i jos jedno pitanje a to je sto imam neke starije verzije programa... konkretno gimp kad sam bio radio update sistema?
su -c 'grep IRQ /var/log/syslog'
su -c 'dmesg | tail'
-c 'dmesg | tail'
CPU0 CPU1
0: 48114 0 IO-APIC-edge timer
1: 10 0 IO-APIC-edge i8042
7: 1 0 IO-APIC-edge
8: 1 0 IO-APIC-edge rtc0
9: 1254 0 IO-APIC-fasteoi acpi
12: 174 0 IO-APIC-edge i8042
14: 1 0 IO-APIC-edge platform
15: 1 0 IO-APIC-edge platform
18: 4935 0 IO-APIC-fasteoi ath9k
20: 4357 0 IO-APIC-fasteoi ohci_hcd:usb2
21: 748 0 IO-APIC-fasteoi snd_hda_intel
23: 343 0 IO-APIC-fasteoi ehci_hcd:usb1
40: 20100 0 PCI-MSI-edge ahci
41: 0 0 PCI-MSI-edge eth0
42: 210 0 PCI-MSI-edge nvidia
NMI: 0 0 Non-maskable interrupts
LOC: 59784 65668 Local timer interrupts
SPU: 0 0 Spurious interrupts
^G Get Help ^O WriteOut ^R Read File ^Y Prev Page ^K Cut Text ^C Cur Pos
^X Exit ^J Justify ^W Where Is ^V Next Page ^U UnCut Text ^T To Spell
su -c "dmesg | grep -i irq"
su -c "dmesg | tail"
dmesg | grep -i irq
ad63r@darkstar:~$ su -c "dmesg | grep -i irq"
Password:
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 14 global_irq 14 high edge)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 15 global_irq 15 high edge)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] ACPI: IRQ14 used by override.
[ 0.000000] ACPI: IRQ15 used by override.
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] NR_IRQS:2304 nr_irqs:712 16
[ 0.000000] CPU 0 irqstacks, hard=f5008000 soft=f500a000
[ 0.000000] spurious 8259A interrupt: IRQ7.
[ 0.035280] CPU 1 irqstacks, hard=f5100000 soft=f5102000
[ 0.222632] ACPI: PCI Interrupt Link [LNKA] (IRQs 16 17 18 19) *0, disabled.
[ 0.223141] ACPI: PCI Interrupt Link [LNKB] (IRQs 16 17 18 19) *0, disabled.
[ 0.223733] ACPI: PCI Interrupt Link [LNKC] (IRQs 16 17 18 19) *0, disabled.
[ 0.224412] ACPI: PCI Interrupt Link [LNKD] (IRQs 16 17 18 19) *0, disabled.
[ 0.225013] ACPI: PCI Interrupt Link [LN0A] (IRQs 16 17 18 19) *0, disabled.
[ 0.225604] ACPI: PCI Interrupt Link [LN0B] (IRQs 16 17 18 19) *0, disabled.
[ 0.226138] ACPI: PCI Interrupt Link [LN0C] (IRQs 16 17 18 19) *0, disabled.
[ 0.226728] ACPI: PCI Interrupt Link [LN0D] (IRQs 16 17 18 19) *0, disabled.
[ 0.227366] ACPI: PCI Interrupt Link [LN1A] (IRQs 16 17 18 19) *0, disabled.
[ 0.227954] ACPI: PCI Interrupt Link [LN1B] (IRQs 16 17 18 19) *0, disabled.
[ 0.228541] ACPI: PCI Interrupt Link [LN1C] (IRQs 16 17 18 19) *0, disabled.
[ 0.229138] ACPI: PCI Interrupt Link [LN1D] (IRQs 16 17 18 19) *0, disabled.
[ 0.229726] ACPI: PCI Interrupt Link [LN2A] (IRQs 16 17 18 19) *0, disabled.
[ 0.230323] ACPI: PCI Interrupt Link [LN2B] (IRQs 16 17 18 19) *0, disabled.
[ 0.230910] ACPI: PCI Interrupt Link [LN2C] (IRQs 16 17 18 19) *0, disabled.
[ 0.231497] ACPI: PCI Interrupt Link [LN2D] (IRQs 16 17 18 19) *0, disabled.
[ 0.232108] ACPI: PCI Interrupt Link [LN3A] (IRQs 16 17 18 19) *15
[ 0.232649] ACPI: PCI Interrupt Link [LN3B] (IRQs 16 17 18 19) *0, disabled.
[ 0.233230] ACPI: PCI Interrupt Link [LN3C] (IRQs 16 17 18 19) *0, disabled.
[ 0.233821] ACPI: PCI Interrupt Link [LN3D] (IRQs 16 17 18 19) *0, disabled.
[ 0.234414] ACPI: PCI Interrupt Link [LN4A] (IRQs 16 17 18 19) *10
[ 0.234960] ACPI: PCI Interrupt Link [LN4B] (IRQs 16 17 18 19) *0, disabled.
[ 0.235549] ACPI: PCI Interrupt Link [LN4C] (IRQs 16 17 18 19) *0, disabled.
[ 0.236138] ACPI: PCI Interrupt Link [LN4D] (IRQs 16 17 18 19) *0, disabled.
[ 0.236726] ACPI: PCI Interrupt Link [LN5A] (IRQs 16 17 18 19) *0, disabled.
[ 0.237323] ACPI: PCI Interrupt Link [LN5B] (IRQs 16 17 18 19) *0, disabled.
[ 0.237911] ACPI: PCI Interrupt Link [LN5C] (IRQs 16 17 18 19) *0, disabled.
[ 0.238497] ACPI: PCI Interrupt Link [LN5D] (IRQs 16 17 18 19) *0, disabled.
[ 0.239120] ACPI: PCI Interrupt Link [LN6A] (IRQs 16 17 18 19) *0, disabled.
[ 0.239709] ACPI: PCI Interrupt Link [LN6B] (IRQs 16 17 18 19) *0, disabled.
[ 0.240278] ACPI: PCI Interrupt Link [LN6C] (IRQs 16 17 18 19) *0, disabled.
[ 0.240869] ACPI: PCI Interrupt Link [LN6D] (IRQs 16 17 18 19) *0, disabled.
[ 0.241458] ACPI: PCI Interrupt Link [LUB0] (IRQs 20 21 22 23) *10
[ 0.242045] ACPI: PCI Interrupt Link [LUB2] (IRQs 20 21 22 23) *11
[ 0.242588] ACPI: PCI Interrupt Link [LMAC] (IRQs 20 21 22 23) *0, disabled.
[ 0.243141] ACPI: PCI Interrupt Link [LAZA] (IRQs 20 21 22 23) *9
[ 0.243684] ACPI: PCI Interrupt Link [SGRU] (IRQs 20 21 22 23) *15
[ 0.244243] ACPI: PCI Interrupt Link [LSMB] (IRQs 20 21 22 23) *14
[ 0.244796] ACPI: PCI Interrupt Link [LPMU] (IRQs 20 21 22 23) *7
[ 0.245374] ACPI: PCI Interrupt Link [LSA0] (IRQs 20 21 22 23) *5
[ 0.245937] ACPI: PCI Interrupt Link [LATA] (IRQs 20 21 22 23) *0, disabled.
[ 0.246542] ACPI: PCI Interrupt Link [UB11] (IRQs 20 21 22 23) *0, disabled.
[ 0.247138] ACPI: PCI Interrupt Link [UB12] (IRQs 20 21 22 23) *0, disabled.
[ 0.247730] ACPI: PCI Interrupt Link [LRP0] (IRQs 20 21 22 23) *10
[ 0.248284] ACPI: PCI Interrupt Link [LRP1] (IRQs 20 21 22 23) *0, disabled.
[ 0.248873] ACPI: PCI Interrupt Link [LRP2] (IRQs 20 21 22 23) *0, disabled.
[ 0.249456] ACPI: PCI Interrupt Link [LRP3] (IRQs 20 21 22 23) *11
[ 0.250030] ACPI: PCI Interrupt Link [LRP4] (IRQs 20 21 22 23) *9
[ 0.250577] ACPI: PCI Interrupt Link [LRP5] (IRQs 20 21 22 23) *0, disabled.
[ 0.251139] ACPI: PCI Interrupt Link [LRP6] (IRQs 20 21 22 23) *0, disabled.
[ 0.253252] PCI: Using ACPI for IRQ routing
[ 0.254008] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 31, 31
[ 0.309801] ACPI: PCI Interrupt Link [LRP0] enabled at IRQ 23
[ 0.310199] ACPI: PCI Interrupt Link [LRP3] enabled at IRQ 22
[ 0.310569] ACPI: PCI Interrupt Link [LRP4] enabled at IRQ 21
[ 0.312792] ACPI: PCI Interrupt Link [LUB0] enabled at IRQ 20
[ 0.386362] ACPI: PCI Interrupt Link [LUB2] enabled at IRQ 23
[ 0.758089] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.763136] qlogicfas: no cards were found, please specify I/O address and IRQ using iobase= and irq= options
[ 0.860019] ACPI: PCI Interrupt Link [LSA0] enabled at IRQ 22
[ 0.860169] ahci 0000:00:0b.0: irq 40 for MSI/MSI-X
[ 0.861361] ata1: SATA max UDMA/133 abar m8192@0xfae7c000 port 0xfae7c100 irq 40
[ 0.861518] ata2: SATA max UDMA/133 abar m8192@0xfae7c000 port 0xfae7c180 irq 40
[ 0.862989] ata3: PATA max PIO4 cmd 0x1f0 ctl 0x3f6 irq 14
[ 3.832251] ata4: PATA max PIO4 cmd 0x170 ctl 0x376 irq 15
[ 3.985219] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
[ 3.991688] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 3.991794] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[ 3.991920] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[ 3.992048] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[ 3.992170] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[ 3.993055] rtc_cmos 00:07: alarms up to one year, y3k, 114 bytes nvram, hpet irqs
[ 6.748149] ACPI: PCI Interrupt Link [LN3A] enabled at IRQ 19
[ 6.748423] r8169 0000:04:00.0: irq 41 for MSI/MSI-X
[ 6.748582] r8169 0000:04:00.0 eth0: RTL8168b/8111b at 0xf89ba000, 00:26:18:2d:23:3c, XID 18000000 IRQ 41
[ 6.809600] ehci-pci 0000:00:04.1: irq 23, io mem 0xfae7ec00
[ 6.817037] ohci_hcd 0000:00:04.0: irq 20, io mem 0xfae7f000
[ 6.946887] ACPI: PCI Interrupt Link [LAZA] enabled at IRQ 21
[ 7.605060] ACPI: PCI Interrupt Link [LN4A] enabled at IRQ 18
[ 7.655983] ieee80211 phy0: Atheros AR9285 Rev:2 mem=0xfa520000, irq=18
[ 12.567692] ACPI: PCI Interrupt Link [LPMU] enabled at IRQ 20
[ 12.568070] ACPI: PCI Interrupt Link [SGRU] enabled at IRQ 23
[ 61.926866] nvidia 0000:03:00.0: irq 42 for MSI/MSI-X
bad63r@darkstar:~$
