ARCH=i686 ./mesa-compat32.Slackbuild
/usr/lib64/gcc/x86_64-slackware-linux/4.7.1/../../../../x86_64-slackware-linux/bin/ld: skipping incompatible /usr/lib64/libpthread.a when searching for -lpthread
ARCH=i484 ./mesa-compat32.Slackbuild
Creating llvm-compat32:
# convertpkg-compat32 -i llvm-VERSION-i486-BUILD.txz
# installpkg /tmp/llvm-compat32-VERSION-x86_64-BUILDcompat32.txz
Creating freeglut-compat32:
# convertpkg-compat32 -i freeglut-VERSION-i486-BUILD.txz
# installpkg /tmp/freeglut-compat32-VERSION-x86_64-BUILDcompat32.txz
/usr/lib64/gcc/x86_64-slackware-linux/4.7.1/../../../../x86_64-slackware-linux/bin/ld: skipping incompatible /usr/lib64/libXfixes.so when searching for -lXfixes
/usr/lib64/gcc/x86_64-slackware-linux/4.7.1/../../../../x86_64-slackware-linux/bin/ld: skipping incompatible /usr/lib64/libX11-xcb.so when searching for -lX11-xcb
/usr/lib64/gcc/x86_64-slackware-linux/4.7.1/../../../../x86_64-slackware-linux/bin/ld: skipping incompatible /usr/lib64/libX11.so when searching for -lX11
/usr/lib64/gcc/x86_64-slackware-linux/4.7.1/../../../../x86_64-slackware-linux/bin/ld: skipping incompatible /usr/lib64/libxcb-glx.so when searching for -lxcb-glx
/usr/lib64/gcc/x86_64-slackware-linux/4.7.1/../../../../x86_64-slackware-linux/bin/ld: skipping incompatible /usr/lib64/libxcb.so when searching for -lxcb
/usr/lib64/gcc/x86_64-slackware-linux/4.7.1/../../../../x86_64-slackware-linux/bin/ld: skipping incompatible /usr/lib64/libXxf86vm.so when searching for -lXxf86vm
/usr/lib64/gcc/x86_64-slackware-linux/4.7.1/../../../../x86_64-slackware-linux/bin/ld: skipping incompatible /usr/lib64/libdrm.so when searching for -ldrm
/usr/lib64/gcc/x86_64-slackware-linux/4.7.1/../../../../x86_64-slackware-linux/bin/ld: skipping incompatible /usr/lib64/libm.so when searching for -lm
/usr/lib64/gcc/x86_64-slackware-linux/4.7.1/../../../../x86_64-slackware-linux/bin/ld: skipping incompatible /usr/lib64/libm.a when searching for -lm
/usr/lib64/gcc/x86_64-slackware-linux/4.7.1/../../../../x86_64-slackware-linux/bin/ld: skipping incompatible /usr/lib64/libpthread.so when searching for -lpthread
collect2: error: ld returned 1 exit status
gmake[4]: *** [lp_test_format] Error 1
gmake[4]: Leaving directory `/tmp/bbsb/Mesa-8.0.4/src/gallium/drivers/llvmpipe'
gmake[3]: *** [default] Error 1
gmake[3]: Leaving directory `/tmp/bbsb/Mesa-8.0.4/src/gallium/drivers'
gmake[2]: *** [default] Error 1
gmake[2]: Leaving directory `/tmp/bbsb/Mesa-8.0.4/src/gallium'
make[1]: *** [subdirs] Error 1
make[1]: Leaving directory `/tmp/bbsb/Mesa-8.0.4/src'
make: *** [default] Error 1
root@brok4:/home/brok/Bumblebee-SlackBuilds/mesa#
ARCH=i486 \
. ./mesa.SlackBuild
ls -l /usr/lib/libX11-xcb.so
CFLAGS="$SLKCFLAGS" \
CXXFLAGS="$SLKCFLAGS" \
LDFLAGS="-L/usr/lib" \
./configure \
bash-4.2# ls -l /usr/lib/libX11-xcb.so
lrwxrwxrwx 1 root root 19 Aug 9 16:55 /usr/lib/libX11-xcb.so -> libX11-xcb.so.1.0.0
#!/bin/sh
. /etc/profile.d/32dev.sh
ARCH=i486 \
. ./mesa.SlackBuild
./configure \
TAG="_compat32" \
convertpkg-compat32 -i $OUTPUT/$PRGNAM-$VERSION-$ARCH-$BUILD$TAG.${PKGTYPE:-tgz}
./configure \
--prefix=/usr \
--sysconfdir=/etc \
--libdir=/usr/lib${LIBDIRSUFFIX} \
--mandir=/usr/man \
--docdir=/usr/doc/mesa-$VERSION \
--build=$ARCH-slackware-linux \
--with-dri-driverdir=/usr/lib${LIBDIRSUFFIX}/xorg/modules/dri \
--with-dri-drivers=i915,i965,nouveau,r200,radeon,swrast \
--with-gallium-drivers=nouveau,swrast,r300,r600 \
--enable-gallium-llvm \
--enable-shared-glapi
./configure \
--prefix=/usr \
--sysconfdir=/etc \
--mandir=/usr/man \
Ukljucen je PAE u kernelu, sto znaci da ce svaki programi moci koristiti do 4GB, dok ce ukupno moci da iskoriste svih 8GB. Primer kod mene:Broker wrote:Što se tiče 32-bit i 64-bit Slackvera, potpuno se slažem, ali ne znam da li bi mi video i koristio svih 8 gb RAM-a (odnosno 7.7 gb) na 32-bitnom Slekveru.
Imam 32-bit na desktopu gde imam 4 gb RAM-a, i vidi sva 4 gb takođe i koristi sva 4 gb, odnosno 3.9 gb RAM-a.
$ uname -a
Linux slack 3.9.7-smp #2 SMP Sat Jun 22 03:28:23 CDT 2013 i686 AMD Phenom(tm) II X4 955 Processor AuthenticAMD GNU/Linux
$ free
total used free shared buffers cached
Mem: 12457912 4785680 7672232 0 188976 2596244
-/+ buffers/cache: 2000460 10457452
Swap: 0 0 0
bash-4.2$ optirun glxgears
Running synchronized to the vertical refresh. The framerate should be
approximately the same as the monitor refresh rate.
349 frames in 5.3 seconds = 65.915 FPS
312 frames in 5.0 seconds = 62.400 FPS
308 frames in 5.3 seconds = 57.753 FPS
XIO: fatal IO error 11 (Resource temporarily unavailable) on X server ":0.0"
after 6095 requests (5849 known processed) with 0 events remaining.
bash-4.2$ primusrun glxgears
302 frames in 5.0 seconds = 60.269 FPS
301 frames in 5.0 seconds = 60.001 FPS
301 frames in 5.0 seconds = 60.003 FPS
primus: warning: dropping a frame to avoid deadlock
after 29 requests (29 known processed) with 0 events remaining.
primus: warning: timeout waiting for display worker
bash-4.2$
01:00.0 VGA compatible controller: nVidia Corporation GF108 [GeForce GT 540M] (rev a1) (prog-if 00 [VGA controller])
Subsystem: Dell Device 04ca
Flags: bus master, fast devsel, latency 0, IRQ 56
Memory at f5000000 (32-bit, non-prefetchable) [size=16M]
Memory at e0000000 (64-bit, prefetchable) [size=256M]
Memory at f0000000 (64-bit, prefetchable) [size=32M]
I/O ports at e000 [size=128]
[virtual] Expansion ROM at f6000000 [disabled] [size=512K]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [b4] Vendor Specific Information: Len=14 <?>
Capabilities: [100] Virtual Channel
Capabilities: [128] Power Budgeting <?>
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Kernel driver in use: nvidia
01:00.0 VGA compatible controller: nVidia Corporation GF108 [GeForce GT 540M] (rev ff) (prog-if ff)
!!! Unknown header type 7f
bash-4.2$ glxgears
302 frames in 5.0 seconds = 60.385 FPS
301 frames in 5.0 seconds = 60.002 FPS
after 3022 requests (3022 known processed) with 0 events remaining.
bash-4.2$
