Post Napisano: 09 Aug 2014, 18:33
Resen problem,pratio sam korake koje je napisao @stereo,malko sam nesto modifikovao ali radi.
Pokrenuo sam #mkinitrd
# mkinitrd -c -k 3.10.17 -m ehci-hcd:ohci-hcd:uhci-hcd:usb-storage:ehci-pci -f ext4 -o /boot/initrd.gz -r /dev/sdb
# lilo
Umesto id diska isam sam standardno /dev/sdb
A ovako izgleda moj fstab i lilo.conf
Lilo
# LILO configuration file
# generated by 'liloconfig'
# Start LILO global section
boot = /dev/sdb
#compact        # faster, but won't work on all systems.
# Boot BMP Image.
  bitmap = /boot/slack.bmp
# be used.  We don't specify it here, as there's just one column.
  bmp-table = 60,6,1,16
  bmp-timer = 65,27,0,255
# Standard menu.
append=" vt.default_utf8=0"
prompt
timeout = 300
# Normal VGA console
vga = normal
#vga = ask
# vga=791
# vga=790
# vga=773
# vga=788
# vga=787
# vga=771
# vga=785
# vga=784
# vga=769
# ramdisk = 0     # paranoia setting
# End LILO global section
image = /boot/vmlinuz
  root = "UUID=7fb7238d-f6dc-4ac9-8565-a4c7f688f019"
  initrd = /boot/initrd.gz
  append = "rootdelay=30"
  label = WD
  read-only  # Partitions should be mounted read-only for checking
Fstab
UUID=1a1e56bd-683c-4bd0-a069-b8b82d219f0a        swap             swap        defaults         0   0
UUID=7fb7238d-f6dc-4ac9-8565-a4c7f688f019        /                ext4        defaults         1   1
UUID=39f63b4c-0661-436c-91b2-a7a6a75e861a        /home            ext4        defaults         1   2
#/dev/cdrom      /mnt/cdrom       auto        noauto,owner,ro,comment=x-gvfs-show 0   0
/dev/fd0         /mnt/floppy      auto        noauto,owner     0   0
devpts           /dev/pts         devpts      gid=5,mode=620   0   0
proc             /proc            proc        defaults         0   0
tmpfs            /dev/shm         tmpfs       defaults         0   0
Nakon reboot-a eto meni radosti.
HVALA SVIMA KOJI SU UCESTVOVALI U RESAVANJU MOG PROBLEMA A POSEBNE ZASLUGE IMA @STEREO
JOS JEDNOM HVALA I IDEMO DALJE
POZDRAV
Post Napisano: 09 Aug 2014, 18:46
Nešto mi se čini da će tu biti još nekih podešavanja :D
u svakom slučaju kad skockaš sistem javi kako radi.
Post Napisano: 09 Aug 2014, 18:55
Sad mi ostaje jos jedna stavka da ubacim u sektor boot u lilo.conf, id diska i ....
Post Napisano: 10 Aug 2014, 15:18
@Stereo: još samo jedan info i možeš lagano da skupiš tih nekoliko postova u kraći tutorijal. :) Da li je initrd potreban i za "huge" kernel?
Post Napisano: 10 Aug 2014, 17:13
Da dodam,izmenio sam sledece stavke kao sto je @stereo postovao u ovom delu lilo.conf i dodao id usb diska
#boot = /dev/sdb
boot = /dev/disk/by-id/usb-WD_My_Passport_0824_575835314132345537373037
Sve radi perfektno.
Pozdrav.Hvala svima u podrsci...
EDIT by stereo: ubačeni code tagovi.
Post Napisano: 10 Aug 2014, 18:58
@bocke
da i u slučaju huge kernela potreban je initrd. Evo izlaza iz ls -l /boot i uname -a sa externog na kome sam radio.
Uname -a:
Linux darkstar 3.10.17-smp #2 SMP Wed Oct 23 17:13:14 CDT 2013 i686 Intel(R) Core(TM) i3-2328M CPU @ 2.20GHz GenuineIntel GNU/Linux
ls -l /boot
total 31612
lrwxrwxrwx  1 root root      37 Aug  7 23:14 README.initrd -> /usr/doc/mkinitrd-1.4.8/README.initrd
lrwxrwxrwx  1 root root      31 Aug  7 23:14 System.map -> System.map-huge-smp-3.10.17-smp
-rw-r--r--  1 root root 1706325 Oct 24  2013 System.map-generic-3.10.17
-rw-r--r--  1 root root 1760315 Oct 24  2013 System.map-generic-smp-3.10.17-smp
-rw-r--r--  1 root root 2667078 Oct 24  2013 System.map-huge-3.10.17
-rw-r--r--  1 root root 2724121 Oct 24  2013 System.map-huge-smp-3.10.17-smp
-rw-r--r--  1 root root     512 Aug  8 22:25 boot.0810
-rw-r--r--  1 root root     512 Aug  7 23:27 boot.0820
-rw-r--r--  1 root root     137 Aug  7 23:23 boot_message.txt
lrwxrwxrwx  1 root root      27 Aug  7 23:14 config -> config-huge-smp-3.10.17-smp
-rw-r--r--  1 root root  140912 Oct 24  2013 config-generic-3.10.17
-rw-r--r--  1 root root  141822 Oct 24  2013 config-generic-smp-3.10.17-smp
-rw-r--r--  1 root root  140912 Oct 24  2013 config-huge-3.10.17
-rw-r--r--  1 root root  141822 Oct 24  2013 config-huge-smp-3.10.17-smp
-rwxr-xr-x  1 root root  217646 Jan 10  2011 elilo-ia32.efi
-rwxr-xr-x  1 root root  250510 Jan 10  2011 elilo-x86_64.efi
drwxr-xr-x 13 root root    4096 Aug  9 01:45 initrd-tree
-rw-r--r--  1 root root 3606193 Aug  9 01:45 initrd.gz
-rw-------  1 root root  126976 Aug  9 01:46 map
lrwxrwxrwx  1 root root      28 Aug  7 23:14 vmlinuz -> vmlinuz-huge-smp-3.10.17-smp
-rw-r--r--  1 root root 3088656 Oct 24  2013 vmlinuz-generic-3.10.17
-rw-r--r--  1 root root 3272208 Oct 24  2013 vmlinuz-generic-smp-3.10.17-smp
-rw-r--r--  1 root root 5995104 Oct 24  2013 vmlinuz-huge-3.10.17
-rw-r--r--  1 root root 6251392 Oct 24  2013 vmlinuz-huge-smp-3.10.17-smp
Vidi se gde upućuju config i vmlinuz.
