MIRRORPLUS['restricted']=http://taper.alienbase.nl/mirrors/slackware/slackware-current/x86/Code: Select all
MIRRORPLUS['restricted']=http://taper.alienbase.nl/mirrors/slackware/slackware-current/Moderator: Urednik
MIRRORPLUS['restricted']=http://taper.alienbase.nl/mirrors/slackware/slackware-current/Code: Select all
MIRRORPLUS['alienbob']=http://taper.alienbase.nl/mirrors/people/alien/sbrepos/current/x86/Code: Select all
bash-4.3# slackpkg info mc
PACKAGE NAME: mc-4.8.14-i586-1.txz
PACKAGE LOCATION: ./slackware/ap
PACKAGE SIZE (compressed): 1672 K
PACKAGE SIZE (uncompressed): 6860 K
PACKAGE DESCRIPTION:
mc: mc (Midnight Commander file manager)Code: Select all
bash-4.3# slackpkg info gcc
PACKAGE NAME: gcc-4.9.2-i586-3.txz
PACKAGE LOCATION: ./slackware/d
PACKAGE SIZE (compressed): 15924 K
PACKAGE SIZE (uncompressed): 59000 K
gcc: gcc (Base GCC package with C support)
gcc:
gcc: GCC is the GNU Compiler Collection.Code: Select all
bash-4.3# slackpkg info dbus
PACKAGE NAME: dbus-1.8.20-i586-1.txz
PACKAGE SIZE (compressed): 496 K
PACKAGE SIZE (uncompressed): 2020 K
dbus: dbus (D-Bus message bus system)Code: Select all
bash-4.3# slackpkg info gcc-gfortran
PACKAGE NAME: gcc-gfortran-4.9.2-i586-3.txz
PACKAGE SIZE (compressed): 5876 K
PACKAGE SIZE (uncompressed): 19700 K
gcc-gfortran: gcc-gfortran (Fortran support for GCC)
bash-4.3# slackpkg info gnome-keyring
PACKAGE NAME: gnome-keyring-3.16.0-i586-1.txz
PACKAGE LOCATION: ./slackware/l
PACKAGE SIZE (compressed): 640 K
PACKAGE SIZE (uncompressed): 4000 K
bash-4.3# slackpkg info xfce4-weather-plugin
PACKAGE NAME: xfce4-weather-plugin-0.8.6-i586-1.txz
PACKAGE LOCATION: ./slackware/xfce
PACKAGE SIZE (compressed): 2288 K
PACKAGE SIZE (uncompressed): 4470 K
bash-4.3# slackpkg info xfdesktop
PACKAGE NAME: xfdesktop-4.12.3-i586-1.txz
PACKAGE SIZE (compressed): 756 K
PACKAGE SIZE (uncompressed): 2340 K
xfdesktop: xfdesktop (Xfce desktop manager)Može biti da je SUN. Ali nikad ga nisam koristio pa ne znam da li i skida pakete ili samo obaveštava. Takođe je moguće da imaš i neku drugu update skriptu u pozadini ili unos u cron konfiguracionim datotekama iz post-instalacionog članka sa docs.slackware.com. Ostale opcije mi deluju nemoguće.Broker wrote:Ima tri objašnjena, ili sam teško oboleo, pa ovo radim u snu, ili možda jedna aplikacija sama ovo nadograđuje u pozadini koju imam instaliranu (SUN Slackware Update Notifier), ili sam nešto debelo zabrljao.
SLACKPKGPLUS=on
VERBOSE=1
ALLOW32BIT=off
USEBL=1
GREYLIST=on
WGETOPTS="--timeout=20 --tries=2"
SEARCH_CLOG_INPARENT=on
CACHEUPDATE=on
ENABLENOTIFY=on
SENSITIVE_SEARCH=off
WW_FILE_SEARCH=on
SHOWORDER=package
DETAILED_INFO=basic
STRICTGPG=on
PKGS_PRIORITY=( multilib )
TAG_PRIORITY=off
REPOPLUS=( slackpkgplus multilib )
MIRRORPLUS['multilib']=http://bear.alienbase.nl/mirrors/people/alien/multilib/current/
MIRRORPLUS['slackpkgplus']=http://slakfinder.org/slackpkg+/Code: Select all
REPOPLUS=( ktown )Code: Select all
slackpkg update gpgUsers browsing this forum: No registered users and 6 guests
