Moderators: Slackmuz, Urednik
Napisano: 04 Jul 2012, 15:35
Prateći uputstva iz
1. posta, zapeo sam na 6. koraku. Točnije, kad kucam "make -j 3 all"
izbaci mi ovo:
fs/built-in.o: In function `gfs2_lock':
file.c:(.text+0x3a04a0): undefined reference to `dlm_posix_lock'
file.c:(.text+0x3a0503): undefined reference to `dlm_posix_get'
file.c:(.text+0x3a0533): undefined reference to `dlm_posix_unlock'
fs/built-in.o: In function `gdlm_cancel':
lock_dlm.c:(.text+0x3b2b1d): undefined reference to `dlm_unlock'
fs/built-in.o: In function `gdlm_lock':
lock_dlm.c:(.text+0x3b2d72): undefined reference to `dlm_lock'
fs/built-in.o: In function `gdlm_unmount':
lock_dlm.c:(.text+0x3b3435): undefined reference to `dlm_release_lockspace'
fs/built-in.o: In function `control_unlock':
lock_dlm.c:(.text+0x3b35e1): undefined reference to `dlm_unlock'
fs/built-in.o: In function `sync_lock':
lock_dlm.c:(.text+0x3b3752): undefined reference to `dlm_lock'
fs/built-in.o: In function `gdlm_put_lock':
lock_dlm.c:(.text+0x3b4080): undefined reference to `dlm_unlock'
fs/built-in.o: In function `gdlm_mount':
lock_dlm.c:(.text+0x3b43cd): undefined reference to `dlm_new_lockspace'
lock_dlm.c:(.text+0x3b46a1): undefined reference to `dlm_unlock'
lock_dlm.c:(.text+0x3b4822): undefined reference to `dlm_release_lockspace'
make: *** [.tmp_vmlinux1] Error 1
Pomoć poželjna
Napisano: 04 Jul 2012, 16:01
trenutno je u tijeku jedan pokušaj, poslije ću, ako ovaj ne prođe, probati točno po ovim uputama. hvala
Napisano: 04 Jul 2012, 17:11
hmmm, sve prođe, ali me poslije boota u 2.6.37-smp, a ne u novi...
Napisano: 04 Jul 2012, 20:21
Napiši nam tačnu verziju novog kernela. Takođe, daj nam izlaz sledeće komande:
Stavi i
/etc/lilo.conf. U slučaju da koristiš GRUB, stavi nam njegovu konf. datoteku. Vjerovatno si preskočio neki korak ili je stvarno nešto zakazalo.
Napisano: 04 Jul 2012, 23:01
kernel: 2.6.37.6-smp
bash-4.1# ls - l /boot
ls: cannot access -: No such file or directory
ls: cannot access l: No such file or directory
/boot:
README.initrd config-generic-2.6.37.6
System.map config-huge-smp-2.6.37.6-smp
System.map-3.4.4 diag1.img
System.map-generic-2.6.37.6 diag2.img
System.map-huge-smp-2.6.37.6-smp map
boot.0800 vmlinuz-generic-2.6.37.6
boot_message.txt vmlinuz-huge-smp-2.6.37.6-smp
config vmlinuz.old
config-3.4.4
bash-4.1#
Napisano: 04 Jul 2012, 23:15
Izvini, ja sam napravio grešku : "-" i "l" trebaju biti spojeni.
Bitno je da vidim simboličke linkove... Novi kernel tj. onaj koji kompajliraš je 3.4.4. Samo mi još napiši da li si ispratio korak br. 6 uključujući i onu komandu "make install"? Nemoj zaboraviti staviti nam konf. datoteku od Lilo-a, odnosno Grub-a (zavisno od toga šta koristiš).
Napisano: 04 Jul 2012, 23:21
bash-4.1# ls -l /boot
total 12180
lrwxrwxrwx 1 root root 37 Jun 6 19:03 README.initrd -> /usr/doc/mkinitrd-1.4.6/README.initrd
lrwxrwxrwx 1 root root 22 Jul 4 23:12 System.map -> /boot/System.map-3.4.4
lrwxrwxrwx 1 root root 22 Jul 4 17:20 System.map-3.4.4 -> /boot/System.map-3.4.4
-rw-r--r-- 1 root root 1381598 Apr 10 2011 System.map-generic-2.6.37.6
-rw-r--r-- 1 root root 2169190 Apr 10 2011 System.map-huge-smp-2.6.37.6-smp
lrwxrwxrwx 1 root root 32 Jun 6 19:02 System.old -> System.map-huge-smp-2.6.37.6-smp
-rw-r--r-- 1 root root 512 Jun 6 19:33 boot.0800
-rw-r--r-- 1 root root 168 Jun 6 19:33 boot_message.txt
lrwxrwxrwx 1 root root 18 Jul 4 23:13 config -> /boot/config-3.4.4
-rw-r--r-- 1 root root 125768 Jul 4 23:12 config-3.4.4
-rw-r--r-- 1 root root 117045 Apr 10 2011 config-generic-2.6.37.6
-rw-r--r-- 1 root root 117494 Apr 10 2011 config-huge-smp-2.6.37.6-smp
-rw-r--r-- 1 root root 5040 Mar 27 2011 diag1.img
-rw-r--r-- 1 root root 17932 Mar 27 2011 diag2.img
-rw------- 1 root root 86016 Jul 4 23:13 map
lrwxrwxrwx 1 root root 19 Jul 4 23:07 vmlinuz -> /boot/vmlinuz-3.4.4
lrwxrwxrwx 1 root root 29 Jun 6 19:02 vmlinuz-3.4.4 -> vmlinuz-huge-smp-2.6.37.6-smp
-rw-r--r-- 1 root root 2687280 Apr 10 2011 vmlinuz-generic-2.6.37.6
-rw-r--r-- 1 root root 5719840 Apr 10 2011 vmlinuz-huge-smp-2.6.37.6-smp
bash-4.1#
Ispratio sam 6. korak
bash-4.1$ cat /etc/lilo.conf
# LILO configuration file
# generated by 'liloconfig'
# Start LILO global section
append=" vt.default_utf8=0"
boot = /dev/sda
# Boot BMP Image.
bitmap = /boot/slack.bmp
bmp-table = 60,6,1,16
bmp-timer = 65,27,0,255
# Standard menu.
# first entry immediately):
prompt
timeout = 1200
change-rules
reset
# Normal VGA console
vga = normal
#vga = ask
#vga=791
#vga=790
#vga=773
#vga=788
#vga=787
#vga=771
#vga=785
#vga=784
#vga=769
# End LILO global section
image = /boot/vmlinuz
root = /dev/sda4
label = Linux
read-only
bash-4.1$
Napisano: 04 Jul 2012, 23:25
ideja je da želim preko Debianovog gruba bootat sustave
Napisano: 04 Jul 2012, 23:52
Problem je u sledećem:
U prvom slučaju (System.map) - System.map je simbolički link na System.map-3.4.4, koji je opet link na samog sebe. Da stvar bude još gora - vmlinuz je simbolički link na vmlinuz-3.4.4 koji je simbolički link na kernel image starog kernela (2.6.37.6).
Kako se to desilo, stvarno ne znam...
Ranije sam u temi spominjao da ja volim "ručno" odraditi taj 6. korak i ništa ne prepustiti slučaju. Pogledaj ovaj
odgovor. Podrazumijeva se da ti je trenutni direktorijum /usr/src/linux (koji je simbolički link i trebao bi pokazivati na kernel source 3.4.4; provjeri sa "ls -l /usr/src/").
Users browsing this forum: No registered users and 33 guests
