Locked
Post Napisano: 29 Oct 2019, 00:11
14.10.2019.
Sveži sudo paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/sudo-1.8.28-i586-1_slack14.2.txz:  Upgraded.
  Fixed a bug where an sudo user may be able to run a command as root when
  the Runas specification explicitly disallows root access as long as the
  ALL keyword is listed first.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-14287
Post Napisano: 29 Oct 2019, 00:17
20.10.2019.
Sveži python paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/python-2.7.17-i586-1_slack14.2.txz:  Upgraded.
  Update vendorized expat library version to 2.2.8.
  Disallow URL paths with embedded whitespace or control characters into the
  underlying http client request. Such potentially malicious header injection
  URLs now cause an httplib.InvalidURL exception to be raised.
  Avoid file reading by disallowing ``local-file://`` and ``local_file://``
  URL schemes in :func:`urllib.urlopen`, :meth:`urllib.URLopener.open` and
  :meth:`urllib.URLopener.retrieve`.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-15903
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-9740
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-9948
Post Napisano: 29 Oct 2019, 00:18
22.10.2019.
patches/packages/mozilla-firefox-68.2.0esr-i686-1_slack14.2.txz:  Upgraded.
    https://www.mozilla.org/en-US/firefox/68.2.0/releasenotes/
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-11757
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-11758
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-11759
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-11760
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-11761
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-11762
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-11763
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-11764
Post Napisano: 01 Dec 2019, 23:01
04.11.2019.
Sveži libtiff paketi za Slackware 14.2 i -current:
patches/packages/libtiff-4.1.0-i586-1_slack14.2.txz:  Upgraded.
  libtiff: fix integer overflow in _TIFFCheckMalloc() that could cause a crash.
  tif_dir: unset transferfunction field if necessary.
  pal2rgb: failed to free memory on a few errors.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-14973
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-19210
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-6128
Post Napisano: 01 Dec 2019, 23:02
07.11.2019.
patches/packages/linux-4.4.199/*:  Upgraded.
  These updates fix various bugs and security issues.
    Fixed in 4.4.191:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-3900
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-15118
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-10906
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-10905
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-10638
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-15117
    Fixed in 4.4.193:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-14835
    Fixed in 4.4.194:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-14816
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-14814
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-15505
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-14821
    Fixed in 4.4.195:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-17053
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-17052
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-17056
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-17055
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-17054
    Fixed in 4.4.196:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-2215
    Fixed in 4.4.197:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-16746
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-20976
    Fixed in 4.4.198:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-17075
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-17133
    Fixed in 4.4.199:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-15098
Post Napisano: 01 Dec 2019, 23:03
16.11.2019.
patches/packages/linux-4.4.202/*:  Upgraded.
   CRYPTO_CRC32C_INTEL m -> y
  +X86_INTEL_TSX_MODE_AUTO n
  +X86_INTEL_TSX_MODE_OFF y
  +X86_INTEL_TSX_MODE_ON n
  These updates fix various bugs and security issues, including mitigation for
  the TSX Asynchronous Abort condition on some CPUs.
    Fixed in 4.4.201:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-0155
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-0154
    Fixed in 4.4.202:
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-11135
Post Napisano: 01 Dec 2019, 23:04
20.11.2019.
patches/packages/bind-9.11.13-i586-1_slack14.2.txz:  Upgraded.
  Set a limit on the number of concurrently served pipelined TCP queries.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-6477
Post Napisano: 03 Apr 2020, 18:00
Samo kratak pregled zakrpa koje nisu (još uvek?) navedene u ovoj temi:
2020:
2020-03-31 - [slackware-security] httpd (SSA:2020-091-02)
2020-03-31 - [slackware-security] gnutls (SSA:2020-091-01)
2020-03-26 - [slackware-security] Slackware 14.2 kernel (SSA:2020-086-01)
2020-03-23 - [slackware-security] gd (SSA:2020-083-01)
2020-03-13 - [slackware-security] mozilla-thunderbird (SSA:2020-073-01)
2020-03-10 - [slackware-security] mozilla-firefox (SSA:2020-070-01)
2020-03-04 - [slackware-security] ppp (SSA:2020-064-01)
2020-03-02 - [slackware-security] seamonkey (SSA:2020-062-01)
2020-02-20 - [slackware-security] proftpd (SSA:2020-051-01)
2020-02-12 - [slackware-security] libarchive (SSA:2020-043-01)
2020-02-11 - [slackware-security] mozilla-thunderbird (SSA:2020-042-02)
2020-02-11 - [slackware-security] mozilla-firefox (SSA:2020-042-01)
2020-01-31 - [slackware-security] sudo (SSA:2020-031-01)
2020-01-24 - [slackware-security] mozilla-thunderbird (SSA:2020-024-01)
2020-01-10 - [slackware-security] mozilla-thunderbird (SSA:2020-010-01)
2020-01-09 - [slackware-security] mozilla-firefox (SSA:2020-009-01)
2020-01-08 - [slackware-security] Slackware 14.2 kernel (SSA:2020-008-01)
2020-01-06 - [slackware-security] mozilla-firefox (SSA:2020-006-01)
Detaljnije: http://www.slackware.com/security/list. ... ity&y=2020
2019:
2019-12-20 - [slackware-security] tigervnc (SSA:2019-354-02)
2019-12-20 - [slackware-security] openssl (SSA:2019-354-01)
2019-12-19 - [slackware-security] wavpack (SSA:2019-353-01)
2019-12-03 - [slackware-security] mozilla-firefox (SSA:2019-337-01)
Detaljnije: http://www.slackware.com/security/list. ... ity&y=2019
Locked
