Locked
Post Napisano: 11 May 2018, 22:11
03.05.2018.
Sveži seamonkey paketi za Slackware 14.2 i -current:
patches/packages/seamonkey-2.49.3-i586-1_slack14.2.txz:  Upgraded.
  For more information (when it appears), see:
    http://www.seamonkey-project.org/releases/seamonkey2.49.3
patches/packages/seamonkey-solibs-2.49.3-i586-1_slack14.2.txz:  Upgraded.
Post Napisano: 11 May 2018, 22:12
04.05.2018.
Sveži python paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/python-2.7.15-i586-1_slack14.2.txz:  Upgraded.
  Updated to the latest 2.7.x release.
  This fixes some security issues in difflib and poplib (regexes vulnerable
  to denial of service attacks), as well as security issues with the bundled
  expat library.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-0876
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-0718
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-4472
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-5300
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-9063
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-9233
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1060
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1061
Post Napisano: 11 May 2018, 22:14
09.05.2018.
patches/packages/mozilla-firefox-52.8.0esr-i586-1_slack14.2.txz:  Upgraded.
    https://www.mozilla.org/en-US/security/advisories/mfsa2018-12/
Sveži wget paketi za Slackware 13.0, 13.1, 13.37, 14.0, 14.1, 14.2 i -current:
patches/packages/wget-1.19.5-i586-1_slack14.2.txz:  Upgraded.
  Fixed a security issue where a malicious web server could inject arbitrary
  cookies into the cookie jar file.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-0494
10.05.2018.
Sveži maridb paketi za Slackware 14.1 i 14.2:
patches/packages/mariadb-10.0.35-i586-1_slack14.2.txz:  Upgraded.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-2782
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-2784
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-2787
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-2766
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-2755
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-2819
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-2817
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-2761
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-2781
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-2771
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-2813
Post Napisano: 24 May 2018, 20:26
16.05.2018.
Sveži curl i php paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/curl-7.60.0-i586-1_slack14.2.txz:  Upgraded.
  This release contains security fixes:
  FTP: shutdown response buffer overflow
  RTSP: bad headers buffer over-read
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1000300
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1000301
patches/packages/php-5.6.36-i586-1_slack14.2.txz:  Upgraded.
  This fixes many bugs, including some security issues:
  Heap Buffer Overflow (READ: 1786) in exif_iif_add_value
  stream filter convert.iconv leads to infinite loop on invalid sequence
  Malicious LDAP-Server Response causes crash
  fix for CVE-2018-5712 may not be complete
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-10549
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-10546
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-10548
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-10547
Post Napisano: 24 May 2018, 20:28
22.05.2018.
patches/packages/linux-4.4.132/*:  Upgraded.
  This kernel upgrade is being provided primarily to fix a regression in the
  getsockopt() function, but it also contains fixes for two denial-of-service
  security issues.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1000004
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1092
Sveži mozilla-thunderbird i procps-ng paketi za Slackware 14.2 i -current:
patches/packages/mozilla-thunderbird-52.8.0-i586-1_slack14.2.txz:  Upgraded.
    https://www.mozilla.org/en-US/thunderbird/52.8.0/releasenotes/
    https://www.mozilla.org/en-US/security/advisories/mfsa2018-13/
patches/packages/procps-ng-3.3.15-i586-1_slack14.2.txz:  Upgraded.
  library: Fix integer overflow and LPE in file2strvec
  library: Use size_t for alloc functions
  pgrep: Fix stack-based buffer overflow
  ps: Fix buffer overflow in output buffer, causing DOS
  top: Don't use cwd for location of config
    https://www.qualys.com/2018/05/17/procps-ng-audit-report-advisory.txt
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1124
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1126
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1125
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1123
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1122
Post Napisano: 02 Jun 2018, 12:49
01.06.2018.
Sveži git paketi za Slackware 13.0, 13.1, 13.37, 14.0, 14.1, 14.2 i -current:
patches/packages/git-2.14.4-i586-1_slack14.2.txz:  Upgraded.
  Submodule "names" come from the untrusted .gitmodules file, but we
  blindly append them to $GIT_DIR/modules to create our on-disk repo
  paths. This means you can do bad things by putting "../" into the
  name. We now enforce some rules for submodule names which will cause
  Git to ignore these malicious names (CVE-2018-11235).
  Credit for finding this vulnerability and the proof of concept from
  which the test script was adapted goes to Etienne Stalmans.
  It was possible to trick the code that sanity-checks paths on NTFS
  into reading random piece of memory (CVE-2018-11233).
  Credit for fixing for these bugs goes to Jeff King, Johannes
  Schindelin and others.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-11235
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-11233
Post Napisano: 07 Jun 2018, 15:45
06.06.2018.
patches/packages/mozilla-firefox-52.8.1esr-i586-1_slack14.2.txz:  Upgraded.
Post Napisano: 16 Jun 2018, 19:38
08.06.2018.
Sveži gnupg2 paketi za Slackware 13.37, 14.0, 14.1, 14.2 i -current:
patches/packages/gnupg2-2.0.31-i586-1_slack14.2.txz:  Upgraded.
  Sanitize the diagnostic output of the original file name in verbose mode.
  By using a made up file name in the message it was possible to fake status
  messages. Using this technique it was for example possible to fake the
  verification status of a signed mail.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-12020
Post Napisano: 16 Jun 2018, 19:39
13.06.2018.
Sveži libgcrypt paketi za Slackware 14.2 i -current:
patches/packages/libgcrypt-1.7.10-i586-1_slack14.2.txz:  Upgraded.
  Use blinding for ECDSA signing to mitigate a novel side-channel attack.
    https://www.nccgroup.trust/us/our-research/technical-advisory-return-of-the-hidden-number-problem/
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-0495
Locked
