Locked
Post Napisano: 31 Jan 2019, 21:18
30.01.2019.
patches/packages/linux-4.4.172/*:  Upgraded.
  These updates fix various bugs and many (mostly minor) security issues.
    Fixed in 4.4.159:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-20511
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-14633
    Fixed in 4.4.160:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-7755
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-18021
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-10880
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-13053
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-17972
    Fixed in 4.4.163:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-18281
    Fixed in 4.4.164:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-18710
    Fixed in 4.4.167:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-19824
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-16862
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-20169
    Fixed in 4.4.168:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1120
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-5848
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-12896
    Fixed in 4.4.169:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-18241
    Fixed in 4.4.170:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-19985
    Fixed in 4.4.171:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-16884
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-14611
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-14610
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-14613
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-14612
    Fixed in 4.4.172:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-14616
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-13096
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-13097
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-14614
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-13099
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-13100
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-3701
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-18690
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-18249
Post Napisano: 04 Feb 2019, 20:31
01.02.2019.
Sveži mariadb paketi za Slackware 14.1 i 14.2:
patches/packages/mariadb-10.0.38-i586-1_slack14.2.txz:  Upgraded.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-2537
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-2529
Post Napisano: 10 Feb 2019, 17:12
06.02.2019.
patches/packages/curl-7.64.0-i586-1_slack14.2.txz:  Upgraded.
  This release fixes the following security issues:
  NTLM type-2 out-of-bounds buffer read.
  NTLMv2 type-3 header stack buffer overflow.
  SMTP end-of-response out-of-bounds read.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-16890
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-3822
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-3823
Post Napisano: 10 Feb 2019, 17:13
07.02.2019.
Sveži php paketi za Slackware 14.0, 14.1 i 14.2:
patches/packages/php-5.6.40-i586-1_slack14.2.txz:  Upgraded.
  Several security bugs have been fixed in this release:
  GD:
  Fixed bug #77269 (efree() on uninitialized Heap data in imagescale leads
  to use-after-free).
  Fixed bug #77270 (imagecolormatch Out Of Bounds Write on Heap).
  Mbstring:
  Fixed bug #77370 (Buffer overflow on mb regex functions - fetch_token).
  Fixed bug #77371 (heap buffer overflow in mb regex functions -
  compile_string_node).
  Fixed bug #77381 (heap buffer overflow in multibyte match_at).
  Fixed bug #77382 (heap buffer overflow due to incorrect length in
  expand_case_fold_string).
  Fixed bug #77385 (buffer overflow in fetch_token).
  Fixed bug #77394 (Buffer overflow in multibyte case folding - unicode).
  Fixed bug #77418 (Heap overflow in utf32be_mbc_to_code).
  Phar:
  Fixed bug #77247 (heap buffer overflow in phar_detect_phar_fname_ext).
  Xmlrpc:
  Fixed bug #77242 (heap out of bounds read in xmlrpc_decode()).
  Fixed bug #77380 (Global out of bounds read in xmlrpc base64 code).
    https://php.net/ChangeLog-5.php#5.6.40
Post Napisano: 16 Mar 2019, 00:10
13.02.2019.
patches/packages/mozilla-firefox-60.5.1esr-i686-1_slack14.2.txz:  Upgraded.
    https://www.mozilla.org/en-US/security/advisories/mfsa2019-05/
    https://www.mozilla.org/en-US/security/advisories/mfsa2019-05/#CVE-2018-18356
    https://www.mozilla.org/en-US/security/advisories/mfsa2019-05/#CVE-2019-5785
    https://www.mozilla.org/en-US/security/advisories/mfsa2019-05/#CVE-2018-18335
Post Napisano: 16 Mar 2019, 00:12
14.02.2019.
Sveži mozilla-thunderbird paketi za Slackware 14.2 i -current:
patches/packages/mozilla-thunderbird-60.5.1-i686-1_slack14.2.txz:  Upgraded.
    https://www.mozilla.org/en-US/thunderbird/60.5.1/releasenotes/
    https://www.mozilla.org/security/known-vulnerabilities/thunderbird.html
    https://www.mozilla.org/en-US/security/advisories/mfsa2019-06/
    https://www.mozilla.org/en-US/security/advisories/mfsa2019-06/#CVE-2018-18356
    https://www.mozilla.org/en-US/security/advisories/mfsa2019-06/#CVE-2019-5785
    https://www.mozilla.org/en-US/security/advisories/mfsa2019-06/#CVE-2018-18335
    https://www.mozilla.org/en-US/security/advisories/mfsa2019-06/#CVE-2018-18509
Post Napisano: 16 Mar 2019, 00:14
23.02.2019.
Sveži file paketi za Slackware 14.0, 14.1, 14.2. -current:
patches/packages/file-5.36-i586-1_slack14.2.txz:  Upgraded.
  Fix out-of-bounds read and denial-of-service security issues:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-8906
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-8907
Post Napisano: 16 Mar 2019, 00:15
26.02.2019.
Sveži openssl paketi za Slackware 14.2:
patches/packages/openssl-1.0.2r-i586-1_slack14.2.txz:  Upgraded.
  Go into the error state if a fatal alert is sent or received. If an
  application calls SSL_shutdown after a fatal alert has occured and
  then behaves different based on error codes from that function then
  the application may be vulnerable to a padding oracle.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-1559
patches/packages/openssl-solibs-1.0.2r-i586-1_slack14.2.txz:  Upgraded.
Post Napisano: 16 Mar 2019, 00:16
01.03.2019.
Sveži infozip paketi za Slackware 14.0, 14.1, 14.2. i -current:
patches/packages/infozip-6.0-i586-4_slack14.2.txz:  Rebuilt.
  Added some patches that should fix extracting archives with non-latin
  characters in the filenames. Thanks to saahriktu.
  This update also fixes various security issues in zip and unzip.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-8139
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-8140
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-8141
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-9844
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-18384
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1000035
Post Napisano: 16 Mar 2019, 00:17
03.03.2019.
Sveži python paketi za Slackware 14.0, 14.1, 14.2. i -current:
patches/packages/python-2.7.16-i586-1_slack14.2.txz:  Upgraded.
  Updated to the latest 2.7.x release, which fixes a few security issues.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-1752
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-14647
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-5010
Locked
Users browsing this forum: Bing [Bot] and 2 guests
