Napisano: 03 Mar 2022, 17:59
02.03.2022.
Sveži seamonkey paketi za Slackware 15 i -current:
patches/packages/seamonkey-2.53.11-i686-1_slack15.0.txz: Upgraded.
https://www.seamonkey-project.org/releases/seamonkey2.53.11
Napisano: 13 Mar 2022, 13:13
05.03.2022.
Sveži mozilla-firefox i mozilla-thunderbird paketi za Slackware 15.0 i -current:
patches/packages/mozilla-firefox-91.6.1esr-i686-1_slack15.0.txz: Upgraded.
https://www.mozilla.org/en-US/firefox/91.6.1/releasenotes/
https://www.mozilla.org/security/advisories/mfsa2022-09/
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-26485
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-26486
patches/packages/mozilla-thunderbird-91.6.2-i686-1_slack15.0.txz: Upgraded.
https://www.mozilla.org/en-US/thunderbird/91.6.2/releasenotes/
Napisano: 13 Mar 2022, 13:14
07.03.2022.
Sveži mozilla-firefox za Slackware 15.0 i -current:
patches/packages/mozilla-firefox-91.7.0esr-i686-1_slack15.0.txz: Upgraded.
https://www.mozilla.org/en-US/firefox/91.7.0/releasenotes/
08.03.2022.
Sveži kernel paketi za Slackware 15.0:
patches/packages/linux-5.15.27/*: Upgraded.
These updates fix various bugs and security issues, including the recently
announced "Dirty Pipe" vulnerability which allows overwriting data in
arbitrary read-only files (CVE-2022-0847).
Fixed in 5.15.20:
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-0492
Fixed in 5.15.23:
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-0516
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-0435
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-0487
Fixed in 5.15.24:
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-25375
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-25258
Fixed in 5.15.25:
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-0847
Fixed in 5.15.26:
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-25636
Napisano: 13 Mar 2022, 13:15
09.03.2022.
patches/packages/mozilla-thunderbird-91.7.0-i686-1_slack15.0.txz: Upgraded.
https://www.mozilla.org/en-US/thunderbird/91.7.0/releasenotes/
https://www.mozilla.org/en-US/security/advisories/mfsa2022-12/
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-26383
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-26384
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-26387
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-26381
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-26386
Napisano: 13 Mar 2022, 13:16
12.03.2022.
Sveži polkit paketi za Slackware 15.0 i -current:
patches/packages/polkit-0.120-i586-3_slack15.0.txz: Rebuilt.
Patched to fix a security issue where an unprivileged user could cause a
denial of service due to process file descriptor exhaustion.
Thanks to marav.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-4115
Napisano: 18 Mar 2022, 18:53
14.03.2022.
Sveži httpd paketi za Slackware 14.0, 14.1, 14.2, 15.0 i -current:
patches/packages/httpd-2.4.53-i586-1_slack15.0.txz: Upgraded.
This update fixes bugs and the following security issues:
mod_sed: Read/write beyond bounds
core: Possible buffer overflow with very large or unlimited
LimitXMLRequestBody
HTTP request smuggling vulnerability
mod_lua: Use of uninitialized value in r:parsebody
https://downloads.apache.org/httpd/CHANGES_2.4.53
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-23943
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22721
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22720
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22719
Napisano: 18 Mar 2022, 18:54
17.03.2022.
Sveži bind paketi za Slackware 14.0, 14.1, 14.2, 15.0 i -current:
patches/packages/bind-9.18.1-i586-1_slack15.0.txz: Upgraded.
An assertion could occur in resume_dslookup() if the fetch had been shut
down earlier.
Lookups involving a DNAME could trigger an INSIST when "synth-from-dnssec"
was enabled.
A synchronous call to closehandle_cb() caused isc__nm_process_sock_buffer()
to be called recursively, which in turn left TCP connections hanging in the
CLOSE_WAIT state blocking indefinitely when out-of-order processing was
disabled.
The rules for acceptance of records into the cache have been tightened to
prevent the possibility of poisoning if forwarders send records outside
the configured bailiwick.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-0667
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-0635
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-0396
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-25220
Sveži openssl paketi za Slackware 14.2, 15.0 i -current:
patches/packages/openssl-1.1.1n-i586-1_slack15.0.txz: Upgraded.
This update fixes a high severity security issue:
The BN_mod_sqrt() function, which computes a modular square root, contains
a bug that can cause it to loop forever for non-prime moduli.
https://www.openssl.org/news/secadv/20220315.txt
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-0778
patches/packages/openssl-solibs-1.1.1n-i586-1_slack15.0.txz: Upgraded.
Napisano: 25 Mar 2022, 16:10
18.03,2022.
Sveži python3 paketi za Slackware 15:
patches/packages/python3-3.9.11-i586-1_slack15.0.txz: Upgraded.
libexpat upgraded from 2.4.1 to 2.4.7
bundled pip upgraded from 21.2.4 to 22.0.4
authorization bypass fixed in urllib.request
REDoS avoided in importlib.metadata
https://pythoninsider.blogspot.com/2022/03/python-3103-3911-3813-and-3713-are-now.html
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-28363
Napisano: 25 Mar 2022, 16:11
21.03.2022
Bind paket za Slackware 15:
patches/packages/bind-9.16.27-i586-1_slack15.0.txz: Upgraded.
Sorry folks, I had not meant to bump BIND to the newer branch. I've moved
the other packages into /testing. Thanks to Nobby6 for pointing this out.
disabled.
testing/packages/bind-9.18.1-i586-1_slack15.0.txz: Moved.
Users browsing this forum: No registered users and 46 guests
