Slackware 13.37 (rcX --> final)
Post Napisano: 09 Mar 2011, 19:54
Zvanicno stigao i RC1 za sledece stabilno izdanje
Wed Mar 9 05:52:06 UTC 2011
Hey folks, I think it's time for Slackware 13.37 (hopefully this helps
make up for our lack of code names) release candidate 1!
After a lot of testing and consideration, we've decided to go with the
recently released 2.6.37.3 Linux kernel which seems to work best for X,
contains support for Speakup, and looks like a better kernel branch to
be using as we move forward.
Please test so we can have a stable release soon. :-)
Moze se videti u ChangeLog-u
Post Napisano: 16 Mar 2011, 09:02
Novosti  :)
Wed Mar 16 06:20:03 UTC 2011
Slackware 13.37 release candidate 2 is ready for testing.
Are we almost there?
a/aaa_elflibs-13.37-i486-2.txz: Rebuilt.
a/glibc-solibs-2.13-i486-3.txz: Rebuilt.
a/glibc-zoneinfo-2.13-noarch-3.txz: Rebuilt.
      Upgraded to tzcode2011d and tzdata2011d.
a/kernel-firmware-2.6.37.4-noarch-1.txz: Upgraded.
a/kernel-generic-2.6.37.4-i486-1.txz: Upgraded.
a/kernel-generic-smp-2.6.37.4_smp-i686-1.txz: Upgraded.
a/kernel-huge-2.6.37.4-i486-1.txz: Upgraded.
a/kernel-huge-smp-2.6.37.4_smp-i686-1.txz: Upgraded.
a/kernel-modules-2.6.37.4-i486-1.txz: Upgraded.
a/kernel-modules-smp-2.6.37.4_smp-i686-1.txz: Upgraded.
ap/lxc-0.7.4-i486-2.txz: Rebuilt.
      Rebuilt with --localstatedir=/var and added /var/lib/lxc.
      Thanks to Audrius Kazukauskas.
ap/mc-4.7.5.1-i486-2.txz: Rebuilt.
      Fixed smb (cifs?) filesystem ./configure options.
      Thanks to Ferenc Deak.
d/kernel-headers-2.6.37.4_smp-x86-1.txz: Upgraded.
k/kernel-source-2.6.37.4_smp-noarch-1.txz: Upgraded.
l/gamin-0.1.10-i486-3.txz: Rebuilt.
      Install a /etc/gamin/gaminrc with reasonable defaults.
      Thanks to Niels Horn.
l/glib2-2.28.3-i486-1.txz: Upgraded.
l/glibc-2.13-i486-3.txz: Rebuilt.
l/glibc-i18n-2.13-i486-3.txz: Rebuilt.
l/glibc-profile-2.13-i486-3.txz: Rebuilt.
l/gtk+2-2.24.3-i486-1.txz: Upgraded.
n/dnsmasq-2.57-i486-1.txz: Upgraded.
n/iproute2-2.6.37-i486-1.txz: Upgraded.
x/mesa-7.9.2-i486-1.txz: Upgraded.
xap/xlockmore-5.32-i486-1.txz: Upgraded.
xap/xscreensaver-5.12-i486-1.txz: Upgraded.
extra/linux-2.6.37.4-nosmp-sdk/*: Upgraded.
isolinux/initrd.img: Rebuilt.
kernels/*: Upgraded.
http://www.slackware.com/changelog/current.php?cpu=i386
Post Napisano: 17 Mar 2011, 02:22
Maločas završio instalaciju Slackware64 current -a, jutros dovukao sve datoteke sa mirror-a i napravio iso DVD. Prilično sveže, ali sam očigledno zakasnio sveka par časova za RC, tako da je kernel 2.6.37.3. Eh, Marfi forever  :) Inače na mašini imam i openSUSE 11.4 i mada sam ga tek juče instalirao mogu da pohvalim da je značajno unapređenje u odnosu na 11.3, između ostalog dolazi sa KDE 4.6. Trenutni Slackware, kao i obično, kasni sa KDE apdejtom, mada se 4.6 može naći na AlienBOB-ovom mirror-u.
Post Napisano: 17 Mar 2011, 14:05
Jako brzo, posle samo nedelju dana, dobili smo i drugog kadidata za narednu stabilnu verziju Slackware Linux.
Ovaj kandidat nam dolazi sa Linux jezgreom verzije 2.6.37.4 i podverzije 1.6.16.
Tu su još, Pidgin 2.7.11, Emacs 23.3, Audacious 2.4.4 i mnoštvo ispravljenih bagova u odnosu na RC1.
Complete changelog :
Screenshot:
Home Page:
Documentation:
http://slackbook.org/
Download:
http://ftp.df.lth.se/pub/slackware/slac ... 11-DVD.iso
http://ftp.slackware.no/slackware/slack ... 11-DVD.iso
Prepravio drugi link na http:// (ne znam zasto bar kod mene je dodavao pre ftp://.... i http://ftp://.... pa je pravio problem (verovatno je bolje koristiti *url][/url])
Post Napisano: 17 Mar 2011, 16:33
Evo i ja da dodam, sigurno sam vec pisao.
Uvek svezi -current ISO
Promenio i naslov teme, ovako izgleda bolje (bar se meni tako cini), prihvatam i druge predloge  :grin:
Post Napisano: 17 Mar 2011, 18:28
Ja uvek sam pravim iso current-a na osnovu datoteka koje sam dovukao sa zvaničnog ftp -a. To radim pre svega jer na taj način izbegavam dovlačenje source grane, te je moj download lakši za par gigabajta. :) Drugi razlog je što mogu da uradim md5sum svake dovučene datoteke (md5sum -c CHECKSUMS.md5 | less). Iso pravim kao što je preporučeno na slackware-ovom mirror-u, pokretanjem programa mkisofs u direktorijumu u kome su dovučene datoteke:
mkisofs -o /tmp/slackware-dvd.iso \
  -R -J -A "Slackware Install" \
  -hide-rr-moved \
  -v -d -N \
  -no-emul-boot -boot-load-size 4 -boot-info-table \
  -sort isolinux/iso.sort \
  -b isolinux/isolinux.bin \
  -c isolinux/isolinux.boot \
  -V "SlackDVD" .
Post Napisano: 17 Mar 2011, 18:51
I ovi ISO image-i ne sadrze source/  ~1.9GiB.
Ja iskreno nisam nikad pravio sam :(  (verujem u alienBOB-a  :grin: )
Post Napisano: 17 Mar 2011, 23:04
Evo da prijavim 13.37 rc2 stabilan i pouzdan  :grin:  (bar tako meni izgleda)
KDE jeste nesto stariji, ali fino radi, najvise me raduje FF4 kome su konacno dodate neke sitnice koje su super
Post Napisano: 18 Mar 2011, 00:31
I kod mene je prilično stabilan...samo jedno me pomalo nervira...dešava mi se da crashuje flash plugin na ff4 64bit...konqueror rai odlično na yt, ali ff4 zakuca ako se otvore dva taba na yt...ali to je problem do ff4 (koji je inače u testing-u) a ne slackware-a :)
Post Napisano: 18 Mar 2011, 01:04
E video sam da je iso sa linka isto bez source-a. I takođe ne sumnjam da je AlienBOB napravio odličan image. ;) Ja već neko vreme furam 64bit Slackware, veoma mi je zgodan jer mnogi programi koje koristim zahtvevaju 64bit okruženje, npr. Chimera koja je zanimljiv bioinformatički program ima i 32bit i 64bit verziju, ali 64bitna verzija je jedina primenljiva u istraživačkom radu jer može da mapira u memoriji veoma dugačke genomske sekvence koje u memoriji računara zauzimaju više od 2GiB. MGLTools i GlycoWorkbench su slični primeri. No da ne idem u off-topic :)
Ja sam imao isti problem sa flash-om u prethodnoj instalaciji koja je bila multilib (samo zbog Skype-a), ali je falsh-plugin bio 64bit. Trenutno još uvek nisam odlučio da li će i nova instalacija biti multilib, tako da je sistem zasada full 64bit ali problem i dalje postoji, mislim da vredi pokušati sa 32bit pluginom na multilib-u, videću ako uspe pustiću na forum svakako. :)
Firefox 4 RC1 je odličan! Izuzetno brz i pouzdan.
