Proverom utvrdim da mi Slackware uopšte ne vidi wifi i (verovatno) bluetooth. WiFi i bluetooth su na matičnoj ploči i kako mi BT manje bitan u ovom trenutku, zanima me da li se neko sretao sa ovom wifi karticom i zna li koji modul bi trebalo da učitam da wifi proradi?
[REŠENO] Intel AX211 wifi problem
Napokon me Gigabyte ploča pustila da boot-ujem ssd na kojem se nalazi Slackware 15 i sredim elilo i sve proradi, napokon ugledam učitavanje sistema, login, kde... kad ono, nema mi wifi nigde
Da dodam, imam onaj prethodni usb dongle sa kojim imam net i radi dobro pa mogu da budem da imam pristup internetu i ostavim izlaze iz terminala ako zatreba. Usput sam uradio update kernel-firmware i ostatka sistema. Kernel je i dalje 5.15.145 i ne radi mi se update trenutno.
Dmesg daje informacije o neučitavanju drajvera za AX211 koji je pod iwlwifi:
bash-5.1# dmesg | grep iw
[ 8.603872] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[ 8.607534] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-66.ucode failed with error -2
[ 8.608013] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-65.ucode failed with error -2
[ 8.619444] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-64.ucode failed with error -2
[ 8.623732] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-63.ucode failed with error -2
[ 8.628585] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-62.ucode failed with error -2
[ 8.631343] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-61.ucode failed with error -2
[ 8.633591] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-60.ucode failed with error -2
[ 8.636568] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-59.ucode failed with error -2
[ 8.639885] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-58.ucode failed with error -2
[ 8.640820] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-57.ucode failed with error -2
[ 8.641661] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-56.ucode failed with error -2
[ 8.642453] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-55.ucode failed with error -2
[ 8.642924] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-54.ucode failed with error -2
[ 8.643307] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-53.ucode failed with error -2
[ 8.643650] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-52.ucode failed with error -2
[ 8.644111] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-51.ucode failed with error -2
[ 8.644417] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-50.ucode failed with error -2
[ 8.644714] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-49.ucode failed with error -2
[ 8.645160] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-48.ucode failed with error -2
[ 8.645420] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-47.ucode failed with error -2
[ 8.645666] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-46.ucode failed with error -2
[ 8.646047] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-45.ucode failed with error -2
[ 8.646553] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-44.ucode failed with error -2
[ 8.647295] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-43.ucode failed with error -2
[ 8.647574] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-42.ucode failed with error -2
[ 8.647852] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-41.ucode failed with error -2
[ 8.648086] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-40.ucode failed with error -2
[ 8.648312] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf-a0-39.ucode failed with error -2
[ 8.648527] iwlwifi 0000:00:14.3: no suitable firmware found!
[ 8.648735] iwlwifi 0000:00:14.3: minimum version required: iwlwifi-so-a0-gf-a0-39
[ 8.649096] iwlwifi 0000:00:14.3: maximum version supported: iwlwifi-so-a0-gf-a0-66
[ 8.649303] iwlwifi 0000:00:14.3: check git://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
bash-5.1#
[iwlwifi 0000:00:14.3: minimum version required: iwlwifi-so-a0-gf-a0-39
iwlwifi 0000:00:14.3: maximum version supported: iwlwifi-so-a0-gf-a0-66Code: Select all
rw-r--r-- 1 root root 1560532 Jun 4 19:48 iwlwifi-so-a0-gf-a0-72.ucode
-rw-r--r-- 1 root root 1563692 Jun 4 19:48 iwlwifi-so-a0-gf-a0-73.ucode
-rw-r--r-- 1 root root 1577460 Jun 4 19:48 iwlwifi-so-a0-gf-a0-74.ucode
-rw-r--r-- 1 root root 1641260 Jun 4 19:48 iwlwifi-so-a0-gf-a0-77.ucode
-rw-r--r-- 1 root root 1667236 Jun 4 19:48 iwlwifi-so-a0-gf-a0-78.ucode
-rw-r--r-- 1 root root 1672988 Jun 4 19:48 iwlwifi-so-a0-gf-a0-79.ucode
-rw-r--r-- 1 root root 1682852 Jun 4 19:48 iwlwifi-so-a0-gf-a0-81.ucode
-rw-r--r-- 1 root root 1739988 Jun 4 19:48 iwlwifi-so-a0-gf-a0-83.ucode
-rw-r--r-- 1 root root 1737644 Jun 4 19:48 iwlwifi-so-a0-gf-a0-84.ucode
-rw-r--r-- 1 root root 1679788 Jun 4 19:48 iwlwifi-so-a0-gf-a0-86.ucode
-rw-r--r-- 1 root root 1736028 Jun 4 19:48 iwlwifi-so-a0-gf-a0-89.ucode
-rw-r--r-- 1 root root 55208 Jun 4 19:48 iwlwifi-so-a0-gf-a0.pnvm
Slack 15.0? Моžda kernel-firmware paket nije dovoljno ažuran i ne uključuje firmware za iwlwifi?
Skini skript za ažuriranje firmware-a iz Slackware Current-a, zatim pokreni skriptu kernel-firmware.SlackBuild i instaliraj kreirani paket.
Izgradnja paketa će potrajati neko vreme pa imaš vremena da skuvaš kafu ili čaj.
cd ~/Downloads
lftp -e "miror https://mirrors.slackware.com/slackware/slackware64-current/source/a/kernel-firmware/ ; exit"
cd kernel-firmware
bash kernel-firmware.SlackBuild
upgradepkg /tmp/kernel-firmware-*.t?z
Evo baš sad sam završio, sredio sam problem. Neophodni drajveri se nisu nalazili u novijim kernel-firmware paketima ali sam ih našao u starim paketima, na adresi https://mirrors.slackware.com/slackware ... arch-1.txz.
Odatle sam izvukao samo ono što mi je trebalo, tri fajla i kopirao u /lib/firmware i restartovao mašinu i evo sad radi, speed test rezultat je očekivan.
Ostaje još samo da vidim hoće li biti stabilna konekcija i to je to.
bash-5.1# iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
wlan1 IEEE 802.11 ESSID:"albatros_5g"
Mode:Managed Frequency:5.18 GHz Access Point: 38:6B:1C:0E:EA:06
Bit Rate=260 Mb/s Tx-Power=22 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:on
Link Quality=43/70 Signal level=-67 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:53 Missed beacon:0
bash-5.1#
To je jednostavnije rešenje.
I kako šljaka?
I kako šljaka?
Radi, deluje ok. Nisam primetio ništa neuobičajeno.
