Doterivanje, editovanje, razmena... conkyrc-a
Post Napisano: 15 Jan 2012, 10:53
Koristim dva conky-a, ali činimi se da još nisam našao onaj pravi.
Sada trenutno koristim ovaj
Ako nekoga zanima evo sadržaja .conkyrc-a
# Force UTF8? note that UTF8 support required XFT
override_utf8_locale yes
# Use Xft?
use_xft yes
xftfont Droid Sans:size=10
xftalpha 0.8
text_buffer_size 2048
# Update interval in seconds
update_interval 1
# This is the number of times Conky will update before quitting.
# Set to zero to run forever.
total_run_times 0
# Create own window instead of using desktop (required in nautilus)
own_window yes
own_window_transparent yes
own_window_type override
#own_window_hints undecorated,below,sticky,skip_taskbar,skip_pager
# Use double buffering (reduces flicker, may not work for everyone)
double_buffer yes
# Minimum size of text area
minimum_size 280 5
maximum_width 250 5
# Draw shades?
draw_shades no
default_color D6D6D6 #4D4D4D
# Draw outlines?
draw_outline no
# Draw borders around text
draw_borders no
# Stippled borders?
stippled_borders 0
# border margins
border_margin 5
# border width
border_width 1
# Text alignment, other possible values are commented
#alignment top_left
alignment top_right
#alignment bottom_left
#alignment bottom_right
# Gap between borders of screen and text
# same thing as passing -x at command line
gap_x 20
gap_y 45
# -- Lua Load -- #
lua_load ~/.draw_bg.lua
lua_draw_hook_pre draw_bg
TEXT
SYSTEM Slackware 13.37 ${hr 2}
${goto 6}${voffset 6}${image /usr/share/icons/logoalt_white.png -p 0,20 -s 26x26}${goto 40}${pre_exec cat /etc/issue.net} $machine
${goto 40}Kernel: ${kernel}
${hr 2}
${goto 6}${font StyleBats:size=16}A${font}${voffset -4}${goto 32}CPU1: ${cpu cpu0}% ${alignr}${cpubar cpu0 8,60}
${goto 6}${voffset 4}${font StyleBats:size=16}A${font}${voffset -4}${goto 32}CPU2: ${cpu cpu1}% ${alignr}${cpubar cpu1 8,60}
#${goto 6}${voffset 4}${font StyleBats:size=16}A${font}${voffset -4}${goto 32}CPU3: ${cpu cpu2}% ${alignr}${cpubar cpu2 8,60}
#${goto 6}${voffset 4}${font StyleBats:size=16}A${font}${voffset -4}${goto 32}CPU4: ${cpu cpu3}% ${alignr}${cpubar cpu3 8,60}
${goto 6}${voffset 4}${font StyleBats:size=16}g${font}${voffset -4}${goto 32}RAM: ${mem} ${alignr}${membar 8,60}
${goto 6}${voffset 4}${font StyleBats:size=16}x${font}${voffset -4}${goto 32}DISK: ${diskio}${alignr}${diskiograph 8,60 F57900 FCAF3E}
${goto 6}${voffset 4}${font StyleBats:size=16}j${font}${voffset -4}${goto 32}SWAP: $swapperc% ${alignr}${swapbar 8,60}
#${goto 6}${voffset 4}${font Devil inside:size=16}1${font}${voffset -4}${goto 32}CPU Temp: ${alignr}${exec sensors | grep 'CPU Temperature' | cut -c19-20}°C / ${color #FCAF3E}${exec sensors | grep 'CPU Temperature' | cut -c37-38}°C$color
#${goto 5}${voffset 4}${font Devil inside:size=16}x${font}${voffset -4}${goto 32}Mother Temp: ${alignr}${exec sensors | grep 'MB Temperature' | cut -c19-20}°C / ${color #FCAF3E}${exec sensors | grep 'MB Temperature' | cut -c37-38}°C$color
#${goto 4.5}${voffset 2}${font Poky:size=15}y${font}${voffset -6}${goto 32}HD Temp:${alignr}${exec hddtemp /dev/sda -n --unit=C}°C / ${color #FCAF3E}${exec sensors | grep 'CPU Temperature' | cut -c54-55}°C$color
#${goto 6}${font Martin Vogel's Symbols:size=16}j${font}${voffset -4}${goto 32}Fan Speed: ${alignr}${exec sensors | grep 'RPM'| cut -c16-25}
${goto 6}${voffset 4}${font StyleBats:size=16}q${font}${voffset -4}${goto 32}Uptime: ${alignr}${uptime}
${goto 6}${voffset 4}${font StyleBats:size=16}k${font}${voffset -4}${goto 32}Processes: ${alignr}$processes ($running_processes running)
${goto 7.5}${voffset 4}${font Poky:size=15}a${font}${goto 32}${voffset -10}Highest: ${alignr 13}CPU${alignr}RAM
${goto 32}${voffset -5.5}${hr 1}
${voffset -1}${goto 32}${top name 1} ${goto 124}${top cpu 1}${alignr }${top mem 1}
${voffset -1}${goto 32}${top name 2} ${goto 124}${top cpu 2}${alignr }${top mem 2}
${voffset -1}${goto 32}${top name 3} ${goto 124}${top cpu 3}${alignr }${top mem 3}
${voffset -1}${goto 32}${top name 4} ${goto 124}${top cpu 4}${alignr }${top mem 4}
${voffset -1}DATE ${hr 2}
${alignc 35}${font Arial Black:size=26}${time %H:%M}${font}
${alignc}${time %A %d %B}
${voffset -1}HD ${hr 2}
${goto 3}${voffset 4}${font Poky:size=16}H${font}${goto 29}${voffset -11} Root: ${fs_used_perc /}%${alignr}${fs_size /}
${goto 29} Free: ${fs_free /}${alignr}${fs_bar 8,60 /}
#${goto 3}${voffset 8}${font Poky:size=16}H${font}${goto 29}${voffset -11} Home: ${fs_used_perc /home}%${alignr}${fs_size /home}
#${goto 29} Free: ${fs_free /home}${alignr}${fs_bar 8,60 /home}
${voffset -1}NETWORK ${hr 2}
${if_up wlan0}
${font Poky:size=14}Y${font}${goto 32}${voffset -8}SSID: ${wireless_essid wlan0}
${goto 32}Signal: ${wireless_link_qual wlan0}% ${alignr}${wireless_link_bar 8,60 wlan0}
${voffset 4}${font VariShapes Solid:size=14}q${font}${goto 32}${voffset -6}Up: ${upspeed wlan0}${font} ${alignr}${upspeedgraph wlan0 8,60 F57900 FCAF3E}
${goto 32}Total: ${totalup wlan0}
${voffset 4}${font VariShapes Solid:size=14}Q${font}${goto 32}${voffset -6}Down: ${downspeed wlan0}${font} ${alignr}${downspeedgraph wlan0 8,60 F57900 FCAF3E}
${goto 32}Total: ${totaldown wlan0}
${voffset 4}${font Poky:size=13}w${font}${goto 32}${voffset -8}Local IP: ${alignr}${addr wlan0}
${goto 32}Public IP: ${alignr}${execi 3600 wget -O - http://www.whatismyip.com/automation/n09230945.asp | tail}
# |--ETH0
${else}${if_up eth0}
${voffset -13}${font VariShapes Solid:size=14}q${font}${goto 32}${voffset -6}Up: ${upspeed eth0}${font} ${alignr}${upspeedgraph eth0 8,60 F57900 FCAF3E}
${goto 32}Total: ${totalup eth0}
${voffset -2}${font VariShapes Solid:size=14}Q${font}${goto 32}${voffset -6}Down: ${downspeed eth0}${font} ${alignr}${downspeedgraph eth0 8,60 F57900 FCAF3E}
${goto 32}Total: ${totaldown eth0}
${voffset -2}${font Poky:size=13}w${font}${goto 32}${voffset -4}Local IP: ${alignr}${addr eth0}
# |--PPP0
${endif}${else}${if_up ppp0}
${voffset -13}${font VariShapes Solid:size=14}q${font}${goto 32}${voffset -6}Up: ${upspeed ppp0}${font} ${alignr}${upspeedgraph ppp0 8,60 F57900 FCAF3E}
${goto 32}Total: ${totalup ppp0}
${voffset -2}${font VariShapes Solid:size=14}Q${font}${goto 32}${voffset -6}Down: ${downspeed ppp0}${font} ${alignr}${downspeedgraph ppp0 8,60 F57900 FCAF3E}
${goto 32}Total: ${totaldown ppp0}
${voffset -2}${font Poky:size=13}w${font}${goto 32}${voffset -4}Local IP: ${alignr}${addr ppp0}
${endif}${else}${voffset 4}${font PizzaDude Bullets:size=12}4${font}${goto 32}Network Unavailable${endif}${endif}
#${voffset -1}WEATHER ${hr 2}
#${voffset -10}${alignr 56}${font ConkyWeather:style=Bold:size=40}${execi 600 conkyForecast --location=UKXX0113 --datatype=WF --imperial}${font}
#${voffset -50}${font Weather:size=40}y${font}  ${voffset -38}${font Arial Black:size=26}${execi 600 conkyForecast --location=UKXX0113 --datatype=HT --imperial}${font}
#${alignc 43}${execpi 600 conkyForecast --location=UKXX0113 --datatype=DW --imperial --startday=1 --shortweekday} ${alignc 8}${execpi 600 conkyForecast --location=UKXX0113 --datatype=DW --imperial --startday=2 --shortweekday} ${alignc -29}${execpi 600 conkyForecast --location=UKXX0113 --datatype=DW --imperial --startday=3 --shortweekday} ${alignc -64}${execpi 600 conkyForecast --location=UKXX0113 --datatype=DW --imperial --startday=4 --shortweekday}
#${alignc 75}${font ConkyWeather:size=28}${execpi 600 conkyForecast --location=UKXX0113 --datatype=WF --imperial --startday=1 --endday=4 --spaces=1}${font}
#${font DejaVu Sans:size=7}${alignc 48}${execpi 600 conkyForecast --location=UKXX0113 --datatype=HT --imperial --startday=1 --hideunits --centeredwidth=3}/${execpi 600 conkyForecast --location=UKXX0113 --datatype=LT --imperial --startday=1 --hideunits --centeredwidth=3} ${alignc -14}${execpi 600 conkyForecast --location=UKXX0113 --datatype=HT --imperial --startday=2 --hideunits --centeredwidth=3}/${execpi 600 conkyForecast --location=UKXX0113 --datatype=LT --imperial --startday=2 --hideunits --centeredwidth=3} ${alignc -40}${execpi 600 conkyForecast --location=UKXX0113 --datatype=HT --imperial --startday=3 --hideunits --centeredwidth=3}/${execpi 600 conkyForecast --location=UKXX0113 --datatype=LT --imperial --startday=3 --hideunits --centeredwidth=3} ${alignr 6}${execpi 600 conkyForecast --location=UKXX0113 --datatype=HT --imperial --startday=4 --hideunits --centeredwidth=3}/${execpi 600 conkyForecast --location=UKXX0113 --datatype=LT --imperial --startday=4 --hideunits --centeredwidth=3}${font}
#${voffset 4}Location:${alignr}${execi 600 conkyForecast --location=UKXX0113 --datatype=CN}
#Last Updated: ${alignr} ${execi 600 conkyForecast --location=UKXX0113 --hideunits --datatype=LU -m 0 }
#Feels Like:${alignr}${execi 600 conkyForecast --location=UKXX0113 --datatype=LT --imperial}
#Dew Point: ${alignr}${execi 600 conkyForecast --location=UKXX0113 --datatype=DP --imperial}
#Current Condition:${alignr}${execi 600 conkyForecast --location=UKXX0113 --datatype=CC}
#Chance of Precip: ${alignr}${execi 600 conkyForecast  --location=UKXX0113 --startday=0 --datatype=PC}
#Humidity: ${alignr}${execi 600 conkyForecast --location=UKXX0113 --datatype=HM}
#Wind: ${alignr}${execi 600 conkyForecast --location=UKXX0113 --datatype=WS --imperial} - ${execi 600 conkyForecast --location=UKXX0113 --datatype=WD}
#Pressure: ${alignr}${execi 600 conkyForecast --location=UKXX0113 --hideunits --datatype=BR}
#Visibility: ${alignr}${execi 600 conkyForecast --location=UKXX0113 --datatype=VI --imperial}
#Sunrise: ${alignr}${execi 600 conkyForecast --location=UKXX0113 --datatype=SR}
#Sunset: ${alignr}${execi 600 conkyForecast --location=UKXX0113 --datatype=SS}
#Moon Phase:${alignr 8}${execi 600 conkyForecast --location=UKXX0113 --datatype=MP} ${font MoonPhases:size=8}${execi 600 conkyForecast --location=UKXX0113 --datatype=MF}${font}
${hr 2}
Ovaj Conky dolazi po defaultu sa PingOS-om, naravno prilagodio sam ga svom okruženju i potrebama.
Još jedan meni drag i često korišćen
Sadržaj .conkyrc
#Author: Thio
# Conky sample configuration
# the list of variables has been removed from this file in favour
# of keeping the documentation more maintainable.
# Check http://conky.sf.net for an up-to-date-list.
# set to yes if you want Conky to be forked in the background
background yes
# X font when Xft is disabled, you can pick one with program xfontsel
#font 5x7
#font 6x10
#font 7x13
#font 8x13
#font 9x15
#font *mintsmild.se*
#font -*-*-*-*-*-*-34-*-*-*-*-*-*-*
# Use Xft?
use_xft yes
# Xft font when Xft is enabled
xftfont xirod:size=8
# Text alpha when using Xft
xftalpha 0.8
# Print everything to stdout?
# out_to_console no
# MPD host/port
# mpd_host localhost
# mpd_port 6600
# mpd_password tinker_bell
# Print everything to console?
# out_to_console no
# mail spool
mail_spool $MAIL
update_interval 1.0
total_run_times 0
own_window 1
# If own_window is yes, you may use type normal, desktop or override
# Use pseudo transparency with own_window?
own_window_transparent 1
# If own_window_transparent is set to no, you can set the background colour here
own_window_colour hotpink
# If own_window is yes, these window manager hints may be used
double_buffer yes
minimum_size 280 5
# Draw shades?
draw_shades no
# Draw outlines?
draw_outline no
draw_borders no
# Draw borders around graphs
draw_graph_borders yes
# Stippled borders?
stippled_borders 8
# border margins
border_margin 4
# border width
border_width 1
# Default colors and also border colors
default_color white
#default_shade_color white
#default_outline_color
dexter_client no
dexter_server no
# config file for libdexter (default search path: $HOME/.dexterrc; /etc/libdexter/dexter.conf)
dexter_config
#alignment top_left
alignment top_right
#alignment none
gap_x 20
gap_y 45
# Subtract file system buffers from used memory?
no_buffers yes
# set to yes if you want all text to be in uppercase
uppercase no
# number of cpu samples to average
# set to 1 to disable averaging
cpu_avg_samples 2
# number of net samples to average
net_avg_samples 2
override_utf8_locale no
# Add spaces to keep things from moving about?  This only affects certain objects.
use_spacer no
# Allow each port monitor to track at most this many connections (if 0 or not set, default is 256)
#max_port_monitor_connections 256
# Maximum number of special things, e.g. fonts, offsets, aligns, etc.
#max_specials 512
# Maximum size of buffer for user text, i.e. below TEXT line.
#max_user_text 16384
# variable is given either in format $variable or in ${variable}. Latter
# allows characters right after the variable and must be used in network
# stuff because of an argument
# stuff after 'TEXT' will be formatted on screen
TEXT
Linux ${color white}Slackware 13.37
Hostname:$alignr$nodename
$sysname $kernel $alignr $machine
Uptime:$alignr$uptime
${time %A}$alignr${time %F}
Intel Core2 Duo Processor E7500 $alignr${freq_g cpu1} Ghz
${color green}CPU#1    ${color whte}${cpu cpu1} %${alignr}${cpu cpu2} %${color green}    CPU#2
${color white}${cpugraph cpu1 25,140 FF8200 ff0000} ${alignr}${cpugraph cpu2
25,140 FF0000 FF9900}$color
MEM $alignc $mem / $memmax $alignr $memperc%
${membar FF8200 ff0000}
${color green}Devices$color
Slackware 13.37/Root $alignc ${fs_used /} / ${fs_size /} $alignr ${fs_free_perc /}%
${fs_bar /}
Ubuntu/Root 10.04.3 $alignc ${fs_used /media/root_ubuntu} / ${fs_size /media/root_ubuntu} $alignr ${fs_free_perc /media/root_ubuntu}%
${fs_bar /media/root_ubuntu}
Ubuntu/Home 10.04.3 $alignc ${fs_used /media/home_ubuntu} / ${fs_size /media/home_ubuntu} $alignr ${fs_free_perc /media/home_ubuntu}%
${fs_bar /media/home_ubuntu}
Windows 7 $alignc ${fs_used /media/windows} / ${fs_size /media/windows} $alignr ${fs_free_perc /media/windows}%
${fs_bar /media/windows}
Hard Drive1 $alignc ${fs_used /media/hard1} / ${fs_size /media/hard1} $alignr ${fs_free_perc /media/hard1}%
${fs_bar /media/hard1}
Hard Drive2 $alignc ${fs_used /media/hard2} / ${fs_size /media/hard2} $alignr ${fs_free_perc /media/hard2}%
${fs_bar /media/hard2}
${color green}Top Processes$color
 CPU  $alignr %
      ${top name 1}$alignr${top cpu 1}
      ${top name 2}$alignr${top cpu 2}
      ${top name 3}$alignr${top cpu 2}
 MEM  $alignr %
      ${top_mem name 1}$alignr${top_mem mem 1}
      ${top_mem name 2}$alignr${top_mem mem 2}
      ${top_mem name 3}$alignr${top_mem mem 3}
${color green}Network$color
	IP on eth0 $alignr ${addr eth0}
${color white}Down: ${color green}${downspeed eth0} k/s ${alignr}${color white}Up:${color green} ${upspeed eth0} k/s
${color white}${downspeedgraph eth0 25,140 FF8200 ff0000} ${alignr}${upspeedgraph eth0
Post Napisano: 04 Feb 2012, 11:25
Još jedan kojeg sada koristim
Conky
alignment top_right
double_buffer yes
gap_x 20
gap_y 45
update_interval 1.0
background yes
own_window yes
# own_window_argb_visual yes
own_window_type normal
own_window_class conky-semi
minimum_size 280 5
maximum_width 250 5
use_xft yes
xftalpha 0.5
xftfont Sans:size=8
TEXT
${font openlogos:size=20}${font Arial:size=15}${color #0088cc}Slackware ${color Ivory}${font openlogos:size=15}13.37${font }
${font size=7}${color slate grey}Info $hr${color }${font }
Kernel: ${alignr}$kernel ($machine)
Uptime: ${alignr}$uptime
Time: ${alignr}${time %H:%M:%S}
Date: ${alignr}${time %d.%m.%y}
User: ${alignr}$alignc${exec whoami} @ $nodename
Filesystem: $alignr${fs_type}
${font size=7}${color slate grey}CPU Usage $hr${color }${font }
CPU1 ${alignr}${cpu cpu1}%
${cpugraph cpu1 16, 200}
CPU2 ${alignr}${cpu cpu2}%
${cpugraph cpu2 16, 200}
CPU-Temp.${alignr}${hwmon temp 1}°C
${font size=7}${color slate grey}Ram Usage $hr${color }${font }
RAM ${alignr}$mem/$memmax
${membar 6, 200}
${font size=7}${color slate grey}Filesystem $hr${color }${font }
Slackware home ${alignr}${fs_free /}
${fs_bar 6, 200 /}
Ubuntu 10.04.3${alignr}${fs_free /media/home_ubuntu}
${fs_bar 6, 200 /media/home_ubuntu}
${font size=7}${color slate grey}Top CPU Tasks $hr${color }${font }
${color #ddaa00}${top name 1}${alignr}${top cpu 1}%${color }
${top name 2}${alignr}${top cpu 2}%
${top name 3}${alignr}${top cpu 3}%
${top name 4}${alignr}${top cpu 4}%
${top name 5}${alignr}${top cpu 5}%
${font size=7}${color slate grey}Top RAM Tasks  $hr${color }${font }
${color #ddaa00}${top_mem name 1}${alignr}${top_mem mem 1}%${color }
${top_mem name 2}${alignr}${top_mem mem 2}%
${top_mem name 3}${alignr}${top_mem mem 3}%
${top_mem name 4}${alignr}${top_mem mem 4}%
${top_mem name 5}${alignr}${top_mem mem 5}%
${font size=7}${color slate grey}Network $hr${color }${font }
IP (Lan): $alignr${addr eth0}
IP (Public): $alignr${execi 600 wget http://checkip.dyndns.org/ -q -O - | grep -Eo '\<[[:digit:]]{1,3}(\.[[:digit:]]{1,3}){3}\>'}
Total Down $alignr${totaldown eth0}
Total Up   $alignr${totalup eth0}
Download ${alignr}${downspeed eth0}
${downspeedgraph eth0}
Upload ${alignr}${upspeed eth0}
${upspeedgraph eth0}
Post Napisano: 08 Apr 2012, 11:35
Evo jedan coky koji trenutno koristim.
conky_sci.tar.7z
Conky Fajlovi
(94.26 KiB) Downloaded 886 times
U arhivi se nalaze cetiri fajla.
Pre svega treba instalirati conky, ako vec niste. ;)
Ja sam svoj pronasao ovde.
Instalirajte font - kreirajte folder .fonts u vasem home direktorijumu prekopirate font iz arhive u folder i u terminalu kucajte fc-cache -f -v.
Idemo dalje ;) u home direktorijumu napravite folder .conky i folder .scripts.
U folder .conky stavite sliku slackware_logo.png i preimenujte je u logo.png.
U folderu .scripts kreirajte folder scientific_lua i u njega prekopirate fajl clock_rings.lua.
Na kraju, fajl conkyrc preimenujte u .conkyrc i premestite u vas home folder.
U terminalu kucajte conky.
Uzivajte.
p.s. Tacka ispred imena foldera i imena fajla je obavezna jer su to fajlovi koji su skriveni da biste ih videli na tastaturi pritisnite kombinaciju tastera ctrl+h.
Post Napisano: 09 Apr 2012, 17:11
Jos jedan conky
clock.7z
(3.23 KiB) Downloaded 894 times
U arhivi su dva fajla.
Fajl circle_script.lua stavite u folder .scripts (kreirajte ga u home direktorijumu ako vec niste).
Fajl conkyrc preimenujte u .conkyrc i premestite u home direktorijum.
Startujte conky u konzoli.
Post Napisano: 09 Apr 2012, 18:29
krugovi.7z
(2.47 KiB) Downloaded 874 times
Arhiva sadrzi 2 fajla.
U folderu .scripts kreirajte folder lua i u njega stavite fajl iza arhive lua.lua.
Fajl conkyrc preimenujte u .conkyrc.
Startujte conky u terminalu.
Post Napisano: 09 Apr 2012, 18:36
Siniša, možeš li kada ti vreme dozvoli i za ovaj da uradiš
http://www.dodaj.rs/?I/Cm/1PerRIRt/snapshot10.png" onclick="window.open(this.href);return false;
Post Napisano: 09 Apr 2012, 19:04
Bice bice Brok. ;)
Post Napisano: 09 Apr 2012, 19:54
steel.7z
(445 KiB) Downloaded 899 times
Kada raspakujete arhivu imate u njoj readme fajl sa uputstvima na srpskom jeziku.
Enjoy. :beer:
Post Napisano: 09 Apr 2012, 20:27
Jos jedan ;)
rings.7z
(21.3 KiB) Downloaded 832 times
Arhiva sadrzi 3 fajla.
Sliku simple_picture_name.png stavite u folder .conky koji se nalazi u Vasem $HOME direktorijumu (ako folder ne postoji kreirajte ga).
Fajl my_clock_rings.lua stavite u folder .scipts koji se takodje nalazi u Vasem $HOME direktorijumu (ako folder ne postoji kreirajte ga).
Fajl conkyrc preimenujte u .conkyrc i postavite ga u Vas $HOME folder.
U konzoli kucajte conky.
Ziveli :beer:
Post Napisano: 09 Apr 2012, 21:02
Jos ovaj i dosta je... za danas :grin:
Conky Slackware-lua.7z
(33.51 KiB) Downloaded 867 times
Arhiva sadrzi tri fajla.
Sliku postaviti u folder .conky u Vasem $HOME folderu.
Lua fajl (clock_rings.lua) stavite u folder .scripts koji je takodje u Vasem $HOME folderu.
Fajl conkyrc preimenujte u .conkyrc i premestite u $HOME folder.
Startujte conky.
