nginx+php-fastcgi slackware 13.37
Post Napisano: 14 Jan 2013, 13:10
Pocnimo!!!
Odavde http://slackbuilds.org/repository/13.37/network/nginx/ skinuti :
Source Downloads:
nginx-1.2.2.tar.gz (53105bbe3ac9319db54d9eb46119695b)
Download SlackBuild:
nginx.tar.gz
Zatim otpakovati paket nginx.tar.gz
tar zxf nginx.tar.gz
Zatim kopirati nginx-1.2.2.tar.gz u nginx folder koji smo malopre raspakovali:
cp nginx-1.2.2 nginx/
zatim uci u folder nginx
cd nginx
Pa slackbuild-u nginx-a promeniti dozvole u izvrsne:
chmod +x nginx.SlackBuild
Pokrenuti slackbuild (imate dva nacina - jedan je):
./nginx.SlackBuild
a drugi:
http://slackbuilds.org/slackbuilds/14.0 ... inx/README pogledajte tu...
zatim instalirati paket:
installpkg /tmp/nginx-1.2.2-i486-1_SBo.tgz
DONE!
Nakon toga promenite dozvole rc.nginx-a u izvrsne:
chmod +x /etc/rc.d/rc.nginx
Nakon toga pokrenite nginx servis:
/etc/rc.d/rc.nginx start
DONE!!!!
Na adresi http://localhost se nalazi vas, za sad html sadrzaj!!!!
nano /etc/nginx/nginx.conf
Sadrzaj:
#user  nobody;
worker_processes  1;
#error_log  logs/error.log;
#error_log  logs/error.log  notice;
#error_log  logs/error.log  info;
#pid        logs/nginx.pid;
events {
    worker_connections  1024;
http {
    include       mime.types;
    default_type  application/octet-stream;
    #log_format  main  '$remote_addr - $remote_user [$time_local] "$request" '
    #                  '$status $body_bytes_sent "$http_referer" '
    #                  '"$http_user_agent" "$http_x_forwarded_for"';
    #access_log  logs/access.log  main;
    sendfile        on;
    #tcp_nopush     on;
    #keepalive_timeout  0;
    keepalive_timeout  65;
    gzip  on;
    server {
        listen       80;
        server_name  localhost;
        #charset koi8-r;
        #access_log  logs/host.access.log  main;
        location / {
            root   /var/www;
            index  index.html index.htm  index.php;
        #error_page  404              /404.html;
        error_page   500 502 503 504  /50x.html;
        location = /50x.html {
            root   html;
        #location ~ \.php$ {
        #    proxy_pass   http://127.0.0.1;
        # pass the PHP scripts to FastCGI server listening on 127.0.0.1:9000
        location ~ \.php$ {
            root           /var/www;
             fastcgi_pass   127.0.0.1:9000;
             fastcgi_index  index.php;
             fastcgi_param  SCRIPT_FILENAME  /var/www$fastcgi_script_name;
             include        fastcgi_params;
        #location ~ /\.ht {
        #    deny  all;
    #server {
    #    listen       8000;
    #    listen       somename:8080;
    #    server_name  somename  alias  another.alias;
    #    location / {
    #        root   html;
    #        index  index.html index.htm;
    # HTTPS server
    #server {
    #    listen       443;
    #    server_name  localhost;
    #    ssl                  on;
    #    ssl_certificate      cert.pem;
    #    ssl_certificate_key  cert.key;
    #    ssl_session_timeout  5m;
    #    ssl_protocols  SSLv2 SSLv3 TLSv1;
    #    ssl_ciphers  HIGH:!aNULL:!MD5;
    #    ssl_prefer_server_ciphers   on;
    #    location / {
    #        root   html;
    include /etc/nginx/conf.d/*.conf;
nano /etc/rc.d/rc.php-cgi
Sadrzaj:
#!/bin/sh
# /etc/rc.d/rc.php-cgi
# Start/stop/restart
# Da se php-cgi startuje automatski prilikom boot-a, ...
# u zvrsni:  chmod +x /etc/rc.d/rc.php-cgi
case "$1" in
  'start')
   echo "Starting php-cgi"
   /usr/bin/php-cgi -b 127.0.0.1:9000 &
'stop')
    echo "Shutdown php-cgi"
    killall php-cgi
  'restart')
    echo "Shutdown php-cgi....."
    killall php-cgi
    sleep 3
    echo "Starting php-cgi..."
    echo "Usage: $0 {start|stop|restart}"
esac
pa:
i:
/etc/rc.d/rc.php-cgi start
DONE!!!
nano /var/www/index.php
Sadrzaj:
<?php echo 'radi :)'; ?>
Ako nam je, kao sto jeste, default user nginx-a "nobody", promeniti vlasnistvo u nobody:
chown -R nobody:nobody /var/www
Na lokaciji:
http://localhost/index.php
se nalazi vasa php skripta :)
httpd(apache) - slekver 1337 --> WSI
phpmyadmin -slekver 1337 --> WSI
Post Napisano: 14 Jan 2013, 14:54
Sjajno! :) Pretekao si me i skinuo mi teret s grbače. Baš mi se ovih dana motala po glavi ideja da se napiše par članaka vezanih za setup nekoliko najpopularnijih web servera pod Slackom.
Imaš li iskustva sa lighttpd?
Post Napisano: 14 Jan 2013, 15:04
Da, na debian-u, ali nije problem da ga poteram ni na slack-u ...
Sutra ili danas cu pokusati malko da eksperimentisem ... a httpd ima taj link ispod... ali i njega cu lepo doterati i postovati ... usput, spremam ovih dana malko opsirnija objasnjenja vezana za web servere na slack-u ... pa nije nikakav problem da ih podelim sa covecanstvom :) :) :) to je valjda i svrha otvorenog koda, da se ne krije nista od korisnika ;)
Post Napisano: 14 Jan 2013, 15:20
hightech wrote:Da, na debian-u, ali nije problem da ga poteram ni na slack-u ...
Hvala. ;) Da dovršimo rundu. O Apaču smo malo pisali ranije.
hightech wrote:usput, spremam ovih dana malko opsirnija objasnjenja vezana za web servere na slack-u ... pa nije nikakav problem da ih podelim sa covecanstvom :) :) :) to je valjda i svrha otvorenog koda, da se ne krije nista od korisnika ;)
Odlično. :)
