Locked
Post Napisano: 16 Mar 2019, 00:18
08.03.2019.
Sveži ntp paketi za Slackware 14.0, 14.1, 14.2. i -current:
patches/packages/ntp-4.2.8p13-i586-1_slack14.2.txz:  Upgraded.
  This release fixes a bug that allows an attacker with access to an explicitly
  trusted source to send a crafted malicious mode 6 (ntpq) packet that can
  trigger a NULL pointer dereference, crashing ntpd.
  It also provides 17 other bugfixes and 1 other improvement.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-8936
Post Napisano: 24 Mar 2019, 01:06
18.03.2019.
Sveži libssh2 paketi za Slackware 14.2 i -current:
patches/packages/libssh2-1.8.1-i586-1_slack14.2.txz:  Upgraded.
  Fixed several security issues.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-3855
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-3856
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-3857
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-3858
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-3859
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-3860
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-3861
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-3862
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-3863
Post Napisano: 24 Mar 2019, 01:08
22.03.2019.
patches/packages/mozilla-firefox-60.6.1esr-i686-1_slack14.2.txz:  Upgraded.
  This release contains security fixes and improvements. The patched flaws
  are considered critical, and could be used to run attacker code and install
  software, requiring no user interaction beyond normal browsing.
    https://www.mozilla.org/en-US/security/advisories/mfsa2019-10/
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-9810i
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-9813
Post Napisano: 01 Apr 2019, 19:55
25.03.2019.
Sveži mozilla-thunderbird paketi za Slackware 14.2 i -current:
patches/packages/mozilla-thunderbird-60.6.1-i686-1_slack14.2.txz:  Upgraded.
    https://www.mozilla.org/en-US/thunderbird/60.6.1/releasenotes/
    https://www.mozilla.org/security/known-vulnerabilities/thunderbird.html
Post Napisano: 01 Apr 2019, 19:56
27.03.2019.
Sveži gnutls paketi za Slackware 14.2 i -current:
patches/packages/gnutls-3.6.7-i586-1_slack14.2.txz:  Upgraded.
  Fixes security issues:
  libgnutls, gnutls tools: Every gnutls_free() will automatically set
  the free'd pointer to NULL. This prevents possible use-after-free and
  double free issues. Use-after-free will be turned into NULL dereference.
  The counter-measure does not extend to applications using gnutls_free().
  libgnutls: Fixed a memory corruption (double free) vulnerability in the
  certificate verification API. Reported by Tavis Ormandy; addressed with
  the change above. [GNUTLS-SA-2019-03-27, #694]
  libgnutls: Fixed an invalid pointer access via malformed TLS1.3 async
  messages; Found using tlsfuzzer. [GNUTLS-SA-2019-03-27, #704]
  libgnutls: enforce key usage limitations on certificates more actively.
  Previously we would enforce it for TLS1.2 protocol, now we enforce it
  even when TLS1.3 is negotiated, or on client certificates as well. When
  an inappropriate for TLS1.3 certificate is seen on the credentials
  structure GnuTLS will disable TLS1.3 support for that session (#690).
  libgnutls: enforce the equality of the two signature parameters fields
  in a certificate. We were already enforcing the signature algorithm,
  but there was a bug in parameter checking code.
Post Napisano: 03 May 2019, 18:52
02.04.2019.
Sveži ghostscript i wget paketi za Slackware 14.2 i -current:
patches/packages/ghostscript-9.26-i586-1_slack14.2.txz:  Upgraded.
  A specially crafted PostScript file could have access to the file system
  outside of the constrains imposed by -dSAFER.
  Transient procedures can allow access to system operators, leading to
  remote code execution.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-3835
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-3838
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-6116
patches/packages/wget-1.20.2-i586-1_slack14.2.txz:  Upgraded.
  Fixed an unspecified buffer overflow vulnerability.
Post Napisano: 03 May 2019, 18:54
05.04.2019.
Sveži openjpeg i wget paketi za Slackware 14.2 i -current:
patches/packages/openjpeg-2.3.1-i586-1_slack14.2.txz:  Upgraded.
  Includes many bug fixes (including security fixes).
patches/packages/wget-1.20.3-i586-1_slack14.2.txz:  Upgraded.
  Fixed a buffer overflow vulnerability:
  src/iri.c(do_conversion): Reallocate the output buffer to a larger
  size if it is already full.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-5953
Post Napisano: 03 May 2019, 18:59
06.04.2019.
Sveži httpd paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/httpd-2.4.39-i586-1_slack14.2.txz:  Upgraded.
  In Apache HTTP Server 2.4 releases 2.4.17 to 2.4.38, with MPM event, worker
  or prefork, code executing in less-privileged child processes or threads
  (including scripts executed by an in-process scripting interpreter) could
  execute arbitrary code with the privileges of the parent process by
  manipulating the scoreboard.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-0211
Post Napisano: 03 May 2019, 19:01
17.04.2019.
Sveži libpng paketi za Slackware 14.2 i -current:
patches/packages/libpng-1.6.37-i586-1_slack14.2.txz:  Upgraded.
  Fixed a use-after-free vulnerability (CVE-2019-7317) in png_image_free.
  Fixed a memory leak in the ARM NEON implementation of png_do_expand_palette.
  Fixed a memory leak in pngtest.c.
  Fixed two vulnerabilities (CVE-2018-14048, CVE-2018-14550) in
  contrib/pngminus; refactor.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-14048
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-14550
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-7317
Post Napisano: 03 May 2019, 19:09
26.04.2019.
patches/packages/bind-9.11.6_P1-i586-1_slack14.2.txz:  Upgraded.
  The TCP client quota set using the tcp-clients option could be exceeded
  in some cases. This could lead to exhaustion of file descriptors.
    https://kb.isc.org/docs/cve-2018-5743
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-5743
Locked
