Novu kartu nažalost ne vidi. Pošto imam dual boot na tom desktopu Slekvera i MW7, na MW7 je bilo isto stanje dok mu nisam našao drajver. Našao sam drajver i za Linuks, ali mi nikako ne polazi za rukom da ga instaliram.
Evo nekih izlaza koji će uglavnom da potvrde ovo iznad napisano, a i da vidimo kako bih mogao da instaliram taj famozni drajver.
Prvo drajver
http://support.asus.com/download.aspx?S ... 7wQUxUumGL" onclick="window.open(this.href);return false;
pa neki izlazi
root@broker:/home/brok# lsmod
Module Size Used by
pci_stub 961 1
vboxpci 15057 0
vboxnetadp 19239 0
vboxnetflt 16688 0
vboxdrv 221604 3 vboxnetflt,vboxnetadp,vboxpci
snd_seq_dummy 1119 0
snd_seq_oss 25020 0
snd_seq_midi_event 4568 1 snd_seq_oss
snd_seq 41624 5 snd_seq_midi_event,snd_seq_oss,snd_seq_dummy
snd_seq_device 4276 3 snd_seq,snd_seq_oss,snd_seq_dummy
snd_pcm_oss 33318 0
snd_mixer_oss 13144 1 snd_pcm_oss
ipv6 238973 20
lp 7119 0
ppdev 4710 0
parport_pc 16691 0
parport 26191 3 parport_pc,ppdev,lp
fuse 58347 11
usbhid 31213 0
hid 66141 1 usbhid
gspca_pac7302 8464 0
gspca_main 18624 1 gspca_pac7302
videodev 66935 1 gspca_main
snd_hda_codec_via 34399 1
nvidia 8494964 32
snd_hda_intel 19471 2
snd_hda_codec 70473 2 snd_hda_intel,snd_hda_codec_via
processor 22956 0
thermal_sys 12122 1 processor
sundance 18284 0
mii 3335 1 sundance
psmouse 54506 0
serio_raw 3349 0
snd_hwdep 4898 1 snd_hda_codec
snd_pcm 59244 3 snd_hda_codec,snd_hda_intel,snd_pcm_oss
snd_page_alloc 5893 2 snd_pcm,snd_hda_intel
snd_timer 14830 2 snd_pcm,snd_seq
snd 43944 15 snd_timer,snd_pcm,snd_hwdep,snd_hda_codec,snd_hda_intel,snd_hda_codec_via,snd_mixer_oss,snd_pcm_oss,snd_seq_device,snd_seq,snd_seq_oss
intel_agp 8712 0
intel_gtt 11603 1 intel_agp
agpgart 21927 2 intel_gtt,intel_agp
i2c_i801 7016 0
button 3633 0
evdev 7314 7
soundcore 4634 1 snd
asus_atk0110 8880 0
hwmon 1033 2 asus_atk0110,thermal_sys
i2c_core 16485 3 i2c_i801,nvidia,videodev
loop 14683 0
root@broker:/home/brok# lspci
00:00.0 Host bridge: Intel Corporation 82G33/G31/P35/P31 Express DRAM Controller (rev 10)
00:01.0 PCI bridge: Intel Corporation 82G33/G31/P35/P31 Express PCI Express Root Port (rev 10)
00:1b.0 Audio device: Intel Corporation N10/ICH 7 Family High Definition Audio Controller (rev 01)
00:1c.0 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 1 (rev 01)
00:1c.1 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 2 (rev 01)
00:1d.0 USB controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #1 (rev 01)
00:1d.1 USB controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #2 (rev 01)
00:1d.2 USB controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #3 (rev 01)
00:1d.3 USB controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #4 (rev 01)
00:1d.7 USB controller: Intel Corporation N10/ICH 7 Family USB2 EHCI Controller (rev 01)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev e1)
00:1f.0 ISA bridge: Intel Corporation 82801GB/GR (ICH7 Family) LPC Interface Bridge (rev 01)
00:1f.1 IDE interface: Intel Corporation 82801G (ICH7 Family) IDE Controller (rev 01)
00:1f.2 IDE interface: Intel Corporation N10/ICH7 Family SATA Controller [IDE mode] (rev 01)
00:1f.3 SMBus: Intel Corporation N10/ICH 7 Family SMBus Controller (rev 01)
01:00.0 VGA compatible controller: nVidia Corporation G94 [GeForce 9600 GT] (rev a1)
04:00.0 Ethernet controller: Sundance Technology Inc / IC Plus Corp IC Plus IP100A Integrated 10/100 Ethernet MAC + PHY (rev 31)
root@broker:/home/brok# lspci -v
Subsystem: ASUSTeK Computer Inc. P5KPL-VM Motherboard
Flags: bus master, fast devsel, latency 0
Capabilities: [e0] Vendor Specific Information: Len=0b <?>
00:01.0 PCI bridge: Intel Corporation 82G33/G31/P35/P31 Express PCI Express Root Port (rev 10) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000d000-0000dfff
Memory behind bridge: fa000000-feafffff
Prefetchable memory behind bridge: 00000000e0000000-00000000efffffff
Capabilities: [88] Subsystem: ASUSTeK Computer Inc. Device 82b0
Capabilities: [80] Power Management version 3
Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [a0] Express Root Port (Slot+), MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [140] Root Complex Link
Kernel driver in use: pcieport
Subsystem: ASUSTeK Computer Inc. Device 83a1
Flags: bus master, fast devsel, latency 0, IRQ 43
Memory at f9ffc000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [50] Power Management version 2
Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [130] Root Complex Link
Kernel driver in use: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 1 (rev 01) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 00002000-00002fff
Memory behind bridge: f4400000-f45fffff
Prefetchable memory behind bridge: 00000000f4600000-00000000f47fffff
Capabilities: [40] Express Root Port (Slot+), MSI 00
Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [90] Subsystem: ASUSTeK Computer Inc. Device 8179
Capabilities: [a0] Power Management version 2
Capabilities: [180] Root Complex Link
00:1c.1 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 2 (rev 01) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 00001000-00001fff
Memory behind bridge: f4000000-f41fffff
Prefetchable memory behind bridge: 00000000f4200000-00000000f43fffff
00:1d.0 USB controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #1 (rev 01) (prog-if 00 [UHCI])
Subsystem: ASUSTeK Computer Inc. P5KPL-VM,P5LD2-VM Mainboard
Flags: bus master, medium devsel, latency 0, IRQ 23
I/O ports at c480 [size=32]
Kernel driver in use: uhci_hcd
00:1d.1 USB controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #2 (rev 01) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 19
I/O ports at c800 [size=32]
00:1d.2 USB controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #3 (rev 01) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 18
I/O ports at c880 [size=32]
00:1d.3 USB controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #4 (rev 01) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 0, IRQ 16
I/O ports at cc00 [size=32]
00:1d.7 USB controller: Intel Corporation N10/ICH 7 Family USB2 EHCI Controller (rev 01) (prog-if 20 [EHCI])
Memory at f9ffbc00 (32-bit, non-prefetchable) [size=1K]
Capabilities: [58] Debug port: BAR=1 offset=00a0
Kernel driver in use: ehci_hcd
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev e1) (prog-if 01 [Subtractive decode])
Bus: primary=00, secondary=04, subordinate=04, sec-latency=32
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: feb00000-febfffff
Capabilities: [50] Subsystem: ASUSTeK Computer Inc. Device 8179
Capabilities: [e0] Vendor Specific Information: Len=0c <?>
00:1f.1 IDE interface: Intel Corporation 82801G (ICH7 Family) IDE Controller (rev 01) (prog-if 8a [Master SecP PriP])
I/O ports at 01f0 [size=8]
I/O ports at 03f4 [size=1]
I/O ports at 0170 [size=8]
I/O ports at 0374 [size=1]
I/O ports at ffa0 [size=16]
Kernel driver in use: ata_piix
00:1f.2 IDE interface: Intel Corporation N10/ICH7 Family SATA Controller [IDE mode] (rev 01) (prog-if 8f [Master SecP SecO PriP PriO])
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 19
I/O ports at c400 [size=8]
I/O ports at c080 [size=4]
I/O ports at c000 [size=8]
I/O ports at bc00 [size=4]
I/O ports at b880 [size=16]
Capabilities: [70] Power Management version 2
Flags: medium devsel, IRQ 19
I/O ports at 0400 [size=32]
Kernel driver in use: i801_smbus
01:00.0 VGA compatible controller: nVidia Corporation G94 [GeForce 9600 GT] (rev a1) (prog-if 00 [VGA controller])
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at fd000000 (32-bit, non-prefetchable) [size=16M]
Memory at e0000000 (64-bit, prefetchable) [size=256M]
Memory at fa000000 (64-bit, non-prefetchable) [size=32M]
I/O ports at dc00 [size=128]
[virtual] Expansion ROM at fea80000 [disabled] [size=512K]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [b4] Vendor Specific Information: Len=14 <?>
Capabilities: [128] Power Budgeting <?>
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Kernel driver in use: nvidia
Subsystem: Sundance Technology Inc / IC Plus Corp Device 0201
Flags: bus master, medium devsel, latency 64, IRQ 20
I/O ports at ec00 [size=128]
Memory at febffc00 (32-bit, non-prefetchable) [size=512]
Expansion ROM at febe0000 [disabled] [size=64K]
Kernel driver in use: sundance
root@broker:/home/brok# uname -a
Linux broker 3.2.45-smp #2 SMP Sat May 18 01:20:11 CDT 2013 i686 Intel(R) Core(TM)2 Duo CPU E7500 @ 2.93GHz GenuineIntel GNU/Linux
root@broker:/home/brok# ifconfig -a
eth1: flags=4098<BROADCAST,MULTICAST> mtu 1500
ether 10:bf:48:e7:65:33 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 20 base 0xec00
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 16436
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 0 (Local Loopback)
RX packets 340 bytes 17320 (16.9 KiB)
TX packets 340 bytes 17320 (16.9 KiB)
compat.h crc32.h ethtool.h Makefile mii.c mii.h nx1001_main.c readme.txt
ASUS NX1001 Network Adapter
Linux Driver
Contents:
1. File Description
2. Driver Installation for Linux
3. Driver Parameter
1. File Description
Filename Description
NX1001_main.c ASUS NX1001 Network Adapter Driver Source Code.
This file is the main part of ASUS NX1001 Network Adapter.
compat.h Network interface message level settings.
crc32.h Crc function for early Linux 2.4.19pre kernel inclusion
ethtool.h: Defines for Linux ethtool.
mii.h definitions for MII-compatible transceivers.
mii.c MII interface library.
makefile Make File For ASUS NX1001 Network Adapter.
Using "make all" for your kernel.
readme.txt A summary of the contents for Linux Driver.
This file, which you are reading me now.
a. for kernel 2.4.x
a1. Redhat 7.3 (linux kernel 2.4.18)
a2. Mandrake 8.1 (kernel 2.4.8)
b. for kernel 2.6.x
c. automatically load and configure at next boot time
a.for kernel 2.4.x
a1.1. install way 1:
#make all =>generate NX1001.o
#cp NX1001.o /lib/modules/2.4.18-3/kernel/drivers/net/
#insmod ./NX1001.o
#ifconfig eth0 xxx.xxx.xxx.xxx netmask yyy.yyy.yyy.yyy
eth0 is your network adapter,use "dmesg" to check it, ex: eth0, eth1...
xxx is your ip address, ex: 192.168.102.211
yyy is your netmask address, ex:255.255.255.0
a1.2. install way 2:
#insmod./NX1001.o
#setup
[network configuration] =>to setup your ip address
#ifup eth0
eth0 is your network adapter, ex: eth0, eth1...
#make all => generate Nx1001.o
#cp NX1001.o /lib/modules/2.4.8-26mdk/kernel/drivers/net
#insmod ./NX1001.o
b. for kernel 2.6.x
#make all => generate NX1001.ko
#insmod ./NX1001.ko (or NX1001.o)
c1. cp NX1001.o /lib/modules/`uname -r`/kernel/drivers/net
*note: The `uname -r` is a command. Don't replace `uname -r` with
2.4.18, 2.4.20smp, or some others. Must type `uname -r` directly.
c2. Add the following lines at /etc/modules.conf:
alias eth0 NX1001
options NX1001 <optional parameters>
c3. Run "netconfig" or "netconf" to create configuration script
ifcfg-eth0 located at /etc/sysconfig/network-scripts or
create it manually.
[see - Configuration Script Sample]
c4. Driver will automatically load and configure at
next boot time.
c5. Configuration Script Sample
Here is a sample of a simple configuration script:
DEVICE=eth0
USERCTL=no
ONBOOT=yes
POOTPROTO=none
BROADCAST=207.200.5.255
NETWORK=207.200.5.0
NETMASK=255.255.255.0
IPADDR=207.200.5.2
3. Driver Parameter
If you want to change the link speed, you could use parameter after
insmod command.
insmod NX1001.o <optional parameter> ; add parameter
example: insmod NX1001.o media=100mbps_hd
or insmod NX1001.o media=3
or insmod NX1001.o media=1,2,3,4 ; for 4 cards or NX1001
Parameter Description
You can install this driver without any addtional parameter. However, if
you are going to have extensive functions then it is necessary to set
extra parameter. Below is a list of the command line parameters supported
by the Linux device driver.
media=xxxxxxxxx - Specifies the media type the NIC operates at.
autosense Autosensing active media.
10mbps_hd 10Mbps half duplex.
10mbps_fd 10Mbps full duplex.
100mbps_hd 100Mbps half duplex.
100mbps_fd 100Mbps full duplex.
0 Autosensing active media.
1 10Mbps half duplex.
2 10Mbps full duplex.
3 100Mbps half duplex.
4 100Mbps full duplex.
By default, the copper devices operate at
autosense, the fiber devices operate at
Note that, the fiber adapter only support
100Mbps half/full duplex types.
If wanting to change speed, this driver needed to be unloaded and reloaded with
new media parameter.
flowctrl=[0|1] - Specifies the flow control function.
0 Disable flow control.
1 Enable flow control.
root@broker:/home/brok# cd Linux\ v1.20/
root@broker:/home/brok/Linux v1.20# ls
Makefile compat.h crc32.h ethtool.h generate mii.c mii.h nx1001_main.c readme.txt
root@broker:/home/brok/Linux v1.20# make all =>generate NX1001.o
make: *** empty variable name. Stop.
gcc -D__KERNEL__ -DMODULE -O -Wall -Wstrict-prototypes -I/usr/src/linux/include -DUSE_IO_OPS -D_COMPAT_WITH_OLD_KERNEL -c -o nx1001_main.o nx1001_main.c
In file included from /usr/src/linux/include/linux/kernel.h:13:0,
from /usr/src/linux/include/linux/cache.h:4,
from /usr/src/linux/include/linux/time.h:7,
from /usr/src/linux/include/linux/stat.h:60,
from /usr/src/linux/include/linux/module.h:10,
from nx1001_main.c:187:
/usr/src/linux/include/linux/linkage.h:5:25: fatal error: asm/linkage.h: No such file or directory
compilation terminated.
make: *** [nx1001_main.o] Error 1
root@broker:/home/brok/Linux v1.20# make all => generate NX1001.ko
root@broker:/home/brok/Linux v1.20# insmod ./NX1001.ko
Error: could not load module ./NX1001.ko: No such file or directory
root@broker:/home/brok/Linux v1.20# insmod ./NX1001.o
Error: could not load module ./NX1001.o: No such file or directory
root@broker:/home/brok/Linux v1.20# cp NX1001.o /lib/modules/`uname -r`/kernel/drivers/net
cp: cannot stat 'NX1001.o': No such file or directory
