Recimo za pango:
Can't locate Cairo.pm
A zatim si uspešno instalirao Cairo (poslednji kod blok).
Za Gtk2::ImageView ti treba gtkimageview, imas na SBo. Posle toga trazi Gnome2 modul, a za to treba Gnome2::VFS, koji se ne moze instalirati bez gnome-vfs, koji isto zahteva 3-4 paketa...Broker wrote:Tuje obavezan i perl-gtk2-imageview kojeg isto ne mogu/ne znam da instaliram.
Ja sam upravo uspeo oba bez tog notest-a.bocke wrote:Osim za gtk. Za instalaciju Gtk je potrebno navesti notest klauzulu. Gtk2::TrayIcon test puca.
Building perl-gnome2-gconf
perl-gnome2-gconf:
Found Gnome2-GConf-1.044.tar.gz in /var/cache/sbopkg.
Checking MD5SUM:
MD5SUM check for Gnome2-GConf-1.044.tar.gz ... OK
Building package for perl-gnome2-gconf...
Gnome2-GConf-1.044/
Gnome2-GConf-1.044/gconfperl.h
Gnome2-GConf-1.044/examples/
Gnome2-GConf-1.044/examples/simple-view.pl
Gnome2-GConf-1.044/examples/simple-controller.pl
Gnome2-GConf-1.044/examples/error.pl
Gnome2-GConf-1.044/examples/basic-gconf-app.pl
Gnome2-GConf-1.044/examples/complex-gconf-app.pl
Gnome2-GConf-1.044/maps
Gnome2-GConf-1.044/xs/
Gnome2-GConf-1.044/xs/GConfClient.xs
Gnome2-GConf-1.044/xs/GConfSchema.xs
Gnome2-GConf-1.044/xs/GConfEngine.xs
Gnome2-GConf-1.044/xs/GConfChangeSet.xs
Gnome2-GConf-1.044/xs/GConfEntry.xs
Gnome2-GConf-1.044/xs/GConfValue.xs
Gnome2-GConf-1.044/xs/GConf2.xs
Gnome2-GConf-1.044/MANIFEST
Gnome2-GConf-1.044/GConf.pm
Gnome2-GConf-1.044/MANIFEST.SKIP
Gnome2-GConf-1.044/genmaps.pl
Gnome2-GConf-1.044/gconf.typemap
Gnome2-GConf-1.044/META.yml
Gnome2-GConf-1.044/AUTHOR
Gnome2-GConf-1.044/perl-Gnome2-GConf.spec.in
Gnome2-GConf-1.044/copyright.pod
Gnome2-GConf-1.044/t/
Gnome2-GConf-1.044/t/00.GConf.t
Gnome2-GConf-1.044/ChangeLog
Gnome2-GConf-1.044/NEWS
Gnome2-GConf-1.044/doctypes
Gnome2-GConf-1.044/README
Gnome2-GConf-1.044/Makefile.PL
Including generated API documentation...
Checking if your kit is complete...
Looks good
Unrecognized argument in LIBS ignored: '-pthread'
Writing Makefile for Gnome2::GConf
Writing MYMETA.yml and MYMETA.json
cp build/IFiles.pm blib/arch/Gnome2/GConf/Install/Files.pm
cp GConf.pm blib/lib/Gnome2/GConf.pm
cp /tmp/SBo/Gnome2-GConf-1.044/build/gconfperl.typemap blib/arch/Gnome2/GConf/Install/gconfperl.typemap
cp gconfperl.h blib/arch/Gnome2/GConf/Install/gconfperl.h
cp doctypes blib/arch/Gnome2/GConf/Install/doctypes
cp build/gconfperl-version.h blib/arch/Gnome2/GConf/Install/gconfperl-version.h
cp /tmp/SBo/Gnome2-GConf-1.044/gconf.typemap blib/arch/Gnome2/GConf/Install/gconf.typemap
cp build/gconfperl-autogen.h blib/arch/Gnome2/GConf/Install/gconfperl-autogen.h
[ XS xs/GConf2.xs ]
[ CC xs/GConf2.c ]
[ XS xs/GConfChangeSet.xs ]
[ CC xs/GConfChangeSet.c ]
[ XS xs/GConfClient.xs ]
[ CC xs/GConfClient.c ]
[ XS xs/GConfEngine.xs ]
[ CC xs/GConfEngine.c ]
[ XS xs/GConfEntry.xs ]
[ CC xs/GConfEntry.c ]
[ XS xs/GConfSchema.xs ]
[ CC xs/GConfSchema.c ]
[ XS xs/GConfValue.xs ]
[ CC xs/GConfValue.c ]
Running Mkbootstrap for Gnome2::GConf ()
chmod 644 GConf.bs
rm -f blib/arch/auto/Gnome2/GConf/GConf.so
[ LD blib/arch/auto/Gnome2/GConf/GConf.so ]
chmod 755 blib/arch/auto/Gnome2/GConf/GConf.so
cp GConf.bs blib/arch/auto/Gnome2/GConf/GConf.bs
chmod 644 blib/arch/auto/Gnome2/GConf/GConf.bs
Parsing XS files...
Generating POD...
Loaded 5 extra types from doctypes
Loaded 8 extra types from /usr/lib/perl5/vendor_perl/5.12.3/i486-linux-thread-multi/Glib/Install/doctypes
Creating POD index...
Manifying blib/man3/Gnome2::GConf::Value.3
Manifying blib/man3/Gnome2::GConf::Schema.3
Manifying blib/man3/Gnome2::GConf::main.3
Manifying blib/man3/Gnome2::GConf::Engine.3
Manifying blib/man3/Gnome2::GConf.3
Manifying blib/man3/Gnome2::GConf::index.3
Manifying blib/man3/Gnome2::GConf::Entry.3
Manifying blib/man3/Gnome2::GConf::Client.3
Manifying blib/man3/Gnome2::GConf::version.3
Manifying blib/man3/Gnome2::GConf::ChangeSet.3
PERL_DL_NONLAZY=1 /usr/bin/perl5.12.3 "-MExtUtils::Command::MM" "-e" "test_harness(0, 'blib/lib', 'blib/arch')" t/*.t
Failed to contact configuration server; the most common cause is a missing or misconfigured D-Bus session bus daemon. See http://projects.gnome.org/gconf/ for information. (Details - 1: Failed to get connection to session: The connection is closed) at t/00.GConf.t line 31.
# Looks like you planned 11 tests but ran 3.
# Looks like your test exited with 255 just after 3.
t/00.GConf.t ..
Dubious, test returned 255 (wstat 65280, 0xff00)
Failed 8/11 subtests
Test Summary Report
t/00.GConf.t (Wstat: 65280 Tests: 3 Failed: 0)
Non-zero exit status: 255
Parse errors: Bad plan. You planned 11 tests but ran 3.
Files=1, Tests=3, 1 wallclock secs ( 0.02 usr 0.00 sys + 0.02 cusr 0.00 csys = 0.04 CPU)
Result: FAIL
Failed 1/1 test programs. 0/3 subtests failed.
make: *** [test_dynamic] Error 255
perl-gnome2-gconf:
Would you like to continue processing the rest of the
build queue or would you like to abort? If this failed
package is a dependency of another package in the queue
then it may not make sense to continue.
(Y)es to continue, (N)o to abort, (R)etry the build?:
bash-4.1# perl Makefile.PL
Looks good
bash-4.1# make
cp /home/brok/Gnome2-GConf-1.044/build/gconfperl.typemap blib/arch/Gnome2/GConf/Install/gconfperl.typemap
cp /home/brok/Gnome2-GConf-1.044/gconf.typemap blib/arch/Gnome2/GConf/Install/gconf.typemap
[ XS xs/GConf2.xs ]
[ CC xs/GConf2.c ]
chmod 644 GConf.bs
Parsing XS files...
Generating POD...
bash-4.1# make test
t/00.GConf.t .. 1/11 Failed to contact configuration server; the most common cause is a missing or misconfigured D-Bus session bus daemon. See http://projects.gnome.org/gconf/ for information. (Details - 1: Failed to get connection to session: The connection is closed) at t/00.GConf.t line 31.
t/00.GConf.t .. Dubious, test returned 255 (wstat 65280, 0xff00)
Test Summary Report
Files=1, Tests=3, 0 wallclock secs ( 0.02 usr 0.00 sys + 0.02 cusr 0.00 csys = 0.04 CPU)
Result: FAIL
bash-4.1# make install
Files found in blib/arch: installing files in blib/lib into architecture dependent library tree
Installing /usr/lib/perl5/site_perl/5.12.3/i486-linux-thread-multi/Gnome2/GConf/Install/gconfperl.typemap
Installing /usr/lib/perl5/site_perl/5.12.3/i486-linux-thread-multi/Gnome2/GConf/Install/gconfperl-version.h
Installing /usr/lib/perl5/site_perl/5.12.3/i486-linux-thread-multi/Gnome2/GConf/Install/gconfperl-autogen.h
Installing /usr/lib/perl5/site_perl/5.12.3/i486-linux-thread-multi/Gnome2/GConf/Install/Files.pm
Installing /usr/lib/perl5/site_perl/5.12.3/i486-linux-thread-multi/Gnome2/GConf/Install/gconf.typemap
Installing /usr/lib/perl5/site_perl/5.12.3/i486-linux-thread-multi/Gnome2/GConf/Install/gconfperl.h
Installing /usr/lib/perl5/site_perl/5.12.3/i486-linux-thread-multi/Gnome2/GConf/Install/doctypes
Installing /usr/lib/perl5/site_perl/5.12.3/i486-linux-thread-multi/auto/Gnome2/GConf/GConf.so
Installing /usr/lib/perl5/site_perl/5.12.3/i486-linux-thread-multi/auto/Gnome2/GConf/GConf.bs
Installing /usr/lib/perl5/site_perl/5.12.3/i486-linux-thread-multi/Gnome2/GConf.pm
Installing /usr/lib/perl5/site_perl/5.12.3/i486-linux-thread-multi/Gnome2/GConf/Value.pod
Installing /usr/lib/perl5/site_perl/5.12.3/i486-linux-thread-multi/Gnome2/GConf/index.pod
Installing /usr/lib/perl5/site_perl/5.12.3/i486-linux-thread-multi/Gnome2/GConf/Entry.pod
Installing /usr/lib/perl5/site_perl/5.12.3/i486-linux-thread-multi/Gnome2/GConf/ChangeSet.pod
Installing /usr/lib/perl5/site_perl/5.12.3/i486-linux-thread-multi/Gnome2/GConf/Schema.pod
Installing /usr/lib/perl5/site_perl/5.12.3/i486-linux-thread-multi/Gnome2/GConf/Engine.pod
Installing /usr/lib/perl5/site_perl/5.12.3/i486-linux-thread-multi/Gnome2/GConf/version.pod
Installing /usr/lib/perl5/site_perl/5.12.3/i486-linux-thread-multi/Gnome2/GConf/main.pod
Installing /usr/lib/perl5/site_perl/5.12.3/i486-linux-thread-multi/Gnome2/GConf/Client.pod
Installing /usr/share/man/man3/Gnome2::GConf::version.3
Installing /usr/share/man/man3/Gnome2::GConf::Client.3
Installing /usr/share/man/man3/Gnome2::GConf::index.3
Installing /usr/share/man/man3/Gnome2::GConf::Engine.3
Installing /usr/share/man/man3/Gnome2::GConf::Value.3
Installing /usr/share/man/man3/Gnome2::GConf::Schema.3
Installing /usr/share/man/man3/Gnome2::GConf::Entry.3
Installing /usr/share/man/man3/Gnome2::GConf::main.3
Installing /usr/share/man/man3/Gnome2::GConf::ChangeSet.3
Installing /usr/share/man/man3/Gnome2::GConf.3
Appending installation info to /usr/lib/perl5/5.12.3/i486-linux-thread-multi/perllocal.pod
slackpkg install GConf
bash: cd: /extra/google-chrome: No such file or directory
bash-4.1$ cd /extra
bash: cd: /extra: No such file or directory
bash-4.1$ su
Password:
bash-4.1# slackpkg install GConf
Looking for GConf in package list. Please wait... DONE
No packages match the pattern for install. Try:
/usr/sbin/slackpkg reinstall|upgrade
@brokbocke wrote:Imaš još jednu zavisnost: GConf. Nalazi se u /extra/google-chrome. Ili ga instaliraj pomoću slackpkg:
Vidim po netu da ta greška može biti rezultat različitih "uzroka". Jedan od njih bi bio i pokretanje gconfa kao root. Ali ako je to u pitanju... Treba nam root da bismo instalirali GConf modul. Pa je malo cirkularan problem.Failed to contact configuration server; the most common cause is a missing or misconfigured D-Bus session bus daemon. See http://projects.gnome.org/gconf/ for information. (Details - 1: Failed to get connection to session: The connection is closed)
Users browsing this forum: No registered users and 39 guests
