Moderators: Slackmuz, Urednik
Povremen korisnik
Napisano: 21 Dec 2012, 15:10
@bocke
Evo izlaza:
bash-4.2# lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 002: ID 18ec:3299 Arkmicro Technologies Inc.
Bus 001 Device 003: ID 148f:3070 Ralink Technology, Corp. RT2870/RT3070 Wireless Adapter
bash-4.2# lsusb -t
/: Bus 07.Port 1: Dev 1, Class=root_hub, Driver=ohci_hcd/2p, 12M
/: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=ohci_hcd/3p, 12M
/: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=ohci_hcd/3p, 12M
/: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ohci_hcd/3p, 12M
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ohci_hcd/3p, 12M
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci_hcd/6p, 480M
|__ Port 2: Dev 2, If 0, Class=Mass Storage, Driver=usb-storage, 480M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci_hcd/6p, 480M
|__ Port 3: Dev 3, If 0, Class=Vendor Specific Class, Driver=rt2800usb, 480M
bash-4.2#
@drummer
Pa sta ces ja rekoh "pa gde brze odgovore"
Napisano: 21 Dec 2012, 16:36
Šta je izlaz:
Malo te propitkujem da bismo videli šta je konkretno u pitanju.
Povremen korisnik
Napisano: 21 Dec 2012, 21:25
Ok, evo izlaza:
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
Pisao sam rucno pa se mozda podkrade greska
Napisano: 22 Dec 2012, 10:44
Hajde da probamo ovako:
slackpkg install wicd
/etc/rc.d/rc.wicd start
Zatim pokreni program wicd-gtk iz "Run" dijaloga desktop okruženja (obično je prečica sa tastature alt+f2, iako nisam siguran za kde).
Pokrenuće se wicd program. Ako je sve ok, on će automatski prepoznati dostupne wireless uređaje u tvojoj okolini.
Povremen korisnik
Napisano: 23 Dec 2012, 10:23
Evo sta se desi:
bash-4.2# su
bash-4.2# slackpkg install wicd
This appears to be the first time you have run slackpkg.
Before you install|upgrade|reinstall anything, you need to uncomment
ONE mirror in /etc/slackpkg/mirrors and run:
# slackpkg update
You can see more information about slackpkg functions in slackpkg manpage.
bash-4.2# /etc/rc.d/rc. wicd start
bash: /etc/rc.d/rc.: No such file or directory
bash-4.2#
Napisano: 23 Dec 2012, 11:02
Да, мораш прво да активираш једно огледало (mirror) у /etc/slapkg/mirrors фајлу. Треба да избришеш коментар (знак тарабице - #) испред жељеног огледала и да сачуваш измене. То мораш да одрадиш као root.
До скоро је белгијско огледало било нешто недоступно, па сам се ја пребацио на бугарско. Ти сад види, ако се јави још неко са неким предлогом, па одлучи.
Povremen korisnik
Napisano: 23 Dec 2012, 13:26
Probao sam to kad sam procitao sta pise, ali kaze da nepostoji /etc/slackpkg/mirrors , pa sam mislio da sam lose otkucao pa sam copy-paste ali nista , kaze da nepostoji ....
Napisano: 23 Dec 2012, 14:02
Komanda je:
Kao što je kolega već rekao samo izbrišeš # (tarabu) ispred linka po izboru. Ja koristim
ftp://ftp.osuosl.org/.2/slackware/slackware64-14.0/" onclick="window.open(this.href);return false;
Nano je tekst editor koji služi za obradu teksta u terminalu. Naravno ovo se radi kao root.
Povremen korisnik
Napisano: 23 Dec 2012, 17:28
Uzeo sam francuski http i evo sta se desilo:
bash-4.2# nano /etc/slackpkg/mirrors
The package list is missing.
Before you install|upgrade|reinstall anything you need to run:
# slackpkg update
bash-4.2# slackpkg update
Downloading http://mirror.ovh.net/mirrors/ftp.slackware.com/slackware-14.0/GPG-KEY...
--2012-12-23 17:24:50-- http://mirror.ovh.net/mirrors/ftp.slackware.com/slackware-14.0/GPG-KEY
Resolving mirror.ovh.net (mirror.ovh.net)... failed: Temporary failure in name resolution.
wget: unable to resolve host address 'mirror.ovh.net'
Updating the package lists...
Downloading...
Downloading http://mirror.ovh.net/mirrors/ftp.slackware.com/slackware-14.0/ChangeLog.txt...
--2012-12-23 17:24:50-- http://mirror.ovh.net/mirrors/ftp.slackware.com/slackware-14.0/ChangeLog.txt
Error downloading from http://mirror.ovh.net/mirrors/ftp.slackware.com/slackware-14.0/.
Please, check your mirror and try again.
Povremen korisnik
Napisano: 23 Dec 2012, 17:30
Pokusavao sam i sa srpskim, danskim, poljskim ali isto...
