Napisano: 08 Jan 2023, 19:29
Slackware 64-bit
Sat Jan 7 20:30:44 UTC 2023
We're going to go ahead and jump to the 6.1.4 kernel, in spite of the fact
that a kernel bisect identified the patch that was preventing 32-bit from
booting here on a Thinkpad X1E:
From 2e479b3b82c49bfb9422274c0a9c155a41caecb7 Mon Sep 17 00:00:00 2001
Date: Wed, 16 Nov 2022 10:41:24 -0800
Subject: [PATCH] x86/ioremap: Fix page aligned size calculation in
__ioremap_caller()
commit 4dbd6a3e90e03130973688fd79e19425f720d999 upstream.
Current code re-calculates the size after aligning the starting and
ending physical addresses on a page boundary. But the re-calculation
also embeds the masking of high order bits that exceed the size of
the physical address space (via PHYSICAL_PAGE_MASK). If the masking
removes any high order bits, the size calculation results in a huge
value that is likely to immediately fail.
Fix this by re-calculating the page-aligned size first. Then mask any
high order bits using PHYSICAL_PAGE_MASK.
Fixes: ffa71f33a820 ("x86, ioremap: Fix incorrect physical address handling in
PAE mode")
The non-SMP non-PAE 32-bit kernel is fine even without the patch revert.
The PAE kernel also works fine with this patch reverted without any need
to revert ffa71f33a820 (the patch that this one is supposed to fix). The
machine's excessive (for 32-bit) amount of physical RAM (64GB) might also
be a factor here considering the PAE kernel works on all the other machines
around here without reverting this patch.
The patch is reverted only on 32-bit. Upstream report still pending.
Enjoy! :-)
a/kernel-generic-6.1.4-x86_64-1.txz: Upgraded.
a/kernel-huge-6.1.4-x86_64-1.txz: Upgraded.
a/kernel-modules-6.1.4-x86_64-1.txz: Upgraded.
a/tree-2.1.0-x86_64-1.txz: Upgraded.
d/kernel-headers-6.1.4-x86-1.txz: Upgraded.
k/kernel-source-6.1.4-noarch-1.txz: Upgraded.
l/gvfs-1.50.3-x86_64-1.txz: Upgraded.
l/hunspell-1.7.2-x86_64-1.txz: Upgraded.
l/libnice-0.1.21-x86_64-1.txz: Upgraded.
n/tin-2.6.2-x86_64-1.txz: Upgraded.
isolinux/initrd.img: Rebuilt.
kernels/*: Upgraded.
Sat Jan 7 01:50:00 UTC 2023
a/btrfs-progs-6.1.2-x86_64-1.txz: Upgraded.
l/mozilla-nss-3.87-x86_64-1.txz: Upgraded.
Fixed memory corruption in NSS via DER-encoded DSA and RSA-PSS signatures.
https://www.mozilla.org/en-US/security/advisories/mfsa2021-51/
https://www.cve.org/CVERecord?id=CVE-2021-43527
l/nodejs-19.4.0-x86_64-1.txz: Upgraded.
n/php-7.4.33-x86_64-2.txz: Rebuilt.
PDO::quote() may return unquoted string.
https://www.cve.org/CVERecord?id=CVE-2022-31631
extra/php80/php80-8.0.27-x86_64-1.txz: Upgraded.
extra/php81/php81-8.1.14-x86_64-1.txz: Upgraded.
This update fixes bugs and a security issue:
Fri Jan 6 00:54:38 UTC 2023
kde/akonadi-22.12.1-x86_64-1.txz: Upgraded.
kde/akonadi-calendar-22.12.1-x86_64-1.txz: Upgraded.
kde/akonadi-calendar-tools-22.12.1-x86_64-1.txz: Upgraded.
kde/akonadi-contacts-22.12.1-x86_64-1.txz: Upgraded.
kde/akonadi-import-wizard-22.12.1-x86_64-1.txz: Upgraded.
kde/akonadi-mime-22.12.1-x86_64-1.txz: Upgraded.
kde/akonadi-notes-22.12.1-x86_64-1.txz: Upgraded.
kde/akonadi-search-22.12.1-x86_64-1.txz: Upgraded.
kde/akonadiconsole-22.12.1-x86_64-1.txz: Upgraded.
kde/akregator-22.12.1-x86_64-1.txz: Upgraded.
kde/analitza-22.12.1-x86_64-1.txz: Upgraded.
kde/ark-22.12.1-x86_64-1.txz: Upgraded.
kde/artikulate-22.12.1-x86_64-1.txz: Upgraded.
kde/audiocd-kio-22.12.1-x86_64-1.txz: Upgraded.
kde/baloo-widgets-22.12.1-x86_64-1.txz: Upgraded.
kde/blinken-22.12.1-x86_64-1.txz: Upgraded.
kde/bomber-22.12.1-x86_64-1.txz: Upgraded.
kde/bovo-22.12.1-x86_64-1.txz: Upgraded.
kde/calendarsupport-22.12.1-x86_64-1.txz: Upgraded.
kde/cantor-22.12.1-x86_64-1.txz: Upgraded.
kde/cervisia-22.12.1-x86_64-1.txz: Upgraded.
kde/dolphin-22.12.1-x86_64-1.txz: Upgraded.
kde/dolphin-plugins-22.12.1-x86_64-1.txz: Upgraded.
kde/dragon-22.12.1-x86_64-1.txz: Upgraded.
kde/elisa-22.12.1-x86_64-1.txz: Upgraded.
kde/eventviews-22.12.1-x86_64-1.txz: Upgraded.
kde/falkon-22.12.1-x86_64-1.txz: Upgraded.
kde/ffmpegthumbs-22.12.1-x86_64-1.txz: Upgraded.
kde/filelight-22.12.1-x86_64-1.txz: Upgraded.
kde/granatier-22.12.1-x86_64-1.txz: Upgraded.
kde/grantlee-editor-22.12.1-x86_64-1.txz: Upgraded.
kde/grantleetheme-22.12.1-x86_64-1.txz: Upgraded.
kde/gwenview-22.12.1-x86_64-1.txz: Upgraded.
kde/incidenceeditor-22.12.1-x86_64-1.txz: Upgraded.
kde/itinerary-22.12.1-x86_64-1.txz: Upgraded.
kde/juk-22.12.1-x86_64-1.txz: Upgraded.
kde/k3b-22.12.1-x86_64-1.txz: Upgraded.
kde/kaddressbook-22.12.1-x86_64-1.txz: Upgraded.
kde/kalarm-22.12.1-x86_64-1.txz: Upgraded.
kde/kalendar-22.12.1-x86_64-1.txz: Upgraded.
kde/kalgebra-22.12.1-x86_64-1.txz: Upgraded.
kde/kalzium-22.12.1-x86_64-1.txz: Upgraded.
kde/kamera-22.12.1-x86_64-1.txz: Upgraded.
kde/kamoso-22.12.1-x86_64-1.txz: Upgraded.
kde/kanagram-22.12.1-x86_64-1.txz: Upgraded.
kde/kapman-22.12.1-x86_64-1.txz: Upgraded.
kde/kapptemplate-22.12.1-x86_64-1.txz: Upgraded.
kde/kate-22.12.1-x86_64-1.txz: Upgraded.
kde/katomic-22.12.1-x86_64-1.txz: Upgraded.
kde/kbackup-22.12.1-x86_64-1.txz: Upgraded.
kde/kblackbox-22.12.1-x86_64-1.txz: Upgraded.
kde/kblocks-22.12.1-x86_64-1.txz: Upgraded.
kde/kbounce-22.12.1-x86_64-1.txz: Upgraded.
kde/kbreakout-22.12.1-x86_64-1.txz: Upgraded.
kde/kbruch-22.12.1-x86_64-1.txz: Upgraded.
kde/kcachegrind-22.12.1-x86_64-1.txz: Upgraded.
kde/kcalc-22.12.1-x86_64-1.txz: Upgraded.
kde/kcalutils-22.12.1-x86_64-1.txz: Upgraded.
kde/kcharselect-22.12.1-x86_64-1.txz: Upgraded.
kde/kcolorchooser-22.12.1-x86_64-1.txz: Upgraded.
kde/kcron-22.12.1-x86_64-1.txz: Upgraded.
kde/kde-dev-scripts-22.12.1-x86_64-1.txz: Upgraded.
kde/kde-dev-utils-22.12.1-x86_64-1.txz: Upgraded.
kde/kdebugsettings-22.12.1-x86_64-1.txz: Upgraded.
kde/kdeconnect-kde-22.12.1-x86_64-1.txz: Upgraded.
kde/kdeedu-data-22.12.1-x86_64-1.txz: Upgraded.
kde/kdegraphics-mobipocket-22.12.1-x86_64-1.txz: Upgraded.
kde/kdegraphics-thumbnailers-22.12.1-x86_64-1.txz: Upgraded.
kde/kdenetwork-filesharing-22.12.1-x86_64-1.txz: Upgraded.
kde/kdenlive-22.12.1-x86_64-1.txz: Upgraded.
kde/kdepim-addons-22.12.1-x86_64-1.txz: Upgraded.
kde/kdepim-runtime-22.12.1-x86_64-1.txz: Upgraded.
kde/kdesdk-kio-22.12.1-x86_64-1.txz: Upgraded.
kde/kdesdk-thumbnailers-22.12.1-x86_64-1.txz: Upgraded.
kde/kdev-php-22.12.1-x86_64-1.txz: Upgraded.
kde/kdev-python-22.12.1-x86_64-1.txz: Upgraded.
kde/kdevelop-22.12.1-x86_64-1.txz: Upgraded.
kde/kdf-22.12.1-x86_64-1.txz: Upgraded.
kde/kdialog-22.12.1-x86_64-1.txz: Upgraded.
kde/kdiamond-22.12.1-x86_64-1.txz: Upgraded.
kde/keditbookmarks-22.12.1-x86_64-1.txz: Upgraded.
kde/kfind-22.12.1-x86_64-1.txz: Upgraded.
kde/kfloppy-22.12.1-x86_64-1.txz: Upgraded.
kde/kfourinline-22.12.1-x86_64-1.txz: Upgraded.
kde/kgeography-22.12.1-x86_64-1.txz: Upgraded.
kde/kget-22.12.1-x86_64-1.txz: Upgraded.
kde/kgoldrunner-22.12.1-x86_64-1.txz: Upgraded.
kde/kgpg-22.12.1-x86_64-1.txz: Upgraded.
kde/khangman-22.12.1-x86_64-1.txz: Upgraded.
kde/khelpcenter-22.12.1-x86_64-1.txz: Upgraded.
kde/kidentitymanagement-22.12.1-x86_64-1.txz: Upgraded.
kde/kig-22.12.1-x86_64-1.txz: Upgraded.
kde/kigo-22.12.1-x86_64-1.txz: Upgraded.
kde/killbots-22.12.1-x86_64-1.txz: Upgraded.
kde/kimagemapeditor-22.12.1-x86_64-1.txz: Upgraded.
kde/kimap-22.12.1-x86_64-1.txz: Upgraded.
kde/kio-extras-22.12.1-x86_64-1.txz: Upgraded.
kde/kio-gdrive-22.12.1-x86_64-1.txz: Upgraded.
kde/kio-zeroconf-22.12.1-x86_64-1.txz: Upgraded.
kde/kipi-plugins-22.12.1-x86_64-1.txz: Upgraded.
kde/kirigami-gallery-22.12.1-x86_64-1.txz: Upgraded.
kde/kiriki-22.12.1-x86_64-1.txz: Upgraded.
kde/kiten-22.12.1-x86_64-1.txz: Upgraded.
kde/kitinerary-22.12.1-x86_64-1.txz: Upgraded.
kde/kjumpingcube-22.12.1-x86_64-1.txz: Upgraded.
kde/kldap-22.12.1-x86_64-1.txz: Upgraded.
kde/kleopatra-22.12.1-x86_64-1.txz: Upgraded.
kde/klickety-22.12.1-x86_64-1.txz: Upgraded.
kde/klines-22.12.1-x86_64-1.txz: Upgraded.
kde/kmag-22.12.1-x86_64-1.txz: Upgraded.
kde/kmahjongg-22.12.1-x86_64-1.txz: Upgraded.
kde/kmail-22.12.1-x86_64-1.txz: Upgraded.
kde/kmail-account-wizard-22.12.1-x86_64-1.txz: Upgraded.
kde/kmailtransport-22.12.1-x86_64-1.txz: Upgraded.
kde/kmbox-22.12.1-x86_64-1.txz: Upgraded.
kde/kmime-22.12.1-x86_64-1.txz: Upgraded.
kde/kmines-22.12.1-x86_64-1.txz: Upgraded.
kde/kmix-22.12.1-x86_64-1.txz: Upgraded.
kde/kmousetool-22.12.1-x86_64-1.txz: Upgraded.
kde/kmouth-22.12.1-x86_64-1.txz: Upgraded.
kde/kmplot-22.12.1-x86_64-1.txz: Upgraded.
kde/knavalbattle-22.12.1-x86_64-1.txz: Upgraded.
kde/knetwalk-22.12.1-x86_64-1.txz: Upgraded.
kde/knights-22.12.1-x86_64-1.txz: Upgraded.
kde/knotes-22.12.1-x86_64-1.txz: Upgraded.
kde/kolf-22.12.1-x86_64-1.txz: Upgraded.
kde/kollision-22.12.1-x86_64-1.txz: Upgraded.
kde/kolourpaint-22.12.1-x86_64-1.txz: Upgraded.
kde/kompare-22.12.1-x86_64-1.txz: Upgraded.
kde/konqueror-22.12.1-x86_64-1.txz: Upgraded.
kde/konquest-22.12.1-x86_64-1.txz: Upgraded.
kde/konsole-22.12.1-x86_64-1.txz: Upgraded.
kde/kontact-22.12.1-x86_64-1.txz: Upgraded.
kde/kontactinterface-22.12.1-x86_64-1.txz: Upgraded.
kde/kontrast-22.12.1-x86_64-1.txz: Upgraded.
kde/konversation-22.12.1-x86_64-1.txz: Upgraded.
kde/kopeninghours-22.12.1-x86_64-1.txz: Upgraded.
kde/kopete-22.12.1-x86_64-1.txz: Upgraded.
kde/korganizer-22.12.1-x86_64-1.txz: Upgraded.
kde/kosmindoormap-22.12.1-x86_64-1.txz: Upgraded.
kde/kpat-22.12.1-x86_64-1.txz: Upgraded.
kde/kpimtextedit-22.12.1-x86_64-1.txz: Upgraded.
kde/kpkpass-22.12.1-x86_64-1.txz: Upgraded.
kde/kpmcore-22.12.1-x86_64-1.txz: Upgraded.
kde/kpublictransport-22.12.1-x86_64-1.txz: Upgraded.
kde/kqtquickcharts-22.12.1-x86_64-1.txz: Upgraded.
kde/krdc-22.12.1-x86_64-1.txz: Upgraded.
kde/kreversi-22.12.1-x86_64-1.txz: Upgraded.
kde/krfb-22.12.1-x86_64-1.txz: Upgraded.
kde/krita-5.1.5-x86_64-1.txz: Upgraded.
kde/kross-interpreters-22.12.1-x86_64-1.txz: Upgraded.
kde/kruler-22.12.1-x86_64-1.txz: Upgraded.
kde/ksanecore-22.12.1-x86_64-1.txz: Upgraded.
kde/kshisen-22.12.1-x86_64-1.txz: Upgraded.
kde/ksirk-22.12.1-x86_64-1.txz: Upgraded.
kde/ksmtp-22.12.1-x86_64-1.txz: Upgraded.
kde/ksnakeduel-22.12.1-x86_64-1.txz: Upgraded.
kde/kspaceduel-22.12.1-x86_64-1.txz: Upgraded.
kde/ksquares-22.12.1-x86_64-1.txz: Upgraded.
kde/ksudoku-22.12.1-x86_64-1.txz: Upgraded.
kde/ksystemlog-22.12.1-x86_64-1.txz: Upgraded.
kde/kteatime-22.12.1-x86_64-1.txz: Upgraded.
kde/ktimer-22.12.1-x86_64-1.txz: Upgraded.
kde/ktnef-22.12.1-x86_64-1.txz: Upgraded.
kde/ktorrent-22.12.1-x86_64-1.txz: Upgraded.
kde/ktouch-22.12.1-x86_64-1.txz: Upgraded.
kde/kturtle-22.12.1-x86_64-1.txz: Upgraded.
kde/kubrick-22.12.1-x86_64-1.txz: Upgraded.
kde/kwalletmanager-22.12.1-x86_64-1.txz: Upgraded.
kde/kwave-22.12.1-x86_64-1.txz: Upgraded.
kde/kwordquiz-22.12.1-x86_64-1.txz: Upgraded.
kde/libgravatar-22.12.1-x86_64-1.txz: Upgraded.
kde/libkcddb-22.12.1-x86_64-1.txz: Upgraded.
kde/libkcompactdisc-22.12.1-x86_64-1.txz: Upgraded.
kde/libkdcraw-22.12.1-x86_64-1.txz: Upgraded.
kde/libkdegames-22.12.1-x86_64-1.txz: Upgraded.
kde/libkdepim-22.12.1-x86_64-1.txz: Upgraded.
kde/libkeduvocdocument-22.12.1-x86_64-1.txz: Upgraded.
kde/libkexiv2-22.12.1-x86_64-1.txz: Upgraded.
kde/libkgapi-22.12.1-x86_64-1.txz: Upgraded.
kde/libkipi-22.12.1-x86_64-1.txz: Upgraded.
kde/libkleo-22.12.1-x86_64-1.txz: Upgraded.
kde/libkmahjongg-22.12.1-x86_64-1.txz: Upgraded.
kde/libkomparediff2-22.12.1-x86_64-1.txz: Upgraded.
kde/libksane-22.12.1-x86_64-1.txz: Upgraded.
kde/libksieve-22.12.1-x86_64-1.txz: Upgraded.
kde/libktorrent-22.12.1-x86_64-1.txz: Upgraded.
kde/lokalize-22.12.1-x86_64-1.txz: Upgraded.
kde/lskat-22.12.1-x86_64-1.txz: Upgraded.
kde/mailcommon-22.12.1-x86_64-1.txz: Upgraded.
kde/mailimporter-22.12.1-x86_64-1.txz: Upgraded.
kde/marble-22.12.1-x86_64-1.txz: Upgraded.
kde/markdownpart-22.12.1-x86_64-1.txz: Upgraded.
kde/mbox-importer-22.12.1-x86_64-1.txz: Upgraded.
kde/messagelib-22.12.1-x86_64-1.txz: Upgraded.
kde/minuet-22.12.1-x86_64-1.txz: Upgraded.
kde/okular-22.12.1-x86_64-1.txz: Upgraded.
kde/palapeli-22.12.1-x86_64-1.txz: Upgraded.
kde/parley-22.12.1-x86_64-1.txz: Upgraded.
kde/partitionmanager-22.12.1-x86_64-1.txz: Upgraded.
kde/picmi-22.12.1-x86_64-1.txz: Upgraded.
kde/pim-data-exporter-22.12.1-x86_64-1.txz: Upgraded.
kde/pim-sieve-editor-22.12.1-x86_64-1.txz: Upgraded.
kde/pimcommon-22.12.1-x86_64-1.txz: Upgraded.
kde/poxml-22.12.1-x86_64-1.txz: Upgraded.
kde/print-manager-22.12.1-x86_64-1.txz: Upgraded.
kde/rocs-22.12.1-x86_64-1.txz: Upgraded.
kde/skanlite-22.12.1-x86_64-1.txz: Upgraded.
kde/skanpage-22.12.1-x86_64-1.txz: Upgraded.
kde/spectacle-22.12.1-x86_64-1.txz: Upgraded.
kde/svgpart-22.12.1-x86_64-1.txz: Upgraded.
kde/sweeper-22.12.1-x86_64-1.txz: Upgraded.
kde/umbrello-22.12.1-x86_64-1.txz: Upgraded.
kde/yakuake-22.12.1-x86_64-1.txz: Upgraded.
kde/zanshin-22.12.1-x86_64-1.txz: Upgraded.
l/libqalculate-4.5.1-x86_64-1.txz: Upgraded.
n/traceroute-2.1.1-x86_64-1.txz: Upgraded.
xap/mozilla-firefox-108.0.2-x86_64-1.txz: Upgraded.
This is a bugfix release.
https://www.mozilla.org/en-US/firefox/108.0.2/releasenotes/
xfce/libxfce4ui-4.18.1-x86_64-1.txz: Upgraded.
xfce/xfce4-screenshooter-1.10.2-x86_64-1.txz: Upgraded.
Thanks to Robby Workman.
xfce/xfce4-systemload-plugin-1.3.2-x86_64-1.txz: Upgraded.
xfce/xfce4-taskmanager-1.5.5-x86_64-1.txz: Upgraded.
Thu Jan 5 03:09:24 UTC 2023
a/btrfs-progs-6.1.1-x86_64-1.txz: Upgraded.
a/hwdata-0.366-noarch-1.txz: Upgraded.
a/kernel-firmware-20230104_4ee2014-noarch-1.txz: Upgraded.
ap/vim-9.0.1146-x86_64-1.txz: Upgraded.
Fixed security issues:
Out-of-bounds Read in GitHub repository vim/vim prior to 9.0.1143.
Heap-based Buffer Overflow in GitHub repository vim/vim prior to 9.0.1144.
https://www.cve.org/CVERecord?id=CVE-2023-0049
https://www.cve.org/CVERecord?id=CVE-2023-0051
d/mercurial-6.3.2-x86_64-1.txz: Upgraded.
l/fluidsynth-2.3.1-x86_64-1.txz: Upgraded.
l/libxkbcommon-1.5.0-x86_64-1.txz: Upgraded.
n/fetchmail-6.4.35-x86_64-1.txz: Upgraded.
xap/vim-gvim-9.0.1146-x86_64-1.txz: Upgraded.
testing/packages/linux-6.1.x/kernel-generic-6.1.3-x86_64-1.txz: Upgraded.
testing/packages/linux-6.1.x/kernel-headers-6.1.3-x86-1.txz: Upgraded.
testing/packages/linux-6.1.x/kernel-huge-6.1.3-x86_64-1.txz: Upgraded.
testing/packages/linux-6.1.x/kernel-modules-6.1.3-x86_64-1.txz: Upgraded.
testing/packages/linux-6.1.x/kernel-source-6.1.3-noarch-1.txz: Upgraded.
Wed Jan 4 02:18:08 UTC 2023
ap/lsof-4.96.5-x86_64-1.txz: Upgraded.
ap/sqlite-3.40.1-x86_64-1.txz: Upgraded.
kde/bluedevil-5.26.5-x86_64-1.txz: Upgraded.
kde/breeze-5.26.5-x86_64-1.txz: Upgraded.
kde/breeze-grub-5.26.5-x86_64-1.txz: Upgraded.
kde/breeze-gtk-5.26.5-x86_64-1.txz: Upgraded.
kde/digikam-7.9.0-x86_64-2.txz: Rebuilt.
Recompiled against opencv-4.7.0.
kde/drkonqi-5.26.5-x86_64-1.txz: Upgraded.
kde/kactivitymanagerd-5.26.5-x86_64-1.txz: Upgraded.
kde/kde-cli-tools-5.26.5-x86_64-1.txz: Upgraded.
kde/kde-gtk-config-5.26.5-x86_64-1.txz: Upgraded.
kde/kdecoration-5.26.5-x86_64-1.txz: Upgraded.
kde/kdeplasma-addons-5.26.5-x86_64-1.txz: Upgraded.
kde/kgamma5-5.26.5-x86_64-1.txz: Upgraded.
kde/khotkeys-5.26.5-x86_64-1.txz: Upgraded.
kde/kinfocenter-5.26.5-x86_64-1.txz: Upgraded.
kde/kmenuedit-5.26.5-x86_64-1.txz: Upgraded.
kde/kpipewire-5.26.5-x86_64-1.txz: Upgraded.
kde/kscreen-5.26.5-x86_64-1.txz: Upgraded.
kde/kscreenlocker-5.26.5-x86_64-1.txz: Upgraded.
kde/ksshaskpass-5.26.5-x86_64-1.txz: Upgraded.
kde/ksystemstats-5.26.5-x86_64-1.txz: Upgraded.
kde/kwallet-pam-5.26.5-x86_64-1.txz: Upgraded.
kde/kwayland-integration-5.26.5-x86_64-1.txz: Upgraded.
kde/kwin-5.26.5-x86_64-1.txz: Upgraded.
kde/kwrited-5.26.5-x86_64-1.txz: Upgraded.
kde/layer-shell-qt-5.26.5-x86_64-1.txz: Upgraded.
kde/libkscreen-5.26.5-x86_64-1.txz: Upgraded.
kde/libksysguard-5.26.5-x86_64-1.txz: Upgraded.
kde/milou-5.26.5-x86_64-1.txz: Upgraded.
kde/oxygen-5.26.5-x86_64-1.txz: Upgraded.
kde/oxygen-sounds-5.26.5-x86_64-1.txz: Upgraded.
kde/plasma-browser-integration-5.26.5-x86_64-1.txz: Upgraded.
kde/plasma-desktop-5.26.5-x86_64-1.txz: Upgraded.
kde/plasma-disks-5.26.5-x86_64-1.txz: Upgraded.
kde/plasma-firewall-5.26.5-x86_64-1.txz: Upgraded.
kde/plasma-integration-5.26.5-x86_64-1.txz: Upgraded.
kde/plasma-nm-5.26.5-x86_64-1.txz: Upgraded.
kde/plasma-pa-5.26.5-x86_64-1.txz: Upgraded.
kde/plasma-sdk-5.26.5-x86_64-1.txz: Upgraded.
kde/plasma-systemmonitor-5.26.5-x86_64-1.txz: Upgraded.
kde/plasma-vault-5.26.5-x86_64-1.txz: Upgraded.
kde/plasma-workspace-5.26.5-x86_64-1.txz: Upgraded.
kde/plasma-workspace-wallpapers-5.26.5-x86_64-1.txz: Upgraded.
kde/polkit-kde-agent-1-5.26.5-x86_64-1.txz: Upgraded.
kde/powerdevil-5.26.5-x86_64-1.txz: Upgraded.
kde/qqc2-breeze-style-5.26.5-x86_64-1.txz: Upgraded.
kde/sddm-kcm-5.26.5-x86_64-1.txz: Upgraded.
kde/systemsettings-5.26.5-x86_64-1.txz: Upgraded.
kde/xdg-desktop-portal-kde-5.26.5-x86_64-1.txz: Upgraded.
l/SDL2-2.26.2-x86_64-1.txz: Upgraded.
l/gst-plugins-bad-free-1.20.5-x86_64-2.txz: Rebuilt.
l/imagemagick-7.1.0_57-x86_64-1.txz: Upgraded.
l/libpcap-1.10.2-x86_64-1.txz: Upgraded.
l/libpsl-0.21.2-x86_64-1.txz: Upgraded.
l/librevenge-0.0.5-x86_64-1.txz: Upgraded.
l/libsndfile-1.2.0-x86_64-1.txz: Upgraded.
l/libtiff-4.4.0-x86_64-2.txz: Rebuilt.
Patched various security bugs.
https://www.cve.org/CVERecord?id=CVE-2022-2056
https://www.cve.org/CVERecord?id=CVE-2022-2057
https://www.cve.org/CVERecord?id=CVE-2022-2058
https://www.cve.org/CVERecord?id=CVE-2022-3970
https://www.cve.org/CVERecord?id=CVE-2022-34526
l/netpbm-11.01.00-x86_64-1.txz: Upgraded.
l/opencv-4.7.0-x86_64-1.txz: Upgraded.
l/poppler-23.01.0-x86_64-1.txz: Upgraded.
n/getmail-6.18.11-x86_64-1.txz: Upgraded.
n/tcpdump-4.99.2-x86_64-1.txz: Upgraded.
n/whois-5.5.15-x86_64-1.txz: Upgraded.
Updated the .bd, .nz and .tv TLD servers.
Added the .llyw.cymru, .gov.scot and .gov.wales SLD servers.
Updated the .ac.uk and .gov.uk SLD servers.
Recursion has been enabled for whois.nic.tv.
Updated the list of new gTLDs with four generic TLDs assigned in October 2013
which were missing due to a bug.
Removed 4 new gTLDs which are no longer active.
Added the Georgian translation, contributed by Temuri Doghonadze.
Updated the Finnish translation, contributed by Lauri Nurmi.
xap/pidgin-2.14.12-x86_64-1.txz: Upgraded.
xap/rxvt-unicode-9.26-x86_64-4.txz: Rebuilt.
When the "background" extension was loaded, an attacker able to control the
data written to the terminal would be able to execute arbitrary code as the
terminal's user. Thanks to David Leadbeater and Ben Collver.
https://www.openwall.com/lists/oss-security/2022/12/05/1
https://www.cve.org/CVERecord?id=CVE-2022-4170
Slackware 32-bit
__ioremap_caller()
PAE mode")
Enjoy! :-)
a/kernel-generic-6.1.4-i586-1.txz: Upgraded.
a/kernel-generic-smp-6.1.4_smp-i686-1.txz: Upgraded.
a/kernel-huge-6.1.4-i586-1.txz: Upgraded.
a/kernel-huge-smp-6.1.4_smp-i686-1.txz: Upgraded.
a/kernel-modules-6.1.4-i586-1.txz: Upgraded.
a/kernel-modules-smp-6.1.4_smp-i686-1.txz: Upgraded.
a/tree-2.1.0-i586-1.txz: Upgraded.
d/kernel-headers-6.1.4_smp-x86-1.txz: Upgraded.
k/kernel-source-6.1.4_smp-noarch-1.txz: Upgraded.
l/gvfs-1.50.3-i586-1.txz: Upgraded.
l/hunspell-1.7.2-i586-1.txz: Upgraded.
l/libnice-0.1.21-i586-1.txz: Upgraded.
n/tin-2.6.2-i586-1.txz: Upgraded.
extra/linux-6.1.4-nosmp-sdk/*: Upgraded.
a/btrfs-progs-6.1.2-i586-1.txz: Upgraded.
l/mozilla-nss-3.87-i586-1.txz: Upgraded.
l/nodejs-19.4.0-i586-1.txz: Upgraded.
n/php-7.4.33-i586-2.txz: Rebuilt.
extra/php80/php80-8.0.27-i586-1.txz: Upgraded.
extra/php81/php81-8.1.14-i586-1.txz: Upgraded.
kde/akonadi-22.12.1-i586-1.txz: Upgraded.
kde/akonadi-calendar-22.12.1-i586-1.txz: Upgraded.
kde/akonadi-calendar-tools-22.12.1-i586-1.txz: Upgraded.
kde/akonadi-contacts-22.12.1-i586-1.txz: Upgraded.
kde/akonadi-import-wizard-22.12.1-i586-1.txz: Upgraded.
kde/akonadi-mime-22.12.1-i586-1.txz: Upgraded.
kde/akonadi-notes-22.12.1-i586-1.txz: Upgraded.
kde/akonadi-search-22.12.1-i586-1.txz: Upgraded.
kde/akonadiconsole-22.12.1-i586-1.txz: Upgraded.
kde/akregator-22.12.1-i586-1.txz: Upgraded.
kde/analitza-22.12.1-i586-1.txz: Upgraded.
kde/ark-22.12.1-i586-1.txz: Upgraded.
kde/artikulate-22.12.1-i586-1.txz: Upgraded.
kde/audiocd-kio-22.12.1-i586-1.txz: Upgraded.
kde/baloo-widgets-22.12.1-i586-1.txz: Upgraded.
kde/blinken-22.12.1-i586-1.txz: Upgraded.
kde/bomber-22.12.1-i586-1.txz: Upgraded.
kde/bovo-22.12.1-i586-1.txz: Upgraded.
kde/calendarsupport-22.12.1-i586-1.txz: Upgraded.
kde/cantor-22.12.1-i586-1.txz: Upgraded.
kde/cervisia-22.12.1-i586-1.txz: Upgraded.
kde/dolphin-22.12.1-i586-1.txz: Upgraded.
kde/dolphin-plugins-22.12.1-i586-1.txz: Upgraded.
kde/dragon-22.12.1-i586-1.txz: Upgraded.
kde/elisa-22.12.1-i586-1.txz: Upgraded.
kde/eventviews-22.12.1-i586-1.txz: Upgraded.
kde/falkon-22.12.1-i586-1.txz: Upgraded.
kde/ffmpegthumbs-22.12.1-i586-1.txz: Upgraded.
kde/filelight-22.12.1-i586-1.txz: Upgraded.
kde/granatier-22.12.1-i586-1.txz: Upgraded.
kde/grantlee-editor-22.12.1-i586-1.txz: Upgraded.
kde/grantleetheme-22.12.1-i586-1.txz: Upgraded.
kde/gwenview-22.12.1-i586-1.txz: Upgraded.
kde/incidenceeditor-22.12.1-i586-1.txz: Upgraded.
kde/itinerary-22.12.1-i586-1.txz: Upgraded.
kde/juk-22.12.1-i586-1.txz: Upgraded.
kde/k3b-22.12.1-i586-1.txz: Upgraded.
kde/kaddressbook-22.12.1-i586-1.txz: Upgraded.
kde/kalarm-22.12.1-i586-1.txz: Upgraded.
kde/kalendar-22.12.1-i586-1.txz: Upgraded.
kde/kalgebra-22.12.1-i586-1.txz: Upgraded.
kde/kalzium-22.12.1-i586-1.txz: Upgraded.
kde/kamera-22.12.1-i586-1.txz: Upgraded.
kde/kamoso-22.12.1-i586-1.txz: Upgraded.
kde/kanagram-22.12.1-i586-1.txz: Upgraded.
kde/kapman-22.12.1-i586-1.txz: Upgraded.
kde/kapptemplate-22.12.1-i586-1.txz: Upgraded.
kde/kate-22.12.1-i586-1.txz: Upgraded.
kde/katomic-22.12.1-i586-1.txz: Upgraded.
kde/kbackup-22.12.1-i586-1.txz: Upgraded.
kde/kblackbox-22.12.1-i586-1.txz: Upgraded.
kde/kblocks-22.12.1-i586-1.txz: Upgraded.
kde/kbounce-22.12.1-i586-1.txz: Upgraded.
kde/kbreakout-22.12.1-i586-1.txz: Upgraded.
kde/kbruch-22.12.1-i586-1.txz: Upgraded.
kde/kcachegrind-22.12.1-i586-1.txz: Upgraded.
kde/kcalc-22.12.1-i586-1.txz: Upgraded.
kde/kcalutils-22.12.1-i586-1.txz: Upgraded.
kde/kcharselect-22.12.1-i586-1.txz: Upgraded.
kde/kcolorchooser-22.12.1-i586-1.txz: Upgraded.
kde/kcron-22.12.1-i586-1.txz: Upgraded.
kde/kde-dev-scripts-22.12.1-i586-1.txz: Upgraded.
kde/kde-dev-utils-22.12.1-i586-1.txz: Upgraded.
kde/kdebugsettings-22.12.1-i586-1.txz: Upgraded.
kde/kdeconnect-kde-22.12.1-i586-1.txz: Upgraded.
kde/kdeedu-data-22.12.1-i586-1.txz: Upgraded.
kde/kdegraphics-mobipocket-22.12.1-i586-1.txz: Upgraded.
kde/kdegraphics-thumbnailers-22.12.1-i586-1.txz: Upgraded.
kde/kdenetwork-filesharing-22.12.1-i586-1.txz: Upgraded.
kde/kdenlive-22.12.1-i586-1.txz: Upgraded.
kde/kdepim-addons-22.12.1-i586-1.txz: Upgraded.
kde/kdepim-runtime-22.12.1-i586-1.txz: Upgraded.
kde/kdesdk-kio-22.12.1-i586-1.txz: Upgraded.
kde/kdesdk-thumbnailers-22.12.1-i586-1.txz: Upgraded.
kde/kdev-php-22.12.1-i586-1.txz: Upgraded.
kde/kdev-python-22.12.1-i586-1.txz: Upgraded.
kde/kdevelop-22.12.1-i586-1.txz: Upgraded.
kde/kdf-22.12.1-i586-1.txz: Upgraded.
kde/kdialog-22.12.1-i586-1.txz: Upgraded.
kde/kdiamond-22.12.1-i586-1.txz: Upgraded.
kde/keditbookmarks-22.12.1-i586-1.txz: Upgraded.
kde/kfind-22.12.1-i586-1.txz: Upgraded.
kde/kfloppy-22.12.1-i586-1.txz: Upgraded.
kde/kfourinline-22.12.1-i586-1.txz: Upgraded.
kde/kgeography-22.12.1-i586-1.txz: Upgraded.
kde/kget-22.12.1-i586-1.txz: Upgraded.
kde/kgoldrunner-22.12.1-i586-1.txz: Upgraded.
kde/kgpg-22.12.1-i586-1.txz: Upgraded.
kde/khangman-22.12.1-i586-1.txz: Upgraded.
kde/khelpcenter-22.12.1-i586-1.txz: Upgraded.
kde/kidentitymanagement-22.12.1-i586-1.txz: Upgraded.
kde/kig-22.12.1-i586-1.txz: Upgraded.
kde/kigo-22.12.1-i586-1.txz: Upgraded.
kde/killbots-22.12.1-i586-1.txz: Upgraded.
kde/kimagemapeditor-22.12.1-i586-1.txz: Upgraded.
kde/kimap-22.12.1-i586-1.txz: Upgraded.
kde/kio-extras-22.12.1-i586-1.txz: Upgraded.
kde/kio-gdrive-22.12.1-i586-1.txz: Upgraded.
kde/kio-zeroconf-22.12.1-i586-1.txz: Upgraded.
kde/kipi-plugins-22.12.1-i586-1.txz: Upgraded.
kde/kirigami-gallery-22.12.1-i586-1.txz: Upgraded.
kde/kiriki-22.12.1-i586-1.txz: Upgraded.
kde/kiten-22.12.1-i586-1.txz: Upgraded.
kde/kitinerary-22.12.1-i586-1.txz: Upgraded.
kde/kjumpingcube-22.12.1-i586-1.txz: Upgraded.
kde/kldap-22.12.1-i586-1.txz: Upgraded.
kde/kleopatra-22.12.1-i586-1.txz: Upgraded.
kde/klickety-22.12.1-i586-1.txz: Upgraded.
kde/klines-22.12.1-i586-1.txz: Upgraded.
kde/kmag-22.12.1-i586-1.txz: Upgraded.
kde/kmahjongg-22.12.1-i586-1.txz: Upgraded.
kde/kmail-22.12.1-i586-1.txz: Upgraded.
kde/kmail-account-wizard-22.12.1-i586-1.txz: Upgraded.
kde/kmailtransport-22.12.1-i586-1.txz: Upgraded.
kde/kmbox-22.12.1-i586-1.txz: Upgraded.
kde/kmime-22.12.1-i586-1.txz: Upgraded.
kde/kmines-22.12.1-i586-1.txz: Upgraded.
kde/kmix-22.12.1-i586-1.txz: Upgraded.
kde/kmousetool-22.12.1-i586-1.txz: Upgraded.
kde/kmouth-22.12.1-i586-1.txz: Upgraded.
kde/kmplot-22.12.1-i586-1.txz: Upgraded.
kde/knavalbattle-22.12.1-i586-1.txz: Upgraded.
kde/knetwalk-22.12.1-i586-1.txz: Upgraded.
kde/knights-22.12.1-i586-1.txz: Upgraded.
kde/knotes-22.12.1-i586-1.txz: Upgraded.
kde/kolf-22.12.1-i586-1.txz: Upgraded.
kde/kollision-22.12.1-i586-1.txz: Upgraded.
kde/kolourpaint-22.12.1-i586-1.txz: Upgraded.
kde/kompare-22.12.1-i586-1.txz: Upgraded.
kde/konqueror-22.12.1-i586-1.txz: Upgraded.
kde/konquest-22.12.1-i586-1.txz: Upgraded.
kde/konsole-22.12.1-i586-1.txz: Upgraded.
kde/kontact-22.12.1-i586-1.txz: Upgraded.
kde/kontactinterface-22.12.1-i586-1.txz: Upgraded.
kde/kontrast-22.12.1-i586-1.txz: Upgraded.
kde/konversation-22.12.1-i586-1.txz: Upgraded.
kde/kopeninghours-22.12.1-i586-1.txz: Upgraded.
kde/kopete-22.12.1-i586-1.txz: Upgraded.
kde/korganizer-22.12.1-i586-1.txz: Upgraded.
kde/kosmindoormap-22.12.1-i586-1.txz: Upgraded.
kde/kpat-22.12.1-i586-1.txz: Upgraded.
kde/kpimtextedit-22.12.1-i586-1.txz: Upgraded.
kde/kpkpass-22.12.1-i586-1.txz: Upgraded.
kde/kpmcore-22.12.1-i586-1.txz: Upgraded.
kde/kpublictransport-22.12.1-i586-1.txz: Upgraded.
kde/kqtquickcharts-22.12.1-i586-1.txz: Upgraded.
kde/krdc-22.12.1-i586-1.txz: Upgraded.
kde/kreversi-22.12.1-i586-1.txz: Upgraded.
kde/krfb-22.12.1-i586-1.txz: Upgraded.
kde/krita-5.1.5-i586-1.txz: Upgraded.
kde/kross-interpreters-22.12.1-i586-1.txz: Upgraded.
kde/kruler-22.12.1-i586-1.txz: Upgraded.
kde/ksanecore-22.12.1-i586-1.txz: Upgraded.
kde/kshisen-22.12.1-i586-1.txz: Upgraded.
kde/ksirk-22.12.1-i586-1.txz: Upgraded.
kde/ksmtp-22.12.1-i586-1.txz: Upgraded.
kde/ksnakeduel-22.12.1-i586-1.txz: Upgraded.
kde/kspaceduel-22.12.1-i586-1.txz: Upgraded.
kde/ksquares-22.12.1-i586-1.txz: Upgraded.
kde/ksudoku-22.12.1-i586-1.txz: Upgraded.
kde/ksystemlog-22.12.1-i586-1.txz: Upgraded.
kde/kteatime-22.12.1-i586-1.txz: Upgraded.
kde/ktimer-22.12.1-i586-1.txz: Upgraded.
kde/ktnef-22.12.1-i586-1.txz: Upgraded.
kde/ktorrent-22.12.1-i586-1.txz: Upgraded.
kde/ktouch-22.12.1-i586-1.txz: Upgraded.
kde/kturtle-22.12.1-i586-1.txz: Upgraded.
kde/kubrick-22.12.1-i586-1.txz: Upgraded.
kde/kwalletmanager-22.12.1-i586-1.txz: Upgraded.
kde/kwave-22.12.1-i586-1.txz: Upgraded.
kde/kwordquiz-22.12.1-i586-1.txz: Upgraded.
kde/libgravatar-22.12.1-i586-1.txz: Upgraded.
kde/libkcddb-22.12.1-i586-1.txz: Upgraded.
kde/libkcompactdisc-22.12.1-i586-1.txz: Upgraded.
kde/libkdcraw-22.12.1-i586-1.txz: Upgraded.
kde/libkdegames-22.12.1-i586-1.txz: Upgraded.
kde/libkdepim-22.12.1-i586-1.txz: Upgraded.
kde/libkeduvocdocument-22.12.1-i586-1.txz: Upgraded.
kde/libkexiv2-22.12.1-i586-1.txz: Upgraded.
kde/libkgapi-22.12.1-i586-1.txz: Upgraded.
kde/libkipi-22.12.1-i586-1.txz: Upgraded.
kde/libkleo-22.12.1-i586-1.txz: Upgraded.
kde/libkmahjongg-22.12.1-i586-1.txz: Upgraded.
kde/libkomparediff2-22.12.1-i586-1.txz: Upgraded.
kde/libksane-22.12.1-i586-1.txz: Upgraded.
kde/libksieve-22.12.1-i586-1.txz: Upgraded.
kde/libktorrent-22.12.1-i586-1.txz: Upgraded.
kde/lokalize-22.12.1-i586-1.txz: Upgraded.
kde/lskat-22.12.1-i586-1.txz: Upgraded.
kde/mailcommon-22.12.1-i586-1.txz: Upgraded.
kde/mailimporter-22.12.1-i586-1.txz: Upgraded.
kde/marble-22.12.1-i586-1.txz: Upgraded.
kde/markdownpart-22.12.1-i586-1.txz: Upgraded.
kde/mbox-importer-22.12.1-i586-1.txz: Upgraded.
kde/messagelib-22.12.1-i586-1.txz: Upgraded.
kde/minuet-22.12.1-i586-1.txz: Upgraded.
kde/okular-22.12.1-i586-1.txz: Upgraded.
kde/palapeli-22.12.1-i586-1.txz: Upgraded.
kde/parley-22.12.1-i586-1.txz: Upgraded.
kde/partitionmanager-22.12.1-i586-1.txz: Upgraded.
kde/picmi-22.12.1-i586-1.txz: Upgraded.
kde/pim-data-exporter-22.12.1-i586-1.txz: Upgraded.
kde/pim-sieve-editor-22.12.1-i586-1.txz: Upgraded.
kde/pimcommon-22.12.1-i586-1.txz: Upgraded.
kde/poxml-22.12.1-i586-1.txz: Upgraded.
kde/print-manager-22.12.1-i586-1.txz: Upgraded.
kde/rocs-22.12.1-i586-1.txz: Upgraded.
kde/skanlite-22.12.1-i586-1.txz: Upgraded.
kde/skanpage-22.12.1-i586-1.txz: Upgraded.
kde/spectacle-22.12.1-i586-1.txz: Upgraded.
kde/svgpart-22.12.1-i586-1.txz: Upgraded.
kde/sweeper-22.12.1-i586-1.txz: Upgraded.
kde/umbrello-22.12.1-i586-1.txz: Upgraded.
kde/yakuake-22.12.1-i586-1.txz: Upgraded.
kde/zanshin-22.12.1-i586-1.txz: Upgraded.
l/libqalculate-4.5.1-i586-1.txz: Upgraded.
n/traceroute-2.1.1-i586-1.txz: Upgraded.
xap/mozilla-firefox-108.0.2-i686-1.txz: Upgraded.
xfce/libxfce4ui-4.18.1-i586-1.txz: Upgraded.
xfce/xfce4-screenshooter-1.10.2-i586-1.txz: Upgraded.
xfce/xfce4-systemload-plugin-1.3.2-i586-1.txz: Upgraded.
xfce/xfce4-taskmanager-1.5.5-i586-1.txz: Upgraded.
a/btrfs-progs-6.1.1-i586-1.txz: Upgraded.
ap/vim-9.0.1146-i586-1.txz: Upgraded.
d/mercurial-6.3.2-i586-1.txz: Upgraded.
l/fluidsynth-2.3.1-i586-1.txz: Upgraded.
l/libxkbcommon-1.5.0-i586-1.txz: Upgraded.
n/fetchmail-6.4.35-i586-1.txz: Upgraded.
xap/vim-gvim-9.0.1146-i586-1.txz: Upgraded.
testing/packages/linux-6.1.x/kernel-generic-6.1.3-i586-1.txz: Upgraded.
testing/packages/linux-6.1.x/kernel-generic-smp-6.1.3_smp-i686-1.txz: Upgraded.
testing/packages/linux-6.1.x/kernel-headers-6.1.3_smp-x86-1.txz: Upgraded.
testing/packages/linux-6.1.x/kernel-huge-6.1.3-i586-1.txz: Upgraded.
testing/packages/linux-6.1.x/kernel-huge-smp-6.1.3_smp-i686-1.txz: Upgraded.
testing/packages/linux-6.1.x/kernel-modules-6.1.3-i586-1.txz: Upgraded.
testing/packages/linux-6.1.x/kernel-modules-smp-6.1.3_smp-i686-1.txz: Upgraded.
testing/packages/linux-6.1.x/kernel-source-6.1.3_smp-noarch-1.txz: Upgraded.
ap/lsof-4.96.5-i586-1.txz: Upgraded.
ap/sqlite-3.40.1-i586-1.txz: Upgraded.
kde/bluedevil-5.26.5-i586-1.txz: Upgraded.
kde/breeze-5.26.5-i586-1.txz: Upgraded.
kde/breeze-grub-5.26.5-i586-1.txz: Upgraded.
kde/breeze-gtk-5.26.5-i586-1.txz: Upgraded.
kde/digikam-7.9.0-i586-2.txz: Rebuilt.
kde/drkonqi-5.26.5-i586-1.txz: Upgraded.
kde/kactivitymanagerd-5.26.5-i586-1.txz: Upgraded.
kde/kde-cli-tools-5.26.5-i586-1.txz: Upgraded.
kde/kde-gtk-config-5.26.5-i586-1.txz: Upgraded.
kde/kdecoration-5.26.5-i586-1.txz: Upgraded.
kde/kdeplasma-addons-5.26.5-i586-1.txz: Upgraded.
kde/kgamma5-5.26.5-i586-1.txz: Upgraded.
kde/khotkeys-5.26.5-i586-1.txz: Upgraded.
kde/kinfocenter-5.26.5-i586-1.txz: Upgraded.
kde/kmenuedit-5.26.5-i586-1.txz: Upgraded.
kde/kpipewire-5.26.5-i586-1.txz: Upgraded.
kde/kscreen-5.26.5-i586-1.txz: Upgraded.
kde/kscreenlocker-5.26.5-i586-1.txz: Upgraded.
kde/ksshaskpass-5.26.5-i586-1.txz: Upgraded.
kde/ksystemstats-5.26.5-i586-1.txz: Upgraded.
kde/kwallet-pam-5.26.5-i586-1.txz: Upgraded.
kde/kwayland-integration-5.26.5-i586-1.txz: Upgraded.
kde/kwin-5.26.5-i586-1.txz: Upgraded.
kde/kwrited-5.26.5-i586-1.txz: Upgraded.
kde/layer-shell-qt-5.26.5-i586-1.txz: Upgraded.
kde/libkscreen-5.26.5-i586-1.txz: Upgraded.
kde/libksysguard-5.26.5-i586-1.txz: Upgraded.
kde/milou-5.26.5-i586-1.txz: Upgraded.
kde/oxygen-5.26.5-i586-1.txz: Upgraded.
kde/oxygen-sounds-5.26.5-i586-1.txz: Upgraded.
kde/plasma-browser-integration-5.26.5-i586-1.txz: Upgraded.
kde/plasma-desktop-5.26.5-i586-1.txz: Upgraded.
kde/plasma-disks-5.26.5-i586-1.txz: Upgraded.
kde/plasma-firewall-5.26.5-i586-1.txz: Upgraded.
kde/plasma-integration-5.26.5-i586-1.txz: Upgraded.
kde/plasma-nm-5.26.5-i586-1.txz: Upgraded.
kde/plasma-pa-5.26.5-i586-1.txz: Upgraded.
kde/plasma-sdk-5.26.5-i586-1.txz: Upgraded.
kde/plasma-systemmonitor-5.26.5-i586-1.txz: Upgraded.
kde/plasma-vault-5.26.5-i586-1.txz: Upgraded.
kde/plasma-workspace-5.26.5-i586-1.txz: Upgraded.
kde/plasma-workspace-wallpapers-5.26.5-i586-1.txz: Upgraded.
kde/polkit-kde-agent-1-5.26.5-i586-1.txz: Upgraded.
kde/powerdevil-5.26.5-i586-1.txz: Upgraded.
kde/qqc2-breeze-style-5.26.5-i586-1.txz: Upgraded.
kde/sddm-kcm-5.26.5-i586-1.txz: Upgraded.
kde/systemsettings-5.26.5-i586-1.txz: Upgraded.
kde/xdg-desktop-portal-kde-5.26.5-i586-1.txz: Upgraded.
l/SDL2-2.26.2-i586-1.txz: Upgraded.
l/gst-plugins-bad-free-1.20.5-i586-2.txz: Rebuilt.
l/imagemagick-7.1.0_57-i586-1.txz: Upgraded.
l/libpcap-1.10.2-i586-1.txz: Upgraded.
l/libpsl-0.21.2-i586-1.txz: Upgraded.
l/librevenge-0.0.5-i586-1.txz: Upgraded.
l/libsndfile-1.2.0-i586-1.txz: Upgraded.
l/libtiff-4.4.0-i586-2.txz: Rebuilt.
l/netpbm-11.01.00-i586-1.txz: Upgraded.
l/opencv-4.7.0-i586-1.txz: Upgraded.
l/poppler-23.01.0-i586-1.txz: Upgraded.
n/getmail-6.18.11-i586-1.txz: Upgraded.
n/tcpdump-4.99.2-i586-1.txz: Upgraded.
n/whois-5.5.15-i586-1.txz: Upgraded.
xap/pidgin-2.14.12-i586-1.txz: Upgraded.
xap/rxvt-unicode-9.26-i586-4.txz: Rebuilt.
Napisano: 11 Jan 2023, 20:21
Slackware 64-bit
Tue Jan 10 21:32:00 UTC 2023
a/kernel-firmware-20230110_a1ad1d5-noarch-1.txz: Upgraded.
n/ca-certificates-20221205-noarch-2.txz: Rebuilt.
Make sure that if we're installing this package on another partition (such as
when using installpkg with a --root parameter) that the updates are done on
that partition. Thanks to fulalas.
x/libva-utils-2.17.1-x86_64-1.txz: Upgraded.
xfce/libxfce4util-4.18.1-x86_64-1.txz: Upgraded.
xfce/thunar-4.18.2-x86_64-1.txz: Upgraded.
Mon Jan 9 20:10:55 UTC 2023
a/aaa_libraries-15.1-x86_64-16.txz: Rebuilt.
Upgraded: libncurses.so.6.4, libncursesw.so.6.4, libtinfo.so.6.4,
libform.so.6.4, libformw.so.6.4, libmenu.so.6.4, libmenuw.so.6.4,
libpanel.so.6.4, libglib-2.0.so.0.7400.4, libgmodule-2.0.so.0.7400.4,
libgobject-2.0.so.0.7400.4, libgthread-2.0.so.0.7400.4, libmpfr.so.6.2.0.
a/aaa_terminfo-6.4-x86_64-1.txz: Upgraded.
ap/man-db-2.11.2-x86_64-1.txz: Upgraded.
kde/kio-5.101.0-x86_64-2.txz: Rebuilt.
[PATCH] Restore old behavior for KFileFilterCombo::setFilter
Thanks to marav.
kde/okteta-0.26.10-x86_64-1.txz: Upgraded.
l/libspectre-0.2.12-x86_64-1.txz: Upgraded.
l/mpfr-4.2.0-x86_64-1.txz: Upgraded.
l/ncurses-6.4-x86_64-1.txz: Upgraded.
x/xterm-378-x86_64-1.txz: Upgraded.
xap/libnma-1.10.6-x86_64-1.txz: Upgraded.
Slackware 32-bit
x/libva-utils-2.17.1-i586-1.txz: Upgraded.
xfce/libxfce4util-4.18.1-i586-1.txz: Upgraded.
xfce/thunar-4.18.2-i586-1.txz: Upgraded.
a/aaa_libraries-15.1-i586-16.txz: Rebuilt.
a/aaa_terminfo-6.4-i586-1.txz: Upgraded.
ap/man-db-2.11.2-i586-1.txz: Upgraded.
kde/kio-5.101.0-i586-2.txz: Rebuilt.
Thanks to marav.
kde/okteta-0.26.10-i586-1.txz: Upgraded.
l/libspectre-0.2.12-i586-1.txz: Upgraded.
l/mpfr-4.2.0-i586-1.txz: Upgraded.
l/ncurses-6.4-i586-1.txz: Upgraded.
x/xterm-378-i586-1.txz: Upgraded.
xap/libnma-1.10.6-i586-1.txz: Upgraded.
Napisano: 18 Jan 2023, 21:10
Slackware 64-bit
Wed Jan 18 06:11:54 UTC 2023
ap/diffutils-3.9-x86_64-1.txz: Upgraded.
ap/lsof-4.97.0-x86_64-1.txz: Upgraded.
ap/mpg123-1.31.2-x86_64-1.txz: Upgraded.
d/binutils-2.40-x86_64-1.txz: Upgraded.
d/git-2.39.1-x86_64-1.txz: Upgraded.
d/oprofile-1.4.0-x86_64-11.txz: Rebuilt.
Recompiled against binutils-2.40.
n/httpd-2.4.55-x86_64-1.txz: Upgraded.
This update fixes bugs and the following security issues:
mod_proxy allows a backend to trigger HTTP response splitting.
mod_proxy_ajp possible request smuggling.
mod_dav out of bounds read, or write of zero byte.
https://downloads.apache.org/httpd/CHANGES_2.4.55
https://www.cve.org/CVERecord?id=CVE-2022-37436
https://www.cve.org/CVERecord?id=CVE-2022-36760
https://www.cve.org/CVERecord?id=CVE-2006-20001
x/ibus-libpinyin-1.15.0-x86_64-1.txz: Upgraded.
Compiled against libpinyin-2.8.1.
x/igt-gpu-tools-1.27-x86_64-1.txz: Upgraded.
x/libXpm-3.5.15-x86_64-1.txz: Upgraded.
Infinite loop on unclosed comments.
Runaway loop with width of 0 and enormous height.
Compression commands depend on $PATH.
https://www.cve.org/CVERecord?id=CVE-2022-46285
https://www.cve.org/CVERecord?id=CVE-2022-44617
https://www.cve.org/CVERecord?id=CVE-2022-4883
x/libinput-1.22.1-x86_64-1.txz: Upgraded.
x/libpinyin-2.8.1-x86_64-1.txz: Upgraded.
xap/mozilla-firefox-109.0-x86_64-1.txz: Upgraded.
Thanks to marav for the build help.
https://www.mozilla.org/en-US/firefox/109.0/releasenotes/
https://www.mozilla.org/en-US/security/advisories/mfsa2023-01/
https://www.cve.org/CVERecord?id=CVE-2023-23597
https://www.cve.org/CVERecord?id=CVE-2023-23598
https://www.cve.org/CVERecord?id=CVE-2023-23599
https://www.cve.org/CVERecord?id=CVE-2023-23600
https://www.cve.org/CVERecord?id=CVE-2023-23601
https://www.cve.org/CVERecord?id=CVE-2023-23602
https://www.cve.org/CVERecord?id=CVE-2023-23603
https://www.cve.org/CVERecord?id=CVE-2023-23604
https://www.cve.org/CVERecord?id=CVE-2023-23605
https://www.cve.org/CVERecord?id=CVE-2023-23606
Sun Jan 15 01:02:36 UTC 2023
a/kernel-generic-6.1.6-x86_64-1.txz: Upgraded.
a/kernel-huge-6.1.6-x86_64-1.txz: Upgraded.
a/kernel-modules-6.1.6-x86_64-1.txz: Upgraded.
d/kernel-headers-6.1.6-x86-1.txz: Upgraded.
k/kernel-source-6.1.6-noarch-1.txz: Upgraded.
kde/attica-5.102.0-x86_64-1.txz: Upgraded.
kde/baloo-5.102.0-x86_64-1.txz: Upgraded.
kde/bluez-qt-5.102.0-x86_64-1.txz: Upgraded.
kde/breeze-icons-5.102.0-noarch-1.txz: Upgraded.
kde/extra-cmake-modules-5.102.0-x86_64-1.txz: Upgraded.
kde/frameworkintegration-5.102.0-x86_64-1.txz: Upgraded.
kde/kactivities-5.102.0-x86_64-1.txz: Upgraded.
kde/kactivities-stats-5.102.0-x86_64-1.txz: Upgraded.
kde/kapidox-5.102.0-x86_64-1.txz: Upgraded.
kde/karchive-5.102.0-x86_64-1.txz: Upgraded.
kde/kauth-5.102.0-x86_64-1.txz: Upgraded.
kde/kbookmarks-5.102.0-x86_64-1.txz: Upgraded.
kde/kcalendarcore-5.102.0-x86_64-1.txz: Upgraded.
kde/kcmutils-5.102.0-x86_64-1.txz: Upgraded.
kde/kcodecs-5.102.0-x86_64-1.txz: Upgraded.
kde/kcompletion-5.102.0-x86_64-1.txz: Upgraded.
kde/kconfig-5.102.0-x86_64-1.txz: Upgraded.
kde/kconfigwidgets-5.102.0-x86_64-1.txz: Upgraded.
kde/kcontacts-5.102.0-x86_64-1.txz: Upgraded.
kde/kcoreaddons-5.102.0-x86_64-1.txz: Upgraded.
kde/kcrash-5.102.0-x86_64-1.txz: Upgraded.
kde/kdav-5.102.0-x86_64-1.txz: Upgraded.
kde/kdbusaddons-5.102.0-x86_64-1.txz: Upgraded.
kde/kdeclarative-5.102.0-x86_64-1.txz: Upgraded.
kde/kded-5.102.0-x86_64-1.txz: Upgraded.
kde/kdelibs4support-5.102.0-x86_64-1.txz: Upgraded.
kde/kdesignerplugin-5.102.0-x86_64-1.txz: Upgraded.
kde/kdesu-5.102.0-x86_64-1.txz: Upgraded.
kde/kdewebkit-5.102.0-x86_64-1.txz: Upgraded.
kde/kdnssd-5.102.0-x86_64-1.txz: Upgraded.
kde/kdoctools-5.102.0-x86_64-1.txz: Upgraded.
kde/kemoticons-5.102.0-x86_64-1.txz: Upgraded.
kde/kfilemetadata-5.102.0-x86_64-1.txz: Upgraded.
kde/kglobalaccel-5.102.0-x86_64-1.txz: Upgraded.
kde/kguiaddons-5.102.0-x86_64-1.txz: Upgraded.
kde/kholidays-5.102.0-x86_64-1.txz: Upgraded.
kde/khtml-5.102.0-x86_64-1.txz: Upgraded.
kde/ki18n-5.102.0-x86_64-1.txz: Upgraded.
kde/kiconthemes-5.102.0-x86_64-1.txz: Upgraded.
kde/kidletime-5.102.0-x86_64-1.txz: Upgraded.
kde/kimageformats-5.102.0-x86_64-1.txz: Upgraded.
kde/kinit-5.102.0-x86_64-1.txz: Upgraded.
kde/kio-5.102.0-x86_64-1.txz: Upgraded.
kde/kirigami2-5.102.0-x86_64-1.txz: Upgraded.
kde/kitemmodels-5.102.0-x86_64-1.txz: Upgraded.
kde/kitemviews-5.102.0-x86_64-1.txz: Upgraded.
kde/kjobwidgets-5.102.0-x86_64-1.txz: Upgraded.
kde/kjs-5.102.0-x86_64-1.txz: Upgraded.
kde/kjsembed-5.102.0-x86_64-1.txz: Upgraded.
kde/kmediaplayer-5.102.0-x86_64-1.txz: Upgraded.
kde/knewstuff-5.102.0-x86_64-1.txz: Upgraded.
kde/knotifications-5.102.0-x86_64-1.txz: Upgraded.
kde/knotifyconfig-5.102.0-x86_64-1.txz: Upgraded.
kde/kpackage-5.102.0-x86_64-1.txz: Upgraded.
kde/kparts-5.102.0-x86_64-1.txz: Upgraded.
kde/kpeople-5.102.0-x86_64-1.txz: Upgraded.
kde/kplotting-5.102.0-x86_64-1.txz: Upgraded.
kde/kpty-5.102.0-x86_64-1.txz: Upgraded.
kde/kquickcharts-5.102.0-x86_64-1.txz: Upgraded.
kde/kross-5.102.0-x86_64-1.txz: Upgraded.
kde/krunner-5.102.0-x86_64-1.txz: Upgraded.
kde/kservice-5.102.0-x86_64-1.txz: Upgraded.
kde/ktexteditor-5.102.0-x86_64-1.txz: Upgraded.
kde/ktextwidgets-5.102.0-x86_64-1.txz: Upgraded.
kde/kunitconversion-5.102.0-x86_64-1.txz: Upgraded.
kde/kwallet-5.102.0-x86_64-1.txz: Upgraded.
kde/kwayland-5.102.0-x86_64-1.txz: Upgraded.
kde/kwidgetsaddons-5.102.0-x86_64-1.txz: Upgraded.
kde/kwindowsystem-5.102.0-x86_64-1.txz: Upgraded.
kde/kxmlgui-5.102.0-x86_64-1.txz: Upgraded.
kde/kxmlrpcclient-5.102.0-x86_64-1.txz: Upgraded.
kde/modemmanager-qt-5.102.0-x86_64-1.txz: Upgraded.
kde/networkmanager-qt-5.102.0-x86_64-1.txz: Upgraded.
kde/oxygen-icons5-5.102.0-noarch-1.txz: Upgraded.
kde/plasma-framework-5.102.0-x86_64-1.txz: Upgraded.
kde/prison-5.102.0-x86_64-1.txz: Upgraded.
kde/purpose-5.102.0-x86_64-1.txz: Upgraded.
kde/qqc2-desktop-style-5.102.0-x86_64-1.txz: Upgraded.
kde/solid-5.102.0-x86_64-1.txz: Upgraded.
kde/sonnet-5.102.0-x86_64-1.txz: Upgraded.
kde/syndication-5.102.0-x86_64-1.txz: Upgraded.
kde/syntax-highlighting-5.102.0-x86_64-1.txz: Upgraded.
kde/threadweaver-5.102.0-x86_64-1.txz: Upgraded.
l/qt5-5.15.8_20230110_755033ba-x86_64-1.txz: Upgraded.
Fri Jan 13 20:29:55 UTC 2023
a/mcelog-191-x86_64-1.txz: Upgraded.
kde/kid3-3.9.3-x86_64-1.txz: Upgraded.
l/fuse3-3.13.0-x86_64-1.txz: Upgraded.
l/libpcap-1.10.3-x86_64-1.txz: Upgraded.
l/libwebp-1.3.0-x86_64-1.txz: Upgraded.
n/netatalk-3.1.14-x86_64-1.txz: Upgraded.
Netatalk through 3.1.13 has an afp_getappl heap-based buffer overflow
resulting in code execution via a crafted .appl file.
https://www.cve.org/CVERecord?id=CVE-2022-45188
n/tcpdump-4.99.3-x86_64-1.txz: Upgraded.
xfce/xfce4-screenshooter-1.10.3-x86_64-1.txz: Upgraded.
Thu Jan 12 21:42:02 UTC 2023
a/aaa_libraries-15.1-x86_64-17.txz: Rebuilt.
Upgraded: liblzma.so.5.4.1.
a/ed-1.19-x86_64-1.txz: Upgraded.
a/kernel-generic-6.1.5-x86_64-1.txz: Upgraded.
a/kernel-huge-6.1.5-x86_64-1.txz: Upgraded.
a/kernel-modules-6.1.5-x86_64-1.txz: Upgraded.
a/xz-5.4.1-x86_64-1.txz: Upgraded.
d/kernel-headers-6.1.5-x86-1.txz: Upgraded.
k/kernel-source-6.1.5-noarch-1.txz: Upgraded.
l/pipewire-0.3.64-x86_64-1.txz: Upgraded.
n/iptables-1.8.9-x86_64-1.txz: Upgraded.
x/mesa-22.3.3-x86_64-1.txz: Upgraded.
xap/xine-ui-0.99.14-x86_64-1.txz: Upgraded.
Wed Jan 11 19:31:20 UTC 2023
d/patchelf-0.17.2-x86_64-1.txz: Upgraded.
kde/kdevelop-pg-qt-2.2.2-x86_64-1.txz: Upgraded.
n/NetworkManager-1.40.10-x86_64-1.txz: Upgraded.
xfce/xfce4-panel-4.18.1-x86_64-1.txz: Upgraded.
testing/packages/rust-1.66.1-x86_64-1.txz: Upgraded.
Slackware 32-bit
ap/diffutils-3.9-i586-1.txz: Upgraded.
ap/lsof-4.97.0-i586-1.txz: Upgraded.
ap/mpg123-1.31.2-i586-1.txz: Upgraded.
d/binutils-2.40-i586-1.txz: Upgraded.
d/git-2.39.1-i586-1.txz: Upgraded.
d/oprofile-1.4.0-i586-11.txz: Rebuilt.
n/httpd-2.4.55-i586-1.txz: Upgraded.
x/ibus-libpinyin-1.15.0-i586-1.txz: Upgraded.
x/igt-gpu-tools-1.27-i586-1.txz: Upgraded.
x/libXpm-3.5.15-i586-1.txz: Upgraded.
x/libinput-1.22.1-i586-1.txz: Upgraded.
x/libpinyin-2.8.1-i586-1.txz: Upgraded.
xap/mozilla-firefox-109.0-i686-1.txz: Upgraded.
a/kernel-generic-6.1.6-i586-1.txz: Upgraded.
a/kernel-generic-smp-6.1.6_smp-i686-1.txz: Upgraded.
a/kernel-huge-6.1.6-i586-1.txz: Upgraded.
a/kernel-huge-smp-6.1.6_smp-i686-1.txz: Upgraded.
a/kernel-modules-6.1.6-i586-1.txz: Upgraded.
a/kernel-modules-smp-6.1.6_smp-i686-1.txz: Upgraded.
d/kernel-headers-6.1.6_smp-x86-1.txz: Upgraded.
k/kernel-source-6.1.6_smp-noarch-1.txz: Upgraded.
kde/attica-5.102.0-i586-1.txz: Upgraded.
kde/baloo-5.102.0-i586-1.txz: Upgraded.
kde/bluez-qt-5.102.0-i586-1.txz: Upgraded.
kde/extra-cmake-modules-5.102.0-i586-1.txz: Upgraded.
kde/frameworkintegration-5.102.0-i586-1.txz: Upgraded.
kde/kactivities-5.102.0-i586-1.txz: Upgraded.
kde/kactivities-stats-5.102.0-i586-1.txz: Upgraded.
kde/kapidox-5.102.0-i586-1.txz: Upgraded.
kde/karchive-5.102.0-i586-1.txz: Upgraded.
kde/kauth-5.102.0-i586-1.txz: Upgraded.
kde/kbookmarks-5.102.0-i586-1.txz: Upgraded.
kde/kcalendarcore-5.102.0-i586-1.txz: Upgraded.
kde/kcmutils-5.102.0-i586-1.txz: Upgraded.
kde/kcodecs-5.102.0-i586-1.txz: Upgraded.
kde/kcompletion-5.102.0-i586-1.txz: Upgraded.
kde/kconfig-5.102.0-i586-1.txz: Upgraded.
kde/kconfigwidgets-5.102.0-i586-1.txz: Upgraded.
kde/kcontacts-5.102.0-i586-1.txz: Upgraded.
kde/kcoreaddons-5.102.0-i586-1.txz: Upgraded.
kde/kcrash-5.102.0-i586-1.txz: Upgraded.
kde/kdav-5.102.0-i586-1.txz: Upgraded.
kde/kdbusaddons-5.102.0-i586-1.txz: Upgraded.
kde/kdeclarative-5.102.0-i586-1.txz: Upgraded.
kde/kded-5.102.0-i586-1.txz: Upgraded.
kde/kdelibs4support-5.102.0-i586-1.txz: Upgraded.
kde/kdesignerplugin-5.102.0-i586-1.txz: Upgraded.
kde/kdesu-5.102.0-i586-1.txz: Upgraded.
kde/kdewebkit-5.102.0-i586-1.txz: Upgraded.
kde/kdnssd-5.102.0-i586-1.txz: Upgraded.
kde/kdoctools-5.102.0-i586-1.txz: Upgraded.
kde/kemoticons-5.102.0-i586-1.txz: Upgraded.
kde/kfilemetadata-5.102.0-i586-1.txz: Upgraded.
kde/kglobalaccel-5.102.0-i586-1.txz: Upgraded.
kde/kguiaddons-5.102.0-i586-1.txz: Upgraded.
kde/kholidays-5.102.0-i586-1.txz: Upgraded.
kde/khtml-5.102.0-i586-1.txz: Upgraded.
kde/ki18n-5.102.0-i586-1.txz: Upgraded.
kde/kiconthemes-5.102.0-i586-1.txz: Upgraded.
kde/kidletime-5.102.0-i586-1.txz: Upgraded.
kde/kimageformats-5.102.0-i586-1.txz: Upgraded.
kde/kinit-5.102.0-i586-1.txz: Upgraded.
kde/kio-5.102.0-i586-1.txz: Upgraded.
kde/kirigami2-5.102.0-i586-1.txz: Upgraded.
kde/kitemmodels-5.102.0-i586-1.txz: Upgraded.
kde/kitemviews-5.102.0-i586-1.txz: Upgraded.
kde/kjobwidgets-5.102.0-i586-1.txz: Upgraded.
kde/kjs-5.102.0-i586-1.txz: Upgraded.
kde/kjsembed-5.102.0-i586-1.txz: Upgraded.
kde/kmediaplayer-5.102.0-i586-1.txz: Upgraded.
kde/knewstuff-5.102.0-i586-1.txz: Upgraded.
kde/knotifications-5.102.0-i586-1.txz: Upgraded.
kde/knotifyconfig-5.102.0-i586-1.txz: Upgraded.
kde/kpackage-5.102.0-i586-1.txz: Upgraded.
kde/kparts-5.102.0-i586-1.txz: Upgraded.
kde/kpeople-5.102.0-i586-1.txz: Upgraded.
kde/kplotting-5.102.0-i586-1.txz: Upgraded.
kde/kpty-5.102.0-i586-1.txz: Upgraded.
kde/kquickcharts-5.102.0-i586-1.txz: Upgraded.
kde/kross-5.102.0-i586-1.txz: Upgraded.
kde/krunner-5.102.0-i586-1.txz: Upgraded.
kde/kservice-5.102.0-i586-1.txz: Upgraded.
kde/ktexteditor-5.102.0-i586-1.txz: Upgraded.
kde/ktextwidgets-5.102.0-i586-1.txz: Upgraded.
kde/kunitconversion-5.102.0-i586-1.txz: Upgraded.
kde/kwallet-5.102.0-i586-1.txz: Upgraded.
kde/kwayland-5.102.0-i586-1.txz: Upgraded.
kde/kwidgetsaddons-5.102.0-i586-1.txz: Upgraded.
kde/kwindowsystem-5.102.0-i586-1.txz: Upgraded.
kde/kxmlgui-5.102.0-i586-1.txz: Upgraded.
kde/kxmlrpcclient-5.102.0-i586-1.txz: Upgraded.
kde/modemmanager-qt-5.102.0-i586-1.txz: Upgraded.
kde/networkmanager-qt-5.102.0-i586-1.txz: Upgraded.
kde/plasma-framework-5.102.0-i586-1.txz: Upgraded.
kde/prison-5.102.0-i586-1.txz: Upgraded.
kde/purpose-5.102.0-i586-1.txz: Upgraded.
kde/qqc2-desktop-style-5.102.0-i586-1.txz: Upgraded.
kde/solid-5.102.0-i586-1.txz: Upgraded.
kde/sonnet-5.102.0-i586-1.txz: Upgraded.
kde/syndication-5.102.0-i586-1.txz: Upgraded.
kde/syntax-highlighting-5.102.0-i586-1.txz: Upgraded.
kde/threadweaver-5.102.0-i586-1.txz: Upgraded.
l/qt5-5.15.8_20230110_755033ba-i586-1.txz: Upgraded.
extra/linux-6.1.6-nosmp-sdk/*: Upgraded.
a/mcelog-191-i586-1.txz: Upgraded.
kde/kid3-3.9.3-i586-1.txz: Upgraded.
l/fuse3-3.13.0-i586-1.txz: Upgraded.
l/libpcap-1.10.3-i586-1.txz: Upgraded.
l/libwebp-1.3.0-i586-1.txz: Upgraded.
n/netatalk-3.1.14-i586-1.txz: Upgraded.
n/tcpdump-4.99.3-i586-1.txz: Upgraded.
xfce/xfce4-screenshooter-1.10.3-i586-1.txz: Upgraded.
a/aaa_libraries-15.1-i586-17.txz: Rebuilt.
a/ed-1.19-i586-1.txz: Upgraded.
a/kernel-generic-6.1.5-i586-1.txz: Upgraded.
a/kernel-generic-smp-6.1.5_smp-i686-1.txz: Upgraded.
a/kernel-huge-6.1.5-i586-1.txz: Upgraded.
a/kernel-huge-smp-6.1.5_smp-i686-1.txz: Upgraded.
a/kernel-modules-6.1.5-i586-1.txz: Upgraded.
a/kernel-modules-smp-6.1.5_smp-i686-1.txz: Upgraded.
a/xz-5.4.1-i586-1.txz: Upgraded.
d/kernel-headers-6.1.5_smp-x86-1.txz: Upgraded.
k/kernel-source-6.1.5_smp-noarch-1.txz: Upgraded.
l/pipewire-0.3.64-i586-1.txz: Upgraded.
n/iptables-1.8.9-i586-1.txz: Upgraded.
x/mesa-22.3.3-i586-1.txz: Upgraded.
xap/xine-ui-0.99.14-i686-1.txz: Upgraded.
extra/linux-6.1.5-nosmp-sdk/*: Upgraded.
d/patchelf-0.17.2-i586-1.txz: Upgraded.
kde/kdevelop-pg-qt-2.2.2-i586-1.txz: Upgraded.
n/NetworkManager-1.40.10-i586-1.txz: Upgraded.
xfce/xfce4-panel-4.18.1-i586-1.txz: Upgraded.
testing/packages/rust-1.66.1-i686-1.txz: Upgraded.
Napisano: 21 Jan 2023, 17:42
Slackware 64-bit
Fri Jan 20 23:58:24 UTC 2023
ap/mc-4.8.29-x86_64-1.txz: Upgraded.
d/cmake-3.25.2-x86_64-1.txz: Upgraded.
l/editorconfig-core-c-0.12.6-x86_64-1.txz: Upgraded.
l/glib2-2.74.5-x86_64-1.txz: Upgraded.
l/gtk+3-3.24.36-x86_64-1.txz: Upgraded.
l/talloc-2.4.0-x86_64-1.txz: Upgraded.
l/tevent-0.14.0-x86_64-1.txz: Upgraded.
xap/mozilla-thunderbird-102.7.0-x86_64-1.txz: Upgraded.
https://www.mozilla.org/en-US/thunderbird/102.7.0/releasenotes/
https://www.mozilla.org/en-US/security/known-vulnerabilities/thunderbird/#thunderbird102.7
xap/seamonkey-2.53.15-x86_64-1.txz: Upgraded.
https://www.seamonkey-project.org/releases/seamonkey2.53.15
Thu Jan 19 21:07:32 UTC 2023
a/pkgtools-15.1-noarch-4.txz: Rebuilt.
makepkg: also let xz decide how many threads to use on ARM platforms aarch64
and riscv64. Thanks to Stuart Winter.
installpkg: fix reversed test for if a --threads option was given. It appears
that it's been wrong for years but since xz didn't support threaded
decompression yet it wasn't noticed.
a/xz-5.4.1-x86_64-2.txz: Rebuilt.
Reduce default verbosity from V_WARNING to V_ERROR to avoid sending non-fatal
memory usage information to stderr.
kde/plasma-wayland-protocols-1.10.0-x86_64-1.txz: Upgraded.
l/exiv2-0.27.6-x86_64-1.txz: Upgraded.
l/tdb-1.4.8-x86_64-1.txz: Upgraded.
x/igt-gpu-tools-1.27.1-x86_64-1.txz: Upgraded.
x/libX11-1.8.3-x86_64-2.txz: Rebuilt.
[PATCH] Fix a9e845 and 797755 Allow X*IfEvent() to reenter libX11
Thanks to marav.
Thu Jan 19 00:40:12 UTC 2023
a/kernel-firmware-20230117_7e4f0ed-noarch-1.txz: Upgraded.
a/kernel-generic-6.1.7-x86_64-1.txz: Upgraded.
a/kernel-huge-6.1.7-x86_64-1.txz: Upgraded.
a/kernel-modules-6.1.7-x86_64-1.txz: Upgraded.
a/pkgtools-15.1-noarch-3.txz: Rebuilt.
installpkg: allow xz to use all the available CPU threads.
makepkg: by default, allow xz to determine how many threads to use. However,
on 32-bit platforms default to 2 threads since we were using this before. If
allowed to decide, xz seems to only want to use a single thread on 32-bit.
ap/nano-7.2-x86_64-1.txz: Upgraded.
ap/sudo-1.9.12p2-x86_64-1.txz: Upgraded.
This update fixes a flaw in sudo's -e option (aka sudoedit) that could allow
a malicious user with sudoedit privileges to edit arbitrary files.
https://www.cve.org/CVERecord?id=CVE-2023-22809
d/kernel-headers-6.1.7-x86-1.txz: Upgraded.
k/kernel-source-6.1.7-noarch-1.txz: Upgraded.
kde/plasma-wayland-protocols-1.10-x86_64-1.txz: Upgraded.
Slackware 32-bit
ap/mc-4.8.29-i586-1.txz: Upgraded.
d/cmake-3.25.2-i586-1.txz: Upgraded.
l/editorconfig-core-c-0.12.6-i586-1.txz: Upgraded.
l/glib2-2.74.5-i586-1.txz: Upgraded.
l/gtk+3-3.24.36-i586-1.txz: Upgraded.
l/talloc-2.4.0-i586-1.txz: Upgraded.
l/tevent-0.14.0-i586-1.txz: Upgraded.
xap/mozilla-thunderbird-102.7.0-i686-1.txz: Upgraded.
xap/seamonkey-2.53.15-i686-1.txz: Upgraded.
a/xz-5.4.1-i586-2.txz: Rebuilt.
kde/plasma-wayland-protocols-1.10.0-i586-1.txz: Upgraded.
l/exiv2-0.27.6-i586-1.txz: Upgraded.
l/tdb-1.4.8-i586-1.txz: Upgraded.
x/igt-gpu-tools-1.27.1-i586-1.txz: Upgraded.
x/libX11-1.8.3-i586-2.txz: Rebuilt.
Thanks to marav.
a/kernel-generic-6.1.7-i586-1.txz: Upgraded.
a/kernel-generic-smp-6.1.7_smp-i686-1.txz: Upgraded.
a/kernel-huge-6.1.7-i586-1.txz: Upgraded.
a/kernel-huge-smp-6.1.7_smp-i686-1.txz: Upgraded.
a/kernel-modules-6.1.7-i586-1.txz: Upgraded.
a/kernel-modules-smp-6.1.7_smp-i686-1.txz: Upgraded.
ap/nano-7.2-i586-1.txz: Upgraded.
ap/sudo-1.9.12p2-i586-1.txz: Upgraded.
d/kernel-headers-6.1.7_smp-x86-1.txz: Upgraded.
k/kernel-source-6.1.7_smp-noarch-1.txz: Upgraded.
kde/plasma-wayland-protocols-1.10-i586-1.txz: Upgraded.
extra/linux-6.1.7-nosmp-sdk/*: Upgraded.
Napisano: 29 Jan 2023, 19:52
Slackware 64-bit
Fri Jan 27 20:08:12 UTC 2023
n/samba-4.17.5-x86_64-1.txz: Upgraded.
BUG 15240: CVE-2022-38023 [SECURITY] Samba should refuse RC4 (aka md5)
based SChannel on NETLOGON (additional changes).
https://www.samba.org/samba/security/CVE-2022-38023.html
https://www.cve.org/CVERecord?id=CVE-2022-38023
x/mesa-22.3.4-x86_64-1.txz: Upgraded.
x/xf86-video-vmware-13.4.0-x86_64-1.txz: Upgraded.
Thu Jan 26 21:12:35 UTC 2023
a/btrfs-progs-6.1.3-x86_64-1.txz: Upgraded.
l/pipewire-0.3.65-x86_64-1.txz: Upgraded.
n/NetworkManager-1.40.12-x86_64-1.txz: Upgraded.
xap/xine-lib-1.2.13-x86_64-1.txz: Upgraded.
Thu Jan 26 00:34:41 UTC 2023
ap/cups-filters-1.28.17-x86_64-1.txz: Upgraded.
ap/vim-9.0.1241-x86_64-1.txz: Upgraded.
Fixed a security issue:
Heap-based Buffer Overflow in GitHub repository vim/vim prior to 9.0.1225.
https://www.cve.org/CVERecord?id=CVE-2023-0433
d/guile-3.0.9-x86_64-1.txz: Upgraded.
d/poke-3.0-x86_64-1.txz: Upgraded.
l/nodejs-19.5.0-x86_64-1.txz: Upgraded.
n/bind-9.18.11-x86_64-1.txz: Upgraded.
An UPDATE message flood could cause :iscman:`named` to exhaust all
available memory. This flaw was addressed by adding a new
:any:`update-quota` option that controls the maximum number of
outstanding DNS UPDATE messages that :iscman:`named` can hold in a
queue at any given time (default: 100).
:iscman:`named` could crash with an assertion failure when an RRSIG
query was received and :any:`stale-answer-client-timeout` was set to a
non-zero value. This has been fixed.
:iscman:`named` running as a resolver with the
:any:`stale-answer-client-timeout` option set to any value greater
than ``0`` could crash with an assertion failure, when the
:any:`recursive-clients` soft quota was reached. This has been fixed.
https://kb.isc.org/docs/cve-2022-3094
https://kb.isc.org/docs/cve-2022-3736
https://kb.isc.org/docs/cve-2022-3924
https://www.cve.org/CVERecord?id=CVE-2022-3094
https://www.cve.org/CVERecord?id=CVE-2022-3736
https://www.cve.org/CVERecord?id=CVE-2022-3924
n/openvpn-2.6.0-x86_64-1.txz: Upgraded.
xap/vim-gvim-9.0.1241-x86_64-1.txz: Upgraded.
Tue Jan 24 20:32:45 UTC 2023
a/kernel-firmware-20230120_bb2d42d-noarch-1.txz: Upgraded.
a/kernel-generic-6.1.8-x86_64-1.txz: Upgraded.
a/kernel-huge-6.1.8-x86_64-1.txz: Upgraded.
a/kernel-modules-6.1.8-x86_64-1.txz: Upgraded.
ap/texinfo-7.0.2-x86_64-1.txz: Upgraded.
d/kernel-headers-6.1.8-x86-1.txz: Upgraded.
k/kernel-source-6.1.8-noarch-1.txz: Upgraded.
Tue Jan 24 03:09:01 UTC 2023
l/gst-plugins-bad-free-1.22.0-x86_64-1.txz: Upgraded.
l/gst-plugins-base-1.22.0-x86_64-1.txz: Upgraded.
l/gst-plugins-good-1.22.0-x86_64-1.txz: Upgraded.
l/gst-plugins-libav-1.22.0-x86_64-1.txz: Upgraded.
l/gstreamer-1.22.0-x86_64-1.txz: Upgraded.
Mon Jan 23 21:25:42 UTC 2023
kde/krita-5.1.5-x86_64-2.txz: Rebuilt.
Recompiled against quazip-1.4.
Thanks to marav.
Mon Jan 23 20:34:38 UTC 2023
ap/ddrescue-1.27-x86_64-1.txz: Upgraded.
ap/lsof-4.98.0-x86_64-1.txz: Upgraded.
d/parallel-20230122-noarch-1.txz: Upgraded.
l/imagemagick-7.1.0_58-x86_64-1.txz: Upgraded.
l/neon-0.32.5-x86_64-1.txz: Upgraded.
l/quazip-1.4-x86_64-1.txz: Upgraded.
n/getmail-6.18.12-x86_64-1.txz: Upgraded.
n/postfix-3.7.4-x86_64-1.txz: Upgraded.
x/libwacom-2.6.0-x86_64-1.txz: Upgraded.
xfce/thunar-4.18.3-x86_64-1.txz: Upgraded.
xfce/xfdesktop-4.18.1-x86_64-1.txz: Upgraded.
Slackware 32-bit
n/samba-4.17.5-i586-1.txz: Upgraded.
x/mesa-22.3.4-i586-1.txz: Upgraded.
x/xf86-video-vmware-13.4.0-i586-1.txz: Upgraded.
a/btrfs-progs-6.1.3-i586-1.txz: Upgraded.
l/pipewire-0.3.65-i586-1.txz: Upgraded.
n/NetworkManager-1.40.12-i586-1.txz: Upgraded.
xap/xine-lib-1.2.13-i586-1.txz: Upgraded.
ap/cups-filters-1.28.17-i586-1.txz: Upgraded.
ap/vim-9.0.1241-i586-1.txz: Upgraded.
d/guile-3.0.9-i586-1.txz: Upgraded.
d/poke-3.0-i586-1.txz: Upgraded.
l/nodejs-19.5.0-i586-1.txz: Upgraded.
n/bind-9.18.11-i586-1.txz: Upgraded.
n/openvpn-2.6.0-i586-1.txz: Upgraded.
xap/vim-gvim-9.0.1241-i586-1.txz: Upgraded.
a/kernel-generic-6.1.8-i586-1.txz: Upgraded.
a/kernel-generic-smp-6.1.8_smp-i686-1.txz: Upgraded.
a/kernel-huge-6.1.8-i586-1.txz: Upgraded.
a/kernel-huge-smp-6.1.8_smp-i686-1.txz: Upgraded.
a/kernel-modules-6.1.8-i586-1.txz: Upgraded.
a/kernel-modules-smp-6.1.8_smp-i686-1.txz: Upgraded.
ap/texinfo-7.0.2-i586-1.txz: Upgraded.
d/kernel-headers-6.1.8_smp-x86-1.txz: Upgraded.
k/kernel-source-6.1.8_smp-noarch-1.txz: Upgraded.
extra/linux-6.1.8-nosmp-sdk/*: Upgraded.
l/gst-plugins-bad-free-1.22.0-i586-1.txz: Upgraded.
l/gst-plugins-base-1.22.0-i586-1.txz: Upgraded.
l/gst-plugins-good-1.22.0-i586-1.txz: Upgraded.
l/gst-plugins-libav-1.22.0-i586-1.txz: Upgraded.
l/gstreamer-1.22.0-i586-1.txz: Upgraded.
kde/krita-5.1.5-i586-2.txz: Rebuilt.
Thanks to marav.
ap/ddrescue-1.27-i586-1.txz: Upgraded.
ap/lsof-4.98.0-i586-1.txz: Upgraded.
l/imagemagick-7.1.0_58-i586-1.txz: Upgraded.
l/neon-0.32.5-i586-1.txz: Upgraded.
l/quazip-1.4-i586-1.txz: Upgraded.
n/getmail-6.18.12-i586-1.txz: Upgraded.
n/postfix-3.7.4-i586-1.txz: Upgraded.
x/libwacom-2.6.0-i586-1.txz: Upgraded.
xfce/thunar-4.18.3-i586-1.txz: Upgraded.
xfce/xfdesktop-4.18.1-i586-1.txz: Upgraded.
Napisano: 07 Feb 2023, 16:31
Slackware 64-bit
Mon Feb 6 20:47:34 UTC 2023
a/kernel-generic-6.1.10-x86_64-1.txz: Upgraded.
a/kernel-huge-6.1.10-x86_64-1.txz: Upgraded.
a/kernel-modules-6.1.10-x86_64-1.txz: Upgraded.
d/kernel-headers-6.1.10-x86-1.txz: Upgraded.
k/kernel-source-6.1.10-noarch-1.txz: Upgraded.
l/imagemagick-7.1.0_61-x86_64-1.txz: Upgraded.
l/openal-soft-1.23.0-x86_64-1.txz: Upgraded.
Sun Feb 5 20:39:36 UTC 2023
ap/htop-3.2.2-x86_64-1.txz: Upgraded.
l/fuse3-3.13.1-x86_64-1.txz: Upgraded.
l/pangomm-2.46.3-x86_64-1.txz: Upgraded.
l/tevent-0.14.1-x86_64-1.txz: Upgraded.
n/dnsmasq-2.89-x86_64-1.txz: Upgraded.
x/libX11-1.8.4-x86_64-1.txz: Upgraded.
x/xkeyboard-config-2.38-noarch-1.txz: Upgraded.
x/xvidtune-1.0.4-x86_64-1.txz: Upgraded.
Fri Feb 3 20:04:33 UTC 2023
a/aaa_glibc-solibs-2.37-x86_64-2.txz: Rebuilt.
a/e2fsprogs-1.46.6-x86_64-1.txz: Upgraded.
a/hwdata-0.367-noarch-1.txz: Upgraded.
l/glibc-2.37-x86_64-2.txz: Rebuilt.
[PATCH] Account for grouping in printf width (bug 23432).
This issue could cause a overflow with sprintf in the corner case where an
application computes the size of buffer to be exactly enough to fit the
digits in question, but sprintf ends up writing a couple of extra bytes.
https://www.cve.org/CVERecord?id=CVE-2023-25139
l/glibc-i18n-2.37-x86_64-2.txz: Rebuilt.
l/glibc-profile-2.37-x86_64-2.txz: Rebuilt.
l/libcap-2.67-x86_64-1.txz: Upgraded.
l/poppler-data-0.4.12-noarch-1.txz: Upgraded.
extra/php81/php81-8.1.15-x86_64-1.txz: Upgraded.
testing/packages/samba-4.17.5-x86_64-2.txz: Rebuilt.
Build with the bundled Heimdal instead of the system MIT Kerberos, since MIT
Kerberos has more issues when Samba is used as an AD DC. I'd appreciate any
feedback on the "Samba on Slackware 15" thread on LQ about how well this
works. Although it's not the sort of change I'd normally make in a -stable
release such as Slackware 15.0, in this case I'm considering it if it can
be done painlessly for any existing users... but I'll need to see some
reports about this. I'd like to note that yes, of course we saw the
"experimental" label in the configure flag we used to build Samba, but we
also saw another prominent Linux distribution go ahead and use it anyway. :)
And the Samba package built against MIT Kerberos cooked in the previous
-current development cycle for a couple of years without any objections.
Anyway, hopefully we'll get some testing from folks out there with networks
that use AD and go from there.
Thanks to Rowland Penny of the Samba team for clarifying this situation.
Thu Feb 2 22:52:48 UTC 2023
a/aaa_glibc-solibs-2.37-x86_64-1.txz: Upgraded.
kde/akonadi-22.12.2-x86_64-1.txz: Upgraded.
kde/akonadi-calendar-22.12.2-x86_64-1.txz: Upgraded.
kde/akonadi-calendar-tools-22.12.2-x86_64-1.txz: Upgraded.
kde/akonadi-contacts-22.12.2-x86_64-1.txz: Upgraded.
kde/akonadi-import-wizard-22.12.2-x86_64-1.txz: Upgraded.
kde/akonadi-mime-22.12.2-x86_64-1.txz: Upgraded.
kde/akonadi-notes-22.12.2-x86_64-1.txz: Upgraded.
kde/akonadi-search-22.12.2-x86_64-1.txz: Upgraded.
kde/akonadiconsole-22.12.2-x86_64-1.txz: Upgraded.
kde/akregator-22.12.2-x86_64-1.txz: Upgraded.
kde/analitza-22.12.2-x86_64-1.txz: Upgraded.
kde/ark-22.12.2-x86_64-1.txz: Upgraded.
kde/artikulate-22.12.2-x86_64-1.txz: Upgraded.
kde/audiocd-kio-22.12.2-x86_64-1.txz: Upgraded.
kde/baloo-widgets-22.12.2-x86_64-1.txz: Upgraded.
kde/blinken-22.12.2-x86_64-1.txz: Upgraded.
kde/bomber-22.12.2-x86_64-1.txz: Upgraded.
kde/bovo-22.12.2-x86_64-1.txz: Upgraded.
kde/calendarsupport-22.12.2-x86_64-1.txz: Upgraded.
kde/cantor-22.12.2-x86_64-1.txz: Upgraded.
kde/cervisia-22.12.2-x86_64-1.txz: Upgraded.
kde/dolphin-22.12.2-x86_64-1.txz: Upgraded.
kde/dolphin-plugins-22.12.2-x86_64-1.txz: Upgraded.
kde/dragon-22.12.2-x86_64-1.txz: Upgraded.
kde/elisa-22.12.2-x86_64-1.txz: Upgraded.
kde/eventviews-22.12.2-x86_64-1.txz: Upgraded.
kde/falkon-22.12.2-x86_64-1.txz: Upgraded.
kde/ffmpegthumbs-22.12.2-x86_64-1.txz: Upgraded.
kde/filelight-22.12.2-x86_64-1.txz: Upgraded.
kde/granatier-22.12.2-x86_64-1.txz: Upgraded.
kde/grantlee-editor-22.12.2-x86_64-1.txz: Upgraded.
kde/grantleetheme-22.12.2-x86_64-1.txz: Upgraded.
kde/gwenview-22.12.2-x86_64-1.txz: Upgraded.
kde/incidenceeditor-22.12.2-x86_64-1.txz: Upgraded.
kde/itinerary-22.12.2-x86_64-1.txz: Upgraded.
kde/juk-22.12.2-x86_64-1.txz: Upgraded.
kde/k3b-22.12.2-x86_64-1.txz: Upgraded.
kde/kaddressbook-22.12.2-x86_64-1.txz: Upgraded.
kde/kalarm-22.12.2-x86_64-1.txz: Upgraded.
kde/kalendar-22.12.2-x86_64-1.txz: Upgraded.
kde/kalgebra-22.12.2-x86_64-1.txz: Upgraded.
kde/kalzium-22.12.2-x86_64-1.txz: Upgraded.
kde/kamera-22.12.2-x86_64-1.txz: Upgraded.
kde/kamoso-22.12.2-x86_64-1.txz: Upgraded.
kde/kanagram-22.12.2-x86_64-1.txz: Upgraded.
kde/kapman-22.12.2-x86_64-1.txz: Upgraded.
kde/kapptemplate-22.12.2-x86_64-1.txz: Upgraded.
kde/kate-22.12.2-x86_64-1.txz: Upgraded.
kde/katomic-22.12.2-x86_64-1.txz: Upgraded.
kde/kbackup-22.12.2-x86_64-1.txz: Upgraded.
kde/kblackbox-22.12.2-x86_64-1.txz: Upgraded.
kde/kblocks-22.12.2-x86_64-1.txz: Upgraded.
kde/kbounce-22.12.2-x86_64-1.txz: Upgraded.
kde/kbreakout-22.12.2-x86_64-1.txz: Upgraded.
kde/kbruch-22.12.2-x86_64-1.txz: Upgraded.
kde/kcachegrind-22.12.2-x86_64-1.txz: Upgraded.
kde/kcalc-22.12.2-x86_64-1.txz: Upgraded.
kde/kcalutils-22.12.2-x86_64-1.txz: Upgraded.
kde/kcharselect-22.12.2-x86_64-1.txz: Upgraded.
kde/kcolorchooser-22.12.2-x86_64-1.txz: Upgraded.
kde/kcron-22.12.2-x86_64-1.txz: Upgraded.
kde/kde-dev-scripts-22.12.2-x86_64-1.txz: Upgraded.
kde/kde-dev-utils-22.12.2-x86_64-1.txz: Upgraded.
kde/kdebugsettings-22.12.2-x86_64-1.txz: Upgraded.
kde/kdeconnect-kde-22.12.2-x86_64-1.txz: Upgraded.
kde/kdeedu-data-22.12.2-x86_64-1.txz: Upgraded.
kde/kdegraphics-mobipocket-22.12.2-x86_64-1.txz: Upgraded.
kde/kdegraphics-thumbnailers-22.12.2-x86_64-1.txz: Upgraded.
kde/kdenetwork-filesharing-22.12.2-x86_64-1.txz: Upgraded.
kde/kdenlive-22.12.2-x86_64-1.txz: Upgraded.
kde/kdepim-addons-22.12.2-x86_64-1.txz: Upgraded.
kde/kdepim-runtime-22.12.2-x86_64-1.txz: Upgraded.
kde/kdesdk-kio-22.12.2-x86_64-1.txz: Upgraded.
kde/kdesdk-thumbnailers-22.12.2-x86_64-1.txz: Upgraded.
kde/kdev-php-22.12.2-x86_64-1.txz: Upgraded.
kde/kdev-python-22.12.2-x86_64-1.txz: Upgraded.
kde/kdevelop-22.12.2-x86_64-1.txz: Upgraded.
kde/kdf-22.12.2-x86_64-1.txz: Upgraded.
kde/kdialog-22.12.2-x86_64-1.txz: Upgraded.
kde/kdiamond-22.12.2-x86_64-1.txz: Upgraded.
kde/keditbookmarks-22.12.2-x86_64-1.txz: Upgraded.
kde/kfind-22.12.2-x86_64-1.txz: Upgraded.
kde/kfloppy-22.12.2-x86_64-1.txz: Upgraded.
kde/kfourinline-22.12.2-x86_64-1.txz: Upgraded.
kde/kgeography-22.12.2-x86_64-1.txz: Upgraded.
kde/kget-22.12.2-x86_64-1.txz: Upgraded.
kde/kgoldrunner-22.12.2-x86_64-1.txz: Upgraded.
kde/kgpg-22.12.2-x86_64-1.txz: Upgraded.
kde/khangman-22.12.2-x86_64-1.txz: Upgraded.
kde/khelpcenter-22.12.2-x86_64-1.txz: Upgraded.
kde/kidentitymanagement-22.12.2-x86_64-1.txz: Upgraded.
kde/kig-22.12.2-x86_64-1.txz: Upgraded.
kde/kigo-22.12.2-x86_64-1.txz: Upgraded.
kde/killbots-22.12.2-x86_64-1.txz: Upgraded.
kde/kimagemapeditor-22.12.2-x86_64-1.txz: Upgraded.
kde/kimap-22.12.2-x86_64-1.txz: Upgraded.
kde/kio-extras-22.12.2-x86_64-1.txz: Upgraded.
kde/kio-gdrive-22.12.2-x86_64-1.txz: Upgraded.
kde/kio-zeroconf-22.12.2-x86_64-1.txz: Upgraded.
kde/kipi-plugins-22.12.2-x86_64-1.txz: Upgraded.
kde/kirigami-gallery-22.12.2-x86_64-1.txz: Upgraded.
kde/kiriki-22.12.2-x86_64-1.txz: Upgraded.
kde/kiten-22.12.2-x86_64-1.txz: Upgraded.
kde/kitinerary-22.12.2-x86_64-1.txz: Upgraded.
kde/kjumpingcube-22.12.2-x86_64-1.txz: Upgraded.
kde/kldap-22.12.2-x86_64-1.txz: Upgraded.
kde/kleopatra-22.12.2-x86_64-1.txz: Upgraded.
kde/klickety-22.12.2-x86_64-1.txz: Upgraded.
kde/klines-22.12.2-x86_64-1.txz: Upgraded.
kde/kmag-22.12.2-x86_64-1.txz: Upgraded.
kde/kmahjongg-22.12.2-x86_64-1.txz: Upgraded.
kde/kmail-22.12.2-x86_64-1.txz: Upgraded.
kde/kmail-account-wizard-22.12.2-x86_64-1.txz: Upgraded.
kde/kmailtransport-22.12.2-x86_64-1.txz: Upgraded.
kde/kmbox-22.12.2-x86_64-1.txz: Upgraded.
kde/kmime-22.12.2-x86_64-1.txz: Upgraded.
kde/kmines-22.12.2-x86_64-1.txz: Upgraded.
kde/kmix-22.12.2-x86_64-1.txz: Upgraded.
kde/kmousetool-22.12.2-x86_64-1.txz: Upgraded.
kde/kmouth-22.12.2-x86_64-1.txz: Upgraded.
kde/kmplot-22.12.2-x86_64-1.txz: Upgraded.
kde/knavalbattle-22.12.2-x86_64-1.txz: Upgraded.
kde/knetwalk-22.12.2-x86_64-1.txz: Upgraded.
kde/knights-22.12.2-x86_64-1.txz: Upgraded.
kde/knotes-22.12.2-x86_64-1.txz: Upgraded.
kde/kolf-22.12.2-x86_64-1.txz: Upgraded.
kde/kollision-22.12.2-x86_64-1.txz: Upgraded.
kde/kolourpaint-22.12.2-x86_64-1.txz: Upgraded.
kde/kompare-22.12.2-x86_64-1.txz: Upgraded.
kde/konqueror-22.12.2-x86_64-1.txz: Upgraded.
kde/konquest-22.12.2-x86_64-1.txz: Upgraded.
kde/konsole-22.12.2-x86_64-1.txz: Upgraded.
kde/kontact-22.12.2-x86_64-1.txz: Upgraded.
kde/kontactinterface-22.12.2-x86_64-1.txz: Upgraded.
kde/kontrast-22.12.2-x86_64-1.txz: Upgraded.
kde/konversation-22.12.2-x86_64-1.txz: Upgraded.
kde/kopeninghours-22.12.2-x86_64-1.txz: Upgraded.
kde/kopete-22.12.2-x86_64-1.txz: Upgraded.
kde/korganizer-22.12.2-x86_64-1.txz: Upgraded.
kde/kosmindoormap-22.12.2-x86_64-1.txz: Upgraded.
kde/kpat-22.12.2-x86_64-1.txz: Upgraded.
kde/kpimtextedit-22.12.2-x86_64-1.txz: Upgraded.
kde/kpkpass-22.12.2-x86_64-1.txz: Upgraded.
kde/kpmcore-22.12.2-x86_64-1.txz: Upgraded.
kde/kpublictransport-22.12.2-x86_64-1.txz: Upgraded.
kde/kqtquickcharts-22.12.2-x86_64-1.txz: Upgraded.
kde/krdc-22.12.2-x86_64-1.txz: Upgraded.
kde/kreversi-22.12.2-x86_64-1.txz: Upgraded.
kde/krfb-22.12.2-x86_64-1.txz: Upgraded.
kde/kross-interpreters-22.12.2-x86_64-1.txz: Upgraded.
kde/kruler-22.12.2-x86_64-1.txz: Upgraded.
kde/ksanecore-22.12.2-x86_64-1.txz: Upgraded.
kde/kshisen-22.12.2-x86_64-1.txz: Upgraded.
kde/ksirk-22.12.2-x86_64-1.txz: Upgraded.
kde/ksmtp-22.12.2-x86_64-1.txz: Upgraded.
kde/ksnakeduel-22.12.2-x86_64-1.txz: Upgraded.
kde/kspaceduel-22.12.2-x86_64-1.txz: Upgraded.
kde/ksquares-22.12.2-x86_64-1.txz: Upgraded.
kde/ksudoku-22.12.2-x86_64-1.txz: Upgraded.
kde/ksystemlog-22.12.2-x86_64-1.txz: Upgraded.
kde/kteatime-22.12.2-x86_64-1.txz: Upgraded.
kde/ktimer-22.12.2-x86_64-1.txz: Upgraded.
kde/ktnef-22.12.2-x86_64-1.txz: Upgraded.
kde/ktorrent-22.12.2-x86_64-1.txz: Upgraded.
kde/ktouch-22.12.2-x86_64-1.txz: Upgraded.
kde/kturtle-22.12.2-x86_64-1.txz: Upgraded.
kde/kubrick-22.12.2-x86_64-1.txz: Upgraded.
kde/kwalletmanager-22.12.2-x86_64-1.txz: Upgraded.
kde/kwave-22.12.2-x86_64-1.txz: Upgraded.
kde/kwordquiz-22.12.2-x86_64-1.txz: Upgraded.
kde/libgravatar-22.12.2-x86_64-1.txz: Upgraded.
kde/libkcddb-22.12.2-x86_64-1.txz: Upgraded.
kde/libkcompactdisc-22.12.2-x86_64-1.txz: Upgraded.
kde/libkdcraw-22.12.2-x86_64-1.txz: Upgraded.
kde/libkdegames-22.12.2-x86_64-1.txz: Upgraded.
kde/libkdepim-22.12.2-x86_64-1.txz: Upgraded.
kde/libkeduvocdocument-22.12.2-x86_64-1.txz: Upgraded.
kde/libkexiv2-22.12.2-x86_64-1.txz: Upgraded.
kde/libkgapi-22.12.2-x86_64-1.txz: Upgraded.
kde/libkipi-22.12.2-x86_64-1.txz: Upgraded.
kde/libkleo-22.12.2-x86_64-1.txz: Upgraded.
kde/libkmahjongg-22.12.2-x86_64-1.txz: Upgraded.
kde/libkomparediff2-22.12.2-x86_64-1.txz: Upgraded.
kde/libksane-22.12.2-x86_64-1.txz: Upgraded.
kde/libksieve-22.12.2-x86_64-1.txz: Upgraded.
kde/libktorrent-22.12.2-x86_64-1.txz: Upgraded.
kde/lokalize-22.12.2-x86_64-1.txz: Upgraded.
kde/lskat-22.12.2-x86_64-1.txz: Upgraded.
kde/mailcommon-22.12.2-x86_64-1.txz: Upgraded.
kde/mailimporter-22.12.2-x86_64-1.txz: Upgraded.
kde/marble-22.12.2-x86_64-1.txz: Upgraded.
kde/markdownpart-22.12.2-x86_64-1.txz: Upgraded.
kde/mbox-importer-22.12.2-x86_64-1.txz: Upgraded.
kde/messagelib-22.12.2-x86_64-1.txz: Upgraded.
kde/minuet-22.12.2-x86_64-1.txz: Upgraded.
kde/okular-22.12.2-x86_64-1.txz: Upgraded.
kde/palapeli-22.12.2-x86_64-1.txz: Upgraded.
kde/parley-22.12.2-x86_64-1.txz: Upgraded.
kde/partitionmanager-22.12.2-x86_64-1.txz: Upgraded.
kde/picmi-22.12.2-x86_64-1.txz: Upgraded.
kde/pim-data-exporter-22.12.2-x86_64-1.txz: Upgraded.
kde/pim-sieve-editor-22.12.2-x86_64-1.txz: Upgraded.
kde/pimcommon-22.12.2-x86_64-1.txz: Upgraded.
kde/poxml-22.12.2-x86_64-1.txz: Upgraded.
kde/print-manager-22.12.2-x86_64-1.txz: Upgraded.
kde/rocs-22.12.2-x86_64-1.txz: Upgraded.
kde/skanlite-22.12.2-x86_64-1.txz: Upgraded.
kde/skanpage-22.12.2-x86_64-1.txz: Upgraded.
kde/spectacle-22.12.2-x86_64-1.txz: Upgraded.
kde/svgpart-22.12.2-x86_64-1.txz: Upgraded.
kde/sweeper-22.12.2-x86_64-1.txz: Upgraded.
kde/umbrello-22.12.2-x86_64-1.txz: Upgraded.
kde/yakuake-22.12.2-x86_64-1.txz: Upgraded.
kde/zanshin-22.12.2-x86_64-1.txz: Upgraded.
l/glibc-2.37-x86_64-1.txz: Upgraded.
l/glibc-i18n-2.37-x86_64-1.txz: Upgraded.
l/glibc-profile-2.37-x86_64-1.txz: Upgraded.
l/nodejs-19.6.0-x86_64-1.txz: Upgraded.
l/poppler-23.02.0-x86_64-1.txz: Upgraded.
l/xapian-core-1.4.22-x86_64-1.txz: Upgraded.
n/openssh-9.2p1-x86_64-1.txz: Upgraded.
This release contains fixes for two security problems and a memory safety
problem. The memory safety problem is not believed to be exploitable, but
upstream reports most network-reachable memory faults as security bugs.
https://www.openssh.com/releasenotes.html#9.2
Wed Feb 1 22:27:31 UTC 2023
a/kernel-firmware-20230125_5c11a37-noarch-1.txz: Upgraded.
a/kernel-generic-6.1.9-x86_64-1.txz: Upgraded.
a/kernel-huge-6.1.9-x86_64-1.txz: Upgraded.
a/kernel-modules-6.1.9-x86_64-1.txz: Upgraded.
d/kernel-headers-6.1.9-x86-1.txz: Upgraded.
k/kernel-source-6.1.9-noarch-1.txz: Upgraded.
l/apr-1.7.2-x86_64-1.txz: Upgraded.
Integer Overflow or Wraparound vulnerability in apr_encode functions of
Apache Portable Runtime (APR) allows an attacker to write beyond bounds
of a buffer. (CVE-2022-24963)
Restore fix for out-of-bounds array dereference in apr_time_exp*() functions.
(This issue was addressed as CVE-2017-12613 in APR 1.6.3 and
later 1.6.x releases, but was missing in 1.7.0.) (CVE-2021-35940)
https://www.cve.org/CVERecord?id=CVE-2022-24963
https://www.cve.org/CVERecord?id=CVE-2021-35940
https://www.cve.org/CVERecord?id=CVE-2017-12613
l/apr-util-1.6.3-x86_64-1.txz: Upgraded.
Integer Overflow or Wraparound vulnerability in apr_base64 functions
of Apache Portable Runtime Utility (APR-util) allows an attacker to
write beyond bounds of a buffer. (CVE-2022-25147)
https://www.cve.org/CVERecord?id=CVE-2022-25147
l/libhandy-1.8.1-x86_64-1.txz: Upgraded.
l/libjpeg-turbo-2.1.5-x86_64-1.txz: Upgraded.
xap/mozilla-thunderbird-102.7.1-x86_64-1.txz: Upgraded.
https://www.mozilla.org/en-US/thunderbird/102.7.1/releasenotes/
https://www.mozilla.org/en-US/security/advisories/mfsa2023-04/
https://www.cve.org/CVERecord?id=CVE-2023-0430
isolinux/initrd.img: Rebuilt.
kernels/*: Upgraded.
Wed Feb 1 05:29:53 UTC 2023
d/perl-5.36.0-x86_64-3.txz: Rebuilt.
Upgraded: IO-Socket-SSL-2.081, Moo-2.005005, Path-Tiny-0.144,
Sub-Quote-2.006008, Template-Toolkit-3.101, URI-5.17.
Added: JSON-4.10 (needed to build Samba with --bundled-libraries=heimdal).
kde/kstars-3.6.3-x86_64-1.txz: Upgraded.
l/gjs-1.74.1-x86_64-1.txz: Upgraded.
Compiled against mozjs102-102.7.0esr.
l/mozjs102-102.7.0esr-x86_64-1.txz: Added.
This is required by gjs-1.74.1 and polkit-122.
l/mozjs78-78.15.0esr-x86_64-1.txz: Removed.
l/polkit-122-x86_64-1.txz: Upgraded.
Mon Jan 30 21:38:07 UTC 2023
ap/sysstat-12.7.2-x86_64-1.txz: Upgraded.
kde/kimageformats-5.102.0-x86_64-2.txz: Rebuilt.
Recompiled against LibRaw-0.21.1.
kde/krita-5.1.5-x86_64-3.txz: Rebuilt.
kde/kstars-3.6.2-x86_64-3.txz: Rebuilt.
kde/libkdcraw-22.12.1-x86_64-2.txz: Rebuilt.
l/LibRaw-0.21.1-x86_64-1.txz: Upgraded.
l/dconf-editor-43.0-x86_64-1.txz: Upgraded.
l/gegl-0.4.40-x86_64-3.txz: Rebuilt.
l/imagemagick-7.1.0_60-x86_64-1.txz: Upgraded.
Compiled against LibRaw-0.21.1.
l/libhandy-1.8.0-x86_64-1.txz: Added.
This is required by dconf-editor-43.0.
xap/geeqie-2.0.1-x86_64-2.txz: Rebuilt.
xap/mozilla-firefox-109.0.1-x86_64-1.txz: Upgraded.
https://www.mozilla.org/en-US/firefox/109.0.1/releasenotes/
Sun Jan 29 19:01:47 UTC 2023
l/imagemagick-7.1.0_59-x86_64-1.txz: Upgraded.
n/c-ares-1.19.0-x86_64-1.txz: Upgraded.
n/fetchmail-6.4.36-x86_64-1.txz: Upgraded.
x/beforelight-1.0.6-x86_64-1.txz: Upgraded.
Slackware 32-bit
a/kernel-generic-6.1.10-i586-1.txz: Upgraded.
a/kernel-generic-smp-6.1.10_smp-i686-1.txz: Upgraded.
a/kernel-huge-6.1.10-i586-1.txz: Upgraded.
a/kernel-huge-smp-6.1.10_smp-i686-1.txz: Upgraded.
a/kernel-modules-6.1.10-i586-1.txz: Upgraded.
a/kernel-modules-smp-6.1.10_smp-i686-1.txz: Upgraded.
d/kernel-headers-6.1.10_smp-x86-1.txz: Upgraded.
k/kernel-source-6.1.10_smp-noarch-1.txz: Upgraded.
l/imagemagick-7.1.0_61-i586-1.txz: Upgraded.
l/openal-soft-1.23.0-i586-1.txz: Upgraded.
extra/linux-6.1.10-nosmp-sdk/*: Upgraded.
ap/htop-3.2.2-i586-1.txz: Upgraded.
l/fuse3-3.13.1-i586-1.txz: Upgraded.
l/pangomm-2.46.3-i586-1.txz: Upgraded.
l/tevent-0.14.1-i586-1.txz: Upgraded.
n/dnsmasq-2.89-i586-1.txz: Upgraded.
x/libX11-1.8.4-i586-1.txz: Upgraded.
x/xvidtune-1.0.4-i586-1.txz: Upgraded.
a/aaa_glibc-solibs-2.37-i586-2.txz: Rebuilt.
a/e2fsprogs-1.46.6-i586-1.txz: Upgraded.
l/glibc-2.37-i586-2.txz: Rebuilt.
l/glibc-i18n-2.37-i586-2.txz: Rebuilt.
l/glibc-profile-2.37-i586-2.txz: Rebuilt.
l/libcap-2.67-i586-1.txz: Upgraded.
extra/php81/php81-8.1.15-i586-1.txz: Upgraded.
testing/packages/samba-4.17.5-i586-2.txz: Rebuilt.
a/aaa_glibc-solibs-2.37-i586-1.txz: Upgraded.
kde/akonadi-22.12.2-i586-1.txz: Upgraded.
kde/akonadi-calendar-22.12.2-i586-1.txz: Upgraded.
kde/akonadi-calendar-tools-22.12.2-i586-1.txz: Upgraded.
kde/akonadi-contacts-22.12.2-i586-1.txz: Upgraded.
kde/akonadi-import-wizard-22.12.2-i586-1.txz: Upgraded.
kde/akonadi-mime-22.12.2-i586-1.txz: Upgraded.
kde/akonadi-notes-22.12.2-i586-1.txz: Upgraded.
kde/akonadi-search-22.12.2-i586-1.txz: Upgraded.
kde/akonadiconsole-22.12.2-i586-1.txz: Upgraded.
kde/akregator-22.12.2-i586-1.txz: Upgraded.
kde/analitza-22.12.2-i586-1.txz: Upgraded.
kde/ark-22.12.2-i586-1.txz: Upgraded.
kde/artikulate-22.12.2-i586-1.txz: Upgraded.
kde/audiocd-kio-22.12.2-i586-1.txz: Upgraded.
kde/baloo-widgets-22.12.2-i586-1.txz: Upgraded.
kde/blinken-22.12.2-i586-1.txz: Upgraded.
kde/bomber-22.12.2-i586-1.txz: Upgraded.
kde/bovo-22.12.2-i586-1.txz: Upgraded.
kde/calendarsupport-22.12.2-i586-1.txz: Upgraded.
kde/cantor-22.12.2-i586-1.txz: Upgraded.
kde/cervisia-22.12.2-i586-1.txz: Upgraded.
kde/dolphin-22.12.2-i586-1.txz: Upgraded.
kde/dolphin-plugins-22.12.2-i586-1.txz: Upgraded.
kde/dragon-22.12.2-i586-1.txz: Upgraded.
kde/elisa-22.12.2-i586-1.txz: Upgraded.
kde/eventviews-22.12.2-i586-1.txz: Upgraded.
kde/falkon-22.12.2-i586-1.txz: Upgraded.
kde/ffmpegthumbs-22.12.2-i586-1.txz: Upgraded.
kde/filelight-22.12.2-i586-1.txz: Upgraded.
kde/granatier-22.12.2-i586-1.txz: Upgraded.
kde/grantlee-editor-22.12.2-i586-1.txz: Upgraded.
kde/grantleetheme-22.12.2-i586-1.txz: Upgraded.
kde/gwenview-22.12.2-i586-1.txz: Upgraded.
kde/incidenceeditor-22.12.2-i586-1.txz: Upgraded.
kde/itinerary-22.12.2-i586-1.txz: Upgraded.
kde/juk-22.12.2-i586-1.txz: Upgraded.
kde/k3b-22.12.2-i586-1.txz: Upgraded.
kde/kaddressbook-22.12.2-i586-1.txz: Upgraded.
kde/kalarm-22.12.2-i586-1.txz: Upgraded.
kde/kalendar-22.12.2-i586-1.txz: Upgraded.
kde/kalgebra-22.12.2-i586-1.txz: Upgraded.
kde/kalzium-22.12.2-i586-1.txz: Upgraded.
kde/kamera-22.12.2-i586-1.txz: Upgraded.
kde/kamoso-22.12.2-i586-1.txz: Upgraded.
kde/kanagram-22.12.2-i586-1.txz: Upgraded.
kde/kapman-22.12.2-i586-1.txz: Upgraded.
kde/kapptemplate-22.12.2-i586-1.txz: Upgraded.
kde/kate-22.12.2-i586-1.txz: Upgraded.
kde/katomic-22.12.2-i586-1.txz: Upgraded.
kde/kbackup-22.12.2-i586-1.txz: Upgraded.
kde/kblackbox-22.12.2-i586-1.txz: Upgraded.
kde/kblocks-22.12.2-i586-1.txz: Upgraded.
kde/kbounce-22.12.2-i586-1.txz: Upgraded.
kde/kbreakout-22.12.2-i586-1.txz: Upgraded.
kde/kbruch-22.12.2-i586-1.txz: Upgraded.
kde/kcachegrind-22.12.2-i586-1.txz: Upgraded.
kde/kcalc-22.12.2-i586-1.txz: Upgraded.
kde/kcalutils-22.12.2-i586-1.txz: Upgraded.
kde/kcharselect-22.12.2-i586-1.txz: Upgraded.
kde/kcolorchooser-22.12.2-i586-1.txz: Upgraded.
kde/kcron-22.12.2-i586-1.txz: Upgraded.
kde/kde-dev-scripts-22.12.2-i586-1.txz: Upgraded.
kde/kde-dev-utils-22.12.2-i586-1.txz: Upgraded.
kde/kdebugsettings-22.12.2-i586-1.txz: Upgraded.
kde/kdeconnect-kde-22.12.2-i586-1.txz: Upgraded.
kde/kdeedu-data-22.12.2-i586-1.txz: Upgraded.
kde/kdegraphics-mobipocket-22.12.2-i586-1.txz: Upgraded.
kde/kdegraphics-thumbnailers-22.12.2-i586-1.txz: Upgraded.
kde/kdenetwork-filesharing-22.12.2-i586-1.txz: Upgraded.
kde/kdenlive-22.12.2-i586-1.txz: Upgraded.
kde/kdepim-addons-22.12.2-i586-1.txz: Upgraded.
kde/kdepim-runtime-22.12.2-i586-1.txz: Upgraded.
kde/kdesdk-kio-22.12.2-i586-1.txz: Upgraded.
kde/kdesdk-thumbnailers-22.12.2-i586-1.txz: Upgraded.
kde/kdev-php-22.12.2-i586-1.txz: Upgraded.
kde/kdev-python-22.12.2-i586-1.txz: Upgraded.
kde/kdevelop-22.12.2-i586-1.txz: Upgraded.
kde/kdf-22.12.2-i586-1.txz: Upgraded.
kde/kdialog-22.12.2-i586-1.txz: Upgraded.
kde/kdiamond-22.12.2-i586-1.txz: Upgraded.
kde/keditbookmarks-22.12.2-i586-1.txz: Upgraded.
kde/kfind-22.12.2-i586-1.txz: Upgraded.
kde/kfloppy-22.12.2-i586-1.txz: Upgraded.
kde/kfourinline-22.12.2-i586-1.txz: Upgraded.
kde/kgeography-22.12.2-i586-1.txz: Upgraded.
kde/kget-22.12.2-i586-1.txz: Upgraded.
kde/kgoldrunner-22.12.2-i586-1.txz: Upgraded.
kde/kgpg-22.12.2-i586-1.txz: Upgraded.
kde/khangman-22.12.2-i586-1.txz: Upgraded.
kde/khelpcenter-22.12.2-i586-1.txz: Upgraded.
kde/kidentitymanagement-22.12.2-i586-1.txz: Upgraded.
kde/kig-22.12.2-i586-1.txz: Upgraded.
kde/kigo-22.12.2-i586-1.txz: Upgraded.
kde/killbots-22.12.2-i586-1.txz: Upgraded.
kde/kimagemapeditor-22.12.2-i586-1.txz: Upgraded.
kde/kimap-22.12.2-i586-1.txz: Upgraded.
kde/kio-extras-22.12.2-i586-1.txz: Upgraded.
kde/kio-gdrive-22.12.2-i586-1.txz: Upgraded.
kde/kio-zeroconf-22.12.2-i586-1.txz: Upgraded.
kde/kipi-plugins-22.12.2-i586-1.txz: Upgraded.
kde/kirigami-gallery-22.12.2-i586-1.txz: Upgraded.
kde/kiriki-22.12.2-i586-1.txz: Upgraded.
kde/kiten-22.12.2-i586-1.txz: Upgraded.
kde/kitinerary-22.12.2-i586-1.txz: Upgraded.
kde/kjumpingcube-22.12.2-i586-1.txz: Upgraded.
kde/kldap-22.12.2-i586-1.txz: Upgraded.
kde/kleopatra-22.12.2-i586-1.txz: Upgraded.
kde/klickety-22.12.2-i586-1.txz: Upgraded.
kde/klines-22.12.2-i586-1.txz: Upgraded.
kde/kmag-22.12.2-i586-1.txz: Upgraded.
kde/kmahjongg-22.12.2-i586-1.txz: Upgraded.
kde/kmail-22.12.2-i586-1.txz: Upgraded.
kde/kmail-account-wizard-22.12.2-i586-1.txz: Upgraded.
kde/kmailtransport-22.12.2-i586-1.txz: Upgraded.
kde/kmbox-22.12.2-i586-1.txz: Upgraded.
kde/kmime-22.12.2-i586-1.txz: Upgraded.
kde/kmines-22.12.2-i586-1.txz: Upgraded.
kde/kmix-22.12.2-i586-1.txz: Upgraded.
kde/kmousetool-22.12.2-i586-1.txz: Upgraded.
kde/kmouth-22.12.2-i586-1.txz: Upgraded.
kde/kmplot-22.12.2-i586-1.txz: Upgraded.
kde/knavalbattle-22.12.2-i586-1.txz: Upgraded.
kde/knetwalk-22.12.2-i586-1.txz: Upgraded.
kde/knights-22.12.2-i586-1.txz: Upgraded.
kde/knotes-22.12.2-i586-1.txz: Upgraded.
kde/kolf-22.12.2-i586-1.txz: Upgraded.
kde/kollision-22.12.2-i586-1.txz: Upgraded.
kde/kolourpaint-22.12.2-i586-1.txz: Upgraded.
kde/kompare-22.12.2-i586-1.txz: Upgraded.
kde/konqueror-22.12.2-i586-1.txz: Upgraded.
kde/konquest-22.12.2-i586-1.txz: Upgraded.
kde/konsole-22.12.2-i586-1.txz: Upgraded.
kde/kontact-22.12.2-i586-1.txz: Upgraded.
kde/kontactinterface-22.12.2-i586-1.txz: Upgraded.
kde/kontrast-22.12.2-i586-1.txz: Upgraded.
kde/konversation-22.12.2-i586-1.txz: Upgraded.
kde/kopeninghours-22.12.2-i586-1.txz: Upgraded.
kde/kopete-22.12.2-i586-1.txz: Upgraded.
kde/korganizer-22.12.2-i586-1.txz: Upgraded.
kde/kosmindoormap-22.12.2-i586-1.txz: Upgraded.
kde/kpat-22.12.2-i586-1.txz: Upgraded.
kde/kpimtextedit-22.12.2-i586-1.txz: Upgraded.
kde/kpkpass-22.12.2-i586-1.txz: Upgraded.
kde/kpmcore-22.12.2-i586-1.txz: Upgraded.
kde/kpublictransport-22.12.2-i586-1.txz: Upgraded.
kde/kqtquickcharts-22.12.2-i586-1.txz: Upgraded.
kde/krdc-22.12.2-i586-1.txz: Upgraded.
kde/kreversi-22.12.2-i586-1.txz: Upgraded.
kde/krfb-22.12.2-i586-1.txz: Upgraded.
kde/kross-interpreters-22.12.2-i586-1.txz: Upgraded.
kde/kruler-22.12.2-i586-1.txz: Upgraded.
kde/ksanecore-22.12.2-i586-1.txz: Upgraded.
kde/kshisen-22.12.2-i586-1.txz: Upgraded.
kde/ksirk-22.12.2-i586-1.txz: Upgraded.
kde/ksmtp-22.12.2-i586-1.txz: Upgraded.
kde/ksnakeduel-22.12.2-i586-1.txz: Upgraded.
kde/kspaceduel-22.12.2-i586-1.txz: Upgraded.
kde/ksquares-22.12.2-i586-1.txz: Upgraded.
kde/ksudoku-22.12.2-i586-1.txz: Upgraded.
kde/ksystemlog-22.12.2-i586-1.txz: Upgraded.
kde/kteatime-22.12.2-i586-1.txz: Upgraded.
kde/ktimer-22.12.2-i586-1.txz: Upgraded.
kde/ktnef-22.12.2-i586-1.txz: Upgraded.
kde/ktorrent-22.12.2-i586-1.txz: Upgraded.
kde/ktouch-22.12.2-i586-1.txz: Upgraded.
kde/kturtle-22.12.2-i586-1.txz: Upgraded.
kde/kubrick-22.12.2-i586-1.txz: Upgraded.
kde/kwalletmanager-22.12.2-i586-1.txz: Upgraded.
kde/kwave-22.12.2-i586-1.txz: Upgraded.
kde/kwordquiz-22.12.2-i586-1.txz: Upgraded.
kde/libgravatar-22.12.2-i586-1.txz: Upgraded.
kde/libkcddb-22.12.2-i586-1.txz: Upgraded.
kde/libkcompactdisc-22.12.2-i586-1.txz: Upgraded.
kde/libkdcraw-22.12.2-i586-1.txz: Upgraded.
kde/libkdegames-22.12.2-i586-1.txz: Upgraded.
kde/libkdepim-22.12.2-i586-1.txz: Upgraded.
kde/libkeduvocdocument-22.12.2-i586-1.txz: Upgraded.
kde/libkexiv2-22.12.2-i586-1.txz: Upgraded.
kde/libkgapi-22.12.2-i586-1.txz: Upgraded.
kde/libkipi-22.12.2-i586-1.txz: Upgraded.
kde/libkleo-22.12.2-i586-1.txz: Upgraded.
kde/libkmahjongg-22.12.2-i586-1.txz: Upgraded.
kde/libkomparediff2-22.12.2-i586-1.txz: Upgraded.
kde/libksane-22.12.2-i586-1.txz: Upgraded.
kde/libksieve-22.12.2-i586-1.txz: Upgraded.
kde/libktorrent-22.12.2-i586-1.txz: Upgraded.
kde/lokalize-22.12.2-i586-1.txz: Upgraded.
kde/lskat-22.12.2-i586-1.txz: Upgraded.
kde/mailcommon-22.12.2-i586-1.txz: Upgraded.
kde/mailimporter-22.12.2-i586-1.txz: Upgraded.
kde/marble-22.12.2-i586-1.txz: Upgraded.
kde/markdownpart-22.12.2-i586-1.txz: Upgraded.
kde/mbox-importer-22.12.2-i586-1.txz: Upgraded.
kde/messagelib-22.12.2-i586-1.txz: Upgraded.
kde/minuet-22.12.2-i586-1.txz: Upgraded.
kde/okular-22.12.2-i586-1.txz: Upgraded.
kde/palapeli-22.12.2-i586-1.txz: Upgraded.
kde/parley-22.12.2-i586-1.txz: Upgraded.
kde/partitionmanager-22.12.2-i586-1.txz: Upgraded.
kde/picmi-22.12.2-i586-1.txz: Upgraded.
kde/pim-data-exporter-22.12.2-i586-1.txz: Upgraded.
kde/pim-sieve-editor-22.12.2-i586-1.txz: Upgraded.
kde/pimcommon-22.12.2-i586-1.txz: Upgraded.
kde/poxml-22.12.2-i586-1.txz: Upgraded.
kde/print-manager-22.12.2-i586-1.txz: Upgraded.
kde/rocs-22.12.2-i586-1.txz: Upgraded.
kde/skanlite-22.12.2-i586-1.txz: Upgraded.
kde/skanpage-22.12.2-i586-1.txz: Upgraded.
kde/spectacle-22.12.2-i586-1.txz: Upgraded.
kde/svgpart-22.12.2-i586-1.txz: Upgraded.
kde/sweeper-22.12.2-i586-1.txz: Upgraded.
kde/umbrello-22.12.2-i586-1.txz: Upgraded.
kde/yakuake-22.12.2-i586-1.txz: Upgraded.
kde/zanshin-22.12.2-i586-1.txz: Upgraded.
l/glibc-2.37-i586-1.txz: Upgraded.
l/glibc-i18n-2.37-i586-1.txz: Upgraded.
l/glibc-profile-2.37-i586-1.txz: Upgraded.
l/nodejs-19.6.0-i586-1.txz: Upgraded.
l/poppler-23.02.0-i586-1.txz: Upgraded.
l/xapian-core-1.4.22-i586-1.txz: Upgraded.
n/openssh-9.2p1-i586-1.txz: Upgraded.
a/kernel-generic-6.1.9-i586-1.txz: Upgraded.
a/kernel-generic-smp-6.1.9_smp-i686-1.txz: Upgraded.
a/kernel-huge-6.1.9-i586-1.txz: Upgraded.
a/kernel-huge-smp-6.1.9_smp-i686-1.txz: Upgraded.
a/kernel-modules-6.1.9-i586-1.txz: Upgraded.
a/kernel-modules-smp-6.1.9_smp-i686-1.txz: Upgraded.
d/kernel-headers-6.1.9_smp-x86-1.txz: Upgraded.
k/kernel-source-6.1.9_smp-noarch-1.txz: Upgraded.
l/apr-1.7.2-i586-1.txz: Upgraded.
l/apr-util-1.6.3-i586-1.txz: Upgraded.
l/libhandy-1.8.1-i586-1.txz: Upgraded.
l/libjpeg-turbo-2.1.5-i586-1.txz: Upgraded.
xap/mozilla-thunderbird-102.7.1-i686-1.txz: Upgraded.
extra/linux-6.1.9-nosmp-sdk/*: Upgraded.
d/perl-5.36.0-i586-3.txz: Rebuilt.
kde/kstars-3.6.3-i586-1.txz: Upgraded.
l/gjs-1.74.1-i586-1.txz: Upgraded.
l/mozjs102-102.7.0esr-i686-1.txz: Added.
l/mozjs78-78.15.0esr-i586-1.txz: Removed.
l/polkit-122-i586-1.txz: Upgraded.
ap/sysstat-12.7.2-i586-1.txz: Upgraded.
kde/kimageformats-5.102.0-i586-2.txz: Rebuilt.
kde/krita-5.1.5-i586-3.txz: Rebuilt.
kde/kstars-3.6.2-i586-3.txz: Rebuilt.
kde/libkdcraw-22.12.1-i586-2.txz: Rebuilt.
l/LibRaw-0.21.1-i586-1.txz: Upgraded.
l/dconf-editor-43.0-i586-1.txz: Upgraded.
l/gegl-0.4.40-i586-3.txz: Rebuilt.
l/imagemagick-7.1.0_60-i586-1.txz: Upgraded.
l/libhandy-1.8.0-i586-1.txz: Added.
xap/geeqie-2.0.1-i586-2.txz: Rebuilt.
xap/mozilla-firefox-109.0.1-i686-1.txz: Upgraded.
l/imagemagick-7.1.0_59-i586-1.txz: Upgraded.
n/c-ares-1.19.0-i586-1.txz: Upgraded.
n/fetchmail-6.4.36-i586-1.txz: Upgraded.
x/beforelight-1.0.6-i586-1.txz: Upgraded.
Napisano: 12 Feb 2023, 17:21
Slackware 64-bit
Sat Feb 11 20:36:32 UTC 2023
l/libvpx-1.13.0-x86_64-1.txz: Upgraded.
l/mozilla-nss-3.88.1-x86_64-1.txz: Upgraded.
xap/gnuplot-5.4.6-x86_64-1.txz: Upgraded.
xfce/xfce4-notifyd-0.8.0-x86_64-1.txz: Upgraded.
xfce/xfce4-settings-4.18.2-x86_64-1.txz: Upgraded.
Fri Feb 10 20:08:41 UTC 2023
a/cryptsetup-2.6.1-x86_64-1.txz: Upgraded.
a/dialog-1.3_20230209-x86_64-1.txz: Upgraded.
l/mozilla-nss-3.87.1-x86_64-1.txz: Upgraded.
l/zstd-1.5.4-x86_64-1.txz: Upgraded.
n/NetworkManager-1.42.0-x86_64-1.txz: Upgraded.
n/gnutls-3.7.9-x86_64-1.txz: Upgraded.
libgnutls: Fix a Bleichenbacher oracle in the TLS RSA key exchange.
Reported by Hubert Kario (#1050). Fix developed by Alexander Sosedkin.
[GNUTLS-SA-2020-07-14, CVSS: medium] [CVE-2023-0361]
https://www.cve.org/CVERecord?id=CVE-2023-0361
xfce/mousepad-0.6.0-x86_64-1.txz: Upgraded.
xfce/xfce4-power-manager-4.18.1-x86_64-1.txz: Upgraded.
xfce/xfce4-session-4.18.1-x86_64-1.txz: Upgraded.
Thu Feb 9 22:39:11 UTC 2023
a/dbus-1.14.6-x86_64-1.txz: Upgraded.
a/kernel-generic-6.1.11-x86_64-1.txz: Upgraded.
a/kernel-huge-6.1.11-x86_64-1.txz: Upgraded.
a/kernel-modules-6.1.11-x86_64-1.txz: Upgraded.
d/kernel-headers-6.1.11-x86-1.txz: Upgraded.
k/kernel-source-6.1.11-noarch-1.txz: Upgraded.
l/freetype-2.13.0-x86_64-1.txz: Upgraded.
l/libjpeg-turbo-2.1.5.1-x86_64-1.txz: Upgraded.
Fix an illegal instruction error on older x86 CPUs.
l/lmdb-0.9.30-x86_64-1.txz: Upgraded.
n/openldap-2.6.4-x86_64-1.txz: Upgraded.
x/libdrm-2.4.115-x86_64-1.txz: Upgraded.
x/mesa-22.3.5-x86_64-1.txz: Upgraded.
xfce/libxfce4ui-4.18.2-x86_64-1.txz: Upgraded.
xfce/xfce4-panel-4.18.2-x86_64-1.txz: Upgraded.
Thu Feb 9 00:59:27 UTC 2023
a/e2fsprogs-1.47.0-x86_64-1.txz: Upgraded.
ap/cdrdao-1.2.5-x86_64-1.txz: Upgraded.
ap/inxi-3.3.25_1-noarch-1.txz: Upgraded.
d/ruby-3.2.1-x86_64-1.txz: Upgraded.
d/rust-bindgen-0.64.0-x86_64-1.txz: Upgraded.
l/SDL2-2.26.3-x86_64-1.txz: Upgraded.
l/gtkmm3-3.24.7-x86_64-1.txz: Upgraded.
n/stunnel-5.68-x86_64-1.txz: Upgraded.
xap/mozilla-thunderbird-102.7.2-x86_64-1.txz: Upgraded.
This is a bugfix release.
https://www.mozilla.org/en-US/thunderbird/102.7.2/releasenotes/
Tue Feb 7 20:48:57 UTC 2023
a/openssl-solibs-1.1.1t-x86_64-1.txz: Upgraded.
ap/mariadb-10.6.12-x86_64-1.txz: Upgraded.
l/SDL2_image-2.6.3-x86_64-1.txz: Upgraded.
l/SDL2_mixer-2.6.3-x86_64-1.txz: Upgraded.
l/SDL2_ttf-2.20.2-x86_64-1.txz: Upgraded.
n/openssl-1.1.1t-x86_64-1.txz: Upgraded.
X.400 address type confusion in X.509 GeneralName.
Timing Oracle in RSA Decryption.
Use-after-free following BIO_new_NDEF.
Double free after calling PEM_read_bio_ex.
https://www.openssl.org/news/secadv/20230207.txt
https://www.cve.org/CVERecord?id=CVE-2023-0286
https://www.cve.org/CVERecord?id=CVE-2022-4304
https://www.cve.org/CVERecord?id=CVE-2023-0215
https://www.cve.org/CVERecord?id=CVE-2022-4450
x/xorg-server-21.1.7-x86_64-1.txz: Upgraded.
[PATCH] Xi: fix potential use-after-free in DeepCopyPointerClasses.
https://www.cve.org/CVERecord?id=CVE-2023-0494
x/xorg-server-xephyr-21.1.7-x86_64-1.txz: Upgraded.
x/xorg-server-xnest-21.1.7-x86_64-1.txz: Upgraded.
x/xorg-server-xvfb-21.1.7-x86_64-1.txz: Upgraded.
x/xorg-server-xwayland-22.1.8-x86_64-1.txz: Upgraded.
Slackware 32-bit
l/libvpx-1.13.0-i586-1.txz: Upgraded.
l/mozilla-nss-3.88.1-i586-1.txz: Upgraded.
xap/gnuplot-5.4.6-i586-1.txz: Upgraded.
xfce/xfce4-notifyd-0.8.0-i586-1.txz: Upgraded.
xfce/xfce4-settings-4.18.2-i586-1.txz: Upgraded.
a/cryptsetup-2.6.1-i586-1.txz: Upgraded.
a/dialog-1.3_20230209-i586-1.txz: Upgraded.
l/mozilla-nss-3.87.1-i586-1.txz: Upgraded.
l/zstd-1.5.4-i586-1.txz: Upgraded.
n/NetworkManager-1.42.0-i586-1.txz: Upgraded.
n/gnutls-3.7.9-i586-1.txz: Upgraded.
xfce/mousepad-0.6.0-i586-1.txz: Upgraded.
xfce/xfce4-power-manager-4.18.1-i586-1.txz: Upgraded.
xfce/xfce4-session-4.18.1-i586-1.txz: Upgraded.
a/dbus-1.14.6-i586-1.txz: Upgraded.
a/kernel-generic-6.1.11-i586-1.txz: Upgraded.
a/kernel-generic-smp-6.1.11_smp-i686-1.txz: Upgraded.
a/kernel-huge-6.1.11-i586-1.txz: Upgraded.
a/kernel-huge-smp-6.1.11_smp-i686-1.txz: Upgraded.
a/kernel-modules-6.1.11-i586-1.txz: Upgraded.
a/kernel-modules-smp-6.1.11_smp-i686-1.txz: Upgraded.
d/kernel-headers-6.1.11_smp-x86-1.txz: Upgraded.
k/kernel-source-6.1.11_smp-noarch-1.txz: Upgraded.
l/freetype-2.13.0-i586-1.txz: Upgraded.
l/libjpeg-turbo-2.1.5.1-i586-1.txz: Upgraded.
l/lmdb-0.9.30-i586-1.txz: Upgraded.
n/openldap-2.6.4-i586-1.txz: Upgraded.
x/libdrm-2.4.115-i586-1.txz: Upgraded.
x/mesa-22.3.5-i586-1.txz: Upgraded.
xfce/libxfce4ui-4.18.2-i586-1.txz: Upgraded.
xfce/xfce4-panel-4.18.2-i586-1.txz: Upgraded.
extra/linux-6.1.11-nosmp-sdk/*: Upgraded.
a/e2fsprogs-1.47.0-i586-1.txz: Upgraded.
ap/cdrdao-1.2.5-i586-1.txz: Upgraded.
d/ruby-3.2.1-i586-1.txz: Upgraded.
d/rust-bindgen-0.64.0-i686-1.txz: Upgraded.
l/SDL2-2.26.3-i586-1.txz: Upgraded.
l/gtkmm3-3.24.7-i586-1.txz: Upgraded.
n/stunnel-5.68-i586-1.txz: Upgraded.
xap/mozilla-thunderbird-102.7.2-i686-1.txz: Upgraded.
a/openssl-solibs-1.1.1t-i586-1.txz: Upgraded.
ap/mariadb-10.6.12-i586-1.txz: Upgraded.
l/SDL2_image-2.6.3-i586-1.txz: Upgraded.
l/SDL2_mixer-2.6.3-i586-1.txz: Upgraded.
l/SDL2_ttf-2.20.2-i586-1.txz: Upgraded.
n/openssl-1.1.1t-i586-1.txz: Upgraded.
x/xorg-server-21.1.7-i586-1.txz: Upgraded.
x/xorg-server-xephyr-21.1.7-i586-1.txz: Upgraded.
x/xorg-server-xnest-21.1.7-i586-1.txz: Upgraded.
x/xorg-server-xvfb-21.1.7-i586-1.txz: Upgraded.
x/xorg-server-xwayland-22.1.8-i586-1.txz: Upgraded.
Napisano: 15 Feb 2023, 09:57
Slackware 64-bit
Wed Feb 15 03:05:40 UTC 2023
a/kernel-firmware-20230214_a253a37-noarch-1.txz: Upgraded.
a/kernel-generic-6.1.12-x86_64-1.txz: Upgraded.
a/kernel-huge-6.1.12-x86_64-1.txz: Upgraded.
a/kernel-modules-6.1.12-x86_64-1.txz: Upgraded.
d/kernel-headers-6.1.12-x86-1.txz: Upgraded.
d/rust-1.66.1-x86_64-1.txz: Upgraded.
k/kernel-source-6.1.12-noarch-1.txz: Upgraded.
kde/bluedevil-5.27.0-x86_64-1.txz: Upgraded.
kde/breeze-5.27.0-x86_64-1.txz: Upgraded.
kde/breeze-grub-5.27.0-x86_64-1.txz: Upgraded.
kde/breeze-gtk-5.27.0-x86_64-1.txz: Upgraded.
kde/drkonqi-5.27.0-x86_64-1.txz: Upgraded.
kde/kactivitymanagerd-5.27.0-x86_64-1.txz: Upgraded.
kde/kde-cli-tools-5.27.0-x86_64-1.txz: Upgraded.
kde/kde-gtk-config-5.27.0-x86_64-1.txz: Upgraded.
kde/kdecoration-5.27.0-x86_64-1.txz: Upgraded.
kde/kdeplasma-addons-5.27.0-x86_64-1.txz: Upgraded.
kde/kgamma5-5.27.0-x86_64-1.txz: Upgraded.
kde/khotkeys-5.27.0-x86_64-1.txz: Upgraded.
kde/kinfocenter-5.27.0-x86_64-1.txz: Upgraded.
kde/kmenuedit-5.27.0-x86_64-1.txz: Upgraded.
kde/kpipewire-5.27.0-x86_64-1.txz: Upgraded.
kde/kscreen-5.27.0-x86_64-1.txz: Upgraded.
kde/kscreenlocker-5.27.0-x86_64-1.txz: Upgraded.
kde/ksshaskpass-5.27.0-x86_64-1.txz: Upgraded.
kde/ksystemstats-5.27.0-x86_64-1.txz: Upgraded.
kde/kwallet-pam-5.27.0-x86_64-1.txz: Upgraded.
kde/kwayland-integration-5.27.0-x86_64-1.txz: Upgraded.
kde/kwin-5.27.0-x86_64-1.txz: Upgraded.
kde/kwrited-5.27.0-x86_64-1.txz: Upgraded.
kde/layer-shell-qt-5.27.0-x86_64-1.txz: Upgraded.
kde/libkscreen-5.27.0-x86_64-1.txz: Upgraded.
kde/libksysguard-5.27.0-x86_64-1.txz: Upgraded.
kde/milou-5.27.0-x86_64-1.txz: Upgraded.
kde/oxygen-5.27.0-x86_64-1.txz: Upgraded.
kde/oxygen-sounds-5.27.0-x86_64-1.txz: Upgraded.
kde/plasma-browser-integration-5.27.0-x86_64-1.txz: Upgraded.
kde/plasma-desktop-5.27.0-x86_64-1.txz: Upgraded.
kde/plasma-disks-5.27.0-x86_64-1.txz: Upgraded.
kde/plasma-firewall-5.27.0-x86_64-1.txz: Upgraded.
kde/plasma-integration-5.27.0-x86_64-1.txz: Upgraded.
kde/plasma-nm-5.27.0-x86_64-1.txz: Upgraded.
kde/plasma-pa-5.27.0-x86_64-1.txz: Upgraded.
kde/plasma-sdk-5.27.0-x86_64-1.txz: Upgraded.
kde/plasma-systemmonitor-5.27.0-x86_64-1.txz: Upgraded.
kde/plasma-vault-5.27.0-x86_64-1.txz: Upgraded.
kde/plasma-workspace-5.27.0-x86_64-1.txz: Upgraded.
kde/plasma-workspace-wallpapers-5.27.0-x86_64-1.txz: Upgraded.
kde/polkit-kde-agent-1-5.27.0-x86_64-1.txz: Upgraded.
kde/powerdevil-5.27.0-x86_64-1.txz: Upgraded.
kde/qqc2-breeze-style-5.27.0-x86_64-1.txz: Upgraded.
kde/sddm-kcm-5.27.0-x86_64-1.txz: Upgraded.
kde/systemsettings-5.27.0-x86_64-1.txz: Upgraded.
kde/xdg-desktop-portal-kde-5.27.0-x86_64-1.txz: Upgraded.
l/mozjs102-102.8.0esr-x86_64-1.txz: Upgraded.
n/php-7.4.33-x86_64-3.txz: Rebuilt.
Core: Password_verify() always return true with some hash.
Core: 1-byte array overrun in common path resolve code.
SAPI: DOS vulnerability when parsing multipart request body.
https://www.cve.org/CVERecord?id=CVE-2023-0567
https://www.cve.org/CVERecord?id=CVE-2023-0568
https://www.cve.org/CVERecord?id=CVE-2023-0662
xap/mozilla-firefox-110.0-x86_64-1.txz: Upgraded.
https://www.mozilla.org/en-US/firefox/110.0/releasenotes/
https://www.mozilla.org/en-US/security/advisories/mfsa2023-05/
https://www.cve.org/CVERecord?id=CVE-2023-25728
https://www.cve.org/CVERecord?id=CVE-2023-25730
https://www.cve.org/CVERecord?id=CVE-2023-25743
https://www.cve.org/CVERecord?id=CVE-2023-0767
https://www.cve.org/CVERecord?id=CVE-2023-25735
https://www.cve.org/CVERecord?id=CVE-2023-25737
https://www.cve.org/CVERecord?id=CVE-2023-25738
https://www.cve.org/CVERecord?id=CVE-2023-25739
https://www.cve.org/CVERecord?id=CVE-2023-25729
https://www.cve.org/CVERecord?id=CVE-2023-25732
https://www.cve.org/CVERecord?id=CVE-2023-25734
https://www.cve.org/CVERecord?id=CVE-2023-25740
https://www.cve.org/CVERecord?id=CVE-2023-25731
https://www.cve.org/CVERecord?id=CVE-2023-25733
https://www.cve.org/CVERecord?id=CVE-2023-25736
https://www.cve.org/CVERecord?id=CVE-2023-25741
https://www.cve.org/CVERecord?id=CVE-2023-25742
https://www.cve.org/CVERecord?id=CVE-2023-25744
https://www.cve.org/CVERecord?id=CVE-2023-25745
extra/php80/php80-8.0.28-x86_64-1.txz: Upgraded.
extra/php81/php81-8.1.16-x86_64-1.txz: Upgraded.
testing/packages/rust-1.67.1-x86_64-1.txz: Upgraded.
Mon Feb 13 20:03:36 UTC 2023
ap/man-pages-6.03-noarch-1.txz: Upgraded.
l/atkmm-2.28.3-x86_64-1.txz: Upgraded.
l/cairomm-1.14.4-x86_64-1.txz: Upgraded.
l/glibmm-2.66.5-x86_64-1.txz: Upgraded.
l/imagemagick-7.1.0_62-x86_64-1.txz: Upgraded.
n/nghttp2-1.52.0-x86_64-1.txz: Upgraded.
x/util-macros-1.20.0-noarch-1.txz: Upgraded.
Mon Feb 13 01:09:36 UTC 2023
d/vala-0.56.4-x86_64-1.txz: Upgraded.
kde/attica-5.103.0-x86_64-1.txz: Upgraded.
kde/baloo-5.103.0-x86_64-1.txz: Upgraded.
kde/bluez-qt-5.103.0-x86_64-1.txz: Upgraded.
kde/breeze-icons-5.103.0-noarch-1.txz: Upgraded.
kde/extra-cmake-modules-5.103.0-x86_64-1.txz: Upgraded.
kde/frameworkintegration-5.103.0-x86_64-1.txz: Upgraded.
kde/kactivities-5.103.0-x86_64-1.txz: Upgraded.
kde/kactivities-stats-5.103.0-x86_64-1.txz: Upgraded.
kde/kapidox-5.103.0-x86_64-1.txz: Upgraded.
kde/karchive-5.103.0-x86_64-1.txz: Upgraded.
kde/kauth-5.103.0-x86_64-1.txz: Upgraded.
kde/kbookmarks-5.103.0-x86_64-1.txz: Upgraded.
kde/kcalendarcore-5.103.0-x86_64-1.txz: Upgraded.
kde/kcmutils-5.103.0-x86_64-1.txz: Upgraded.
kde/kcodecs-5.103.0-x86_64-1.txz: Upgraded.
kde/kcompletion-5.103.0-x86_64-1.txz: Upgraded.
kde/kconfig-5.103.0-x86_64-1.txz: Upgraded.
kde/kconfigwidgets-5.103.0-x86_64-1.txz: Upgraded.
kde/kcontacts-5.103.0-x86_64-1.txz: Upgraded.
kde/kcoreaddons-5.103.0-x86_64-1.txz: Upgraded.
kde/kcrash-5.103.0-x86_64-1.txz: Upgraded.
kde/kdav-5.103.0-x86_64-1.txz: Upgraded.
kde/kdbusaddons-5.103.0-x86_64-1.txz: Upgraded.
kde/kdeclarative-5.103.0-x86_64-1.txz: Upgraded.
kde/kded-5.103.0-x86_64-1.txz: Upgraded.
kde/kdelibs4support-5.103.0-x86_64-1.txz: Upgraded.
kde/kdesignerplugin-5.103.0-x86_64-1.txz: Upgraded.
kde/kdesu-5.103.0-x86_64-1.txz: Upgraded.
kde/kdewebkit-5.103.0-x86_64-1.txz: Upgraded.
kde/kdnssd-5.103.0-x86_64-1.txz: Upgraded.
kde/kdoctools-5.103.0-x86_64-1.txz: Upgraded.
kde/kemoticons-5.103.0-x86_64-1.txz: Upgraded.
kde/kfilemetadata-5.103.0-x86_64-1.txz: Upgraded.
kde/kglobalaccel-5.103.0-x86_64-1.txz: Upgraded.
kde/kguiaddons-5.103.0-x86_64-1.txz: Upgraded.
kde/kholidays-5.103.0-x86_64-1.txz: Upgraded.
kde/khtml-5.103.0-x86_64-1.txz: Upgraded.
kde/ki18n-5.103.0-x86_64-1.txz: Upgraded.
kde/kiconthemes-5.103.0-x86_64-1.txz: Upgraded.
kde/kidletime-5.103.0-x86_64-1.txz: Upgraded.
kde/kimageformats-5.103.0-x86_64-1.txz: Upgraded.
kde/kinit-5.103.0-x86_64-1.txz: Upgraded.
kde/kio-5.103.0-x86_64-1.txz: Upgraded.
kde/kirigami2-5.103.0-x86_64-1.txz: Upgraded.
kde/kitemmodels-5.103.0-x86_64-1.txz: Upgraded.
kde/kitemviews-5.103.0-x86_64-1.txz: Upgraded.
kde/kjobwidgets-5.103.0-x86_64-1.txz: Upgraded.
kde/kjs-5.103.0-x86_64-1.txz: Upgraded.
kde/kjsembed-5.103.0-x86_64-1.txz: Upgraded.
kde/kmediaplayer-5.103.0-x86_64-1.txz: Upgraded.
kde/knewstuff-5.103.0-x86_64-1.txz: Upgraded.
kde/knotifications-5.103.0-x86_64-1.txz: Upgraded.
kde/knotifyconfig-5.103.0-x86_64-1.txz: Upgraded.
kde/kpackage-5.103.0-x86_64-1.txz: Upgraded.
kde/kparts-5.103.0-x86_64-1.txz: Upgraded.
kde/kpeople-5.103.0-x86_64-1.txz: Upgraded.
kde/kplotting-5.103.0-x86_64-1.txz: Upgraded.
kde/kpty-5.103.0-x86_64-1.txz: Upgraded.
kde/kquickcharts-5.103.0-x86_64-1.txz: Upgraded.
kde/kross-5.103.0-x86_64-1.txz: Upgraded.
kde/krunner-5.103.0-x86_64-1.txz: Upgraded.
kde/kservice-5.103.0-x86_64-1.txz: Upgraded.
kde/ktexteditor-5.103.0-x86_64-1.txz: Upgraded.
kde/ktextwidgets-5.103.0-x86_64-1.txz: Upgraded.
kde/kunitconversion-5.103.0-x86_64-1.txz: Upgraded.
kde/kwallet-5.103.0-x86_64-1.txz: Upgraded.
kde/kwayland-5.103.0-x86_64-1.txz: Upgraded.
kde/kwidgetsaddons-5.103.0-x86_64-1.txz: Upgraded.
kde/kwindowsystem-5.103.0-x86_64-1.txz: Upgraded.
kde/kxmlgui-5.103.0-x86_64-1.txz: Upgraded.
kde/kxmlrpcclient-5.103.0-x86_64-1.txz: Upgraded.
kde/modemmanager-qt-5.103.0-x86_64-1.txz: Upgraded.
kde/networkmanager-qt-5.103.0-x86_64-1.txz: Upgraded.
kde/oxygen-icons5-5.103.0-noarch-1.txz: Upgraded.
kde/plasma-framework-5.103.0-x86_64-1.txz: Upgraded.
kde/prison-5.103.0-x86_64-1.txz: Upgraded.
kde/purpose-5.103.0-x86_64-1.txz: Upgraded.
kde/qqc2-desktop-style-5.103.0-x86_64-1.txz: Upgraded.
kde/solid-5.103.0-x86_64-1.txz: Upgraded.
kde/sonnet-5.103.0-x86_64-1.txz: Upgraded.
kde/syndication-5.103.0-x86_64-1.txz: Upgraded.
kde/syntax-highlighting-5.103.0-x86_64-1.txz: Upgraded.
kde/threadweaver-5.103.0-x86_64-1.txz: Upgraded.
l/ffmpeg-5.1.2-x86_64-2.txz: Rebuilt.
Recompiled against libvpx-1.13.0.
l/gst-plugins-good-1.22.0-x86_64-2.txz: Rebuilt.
l/harfbuzz-7.0.0-x86_64-1.txz: Upgraded.
l/qt5-5.15.8_20230208_cae1723a-x86_64-1.txz: Upgraded.
Compiled against libvpx-1.13.0.
l/vte-0.70.3-x86_64-1.txz: Upgraded.
xap/xine-lib-1.2.13-x86_64-2.txz: Rebuilt.
Slackware 32-bit
a/kernel-generic-6.1.12-i586-1.txz: Upgraded.
a/kernel-generic-smp-6.1.12_smp-i686-1.txz: Upgraded.
a/kernel-huge-6.1.12-i586-1.txz: Upgraded.
a/kernel-huge-smp-6.1.12_smp-i686-1.txz: Upgraded.
a/kernel-modules-6.1.12-i586-1.txz: Upgraded.
a/kernel-modules-smp-6.1.12_smp-i686-1.txz: Upgraded.
d/kernel-headers-6.1.12_smp-x86-1.txz: Upgraded.
d/rust-1.66.1-i686-1.txz: Upgraded.
k/kernel-source-6.1.12_smp-noarch-1.txz: Upgraded.
kde/bluedevil-5.27.0-i586-1.txz: Upgraded.
kde/breeze-5.27.0-i586-1.txz: Upgraded.
kde/breeze-grub-5.27.0-i586-1.txz: Upgraded.
kde/breeze-gtk-5.27.0-i586-1.txz: Upgraded.
kde/drkonqi-5.27.0-i586-1.txz: Upgraded.
kde/kactivitymanagerd-5.27.0-i586-1.txz: Upgraded.
kde/kde-cli-tools-5.27.0-i586-1.txz: Upgraded.
kde/kde-gtk-config-5.27.0-i586-1.txz: Upgraded.
kde/kdecoration-5.27.0-i586-1.txz: Upgraded.
kde/kdeplasma-addons-5.27.0-i586-1.txz: Upgraded.
kde/kgamma5-5.27.0-i586-1.txz: Upgraded.
kde/khotkeys-5.27.0-i586-1.txz: Upgraded.
kde/kinfocenter-5.27.0-i586-1.txz: Upgraded.
kde/kmenuedit-5.27.0-i586-1.txz: Upgraded.
kde/kpipewire-5.27.0-i586-1.txz: Upgraded.
kde/kscreen-5.27.0-i586-1.txz: Upgraded.
kde/kscreenlocker-5.27.0-i586-1.txz: Upgraded.
kde/ksshaskpass-5.27.0-i586-1.txz: Upgraded.
kde/ksystemstats-5.27.0-i586-1.txz: Upgraded.
kde/kwallet-pam-5.27.0-i586-1.txz: Upgraded.
kde/kwayland-integration-5.27.0-i586-1.txz: Upgraded.
kde/kwin-5.27.0-i586-1.txz: Upgraded.
kde/kwrited-5.27.0-i586-1.txz: Upgraded.
kde/layer-shell-qt-5.27.0-i586-1.txz: Upgraded.
kde/libkscreen-5.27.0-i586-1.txz: Upgraded.
kde/libksysguard-5.27.0-i586-1.txz: Upgraded.
kde/milou-5.27.0-i586-1.txz: Upgraded.
kde/oxygen-5.27.0-i586-1.txz: Upgraded.
kde/oxygen-sounds-5.27.0-i586-1.txz: Upgraded.
kde/plasma-browser-integration-5.27.0-i586-1.txz: Upgraded.
kde/plasma-desktop-5.27.0-i586-1.txz: Upgraded.
kde/plasma-disks-5.27.0-i586-1.txz: Upgraded.
kde/plasma-firewall-5.27.0-i586-1.txz: Upgraded.
kde/plasma-integration-5.27.0-i586-1.txz: Upgraded.
kde/plasma-nm-5.27.0-i586-1.txz: Upgraded.
kde/plasma-pa-5.27.0-i586-1.txz: Upgraded.
kde/plasma-sdk-5.27.0-i586-1.txz: Upgraded.
kde/plasma-systemmonitor-5.27.0-i586-1.txz: Upgraded.
kde/plasma-vault-5.27.0-i586-1.txz: Upgraded.
kde/plasma-workspace-5.27.0-i586-1.txz: Upgraded.
kde/plasma-workspace-wallpapers-5.27.0-i586-1.txz: Upgraded.
kde/polkit-kde-agent-1-5.27.0-i586-1.txz: Upgraded.
kde/powerdevil-5.27.0-i586-1.txz: Upgraded.
kde/qqc2-breeze-style-5.27.0-i586-1.txz: Upgraded.
kde/sddm-kcm-5.27.0-i586-1.txz: Upgraded.
kde/systemsettings-5.27.0-i586-1.txz: Upgraded.
kde/xdg-desktop-portal-kde-5.27.0-i586-1.txz: Upgraded.
l/mozjs102-102.8.0esr-i686-1.txz: Upgraded.
n/php-7.4.33-i586-3.txz: Rebuilt.
xap/mozilla-firefox-110.0-i686-1.txz: Upgraded.
extra/linux-6.1.12-nosmp-sdk/*: Upgraded.
extra/php80/php80-8.0.28-i586-1.txz: Upgraded.
extra/php81/php81-8.1.16-i586-1.txz: Upgraded.
testing/packages/rust-1.67.1-i686-1.txz: Upgraded.
l/atkmm-2.28.3-i586-1.txz: Upgraded.
l/cairomm-1.14.4-i586-1.txz: Upgraded.
l/glibmm-2.66.5-i586-1.txz: Upgraded.
l/imagemagick-7.1.0_62-i586-1.txz: Upgraded.
n/nghttp2-1.52.0-i586-1.txz: Upgraded.
d/vala-0.56.4-i586-1.txz: Upgraded.
kde/attica-5.103.0-i586-1.txz: Upgraded.
kde/baloo-5.103.0-i586-1.txz: Upgraded.
kde/bluez-qt-5.103.0-i586-1.txz: Upgraded.
kde/extra-cmake-modules-5.103.0-i586-1.txz: Upgraded.
kde/frameworkintegration-5.103.0-i586-1.txz: Upgraded.
kde/kactivities-5.103.0-i586-1.txz: Upgraded.
kde/kactivities-stats-5.103.0-i586-1.txz: Upgraded.
kde/kapidox-5.103.0-i586-1.txz: Upgraded.
kde/karchive-5.103.0-i586-1.txz: Upgraded.
kde/kauth-5.103.0-i586-1.txz: Upgraded.
kde/kbookmarks-5.103.0-i586-1.txz: Upgraded.
kde/kcalendarcore-5.103.0-i586-1.txz: Upgraded.
kde/kcmutils-5.103.0-i586-1.txz: Upgraded.
kde/kcodecs-5.103.0-i586-1.txz: Upgraded.
kde/kcompletion-5.103.0-i586-1.txz: Upgraded.
kde/kconfig-5.103.0-i586-1.txz: Upgraded.
kde/kconfigwidgets-5.103.0-i586-1.txz: Upgraded.
kde/kcontacts-5.103.0-i586-1.txz: Upgraded.
kde/kcoreaddons-5.103.0-i586-1.txz: Upgraded.
kde/kcrash-5.103.0-i586-1.txz: Upgraded.
kde/kdav-5.103.0-i586-1.txz: Upgraded.
kde/kdbusaddons-5.103.0-i586-1.txz: Upgraded.
kde/kdeclarative-5.103.0-i586-1.txz: Upgraded.
kde/kded-5.103.0-i586-1.txz: Upgraded.
kde/kdelibs4support-5.103.0-i586-1.txz: Upgraded.
kde/kdesignerplugin-5.103.0-i586-1.txz: Upgraded.
kde/kdesu-5.103.0-i586-1.txz: Upgraded.
kde/kdewebkit-5.103.0-i586-1.txz: Upgraded.
kde/kdnssd-5.103.0-i586-1.txz: Upgraded.
kde/kdoctools-5.103.0-i586-1.txz: Upgraded.
kde/kemoticons-5.103.0-i586-1.txz: Upgraded.
kde/kfilemetadata-5.103.0-i586-1.txz: Upgraded.
kde/kglobalaccel-5.103.0-i586-1.txz: Upgraded.
kde/kguiaddons-5.103.0-i586-1.txz: Upgraded.
kde/kholidays-5.103.0-i586-1.txz: Upgraded.
kde/khtml-5.103.0-i586-1.txz: Upgraded.
kde/ki18n-5.103.0-i586-1.txz: Upgraded.
kde/kiconthemes-5.103.0-i586-1.txz: Upgraded.
kde/kidletime-5.103.0-i586-1.txz: Upgraded.
kde/kimageformats-5.103.0-i586-1.txz: Upgraded.
kde/kinit-5.103.0-i586-1.txz: Upgraded.
kde/kio-5.103.0-i586-1.txz: Upgraded.
kde/kirigami2-5.103.0-i586-1.txz: Upgraded.
kde/kitemmodels-5.103.0-i586-1.txz: Upgraded.
kde/kitemviews-5.103.0-i586-1.txz: Upgraded.
kde/kjobwidgets-5.103.0-i586-1.txz: Upgraded.
kde/kjs-5.103.0-i586-1.txz: Upgraded.
kde/kjsembed-5.103.0-i586-1.txz: Upgraded.
kde/kmediaplayer-5.103.0-i586-1.txz: Upgraded.
kde/knewstuff-5.103.0-i586-1.txz: Upgraded.
kde/knotifications-5.103.0-i586-1.txz: Upgraded.
kde/knotifyconfig-5.103.0-i586-1.txz: Upgraded.
kde/kpackage-5.103.0-i586-1.txz: Upgraded.
kde/kparts-5.103.0-i586-1.txz: Upgraded.
kde/kpeople-5.103.0-i586-1.txz: Upgraded.
kde/kplotting-5.103.0-i586-1.txz: Upgraded.
kde/kpty-5.103.0-i586-1.txz: Upgraded.
kde/kquickcharts-5.103.0-i586-1.txz: Upgraded.
kde/kross-5.103.0-i586-1.txz: Upgraded.
kde/krunner-5.103.0-i586-1.txz: Upgraded.
kde/kservice-5.103.0-i586-1.txz: Upgraded.
kde/ktexteditor-5.103.0-i586-1.txz: Upgraded.
kde/ktextwidgets-5.103.0-i586-1.txz: Upgraded.
kde/kunitconversion-5.103.0-i586-1.txz: Upgraded.
kde/kwallet-5.103.0-i586-1.txz: Upgraded.
kde/kwayland-5.103.0-i586-1.txz: Upgraded.
kde/kwidgetsaddons-5.103.0-i586-1.txz: Upgraded.
kde/kwindowsystem-5.103.0-i586-1.txz: Upgraded.
kde/kxmlgui-5.103.0-i586-1.txz: Upgraded.
kde/kxmlrpcclient-5.103.0-i586-1.txz: Upgraded.
kde/modemmanager-qt-5.103.0-i586-1.txz: Upgraded.
kde/networkmanager-qt-5.103.0-i586-1.txz: Upgraded.
kde/plasma-framework-5.103.0-i586-1.txz: Upgraded.
kde/prison-5.103.0-i586-1.txz: Upgraded.
kde/purpose-5.103.0-i586-1.txz: Upgraded.
kde/qqc2-desktop-style-5.103.0-i586-1.txz: Upgraded.
kde/solid-5.103.0-i586-1.txz: Upgraded.
kde/sonnet-5.103.0-i586-1.txz: Upgraded.
kde/syndication-5.103.0-i586-1.txz: Upgraded.
kde/syntax-highlighting-5.103.0-i586-1.txz: Upgraded.
kde/threadweaver-5.103.0-i586-1.txz: Upgraded.
l/ffmpeg-5.1.2-i586-2.txz: Rebuilt.
l/gst-plugins-good-1.22.0-i586-2.txz: Rebuilt.
l/harfbuzz-7.0.0-i586-1.txz: Upgraded.
l/qt5-5.15.8_20230208_cae1723a-i586-1.txz: Upgraded.
l/vte-0.70.3-i586-1.txz: Upgraded.
xap/xine-lib-1.2.13-i586-2.txz: Rebuilt.
Napisano: 25 Feb 2023, 19:38
Slackware 64-bit
Fri Feb 24 19:54:11 UTC 2023
d/meson-1.0.1-x86_64-1.txz: Upgraded.
l/gjs-1.74.2-x86_64-1.txz: Upgraded.
x/mesa-22.3.6-x86_64-2.txz: Rebuilt.
Hardlink duplicated Amber drivers. Thanks to e5150.
Thu Feb 23 20:47:06 UTC 2023
ap/sqlite-3.41.0-x86_64-1.txz: Upgraded.
d/parallel-20230222-noarch-1.txz: Upgraded.
kde/kidletime-5.103.0-x86_64-2.txz: Rebuilt.
[PATCH] wayland: Guard wayland object destructors.
Thanks to marav.
l/glib2-2.74.6-x86_64-1.txz: Upgraded.
l/nodejs-19.7.0-x86_64-1.txz: Upgraded.
l/v4l-utils-1.24.0-x86_64-1.txz: Upgraded.
n/NetworkManager-1.42.2-x86_64-1.txz: Upgraded.
x/font-util-1.4.0-x86_64-1.txz: Upgraded.
x/mesa-22.3.6-x86_64-1.txz: Upgraded.
x/xbitmaps-1.1.3-x86_64-1.txz: Upgraded.
x/xcursor-themes-1.0.7-noarch-1.txz: Upgraded.
x/xf86-video-amdgpu-23.0.0-x86_64-1.txz: Upgraded.
x/xorg-cf-files-1.0.8-x86_64-1.txz: Upgraded.
xap/gimp-2.10.34-x86_64-1.txz: Upgraded.
xap/gparted-1.5.0-x86_64-1.txz: Upgraded.
xfce/thunar-4.18.4-x86_64-1.txz: Upgraded.
Thu Feb 23 06:05:39 UTC 2023
a/kernel-firmware-20230215_83f1d77-noarch-1.txz: Upgraded.
a/kernel-generic-6.1.13-x86_64-1.txz: Upgraded.
a/kernel-huge-6.1.13-x86_64-1.txz: Upgraded.
a/kernel-modules-6.1.13-x86_64-1.txz: Upgraded.
d/kernel-headers-6.1.13-x86-1.txz: Upgraded.
k/kernel-source-6.1.13-noarch-1.txz: Upgraded.
ACPI_EC_DEBUGFS m -> n
INIT_STACK_ALL_ZERO n -> y
INIT_STACK_NONE y -> n
kde/bluedevil-5.27.1-x86_64-1.txz: Upgraded.
kde/breeze-5.27.1-x86_64-1.txz: Upgraded.
kde/breeze-grub-5.27.1-x86_64-1.txz: Upgraded.
kde/breeze-gtk-5.27.1-x86_64-1.txz: Upgraded.
kde/drkonqi-5.27.1-x86_64-1.txz: Upgraded.
kde/kactivitymanagerd-5.27.1-x86_64-1.txz: Upgraded.
kde/kde-cli-tools-5.27.1-x86_64-1.txz: Upgraded.
kde/kde-gtk-config-5.27.1-x86_64-1.txz: Upgraded.
kde/kdecoration-5.27.1-x86_64-1.txz: Upgraded.
kde/kdeplasma-addons-5.27.1-x86_64-1.txz: Upgraded.
kde/kgamma5-5.27.1-x86_64-1.txz: Upgraded.
kde/khotkeys-5.27.1-x86_64-1.txz: Upgraded.
kde/kinfocenter-5.27.1-x86_64-1.txz: Upgraded.
kde/kmenuedit-5.27.1-x86_64-1.txz: Upgraded.
kde/kpipewire-5.27.1-x86_64-1.txz: Upgraded.
kde/kscreen-5.27.1.1-x86_64-1.txz: Upgraded.
kde/kscreenlocker-5.27.1-x86_64-1.txz: Upgraded.
kde/ksshaskpass-5.27.1-x86_64-1.txz: Upgraded.
kde/ksystemstats-5.27.1-x86_64-1.txz: Upgraded.
kde/kwallet-pam-5.27.1-x86_64-1.txz: Upgraded.
kde/kwayland-integration-5.27.1-x86_64-1.txz: Upgraded.
kde/kwin-5.27.1-x86_64-1.txz: Upgraded.
kde/kwrited-5.27.1-x86_64-1.txz: Upgraded.
kde/layer-shell-qt-5.27.1-x86_64-1.txz: Upgraded.
kde/libkscreen-5.27.1-x86_64-1.txz: Upgraded.
kde/libksysguard-5.27.1-x86_64-1.txz: Upgraded.
kde/milou-5.27.1-x86_64-1.txz: Upgraded.
kde/oxygen-5.27.1-x86_64-1.txz: Upgraded.
kde/oxygen-sounds-5.27.1-x86_64-1.txz: Upgraded.
kde/plasma-browser-integration-5.27.1-x86_64-1.txz: Upgraded.
kde/plasma-desktop-5.27.1-x86_64-1.txz: Upgraded.
kde/plasma-disks-5.27.1-x86_64-1.txz: Upgraded.
kde/plasma-firewall-5.27.1-x86_64-1.txz: Upgraded.
kde/plasma-integration-5.27.1-x86_64-1.txz: Upgraded.
kde/plasma-nm-5.27.1-x86_64-1.txz: Upgraded.
kde/plasma-pa-5.27.1-x86_64-1.txz: Upgraded.
kde/plasma-sdk-5.27.1-x86_64-1.txz: Upgraded.
kde/plasma-systemmonitor-5.27.1-x86_64-1.txz: Upgraded.
kde/plasma-vault-5.27.1-x86_64-1.txz: Upgraded.
kde/plasma-workspace-5.27.1-x86_64-1.txz: Upgraded.
kde/plasma-workspace-wallpapers-5.27.1-x86_64-1.txz: Upgraded.
kde/polkit-kde-agent-1-5.27.1-x86_64-1.txz: Upgraded.
kde/powerdevil-5.27.1-x86_64-1.txz: Upgraded.
kde/qqc2-breeze-style-5.27.1-x86_64-1.txz: Upgraded.
kde/sddm-kcm-5.27.1-x86_64-1.txz: Upgraded.
kde/systemsettings-5.27.1-x86_64-1.txz: Upgraded.
kde/xdg-desktop-portal-kde-5.27.1-x86_64-1.txz: Upgraded.
Tue Feb 21 19:15:06 UTC 2023
ap/vim-9.0.1337-x86_64-1.txz: Upgraded.
OK, so the upstream runtime update didn't fix sh syntax highlighting, so we
patched it. Thanks to marav.
Also, we needed this version number. ;-)
d/autoconf-archive-2023.02.20-noarch-1.txz: Upgraded.
l/babl-0.1.100-x86_64-1.txz: Upgraded.
l/gegl-0.4.42-x86_64-1.txz: Upgraded.
x/ibus-1.5.28-x86_64-1.txz: Upgraded.
x/ibus-libpinyin-1.15.1-x86_64-1.txz: Upgraded.
xap/vim-gvim-9.0.1337-x86_64-1.txz: Upgraded.
Mon Feb 20 22:35:43 UTC 2023
ap/vim-9.0.1333-x86_64-1.txz: Upgraded.
n/iproute2-6.2.0-x86_64-1.txz: Upgraded.
xap/vim-gvim-9.0.1333-x86_64-1.txz: Upgraded.
Mon Feb 20 19:41:06 UTC 2023
l/harfbuzz-7.0.1-x86_64-1.txz: Upgraded.
l/pango-1.50.13-x86_64-1.txz: Upgraded.
n/curl-7.88.1-x86_64-1.txz: Upgraded.
n/gnupg2-2.4.0-x86_64-1.txz: Upgraded.
n/traceroute-2.1.2-x86_64-1.txz: Upgraded.
x/ibus-m17n-1.4.19-x86_64-1.txz: Upgraded.
Sun Feb 19 20:11:11 UTC 2023
ap/sudo-1.9.13p1-x86_64-1.txz: Upgraded.
d/gdb-13.1-x86_64-1.txz: Upgraded.
l/enchant-2.3.4-x86_64-1.txz: Upgraded.
l/libnotify-0.8.2-x86_64-1.txz: Upgraded.
y/nethack-3.6.7-x86_64-1.txz: Upgraded.
Fri Feb 17 21:36:03 UTC 2023
l/fuse3-3.14.0-x86_64-1.txz: Upgraded.
l/libsigc++3-3.4.0-x86_64-1.txz: Upgraded.
l/nodejs-19.6.1-x86_64-1.txz: Upgraded.
xfce/xfce4-notifyd-0.8.1-x86_64-1.txz: Upgraded.
Thu Feb 16 22:07:06 UTC 2023
ap/vim-9.0.1314-x86_64-1.txz: Upgraded.
l/pipewire-0.3.66-x86_64-1.txz: Upgraded.
n/bind-9.18.12-x86_64-1.txz: Upgraded.
x/xf86-video-s3virge-1.11.1-x86_64-1.txz: Added.
x/xf86-video-trident-1.4.0-x86_64-1.txz: Added.
x/xterm-379-x86_64-1.txz: Upgraded.
xap/freerdp-2.10.0-x86_64-1.txz: Upgraded.
xap/mozilla-thunderbird-102.8.0-x86_64-1.txz: Upgraded.
https://www.mozilla.org/en-US/thunderbird/102.8.0/releasenotes/
https://www.mozilla.org/en-US/security/advisories/mfsa2023-07/
https://www.cve.org/CVERecord?id=CVE-2023-0616
https://www.cve.org/CVERecord?id=CVE-2023-25746
xap/vim-gvim-9.0.1314-x86_64-1.txz: Upgraded.
Wed Feb 15 19:48:10 UTC 2023
ap/sudo-1.9.13-x86_64-1.txz: Upgraded.
d/git-2.39.2-x86_64-1.txz: Upgraded.
Using a specially-crafted repository, Git can be tricked into using
its local clone optimization even when using a non-local transport.
Though Git will abort local clones whose source $GIT_DIR/objects
directory contains symbolic links (c.f., CVE-2022-39253), the objects
directory itself may still be a symbolic link.
These two may be combined to include arbitrary files based on known
paths on the victim's filesystem within the malicious repository's
working copy, allowing for data exfiltration in a similar manner as
CVE-2022-39253.
By feeding a crafted input to "git apply", a path outside the
working tree can be overwritten as the user who is running "git
apply".
https://www.cve.org/CVERecord?id=CVE-2023-22490
https://www.cve.org/CVERecord?id=CVE-2023-23946
n/curl-7.88.0-x86_64-1.txz: Upgraded.
HTTP multi-header compression denial of service.
HSTS amnesia with --parallel.
HSTS ignored on multiple requests.
https://curl.se/docs/CVE-2023-23916.html
https://curl.se/docs/CVE-2023-23915.html
https://curl.se/docs/CVE-2023-23914.html
https://www.cve.org/CVERecord?id=CVE-2023-23916
https://www.cve.org/CVERecord?id=CVE-2023-23915
https://www.cve.org/CVERecord?id=CVE-2023-23914
Slackware 32-bit
d/meson-1.0.1-i586-1.txz: Upgraded.
l/gjs-1.74.2-i586-1.txz: Upgraded.
x/mesa-22.3.6-i586-2.txz: Rebuilt.
ap/sqlite-3.41.0-i586-1.txz: Upgraded.
kde/kidletime-5.103.0-i586-2.txz: Rebuilt.
Thanks to marav.
l/glib2-2.74.6-i586-1.txz: Upgraded.
l/nodejs-19.7.0-i586-1.txz: Upgraded.
l/v4l-utils-1.24.0-i586-1.txz: Upgraded.
n/NetworkManager-1.42.2-i586-1.txz: Upgraded.
x/font-util-1.4.0-i586-1.txz: Upgraded.
x/mesa-22.3.6-i586-1.txz: Upgraded.
x/xbitmaps-1.1.3-i586-1.txz: Upgraded.
x/xf86-video-amdgpu-23.0.0-i586-1.txz: Upgraded.
x/xorg-cf-files-1.0.8-i586-1.txz: Upgraded.
xap/gimp-2.10.34-i586-1.txz: Upgraded.
xap/gparted-1.5.0-i586-1.txz: Upgraded.
xfce/thunar-4.18.4-i586-1.txz: Upgraded.
a/kernel-generic-6.1.13-i586-1.txz: Upgraded.
a/kernel-generic-smp-6.1.13_smp-i686-1.txz: Upgraded.
a/kernel-huge-6.1.13-i586-1.txz: Upgraded.
a/kernel-huge-smp-6.1.13_smp-i686-1.txz: Upgraded.
a/kernel-modules-6.1.13-i586-1.txz: Upgraded.
a/kernel-modules-smp-6.1.13_smp-i686-1.txz: Upgraded.
d/kernel-headers-6.1.13_smp-x86-1.txz: Upgraded.
k/kernel-source-6.1.13_smp-noarch-1.txz: Upgraded.
kde/bluedevil-5.27.1-i586-1.txz: Upgraded.
kde/breeze-5.27.1-i586-1.txz: Upgraded.
kde/breeze-grub-5.27.1-i586-1.txz: Upgraded.
kde/breeze-gtk-5.27.1-i586-1.txz: Upgraded.
kde/drkonqi-5.27.1-i586-1.txz: Upgraded.
kde/kactivitymanagerd-5.27.1-i586-1.txz: Upgraded.
kde/kde-cli-tools-5.27.1-i586-1.txz: Upgraded.
kde/kde-gtk-config-5.27.1-i586-1.txz: Upgraded.
kde/kdecoration-5.27.1-i586-1.txz: Upgraded.
kde/kdeplasma-addons-5.27.1-i586-1.txz: Upgraded.
kde/kgamma5-5.27.1-i586-1.txz: Upgraded.
kde/khotkeys-5.27.1-i586-1.txz: Upgraded.
kde/kinfocenter-5.27.1-i586-1.txz: Upgraded.
kde/kmenuedit-5.27.1-i586-1.txz: Upgraded.
kde/kpipewire-5.27.1-i586-1.txz: Upgraded.
kde/kscreen-5.27.1.1-i586-1.txz: Upgraded.
kde/kscreenlocker-5.27.1-i586-1.txz: Upgraded.
kde/ksshaskpass-5.27.1-i586-1.txz: Upgraded.
kde/ksystemstats-5.27.1-i586-1.txz: Upgraded.
kde/kwallet-pam-5.27.1-i586-1.txz: Upgraded.
kde/kwayland-integration-5.27.1-i586-1.txz: Upgraded.
kde/kwin-5.27.1-i586-1.txz: Upgraded.
kde/kwrited-5.27.1-i586-1.txz: Upgraded.
kde/layer-shell-qt-5.27.1-i586-1.txz: Upgraded.
kde/libkscreen-5.27.1-i586-1.txz: Upgraded.
kde/libksysguard-5.27.1-i586-1.txz: Upgraded.
kde/milou-5.27.1-i586-1.txz: Upgraded.
kde/oxygen-5.27.1-i586-1.txz: Upgraded.
kde/oxygen-sounds-5.27.1-i586-1.txz: Upgraded.
kde/plasma-browser-integration-5.27.1-i586-1.txz: Upgraded.
kde/plasma-desktop-5.27.1-i586-1.txz: Upgraded.
kde/plasma-disks-5.27.1-i586-1.txz: Upgraded.
kde/plasma-firewall-5.27.1-i586-1.txz: Upgraded.
kde/plasma-integration-5.27.1-i586-1.txz: Upgraded.
kde/plasma-nm-5.27.1-i586-1.txz: Upgraded.
kde/plasma-pa-5.27.1-i586-1.txz: Upgraded.
kde/plasma-sdk-5.27.1-i586-1.txz: Upgraded.
kde/plasma-systemmonitor-5.27.1-i586-1.txz: Upgraded.
kde/plasma-vault-5.27.1-i586-1.txz: Upgraded.
kde/plasma-workspace-5.27.1-i586-1.txz: Upgraded.
kde/plasma-workspace-wallpapers-5.27.1-i586-1.txz: Upgraded.
kde/polkit-kde-agent-1-5.27.1-i586-1.txz: Upgraded.
kde/powerdevil-5.27.1-i586-1.txz: Upgraded.
kde/qqc2-breeze-style-5.27.1-i586-1.txz: Upgraded.
kde/sddm-kcm-5.27.1-i586-1.txz: Upgraded.
kde/systemsettings-5.27.1-i586-1.txz: Upgraded.
kde/xdg-desktop-portal-kde-5.27.1-i586-1.txz: Upgraded.
extra/linux-6.1.13-nosmp-sdk/*: Upgraded.
ap/vim-9.0.1337-i586-1.txz: Upgraded.
l/babl-0.1.100-i586-1.txz: Upgraded.
l/gegl-0.4.42-i586-1.txz: Upgraded.
x/ibus-1.5.28-i586-1.txz: Upgraded.
x/ibus-libpinyin-1.15.1-i586-1.txz: Upgraded.
xap/vim-gvim-9.0.1337-i586-1.txz: Upgraded.
ap/vim-9.0.1333-i586-1.txz: Upgraded.
n/iproute2-6.2.0-i586-1.txz: Upgraded.
xap/vim-gvim-9.0.1333-i586-1.txz: Upgraded.
l/harfbuzz-7.0.1-i586-1.txz: Upgraded.
l/pango-1.50.13-i586-1.txz: Upgraded.
n/curl-7.88.1-i586-1.txz: Upgraded.
n/gnupg2-2.4.0-i586-1.txz: Upgraded.
n/traceroute-2.1.2-i586-1.txz: Upgraded.
x/ibus-m17n-1.4.19-i586-1.txz: Upgraded.
ap/sudo-1.9.13p1-i586-1.txz: Upgraded.
d/gdb-13.1-i586-1.txz: Upgraded.
l/enchant-2.3.4-i586-1.txz: Upgraded.
l/libnotify-0.8.2-i586-1.txz: Upgraded.
y/nethack-3.6.7-i586-1.txz: Upgraded.
l/fuse3-3.14.0-i586-1.txz: Upgraded.
l/libsigc++3-3.4.0-i586-1.txz: Upgraded.
l/nodejs-19.6.1-i586-1.txz: Upgraded.
xfce/xfce4-notifyd-0.8.1-i586-1.txz: Upgraded.
ap/vim-9.0.1314-i586-1.txz: Upgraded.
l/pipewire-0.3.66-i586-1.txz: Upgraded.
n/bind-9.18.12-i586-1.txz: Upgraded.
x/xf86-video-s3virge-1.11.1-i586-1.txz: Added.
x/xf86-video-trident-1.4.0-i586-1.txz: Added.
x/xterm-379-i586-1.txz: Upgraded.
xap/freerdp-2.10.0-i586-1.txz: Upgraded.
xap/mozilla-thunderbird-102.8.0-i686-1.txz: Upgraded.
xap/vim-gvim-9.0.1314-i586-1.txz: Upgraded.
ap/sudo-1.9.13-i586-1.txz: Upgraded.
d/git-2.39.2-i586-1.txz: Upgraded.
CVE-2022-39253.
apply".
n/curl-7.88.0-i586-1.txz: Upgraded.
Napisano: 01 Mar 2023, 23:03
Slackware 64-bit
Wed Mar 1 21:21:21 UTC 2023
a/btrfs-progs-6.2-x86_64-2.txz: Rebuilt.
Rebuilt to link btrfs-convert to libreiserfscore. Thanks to Didier Spaier.
a/reiserfsprogs-3.6.27-x86_64-5.txz: Rebuilt.
Add shared library and devel files. Thanks to Didier Spaier.
Wed Mar 1 20:18:13 UTC 2023
a/btrfs-progs-6.2-x86_64-1.txz: Upgraded.
l/libdiscid-0.6.3-x86_64-1.txz: Upgraded.
xap/xsnow-3.7.1-x86_64-1.txz: Upgraded.
Tue Feb 28 21:33:32 UTC 2023
a/mkinitrd-1.4.11-x86_64-31.txz: Rebuilt.
Fix the check to ensure -R is added when the root partition is a partition of
a RAID device.
Thanks to perrin4869 and drumz.
ap/vim-9.0.1362-x86_64-1.txz: Upgraded.
kde/bluedevil-5.27.2-x86_64-1.txz: Upgraded.
kde/breeze-5.27.2-x86_64-1.txz: Upgraded.
kde/breeze-grub-5.27.2-x86_64-1.txz: Upgraded.
kde/breeze-gtk-5.27.2-x86_64-1.txz: Upgraded.
kde/drkonqi-5.27.2-x86_64-1.txz: Upgraded.
kde/kactivitymanagerd-5.27.2-x86_64-1.txz: Upgraded.
kde/kde-cli-tools-5.27.2-x86_64-1.txz: Upgraded.
kde/kde-gtk-config-5.27.2-x86_64-1.txz: Upgraded.
kde/kdecoration-5.27.2-x86_64-1.txz: Upgraded.
kde/kdeplasma-addons-5.27.2-x86_64-1.txz: Upgraded.
kde/kgamma5-5.27.2-x86_64-1.txz: Upgraded.
kde/khotkeys-5.27.2-x86_64-1.txz: Upgraded.
kde/kinfocenter-5.27.2-x86_64-1.txz: Upgraded.
kde/kmenuedit-5.27.2-x86_64-1.txz: Upgraded.
kde/kpipewire-5.27.2-x86_64-1.txz: Upgraded.
kde/kscreen-5.27.2-x86_64-1.txz: Upgraded.
kde/kscreenlocker-5.27.2-x86_64-1.txz: Upgraded.
kde/ksshaskpass-5.27.2-x86_64-1.txz: Upgraded.
kde/ksystemstats-5.27.2-x86_64-1.txz: Upgraded.
kde/kwallet-pam-5.27.2-x86_64-1.txz: Upgraded.
kde/kwayland-integration-5.27.2-x86_64-1.txz: Upgraded.
kde/kwin-5.27.2-x86_64-1.txz: Upgraded.
kde/kwrited-5.27.2-x86_64-1.txz: Upgraded.
kde/layer-shell-qt-5.27.2-x86_64-1.txz: Upgraded.
kde/libkscreen-5.27.2-x86_64-1.txz: Upgraded.
kde/libksysguard-5.27.2-x86_64-1.txz: Upgraded.
kde/milou-5.27.2-x86_64-1.txz: Upgraded.
kde/oxygen-5.27.2-x86_64-1.txz: Upgraded.
kde/oxygen-sounds-5.27.2-x86_64-1.txz: Upgraded.
kde/plasma-browser-integration-5.27.2-x86_64-1.txz: Upgraded.
kde/plasma-desktop-5.27.2-x86_64-1.txz: Upgraded.
kde/plasma-disks-5.27.2-x86_64-1.txz: Upgraded.
kde/plasma-firewall-5.27.2-x86_64-1.txz: Upgraded.
kde/plasma-integration-5.27.2-x86_64-1.txz: Upgraded.
kde/plasma-nm-5.27.2-x86_64-1.txz: Upgraded.
kde/plasma-pa-5.27.2-x86_64-1.txz: Upgraded.
kde/plasma-sdk-5.27.2-x86_64-1.txz: Upgraded.
kde/plasma-systemmonitor-5.27.2-x86_64-1.txz: Upgraded.
kde/plasma-vault-5.27.2-x86_64-1.txz: Upgraded.
kde/plasma-workspace-5.27.2-x86_64-1.txz: Upgraded.
kde/plasma-workspace-wallpapers-5.27.2-x86_64-1.txz: Upgraded.
kde/polkit-kde-agent-1-5.27.2-x86_64-1.txz: Upgraded.
kde/powerdevil-5.27.2-x86_64-1.txz: Upgraded.
kde/qqc2-breeze-style-5.27.2-x86_64-1.txz: Upgraded.
kde/sddm-kcm-5.27.2-x86_64-1.txz: Upgraded.
kde/systemsettings-5.27.2-x86_64-1.txz: Upgraded.
kde/xdg-desktop-portal-kde-5.27.2-x86_64-1.txz: Upgraded.
l/iso-codes-4.13.0-noarch-1.txz: Upgraded.
n/whois-5.5.16-x86_64-1.txz: Upgraded.
Add bash completion support, courtesy of Ville Skytta.
Updated the .tr TLD server.
Removed support for -metu NIC handles.
x/encodings-1.0.7-noarch-1.txz: Upgraded.
x/font-adobe-100dpi-1.0.4-noarch-1.txz: Upgraded.
x/font-adobe-75dpi-1.0.4-noarch-1.txz: Upgraded.
x/font-adobe-utopia-100dpi-1.0.5-noarch-1.txz: Upgraded.
x/font-adobe-utopia-75dpi-1.0.5-noarch-1.txz: Upgraded.
x/font-adobe-utopia-type1-1.0.5-noarch-1.txz: Upgraded.
x/font-alias-1.0.5-noarch-1.txz: Upgraded.
x/font-arabic-misc-1.0.4-noarch-1.txz: Upgraded.
x/font-bh-100dpi-1.0.4-noarch-1.txz: Upgraded.
x/font-bh-75dpi-1.0.4-noarch-1.txz: Upgraded.
x/font-bh-lucidatypewriter-100dpi-1.0.4-noarch-1.txz: Upgraded.
x/font-bh-lucidatypewriter-75dpi-1.0.4-noarch-1.txz: Upgraded.
x/font-bh-ttf-1.0.4-noarch-1.txz: Upgraded.
x/font-bh-type1-1.0.4-noarch-1.txz: Upgraded.
x/font-bitstream-100dpi-1.0.4-noarch-1.txz: Upgraded.
x/font-bitstream-75dpi-1.0.4-noarch-1.txz: Upgraded.
x/font-bitstream-type1-1.0.4-noarch-1.txz: Upgraded.
x/font-cronyx-cyrillic-1.0.4-noarch-1.txz: Upgraded.
x/font-cursor-misc-1.0.4-noarch-1.txz: Upgraded.
x/font-daewoo-misc-1.0.4-noarch-1.txz: Upgraded.
x/font-dec-misc-1.0.4-noarch-1.txz: Upgraded.
x/font-ibm-type1-1.0.4-noarch-1.txz: Upgraded.
x/font-isas-misc-1.0.4-noarch-1.txz: Upgraded.
x/font-jis-misc-1.0.4-noarch-1.txz: Upgraded.
x/font-micro-misc-1.0.4-noarch-1.txz: Upgraded.
x/font-misc-cyrillic-1.0.4-noarch-1.txz: Upgraded.
x/font-misc-ethiopic-1.0.5-noarch-1.txz: Upgraded.
x/font-misc-meltho-1.0.4-noarch-1.txz: Upgraded.
x/font-misc-misc-1.1.3-noarch-1.txz: Upgraded.
x/font-mutt-misc-1.0.4-noarch-1.txz: Upgraded.
x/font-schumacher-misc-1.1.3-noarch-1.txz: Upgraded.
x/font-screen-cyrillic-1.0.5-noarch-1.txz: Upgraded.
x/font-sony-misc-1.0.4-noarch-1.txz: Upgraded.
x/font-sun-misc-1.0.4-noarch-1.txz: Upgraded.
x/font-winitzki-cyrillic-1.0.4-noarch-1.txz: Upgraded.
x/font-xfree86-type1-1.0.5-noarch-1.txz: Upgraded.
xap/mozilla-firefox-110.0.1-x86_64-1.txz: Upgraded.
https://www.mozilla.org/en-US/firefox/110.0.1/releasenotes/
xap/vim-gvim-9.0.1362-x86_64-1.txz: Upgraded.
xfce/xfce4-notifyd-0.8.2-x86_64-1.txz: Upgraded.
Mon Feb 27 20:41:05 UTC 2023
ap/sudo-1.9.13p2-x86_64-1.txz: Upgraded.
d/make-4.4.1-x86_64-1.txz: Upgraded.
d/strace-6.2-x86_64-1.txz: Upgraded.
x/ibus-libpinyin-1.15.1-x86_64-2.txz: Rebuilt.
[PATCH] fix awk scripts to work properly when used against sqlite 3.41.0.
Thanks to lucabon.
Sun Feb 26 19:51:47 UTC 2023
ap/qpdf-11.3.0-x86_64-1.txz: Upgraded.
l/babl-0.1.102-x86_64-1.txz: Upgraded.
n/fetchmail-6.4.37-x86_64-1.txz: Upgraded.
Sat Feb 25 20:33:03 UTC 2023
a/kernel-generic-6.1.14-x86_64-1.txz: Upgraded.
a/kernel-huge-6.1.14-x86_64-1.txz: Upgraded.
a/kernel-modules-6.1.14-x86_64-1.txz: Upgraded.
d/kernel-headers-6.1.14-x86-1.txz: Upgraded.
k/kernel-source-6.1.14-noarch-1.txz: Upgraded.
l/v4l-utils-1.24.1-x86_64-1.txz: Upgraded.
Slackware 32-bit
a/btrfs-progs-6.2-i586-2.txz: Rebuilt.
a/reiserfsprogs-3.6.27-i586-5.txz: Rebuilt.
a/btrfs-progs-6.2-i586-1.txz: Upgraded.
l/libdiscid-0.6.3-i586-1.txz: Upgraded.
xap/xsnow-3.7.1-i586-1.txz: Upgraded.
a/mkinitrd-1.4.11-i586-31.txz: Rebuilt.
a RAID device.
ap/vim-9.0.1362-i586-1.txz: Upgraded.
kde/bluedevil-5.27.2-i586-1.txz: Upgraded.
kde/breeze-5.27.2-i586-1.txz: Upgraded.
kde/breeze-grub-5.27.2-i586-1.txz: Upgraded.
kde/breeze-gtk-5.27.2-i586-1.txz: Upgraded.
kde/drkonqi-5.27.2-i586-1.txz: Upgraded.
kde/kactivitymanagerd-5.27.2-i586-1.txz: Upgraded.
kde/kde-cli-tools-5.27.2-i586-1.txz: Upgraded.
kde/kde-gtk-config-5.27.2-i586-1.txz: Upgraded.
kde/kdecoration-5.27.2-i586-1.txz: Upgraded.
kde/kdeplasma-addons-5.27.2-i586-1.txz: Upgraded.
kde/kgamma5-5.27.2-i586-1.txz: Upgraded.
kde/khotkeys-5.27.2-i586-1.txz: Upgraded.
kde/kinfocenter-5.27.2-i586-1.txz: Upgraded.
kde/kmenuedit-5.27.2-i586-1.txz: Upgraded.
kde/kpipewire-5.27.2-i586-1.txz: Upgraded.
kde/kscreen-5.27.2-i586-1.txz: Upgraded.
kde/kscreenlocker-5.27.2-i586-1.txz: Upgraded.
kde/ksshaskpass-5.27.2-i586-1.txz: Upgraded.
kde/ksystemstats-5.27.2-i586-1.txz: Upgraded.
kde/kwallet-pam-5.27.2-i586-1.txz: Upgraded.
kde/kwayland-integration-5.27.2-i586-1.txz: Upgraded.
kde/kwin-5.27.2-i586-1.txz: Upgraded.
kde/kwrited-5.27.2-i586-1.txz: Upgraded.
kde/layer-shell-qt-5.27.2-i586-1.txz: Upgraded.
kde/libkscreen-5.27.2-i586-1.txz: Upgraded.
kde/libksysguard-5.27.2-i586-1.txz: Upgraded.
kde/milou-5.27.2-i586-1.txz: Upgraded.
kde/oxygen-5.27.2-i586-1.txz: Upgraded.
kde/oxygen-sounds-5.27.2-i586-1.txz: Upgraded.
kde/plasma-browser-integration-5.27.2-i586-1.txz: Upgraded.
kde/plasma-desktop-5.27.2-i586-1.txz: Upgraded.
kde/plasma-disks-5.27.2-i586-1.txz: Upgraded.
kde/plasma-firewall-5.27.2-i586-1.txz: Upgraded.
kde/plasma-integration-5.27.2-i586-1.txz: Upgraded.
kde/plasma-nm-5.27.2-i586-1.txz: Upgraded.
kde/plasma-pa-5.27.2-i586-1.txz: Upgraded.
kde/plasma-sdk-5.27.2-i586-1.txz: Upgraded.
kde/plasma-systemmonitor-5.27.2-i586-1.txz: Upgraded.
kde/plasma-vault-5.27.2-i586-1.txz: Upgraded.
kde/plasma-workspace-5.27.2-i586-1.txz: Upgraded.
kde/plasma-workspace-wallpapers-5.27.2-i586-1.txz: Upgraded.
kde/polkit-kde-agent-1-5.27.2-i586-1.txz: Upgraded.
kde/powerdevil-5.27.2-i586-1.txz: Upgraded.
kde/qqc2-breeze-style-5.27.2-i586-1.txz: Upgraded.
kde/sddm-kcm-5.27.2-i586-1.txz: Upgraded.
kde/systemsettings-5.27.2-i586-1.txz: Upgraded.
kde/xdg-desktop-portal-kde-5.27.2-i586-1.txz: Upgraded.
n/whois-5.5.16-i586-1.txz: Upgraded.
xap/mozilla-firefox-110.0.1-i686-1.txz: Upgraded.
xap/vim-gvim-9.0.1362-i586-1.txz: Upgraded.
xfce/xfce4-notifyd-0.8.2-i586-1.txz: Upgraded.
ap/sudo-1.9.13p2-i586-1.txz: Upgraded.
d/make-4.4.1-i586-1.txz: Upgraded.
d/strace-6.2-i586-1.txz: Upgraded.
x/ibus-libpinyin-1.15.1-i586-2.txz: Rebuilt.
Thanks to lucabon.
ap/qpdf-11.3.0-i586-1.txz: Upgraded.
l/babl-0.1.102-i586-1.txz: Upgraded.
n/fetchmail-6.4.37-i586-1.txz: Upgraded.
a/kernel-generic-6.1.14-i586-1.txz: Upgraded.
a/kernel-generic-smp-6.1.14_smp-i686-1.txz: Upgraded.
a/kernel-huge-6.1.14-i586-1.txz: Upgraded.
a/kernel-huge-smp-6.1.14_smp-i686-1.txz: Upgraded.
a/kernel-modules-6.1.14-i586-1.txz: Upgraded.
a/kernel-modules-smp-6.1.14_smp-i686-1.txz: Upgraded.
d/kernel-headers-6.1.14_smp-x86-1.txz: Upgraded.
k/kernel-source-6.1.14_smp-noarch-1.txz: Upgraded.
l/v4l-utils-1.24.1-i586-1.txz: Upgraded.
extra/linux-6.1.14-nosmp-sdk/*: Upgraded.
