.
kde/pykde4-4.14.3-x86_64-11.txz: Removed.
kde/qqc2-desktop-style-5.76.0-x86_64-1.txz: Added.
kde/qtruby-4.14.3-x86_64-11.txz: Removed.
kde/rocs-20.08.3-x86_64-1.txz: Upgraded.
kde/sddm-0.19.0-x86_64-1.txz: Added.
kde/sddm-kcm-5.20.4-x86_64-1.txz: Added.
kde/skanlite-2.2.0-x86_64-1.txz: Upgraded.
kde/smokegen-4.14.3-x86_64-3.txz: Removed.
kde/smokekde-4.14.3-x86_64-3.txz: Removed.
kde/smokeqt-4.14.3-x86_64-6.txz: Removed.
kde/solid-5.76.0-x86_64-1.txz: Added.
kde/sonnet-5.76.0-x86_64-1.txz: Added.
kde/spectacle-20.08.3-x86_64-1.txz: Added.
kde/step-20.08.3-x86_64-1.txz: Upgraded.
kde/superkaramba-4.14.3-x86_64-4.txz: Removed.
kde/svgpart-20.08.3-x86_64-1.txz: Upgraded.
kde/sweeper-20.08.3-x86_64-1.txz: Upgraded.
kde/syndication-5.76.0-x86_64-1.txz: Added.
kde/syntax-highlighting-5.76.0-x86_64-1.txz: Added.
kde/systemsettings-5.20.4-x86_64-1.txz: Added.
kde/threadweaver-5.76.0-x86_64-1.txz: Added.
kde/umbrello-20.08.3-x86_64-1.txz: Upgraded.
kde/wacomtablet-20201030_417d9d9-x86_64-1.txz: Added.
kde/wicd-kde-0.3.0_bcf27d8-x86_64-3.txz: Removed.
kde/xdg-desktop-portal-kde-5.20.4-x86_64-1.txz: Added.
kde/yakuake-20.08.3-x86_64-1.txz: Added.
kde/zeroconf-ioslave-20.08.3-x86_64-1.txz: Upgraded.
kdei/calligra-l10n-bs-2.9.11-noarch-1.txz: Removed.
kdei/calligra-l10n-ca-2.9.11-noarch-1.txz: Removed.
kdei/calligra-l10n-ca@valencia-2.9.11-noarch-1.txz: Removed.
kdei/calligra-l10n-cs-2.9.11-noarch-1.txz: Removed.
kdei/calligra-l10n-da-2.9.11-noarch-1.txz: Removed.
kdei/calligra-l10n-de-2.9.11-noarch-1.txz: Removed.
kdei/calligra-l10n-el-2.9.11-noarch-1.txz: Removed.
kdei/calligra-l10n-en_GB-2.9.11-noarch-1.txz: Removed.
kdei/calligra-l10n-es-2.9.11-noarch-1.txz: Removed.
kdei/calligra-l10n-et-2.9.11-noarch-1.txz: Removed.
kdei/calligra-l10n-fi-2.9.11-noarch-1.txz: Removed.
kdei/calligra-l10n-fr-2.9.11-noarch-1.txz: Removed.
kdei/calligra-l10n-gl-2.9.11-noarch-1.txz: Removed.
kdei/calligra-l10n-hu-2.9.11-noarch-1.txz: Removed.
kdei/calligra-l10n-it-2.9.11-noarch-1.txz: Removed.
kdei/calligra-l10n-ja-2.9.11-noarch-1.txz: Removed.
kdei/calligra-l10n-kk-2.9.11-noarch-1.txz: Removed.
kdei/calligra-l10n-nb-2.9.11-noarch-1.txz: Removed.
kdei/calligra-l10n-nl-2.9.11-noarch-1.txz: Removed.
kdei/calligra-l10n-pl-2.9.11-noarch-1.txz: Removed.
kdei/calligra-l10n-pt-2.9.11-noarch-1.txz: Removed.
kdei/calligra-l10n-pt_BR-2.9.11-noarch-1.txz: Removed.
kdei/calligra-l10n-ru-2.9.11-noarch-1.txz: Removed.
kdei/calligra-l10n-sk-2.9.11-noarch-1.txz: Removed.
kdei/calligra-l10n-sv-2.9.11-noarch-1.txz: Removed.
kdei/calligra-l10n-tr-2.9.11-noarch-1.txz: Removed.
kdei/calligra-l10n-uk-2.9.11-noarch-1.txz: Removed.
kdei/calligra-l10n-zh_CN-2.9.11-noarch-1.txz: Removed.
kdei/calligra-l10n-zh_TW-2.9.11-noarch-1.txz: Removed.
kdei/kde-l10n-ar-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-bg-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-bs-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-ca-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-ca@valencia-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-cs-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-da-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-de-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-el-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-en_GB-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-es-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-et-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-eu-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-fa-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-fi-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-fr-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-ga-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-gl-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-he-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-hi-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-hr-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-hu-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-ia-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-id-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-is-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-it-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-ja-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-kk-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-km-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-ko-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-lt-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-lv-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-mr-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-nb-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-nds-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-nl-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-nn-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-pa-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-pl-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-pt-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-pt_BR-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-ro-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-ru-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-sk-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-sl-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-sr-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-sv-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-tr-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-ug-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-uk-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-wa-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-zh_CN-4.14.3-noarch-1.txz: Removed.
kdei/kde-l10n-zh_TW-4.14.3-noarch-1.txz: Removed.
l/ConsoleKit2-1.2.1-x86_64-4.txz: Removed.
l/PyQt-4.12.3-x86_64-3.txz: Removed.
l/QScintilla-2.11.6-x86_64-1.txz: Upgraded.
       Drop Qt4 support.
l/QtAV-20200910_2a470d2a-x86_64-1.txz: Added.
l/SDL2-2.0.12-x86_64-2.txz: Rebuilt.
l/accountsservice-0.6.55-x86_64-1.txz: Added.
l/automoc4-0.9.88-x86_64-2.txz: Removed.
l/cfitsio-3.49-x86_64-1.txz: Added.
l/cryfs-0.10.2-x86_64-1.txz: Added.
l/cryptopp-8.2.0-x86_64-1.txz: Added.
l/dotconf-1.3-x86_64-1.txz: Added.
l/dvdauthor-0.7.2-x86_64-1.txz: Added.
l/eigen3-3.3.9-x86_64-1.txz: Upgraded.
l/frei0r-plugins-1.7.0-x86_64-1.txz: Added.
l/fuse3-3.10.1-x86_64-1.txz: Upgraded.
l/grantlee-5.2.0-x86_64-1.txz: Upgraded.
l/gst-plugins-base-1.18.2-x86_64-1.txz: Upgraded.
l/gst-plugins-good-1.18.2-x86_64-1.txz: Upgraded.
l/gst-plugins-libav-1.18.2-x86_64-1.txz: Upgraded.
l/gstreamer-1.18.2-x86_64-1.txz: Upgraded.
l/gtk+3-3.24.24-x86_64-1.txz: Upgraded.
l/gvfs-1.46.1-x86_64-2.txz: Rebuilt.
       Recompiled using -Dlogind=true.
l/kdsoap-1.9.1-x86_64-1.txz: Added.
l/lensfun-0.3.95-x86_64-1.txz: Added.
l/libappindicator-12.10.0-x86_64-1.txz: Added.
l/libbluedevil-2.1-x86_64-2.txz: Removed.
l/libburn-1.5.2.pl01-x86_64-1.txz: Added.
l/libdbusmenu-16.04.0-x86_64-1.txz: Added.
l/libdbusmenu-qt-0.9.3+16.04.20160218-x86_64-1.txz: Upgraded.
l/libdmtx-0.7.5-x86_64-1.txz: Added.
l/libindicator-12.10.1-x86_64-1.txz: Added.
l/liblastfm-1.1.0-x86_64-1.txz: Removed.
l/libqalculate-3.14.0-x86_64-1.txz: Added.
l/mlt-6.22.1-x86_64-1.txz: Added.
l/opencv-4.5.0-x86_64-1.txz: Added.
l/phonon-4.11.1-x86_64-1.txz: Upgraded.
l/phonon-backend-gstreamer-4.10.0-x86_64-1.txz: Added.
l/phonon-gstreamer-4.8.2-x86_64-2.txz: Removed.
l/pipewire-0.3.13-x86_64-1.txz: Added.
l/polkit-0.118-x86_64-2.txz: Rebuilt.
l/polkit-qt-1-0.113.0-x86_64-1.txz: Upgraded.
l/poppler-20.12.1-x86_64-1.txz: Upgraded.
l/python-certifi-2020.12.5-x86_64-1.txz: Upgraded.
l/python-pygments-2.7.3-x86_64-1.txz: Upgraded.
l/qca-2.3.1-x86_64-1.txz: Upgraded.
l/qca-qt5-2.3.1-x86_64-1.txz: Removed.
l/qimageblitz-0.0.6-x86_64-2.txz: Removed.
l/qjson-0.9.0-x86_64-1.txz: Removed.
l/qrencode-4.1.1-x86_64-1.txz: Added.
l/qt-4.8.7-x86_64-17.txz: Removed.
l/qt-gstreamer-1.2.0-x86_64-2.txz: Removed.
l/qt5-5.15.2-x86_64-2.txz: Rebuilt.
l/qtkeychain-0.11.1-x86_64-1.txz: Added.
l/qtscriptgenerator-0.2.0-x86_64-3.txz: Removed.
l/quazip-1.1-x86_64-1.txz: Added.
l/raptor2-2.0.15-x86_64-10.txz: Removed.
l/rasqal-0.9.33-x86_64-3.txz: Removed.
l/readline-8.1.000-x86_64-1.txz: Upgraded.
l/redland-1.0.17-x86_64-6.txz: Removed.
l/rttr-0.9.6-x86_64-1.txz: Added.
l/soprano-2.9.4-x86_64-3.txz: Removed.
l/speech-dispatcher-0.10.2-x86_64-1.txz: Added.
l/strigi-0.7.8-x86_64-4.txz: Removed.
l/vid.stab-20200916_e851e7b-x86_64-1.txz: Added.
l/xapian-core-1.4.17-x86_64-2.txz: Rebuilt.
n/NetworkManager-1.28.0-x86_64-1.txz: Upgraded.
       Drop ConsoleKit2 support and add elogind support.
x/OpenCC-1.1.1-x86_64-1.txz: Added.
x/cldr-emoji-annotation-37.0_13.0_0_2-noarch-1.txz: Added.
x/fcitx-4.2.9.8-x86_64-1.txz: Added.
       Don't build Qt4 components.
x/fcitx-anthy-0.2.3-x86_64-1.txz: Added.
x/fcitx-configtool-0.4.9-x86_64-1.txz: Added.
x/fcitx-hangul-0.3.1-x86_64-1.txz: Added.
x/fcitx-kkc-0.1.4-x86_64-1.txz: Added.
x/fcitx-libpinyin-0.5.3-x86_64-1.txz: Added.
x/fcitx-m17n-0.2.4-x86_64-1.txz: Added.
x/fcitx-qt5-1.2.5-x86_64-1.txz: Added.
x/fcitx-sayura-0.1.2-x86_64-1.txz: Added.
x/fcitx-table-extra-0.3.8-x86_64-1.txz: Added.
x/fcitx-table-other-0.2.4-x86_64-1.txz: Added.
x/fcitx-unikey-0.2.7-x86_64-1.txz: Added.
x/ibus-1.5.23-x86_64-1.txz: Added.
x/ibus-anthy-1.5.11-x86_64-1.txz: Added.
x/ibus-hangul-1.5.4-x86_64-1.txz: Added.
x/ibus-kkc-1.5.22-x86_64-1.txz: Added.
x/ibus-libpinyin-1.11.1-x86_64-1.txz: Added.
x/ibus-m17n-1.4.3-x86_64-1.txz: Added.
x/ibus-table-1.12.1-x86_64-1.txz: Added.
x/ibus-unikey-0.6.1-x86_64-1.txz: Added.
x/libgee-0.20.1-x86_64-1.txz: Added.
x/libkkc-0.3.5-x86_64-1.txz: Added.
x/libkkc-data-0.2.7-x86_64-1.txz: Added.
x/libpinyin-2.3.0-x86_64-1.txz: Added.
x/marisa-0.2.4-x86_64-1.txz: Added.
x/motif-2.3.8-x86_64-3.txz: Rebuilt.
       Added xinitrc.mwm. Thanks to ziprun.
x/scim-1.4.18-x86_64-1.txz: Removed.
x/scim-anthy-1.2.7-x86_64-2.txz: Removed.
x/scim-hangul-0.4.0-x86_64-2.txz: Removed.
x/scim-input-pad-0.1.3.1-x86_64-2.txz: Removed.
x/scim-m17n-0.2.3-x86_64-2.txz: Removed.
x/scim-pinyin-0.5.92-x86_64-2.txz: Removed.
x/scim-tables-0.5.14.1-x86_64-2.txz: Removed.
x/skkdic-20200128-noarch-1.txz: Added.
x/xdm-1.1.11-x86_64-11.txz: Rebuilt.
       Drop ConsoleKit2 patch, fix pam.d/xdm file.
xap/seamonkey-2.53.5.1-x86_64-1.txz: Upgraded.
       https://www.seamonkey-project.org/releases/seamonkey2.53.5.1
xap/vim-gvim-8.2.2105-x86_64-1.txz: Upgraded.
xap/xine-lib-1.2.11-x86_64-1.txz: Upgraded.
xfce/Greybird-3.22.12-noarch-1.txz: Added.
xfce/elementary-xfce-0.15.1-x86_64-1.txz: Added.
xfce/exo-0.12.11-x86_64-2.txz: Rebuilt.
xfce/garcon-0.6.4-x86_64-2.txz: Rebuilt.
xfce/gtk-xfce-engine-2.10.1-x86_64-3.txz: Removed.
xfce/libxfce4ui-4.14.1-x86_64-1.txz: Upgraded.
xfce/libxfce4util-4.14.0-x86_64-1.txz: Upgraded.
xfce/mousepad-0.4.2-x86_64-1.txz: Added.
xfce/orage-4.12.1-x86_64-5.txz: Removed.
xfce/thunar-1.8.16-x86_64-2.txz: Rebuilt.
xfce/thunar-volman-0.9.5-x86_64-2.txz: Rebuilt.
xfce/tumbler-0.2.9-x86_64-2.txz: Rebuilt.
xfce/xfce4-appfinder-4.14.0-x86_64-1.txz: Upgraded.
xfce/xfce4-clipman-plugin-1.6.1-x86_64-1.txz: Upgraded.
xfce/xfce4-dev-tools-4.14.0-x86_64-1.txz: Upgraded.
xfce/xfce4-notifyd-0.6.2-x86_64-1.txz: Upgraded.
xfce/xfce4-panel-4.14.4-x86_64-1.txz: Upgraded.
xfce/xfce4-panel-profiles-1.0.10-x86_64-1.txz: Added.
xfce/xfce4-power-manager-1.6.6-x86_64-1.txz: Upgraded.
xfce/xfce4-pulseaudio-plugin-0.4.3-x86_64-1.txz: Upgraded.
xfce/xfce4-screensaver-0.1.11-x86_64-1.txz: Added.
xfce/xfce4-screenshooter-1.9.7-x86_64-1.txz: Upgraded.
xfce/xfce4-session-4.14.2-x86_64-1.txz: Upgraded.
xfce/xfce4-settings-4.14.3-x86_64-1.txz: Upgraded.
xfce/xfce4-systemload-plugin-1.2.3-x86_64-2.txz: Rebuilt.
xfce/xfce4-taskmanager-1.2.3-x86_64-1.txz: Upgraded.
xfce/xfce4-terminal-0.8.9.2-x86_64-1.txz: Upgraded.
xfce/xfce4-weather-plugin-0.10.2-x86_64-1.txz: Upgraded.
xfce/xfce4-whiskermenu-plugin-2.4.6-x86_64-1.txz: Added.
xfce/xfconf-4.14.4-x86_64-1.txz: Upgraded.
xfce/xfdesktop-4.14.3-x86_64-1.txz: Upgraded.
xfce/xfwm4-4.14.6-x86_64-1.txz: Upgraded.
Sat Dec 5 20:36:27 UTC 2020
l/libproxy-0.4.16-x86_64-1.txz: Upgraded.
n/mutt-2.0.3-x86_64-1.txz: Upgraded.
Post Napisano: 11 Dec 2020, 15:51
Slackware 32-bit
a/elogind-243.7-i586-2.txz: Rebuilt.
       /usr directory.
a/upower-0.99.11-i586-2.txz: Rebuilt.
d/gnucobol-3.1.1-i586-1.txz: Upgraded.
kde/powerdevil-5.20.4-i586-2.txz: Rebuilt.
       Thanks to GazL.
l/jasper-2.0.23-i586-1.txz: Upgraded.
l/sbc-1.5-i586-1.txz: Upgraded.
n/curl-7.74.0-i586-1.txz: Upgraded.
xap/xscreensaver-5.45-i586-1.txz: Upgraded.
a/kernel-generic-5.4.82-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.4.82_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.4.82-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.4.82_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.4.82-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.4.82_smp-i686-1.txz: Upgraded.
a/openssl-solibs-1.1.1i-i586-1.txz: Upgraded.
ap/gutenprint-5.3.4-i586-1.txz: Upgraded.
ap/htop-3.0.3-i586-1.txz: Upgraded.
d/kernel-headers-5.4.82_smp-x86-1.txz: Upgraded.
d/python3-3.9.1-i586-1.txz: Upgraded.
k/kernel-source-5.4.82_smp-noarch-1.txz: Upgraded.
l/M2Crypto-0.37.1-i586-1.txz: Upgraded.
l/gdk-pixbuf2-2.42.2-i586-1.txz: Upgraded.
l/imagemagick-7.0.10_46-i586-1.txz: Upgraded.
l/mlt-6.24.0-i586-1.txz: Upgraded.
l/pipewire-0.3.17-i586-1.txz: Upgraded.
n/openssl-1.1.1i-i586-1.txz: Upgraded.
x/fcitx-configtool-0.4.10-i586-1.txz: Upgraded.
x/libgee-0.20.3-i586-1.txz: Upgraded.
x/marisa-0.2.6-i586-1.txz: Upgraded.
extra/linux-5.4.82-nosmp-sdk/*: Upgraded.
packages.
Enjoy! :-)
a/aaa_elflibs-15.0-i586-28.txz: Rebuilt.
       libraw_r.so.16.0.0.
a/bash-5.1.000-i586-1.txz: Upgraded.
a/dbus-1.12.20-i586-2.txz: Rebuilt.
a/elogind-243.7-i586-1.txz: Added.
a/eudev-3.2.9-i586-2.txz: Rebuilt.
a/procps-ng-3.3.16-i586-3.txz: Rebuilt.
ap/cgmanager-0.42-i586-1.txz: Removed.
ap/pm-utils-1.4.1-i586-6.txz: Removed.
ap/vim-8.2.2105-i586-1.txz: Upgraded.
d/python-setuptools-51.0.0-i586-1.txz: Upgraded.
kde/akonadi-20.08.3-i586-1.txz: Upgraded.
kde/akonadi-calendar-20.08.3-i586-1.txz: Added.
kde/akonadi-calendar-tools-20.08.3-i586-1.txz: Added.
kde/akonadi-contacts-20.08.3-i586-1.txz: Added.
kde/akonadi-import-wizard-20.08.3-i586-1.txz: Added.
kde/akonadi-mime-20.08.3-i586-1.txz: Added.
kde/akonadi-notes-20.08.3-i586-1.txz: Added.
kde/akonadi-search-20.08.3-i586-1.txz: Added.
kde/akonadiconsole-20.08.3-i586-1.txz: Added.
kde/akregator-20.08.3-i586-1.txz: Added.
kde/alkimia-8.0.4-i586-1.txz: Added.
kde/amarok-2.9.0-i586-3.txz: Removed.
kde/amor-4.14.3-i586-3.txz: Removed.
kde/analitza-20.08.3-i586-1.txz: Upgraded.
kde/ark-20.08.3-i586-1.txz: Upgraded.
kde/artikulate-20.08.3-i586-1.txz: Upgraded.
kde/attica-5.76.0-i586-1.txz: Upgraded.
kde/audiocd-kio-20.08.3-i586-1.txz: Upgraded.
kde/baloo-5.76.0-i586-1.txz: Upgraded.
kde/baloo-widgets-20.08.3-i586-1.txz: Upgraded.
kde/blinken-20.08.3-i586-1.txz: Upgraded.
kde/bluedevil-5.20.4-i586-1.txz: Upgraded.
kde/bluez-qt-5.76.0-i586-1.txz: Added.
kde/bomber-20.08.3-i586-1.txz: Upgraded.
kde/bovo-20.08.3-i586-1.txz: Upgraded.
kde/breeze-5.20.4-i586-1.txz: Added.
kde/breeze-grub-5.20.4-i586-1.txz: Added.
kde/breeze-gtk-5.20.4-i586-1.txz: Added.
kde/calendarsupport-20.08.3-i586-1.txz: Added.
kde/calligra-3.2.1-i586-1.txz: Upgraded.
kde/calligraplan-3.2.2-i586-1.txz: Added.
kde/cantor-20.08.3-i586-1.txz: Upgraded.
kde/cervisia-20.08.3-i586-1.txz: Upgraded.
kde/digikam-7.1.0-i586-1.txz: Added.
kde/dolphin-20.08.3-i586-1.txz: Added.
kde/dolphin-plugins-20.08.3-i586-1.txz: Upgraded.
kde/dragon-20.08.3-i586-1.txz: Upgraded.
kde/drkonqi-5.20.4-i586-1.txz: Added.
kde/elisa-20.08.3-i586-1.txz: Added.
kde/eventviews-20.08.3-i586-1.txz: Added.
kde/extra-cmake-modules-5.76.0-i586-1.txz: Added.
kde/falkon-3.1.0-i586-1.txz: Added.
kde/ffmpegthumbs-20.08.3-i586-1.txz: Added.
kde/filelight-20.08.3-i586-1.txz: Upgraded.
kde/frameworkintegration-5.76.0-i586-1.txz: Added.
kde/granatier-20.08.3-i586-1.txz: Upgraded.
kde/grantlee-editor-20.08.3-i586-1.txz: Added.
kde/grantleetheme-20.08.3-i586-1.txz: Added.
kde/gwenview-20.08.3-i586-1.txz: Upgraded.
kde/incidenceeditor-20.08.3-i586-1.txz: Added.
kde/juk-20.08.3-i586-1.txz: Upgraded.
kde/k3b-20.08.3-i586-1.txz: Upgraded.
kde/kaccessible-4.14.3-i586-3.txz: Removed.
kde/kactivities-5.76.0-i586-1.txz: Upgraded.
kde/kactivities-stats-5.76.0-i586-1.txz: Added.
kde/kactivitymanagerd-5.20.4-i586-1.txz: Added.
kde/kaddressbook-20.08.3-i586-1.txz: Added.
kde/kajongg-4.14.3-i586-3.txz: Removed.
kde/kalarm-20.08.3-i586-1.txz: Added.
kde/kalarmcal-20.08.3-i586-1.txz: Added.
kde/kalgebra-20.08.3-i586-1.txz: Upgraded.
kde/kalzium-20.08.3-i586-1.txz: Upgraded.
kde/kamera-20.08.3-i586-1.txz: Upgraded.
kde/kamoso-20.08.3-i586-1.txz: Added.
kde/kanagram-20.08.3-i586-1.txz: Upgraded.
kde/kapidox-5.76.0-i586-1.txz: Added.
kde/kapman-20.08.3-i586-1.txz: Upgraded.
kde/kapptemplate-20.08.3-i586-1.txz: Upgraded.
kde/karchive-5.76.0-i586-1.txz: Added.
kde/kate-20.08.3-i586-1.txz: Upgraded.
kde/katomic-20.08.3-i586-1.txz: Upgraded.
kde/kaudiocreator-1.3-i586-3.txz: Removed.
kde/kauth-5.76.0-i586-1.txz: Added.
kde/kbackup-20.08.3-i586-1.txz: Added.
kde/kblackbox-20.08.3-i586-1.txz: Upgraded.
kde/kblocks-20.08.3-i586-1.txz: Upgraded.
kde/kbookmarks-5.76.0-i586-1.txz: Added.
kde/kbounce-20.08.3-i586-1.txz: Upgraded.
kde/kbreakout-20.08.3-i586-1.txz: Upgraded.
kde/kbruch-20.08.3-i586-1.txz: Upgraded.
kde/kcachegrind-20.08.3-i586-1.txz: Upgraded.
kde/kcalc-20.08.3-i586-1.txz: Upgraded.
kde/kcalendarcore-5.76.0-i586-1.txz: Added.
kde/kcalutils-20.08.3-i586-1.txz: Added.
kde/kcharselect-20.08.3-i586-1.txz: Upgraded.
kde/kcm-fcitx-0.5.6-i586-1.txz: Added.
kde/kcmutils-5.76.0-i586-1.txz: Added.
kde/kcodecs-5.76.0-i586-1.txz: Added.
kde/kcolorchooser-20.08.3-i586-1.txz: Upgraded.
kde/kcompletion-5.76.0-i586-1.txz: Added.
kde/kconfig-5.76.0-i586-1.txz: Added.
kde/kconfigwidgets-5.76.0-i586-1.txz: Added.
kde/kcontacts-5.76.0-i586-1.txz: Added.
kde/kcoreaddons-5.76.0-i586-1.txz: Added.
kde/kcrash-5.76.0-i586-1.txz: Added.
kde/kcron-20.08.3-i586-1.txz: Upgraded.
kde/kdav-5.76.0-i586-1.txz: Added.
kde/kdbusaddons-5.76.0-i586-1.txz: Added.
kde/kde-base-artwork-4.14.3-i586-3.txz: Removed.
kde/kde-baseapps-4.14.3-i586-3.txz: Removed.
kde/kde-cli-tools-5.20.4-i586-1.txz: Added.
kde/kde-dev-scripts-20.08.3-i586-1.txz: Upgraded.
kde/kde-dev-utils-20.08.3-i586-1.txz: Upgraded.
kde/kde-gtk-config-5.20.4-i586-1.txz: Added.
kde/kde-runtime-4.14.3-i586-8.txz: Removed.
kde/kde-workspace-4.11.22-i586-9.txz: Removed.
kde/kdeartwork-4.14.3-i586-3.txz: Removed.
kde/kdebugsettings-20.08.3-i586-1.txz: Added.
kde/kdeclarative-5.76.0-i586-1.txz: Added.
kde/kdeconnect-kde-20.08.3-i586-1.txz: Upgraded.
kde/kdecoration-5.20.4-i586-1.txz: Added.
kde/kded-5.76.0-i586-1.txz: Added.
kde/kdeedu-data-20.08.3-i586-1.txz: Added.
kde/kdegraphics-mobipocket-20.08.3-i586-1.txz: Upgraded.
kde/kdegraphics-strigi-analyzer-4.14.3-i586-3.txz: Removed.
kde/kdegraphics-thumbnailers-20.08.3-i586-1.txz: Upgraded.
kde/kdelibs-4.14.38-i586-8.txz: Removed.
kde/kdelibs4support-5.76.0-i586-1.txz: Added.
kde/kdenetwork-filesharing-20.08.3-i586-1.txz: Upgraded.
kde/kdenetwork-strigi-analyzers-4.14.3-i586-3.txz: Removed.
kde/kdenlive-20.08.3-i586-1.txz: Added.
kde/kdepim-4.14.10-i586-5.txz: Removed.
kde/kdepim-addons-20.08.3-i586-1.txz: Added.
kde/kdepim-apps-libs-20.08.3-i586-1.txz: Added.
kde/kdepim-runtime-20.08.3-i586-1.txz: Upgraded.
kde/kdepimlibs-4.14.10-i586-9.txz: Removed.
kde/kdeplasma-addons-5.20.4-i586-1.txz: Upgraded.
kde/kdesdk-kioslaves-20.08.3-i586-1.txz: Upgraded.
kde/kdesdk-strigi-analyzers-4.14.3-i586-3.txz: Removed.
kde/kdesdk-thumbnailers-20.08.3-i586-1.txz: Upgraded.
kde/kdesignerplugin-5.76.0-i586-1.txz: Added.
kde/kdesu-5.76.0-i586-1.txz: Added.
kde/kdev-php-5.6.0-i586-1.txz: Added.
kde/kdev-python-5.6.0-i586-1.txz: Upgraded.
kde/kdevelop-5.6.0-i586-1.txz: Upgraded.
kde/kdevelop-pg-qt-2.2.1-i586-1.txz: Upgraded.
kde/kdevelop-php-1.7.4-i586-2.txz: Removed.
kde/kdevelop-php-docs-1.7.4-i586-2.txz: Removed.
kde/kdevplatform-1.7.4-i586-2.txz: Removed.
kde/kdewebdev-4.14.3-i586-3.txz: Removed.
kde/kdewebkit-5.76.0-i586-1.txz: Added.
kde/kdf-20.08.3-i586-1.txz: Upgraded.
kde/kdiagram-2.7.0-i586-1.txz: Added.
kde/kdialog-20.08.3-i586-1.txz: Added.
kde/kdiamond-20.08.3-i586-1.txz: Upgraded.
kde/kdnssd-5.76.0-i586-1.txz: Added.
kde/kdoctools-5.76.0-i586-1.txz: Added.
kde/keditbookmarks-20.08.3-i586-1.txz: Added.
kde/kemoticons-5.76.0-i586-1.txz: Added.
kde/kfilemetadata-5.76.0-i586-1.txz: Upgraded.
kde/kfind-20.08.3-i586-1.txz: Added.
kde/kfloppy-20.08.3-i586-1.txz: Upgraded.
kde/kfourinline-20.08.3-i586-1.txz: Upgraded.
kde/kgamma-4.14.3-i586-3.txz: Removed.
kde/kgamma5-5.20.4-i586-1.txz: Added.
kde/kgeography-20.08.3-i586-1.txz: Upgraded.
kde/kget-20.08.3-i586-1.txz: Upgraded.
kde/kglobalaccel-5.76.0-i586-1.txz: Added.
kde/kgoldrunner-20.08.3-i586-1.txz: Upgraded.
kde/kgpg-20.08.3-i586-1.txz: Upgraded.
kde/kguiaddons-5.76.0-i586-1.txz: Added.
kde/khangman-20.08.3-i586-1.txz: Upgraded.
kde/khelpcenter-20.08.3-i586-1.txz: Added.
kde/kholidays-5.76.0-i586-1.txz: Added.
kde/khotkeys-5.20.4-i586-1.txz: Added.
kde/khtml-5.76.0-i586-1.txz: Added.
kde/ki18n-5.76.0-i586-1.txz: Added.
kde/kiconthemes-5.76.0-i586-1.txz: Added.
kde/kid3-3.8.4-i586-1.txz: Added.
kde/kidentitymanagement-20.08.3-i586-1.txz: Added.
kde/kidletime-5.76.0-i586-1.txz: Added.
kde/kig-20.08.3-i586-1.txz: Upgraded.
kde/kigo-20.08.3-i586-1.txz: Upgraded.
kde/kile-2.9.93-i586-1.txz: Added.
kde/killbots-20.08.3-i586-1.txz: Upgraded.
kde/kimageformats-5.76.0-i586-1.txz: Added.
kde/kimagemapeditor-20.08.3-i586-1.txz: Added.
kde/kimap-20.08.3-i586-1.txz: Added.
kde/kinfocenter-5.20.4-i586-1.txz: Added.
kde/kinit-5.76.0-i586-1.txz: Added.
kde/kio-5.76.0-i586-1.txz: Added.
kde/kio-extras-20.08.3-i586-1.txz: Added.
kde/kio-gdrive-20.08.3-i586-1.txz: Added.
kde/kio-mtp-2063e75_20131020git-i586-4.txz: Removed.
kde/kipi-plugins-20.08.3-i586-1.txz: Added.
kde/kirigami-gallery-20.08.3-i586-1.txz: Added.
kde/kirigami2-5.76.0-i586-1.txz: Added.
kde/kiriki-20.08.3-i586-1.txz: Upgraded.
kde/kitemmodels-5.76.0-i586-1.txz: Added.
kde/kitemviews-5.76.0-i586-1.txz: Added.
kde/kiten-20.08.3-i586-1.txz: Upgraded.
kde/kitinerary-20.08.3-i586-1.txz: Added.
kde/kjobwidgets-5.76.0-i586-1.txz: Added.
kde/kjots-20200924_355b642-i586-1.txz: Added.
kde/kjs-5.76.0-i586-1.txz: Added.
kde/kjsembed-5.76.0-i586-1.txz: Added.
kde/kjumpingcube-20.08.3-i586-1.txz: Upgraded.
kde/kldap-20.08.3-i586-1.txz: Added.
kde/kleopatra-20.08.3-i586-1.txz: Added.
kde/klettres-4.14.3-i586-3.txz: Removed.
kde/klickety-20.08.3-i586-1.txz: Upgraded.
kde/klines-20.08.3-i586-1.txz: Upgraded.
kde/kmag-20.08.3-i586-1.txz: Upgraded.
kde/kmahjongg-20.08.3-i586-1.txz: Upgraded.
kde/kmail-20.08.3-i586-1.txz: Added.
kde/kmail-account-wizard-20.08.3-i586-1.txz: Added.
kde/kmailtransport-20.08.3-i586-1.txz: Added.
kde/kmbox-20.08.3-i586-1.txz: Added.
kde/kmediaplayer-5.76.0-i586-1.txz: Added.
kde/kmenuedit-5.20.4-i586-1.txz: Added.
kde/kmime-20.08.3-i586-1.txz: Added.
kde/kmines-20.08.3-i586-1.txz: Upgraded.
kde/kmix-20.08.3-i586-1.txz: Upgraded.
kde/kmousetool-20.08.3-i586-1.txz: Upgraded.
kde/kmouth-20.08.3-i586-1.txz: Upgraded.
kde/kmplot-20.08.3-i586-1.txz: Upgraded.
kde/kmymoney-5.1.0-i586-1.txz: Added.
kde/knavalbattle-20.08.3-i586-1.txz: Upgraded.
kde/knetwalk-20.08.3-i586-1.txz: Upgraded.
kde/knewstuff-5.76.0-i586-1.txz: Added.
kde/knights-20.08.3-i586-1.txz: Added.
kde/knotes-20.08.3-i586-1.txz: Added.
kde/knotifications-5.76.0-i586-1.txz: Added.
kde/knotifyconfig-5.76.0-i586-1.txz: Added.
kde/kolf-20.08.3-i586-1.txz: Upgraded.
kde/kollision-20.08.3-i586-1.txz: Upgraded.
kde/kolourpaint-20.08.3-i586-1.txz: Upgraded.
kde/kompare-20.08.3-i586-1.txz: Upgraded.
kde/konqueror-20.08.3-i586-1.txz: Added.
kde/konquest-20.08.3-i586-1.txz: Upgraded.
kde/konsole-20.08.3-i586-1.txz: Upgraded.
kde/kontact-20.08.3-i586-1.txz: Added.
kde/kontactinterface-20.08.3-i586-1.txz: Added.
kde/kopete-20.08.3-i586-1.txz: Upgraded.
kde/korganizer-20.08.3-i586-1.txz: Added.
kde/korundum-4.14.3-i586-8.txz: Removed.
kde/kpackage-5.76.0-i586-1.txz: Added.
kde/kparts-5.76.0-i586-1.txz: Added.
kde/kpat-20.08.3-i586-1.txz: Upgraded.
kde/kpeople-5.76.0-i586-1.txz: Added.
kde/kpeoplevcard-0.1-i586-1.txz: Added.
kde/kpimtextedit-20.08.3-i586-1.txz: Added.
kde/kpkpass-20.08.3-i586-1.txz: Added.
kde/kplayer-0.7.2-i586-3.txz: Removed.
kde/kplotting-5.76.0-i586-1.txz: Added.
kde/kpmcore-4.2.0-i586-1.txz: Added.
kde/kppp-4.14.3-i586-3.txz: Removed.
kde/kpty-5.76.0-i586-1.txz: Added.
kde/kqtquickcharts-20.08.3-i586-1.txz: Upgraded.
kde/kquickcharts-5.76.0-i586-1.txz: Added.
kde/krdc-20.08.3-i586-1.txz: Upgraded.
kde/kremotecontrol-4.14.3-i586-3.txz: Removed.
kde/krename-5.0.1-i586-1.txz: Added.
kde/kreversi-20.08.3-i586-1.txz: Upgraded.
kde/krfb-20.08.3-i586-1.txz: Upgraded.
kde/krita-4.4.1-i586-1.txz: Added.
kde/kross-5.76.0-i586-1.txz: Added.
kde/kross-interpreters-20.08.3-i586-1.txz: Upgraded.
kde/kruler-20.08.3-i586-1.txz: Upgraded.
kde/krunner-5.76.0-i586-1.txz: Added.
kde/krusader-2.7.2-i586-1.txz: Added.
kde/ksaneplugin-4.14.3-i586-3.txz: Removed.
kde/kscreen-5.20.4-i586-1.txz: Upgraded.
kde/kscreenlocker-5.20.4-i586-1.txz: Added.
kde/kservice-5.76.0-i586-1.txz: Added.
kde/kshisen-20.08.3-i586-1.txz: Upgraded.
kde/ksirk-20.08.3-i586-1.txz: Upgraded.
kde/ksmtp-20.08.3-i586-1.txz: Added.
kde/ksnakeduel-20.08.3-i586-1.txz: Upgraded.
kde/ksnapshot-4.14.3-i586-3.txz: Removed.
kde/kspaceduel-20.08.3-i586-1.txz: Upgraded.
kde/ksquares-20.08.3-i586-1.txz: Upgraded.
kde/ksshaskpass-5.20.4-i586-1.txz: Added.
kde/kstars-3.5.0-i586-1.txz: Upgraded.
kde/ksudoku-20.08.3-i586-1.txz: Upgraded.
kde/ksysguard-5.20.4-i586-1.txz: Added.
kde/ksystemlog-20.08.3-i586-1.txz: Upgraded.
kde/kteatime-20.08.3-i586-1.txz: Upgraded.
kde/ktexteditor-5.76.0-i586-1.txz: Added.
kde/ktextwidgets-5.76.0-i586-1.txz: Added.
kde/ktimer-20.08.3-i586-1.txz: Upgraded.
kde/ktimetracker-5.0.1-i586-1.txz: Added.
kde/ktnef-20.08.3-i586-1.txz: Added.
kde/ktorrent-5.2.0-i586-1.txz: Upgraded.
kde/ktouch-20.08.3-i586-1.txz: Upgraded.
kde/ktuberling-4.14.3-i586-3.txz: Removed.
kde/kturtle-20.08.3-i586-1.txz: Upgraded.
kde/ktux-4.14.3-i586-3.txz: Removed.
kde/kubrick-20.08.3-i586-1.txz: Upgraded.
kde/kunitconversion-5.76.0-i586-1.txz: Added.
kde/kuser-4.14.3-i586-3.txz: Removed.
kde/kwallet-5.76.0-i586-1.txz: Added.
kde/kwallet-pam-5.20.4-i586-1.txz: Added.
kde/kwalletmanager-20.08.3-i586-1.txz: Upgraded.
kde/kwave-20.08.3-i586-1.txz: Added.
kde/kwayland-5.76.0-i586-1.txz: Added.
kde/kwayland-integration-5.20.4-i586-1.txz: Added.
kde/kwayland-server-5.20.4-i586-1.txz: Added.
kde/kwebkitpart-1.3.4-i586-3.txz: Removed.
kde/kwidgetsaddons-5.76.0-i586-1.txz: Added.
kde/kwin-5.20.4-i586-1.txz: Added.
kde/kwindowsystem-5.76.0-i586-1.txz: Added.
kde/kwordquiz-20.08.3-i586-1.txz: Upgraded.
kde/kwrited-5.20.4-i586-1.txz: Added.
kde/kxmlgui-5.76.0-i586-1.txz: Added.
kde/kxmlrpcclient-5.76.0-i586-1.txz: Added.
kde/latte-dock-0.9.11-i586-1.txz: Added.
kde/libgravatar-20.08.3-i586-1.txz: Added.
kde/libkcddb-20.08.3-i586-1.txz: Upgraded.
kde/libkcompactdisc-20.08.3-i586-1.txz: Upgraded.
kde/libkdcraw-20.08.3-i586-1.txz: Upgraded.
kde/libkdeedu-4.14.3-i586-3.txz: Removed.
kde/libkdegames-20.08.3-i586-1.txz: Upgraded.
kde/libkdepim-20.08.3-i586-1.txz: Added.
kde/libkeduvocdocument-20.08.3-i586-1.txz: Added.
kde/libkexiv2-20.08.3-i586-1.txz: Upgraded.
kde/libkgapi-20.08.3-i586-1.txz: Added.
kde/libkgeomap-20.08.3-i586-1.txz: Added.
kde/libkipi-20.08.3-i586-1.txz: Upgraded.
kde/libkleo-20.08.3-i586-1.txz: Added.
kde/libkmahjongg-20.08.3-i586-1.txz: Upgraded.
kde/libkomparediff2-20.08.3-i586-1.txz: Upgraded.
kde/libksane-20.08.3-i586-1.txz: Upgraded.
kde/libkscreen-5.20.4-i586-1.txz: Upgraded.
kde/libksieve-20.08.3-i586-1.txz: Added.
kde/libksysguard-5.20.4-i586-1.txz: Added.
kde/libktorrent-2.2.0-i586-1.txz: Upgraded.
kde/libmm-qt-1.0.1-i586-3.txz: Removed.
kde/libnm-qt-0.9.8.4-i586-1.txz: Removed.
kde/lokalize-20.08.3-i586-1.txz: Upgraded.
kde/lskat-20.08.3-i586-1.txz: Upgraded.
kde/mailcommon-20.08.3-i586-1.txz: Added.
kde/mailimporter-20.08.3-i586-1.txz: Added.
kde/marble-20.08.3-i586-1.txz: Upgraded.
kde/mbox-importer-20.08.3-i586-1.txz: Added.
kde/messagelib-20.08.3-i586-1.txz: Added.
kde/milou-5.20.4-i586-1.txz: Added.
kde/minuet-20.08.3-i586-1.txz: Added.
kde/modemmanager-qt-5.76.0-i586-1.txz: Added.
kde/mplayerthumbs-4.14.3-i586-3.txz: Removed.
kde/nepomuk-core-4.14.3-i586-5.txz: Removed.
kde/nepomuk-widgets-4.14.3-i586-3.txz: Removed.
kde/networkmanager-qt-5.76.0-i586-1.txz: Added.
kde/okteta-0.26.4-i586-1.txz: Upgraded.
kde/okular-20.08.3-i586-1.txz: Upgraded.
kde/oxygen-5.20.4-i586-1.txz: Added.
kde/oxygen-gtk2-1.4.6-i586-1.txz: Upgraded.
kde/oxygen-icons-4.14.3-i586-3.txz: Removed.
kde/pairs-4.14.3-i586-3.txz: Removed.
kde/palapeli-20.08.3-i586-1.txz: Upgraded.
kde/parley-20.08.3-i586-1.txz: Upgraded.
kde/partitionmanager-4.2.0-i586-1.txz: Upgraded.
kde/perlkde-4.14.3-i586-10.txz: Removed.
kde/perlqt-4.14.3-i586-11.txz: Removed.
kde/picmi-20.08.3-i586-1.txz: Upgraded.
kde/pim-data-exporter-20.08.3-i586-1.txz: Added.
kde/pim-sieve-editor-20.08.3-i586-1.txz: Added.
kde/pimcommon-20.08.3-i586-1.txz: Added.
kde/plasma-browser-integration-5.20.4-i586-1.txz: Added.
kde/plasma-desktop-5.20.4-i586-1.txz: Added.
kde/plasma-disks-5.20.4-i586-1.txz: Added.
kde/plasma-framework-5.76.0-i586-1.txz: Added.
kde/plasma-integration-5.20.4-i586-1.txz: Added.
kde/plasma-nm-5.20.4-i586-1.txz: Upgraded.
kde/plasma-pa-5.20.4-i586-1.txz: Added.
kde/plasma-sdk-5.20.4-i586-1.txz: Added.
kde/plasma-vault-5.20.4-i586-1.txz: Added.
kde/plasma-wayland-protocols-1.1.1-i586-1.txz: Added.
kde/plasma-workspace-5.20.4-i586-1.txz: Added.
kde/plasma-workspace-wallpapers-5.20.4-i586-1.txz: Added.
kde/polkit-kde-agent-1-5.20.4-i586-1.txz: Upgraded.
kde/polkit-kde-kcmodules-1-001bdf7_20120111git-i586-3.txz: Removed.
kde/powerdevil-5.20.4-i586-1.txz: Added.
kde/poxml-20.08.3-i586-1.txz: Upgraded.
kde/print-manager-20.08.3-i586-1.txz: Upgraded.
kde/prison-5.76.0-i586-1.txz: Added.
kde/pulseaudio-qt-1.2-i586-1.txz: Added.
kde/purpose-5.76.0-i586-1.txz: Added.
kde/pykde4-4.14.3-i586-11.txz: Removed.
kde/qqc2-desktop-style-5.76.0-i586-1.txz: Added.
kde/qtruby-4.14.3-i586-11.txz: Removed.
kde/rocs-20.08.3-i586-1.txz: Upgraded.
kde/sddm-0.19.0-i586-1.txz: Added.
kde/sddm-kcm-5.20.4-i586-1.txz: Added.
kde/skanlite-2.2.0-i586-1.txz: Upgraded.
kde/smokegen-4.14.3-i586-3.txz: Removed.
kde/smokekde-4.14.3-i586-3.txz: Removed.
kde/smokeqt-4.14.3-i586-6.txz: Removed.
kde/solid-5.76.0-i586-1.txz: Added.
kde/sonnet-5.76.0-i586-1.txz: Added.
kde/spectacle-20.08.3-i586-1.txz: Added.
kde/step-20.08.3-i586-1.txz: Upgraded.
kde/superkaramba-4.14.3-i586-4.txz: Removed.
kde/svgpart-20.08.3-i586-1.txz: Upgraded.
kde/sweeper-20.08.3-i586-1.txz: Upgraded.
kde/syndication-5.76.0-i586-1.txz: Added.
kde/syntax-highlighting-5.76.0-i586-1.txz: Added.
kde/systemsettings-5.20.4-i586-1.txz: Added.
kde/threadweaver-5.76.0-i586-1.txz: Added.
kde/umbrello-20.08.3-i586-1.txz: Upgraded.
kde/wacomtablet-20201030_417d9d9-i586-1.txz: Added.
kde/wicd-kde-0.3.0_bcf27d8-i586-3.txz: Removed.
kde/xdg-desktop-portal-kde-5.20.4-i586-1.txz: Added.
kde/yakuake-20.08.3-i586-1.txz: Added.
kde/zeroconf-ioslave-20.08.3-i586-1.txz: Upgraded.
l/ConsoleKit2-1.2.1-i586-4.txz: Removed.
l/PyQt-4.12.3-i586-3.txz: Removed.
l/QScintilla-2.11.6-i586-1.txz: Upgraded.
       Drop Qt4 support.
l/QtAV-20200910_2a470d2a-i586-1.txz: Added.
l/SDL2-2.0.12-i586-2.txz: Rebuilt.
l/accountsservice-0.6.55-i586-1.txz: Added.
l/automoc4-0.9.88-i586-2.txz: Removed.
l/cfitsio-3.49-i586-1.txz: Added.
l/cryfs-0.10.2-i586-1.txz: Added.
l/cryptopp-8.2.0-i586-1.txz: Added.
l/dotconf-1.3-i586-1.txz: Added.
l/dvdauthor-0.7.2-i586-1.txz: Added.
l/eigen3-3.3.9-i586-1.txz: Upgraded.
l/frei0r-plugins-1.7.0-i586-1.txz: Added.
l/fuse3-3.10.1-i586-1.txz: Upgraded.
l/grantlee-5.2.0-i586-1.txz: Upgraded.
l/gst-plugins-base-1.18.2-i586-1.txz: Upgraded.
l/gst-plugins-good-1.18.2-i586-1.txz: Upgraded.
l/gst-plugins-libav-1.18.2-i586-1.txz: Upgraded.
l/gstreamer-1.18.2-i586-1.txz: Upgraded.
l/gtk+3-3.24.24-i586-1.txz: Upgraded.
l/gvfs-1.46.1-i586-2.txz: Rebuilt.
l/kdsoap-1.9.1-i586-1.txz: Added.
l/lensfun-0.3.95-i586-1.txz: Added.
l/libappindicator-12.10.0-i586-1.txz: Added.
l/libbluedevil-2.1-i586-2.txz: Removed.
l/libburn-1.5.2.pl01-i586-1.txz: Added.
l/libdbusmenu-16.04.0-i586-1.txz: Added.
l/libdbusmenu-qt-0.9.3+16.04.20160218-i586-1.txz: Upgraded.
l/libdmtx-0.7.5-i586-1.txz: Added.
l/libindicator-12.10.1-i586-1.txz: Added.
l/liblastfm-1.1.0-i586-1.txz: Removed.
l/libqalculate-3.14.0-i586-1.txz: Added.
l/mlt-6.22.1-i586-1.txz: Added.
l/opencv-4.5.0-i586-1.txz: Added.
l/phonon-4.11.1-i586-1.txz: Upgraded.
l/phonon-backend-gstreamer-4.10.0-i586-1.txz: Added.
l/phonon-gstreamer-4.8.2-i586-2.txz: Removed.
l/pipewire-0.3.13-i586-1.txz: Added.
l/polkit-0.118-i586-2.txz: Rebuilt.
l/polkit-qt-1-0.113.0-i586-1.txz: Upgraded.
l/poppler-20.12.1-i586-1.txz: Upgraded.
l/python-certifi-2020.12.5-i586-1.txz: Upgraded.
l/python-pygments-2.7.3-i586-1.txz: Upgraded.
l/qca-2.3.1-i586-1.txz: Upgraded.
l/qca-qt5-2.3.1-i586-1.txz: Removed.
l/qimageblitz-0.0.6-i586-2.txz: Removed.
l/qjson-0.9.0-i586-1.txz: Removed.
l/qrencode-4.1.1-i586-1.txz: Added.
l/qt-4.8.7-i586-17.txz: Removed.
l/qt-gstreamer-1.2.0-i586-2.txz: Removed.
l/qt5-5.15.2-i586-2.txz: Rebuilt.
l/qtkeychain-0.11.1-i586-1.txz: Added.
l/qtscriptgenerator-0.2.0-i586-3.txz: Removed.
l/quazip-1.1-i586-1.txz: Added.
l/raptor2-2.0.15-i586-10.txz: Removed.
l/rasqal-0.9.33-i586-3.txz: Removed.
l/readline-8.1.000-i586-1.txz: Upgraded.
l/redland-1.0.17-i586-6.txz: Removed.
l/rttr-0.9.6-i586-1.txz: Added.
l/soprano-2.9.4-i586-3.txz: Removed.
l/speech-dispatcher-0.10.2-i586-1.txz: Added.
l/strigi-0.7.8-i586-4.txz: Removed.
l/vid.stab-20200916_e851e7b-i586-1.txz: Added.
l/xapian-core-1.4.17-i586-2.txz: Rebuilt.
n/NetworkManager-1.28.0-i586-1.txz: Upgraded.
x/OpenCC-1.1.1-i586-1.txz: Added.
x/fcitx-4.2.9.8-i586-1.txz: Added.
x/fcitx-anthy-0.2.3-i586-1.txz: Added.
x/fcitx-configtool-0.4.9-i586-1.txz: Added.
x/fcitx-hangul-0.3.1-i586-1.txz: Added.
x/fcitx-kkc-0.1.4-i586-1.txz: Added.
x/fcitx-libpinyin-0.5.3-i586-1.txz: Added.
x/fcitx-m17n-0.2.4-i586-1.txz: Added.
x/fcitx-qt5-1.2.5-i586-1.txz: Added.
x/fcitx-sayura-0.1.2-i586-1.txz: Added.
x/fcitx-table-extra-0.3.8-i586-1.txz: Added.
x/fcitx-table-other-0.2.4-i586-1.txz: Added.
x/fcitx-unikey-0.2.7-i586-1.txz: Added.
x/ibus-1.5.23-i586-1.txz: Added.
x/ibus-anthy-1.5.11-i586-1.txz: Added.
x/ibus-hangul-1.5.4-i586-1.txz: Added.
x/ibus-kkc-1.5.22-i586-1.txz: Added.
x/ibus-libpinyin-1.11.1-i586-1.txz: Added.
x/ibus-m17n-1.4.3-i586-1.txz: Added.
x/ibus-table-1.12.1-i586-1.txz: Added.
x/ibus-unikey-0.6.1-i586-1.txz: Added.
x/libgee-0.20.1-i586-1.txz: Added.
x/libkkc-0.3.5-i586-1.txz: Added.
x/libkkc-data-0.2.7-i586-1.txz: Added.
x/libpinyin-2.3.0-i586-1.txz: Added.
x/marisa-0.2.4-i586-1.txz: Added.
x/motif-2.3.8-i586-3.txz: Rebuilt.
x/scim-1.4.18-i586-1.txz: Removed.
x/scim-anthy-1.2.7-i586-2.txz: Removed.
x/scim-hangul-0.4.0-i586-2.txz: Removed.
x/scim-input-pad-0.1.3.1-i586-2.txz: Removed.
x/scim-m17n-0.2.3-i586-2.txz: Removed.
x/scim-pinyin-0.5.92-i586-2.txz: Removed.
x/scim-tables-0.5.14.1-i586-2.txz: Removed.
x/xdm-1.1.11-i586-11.txz: Rebuilt.
xap/seamonkey-2.53.5.1-i686-1.txz: Upgraded.
xap/vim-gvim-8.2.2105-i586-1.txz: Upgraded.
xap/xine-lib-1.2.11-i586-1.txz: Upgraded.
xfce/elementary-xfce-0.15.1-i586-1.txz: Added.
xfce/exo-0.12.11-i586-2.txz: Rebuilt.
xfce/garcon-0.6.4-i586-2.txz: Rebuilt.
xfce/gtk-xfce-engine-2.10.1-i586-3.txz: Removed.
xfce/libxfce4ui-4.14.1-i586-1.txz: Upgraded.
xfce/libxfce4util-4.14.0-i586-1.txz: Upgraded.
xfce/mousepad-0.4.2-i586-1.txz: Added.
xfce/orage-4.12.1-i586-5.txz: Removed.
xfce/thunar-1.8.16-i586-2.txz: Rebuilt.
xfce/thunar-volman-0.9.5-i586-2.txz: Rebuilt.
xfce/tumbler-0.2.9-i586-2.txz: Rebuilt.
xfce/xfce4-appfinder-4.14.0-i586-1.txz: Upgraded.
xfce/xfce4-clipman-plugin-1.6.1-i586-1.txz: Upgraded.
xfce/xfce4-dev-tools-4.14.0-i586-1.txz: Upgraded.
xfce/xfce4-notifyd-0.6.2-i586-1.txz: Upgraded.
xfce/xfce4-panel-4.14.4-i586-1.txz: Upgraded.
xfce/xfce4-panel-profiles-1.0.10-i586-1.txz: Added.
xfce/xfce4-power-manager-1.6.6-i586-1.txz: Upgraded.
xfce/xfce4-pulseaudio-plugin-0.4.3-i586-1.txz: Upgraded.
xfce/xfce4-screensaver-0.1.11-i586-1.txz: Added.
xfce/xfce4-screenshooter-1.9.7-i586-1.txz: Upgraded.
xfce/xfce4-session-4.14.2-i586-1.txz: Upgraded.
xfce/xfce4-settings-4.14.3-i586-1.txz: Upgraded.
xfce/xfce4-systemload-plugin-1.2.3-i586-2.txz: Rebuilt.
xfce/xfce4-taskmanager-1.2.3-i586-1.txz: Upgraded.
xfce/xfce4-terminal-0.8.9.2-i586-1.txz: Upgraded.
xfce/xfce4-weather-plugin-0.10.2-i586-1.txz: Upgraded.
xfce/xfce4-whiskermenu-plugin-2.4.6-i586-1.txz: Added.
xfce/xfconf-4.14.4-i586-1.txz: Upgraded.
xfce/xfdesktop-4.14.3-i586-1.txz: Upgraded.
xfce/xfwm4-4.14.6-i586-1.txz: Upgraded.
l/libproxy-0.4.16-i586-1.txz: Upgraded.
n/mutt-2.0.3-i586-1.txz: Upgraded.
Post Napisano: 14 Dec 2020, 23:11
Slackware 64-bit
Sat Dec 12 22:14:17 UTC 2020
a/kernel-generic-5.4.83-x86_64-1.txz: Upgraded.
a/kernel-huge-5.4.83-x86_64-1.txz: Upgraded.
a/kernel-modules-5.4.83-x86_64-1.txz: Upgraded.
d/kernel-headers-5.4.83-x86-1.txz: Upgraded.
k/kernel-source-5.4.83-noarch-1.txz: Upgraded.
kde/akonadi-20.12.0-x86_64-1.txz: Upgraded.
kde/akonadi-calendar-20.12.0-x86_64-1.txz: Upgraded.
kde/akonadi-calendar-tools-20.12.0-x86_64-1.txz: Upgraded.
kde/akonadi-contacts-20.12.0-x86_64-1.txz: Upgraded.
kde/akonadi-import-wizard-20.12.0-x86_64-1.txz: Upgraded.
kde/akonadi-mime-20.12.0-x86_64-1.txz: Upgraded.
kde/akonadi-notes-20.12.0-x86_64-1.txz: Upgraded.
kde/akonadi-search-20.12.0-x86_64-1.txz: Upgraded.
kde/akonadiconsole-20.12.0-x86_64-1.txz: Upgraded.
kde/akregator-20.12.0-x86_64-1.txz: Upgraded.
kde/analitza-20.12.0-x86_64-1.txz: Upgraded.
kde/ark-20.12.0-x86_64-1.txz: Upgraded.
kde/artikulate-20.12.0-x86_64-1.txz: Upgraded.
kde/attica-5.77.0-x86_64-1.txz: Upgraded.
kde/audiocd-kio-20.12.0-x86_64-1.txz: Upgraded.
kde/baloo-5.77.0-x86_64-1.txz: Upgraded.
kde/baloo-widgets-20.12.0-x86_64-1.txz: Upgraded.
kde/blinken-20.12.0-x86_64-1.txz: Upgraded.
kde/bluez-qt-5.77.0-x86_64-1.txz: Upgraded.
kde/bomber-20.12.0-x86_64-1.txz: Upgraded.
kde/bovo-20.12.0-x86_64-1.txz: Upgraded.
kde/breeze-icons-5.77.0-noarch-1.txz: Upgraded.
kde/calendarsupport-20.12.0-x86_64-1.txz: Upgraded.
kde/cantor-20.12.0-x86_64-1.txz: Upgraded.
kde/cervisia-20.12.0-x86_64-1.txz: Upgraded.
kde/dolphin-20.12.0-x86_64-1.txz: Upgraded.
kde/dolphin-plugins-20.12.0-x86_64-1.txz: Upgraded.
kde/dragon-20.12.0-x86_64-1.txz: Upgraded.
kde/elisa-20.12.0-x86_64-1.txz: Upgraded.
kde/eventviews-20.12.0-x86_64-1.txz: Upgraded.
kde/extra-cmake-modules-5.77.0-x86_64-1.txz: Upgraded.
kde/ffmpegthumbs-20.12.0-x86_64-1.txz: Upgraded.
kde/filelight-20.12.0-x86_64-1.txz: Upgraded.
kde/frameworkintegration-5.77.0-x86_64-1.txz: Upgraded.
kde/granatier-20.12.0-x86_64-1.txz: Upgraded.
kde/grantlee-editor-20.12.0-x86_64-1.txz: Upgraded.
kde/grantleetheme-20.12.0-x86_64-1.txz: Upgraded.
kde/gwenview-20.12.0-x86_64-1.txz: Upgraded.
kde/incidenceeditor-20.12.0-x86_64-1.txz: Upgraded.
kde/itinerary-20.12.0-x86_64-1.txz: Added.
kde/juk-20.12.0-x86_64-1.txz: Upgraded.
kde/k3b-20.12.0-x86_64-1.txz: Upgraded.
kde/kactivities-5.77.0-x86_64-1.txz: Upgraded.
kde/kactivities-stats-5.77.0-x86_64-1.txz: Upgraded.
kde/kaddressbook-20.12.0-x86_64-1.txz: Upgraded.
kde/kalarm-20.12.0-x86_64-1.txz: Upgraded.
kde/kalarmcal-20.12.0-x86_64-1.txz: Upgraded.
kde/kalgebra-20.12.0-x86_64-1.txz: Upgraded.
kde/kalzium-20.12.0-x86_64-1.txz: Upgraded.
kde/kamera-20.12.0-x86_64-1.txz: Upgraded.
kde/kamoso-20.12.0-x86_64-1.txz: Upgraded.
kde/kanagram-20.12.0-x86_64-1.txz: Upgraded.
kde/kapidox-5.77.0-x86_64-1.txz: Upgraded.
kde/kapman-20.12.0-x86_64-1.txz: Upgraded.
kde/kapptemplate-20.12.0-x86_64-1.txz: Upgraded.
kde/karchive-5.77.0-x86_64-1.txz: Upgraded.
kde/kate-20.12.0-x86_64-1.txz: Upgraded.
kde/katomic-20.12.0-x86_64-1.txz: Upgraded.
kde/kauth-5.77.0-x86_64-1.txz: Upgraded.
kde/kbackup-20.12.0-x86_64-1.txz: Upgraded.
kde/kblackbox-20.12.0-x86_64-1.txz: Upgraded.
kde/kblocks-20.12.0-x86_64-1.txz: Upgraded.
kde/kbookmarks-5.77.0-x86_64-1.txz: Upgraded.
kde/kbounce-20.12.0-x86_64-1.txz: Upgraded.
kde/kbreakout-20.12.0-x86_64-1.txz: Upgraded.
kde/kbruch-20.12.0-x86_64-1.txz: Upgraded.
kde/kcachegrind-20.12.0-x86_64-1.txz: Upgraded.
kde/kcalc-20.12.0-x86_64-1.txz: Upgraded.
kde/kcalendarcore-5.77.0-x86_64-1.txz: Upgraded.
kde/kcalutils-20.12.0-x86_64-1.txz: Upgraded.
kde/kcharselect-20.12.0-x86_64-1.txz: Upgraded.
kde/kcm-fcitx-0.5.6-x86_64-2.txz: Rebuilt.
       Applied upstream patch to fix ErrorOverlay panel.
       Thanks to Weng Xuetian and PiterPunk.
kde/kcmutils-5.77.0-x86_64-1.txz: Upgraded.
kde/kcodecs-5.77.0-x86_64-1.txz: Upgraded.
kde/kcolorchooser-20.12.0-x86_64-1.txz: Upgraded.
kde/kcompletion-5.77.0-x86_64-1.txz: Upgraded.
kde/kconfig-5.77.0-x86_64-1.txz: Upgraded.
kde/kconfigwidgets-5.77.0-x86_64-1.txz: Upgraded.
kde/kcontacts-5.77.0-x86_64-1.txz: Upgraded.
kde/kcoreaddons-5.77.0-x86_64-1.txz: Upgraded.
kde/kcrash-5.77.0-x86_64-1.txz: Upgraded.
kde/kcron-20.12.0-x86_64-1.txz: Upgraded.
kde/kdav-5.77.0-x86_64-1.txz: Upgraded.
kde/kdbusaddons-5.77.0-x86_64-1.txz: Upgraded.
kde/kde-dev-scripts-20.12.0-x86_64-1.txz: Upgraded.
kde/kde-dev-utils-20.12.0-x86_64-1.txz: Upgraded.
kde/kdebugsettings-20.12.0-x86_64-1.txz: Upgraded.
kde/kdeclarative-5.77.0-x86_64-1.txz: Upgraded.
kde/kdeconnect-kde-20.12.0-x86_64-1.txz: Upgraded.
kde/kded-5.77.0-x86_64-1.txz: Upgraded.
kde/kdeedu-data-20.12.0-x86_64-1.txz: Upgraded.
kde/kdegraphics-mobipocket-20.12.0-x86_64-1.txz: Upgraded.
kde/kdegraphics-thumbnailers-20.12.0-x86_64-1.txz: Upgraded.
kde/kdelibs4support-5.77.0-x86_64-1.txz: Upgraded.
kde/kdenetwork-filesharing-20.12.0-x86_64-1.txz: Upgraded.
kde/kdenlive-20.12.0-x86_64-1.txz: Upgraded.
kde/kdepim-addons-20.12.0-x86_64-1.txz: Upgraded.
kde/kdepim-apps-libs-20.08.3-x86_64-1.txz: Removed.
kde/kdepim-runtime-20.12.0-x86_64-1.txz: Upgraded.
kde/kdesdk-kioslaves-20.12.0-x86_64-1.txz: Upgraded.
kde/kdesdk-thumbnailers-20.12.0-x86_64-1.txz: Upgraded.
kde/kdesignerplugin-5.77.0-x86_64-1.txz: Upgraded.
kde/kdesu-5.77.0-x86_64-1.txz: Upgraded.
kde/kdev-php-5.6.1-x86_64-1.txz: Upgraded.
kde/kdev-python-5.6.1-x86_64-1.txz: Upgraded.
kde/kdevelop-5.6.1-x86_64-1.txz: Upgraded.
kde/kdewebkit-5.77.0-x86_64-1.txz: Upgraded.
kde/kdf-20.12.0-x86_64-1.txz: Upgraded.
kde/kdialog-20.12.0-x86_64-1.txz: Upgraded.
kde/kdiamond-20.12.0-x86_64-1.txz: Upgraded.
kde/kdnssd-5.77.0-x86_64-1.txz: Upgraded.
kde/kdoctools-5.77.0-x86_64-1.txz: Upgraded.
kde/keditbookmarks-20.12.0-x86_64-1.txz: Upgraded.
kde/kemoticons-5.77.0-x86_64-1.txz: Upgraded.
kde/kfilemetadata-5.77.0-x86_64-1.txz: Upgraded.
kde/kfind-20.12.0-x86_64-1.txz: Upgraded.
kde/kfloppy-20.12.0-x86_64-1.txz: Upgraded.
kde/kfourinline-20.12.0-x86_64-1.txz: Upgraded.
kde/kgeography-20.12.0-x86_64-1.txz: Upgraded.
kde/kget-20.12.0-x86_64-1.txz: Upgraded.
kde/kglobalaccel-5.77.0-x86_64-1.txz: Upgraded.
kde/kgoldrunner-20.12.0-x86_64-1.txz: Upgraded.
kde/kgpg-20.12.0-x86_64-1.txz: Upgraded.
kde/kguiaddons-5.77.0-x86_64-1.txz: Upgraded.
kde/khangman-20.12.0-x86_64-1.txz: Upgraded.
kde/khelpcenter-20.12.0-x86_64-1.txz: Upgraded.
kde/kholidays-5.77.0-x86_64-1.txz: Upgraded.
kde/khtml-5.77.0-x86_64-1.txz: Upgraded.
kde/ki18n-5.77.0-x86_64-1.txz: Upgraded.
kde/kiconthemes-5.77.0-x86_64-1.txz: Upgraded.
kde/kidentitymanagement-20.12.0-x86_64-1.txz: Upgraded.
kde/kidletime-5.77.0-x86_64-1.txz: Upgraded.
kde/kig-20.12.0-x86_64-1.txz: Upgraded.
kde/kigo-20.12.0-x86_64-1.txz: Upgraded.
kde/killbots-20.12.0-x86_64-1.txz: Upgraded.
kde/kimageformats-5.77.0-x86_64-1.txz: Upgraded.
kde/kimagemapeditor-20.12.0-x86_64-1.txz: Upgraded.
kde/kimap-20.12.0-x86_64-1.txz: Upgraded.
kde/kinit-5.77.0-x86_64-1.txz: Upgraded.
kde/kio-5.77.0-x86_64-1.txz: Upgraded.
kde/kio-extras-20.12.0-x86_64-1.txz: Upgraded.
kde/kio-gdrive-20.12.0-x86_64-1.txz: Upgraded.
kde/kipi-plugins-20.12.0-x86_64-1.txz: Upgraded.
kde/kirigami-gallery-20.12.0-x86_64-1.txz: Upgraded.
kde/kirigami2-5.77.0-x86_64-1.txz: Upgraded.
kde/kiriki-20.12.0-x86_64-1.txz: Upgraded.
kde/kitemmodels-5.77.0-x86_64-1.txz: Upgraded.
kde/kitemviews-5.77.0-x86_64-1.txz: Upgraded.
kde/kiten-20.12.0-x86_64-1.txz: Upgraded.
kde/kitinerary-20.12.0-x86_64-1.txz: Upgraded.
kde/kjobwidgets-5.77.0-x86_64-1.txz: Upgraded.
kde/kjots-20201206_f7d555c-x86_64-1.txz: Upgraded.
kde/kjs-5.77.0-x86_64-1.txz: Upgraded.
kde/kjsembed-5.77.0-x86_64-1.txz: Upgraded.
kde/kjumpingcube-20.12.0-x86_64-1.txz: Upgraded.
kde/kldap-20.12.0-x86_64-1.txz: Upgraded.
kde/kleopatra-20.12.0-x86_64-1.txz: Upgraded.
kde/klickety-20.12.0-x86_64-1.txz: Upgraded.
kde/klines-20.12.0-x86_64-1.txz: Upgraded.
kde/kmag-20.12.0-x86_64-1.txz: Upgraded.
kde/kmahjongg-20.12.0-x86_64-1.txz: Upgraded.
kde/kmail-20.12.0-x86_64-1.txz: Upgraded.
kde/kmail-account-wizard-20.12.0-x86_64-1.txz: Upgraded.
kde/kmailtransport-20.12.0-x86_64-1.txz: Upgraded.
kde/kmbox-20.12.0-x86_64-1.txz: Upgraded.
kde/kmediaplayer-5.77.0-x86_64-1.txz: Upgraded.
kde/kmime-20.12.0-x86_64-1.txz: Upgraded.
kde/kmines-20.12.0-x86_64-1.txz: Upgraded.
kde/kmix-20.12.0-x86_64-1.txz: Upgraded.
kde/kmousetool-20.12.0-x86_64-1.txz: Upgraded.
kde/kmouth-20.12.0-x86_64-1.txz: Upgraded.
kde/kmplot-20.12.0-x86_64-1.txz: Upgraded.
kde/knavalbattle-20.12.0-x86_64-1.txz: Upgraded.
kde/knetwalk-20.12.0-x86_64-1.txz: Upgraded.
kde/knewstuff-5.77.0-x86_64-1.txz: Upgraded.
kde/knights-20.12.0-x86_64-1.txz: Upgraded.
kde/knotes-20.12.0-x86_64-1.txz: Upgraded.
kde/knotifications-5.77.0-x86_64-1.txz: Upgraded.
kde/knotifyconfig-5.77.0-x86_64-1.txz: Upgraded.
kde/kolf-20.12.0-x86_64-1.txz: Upgraded.
kde/kollision-20.12.0-x86_64-1.txz: Upgraded.
kde/kolourpaint-20.12.0-x86_64-1.txz: Upgraded.
kde/kompare-20.12.0-x86_64-1.txz: Upgraded.
kde/konqueror-20.12.0-x86_64-1.txz: Upgraded.
kde/konquest-20.12.0-x86_64-1.txz: Upgraded.
kde/konsole-20.12.0-x86_64-1.txz: Upgraded.
kde/kontact-20.12.0-x86_64-1.txz: Upgraded.
kde/kontactinterface-20.12.0-x86_64-1.txz: Upgraded.
kde/kontrast-20.12.0-x86_64-1.txz: Added.
kde/konversation-20.12.0-x86_64-1.txz: Added.
kde/kopete-20.12.0-x86_64-1.txz: Upgraded.
kde/korganizer-20.12.0-x86_64-1.txz: Upgraded.
kde/kosmindoormap-20.12.0-x86_64-1.txz: Added.
kde/kpackage-5.77.0-x86_64-1.txz: Upgraded.
kde/kparts-5.77.0-x86_64-1.txz: Upgraded.
kde/kpat-20.12.0-x86_64-1.txz: Upgraded.
kde/kpeople-5.77.0-x86_64-1.txz: Upgraded.
kde/kpimtextedit-20.12.0-x86_64-1.txz: Upgraded.
kde/kpkpass-20.12.0-x86_64-1.txz: Upgraded.
kde/kplotting-5.77.0-x86_64-1.txz: Upgraded.
kde/kpmcore-20.12.0-x86_64-1.txz: Upgraded.
kde/kpty-5.77.0-x86_64-1.txz: Upgraded.
kde/kpublictransport-20.12.0-x86_64-1.txz: Added.
kde/kqtquickcharts-20.12.0-x86_64-1.txz: Upgraded.
kde/kquickcharts-5.77.0-x86_64-1.txz: Upgraded.
kde/krdc-20.12.0-x86_64-1.txz: Upgraded.
kde/kreversi-20.12.0-x86_64-1.txz: Upgraded.
kde/krfb-20.12.0-x86_64-1.txz: Upgraded.
kde/kross-5.77.0-x86_64-1.txz: Upgraded.
kde/kross-interpreters-20.12.0-x86_64-1.txz: Upgraded.
kde/kruler-20.12.0-x86_64-1.txz: Upgraded.
kde/krunner-5.77.0-x86_64-1.txz: Upgraded.
kde/kservice-5.77.0-x86_64-1.txz: Upgraded.
kde/kshisen-20.12.0-x86_64-1.txz: Upgraded.
kde/ksirk-20.12.0-x86_64-1.txz: Upgraded.
kde/ksmtp-20.12.0-x86_64-1.txz: Upgraded.
kde/ksnakeduel-20.12.0-x86_64-1.txz: Upgraded.
kde/kspaceduel-20.12.0-x86_64-1.txz: Upgraded.
kde/ksquares-20.12.0-x86_64-1.txz: Upgraded.
kde/ksudoku-20.12.0-x86_64-1.txz: Upgraded.
kde/ksystemlog-20.12.0-x86_64-1.txz: Upgraded.
kde/kteatime-20.12.0-x86_64-1.txz: Upgraded.
kde/ktexteditor-5.77.0-x86_64-1.txz: Upgraded.
kde/ktextwidgets-5.77.0-x86_64-1.txz: Upgraded.
kde/ktimer-20.12.0-x86_64-1.txz: Upgraded.
kde/ktnef-20.12.0-x86_64-1.txz: Upgraded.
kde/ktorrent-20.12.0-x86_64-1.txz: Upgraded.
kde/ktouch-20.12.0-x86_64-1.txz: Upgraded.
kde/kturtle-20.12.0-x86_64-1.txz: Upgraded.
kde/kubrick-20.12.0-x86_64-1.txz: Upgraded.
kde/kunitconversion-5.77.0-x86_64-1.txz: Upgraded.
kde/kwallet-5.77.0-x86_64-1.txz: Upgraded.
kde/kwalletmanager-20.12.0-x86_64-1.txz: Upgraded.
kde/kwave-20.12.0-x86_64-1.txz: Upgraded.
kde/kwayland-5.77.0-x86_64-1.txz: Upgraded.
kde/kwidgetsaddons-5.77.0-x86_64-1.txz: Upgraded.
kde/kwindowsystem-5.77.0-x86_64-1.txz: Upgraded.
kde/kwordquiz-20.12.0-x86_64-1.txz: Upgraded.
kde/kxmlgui-5.77.0-x86_64-1.txz: Upgraded.
kde/kxmlrpcclient-5.77.0-x86_64-1.txz: Upgraded.
kde/libgravatar-20.12.0-x86_64-1.txz: Upgraded.
kde/libkcddb-20.12.0-x86_64-1.txz: Upgraded.
kde/libkcompactdisc-20.12.0-x86_64-1.txz: Upgraded.
kde/libkdcraw-20.12.0-x86_64-1.txz: Upgraded.
kde/libkdegames-20.12.0-x86_64-1.txz: Upgraded.
kde/libkdepim-20.12.0-x86_64-1.txz: Upgraded.
kde/libkeduvocdocument-20.12.0-x86_64-1.txz: Upgraded.
kde/libkexiv2-20.12.0-x86_64-1.txz: Upgraded.
kde/libkgapi-20.12.0-x86_64-1.txz: Upgraded.
kde/libkgeomap-20.08.3-x86_64-1.txz: Removed.
kde/libkipi-20.12.0-x86_64-1.txz: Upgraded.
kde/libkleo-20.12.0-x86_64-1.txz: Upgraded.
kde/libkmahjongg-20.12.0-x86_64-1.txz: Upgraded.
kde/libkomparediff2-20.12.0-x86_64-1.txz: Upgraded.
kde/libksane-20.12.0-x86_64-1.txz: Upgraded.
kde/libksieve-20.12.0-x86_64-1.txz: Upgraded.
kde/libktorrent-20.12.0-x86_64-1.txz: Upgraded.
kde/lokalize-20.12.0-x86_64-1.txz: Upgraded.
kde/lskat-20.12.0-x86_64-1.txz: Upgraded.
kde/mailcommon-20.12.0-x86_64-1.txz: Upgraded.
kde/mailimporter-20.12.0-x86_64-1.txz: Upgraded.
kde/marble-20.12.0-x86_64-1.txz: Upgraded.
kde/markdownpart-20.12.0-x86_64-1.txz: Added.
kde/mbox-importer-20.12.0-x86_64-1.txz: Upgraded.
kde/messagelib-20.12.0-x86_64-1.txz: Upgraded.
kde/minuet-20.12.0-x86_64-1.txz: Upgraded.
kde/modemmanager-qt-5.77.0-x86_64-1.txz: Upgraded.
kde/networkmanager-qt-5.77.0-x86_64-1.txz: Upgraded.
kde/okular-20.12.0-x86_64-1.txz: Upgraded.
kde/oxygen-icons5-5.77.0-noarch-1.txz: Upgraded.
kde/palapeli-20.12.0-x86_64-1.txz: Upgraded.
kde/parley-20.12.0-x86_64-1.txz: Upgraded.
kde/partitionmanager-20.12.0-x86_64-1.txz: Upgraded.
kde/picmi-20.12.0-x86_64-1.txz: Upgraded.
kde/pim-data-exporter-20.12.0-x86_64-1.txz: Upgraded.
kde/pim-sieve-editor-20.12.0-x86_64-1.txz: Upgraded.
kde/pimcommon-20.12.0-x86_64-1.txz: Upgraded.
kde/plasma-framework-5.77.0-x86_64-1.txz: Upgraded.
kde/powerdevil-5.20.4-x86_64-3.txz: Rebuilt.
       Don't make polkit rules shipped in /usr/share/polkit-1/rules.d/ .new.
       These can be overridden in /etc/polkit-1/rules.d/.
kde/poxml-20.12.0-x86_64-1.txz: Upgraded.
kde/print-manager-20.12.0-x86_64-1.txz: Upgraded.
kde/prison-5.77.0-x86_64-1.txz: Upgraded.
kde/purpose-5.77.0-x86_64-1.txz: Upgraded.
kde/qqc2-desktop-style-5.77.0-x86_64-1.txz: Upgraded.
kde/rocs-20.12.0-x86_64-1.txz: Upgraded.
kde/sddm-0.19.0-x86_64-2.txz: Rebuilt.
       Don't make files under /usr .new. If custom scripts are needed, these may
       be specified in /etc/sddm.conf.
kde/solid-5.77.0-x86_64-1.txz: Upgraded.
kde/sonnet-5.77.0-x86_64-1.txz: Upgraded.
kde/spectacle-20.12.0-x86_64-1.txz: Upgraded.
kde/step-20.12.0-x86_64-1.txz: Upgraded.
kde/svgpart-20.12.0-x86_64-1.txz: Upgraded.
kde/sweeper-20.12.0-x86_64-1.txz: Upgraded.
kde/syndication-5.77.0-x86_64-1.txz: Upgraded.
kde/syntax-highlighting-5.77.0-x86_64-1.txz: Upgraded.
kde/threadweaver-5.77.0-x86_64-1.txz: Upgraded.
kde/umbrello-20.12.0-x86_64-1.txz: Upgraded.
kde/yakuake-20.12.0-x86_64-1.txz: Upgraded.
kde/zeroconf-ioslave-20.12.0-x86_64-1.txz: Upgraded.
l/imagemagick-7.0.10_48-x86_64-1.txz: Upgraded.
l/libcap-ng-0.8.2-x86_64-1.txz: Upgraded.
l/mozilla-nss-3.60-x86_64-1.txz: Upgraded.
n/p11-kit-0.23.22-x86_64-1.txz: Upgraded.
       Fix memory-safety issues that affect the RPC protocol.
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-29361
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-29362
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-29363
isolinux/initrd.img: Rebuilt.
kernels/*: Upgraded.
Slackware 32-bit
a/kernel-generic-5.4.83-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.4.83_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.4.83-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.4.83_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.4.83-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.4.83_smp-i686-1.txz: Upgraded.
d/kernel-headers-5.4.83_smp-x86-1.txz: Upgraded.
k/kernel-source-5.4.83_smp-noarch-1.txz: Upgraded.
kde/akonadi-20.12.0-i586-1.txz: Upgraded.
kde/akonadi-calendar-20.12.0-i586-1.txz: Upgraded.
kde/akonadi-calendar-tools-20.12.0-i586-1.txz: Upgraded.
kde/akonadi-contacts-20.12.0-i586-1.txz: Upgraded.
kde/akonadi-import-wizard-20.12.0-i586-1.txz: Upgraded.
kde/akonadi-mime-20.12.0-i586-1.txz: Upgraded.
kde/akonadi-notes-20.12.0-i586-1.txz: Upgraded.
kde/akonadi-search-20.12.0-i586-1.txz: Upgraded.
kde/akonadiconsole-20.12.0-i586-1.txz: Upgraded.
kde/akregator-20.12.0-i586-1.txz: Upgraded.
kde/analitza-20.12.0-i586-1.txz: Upgraded.
kde/ark-20.12.0-i586-1.txz: Upgraded.
kde/artikulate-20.12.0-i586-1.txz: Upgraded.
kde/attica-5.77.0-i586-1.txz: Upgraded.
kde/audiocd-kio-20.12.0-i586-1.txz: Upgraded.
kde/baloo-5.77.0-i586-1.txz: Upgraded.
kde/baloo-widgets-20.12.0-i586-1.txz: Upgraded.
kde/blinken-20.12.0-i586-1.txz: Upgraded.
kde/bluez-qt-5.77.0-i586-1.txz: Upgraded.
kde/bomber-20.12.0-i586-1.txz: Upgraded.
kde/bovo-20.12.0-i586-1.txz: Upgraded.
kde/calendarsupport-20.12.0-i586-1.txz: Upgraded.
kde/cantor-20.12.0-i586-1.txz: Upgraded.
kde/cervisia-20.12.0-i586-1.txz: Upgraded.
kde/dolphin-20.12.0-i586-1.txz: Upgraded.
kde/dolphin-plugins-20.12.0-i586-1.txz: Upgraded.
kde/dragon-20.12.0-i586-1.txz: Upgraded.
kde/elisa-20.12.0-i586-1.txz: Upgraded.
kde/eventviews-20.12.0-i586-1.txz: Upgraded.
kde/extra-cmake-modules-5.77.0-i586-1.txz: Upgraded.
kde/ffmpegthumbs-20.12.0-i586-1.txz: Upgraded.
kde/filelight-20.12.0-i586-1.txz: Upgraded.
kde/frameworkintegration-5.77.0-i586-1.txz: Upgraded.
kde/granatier-20.12.0-i586-1.txz: Upgraded.
kde/grantlee-editor-20.12.0-i586-1.txz: Upgraded.
kde/grantleetheme-20.12.0-i586-1.txz: Upgraded.
kde/gwenview-20.12.0-i586-1.txz: Upgraded.
kde/incidenceeditor-20.12.0-i586-1.txz: Upgraded.
kde/itinerary-20.12.0-i586-1.txz: Added.
kde/juk-20.12.0-i586-1.txz: Upgraded.
kde/k3b-20.12.0-i586-1.txz: Upgraded.
kde/kactivities-5.77.0-i586-1.txz: Upgraded.
kde/kactivities-stats-5.77.0-i586-1.txz: Upgraded.
kde/kaddressbook-20.12.0-i586-1.txz: Upgraded.
kde/kalarm-20.12.0-i586-1.txz: Upgraded.
kde/kalarmcal-20.12.0-i586-1.txz: Upgraded.
kde/kalgebra-20.12.0-i586-1.txz: Upgraded.
kde/kalzium-20.12.0-i586-1.txz: Upgraded.
kde/kamera-20.12.0-i586-1.txz: Upgraded.
kde/kamoso-20.12.0-i586-1.txz: Upgraded.
kde/kanagram-20.12.0-i586-1.txz: Upgraded.
kde/kapidox-5.77.0-i586-1.txz: Upgraded.
kde/kapman-20.12.0-i586-1.txz: Upgraded.
kde/kapptemplate-20.12.0-i586-1.txz: Upgraded.
kde/karchive-5.77.0-i586-1.txz: Upgraded.
kde/kate-20.12.0-i586-1.txz: Upgraded.
kde/katomic-20.12.0-i586-1.txz: Upgraded.
kde/kauth-5.77.0-i586-1.txz: Upgraded.
kde/kbackup-20.12.0-i586-1.txz: Upgraded.
kde/kblackbox-20.12.0-i586-1.txz: Upgraded.
kde/kblocks-20.12.0-i586-1.txz: Upgraded.
kde/kbookmarks-5.77.0-i586-1.txz: Upgraded.
kde/kbounce-20.12.0-i586-1.txz: Upgraded.
kde/kbreakout-20.12.0-i586-1.txz: Upgraded.
kde/kbruch-20.12.0-i586-1.txz: Upgraded.
kde/kcachegrind-20.12.0-i586-1.txz: Upgraded.
kde/kcalc-20.12.0-i586-1.txz: Upgraded.
kde/kcalendarcore-5.77.0-i586-1.txz: Upgraded.
kde/kcalutils-20.12.0-i586-1.txz: Upgraded.
kde/kcharselect-20.12.0-i586-1.txz: Upgraded.
kde/kcm-fcitx-0.5.6-i586-2.txz: Rebuilt.
kde/kcmutils-5.77.0-i586-1.txz: Upgraded.
kde/kcodecs-5.77.0-i586-1.txz: Upgraded.
kde/kcolorchooser-20.12.0-i586-1.txz: Upgraded.
kde/kcompletion-5.77.0-i586-1.txz: Upgraded.
kde/kconfig-5.77.0-i586-1.txz: Upgraded.
kde/kconfigwidgets-5.77.0-i586-1.txz: Upgraded.
kde/kcontacts-5.77.0-i586-1.txz: Upgraded.
kde/kcoreaddons-5.77.0-i586-1.txz: Upgraded.
kde/kcrash-5.77.0-i586-1.txz: Upgraded.
kde/kcron-20.12.0-i586-1.txz: Upgraded.
kde/kdav-5.77.0-i586-1.txz: Upgraded.
kde/kdbusaddons-5.77.0-i586-1.txz: Upgraded.
kde/kde-dev-scripts-20.12.0-i586-1.txz: Upgraded.
kde/kde-dev-utils-20.12.0-i586-1.txz: Upgraded.
kde/kdebugsettings-20.12.0-i586-1.txz: Upgraded.
kde/kdeclarative-5.77.0-i586-1.txz: Upgraded.
kde/kdeconnect-kde-20.12.0-i586-1.txz: Upgraded.
kde/kded-5.77.0-i586-1.txz: Upgraded.
kde/kdeedu-data-20.12.0-i586-1.txz: Upgraded.
kde/kdegraphics-mobipocket-20.12.0-i586-1.txz: Upgraded.
kde/kdegraphics-thumbnailers-20.12.0-i586-1.txz: Upgraded.
kde/kdelibs4support-5.77.0-i586-1.txz: Upgraded.
kde/kdenetwork-filesharing-20.12.0-i586-1.txz: Upgraded.
kde/kdenlive-20.12.0-i586-1.txz: Upgraded.
kde/kdepim-addons-20.12.0-i586-1.txz: Upgraded.
kde/kdepim-apps-libs-20.08.3-i586-1.txz: Removed.
kde/kdepim-runtime-20.12.0-i586-1.txz: Upgraded.
kde/kdesdk-kioslaves-20.12.0-i586-1.txz: Upgraded.
kde/kdesdk-thumbnailers-20.12.0-i586-1.txz: Upgraded.
kde/kdesignerplugin-5.77.0-i586-1.txz: Upgraded.
kde/kdesu-5.77.0-i586-1.txz: Upgraded.
kde/kdev-php-5.6.1-i586-1.txz: Upgraded.
kde/kdev-python-5.6.1-i586-1.txz: Upgraded.
kde/kdevelop-5.6.1-i586-1.txz: Upgraded.
kde/kdewebkit-5.77.0-i586-1.txz: Upgraded.
kde/kdf-20.12.0-i586-1.txz: Upgraded.
kde/kdialog-20.12.0-i586-1.txz: Upgraded.
kde/kdiamond-20.12.0-i586-1.txz: Upgraded.
kde/kdnssd-5.77.0-i586-1.txz: Upgraded.
kde/kdoctools-5.77.0-i586-1.txz: Upgraded.
kde/keditbookmarks-20.12.0-i586-1.txz: Upgraded.
kde/kemoticons-5.77.0-i586-1.txz: Upgraded.
kde/kfilemetadata-5.77.0-i586-1.txz: Upgraded.
kde/kfind-20.12.0-i586-1.txz: Upgraded.
kde/kfloppy-20.12.0-i586-1.txz: Upgraded.
kde/kfourinline-20.12.0-i586-1.txz: Upgraded.
kde/kgeography-20.12.0-i586-1.txz: Upgraded.
kde/kget-20.12.0-i586-1.txz: Upgraded.
kde/kglobalaccel-5.77.0-i586-1.txz: Upgraded.
kde/kgoldrunner-20.12.0-i586-1.txz: Upgraded.
kde/kgpg-20.12.0-i586-1.txz: Upgraded.
kde/kguiaddons-5.77.0-i586-1.txz: Upgraded.
kde/khangman-20.12.0-i586-1.txz: Upgraded.
kde/khelpcenter-20.12.0-i586-1.txz: Upgraded.
kde/kholidays-5.77.0-i586-1.txz: Upgraded.
kde/khtml-5.77.0-i586-1.txz: Upgraded.
kde/ki18n-5.77.0-i586-1.txz: Upgraded.
kde/kiconthemes-5.77.0-i586-1.txz: Upgraded.
kde/kidentitymanagement-20.12.0-i586-1.txz: Upgraded.
kde/kidletime-5.77.0-i586-1.txz: Upgraded.
kde/kig-20.12.0-i586-1.txz: Upgraded.
kde/kigo-20.12.0-i586-1.txz: Upgraded.
kde/killbots-20.12.0-i586-1.txz: Upgraded.
kde/kimageformats-5.77.0-i586-1.txz: Upgraded.
kde/kimagemapeditor-20.12.0-i586-1.txz: Upgraded.
kde/kimap-20.12.0-i586-1.txz: Upgraded.
kde/kinit-5.77.0-i586-1.txz: Upgraded.
kde/kio-5.77.0-i586-1.txz: Upgraded.
kde/kio-extras-20.12.0-i586-1.txz: Upgraded.
kde/kio-gdrive-20.12.0-i586-1.txz: Upgraded.
kde/kipi-plugins-20.12.0-i586-1.txz: Upgraded.
kde/kirigami-gallery-20.12.0-i586-1.txz: Upgraded.
kde/kirigami2-5.77.0-i586-1.txz: Upgraded.
kde/kiriki-20.12.0-i586-1.txz: Upgraded.
kde/kitemmodels-5.77.0-i586-1.txz: Upgraded.
kde/kitemviews-5.77.0-i586-1.txz: Upgraded.
kde/kiten-20.12.0-i586-1.txz: Upgraded.
kde/kitinerary-20.12.0-i586-1.txz: Upgraded.
kde/kjobwidgets-5.77.0-i586-1.txz: Upgraded.
kde/kjots-20201206_f7d555c-i586-1.txz: Upgraded.
kde/kjs-5.77.0-i586-1.txz: Upgraded.
kde/kjsembed-5.77.0-i586-1.txz: Upgraded.
kde/kjumpingcube-20.12.0-i586-1.txz: Upgraded.
kde/kldap-20.12.0-i586-1.txz: Upgraded.
kde/kleopatra-20.12.0-i586-1.txz: Upgraded.
kde/klickety-20.12.0-i586-1.txz: Upgraded.
kde/klines-20.12.0-i586-1.txz: Upgraded.
kde/kmag-20.12.0-i586-1.txz: Upgraded.
kde/kmahjongg-20.12.0-i586-1.txz: Upgraded.
kde/kmail-20.12.0-i586-1.txz: Upgraded.
kde/kmail-account-wizard-20.12.0-i586-1.txz: Upgraded.
kde/kmailtransport-20.12.0-i586-1.txz: Upgraded.
kde/kmbox-20.12.0-i586-1.txz: Upgraded.
kde/kmediaplayer-5.77.0-i586-1.txz: Upgraded.
kde/kmime-20.12.0-i586-1.txz: Upgraded.
kde/kmines-20.12.0-i586-1.txz: Upgraded.
kde/kmix-20.12.0-i586-1.txz: Upgraded.
kde/kmousetool-20.12.0-i586-1.txz: Upgraded.
kde/kmouth-20.12.0-i586-1.txz: Upgraded.
kde/kmplot-20.12.0-i586-1.txz: Upgraded.
kde/knavalbattle-20.12.0-i586-1.txz: Upgraded.
kde/knetwalk-20.12.0-i586-1.txz: Upgraded.
kde/knewstuff-5.77.0-i586-1.txz: Upgraded.
kde/knights-20.12.0-i586-1.txz: Upgraded.
kde/knotes-20.12.0-i586-1.txz: Upgraded.
kde/knotifications-5.77.0-i586-1.txz: Upgraded.
kde/knotifyconfig-5.77.0-i586-1.txz: Upgraded.
kde/kolf-20.12.0-i586-1.txz: Upgraded.
kde/kollision-20.12.0-i586-1.txz: Upgraded.
kde/kolourpaint-20.12.0-i586-1.txz: Upgraded.
kde/kompare-20.12.0-i586-1.txz: Upgraded.
kde/konqueror-20.12.0-i586-1.txz: Upgraded.
kde/konquest-20.12.0-i586-1.txz: Upgraded.
kde/konsole-20.12.0-i586-1.txz: Upgraded.
kde/kontact-20.12.0-i586-1.txz: Upgraded.
kde/kontactinterface-20.12.0-i586-1.txz: Upgraded.
kde/kontrast-20.12.0-i586-1.txz: Added.
kde/konversation-20.12.0-i586-1.txz: Added.
kde/kopete-20.12.0-i586-1.txz: Upgraded.
kde/korganizer-20.12.0-i586-1.txz: Upgraded.
kde/kosmindoormap-20.12.0-i586-1.txz: Added.
kde/kpackage-5.77.0-i586-1.txz: Upgraded.
kde/kparts-5.77.0-i586-1.txz: Upgraded.
kde/kpat-20.12.0-i586-1.txz: Upgraded.
kde/kpeople-5.77.0-i586-1.txz: Upgraded.
kde/kpimtextedit-20.12.0-i586-1.txz: Upgraded.
kde/kpkpass-20.12.0-i586-1.txz: Upgraded.
kde/kplotting-5.77.0-i586-1.txz: Upgraded.
kde/kpmcore-20.12.0-i586-1.txz: Upgraded.
kde/kpty-5.77.0-i586-1.txz: Upgraded.
kde/kpublictransport-20.12.0-i586-1.txz: Added.
kde/kqtquickcharts-20.12.0-i586-1.txz: Upgraded.
kde/kquickcharts-5.77.0-i586-1.txz: Upgraded.
kde/krdc-20.12.0-i586-1.txz: Upgraded.
kde/kreversi-20.12.0-i586-1.txz: Upgraded.
kde/krfb-20.12.0-i586-1.txz: Upgraded.
kde/kross-5.77.0-i586-1.txz: Upgraded.
kde/kross-interpreters-20.12.0-i586-1.txz: Upgraded.
kde/kruler-20.12.0-i586-1.txz: Upgraded.
kde/krunner-5.77.0-i586-1.txz: Upgraded.
kde/kservice-5.77.0-i586-1.txz: Upgraded.
kde/kshisen-20.12.0-i586-1.txz: Upgraded.
kde/ksirk-20.12.0-i586-1.txz: Upgraded.
kde/ksmtp-20.12.0-i586-1.txz: Upgraded.
kde/ksnakeduel-20.12.0-i586-1.txz: Upgraded.
kde/kspaceduel-20.12.0-i586-1.txz: Upgraded.
kde/ksquares-20.12.0-i586-1.txz: Upgraded.
kde/ksudoku-20.12.0-i586-1.txz: Upgraded.
kde/ksystemlog-20.12.0-i586-1.txz: Upgraded.
kde/kteatime-20.12.0-i586-1.txz: Upgraded.
kde/ktexteditor-5.77.0-i586-1.txz: Upgraded.
kde/ktextwidgets-5.77.0-i586-1.txz: Upgraded.
kde/ktimer-20.12.0-i586-1.txz: Upgraded.
kde/ktnef-20.12.0-i586-1.txz: Upgraded.
kde/ktorrent-20.12.0-i586-1.txz: Upgraded.
kde/ktouch-20.12.0-i586-1.txz: Upgraded.
kde/kturtle-20.12.0-i586-1.txz: Upgraded.
kde/kubrick-20.12.0-i586-1.txz: Upgraded.
kde/kunitconversion-5.77.0-i586-1.txz: Upgraded.
kde/kwallet-5.77.0-i586-1.txz: Upgraded.
kde/kwalletmanager-20.12.0-i586-1.txz: Upgraded.
kde/kwave-20.12.0-i586-1.txz: Upgraded.
kde/kwayland-5.77.0-i586-1.txz: Upgraded.
kde/kwidgetsaddons-5.77.0-i586-1.txz: Upgraded.
kde/kwindowsystem-5.77.0-i586-1.txz: Upgraded.
kde/kwordquiz-20.12.0-i586-1.txz: Upgraded.
kde/kxmlgui-5.77.0-i586-1.txz: Upgraded.
kde/kxmlrpcclient-5.77.0-i586-1.txz: Upgraded.
kde/libgravatar-20.12.0-i586-1.txz: Upgraded.
kde/libkcddb-20.12.0-i586-1.txz: Upgraded.
kde/libkcompactdisc-20.12.0-i586-1.txz: Upgraded.
kde/libkdcraw-20.12.0-i586-1.txz: Upgraded.
kde/libkdegames-20.12.0-i586-1.txz: Upgraded.
kde/libkdepim-20.12.0-i586-1.txz: Upgraded.
kde/libkeduvocdocument-20.12.0-i586-1.txz: Upgraded.
kde/libkexiv2-20.12.0-i586-1.txz: Upgraded.
kde/libkgapi-20.12.0-i586-1.txz: Upgraded.
kde/libkgeomap-20.08.3-i586-1.txz: Removed.
kde/libkipi-20.12.0-i586-1.txz: Upgraded.
kde/libkleo-20.12.0-i586-1.txz: Upgraded.
kde/libkmahjongg-20.12.0-i586-1.txz: Upgraded.
kde/libkomparediff2-20.12.0-i586-1.txz: Upgraded.
kde/libksane-20.12.0-i586-1.txz: Upgraded.
kde/libksieve-20.12.0-i586-1.txz: Upgraded.
kde/libktorrent-20.12.0-i586-1.txz: Upgraded.
kde/lokalize-20.12.0-i586-1.txz: Upgraded.
kde/lskat-20.12.0-i586-1.txz: Upgraded.
kde/mailcommon-20.12.0-i586-1.txz: Upgraded.
kde/mailimporter-20.12.0-i586-1.txz: Upgraded.
kde/marble-20.12.0-i586-1.txz: Upgraded.
kde/markdownpart-20.12.0-i586-1.txz: Added.
kde/mbox-importer-20.12.0-i586-1.txz: Upgraded.
kde/messagelib-20.12.0-i586-1.txz: Upgraded.
kde/minuet-20.12.0-i586-1.txz: Upgraded.
kde/modemmanager-qt-5.77.0-i586-1.txz: Upgraded.
kde/networkmanager-qt-5.77.0-i586-1.txz: Upgraded.
kde/okular-20.12.0-i586-1.txz: Upgraded.
kde/palapeli-20.12.0-i586-1.txz: Upgraded.
kde/parley-20.12.0-i586-1.txz: Upgraded.
kde/partitionmanager-20.12.0-i586-1.txz: Upgraded.
kde/picmi-20.12.0-i586-1.txz: Upgraded.
kde/pim-data-exporter-20.12.0-i586-1.txz: Upgraded.
kde/pim-sieve-editor-20.12.0-i586-1.txz: Upgraded.
kde/pimcommon-20.12.0-i586-1.txz: Upgraded.
kde/plasma-framework-5.77.0-i586-1.txz: Upgraded.
kde/powerdevil-5.20.4-i586-3.txz: Rebuilt.
kde/poxml-20.12.0-i586-1.txz: Upgraded.
kde/print-manager-20.12.0-i586-1.txz: Upgraded.
kde/prison-5.77.0-i586-1.txz: Upgraded.
kde/purpose-5.77.0-i586-1.txz: Upgraded.
kde/qqc2-desktop-style-5.77.0-i586-1.txz: Upgraded.
kde/rocs-20.12.0-i586-1.txz: Upgraded.
kde/sddm-0.19.0-i586-2.txz: Rebuilt.
kde/solid-5.77.0-i586-1.txz: Upgraded.
kde/sonnet-5.77.0-i586-1.txz: Upgraded.
kde/spectacle-20.12.0-i586-1.txz: Upgraded.
kde/step-20.12.0-i586-1.txz: Upgraded.
kde/svgpart-20.12.0-i586-1.txz: Upgraded.
kde/sweeper-20.12.0-i586-1.txz: Upgraded.
kde/syndication-5.77.0-i586-1.txz: Upgraded.
kde/syntax-highlighting-5.77.0-i586-1.txz: Upgraded.
kde/threadweaver-5.77.0-i586-1.txz: Upgraded.
kde/umbrello-20.12.0-i586-1.txz: Upgraded.
kde/yakuake-20.12.0-i586-1.txz: Upgraded.
kde/zeroconf-ioslave-20.12.0-i586-1.txz: Upgraded.
l/imagemagick-7.0.10_48-i586-1.txz: Upgraded.
l/libcap-ng-0.8.2-i586-1.txz: Upgraded.
l/mozilla-nss-3.60-i586-1.txz: Upgraded.
n/p11-kit-0.23.22-i586-1.txz: Upgraded.
extra/linux-5.4.83-nosmp-sdk/*: Upgraded.
Post Napisano: 16 Dec 2020, 13:10
Slackware 64-bit
Tue Dec 15 20:39:53 UTC 2020
d/python-pip-20.3.3-x86_64-1.txz: Upgraded.
kde/sddm-0.19.0-x86_64-3.txz: Rebuilt.
       In SDDM's Xsession script, don't source $HOME/.xsession as this may launch
       the wrong session type or cause dbus-run-session to start twice breaking
       logout.
l/orc-0.4.32-x86_64-1.txz: Upgraded.
l/pipewire-0.3.18-x86_64-1.txz: Upgraded.
l/python-chardet-4.0.0-x86_64-1.txz: Upgraded.
l/python-packaging-20.8-x86_64-1.txz: Upgraded.
n/samba-4.13.3-x86_64-1.txz: Upgraded.
xap/mozilla-thunderbird-78.6.0-x86_64-1.txz: Upgraded.
       This is a bugfix release.
       https://www.mozilla.org/en-US/thunderbird/78.6.0/releasenotes/
xfce/mousepad-0.5.0-x86_64-1.txz: Upgraded.
Mon Dec 14 22:41:16 UTC 2020
ap/pamixer-1.4-x86_64-7.txz: Rebuilt.
       Recompiled against boost-1.75.0.
ap/rpm-4.16.1-x86_64-1.txz: Upgraded.
d/strace-5.10-x86_64-1.txz: Upgraded.
kde/kig-20.12.0-x86_64-2.txz: Rebuilt.
kde/krita-4.4.1-x86_64-2.txz: Rebuilt.
l/atkmm-2.28.1-x86_64-1.txz: Upgraded.
l/boost-1.75.0-x86_64-1.txz: Upgraded.
l/cryfs-0.10.2-x86_64-2.txz: Rebuilt.
l/fftw-3.3.9-x86_64-1.txz: Upgraded.
l/glade3-3.8.6-x86_64-2.txz: Removed.
l/gtkmm3-3.24.3-x86_64-1.txz: Upgraded.
l/libcap-2.46-x86_64-1.txz: Upgraded.
l/mozjs78-78.6.0esr-x86_64-1.txz: Upgraded.
l/openexr-2.5.3-x86_64-2.txz: Rebuilt.
l/pangomm-2.42.2-x86_64-1.txz: Upgraded.
l/rttr-0.9.6-x86_64-2.txz: Rebuilt.
       Get rid of /usr/doc/index.html (and excessive docs).
n/s-nail-14.9.20-x86_64-1.txz: Upgraded.
xap/mozilla-firefox-78.6.0esr-x86_64-1.txz: Upgraded.
       https://www.mozilla.org/en-US/firefox/78.6.0/releasenotes/
xap/xpaint-3.0.3-x86_64-1.txz: Upgraded.
xfce/libxfce4ui-4.14.1-x86_64-2.txz: Rebuilt.
       Recompiled against glade-3.38.2.
Slackware 32-bit
d/python-pip-20.3.3-i586-1.txz: Upgraded.
kde/sddm-0.19.0-i586-3.txz: Rebuilt.
       logout.
l/orc-0.4.32-i586-1.txz: Upgraded.
l/pipewire-0.3.18-i586-1.txz: Upgraded.
l/python-chardet-4.0.0-i586-1.txz: Upgraded.
l/python-packaging-20.8-i586-1.txz: Upgraded.
n/samba-4.13.3-i586-1.txz: Upgraded.
xap/mozilla-thunderbird-78.6.0-i686-1.txz: Upgraded.
xfce/mousepad-0.5.0-i586-1.txz: Upgraded.
ap/pamixer-1.4-i586-7.txz: Rebuilt.
ap/rpm-4.16.1-i586-1.txz: Upgraded.
d/strace-5.10-i586-1.txz: Upgraded.
kde/kig-20.12.0-i586-2.txz: Rebuilt.
kde/krita-4.4.1-i586-2.txz: Rebuilt.
l/atkmm-2.28.1-i586-1.txz: Upgraded.
l/boost-1.75.0-i586-1.txz: Upgraded.
l/cryfs-0.10.2-i586-2.txz: Rebuilt.
l/fftw-3.3.9-i586-1.txz: Upgraded.
l/glade3-3.8.6-i586-2.txz: Removed.
l/gtkmm3-3.24.3-i586-1.txz: Upgraded.
l/libcap-2.46-i586-1.txz: Upgraded.
l/mozjs78-78.6.0esr-i586-1.txz: Upgraded.
l/openexr-2.5.3-i586-2.txz: Rebuilt.
l/pangomm-2.42.2-i586-1.txz: Upgraded.
l/rttr-0.9.6-i586-2.txz: Rebuilt.
n/s-nail-14.9.20-i586-1.txz: Upgraded.
xap/mozilla-firefox-78.6.0esr-i686-1.txz: Upgraded.
xap/xpaint-3.0.3-i586-1.txz: Upgraded.
xfce/libxfce4ui-4.14.1-i586-2.txz: Rebuilt.
Post Napisano: 17 Dec 2020, 19:07
Slackware 64-bit
Thu Dec 17 04:05:14 UTC 2020
I'm still poking at that other kernel, but it shouldn't take too much longer.
a/kernel-generic-5.4.84-x86_64-1.txz: Upgraded.
a/kernel-huge-5.4.84-x86_64-1.txz: Upgraded.
a/kernel-modules-5.4.84-x86_64-1.txz: Upgraded.
ap/rpm-4.16.1.2-x86_64-1.txz: Upgraded.
d/cmake-3.19.2-x86_64-1.txz: Upgraded.
d/kernel-headers-5.4.84-x86-1.txz: Upgraded.
k/kernel-source-5.4.84-noarch-1.txz: Upgraded.
l/utf8proc-2.6.1-x86_64-1.txz: Upgraded.
x/fonttosfnt-1.2.1-x86_64-1.txz: Upgraded.
x/mesa-20.3.1-x86_64-1.txz: Upgraded.
       Don't specify dri-drivers-path. Thanks to 414N.
Slackware 32-bit
a/kernel-generic-5.4.84-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.4.84_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.4.84-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.4.84_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.4.84-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.4.84_smp-i686-1.txz: Upgraded.
ap/rpm-4.16.1.2-i586-1.txz: Upgraded.
d/cmake-3.19.2-i586-1.txz: Upgraded.
d/kernel-headers-5.4.84_smp-x86-1.txz: Upgraded.
k/kernel-source-5.4.84_smp-noarch-1.txz: Upgraded.
l/utf8proc-2.6.1-i586-1.txz: Upgraded.
x/fonttosfnt-1.2.1-i586-1.txz: Upgraded.
x/mesa-20.3.1-i586-1.txz: Upgraded.
extra/linux-5.4.84-nosmp-sdk/*: Upgraded.
Post Napisano: 21 Dec 2020, 21:03
Slackware 64-bit
Sun Dec 20 21:30:36 UTC 2020
ap/sudo-1.9.4p2-x86_64-1.txz: Upgraded.
kde/kmymoney-5.1.1-x86_64-1.txz: Upgraded.
l/babl-0.1.84-x86_64-1.txz: Upgraded.
l/gegl-0.4.28-x86_64-1.txz: Upgraded.
l/imagemagick-7.0.10_51-x86_64-1.txz: Upgraded.
Sun Dec 20 03:10:57 UTC 2020
Linus didn't think this was a scary kernel and in spite of skipping a few
branches here before getting to this one, I don't either. Not scary enough
to make me think I need to start it out in /testing, anyway. I have a good
feeling about this kernel. Enjoy! :-)
a/bash-5.1.004-x86_64-1.txz: Upgraded.
a/elogind-246.9-x86_64-1.txz: Upgraded.
       Don't make 10-enable-session-power.rules a .new file.
       Thanks to Robby Workman.
a/kernel-firmware-20201218_646f159-noarch-1.txz: Upgraded.
a/kernel-generic-5.10.1-x86_64-1.txz: Upgraded.
a/kernel-huge-5.10.1-x86_64-1.txz: Upgraded.
a/kernel-modules-5.10.1-x86_64-1.txz: Upgraded.
a/ndctl-71-x86_64-1.txz: Upgraded.
a/sysvinit-scripts-2.1-noarch-37.txz: Rebuilt.
       rc.S: don't start cgmanager/cgproxy.
       rc.6: don't stop cgmanager/cgproxy.
d/kernel-headers-5.10.1-x86-1.txz: Upgraded.
k/kernel-source-5.10.1-noarch-1.txz: Upgraded.
l/libtiff-4.2.0-x86_64-1.txz: Upgraded.
l/zstd-1.4.8-x86_64-1.txz: Upgraded.
n/ca-certificates-20201219-noarch-1.txz: Upgraded.
       This update provides the latest CA certificates to check for the
       authenticity of SSL connections.
xap/libnma-1.8.30-x86_64-1.txz: Upgraded.
Fri Dec 18 20:41:05 UTC 2020
ap/sudo-1.9.4p1-x86_64-1.txz: Upgraded.
l/icu4c-68.2-x86_64-1.txz: Upgraded.
l/netpbm-10.92.01-x86_64-1.txz: Upgraded.
n/ethtool-5.10-x86_64-1.txz: Upgraded.
x/libva-utils-2.10.0-x86_64-1.txz: Upgraded.
x/xf86-video-intel-20201215_a511f22c-x86_64-1.txz: Upgraded.
Thu Dec 17 23:02:41 UTC 2020
a/inih-r52-x86_64-1.txz: Added.
       This is required by the latest xfsprogs.
a/sysklogd-2.1.2-x86_64-2.txz: Rebuilt.
       rc.syslog: fix lack of <CR> after startup output.
a/xfsprogs-5.10.0-x86_64-1.txz: Upgraded.
ap/vim-8.2.2151-x86_64-1.txz: Upgraded.
l/glib2-2.66.4-x86_64-1.txz: Upgraded.
l/imagemagick-7.0.10_50-x86_64-1.txz: Upgraded.
l/python-requests-2.25.1-x86_64-1.txz: Upgraded.
l/qtkeychain-0.12.0-x86_64-1.txz: Upgraded.
l/zstd-1.4.7-x86_64-1.txz: Upgraded.
n/bind-9.16.10-x86_64-1.txz: Upgraded.
x/libwacom-1.7-x86_64-1.txz: Upgraded.
x/xorg-server-1.20.10-x86_64-2.txz: Rebuilt.
       Recompiled to find DRI modules in the new location.
x/xorg-server-xephyr-1.20.10-x86_64-2.txz: Rebuilt.
x/xorg-server-xnest-1.20.10-x86_64-2.txz: Rebuilt.
x/xorg-server-xvfb-1.20.10-x86_64-2.txz: Rebuilt.
x/xorg-server-xwayland-1.20.10-x86_64-2.txz: Rebuilt.
xap/vim-gvim-8.2.2151-x86_64-1.txz: Upgraded.
extra/pure-alsa-system/kde-runtime-4.14.3-x86_64-8_alsa.txz: Removed.
       I'm starting to lean towards removing all of these packages as there are
       ways to configure PulseAudio to get out of the way. See (for example) this
       article mentioned in a blog post by alienBOB:
       https://wiki.archlinux.org/index.php/PulseAudio/Examples#PulseAudio_as_a_minimal_unintrusive_dumb_pipe_to_ALSA
Slackware 32-bit
ap/sudo-1.9.4p2-i586-1.txz: Upgraded.
kde/kmymoney-5.1.1-i586-1.txz: Upgraded.
l/babl-0.1.84-i586-1.txz: Upgraded.
l/gegl-0.4.28-i586-1.txz: Upgraded.
l/imagemagick-7.0.10_51-i586-1.txz: Upgraded.
a/bash-5.1.004-i586-1.txz: Upgraded.
a/elogind-246.9-i586-1.txz: Upgraded.
a/kernel-generic-5.10.1-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.10.1_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.10.1-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.10.1_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.10.1-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.10.1_smp-i686-1.txz: Upgraded.
a/ndctl-71-i586-1.txz: Upgraded.
d/kernel-headers-5.10.1_smp-x86-1.txz: Upgraded.
k/kernel-source-5.10.1_smp-noarch-1.txz: Upgraded.
l/libtiff-4.2.0-i586-1.txz: Upgraded.
l/zstd-1.4.8-i586-1.txz: Upgraded.
xap/libnma-1.8.30-i586-1.txz: Upgraded.
extra/linux-5.10.1-nosmp-sdk/*: Upgraded.
ap/sudo-1.9.4p1-i586-1.txz: Upgraded.
l/icu4c-68.2-i586-1.txz: Upgraded.
l/netpbm-10.92.01-i586-1.txz: Upgraded.
n/ethtool-5.10-i586-1.txz: Upgraded.
x/libva-utils-2.10.0-i586-1.txz: Upgraded.
x/xf86-video-intel-20201215_a511f22c-i686-1.txz: Upgraded.
a/inih-r52-i586-1.txz: Added.
a/sysklogd-2.1.2-i586-2.txz: Rebuilt.
a/xfsprogs-5.10.0-i586-1.txz: Upgraded.
ap/vim-8.2.2151-i586-1.txz: Upgraded.
l/glib2-2.66.4-i586-1.txz: Upgraded.
l/imagemagick-7.0.10_50-i586-1.txz: Upgraded.
l/python-requests-2.25.1-i586-1.txz: Upgraded.
l/qtkeychain-0.12.0-i586-1.txz: Upgraded.
l/zstd-1.4.7-i586-1.txz: Upgraded.
n/bind-9.16.10-i586-1.txz: Upgraded.
x/libwacom-1.7-i586-1.txz: Upgraded.
x/xorg-server-1.20.10-i586-2.txz: Rebuilt.
x/xorg-server-xephyr-1.20.10-i586-2.txz: Rebuilt.
x/xorg-server-xnest-1.20.10-i586-2.txz: Rebuilt.
x/xorg-server-xvfb-1.20.10-i586-2.txz: Rebuilt.
x/xorg-server-xwayland-1.20.10-i586-2.txz: Rebuilt.
xap/vim-gvim-8.2.2151-i586-1.txz: Upgraded.
extra/pure-alsa-system/kde-runtime-4.14.3-i586-8_alsa.txz: Removed.
Post Napisano: 23 Dec 2020, 17:09
Slackware 64-bit
Tue Dec 22 20:45:03 UTC 2020
a/elogind-246.9.1-x86_64-1.txz: Upgraded.
ap/htop-3.0.4-x86_64-1.txz: Upgraded.
ap/man-pages-5.10-noarch-1.txz: Upgraded.
l/SDL2-2.0.14-x86_64-1.txz: Upgraded.
l/kdsoap-1.10.0-x86_64-1.txz: Upgraded.
l/opencv-4.5.1-x86_64-1.txz: Upgraded.
n/libgpg-error-1.41-x86_64-1.txz: Upgraded.
t/xfig-3.2.8-x86_64-1.txz: Upgraded.
xap/blueman-2.1.4-x86_64-2.txz: Rebuilt.
       Restore the AppIndicator.py plugin.
Mon Dec 21 22:23:10 UTC 2020
a/kernel-generic-5.10.2-x86_64-1.txz: Upgraded.
a/kernel-huge-5.10.2-x86_64-1.txz: Upgraded.
a/kernel-modules-5.10.2-x86_64-1.txz: Upgraded.
d/kernel-headers-5.10.2-x86-1.txz: Upgraded.
d/parallel-20201222-noarch-1.txz: Upgraded.
d/python-setuptools-51.1.0-x86_64-1.txz: Upgraded.
k/kernel-source-5.10.2-noarch-1.txz: Upgraded.
       -USB_SISUSBVGA_CON y
       PCIE_BW y -> n
       Thanks to walecha.
l/gegl-0.4.28-x86_64-2.txz: Rebuilt.
       Make sure gegl:introspect is available or GIMP won't start.
n/gnupg2-2.2.26-x86_64-1.txz: Upgraded.
n/iproute2-5.10.0-x86_64-1.txz: Upgraded.
n/ipset-7.10-x86_64-1.txz: Upgraded.
x/liberation-fonts-ttf-2.1.2-noarch-1.txz: Upgraded.
xfce/xfce4-systemload-plugin-1.2.4-x86_64-1.txz: Upgraded.
Slackware 32-bit
a/elogind-246.9.1-i586-1.txz: Upgraded.
ap/htop-3.0.4-i586-1.txz: Upgraded.
l/SDL2-2.0.14-i586-1.txz: Upgraded.
l/kdsoap-1.10.0-i586-1.txz: Upgraded.
l/opencv-4.5.1-i586-1.txz: Upgraded.
n/libgpg-error-1.41-i586-1.txz: Upgraded.
t/xfig-3.2.8-i586-1.txz: Upgraded.
xap/blueman-2.1.4-i586-2.txz: Rebuilt.
a/kernel-generic-5.10.2-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.10.2_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.10.2-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.10.2_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.10.2-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.10.2_smp-i686-1.txz: Upgraded.
d/kernel-headers-5.10.2_smp-x86-1.txz: Upgraded.
d/python-setuptools-51.1.0-i586-1.txz: Upgraded.
k/kernel-source-5.10.2_smp-noarch-1.txz: Upgraded.
       PCIE_BW y -> n
       Thanks to walecha.
l/gegl-0.4.28-i586-2.txz: Rebuilt.
n/gnupg2-2.2.26-i586-1.txz: Upgraded.
n/iproute2-5.10.0-i586-1.txz: Upgraded.
n/ipset-7.10-i586-1.txz: Upgraded.
xfce/xfce4-systemload-plugin-1.2.4-i586-1.txz: Upgraded.
extra/linux-5.10.2-nosmp-sdk/*: Upgraded.
Post Napisano: 26 Dec 2020, 12:22
Slackware 64-bit
Fri Dec 25 21:31:29 UTC 2020
l/keyutils-1.6.3-x86_64-1.txz: Upgraded.
l/pulseaudio-14.0-x86_64-3.txz: Rebuilt.
       Patched to support detecting elogind at compile time when built with meson.
       This restores PulseAudio exiting upon user logout.
       Thanks to LuckyCyborg for the bug report and patch.
l/system-config-printer-1.5.13-x86_64-1.txz: Upgraded.
n/mobile-broadband-provider-info-20201225-x86_64-1.txz: Upgraded.
Fri Dec 25 06:10:08 UTC 2020
l/harfbuzz-2.7.3-x86_64-2.txz: Rebuilt.
       Seems the --enable-introspection option didn't work, so rebuild with meson
       since that's probably what most of the developers do. Fixes blueman.
       Thanks to marav for the bug report.
Fri Dec 25 00:52:08 UTC 2020
Here are some updates to provide a little holiday cheer. The kernels are
rebuilt (yeah, we'll probably have new ones tomorrow but whatever) to build in
HWMON making NVMe temperature monitoring available, and there's also a massive
cleanup of polkit/dbus related packages to move most of the config files out
of /etc and not install them as .new. Local config files that override the
shipped ones may be placed in the directories in /etc to override the ones that
we ship. Thanks to Robby Workman for this!
None of the packages included in Slackware place any files in
/etc/polkit-1/rules.d/ or /etc/dbus-1/system.d/ any more, but there may be
third-party packages that still do. However, since Slackware's packages
originally installed these as .new files, the leftover configs will remain.
You'll probably want to take a look in those directories to clean out any
config files that you haven't modified yourself or that belong to packages that
aren't part of Slackware itself.
Hope everyone has a great day. :-)
a/dbus-1.12.20-x86_64-3.txz: Rebuilt.
       Added local config override directory /etc/dbus-1/system.d/ since no other
       package provides it now.
a/kernel-generic-5.10.2-x86_64-2.txz: Upgraded.
a/kernel-huge-5.10.2-x86_64-2.txz: Upgraded.
a/kernel-modules-5.10.2-x86_64-2.txz: Upgraded.
a/udisks-1.0.5-x86_64-6.txz: Rebuilt.
       Move D-Bus configs from /etc to the system location. Thanks to Robby Workman.
a/udisks2-2.9.1-x86_64-2.txz: Rebuilt.
       Include 20-plugdev-group-mount-override.rules, installed in the system
ap/cups-2.3.3-x86_64-3.txz: Rebuilt.
ap/hplip-3.20.6-x86_64-4.txz: Rebuilt.
       Use --enable-qt5.
       Drop HAL support (LOL!)
ap/mpg123-1.26.4-x86_64-1.txz: Upgraded.
d/gnucobol-3.1.2-x86_64-1.txz: Upgraded.
d/kernel-headers-5.10.2-x86-2.txz: Upgraded.
k/kernel-source-5.10.2-noarch-2.txz: Upgraded.
       HWMON m -> y
       +NVME_HWMON y
       +POWER_SUPPLY_HWMON y
       +THERMAL_HWMON y
       Thanks to Daedra.
kde/sddm-0.19.0-x86_64-4.txz: Rebuilt.
       Don't include the /etc/dbus-1/system.d/ directory.
l/GConf-3.2.6-x86_64-5.txz: Rebuilt.
l/accountsservice-0.6.55-x86_64-2.txz: Rebuilt.
l/cryptopp-8.3.0-x86_64-1.txz: Upgraded.
l/harfbuzz-2.7.3-x86_64-1.txz: Upgraded.
l/polkit-0.118-x86_64-3.txz: Rebuilt.
       Remove D-Bus rules for udisks2 and NetworkManager (moved to those packages).
l/pulseaudio-14.0-x86_64-2.txz: Rebuilt.
l/system-config-printer-1.5.12-x86_64-6.txz: Rebuilt.
n/ModemManager-1.14.8-x86_64-2.txz: Rebuilt.
       Added elogind support.
n/NetworkManager-1.28.0-x86_64-2.txz: Rebuilt.
       Include 10-org.freedesktop.NetworkManager.rules, installed in the system
n/bluez-5.55-x86_64-2.txz: Rebuilt.
n/netatalk-3.1.12-x86_64-5.txz: Rebuilt.
       Patched to fix failure to build from source with gcc10.
n/wpa_supplicant-2.9-x86_64-3.txz: Rebuilt.
x/mesa-20.3.1-x86_64-2.txz: Rebuilt.
       [PATCH] vulkan/device_select: Store Vulkan vendorID and deviceID as uint32_t.
       Thanks to sasha69 for the link to the upstream discussion/commit.
xap/blueman-2.1.4-x86_64-3.txz: Rebuilt.
xap/xgames-0.3-x86_64-6.txz: Rebuilt.
       Fixed spider failing to build from source with gcc10.
       Removed the ancient version of xsnow.
xap/xscreensaver-5.45-x86_64-2.txz: Rebuilt.
       Make the description of the xscreensaver settings be clearly for xscreensaver
       as opposed to a generic "screensaver" settings. Thanks to Robby Workman.
xap/xsnow-3.1.9-x86_64-1.txz: Added.
       Merry Christmas / Happy Holidays! :-)
xfce/mousepad-0.5.1-x86_64-1.txz: Upgraded.
xfce/xfce4-screensaver-0.1.11-x86_64-2.txz: Rebuilt.
       Make the description of the xfce4-screensaver settings be clearly for
       xfce4-screensaver as opposed to a generic "screensaver" settings.
xfce/xfce4-session-4.14.2-x86_64-2.txz: Rebuilt.
       Use xfce4-screensaver by default and don't ship the xscreensaver.desktop
       autostart file. Thanks to Robby Workman.
extra/pure-alsa-system/*: Removed.
       This served a purpose during the pure ALSA to PulseAudio transition, but
       it's time for it to go away. If the latency is an issue for your use case,
       a look around should turn up documentation on how to reduce it, or how to
       send output directly to ALSA without having to uninstall PulseAudio or
       recompile anything that's linked to it. As an example, see this one (which
       was mentioned here before):
Wed Dec 23 21:21:34 UTC 2020
a/lilo-24.2-x86_64-10.txz: Rebuilt.
       Add -fcommon to fix build with gcc10.
       liloconfig:
       Don't warn about UMSDOS which is long obsolete.
       Detect QEMU and use /dev/vda as the boot device in that case.
       Fix a case where /mnt was used instead of the target partition variable.
       Thanks to alienBOB.
a/mkinitrd-1.4.11-x86_64-16.txz: Rebuilt.
       Blacklist rules.d/73-seat-late.rules. Thanks to Robby Workman.
a/ndctl-71.1-x86_64-1.txz: Upgraded.
a/sysklogd-2.1.2-x86_64-3.txz: Rebuilt.
       /etc/logrotate.d/syslog.new: add missingok option. Thanks to sovteq.
l/gdbm-1.19-x86_64-1.txz: Upgraded.
t/fig2dev-3.2.8-x86_64-1.txz: Upgraded.
x/libepoxy-1.5.5-x86_64-1.txz: Upgraded.
Slackware 32-bit
l/keyutils-1.6.3-i586-1.txz: Upgraded.
l/pulseaudio-14.0-i586-3.txz: Rebuilt.
l/system-config-printer-1.5.13-i586-1.txz: Upgraded.
n/mobile-broadband-provider-info-20201225-i586-1.txz: Upgraded.
l/harfbuzz-2.7.3-i586-2.txz: Rebuilt.
a/dbus-1.12.20-i586-3.txz: Rebuilt.
a/kernel-generic-5.10.2-i586-2.txz: Upgraded.
a/kernel-generic-smp-5.10.2_smp-i686-2.txz: Upgraded.
a/kernel-huge-5.10.2-i586-2.txz: Upgraded.
a/kernel-huge-smp-5.10.2_smp-i686-2.txz: Upgraded.
a/kernel-modules-5.10.2-i586-2.txz: Upgraded.
a/kernel-modules-smp-5.10.2_smp-i686-2.txz: Upgraded.
a/udisks-1.0.5-i586-6.txz: Rebuilt.
a/udisks2-2.9.1-i586-2.txz: Rebuilt.
ap/cups-2.3.3-i586-3.txz: Rebuilt.
ap/hplip-3.20.6-i586-4.txz: Rebuilt.
       Use --enable-qt5.
ap/mpg123-1.26.4-i586-1.txz: Upgraded.
d/gnucobol-3.1.2-i586-1.txz: Upgraded.
d/kernel-headers-5.10.2_smp-x86-2.txz: Upgraded.
k/kernel-source-5.10.2_smp-noarch-2.txz: Upgraded.
       HWMON m -> y
       +NVME_HWMON y
       +THERMAL_HWMON y
       Thanks to Daedra.
kde/sddm-0.19.0-i586-4.txz: Rebuilt.
l/GConf-3.2.6-i586-5.txz: Rebuilt.
l/accountsservice-0.6.55-i586-2.txz: Rebuilt.
l/cryptopp-8.3.0-i586-1.txz: Upgraded.
l/harfbuzz-2.7.3-i586-1.txz: Upgraded.
l/polkit-0.118-i586-3.txz: Rebuilt.
l/pulseaudio-14.0-i586-2.txz: Rebuilt.
l/system-config-printer-1.5.12-i586-6.txz: Rebuilt.
n/ModemManager-1.14.8-i586-2.txz: Rebuilt.
n/NetworkManager-1.28.0-i586-2.txz: Rebuilt.
n/bluez-5.55-i586-2.txz: Rebuilt.
n/netatalk-3.1.12-i586-5.txz: Rebuilt.
n/wpa_supplicant-2.9-i586-3.txz: Rebuilt.
x/mesa-20.3.1-i586-2.txz: Rebuilt.
xap/blueman-2.1.4-i586-3.txz: Rebuilt.
xap/xgames-0.3-i586-6.txz: Rebuilt.
xap/xscreensaver-5.45-i586-2.txz: Rebuilt.
xap/xsnow-3.1.9-i586-1.txz: Added.
xfce/mousepad-0.5.1-i586-1.txz: Upgraded.
xfce/xfce4-screensaver-0.1.11-i586-2.txz: Rebuilt.
xfce/xfce4-session-4.14.2-i586-2.txz: Rebuilt.
a/lilo-24.2-i586-10.txz: Rebuilt.
       liloconfig:
       Thanks to alienBOB.
a/mkinitrd-1.4.11-i586-16.txz: Rebuilt.
a/ndctl-71.1-i586-1.txz: Upgraded.
a/sysklogd-2.1.2-i586-3.txz: Rebuilt.
l/gdbm-1.19-i586-1.txz: Upgraded.
t/fig2dev-3.2.8-i586-1.txz: Upgraded.
x/libepoxy-1.5.5-i586-1.txz: Upgraded.
Post Napisano: 27 Dec 2020, 12:44
Slackware 64-bit
Sat Dec 26 21:51:18 UTC 2020
a/glibc-zoneinfo-2020e-noarch-1.txz: Upgraded.
       This package provides the latest timezone updates.
a/kernel-generic-5.10.3-x86_64-1.txz: Upgraded.
a/kernel-huge-5.10.3-x86_64-1.txz: Upgraded.
a/kernel-modules-5.10.3-x86_64-1.txz: Upgraded.
ap/sysstat-12.5.2-x86_64-1.txz: Upgraded.
d/kernel-headers-5.10.3-x86-1.txz: Upgraded.
k/kernel-source-5.10.3-noarch-1.txz: Upgraded.
       SND_PCSP n -> m
       SND_SOC_AK5558 n -> m
       SND_SOC_INTEL_CML_LP_DA7219_MAX98357A_MACH n -> m
       SND_SOC_INTEL_KBL_RT5663_RT5514_MAX98927_MACH n -> m
       SND_SOC_INTEL_SKL_HDA_DSP_GENERIC_MACH n -> m
       SND_SOC_INTEL_SOF_RT5682_MACH n -> m
       +SND_SOC_RT5514 m
       +SND_SOC_RT5514_SPI m
       Added a few more sound modules. Thanks to Loomx for pointing out that
       SND_SOC_INTEL_SKL_HDA_DSP_GENERIC_MACH was missing.
l/imagemagick-7.0.10_53-x86_64-1.txz: Upgraded.
l/libusb-1.0.24-x86_64-1.txz: Upgraded.
Slackware 32-bit
a/kernel-generic-5.10.3-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.10.3_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.10.3-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.10.3_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.10.3-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.10.3_smp-i686-1.txz: Upgraded.
ap/sysstat-12.5.2-i586-1.txz: Upgraded.
d/kernel-headers-5.10.3_smp-x86-1.txz: Upgraded.
k/kernel-source-5.10.3_smp-noarch-1.txz: Upgraded.
       SND_PCSP n -> m
       +SND_SOC_RT5514 m
l/imagemagick-7.0.10_53-i586-1.txz: Upgraded.
l/libusb-1.0.24-i586-1.txz: Upgraded.
extra/linux-5.10.3-nosmp-sdk/*: Upgraded.
Post Napisano: 28 Dec 2020, 10:46
Slackware 64-bit
Sun Dec 27 22:52:10 UTC 2020
And, just a month after Xfce 4.14 appeared in vtown, we have Xfce 4.16 updates
in the main tree. Thanks much to Robby Workman for making it happen. :-)
a/aaa_terminfo-6.2_20201219-x86_64-1.txz: Upgraded.
a/ndctl-71.1-x86_64-2.txz: Rebuilt.
       Fix bash-completion file installation (previously it was causing the
       completion dir to have mode 0644). Thanks to Robby Workman.
l/harfbuzz-2.7.4-x86_64-1.txz: Upgraded.
l/libarchive-3.5.1-x86_64-1.txz: Upgraded.
l/libgtop-2.40.0-x86_64-1.txz: Added.
       This is used by libxfce4ui to provide extra information in the about page.
l/ncurses-6.2_20201219-x86_64-1.txz: Upgraded.
n/wpa_supplicant-2.9-x86_64-4.txz: Rebuilt.
       Fix desktop file to not show if kdesu isn't available. Thanks to Hyperion.
x/xterm-363-x86_64-1.txz: Upgraded.
xap/xsnow-3.2.0-x86_64-1.txz: Upgraded.
xfce/Greybird-3.22.13-noarch-2.txz: Rebuilt.
xfce/exo-4.16.0-x86_64-1.txz: Upgraded.
xfce/garcon-0.8.0-x86_64-1.txz: Upgraded.
xfce/libxfce4ui-4.16.0-x86_64-1.txz: Upgraded.
xfce/libxfce4util-4.16.0-x86_64-1.txz: Upgraded.
xfce/mousepad-0.5.1-x86_64-2.txz: Rebuilt.
xfce/thunar-4.16.0-x86_64-1.txz: Upgraded.
xfce/thunar-volman-4.16.0-x86_64-1.txz: Upgraded.
xfce/tumbler-4.16.0-x86_64-1.txz: Upgraded.
xfce/xfce4-appfinder-4.16.0-x86_64-1.txz: Upgraded.
xfce/xfce4-clipman-plugin-1.6.1-x86_64-2.txz: Rebuilt.
xfce/xfce4-dev-tools-4.16.0-x86_64-1.txz: Upgraded.
xfce/xfce4-notifyd-0.6.2-x86_64-2.txz: Rebuilt.
xfce/xfce4-panel-4.16.0-x86_64-1.txz: Upgraded.
xfce/xfce4-panel-profiles-1.0.10-x86_64-2.txz: Rebuilt.
xfce/xfce4-power-manager-4.16.0-x86_64-1.txz: Upgraded.
xfce/xfce4-pulseaudio-plugin-0.4.3-x86_64-2.txz: Rebuilt.
xfce/xfce4-screensaver-0.1.11-x86_64-3.txz: Rebuilt.
xfce/xfce4-screenshooter-1.9.8-x86_64-1.txz: Upgraded.
xfce/xfce4-session-4.16.0-x86_64-1.txz: Upgraded.
xfce/xfce4-settings-4.16.0-x86_64-1.txz: Upgraded.
xfce/xfce4-systemload-plugin-1.2.4-x86_64-2.txz: Rebuilt.
xfce/xfce4-taskmanager-1.2.3-x86_64-2.txz: Rebuilt.
xfce/xfce4-terminal-0.8.10-x86_64-1.txz: Upgraded.
xfce/xfce4-weather-plugin-0.10.2-x86_64-2.txz: Rebuilt.
xfce/xfce4-whiskermenu-plugin-2.5.0-x86_64-1.txz: Upgraded.
xfce/xfconf-4.16.0-x86_64-1.txz: Upgraded.
xfce/xfdesktop-4.16.0-x86_64-1.txz: Upgraded.
xfce/xfwm4-4.16.0-x86_64-1.txz: Upgraded.
Slackware 32-bit
a/aaa_terminfo-6.2_20201219-i586-1.txz: Upgraded.
a/ndctl-71.1-i586-2.txz: Rebuilt.
l/harfbuzz-2.7.4-i586-1.txz: Upgraded.
l/libarchive-3.5.1-i586-1.txz: Upgraded.
l/libgtop-2.40.0-i586-1.txz: Added.
l/ncurses-6.2_20201219-i586-1.txz: Upgraded.
n/wpa_supplicant-2.9-i586-4.txz: Rebuilt.
x/xterm-363-i586-1.txz: Upgraded.
xap/xsnow-3.2.0-i586-1.txz: Upgraded.
xfce/exo-4.16.0-i586-1.txz: Upgraded.
xfce/garcon-0.8.0-i586-1.txz: Upgraded.
xfce/libxfce4ui-4.16.0-i586-1.txz: Upgraded.
xfce/libxfce4util-4.16.0-i586-1.txz: Upgraded.
xfce/mousepad-0.5.1-i586-2.txz: Rebuilt.
xfce/thunar-4.16.0-i586-1.txz: Upgraded.
xfce/thunar-volman-4.16.0-i586-1.txz: Upgraded.
xfce/tumbler-4.16.0-i586-1.txz: Upgraded.
xfce/xfce4-appfinder-4.16.0-i586-1.txz: Upgraded.
xfce/xfce4-clipman-plugin-1.6.1-i586-2.txz: Rebuilt.
xfce/xfce4-dev-tools-4.16.0-i586-1.txz: Upgraded.
xfce/xfce4-notifyd-0.6.2-i586-2.txz: Rebuilt.
xfce/xfce4-panel-4.16.0-i586-1.txz: Upgraded.
xfce/xfce4-panel-profiles-1.0.10-i586-2.txz: Rebuilt.
xfce/xfce4-power-manager-4.16.0-i586-1.txz: Upgraded.
xfce/xfce4-pulseaudio-plugin-0.4.3-i586-2.txz: Rebuilt.
xfce/xfce4-screensaver-0.1.11-i586-3.txz: Rebuilt.
xfce/xfce4-screenshooter-1.9.8-i586-1.txz: Upgraded.
xfce/xfce4-session-4.16.0-i586-1.txz: Upgraded.
xfce/xfce4-settings-4.16.0-i586-1.txz: Upgraded.
xfce/xfce4-systemload-plugin-1.2.4-i586-2.txz: Rebuilt.
xfce/xfce4-taskmanager-1.2.3-i586-2.txz: Rebuilt.
xfce/xfce4-terminal-0.8.10-i586-1.txz: Upgraded.
xfce/xfce4-weather-plugin-0.10.2-i586-2.txz: Rebuilt.
xfce/xfce4-whiskermenu-plugin-2.5.0-i586-1.txz: Upgraded.
xfce/xfconf-4.16.0-i586-1.txz: Upgraded.
xfce/xfdesktop-4.16.0-i586-1.txz: Upgraded.
xfce/xfwm4-4.16.0-i586-1.txz: Upgraded.
