Kada gledam film ili seriju iskljuci se ekran posle 10 min
Obrada zvuka i slike, audio i video produkcija i slične teme
Birthday
Post Napisano: 12 Feb 2014, 01:44
Ovako, podesio sam u settings da mi ne radi screensaver i stavio sam da nema iskljucivanja ekrana posle x minuta ako je na bateriji isto tako i ako je na struji... Ali jednostavno posle jedno 10 min samo se pojavi crn ekran i kada mrdnem misem od nestane i tako u krug, sto morate priznati zna da bude iritantno... :huh:
Da li je neko resavao ovaj problem i ima li neko ideju?
system: slackware 14.1 kde
masina:laptop ASUS K50IN
Post Napisano: 12 Feb 2014, 04:04
Da, i mene je to pocelo da nervira.
komanda koju trazis je
xset -dpms
usage: xset [-display host:dpy] option ...
To turn bell off:
-b b off b 0
To set bell volume, pitch and duration:
b [vol [pitch [dur]]] b on
To disable bug compatibility mode:
-bc
To enable bug compatibility mode:
bc
To turn keyclick off:
-c c off c 0
To set keyclick volume:
c [0-100] c on
To control Energy Star (DPMS) features:
-dpms Energy Star features off
+dpms Energy Star features on
dpms [standby [suspend [off]]]
force standby
force suspend
force off
force on
(also implicitly enables DPMS features)
a timeout value of zero disables the mode
To control font cache:
fc [hi-mark [low-mark [balance]]]
both mark values specified in KB
balance value specified in percent (10 - 90)
Show font cache statistics:
fc s
To set the font path:
fp= path[,path...]
To restore the default font path:
fp default
To have the server reread font databases:
fp rehash
To remove elements from font path:
-fp path[,path...] fp- path[,path...]
To prepend or append elements to font path:
+fp path[,path...] fp+ path[,path...]
To set LED states off or on:
-led [1-32] led off
led [1-32] led on
-led named 'name' led off
led named 'name' led on
To set mouse acceleration and threshold:
m [acc_mult[/acc_div] [thr]] m default
To set pixel colors:
p pixel_value color_name
To turn auto-repeat off or on:
-r [keycode] r off
r [keycode] r on
r rate [delay [rate]]
For screen-saver control:
s [timeout [cycle]] s default s on
s blank s noblank s off
s expose s noexpose
s activate s reset
For status information: q
To print version: -version
Post Napisano: 12 Feb 2014, 09:27
A možeš i da otvoriš podešavanja power management-a i tamo definišeš neko duže vreme... lično sam imao problem sa time da se podešavanja ignorišu od strane sistema, čak ni gašenje PM-a nije pomagalo...
Tako da je najbolje da odeš u PM podešavanja, definišeš na koliko da se ugasi monitor u svim režimima rada, sačuvaš i primeniš.
Post Napisano: 12 Feb 2014, 09:50
Овако стоје поставке код мене и никад нисам имао проблема...
Post Napisano: 12 Feb 2014, 10:28
Možda da probaš ovo viewtopic.php?p=17519#p17519
Ja ga koristim na LXDE, verovatno može i sa KDE da radi.
Post Napisano: 12 Feb 2014, 12:28
Koleza @bad63r koristi KDE pa bih ja poslušao predlog kolege @Slackmuz. Koristim i sam slična podešavanja.
Za xfce i fluxbox mi je sledeća komanda rešavala problem:
xset s 0 0
Još kad ovo ubaciš u /etc/rc.d/rc.local na kraj fajla, svaki put će se nakon boot sistema pokrenuti komanda tako da ne moraš da je kucaš svaki put.
Da ponovim još jednom, poslušaj predlog @Slackmuza pa ako nekim čudom ne radi tako onda uradi kao što sam ti napisao.
Post Napisano: 12 Feb 2014, 12:43
Stereo, imaš PP. Javi kad si pročitao da obrišem moju poruku. :)
Post Napisano: 12 Feb 2014, 12:59
Ništa od kolege. :) Ok. Onda moram da ga ispravim javno.
xset zahteva pokrenut X server. Nema neke vajde staviti ga u /etc/rc.d/rc.local pošto se rc.local pokreće pre pokretanja X servera ili X desktop menadžera. Ali može se staviti u .xinitrc (startx) ili .xsession (xdm, gdm, kdm, lightdm, itd).
Post Napisano: 12 Feb 2014, 16:05
Huh, da, Bocke je u pravu skroz. U fluxboxu sam imao tu komandu u ~/.fluxbox/startup a u xfce je otkucam jednom i posle na gasim komp danima.
Da, da, hvala Bocke a ostalima izvinjenje zbog širenja dezinformacija :)
Birthday
Post Napisano: 21 Feb 2014, 13:52
Uf nisam vam ni rekao da sam resio problem :)
Btw eto bili ispiti pa ja nisam ni gledao filmove i serije pa kad sam pre neki dan reku da vidim dal radi... kad ono ne gasi se ekran sve radu ko od sale .Verovatno je neki od update-a resio problem jer ja verujte nista nisam dirao . Hvala svima na pomoci u svakom slucaju :beer:
