Štampač: Lexmark E260 USB
OS: Slackware 14.0
Kernel: 3.2.29-smp
Cups: 1.5.4-i486-2
Blacklistovan modul usblp u /etc/modprobe.d/blacklist.conf
blacklist usblp
Module Size Used by
snd_seq_dummy 1119 0
snd_seq_oss 24956 0
snd_seq_midi_event 4568 1 snd_seq_oss
snd_seq 41599 5 snd_seq_midi_event,snd_seq_oss,snd_seq_dummy
snd_seq_device 4276 3 snd_seq,snd_seq_oss,snd_seq_dummy
snd_pcm_oss 33254 0
snd_mixer_oss 12984 3 snd_pcm_oss
ipv6 238549 32
lp 7119 0
ppdev 4710 0
parport_pc 16755 0
parport 26159 3 parport_pc,ppdev,lp
fuse 58282 3
snd_hda_codec_realtek 150654 1
nvidia 7040139 18
thermal 6587 0
snd_hda_intel 19503 8
snd_hda_codec 70505 2 snd_hda_intel,snd_hda_codec_realtek
snd_hwdep 4802 1 snd_hda_codec
snd_pcm 59013 4 snd_hda_codec,snd_hda_intel,snd_pcm_oss
snd_page_alloc 5925 2 snd_pcm,snd_hda_intel
processor 23020 0
agpgart 22087 1 nvidia
k10temp 2131 0
snd_timer 14798 3 snd_pcm,snd_seq
psmouse 54408 0
evdev 7314 5
button 3665 0
serio_raw 3349 0
forcedeth 47072 0
thermal_sys 12122 2 processor,thermal
i2c_nforce2 4512 0
hwmon 1033 2 thermal_sys,k10temp
i2c_core 16454 2 i2c_nforce2,nvidia
snd 43657 22 snd_timer,snd_pcm,snd_hwdep,snd_hda_codec,snd_hda_intel,snd_hda_codec_realtek,snd_mixer_oss,snd_pcm_oss,snd_seq_device,snd_seq,snd_seq_oss
soundcore 4570 3 snd
loop 14650 0
ATTR{idVendor}=="043d", ATTR{idProduct}=="0122", MODE:="0664", GROUP:="lp"
Bus 001 Device 002: ID 043d:0122 Lexmark International, Inc.
[ 1059.817392] usb 1-6: USB disconnect, device number 2
[ 1061.988040] usb 1-6: new high-speed USB device number 3 using ehci_hcd
[ 1062.102989] usb 1-6: New USB device found, idVendor=043d, idProduct=0122
[ 1062.102993] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1062.102995] usb 1-6: Product: Lexmark E260
[ 1062.102997] usb 1-6: Manufacturer: Lexmark International
[ 1062.102998] usb 1-6: SerialNumber: 72B53GR
Nov 13 10:22:21 Dragan105 kernel: [ 1061.988040] usb 1-6: new high-speed USB device number 3 using ehci_hcd
Nov 13 10:22:21 Dragan105 kernel: [ 1062.102989] usb 1-6: New USB device found, idVendor=043d, idProduct=0122
Nov 13 10:22:21 Dragan105 kernel: [ 1062.102993] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Nov 13 10:22:21 Dragan105 kernel: [ 1062.102995] usb 1-6: Product: Lexmark E260
Nov 13 10:22:21 Dragan105 kernel: [ 1062.102997] usb 1-6: Manufacturer: Lexmark International
Nov 13 10:22:21 Dragan105 kernel: [ 1062.102998] usb 1-6: SerialNumber: 72B53GR
Nov 13 10:22:21 Dragan105 mtp-probe: checking bus 1, device 3: "/sys/devices/pci0000:00/0000:00:02.1/usb1/1-6"
Nov 13 10:22:21 Dragan105 mtp-probe: bus: 1, device: 3 was not an MTP device
DEBUG: list_devices
DEBUG: libusb_get_device_list=3
DEBUG2: Printer found with device ID: MANUFACTURER:Lexmark International;COMMAND SET:PCL 6 Emulation, PostScript Level 3 Emulation, NPAP, PJL;MODEL:Lexmark E260;CLS:PRINTER;DES:Lexmark E260;CID:Lexmark_Internationa4B5D, Lexmark_Internationa4BAD, Lexmark_Internationa9D12, Lexmark_InternationaCC02;COMMENT:ECP1.0, LV_043D, LP_0122, LF_0050; Device URI: usb://Lexmark/E260?serial=72B53GR
direct usb://Lexmark/E260?serial=72B53GR "Lexmark Lexmark E260" "Lexmark Lexmark E260" "MANUFACTURER:Lexmark International;COMMAND SET:PCL 6 Emulation, PostScript Level 3 Emulation, NPAP, PJL;MODEL:Lexmark E260;CLS:PRINTER;DES:Lexmark E260;CID:Lexmark_Internationa4B5D, Lexmark_Internationa4BAD, Lexmark_Internationa9D12, Lexmark_InternationaCC02;COMMENT:ECP1.0, LV_043D, LP_0122, LF_0050;" ""
lpinfo -v
network lpd
network socket
network ipp
network http
network ipps
network https
direct hp
network smb
network beh
direct hpfax
ldconfig -p | grep libcups
libcupsppdc.so.1 (libc6) => /usr/lib/libcupsppdc.so.1
libcupsppdc.so (libc6) => /usr/lib/libcupsppdc.so
libcupsmime.so.1 (libc6) => /usr/lib/libcupsmime.so.1
libcupsmime.so (libc6) => /usr/lib/libcupsmime.so
libcupsimage.so.2 (libc6) => /usr/lib/libcupsimage.so.2
libcupsimage.so (libc6) => /usr/lib/libcupsimage.so
libcupsdriver.so.1 (libc6) => /usr/lib/libcupsdriver.so.1
libcupsdriver.so (libc6) => /usr/lib/libcupsdriver.so
libcupscgi.so.1 (libc6) => /usr/lib/libcupscgi.so.1
libcupscgi.so (libc6) => /usr/lib/libcupscgi.so
libcups.so.2 (libc6) => /usr/lib/libcups.so.2
libcups.so (libc6) => /usr/lib/libcups.so
lpstat -p -d
printer CLP-300splc is idle. enabled since Wed 13 Nov 2013 10:05:16 AM CET
printer HP1020_Srba is idle. enabled since Wed 13 Nov 2013 10:05:09 AM CET
printer HP1020_Zorica109 is idle. enabled since Wed 13 Nov 2013 10:05:09 AM CET
printer HPLasJet1150 is idle. enabled since Wed 13 Nov 2013 10:05:20 AM CET
printer LexmarkE260 is idle. enabled since Wed 13 Nov 2013 09:33:56 AM CET
printer Samsung1910 is idle. enabled since Wed 13 Nov 2013 10:05:17 AM CET
printer SCX-3400-Series is idle. enabled since Wed 13 Nov 2013 10:05:09 AM CET
printer SCX3400F is idle. enabled since Wed 13 Nov 2013 10:05:09 AM CET
system default destination: SCX3400F
lpstat -p -d
printer LexmarkE260 now printing LexmarkE260-151. enabled since Wed 13 Nov 2013 10:45:03 AM CET
Waiting for printer to become available.
Znači sistem vidi i reaguje na priključivanje / isključivanje štampača, ali nemam način da ga "upoznam" sa CUPS-om. Probao sam i sa instalacijom prethodne verzije (cups-1.4.6-i486-1 za 13.37) ali je to naravno prebilo KDE-ov alat za podešavanje štampača.
Ko je ovde lud, koliko i zašto, ne znam, ali ako ne rešim problem štampanja (koji je na žalost sve veći i veći iz verzije u verziju), bit će vrlo čupavo
