VLC media player
Post Napisano: 24 Sep 2013, 09:35
Odakle si ga instalirao? :) Koliko vidim poslednji AlienBobov VLC za 14.0 je 2.0.8. Tvoja verzija je 2.1.0-rc1.
Post Napisano: 24 Sep 2013, 10:01
Pa ovo se našlo na http://www.slackware.com/~alien/slackbuilds" onclick="window.open(this.href);return false; :) pa sam unapredio paket :) upravo sam ga deinstalirao i postavio 2.0.8 pa da vidim
A imam i šta :(
bash-4.2$ vlc
VLC media player 2.0.8 Twoflower (revision 2.0.7-29-g12aebf9)
[0x8ccc460] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
QGtkStyle was unable to detect the current GTK+ theme.
ALSA lib pcm_dmix.c:1018:(snd_pcm_dmix_open) unable to open slave
[0xb36c91b0] alsa audio output error: cannot open ALSA device "default": Device or resource busy
[0xb36c91b0] oss audio output error: cannot open audio device (/dev/dsp)
[0xb36c91b0] main audio output error: no suitable audio output module
[0x8d77300] main decoder error: failed to create audio output
I koji god uređaj da stavim, uvek je busy.... a mogu da stavim i default i alsa i oss... sve mi je jedno... :(
Post Napisano: 24 Sep 2013, 10:25
Khm... :| Kao da drajver nije učitan. Rade li druge audio aplikacije? Šta ja znam... Audacious, napr.
Šta kaže:
/sbin/lspci | grep Audio
Post Napisano: 24 Sep 2013, 10:37
A da, napisao si da radi. :) Izvinjavam se. Nisam još popio kaficu pa mi mozak usporeno procesira informacije. ;)
Onda je zaista čudno. Da li je isto i posle restarta?
Post Napisano: 24 Sep 2013, 10:57
pih... windows fore.. cccc sad radi... nakon restarta...
Post Napisano: 29 Sep 2013, 13:33
VLC 2.1.0
AlienBOB-ov VLC sada stiže i preko slackpkg plus alata ali ne koriste svi slackpkg+.
13.37
32-bit
http://taper.alienbase.nl/mirrors/peopl ... pkg/13.37/" onclick="window.open(this.href);return false;
64-bit
http://taper.alienbase.nl/mirrors/peopl ... g64/13.37/" onclick="window.open(this.href);return false;
14.0
32-bit
http://taper.alienbase.nl/mirrors/peopl ... /pkg/14.0/" onclick="window.open(this.href);return false;
64-bit
http://taper.alienbase.nl/mirrors/peopl ... kg64/14.0/" onclick="window.open(this.href);return false;
14.1 Beta
32-bit
http://taper.alienbase.nl/mirrors/peopl ... g/current/" onclick="window.open(this.href);return false;
64-bit
http://taper.alienbase.nl/mirrors/peopl ... 4/current/" onclick="window.open(this.href);return false;
Prikaz verzije:
Post Napisano: 29 Sep 2013, 13:40
Ohoho stiglo :)
Kažu da je najveća nadogradnja u audio/video segmentu. Vlc sada podržava ultraHD i 4k formate. Znam da su i nešto oko zvuka poboljšavali ali ne mogu sad da se setim šta :)
Post Napisano: 21 Oct 2013, 13:00
Totalni sam amater u polju A/V softvera, zato vas molim za pomoc. Kada pustam filmove u VLC plejeru kvalitet videa je loš. Sve izgleda kao da gledam kroz neku mrežu. verovatno treba nesta podesiti, ali sta.
Hvala, pozdrav
Post Napisano: 21 Oct 2013, 13:07
Verovatno treba da podesiš video output ali to zavisi od grafičke kartice. Javi koju grafičku karticu imaš pa da podesimo. Ili probaj sam nađi u Tools—>Preferences—>Video—>Output. Meni stoji automatic. Inače koristim SMplayer a VLC imam instalirano samo zbog nekih proba...
Post Napisano: 21 Oct 2013, 13:08
I dobrodošao na forum :)
Users browsing this forum: Claude User [Bot], Google [Bot] and 0 guests
