Novosti u *current* -u
Post Napisano: 18 Sep 2021, 17:39
Slackware 64-bit
Fri Sep 17 17:22:57 UTC 2021
kde/plasma-workspace-5.22.5-x86_64-2.txz: Rebuilt.
       Patched to fix USB storage devices detected only once per session.
       Thanks to ctrlaltca.
n/NetworkManager-1.32.10-x86_64-4.txz: Rebuilt.
       Patched to shut down dhcpcd gracefully, and restored dhcpcd as the default
       client when using NetworkManager on Slackware. In this case I'll swim
       upstream if it means better security. Who knows what your DHCP server might
       attempt when it comes to public WiFi? :-)
       Thanks to Roy Marples and marav.
n/gnupg2-2.2.31-x86_64-1.txz: Upgraded.
xap/pidgin-2.14.7-x86_64-1.txz: Upgraded.
Fri Sep 17 04:17:57 UTC 2021
a/cryptsetup-2.4.1-x86_64-1.txz: Upgraded.
a/sysvinit-scripts-15.0-noarch-5.txz: Rebuilt.
       Stop D-Bus after NFS partitions are unmounted to avoid a hang.
       Thanks to vulcan59 and bassmadrigal.
ap/sudo-1.9.8p1-x86_64-1.txz: Upgraded.
l/fftw-3.3.10-x86_64-1.txz: Upgraded.
l/libxkbcommon-1.3.1-x86_64-1.txz: Upgraded.
l/pipewire-0.3.36-x86_64-1.txz: Upgraded.
n/dhcpcd-9.4.0-x86_64-2.txz: Rebuilt.
       Applied upstream patch:
       DHCP6: Only send FQDN for SOLICIT, REQUEST, RENEW, or REBIND messages.
       Thanks to marav.
n/httpd-2.4.49-x86_64-1.txz: Upgraded.
       mod_proxy: Server Side Request Forgery (SSRF) vulnerabilty [Yann Ylavic]
       core: ap_escape_quotes buffer overflow
       mod_proxy_uwsgi: Out of bound read vulnerability [Yann Ylavic]
       core: null pointer dereference on malformed request
       mod_http2: Request splitting vulnerability with mod_proxy [Stefan Eissing]
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-40438
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-39275
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-36160
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-34798
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-33193
x/ibus-libpinyin-1.12.1-x86_64-1.txz: Upgraded.
x/libpinyin-2.6.1-x86_64-1.txz: Upgraded.
xap/mozilla-thunderbird-91.1.1-x86_64-1.txz: Upgraded.
       This is a bugfix release.
       https://www.mozilla.org/en-US/thunderbird/91.1.1/releasenotes/
Thu Sep 16 18:33:01 UTC 2021
a/kernel-generic-5.14.5-x86_64-1.txz: Upgraded.
a/kernel-huge-5.14.5-x86_64-1.txz: Upgraded.
a/kernel-modules-5.14.5-x86_64-1.txz: Upgraded.
d/kernel-headers-5.14.5-x86-1.txz: Upgraded.
k/kernel-source-5.14.5-noarch-1.txz: Upgraded.
isolinux/initrd.img: Rebuilt.
kernels/*: Upgraded.
Thu Sep 16 02:52:54 UTC 2021
a/etc-15.0-x86_64-17.txz: Rebuilt.
       Added named:named (53:53) user and group.
a/kernel-firmware-20210915_198ac65-noarch-1.txz: Upgraded.
a/kernel-generic-5.14.4-x86_64-1.txz: Upgraded.
a/kernel-huge-5.14.4-x86_64-1.txz: Upgraded.
a/kernel-modules-5.14.4-x86_64-1.txz: Upgraded.
ap/sudo-1.9.8-x86_64-1.txz: Upgraded.
d/kernel-headers-5.14.4-x86-1.txz: Upgraded.
k/kernel-source-5.14.4-noarch-1.txz: Upgraded.
kde/breeze-icons-5.85.0-noarch-2.txz: Rebuilt.
       Patched with upstream commit to allow using this icon theme with Xfce.
l/fluidsynth-2.2.3-x86_64-1.txz: Upgraded.
l/python-charset-normalizer-2.0.5-x86_64-1.txz: Upgraded.
l/qca-2.3.4-x86_64-1.txz: Upgraded.
n/NetworkManager-1.32.10-x86_64-3.txz: Rebuilt.
       Switch to dhcp=internal to avoid problems swimming upstream.
       For those looking for a fix to continue using dhcpcd, a PRIVSEP build
       variable was added to the SlackBuild, and you may produce a fully
       NetworkManager compatible dhcpcd package with this command:
       PRIVSEP=no ./dhcpcd.SlackBuild
       Privilege separation remains the dhcpcd package default as we don't want
       to weaken security for those using rc.inet1 along with dhcpcd.
       Some additional comments about this were added to 00-dhcp-client.conf
       mentioning this and the workaround of killing dhcpcd manually when
       resuming with the stock dhcpcd package.
n/bind-9.16.21-x86_64-1.txz: Upgraded.
       Fixed call to rndc-confgen in the install script.
       Make /etc/rndc.key owned by named:named.
       Run named as named:named by default (configurable in /etc/default/named).
       rc.bind: chown /run/named and /var/named to configured user:group.
       Thanks to Ressy for prompting this cleanup. :)
n/curl-7.79.0-x86_64-1.txz: Upgraded.
       clear the leftovers pointer when sending succeeds.
       do not ignore --ssl-reqd.
       reject STARTTLS server response pipelining.
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-22945
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-22946
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-22947
n/links-2.24-x86_64-1.txz: Upgraded.
n/wireguard-tools-1.0.20210914-x86_64-1.txz: Upgraded.
x/libinput-1.19.0-x86_64-1.txz: Upgraded.
xap/gimp-2.10.28-x86_64-1.txz: Upgraded.
Mon Sep 13 18:04:35 UTC 2021
a/btrfs-progs-5.14-x86_64-1.txz: Upgraded.
a/kernel-firmware-20210912_7160358-noarch-1.txz: Upgraded.
a/kernel-generic-5.14.3-x86_64-1.txz: Upgraded.
a/kernel-huge-5.14.3-x86_64-1.txz: Upgraded.
a/kernel-modules-5.14.3-x86_64-1.txz: Upgraded.
ap/vim-8.2.3435-x86_64-1.txz: Upgraded.
d/bison-3.8.1-x86_64-1.txz: Upgraded.
d/ccache-4.4.1-x86_64-1.txz: Upgraded.
d/gdb-11.1-x86_64-1.txz: Upgraded.
d/kernel-headers-5.14.3-x86-1.txz: Upgraded.
k/kernel-source-5.14.3-noarch-1.txz: Upgraded.
kde/latte-dock-0.10.2-x86_64-1.txz: Upgraded.
l/gd-2.3.3-x86_64-1.txz: Upgraded.
l/imagemagick-7.1.0_7-x86_64-1.txz: Upgraded.
l/libedit-20210910_3.1-x86_64-1.txz: Upgraded.
l/libexif-0.6.23-x86_64-1.txz: Upgraded.
l/pango-1.48.10-x86_64-1.txz: Upgraded.
n/NetworkManager-1.32.10-x86_64-2.txz: Rebuilt.
       00-dhcp-client.conf: Add the --noconfigure option to dhcpcd, or else the
       network won't return after suspend/resume. Thanks to marav.
n/ethtool-5.14-x86_64-1.txz: Upgraded.
n/mutt-2.1.3-x86_64-1.txz: Upgraded.
n/wget2-2.0.0-x86_64-1.txz: Added.
xap/vim-gvim-8.2.3435-x86_64-1.txz: Upgraded.
xfce/thunar-4.16.9-x86_64-1.txz: Upgraded.
Slackware 32-bit
kde/plasma-workspace-5.22.5-i586-2.txz: Rebuilt.
n/NetworkManager-1.32.10-i586-4.txz: Rebuilt.
n/gnupg2-2.2.31-i586-1.txz: Upgraded.
xap/pidgin-2.14.7-i586-1.txz: Upgraded.
a/cryptsetup-2.4.1-i586-1.txz: Upgraded.
ap/sudo-1.9.8p1-i586-1.txz: Upgraded.
l/fftw-3.3.10-i586-1.txz: Upgraded.
l/libxkbcommon-1.3.1-i586-1.txz: Upgraded.
l/pipewire-0.3.36-i586-1.txz: Upgraded.
n/dhcpcd-9.4.0-i586-2.txz: Rebuilt.
       Thanks to marav.
n/httpd-2.4.49-i586-1.txz: Upgraded.
x/ibus-libpinyin-1.12.1-i586-1.txz: Upgraded.
x/libpinyin-2.6.1-i586-1.txz: Upgraded.
xap/mozilla-thunderbird-91.1.1-i686-1.txz: Upgraded.
a/kernel-generic-5.14.5-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.14.5_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.14.5-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.14.5_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.14.5-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.14.5_smp-i686-1.txz: Upgraded.
d/kernel-headers-5.14.5_smp-x86-1.txz: Upgraded.
k/kernel-source-5.14.5_smp-noarch-1.txz: Upgraded.
extra/linux-5.14.5-nosmp-sdk/*: Upgraded.
a/etc-15.0-i586-17.txz: Rebuilt.
a/kernel-generic-5.14.4-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.14.4_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.14.4-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.14.4_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.14.4-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.14.4_smp-i686-1.txz: Upgraded.
ap/sudo-1.9.8-i586-1.txz: Upgraded.
d/kernel-headers-5.14.4_smp-x86-1.txz: Upgraded.
k/kernel-source-5.14.4_smp-noarch-1.txz: Upgraded.
l/fluidsynth-2.2.3-i586-1.txz: Upgraded.
l/python-charset-normalizer-2.0.5-i586-1.txz: Upgraded.
l/qca-2.3.4-i586-1.txz: Upgraded.
n/NetworkManager-1.32.10-i586-3.txz: Rebuilt.
n/bind-9.16.21-i586-1.txz: Upgraded.
n/curl-7.79.0-i586-1.txz: Upgraded.
n/links-2.24-i586-1.txz: Upgraded.
n/wireguard-tools-1.0.20210914-i586-1.txz: Upgraded.
x/libinput-1.19.0-i586-1.txz: Upgraded.
xap/gimp-2.10.28-i586-1.txz: Upgraded.
extra/linux-5.14.4-nosmp-sdk/*: Upgraded.
a/btrfs-progs-5.14-i586-1.txz: Upgraded.
a/kernel-generic-5.14.3-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.14.3_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.14.3-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.14.3_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.14.3-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.14.3_smp-i686-1.txz: Upgraded.
ap/vim-8.2.3435-i586-1.txz: Upgraded.
d/bison-3.8.1-i586-1.txz: Upgraded.
d/ccache-4.4.1-i586-1.txz: Upgraded.
d/gdb-11.1-i586-1.txz: Upgraded.
d/kernel-headers-5.14.3_smp-x86-1.txz: Upgraded.
k/kernel-source-5.14.3_smp-noarch-1.txz: Upgraded.
kde/latte-dock-0.10.2-i586-1.txz: Upgraded.
l/gd-2.3.3-i586-1.txz: Upgraded.
l/imagemagick-7.1.0_7-i586-1.txz: Upgraded.
l/libedit-20210910_3.1-i586-1.txz: Upgraded.
l/libexif-0.6.23-i586-1.txz: Upgraded.
l/pango-1.48.10-i586-1.txz: Upgraded.
n/NetworkManager-1.32.10-i586-2.txz: Rebuilt.
n/ethtool-5.14-i586-1.txz: Upgraded.
n/mutt-2.1.3-i586-1.txz: Upgraded.
n/wget2-2.0.0-i586-1.txz: Added.
xap/vim-gvim-8.2.3435-i586-1.txz: Upgraded.
xfce/thunar-4.16.9-i586-1.txz: Upgraded.
extra/linux-5.14.3-nosmp-sdk/*: Upgraded.
Post Napisano: 20 Sep 2021, 21:25
Slackware 64-bit
Mon Sep 20 18:49:19 UTC 2021
a/acpid-2.0.33-x86_64-1.txz: Upgraded.
n/nghttp2-1.45.0-x86_64-1.txz: Upgraded.
n/samba-4.15.0-x86_64-1.txz: Upgraded.
x/libXi-1.8-x86_64-1.txz: Upgraded.
x/libva-2.13.0-x86_64-1.txz: Upgraded.
       Build with enable_va_messaging=false to avoid console spam. Thanks to GazL.
x/wayland-protocols-1.23-noarch-1.txz: Upgraded.
x/xf86-input-libinput-1.2.0-x86_64-1.txz: Upgraded.
x/xorgproto-2021.5-x86_64-1.txz: Upgraded.
xap/pan-0.147-x86_64-1.txz: Upgraded.
Sun Sep 19 18:57:24 UTC 2021
a/kernel-firmware-20210919_d526e04-noarch-1.txz: Upgraded.
l/gd-2.3.3-x86_64-2.txz: Rebuilt.
       Applied upstream patch to restore macros used while building PHP.
       Thanks to nobodino.
l/gjs-1.68.4-x86_64-1.txz: Upgraded.
l/imagemagick-7.1.0_8-x86_64-1.txz: Upgraded.
l/python-charset-normalizer-2.0.6-x86_64-1.txz: Upgraded.
xfce/xfce4-whiskermenu-plugin-2.6.0-x86_64-1.txz: Upgraded.
Sun Sep 19 00:13:58 UTC 2021
a/kernel-generic-5.14.6-x86_64-1.txz: Upgraded.
a/kernel-huge-5.14.6-x86_64-1.txz: Upgraded.
a/kernel-modules-5.14.6-x86_64-1.txz: Upgraded.
ap/mpg123-1.29.0-x86_64-2.txz: Rebuilt.
       Add ../lib64/mpg123 to the module search path. Thanks to Pithium.
d/kernel-headers-5.14.6-x86-1.txz: Upgraded.
k/kernel-source-5.14.6-noarch-1.txz: Upgraded.
       PINCTRL_CANNONLAKE n -> m
       Thanks to bassmadrigal.
kde/kstars-3.5.5-x86_64-1.txz: Upgraded.
l/libcap-2.58-x86_64-1.txz: Upgraded.
n/bind-9.16.21-x86_64-2.txz: Rebuilt.
       rc.bind: make sure /etc/rndc.key has correct ownership. Thanks to marav.
xfce/thunar-4.16.10-x86_64-1.txz: Upgraded.
Slackware 32-bit
a/acpid-2.0.33-i586-1.txz: Upgraded.
n/nghttp2-1.45.0-i586-1.txz: Upgraded.
n/samba-4.15.0-i586-1.txz: Upgraded.
x/libXi-1.8-i586-1.txz: Upgraded.
x/libva-2.13.0-i586-1.txz: Upgraded.
x/xf86-input-libinput-1.2.0-i586-1.txz: Upgraded.
x/xorgproto-2021.5-i586-1.txz: Upgraded.
xap/pan-0.147-i586-1.txz: Upgraded.
l/gd-2.3.3-i586-2.txz: Rebuilt.
       Thanks to nobodino.
l/gjs-1.68.4-i586-1.txz: Upgraded.
l/imagemagick-7.1.0_8-i586-1.txz: Upgraded.
l/python-charset-normalizer-2.0.6-i586-1.txz: Upgraded.
xfce/xfce4-whiskermenu-plugin-2.6.0-i586-1.txz: Upgraded.
a/kernel-generic-5.14.6-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.14.6_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.14.6-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.14.6_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.14.6-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.14.6_smp-i686-1.txz: Upgraded.
ap/mpg123-1.29.0-i586-2.txz: Rebuilt.
d/kernel-headers-5.14.6_smp-x86-1.txz: Upgraded.
k/kernel-source-5.14.6_smp-noarch-1.txz: Upgraded.
kde/kstars-3.5.5-i586-1.txz: Upgraded.
l/libcap-2.58-i586-1.txz: Upgraded.
n/bind-9.16.21-i586-2.txz: Rebuilt.
xfce/thunar-4.16.10-i586-1.txz: Upgraded.
extra/linux-5.14.6-nosmp-sdk/*: Upgraded.
Post Napisano: 23 Sep 2021, 20:19
Slackware 64-bit
Wed Sep 22 18:45:12 UTC 2021
a/kernel-generic-5.14.7-x86_64-1.txz: Upgraded.
a/kernel-huge-5.14.7-x86_64-1.txz: Upgraded.
a/kernel-modules-5.14.7-x86_64-1.txz: Upgraded.
ap/sudo-1.9.8p2-x86_64-1.txz: Upgraded.
d/kernel-headers-5.14.7-x86-1.txz: Upgraded.
d/python-setuptools-58.1.0-x86_64-1.txz: Upgraded.
k/kernel-source-5.14.7-noarch-1.txz: Upgraded.
l/neon-0.32.1-x86_64-1.txz: Upgraded.
n/ca-certificates-20210922-noarch-1.txz: Upgraded.
n/curl-7.79.1-x86_64-1.txz: Upgraded.
n/nghttp2-1.45.1-x86_64-1.txz: Upgraded.
x/xterm-369-x86_64-1.txz: Upgraded.
Tue Sep 21 18:03:27 UTC 2021
a/btrfs-progs-5.14.1-x86_64-1.txz: Upgraded.
a/sysvinit-3.00-x86_64-1.txz: Upgraded.
ap/htop-3.1.0-x86_64-1.txz: Upgraded.
d/cmake-3.21.3-x86_64-1.txz: Upgraded.
kde/attica-5.86.0-x86_64-1.txz: Upgraded.
kde/baloo-5.86.0-x86_64-1.txz: Upgraded.
kde/bluez-qt-5.86.0-x86_64-1.txz: Upgraded.
kde/breeze-icons-5.86.0-noarch-1.txz: Upgraded.
kde/extra-cmake-modules-5.86.0-x86_64-1.txz: Upgraded.
kde/frameworkintegration-5.86.0-x86_64-1.txz: Upgraded.
kde/kactivities-5.86.0-x86_64-1.txz: Upgraded.
kde/kactivities-stats-5.86.0-x86_64-1.txz: Upgraded.
kde/kapidox-5.86.0-x86_64-1.txz: Upgraded.
kde/karchive-5.86.0-x86_64-1.txz: Upgraded.
kde/kauth-5.86.0-x86_64-1.txz: Upgraded.
kde/kbookmarks-5.86.0-x86_64-1.txz: Upgraded.
kde/kcalendarcore-5.86.0-x86_64-1.txz: Upgraded.
kde/kcmutils-5.86.0-x86_64-1.txz: Upgraded.
kde/kcodecs-5.86.0-x86_64-1.txz: Upgraded.
kde/kcompletion-5.86.0-x86_64-1.txz: Upgraded.
kde/kconfig-5.86.0-x86_64-1.txz: Upgraded.
kde/kconfigwidgets-5.86.0-x86_64-1.txz: Upgraded.
kde/kcontacts-5.86.0-x86_64-1.txz: Upgraded.
kde/kcoreaddons-5.86.0-x86_64-1.txz: Upgraded.
kde/kcrash-5.86.0-x86_64-1.txz: Upgraded.
kde/kdav-5.86.0-x86_64-1.txz: Upgraded.
kde/kdbusaddons-5.86.0-x86_64-1.txz: Upgraded.
kde/kdeclarative-5.86.0-x86_64-1.txz: Upgraded.
kde/kded-5.86.0-x86_64-1.txz: Upgraded.
kde/kdelibs4support-5.86.0-x86_64-1.txz: Upgraded.
kde/kdesignerplugin-5.86.0-x86_64-1.txz: Upgraded.
kde/kdesu-5.86.0-x86_64-1.txz: Upgraded.
kde/kdewebkit-5.86.0-x86_64-1.txz: Upgraded.
kde/kdnssd-5.86.0-x86_64-1.txz: Upgraded.
kde/kdoctools-5.86.0-x86_64-1.txz: Upgraded.
kde/kemoticons-5.86.0-x86_64-1.txz: Upgraded.
kde/kfilemetadata-5.86.0-x86_64-1.txz: Upgraded.
kde/kglobalaccel-5.86.0-x86_64-1.txz: Upgraded.
kde/kguiaddons-5.86.0-x86_64-1.txz: Upgraded.
kde/kholidays-5.86.0-x86_64-1.txz: Upgraded.
kde/khtml-5.86.0-x86_64-1.txz: Upgraded.
kde/ki18n-5.86.0-x86_64-1.txz: Upgraded.
kde/kiconthemes-5.86.0-x86_64-1.txz: Upgraded.
kde/kidletime-5.86.0-x86_64-1.txz: Upgraded.
kde/kimageformats-5.86.0-x86_64-1.txz: Upgraded.
kde/kinit-5.86.0-x86_64-1.txz: Upgraded.
kde/kio-5.86.0-x86_64-1.txz: Upgraded.
kde/kirigami2-5.86.0-x86_64-1.txz: Upgraded.
kde/kitemmodels-5.86.0-x86_64-1.txz: Upgraded.
kde/kitemviews-5.86.0-x86_64-1.txz: Upgraded.
kde/kjobwidgets-5.86.0-x86_64-1.txz: Upgraded.
kde/kjs-5.86.0-x86_64-1.txz: Upgraded.
kde/kjsembed-5.86.0-x86_64-1.txz: Upgraded.
kde/kmediaplayer-5.86.0-x86_64-1.txz: Upgraded.
kde/knewstuff-5.86.0-x86_64-1.txz: Upgraded.
kde/knotifications-5.86.0-x86_64-1.txz: Upgraded.
kde/knotifyconfig-5.86.0-x86_64-1.txz: Upgraded.
kde/kpackage-5.86.0-x86_64-1.txz: Upgraded.
kde/kparts-5.86.0-x86_64-1.txz: Upgraded.
kde/kpeople-5.86.0-x86_64-1.txz: Upgraded.
kde/kplotting-5.86.0-x86_64-1.txz: Upgraded.
kde/kpty-5.86.0-x86_64-1.txz: Upgraded.
kde/kquickcharts-5.86.0-x86_64-1.txz: Upgraded.
kde/kross-5.86.0-x86_64-1.txz: Upgraded.
kde/krunner-5.86.0-x86_64-1.txz: Upgraded.
kde/kservice-5.86.0-x86_64-1.txz: Upgraded.
kde/ktexteditor-5.86.0-x86_64-1.txz: Upgraded.
kde/ktextwidgets-5.86.0-x86_64-1.txz: Upgraded.
kde/kunitconversion-5.86.0-x86_64-1.txz: Upgraded.
kde/kwallet-5.86.0-x86_64-1.txz: Upgraded.
kde/kwayland-5.86.0-x86_64-1.txz: Upgraded.
kde/kwidgetsaddons-5.86.0-x86_64-1.txz: Upgraded.
kde/kwindowsystem-5.86.0-x86_64-1.txz: Upgraded.
kde/kxmlgui-5.86.0-x86_64-1.txz: Upgraded.
kde/kxmlrpcclient-5.86.0-x86_64-1.txz: Upgraded.
kde/modemmanager-qt-5.86.0-x86_64-1.txz: Upgraded.
kde/networkmanager-qt-5.86.0-x86_64-1.txz: Upgraded.
kde/oxygen-icons5-5.86.0-noarch-1.txz: Upgraded.
kde/plasma-framework-5.86.0-x86_64-1.txz: Upgraded.
kde/prison-5.86.0-x86_64-1.txz: Upgraded.
kde/purpose-5.86.0-x86_64-1.txz: Upgraded.
kde/qqc2-desktop-style-5.86.0-x86_64-1.txz: Upgraded.
kde/solid-5.86.0-x86_64-1.txz: Upgraded.
kde/sonnet-5.86.0-x86_64-1.txz: Upgraded.
kde/syndication-5.86.0-x86_64-1.txz: Upgraded.
kde/syntax-highlighting-5.86.0-x86_64-1.txz: Upgraded.
kde/threadweaver-5.86.0-x86_64-1.txz: Upgraded.
l/neon-0.32.0-x86_64-1.txz: Upgraded.
n/alpine-2.25-x86_64-1.txz: Upgraded.
       Fixed a denial-of-service security issue where untagged responses from an
       IMAP server are accepted before STARTTLS.
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-38370
n/fetchmail-6.4.22-x86_64-1.txz: Upgraded.
x/libva-2.13.0-x86_64-2.txz: Rebuilt.
       Instead of disabling messaging entirely, add an /etc/libva.conf that sets it
       to a medium level and can be adjusted by the user. Thanks to Markus Wiesner.
x/mesa-21.2.2-x86_64-1.txz: Upgraded.
Slackware 32-bit
a/kernel-generic-5.14.7-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.14.7_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.14.7-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.14.7_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.14.7-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.14.7_smp-i686-1.txz: Upgraded.
ap/sudo-1.9.8p2-i586-1.txz: Upgraded.
d/kernel-headers-5.14.7_smp-x86-1.txz: Upgraded.
d/python-setuptools-58.1.0-i586-1.txz: Upgraded.
k/kernel-source-5.14.7_smp-noarch-1.txz: Upgraded.
l/neon-0.32.1-i586-1.txz: Upgraded.
n/curl-7.79.1-i586-1.txz: Upgraded.
n/nghttp2-1.45.1-i586-1.txz: Upgraded.
x/xterm-369-i586-1.txz: Upgraded.
extra/linux-5.14.7-nosmp-sdk/*: Upgraded.
a/btrfs-progs-5.14.1-i586-1.txz: Upgraded.
a/sysvinit-3.00-i586-1.txz: Upgraded.
ap/htop-3.1.0-i586-1.txz: Upgraded.
d/cmake-3.21.3-i586-1.txz: Upgraded.
kde/attica-5.86.0-i586-1.txz: Upgraded.
kde/baloo-5.86.0-i586-1.txz: Upgraded.
kde/bluez-qt-5.86.0-i586-1.txz: Upgraded.
kde/extra-cmake-modules-5.86.0-i586-1.txz: Upgraded.
kde/frameworkintegration-5.86.0-i586-1.txz: Upgraded.
kde/kactivities-5.86.0-i586-1.txz: Upgraded.
kde/kactivities-stats-5.86.0-i586-1.txz: Upgraded.
kde/kapidox-5.86.0-i586-1.txz: Upgraded.
kde/karchive-5.86.0-i586-1.txz: Upgraded.
kde/kauth-5.86.0-i586-1.txz: Upgraded.
kde/kbookmarks-5.86.0-i586-1.txz: Upgraded.
kde/kcalendarcore-5.86.0-i586-1.txz: Upgraded.
kde/kcmutils-5.86.0-i586-1.txz: Upgraded.
kde/kcodecs-5.86.0-i586-1.txz: Upgraded.
kde/kcompletion-5.86.0-i586-1.txz: Upgraded.
kde/kconfig-5.86.0-i586-1.txz: Upgraded.
kde/kconfigwidgets-5.86.0-i586-1.txz: Upgraded.
kde/kcontacts-5.86.0-i586-1.txz: Upgraded.
kde/kcoreaddons-5.86.0-i586-1.txz: Upgraded.
kde/kcrash-5.86.0-i586-1.txz: Upgraded.
kde/kdav-5.86.0-i586-1.txz: Upgraded.
kde/kdbusaddons-5.86.0-i586-1.txz: Upgraded.
kde/kdeclarative-5.86.0-i586-1.txz: Upgraded.
kde/kded-5.86.0-i586-1.txz: Upgraded.
kde/kdelibs4support-5.86.0-i586-1.txz: Upgraded.
kde/kdesignerplugin-5.86.0-i586-1.txz: Upgraded.
kde/kdesu-5.86.0-i586-1.txz: Upgraded.
kde/kdewebkit-5.86.0-i586-1.txz: Upgraded.
kde/kdnssd-5.86.0-i586-1.txz: Upgraded.
kde/kdoctools-5.86.0-i586-1.txz: Upgraded.
kde/kemoticons-5.86.0-i586-1.txz: Upgraded.
kde/kfilemetadata-5.86.0-i586-1.txz: Upgraded.
kde/kglobalaccel-5.86.0-i586-1.txz: Upgraded.
kde/kguiaddons-5.86.0-i586-1.txz: Upgraded.
kde/kholidays-5.86.0-i586-1.txz: Upgraded.
kde/khtml-5.86.0-i586-1.txz: Upgraded.
kde/ki18n-5.86.0-i586-1.txz: Upgraded.
kde/kiconthemes-5.86.0-i586-1.txz: Upgraded.
kde/kidletime-5.86.0-i586-1.txz: Upgraded.
kde/kimageformats-5.86.0-i586-1.txz: Upgraded.
kde/kinit-5.86.0-i586-1.txz: Upgraded.
kde/kio-5.86.0-i586-1.txz: Upgraded.
kde/kirigami2-5.86.0-i586-1.txz: Upgraded.
kde/kitemmodels-5.86.0-i586-1.txz: Upgraded.
kde/kitemviews-5.86.0-i586-1.txz: Upgraded.
kde/kjobwidgets-5.86.0-i586-1.txz: Upgraded.
kde/kjs-5.86.0-i586-1.txz: Upgraded.
kde/kjsembed-5.86.0-i586-1.txz: Upgraded.
kde/kmediaplayer-5.86.0-i586-1.txz: Upgraded.
kde/knewstuff-5.86.0-i586-1.txz: Upgraded.
kde/knotifications-5.86.0-i586-1.txz: Upgraded.
kde/knotifyconfig-5.86.0-i586-1.txz: Upgraded.
kde/kpackage-5.86.0-i586-1.txz: Upgraded.
kde/kparts-5.86.0-i586-1.txz: Upgraded.
kde/kpeople-5.86.0-i586-1.txz: Upgraded.
kde/kplotting-5.86.0-i586-1.txz: Upgraded.
kde/kpty-5.86.0-i586-1.txz: Upgraded.
kde/kquickcharts-5.86.0-i586-1.txz: Upgraded.
kde/kross-5.86.0-i586-1.txz: Upgraded.
kde/krunner-5.86.0-i586-1.txz: Upgraded.
kde/kservice-5.86.0-i586-1.txz: Upgraded.
kde/ktexteditor-5.86.0-i586-1.txz: Upgraded.
kde/ktextwidgets-5.86.0-i586-1.txz: Upgraded.
kde/kunitconversion-5.86.0-i586-1.txz: Upgraded.
kde/kwallet-5.86.0-i586-1.txz: Upgraded.
kde/kwayland-5.86.0-i586-1.txz: Upgraded.
kde/kwidgetsaddons-5.86.0-i586-1.txz: Upgraded.
kde/kwindowsystem-5.86.0-i586-1.txz: Upgraded.
kde/kxmlgui-5.86.0-i586-1.txz: Upgraded.
kde/kxmlrpcclient-5.86.0-i586-1.txz: Upgraded.
kde/modemmanager-qt-5.86.0-i586-1.txz: Upgraded.
kde/networkmanager-qt-5.86.0-i586-1.txz: Upgraded.
kde/plasma-framework-5.86.0-i586-1.txz: Upgraded.
kde/prison-5.86.0-i586-1.txz: Upgraded.
kde/purpose-5.86.0-i586-1.txz: Upgraded.
kde/qqc2-desktop-style-5.86.0-i586-1.txz: Upgraded.
kde/solid-5.86.0-i586-1.txz: Upgraded.
kde/sonnet-5.86.0-i586-1.txz: Upgraded.
kde/syndication-5.86.0-i586-1.txz: Upgraded.
kde/syntax-highlighting-5.86.0-i586-1.txz: Upgraded.
kde/threadweaver-5.86.0-i586-1.txz: Upgraded.
l/neon-0.32.0-i586-1.txz: Upgraded.
n/alpine-2.25-i586-1.txz: Upgraded.
n/fetchmail-6.4.22-i586-1.txz: Upgraded.
x/libva-2.13.0-i586-2.txz: Rebuilt.
x/mesa-21.2.2-i586-1.txz: Upgraded.
Post Napisano: 27 Sep 2021, 09:02
Slackware 64-bit
Sun Sep 26 18:57:07 UTC 2021
a/kernel-generic-5.14.8-x86_64-1.txz: Upgraded.
a/kernel-huge-5.14.8-x86_64-1.txz: Upgraded.
a/kernel-modules-5.14.8-x86_64-1.txz: Upgraded.
ap/itstool-2.0.7-x86_64-1.txz: Upgraded.
d/kernel-headers-5.14.8-x86-1.txz: Upgraded.
k/kernel-source-5.14.8-noarch-1.txz: Upgraded.
l/libmtp-1.1.19-x86_64-1.txz: Upgraded.
n/getmail-6.18.4-x86_64-1.txz: Upgraded.
n/openssh-8.8p1-x86_64-1.txz: Upgraded.
       Please note "Potentially-incompatible changes" from the release notes:
       This release disables RSA signatures using the SHA-1 hash algorithm
       by default. This change has been made as the SHA-1 hash algorithm is
       cryptographically broken, and it is possible to create chosen-prefix
       hash collisions for <USD$50K [1]
       For most users, this change should be invisible and there is
       no need to replace ssh-rsa keys. OpenSSH has supported RFC8332
       RSA/SHA-256/512 signatures since release 7.2 and existing ssh-rsa keys
       will automatically use the stronger algorithm where possible.
       Incompatibility is more likely when connecting to older SSH
       implementations that have not been upgraded or have not closely tracked
       improvements in the SSH protocol. For these cases, it may be necessary
       to selectively re-enable RSA/SHA1 to allow connection and/or user
       authentication via the HostkeyAlgorithms and PubkeyAcceptedAlgorithms
       options. For example, the following stanza in ~/.ssh/config will enable
       RSA/SHA1 for host and user authentication for a single destination host:
       Host old-host
       HostkeyAlgorithms +ssh-rsa
       PubkeyAcceptedAlgorithms +ssh-rsa
       We recommend enabling RSA/SHA1 only as a stopgap measure until legacy
       implementations can be upgraded or reconfigured with another key type
       (such as ECDSA or Ed25519).
       [1] "SHA-1 is a Shambles: First Chosen-Prefix Collision on SHA-1 and
       Application to the PGP Web of Trust" Leurent, G and Peyrin, T
       (2020) https://eprint.iacr.org/2020/014.pdf
Sat Sep 25 19:32:08 UTC 2021
a/coreutils-9.0-x86_64-2.txz: Rebuilt.
       DIR_COLORS: Add support for .tzst, .zst, .flv, and .m2t extensions.
       Thanks to regdub.
a/elvis-2.2_0-x86_64-8.txz: Rebuilt.
       Removed elvis.clr.orig. Thanks to ctrlaltca.
d/bison-3.8.2-x86_64-1.txz: Upgraded.
d/meson-0.59.1-x86_64-1.txz: Upgraded.
d/subversion-1.14.1-x86_64-4.txz: Rebuilt.
       Added compile options --with-kwallet and --with-gnome-keyring (the latter was
       already used by default). Thanks to rsts and Windu.
kde/plasma-desktop-5.22.5-x86_64-2.txz: Rebuilt.
       Removed main.xml.orig. Thanks to ctrlaltca.
l/gst-plugins-bad-free-1.18.5-x86_64-1.txz: Added.
       These are the "bad" GStreamer plugins that have free enough licenses to ship.
       Thanks to Heinz Wiesinger.
l/gtk4-4.4.0-x86_64-1.txz: Upgraded.
l/libssh2-1.10.0-x86_64-1.txz: Upgraded.
n/lynx-2.9.0dev.9-x86_64-1.txz: Upgraded.
       Based on testing here, this seems stable enough to include. Please let me
       know if there are any new problems.
       lynx.cfg: Add ASSUME_CHARSET:utf-8. Thanks to usr345.
       Removed CHANGES.orig. Thanks to ctrlaltca.
xap/x3270-4.0ga14-x86_64-1.txz: Upgraded.
xap/xpdf-4.03-x86_64-3.txz: Rebuilt.
       Removed .orig files. Thanks to ctrlaltca.
Sat Sep 25 01:05:55 UTC 2021
a/coreutils-9.0-x86_64-1.txz: Upgraded.
       Thanks to GazL for pointing out where I needed to be looking in the code to
       stick with the traditional (for us, anyway) ls quoting style.
n/ca-certificates-20210924-noarch-1.txz: Upgraded.
       Removed DST_Root_CA_X3.crt.
n/cifs-utils-6.14-x86_64-1.txz: Upgraded.
Fri Sep 24 19:47:44 UTC 2021
l/fribidi-1.0.11-x86_64-1.txz: Upgraded.
l/harfbuzz-3.0.0-x86_64-1.txz: Upgraded.
n/bind-9.16.21-x86_64-3.txz: Rebuilt.
       Clean this up a little more... for consistency, make all three variables
       set in /etc/default/named start with NAMED_. Likewise, make sure that all
       uses of them in rc.bind start with NAMED_ (fixes a mismatch discovered by
       Nobby6). For anyone wishing to run BIND as root, it seems to accept -u root
       just fine, but if you really don't want a -u option, just set NAMED_OPTIONS
       to " " to avoid triggering the fallback.
n/php-7.4.24-x86_64-1.txz: Upgraded.
       This update fixes bugs and a security issue:
       Zip: ZipArchive::extractTo extracts outside of destination.
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-21706
x/xdg-desktop-portal-1.10.1-x86_64-1.txz: Added.
       This is needed by the xdg-desktop-portal-kde backend.
       Thanks to Vincent Batts.
extra/php8/php8-8.0.11-x86_64-1.txz: Upgraded.
Thu Sep 23 19:15:14 UTC 2021
a/kernel-firmware-20210923_0268c1b-noarch-1.txz: Upgraded.
d/parallel-20210922-noarch-1.txz: Upgraded.
l/pipewire-0.3.37-x86_64-1.txz: Upgraded.
l/python-urllib3-1.26.7-x86_64-1.txz: Upgraded.
xap/freerdp-2.4.0-x86_64-1.txz: Added.
       This is needed for krdc to use RDP. Thanks to max242.
xfce/mousepad-0.5.7-x86_64-1.txz: Upgraded.
Slackware 32-bit
       Host old-host
       Thanks to regdub.
Post Napisano: 04 Oct 2021, 21:53
Slackware 64-bit
Mon Oct 4 19:28:39 UTC 2021
a/util-linux-2.37.2-x86_64-3.txz: Rebuilt.
       Removed broken /usr/bin/raw symlink. Thanks to marav.
d/gdb-11.1-x86_64-2.txz: Rebuilt.
       Don't ship .la files.
d/vala-0.54.2-x86_64-1.txz: Upgraded.
kde/artikulate-21.08.1-x86_64-3.txz: Rebuilt.
       Fixed broken COPYING{,.DOC} symlinks. Thanks to marav.
kde/kservice-5.86.0-x86_64-4.txz: Rebuilt.
       In /etc/profile.d/kde.{csh,sh}:
       Fixed test for kf5 directory. Thanks to LuckyCyborg.
       Make adding /etc/kde/xdg to $XDG_CONFIG_DIRS conditional on the existence
       of that directory.
l/imagemagick-7.1.0_9-x86_64-1.txz: Upgraded.
n/bind-9.16.21-x86_64-4.txz: Rebuilt.
       Removed broken symlink. Thanks to marav.
n/httpd-2.4.50-x86_64-1.txz: Upgraded.
x/cldr-emoji-annotation-37.0_13.0_0_2-noarch-4.txz: Rebuilt.
       Fixed broken COPYING symlink. Thanks to marav.
xap/x3270-4.0ga14-x86_64-2.txz: Rebuilt.
       Fixed symlinks in html directory. Thanks to marav.
Sun Oct 3 23:05:29 UTC 2021
a/mcelog-179-x86_64-1.txz: Upgraded.
ap/squashfs-tools-4.5-x86_64-2.txz: Rebuilt.
       Fixed broken symlinks. Thanks to marav.
l/eigen2-2.0.17-x86_64-4.txz: Removed.
l/eigen3-3.4.0-x86_64-1.txz: Upgraded.
l/pcre2-10.38-x86_64-1.txz: Upgraded.
n/links-2.25-x86_64-1.txz: Upgraded.
n/snownews-1.9-x86_64-1.txz: Upgraded.
Sat Oct 2 19:21:52 UTC 2021
d/python-setuptools-58.2.0-x86_64-1.txz: Upgraded.
kde/kservice-5.86.0-x86_64-3.txz: Rebuilt.
       Fix paths in kde.{csh,sh}. Thanks to marco70.
       Since kdesu and kxmlgui are looking in /usr/lib${LIBDIRSUFFIX}/kf5 for
       some reason, let's just link that location to libexec/kf5 to make things
       work again. Also, I'm not sure why these things are in this particular
       package, but I guess they had to go somewhere.
l/python-cffi-1.14.6-x86_64-1.txz: Added.
       This is needed by hexchat-2.16.0.
l/python-pycparser-2.20-x86_64-1.txz: Added.
l/vte-0.66.0-x86_64-1.txz: Upgraded.
xap/hexchat-2.16.0-x86_64-1.txz: Upgraded.
extra/brltty/brltty-6.4-x86_64-1.txz: Upgraded.
Sat Oct 2 05:36:25 UTC 2021
kde/calligra-3.2.1-x86_64-13.txz: Rebuilt.
       Recompiled against poppler-21.10.0.
kde/cantor-21.08.1-x86_64-3.txz: Rebuilt.
kde/kde-cli-tools-5.22.5-x86_64-3.txz: Rebuilt.
       Added /usr/bin/kdesu symlink. Thanks to rherbert.
kde/kdesu-5.86.0-x86_64-3.txz: Rebuilt.
       Removed broken /usr/bin/kdesu symlink. Thanks to rherbert.
kde/kfilemetadata-5.86.0-x86_64-3.txz: Rebuilt.
kde/kile-2.9.93-x86_64-13.txz: Rebuilt.
kde/kitinerary-21.08.1-x86_64-3.txz: Rebuilt.
kde/krita-4.4.8-x86_64-4.txz: Rebuilt.
kde/krusader-2.7.2-x86_64-5.txz: Rebuilt.
       Adjust cmake to point to the correct kdesu location. Thanks to marco70.
kde/okular-21.08.1-x86_64-3.txz: Rebuilt.
l/poppler-21.10.0-x86_64-1.txz: Upgraded.
Fri Oct 1 05:38:04 UTC 2021
x/liberation-fonts-ttf-2.1.5-noarch-1.txz: Upgraded.
x/libva-utils-2.13.0-x86_64-1.txz: Upgraded.
x/noto-fonts-ttf-20171024-noarch-4.txz: Rebuilt.
       Package NotoSansCoptic-Regular.ttf and a few other unhinted fonts.
       Thanks to Roman Dyaba.
xfce/Greybird-3.22.15-noarch-1.txz: Upgraded.
Fri Oct 1 00:21:20 UTC 2021
Hey folks, sorry about all the bandwidth rebuilding Plasma, but there's no
good reason to specify a libexec dir that's different from upsteam's default,
so we've removed that option to let everything fall into the default location.
Only a couple dozen packages seemed to be affected, but it's just safer to
recompile all of them just to be sure. Thanks to fulalas.
a/haveged-1.9.15-x86_64-1.txz: Upgraded.
a/kernel-generic-5.14.9-x86_64-1.txz: Upgraded.
a/kernel-huge-5.14.9-x86_64-1.txz: Upgraded.
a/kernel-modules-5.14.9-x86_64-1.txz: Upgraded.
a/udisks2-2.9.4-x86_64-1.txz: Upgraded.
d/kernel-headers-5.14.9-x86-1.txz: Upgraded.
k/kernel-source-5.14.9-noarch-1.txz: Upgraded.
kde/akonadi-21.08.1-x86_64-2.txz: Rebuilt.
kde/akonadi-calendar-21.08.1-x86_64-2.txz: Rebuilt.
kde/akonadi-calendar-tools-21.08.1-x86_64-2.txz: Rebuilt.
kde/akonadi-contacts-21.08.1-x86_64-2.txz: Rebuilt.
kde/akonadi-import-wizard-21.08.1-x86_64-2.txz: Rebuilt.
kde/akonadi-mime-21.08.1-x86_64-2.txz: Rebuilt.
kde/akonadi-notes-21.08.1-x86_64-2.txz: Rebuilt.
kde/akonadi-search-21.08.1-x86_64-2.txz: Rebuilt.
kde/akonadiconsole-21.08.1-x86_64-2.txz: Rebuilt.
kde/akregator-21.08.1-x86_64-2.txz: Rebuilt.
kde/alkimia-8.1.0-x86_64-2.txz: Rebuilt.
kde/analitza-21.08.1-x86_64-2.txz: Rebuilt.
kde/ark-21.08.1-x86_64-2.txz: Rebuilt.
kde/artikulate-21.08.1-x86_64-2.txz: Rebuilt.
kde/attica-5.86.0-x86_64-2.txz: Rebuilt.
kde/audiocd-kio-21.08.1-x86_64-2.txz: Rebuilt.
kde/baloo-5.86.0-x86_64-2.txz: Rebuilt.
kde/baloo-widgets-21.08.1-x86_64-2.txz: Rebuilt.
kde/blinken-21.08.1-x86_64-2.txz: Rebuilt.
kde/bluedevil-5.22.5-x86_64-2.txz: Rebuilt.
kde/bluez-qt-5.86.0-x86_64-2.txz: Rebuilt.
kde/bomber-21.08.1-x86_64-2.txz: Rebuilt.
kde/bovo-21.08.1-x86_64-2.txz: Rebuilt.
kde/breeze-5.22.5-x86_64-2.txz: Rebuilt.
kde/breeze-grub-5.22.5-x86_64-2.txz: Rebuilt.
kde/breeze-gtk-5.22.5-x86_64-2.txz: Rebuilt.
kde/breeze-icons-5.86.0-noarch-2.txz: Rebuilt.
kde/calendarsupport-21.08.1-x86_64-2.txz: Rebuilt.
kde/calligra-3.2.1-x86_64-12.txz: Rebuilt.
kde/calligraplan-3.3.0-x86_64-3.txz: Rebuilt.
kde/cantor-21.08.1-x86_64-2.txz: Rebuilt.
kde/cervisia-21.08.1-x86_64-2.txz: Rebuilt.
kde/digikam-7.3.0-x86_64-2.txz: Rebuilt.
kde/dolphin-21.08.1-x86_64-2.txz: Rebuilt.
kde/dolphin-plugins-21.08.1-x86_64-2.txz: Rebuilt.
kde/dragon-21.08.1-x86_64-2.txz: Rebuilt.
kde/drkonqi-5.22.5-x86_64-2.txz: Rebuilt.
kde/elisa-21.08.1-x86_64-2.txz: Rebuilt.
kde/eventviews-21.08.1-x86_64-2.txz: Rebuilt.
kde/extra-cmake-modules-5.86.0-x86_64-2.txz: Rebuilt.
kde/falkon-3.1.0-x86_64-4.txz: Rebuilt.
kde/ffmpegthumbs-21.08.1-x86_64-2.txz: Rebuilt.
kde/filelight-21.08.1-x86_64-2.txz: Rebuilt.
kde/frameworkintegration-5.86.0-x86_64-2.txz: Rebuilt.
kde/granatier-21.08.1-x86_64-2.txz: Rebuilt.
kde/grantlee-editor-21.08.1-x86_64-2.txz: Rebuilt.
kde/grantleetheme-21.08.1-x86_64-2.txz: Rebuilt.
kde/gwenview-21.08.1-x86_64-2.txz: Rebuilt.
kde/incidenceeditor-21.08.1-x86_64-2.txz: Rebuilt.
kde/itinerary-21.08.1-x86_64-2.txz: Rebuilt.
kde/juk-21.08.1-x86_64-2.txz: Rebuilt.
kde/k3b-21.08.1-x86_64-2.txz: Rebuilt.
kde/kactivities-5.86.0-x86_64-2.txz: Rebuilt.
kde/kactivities-stats-5.86.0-x86_64-2.txz: Rebuilt.
kde/kactivitymanagerd-5.22.5-x86_64-2.txz: Rebuilt.
kde/kaddressbook-21.08.1-x86_64-2.txz: Rebuilt.
kde/kalarm-21.08.1-x86_64-2.txz: Rebuilt.
kde/kalarmcal-21.08.1-x86_64-2.txz: Rebuilt.
kde/kalgebra-21.08.1-x86_64-2.txz: Rebuilt.
kde/kalzium-21.08.1-x86_64-2.txz: Rebuilt.
kde/kamera-21.08.1-x86_64-2.txz: Rebuilt.
kde/kamoso-21.08.1-x86_64-2.txz: Rebuilt.
kde/kanagram-21.08.1-x86_64-2.txz: Rebuilt.
kde/kapidox-5.86.0-x86_64-2.txz: Rebuilt.
kde/kapman-21.08.1-x86_64-2.txz: Rebuilt.
kde/kapptemplate-21.08.1-x86_64-2.txz: Rebuilt.
kde/karchive-5.86.0-x86_64-2.txz: Rebuilt.
kde/kate-21.08.1-x86_64-2.txz: Rebuilt.
kde/katomic-21.08.1-x86_64-2.txz: Rebuilt.
kde/kauth-5.86.0-x86_64-2.txz: Rebuilt.
kde/kbackup-21.08.1-x86_64-2.txz: Rebuilt.
kde/kblackbox-21.08.1-x86_64-2.txz: Rebuilt.
kde/kblocks-21.08.1-x86_64-2.txz: Rebuilt.
kde/kbookmarks-5.86.0-x86_64-2.txz: Rebuilt.
kde/kbounce-21.08.1-x86_64-2.txz: Rebuilt.
kde/kbreakout-21.08.1-x86_64-2.txz: Rebuilt.
kde/kbruch-21.08.1-x86_64-2.txz: Rebuilt.
kde/kcachegrind-21.08.1-x86_64-2.txz: Rebuilt.
kde/kcalc-21.08.1-x86_64-2.txz: Rebuilt.
kde/kcalendarcore-5.86.0-x86_64-2.txz: Rebuilt.
kde/kcalutils-21.08.1-x86_64-2.txz: Rebuilt.
kde/kcharselect-21.08.1-x86_64-2.txz: Rebuilt.
kde/kcmutils-5.86.0-x86_64-2.txz: Rebuilt.
kde/kcodecs-5.86.0-x86_64-2.txz: Rebuilt.
kde/kcolorchooser-21.08.1-x86_64-2.txz: Rebuilt.
kde/kcompletion-5.86.0-x86_64-2.txz: Rebuilt.
kde/kconfig-5.86.0-x86_64-2.txz: Rebuilt.
kde/kconfigwidgets-5.86.0-x86_64-2.txz: Rebuilt.
kde/kcontacts-5.86.0-x86_64-2.txz: Rebuilt.
kde/kcoreaddons-5.86.0-x86_64-2.txz: Rebuilt.
kde/kcrash-5.86.0-x86_64-2.txz: Rebuilt.
kde/kcron-21.08.1-x86_64-2.txz: Rebuilt.
kde/kdav-5.86.0-x86_64-2.txz: Rebuilt.
kde/kdbusaddons-5.86.0-x86_64-2.txz: Rebuilt.
kde/kde-cli-tools-5.22.5-x86_64-2.txz: Rebuilt.
kde/kde-dev-scripts-21.08.1-x86_64-2.txz: Rebuilt.
kde/kde-dev-utils-21.08.1-x86_64-2.txz: Rebuilt.
kde/kde-gtk-config-5.22.5-x86_64-2.txz: Rebuilt.
kde/kdebugsettings-21.08.1-x86_64-2.txz: Rebuilt.
kde/kdeclarative-5.86.0-x86_64-2.txz: Rebuilt.
kde/kdeconnect-kde-21.08.1-x86_64-2.txz: Rebuilt.
kde/kdecoration-5.22.5-x86_64-2.txz: Rebuilt.
kde/kded-5.86.0-x86_64-2.txz: Rebuilt.
kde/kdeedu-data-21.08.1-x86_64-2.txz: Rebuilt.
kde/kdegraphics-mobipocket-21.08.1-x86_64-2.txz: Rebuilt.
kde/kdegraphics-thumbnailers-21.08.1-x86_64-2.txz: Rebuilt.
kde/kdelibs4support-5.86.0-x86_64-2.txz: Rebuilt.
kde/kdenetwork-filesharing-21.08.1-x86_64-2.txz: Rebuilt.
kde/kdenlive-21.08.1-x86_64-2.txz: Rebuilt.
kde/kdepim-addons-21.08.1-x86_64-2.txz: Rebuilt.
kde/kdepim-runtime-21.08.1-x86_64-2.txz: Rebuilt.
kde/kdeplasma-addons-5.22.5-x86_64-2.txz: Rebuilt.
kde/kdesdk-kioslaves-21.08.1-x86_64-2.txz: Rebuilt.
kde/kdesdk-thumbnailers-21.08.1-x86_64-2.txz: Rebuilt.
kde/kdesignerplugin-5.86.0-x86_64-2.txz: Rebuilt.
kde/kdesu-5.86.0-x86_64-2.txz: Rebuilt.
kde/kdev-php-5.6.2-x86_64-3.txz: Rebuilt.
kde/kdev-python-5.6.2-x86_64-3.txz: Rebuilt.
kde/kdevelop-5.6.2-x86_64-5.txz: Rebuilt.
kde/kdevelop-pg-qt-2.2.1-x86_64-4.txz: Rebuilt.
kde/kdewebkit-5.86.0-x86_64-2.txz: Rebuilt.
kde/kdf-21.08.1-x86_64-2.txz: Rebuilt.
kde/kdiagram-2.8.0-x86_64-4.txz: Rebuilt.
kde/kdialog-21.08.1-x86_64-2.txz: Rebuilt.
kde/kdiamond-21.08.1-x86_64-2.txz: Rebuilt.
kde/kdnssd-5.86.0-x86_64-2.txz: Rebuilt.
kde/kdoctools-5.86.0-x86_64-2.txz: Rebuilt.
kde/keditbookmarks-21.08.1-x86_64-2.txz: Rebuilt.
kde/kemoticons-5.86.0-x86_64-2.txz: Rebuilt.
kde/kfilemetadata-5.86.0-x86_64-2.txz: Rebuilt.
kde/kfind-21.08.1-x86_64-2.txz: Rebuilt.
kde/kfloppy-21.08.1-x86_64-2.txz: Rebuilt.
kde/kfourinline-21.08.1-x86_64-2.txz: Rebuilt.
kde/kgamma5-5.22.5-x86_64-2.txz: Rebuilt.
kde/kgeography-21.08.1-x86_64-2.txz: Rebuilt.
kde/kget-21.08.1-x86_64-2.txz: Rebuilt.
kde/kglobalaccel-5.86.0-x86_64-2.txz: Rebuilt.
kde/kgoldrunner-21.08.1-x86_64-2.txz: Rebuilt.
kde/kgpg-21.08.1-x86_64-2.txz: Rebuilt.
kde/kguiaddons-5.86.0-x86_64-2.txz: Rebuilt.
kde/khangman-21.08.1-x86_64-2.txz: Rebuilt.
kde/khelpcenter-21.08.1-x86_64-2.txz: Rebuilt.
kde/kholidays-5.86.0-x86_64-2.txz: Rebuilt.
kde/khotkeys-5.22.5-x86_64-2.txz: Rebuilt.
kde/khtml-5.86.0-x86_64-2.txz: Rebuilt.
kde/ki18n-5.86.0-x86_64-2.txz: Rebuilt.
kde/kiconthemes-5.86.0-x86_64-2.txz: Rebuilt.
kde/kid3-3.8.7-x86_64-2.txz: Rebuilt.
kde/kidentitymanagement-21.08.1-x86_64-2.txz: Rebuilt.
kde/kidletime-5.86.0-x86_64-2.txz: Rebuilt.
kde/kig-21.08.1-x86_64-2.txz: Rebuilt.
kde/kigo-21.08.1-x86_64-2.txz: Rebuilt.
kde/kile-2.9.93-x86_64-12.txz: Rebuilt.
kde/killbots-21.08.1-x86_64-2.txz: Rebuilt.
kde/kimageformats-5.86.0-x86_64-2.txz: Rebuilt.
kde/kimagemapeditor-21.08.1-x86_64-2.txz: Rebuilt.
kde/kimap-21.08.1-x86_64-2.txz: Rebuilt.
kde/kinfocenter-5.22.5-x86_64-2.txz: Rebuilt.
kde/kinit-5.86.0-x86_64-2.txz: Rebuilt.
kde/kio-5.86.0-x86_64-2.txz: Rebuilt.
kde/kio-extras-21.08.1-x86_64-2.txz: Rebuilt.
kde/kio-gdrive-21.08.1-x86_64-2.txz: Rebuilt.
kde/kipi-plugins-21.08.1-x86_64-2.txz: Rebuilt.
kde/kirigami-gallery-21.08.1-x86_64-2.txz: Rebuilt.
kde/kirigami2-5.86.0-x86_64-2.txz: Rebuilt.
kde/kiriki-21.08.1-x86_64-2.txz: Rebuilt.
kde/kitemmodels-5.86.0-x86_64-2.txz: Rebuilt.
kde/kitemviews-5.86.0-x86_64-2.txz: Rebuilt.
kde/kiten-21.08.1-x86_64-2.txz: Rebuilt.
kde/kitinerary-21.08.1-x86_64-2.txz: Rebuilt.
kde/kjobwidgets-5.86.0-x86_64-2.txz: Rebuilt.
kde/kjots-20201206_f7d555c-x86_64-4.txz: Rebuilt.
kde/kjs-5.86.0-x86_64-2.txz: Rebuilt.
kde/kjsembed-5.86.0-x86_64-2.txz: Rebuilt.
kde/kjumpingcube-21.08.1-x86_64-2.txz: Rebuilt.
kde/kldap-21.08.1-x86_64-2.txz: Rebuilt.
kde/kleopatra-21.08.1-x86_64-2.txz: Rebuilt.
kde/klickety-21.08.1-x86_64-2.txz: Rebuilt.
kde/klines-21.08.1-x86_64-2.txz: Rebuilt.
kde/kmag-21.08.1-x86_64-2.txz: Rebuilt.
kde/kmahjongg-21.08.1-x86_64-2.txz: Rebuilt.
kde/kmail-21.08.1-x86_64-2.txz: Rebuilt.
kde/kmail-account-wizard-21.08.1-x86_64-2.txz: Rebuilt.
kde/kmailtransport-21.08.1-x86_64-2.txz: Rebuilt.
kde/kmbox-21.08.1-x86_64-2.txz: Rebuilt.
kde/kmediaplayer-5.86.0-x86_64-2.txz: Rebuilt.
kde/kmenuedit-5.22.5-x86_64-2.txz: Rebuilt.
kde/kmime-21.08.1-x86_64-2.txz: Rebuilt.
kde/kmines-21.08.1-x86_64-2.txz: Rebuilt.
kde/kmix-21.08.1-x86_64-2.txz: Rebuilt.
kde/kmousetool-21.08.1-x86_64-2.txz: Rebuilt.
kde/kmouth-21.08.1-x86_64-2.txz: Rebuilt.
kde/kmplot-21.08.1-x86_64-2.txz: Rebuilt.
kde/kmymoney-5.1.2-x86_64-2.txz: Rebuilt.
kde/knavalbattle-21.08.1-x86_64-2.txz: Rebuilt.
kde/knetwalk-21.08.1-x86_64-2.txz: Rebuilt.
kde/knewstuff-5.86.0-x86_64-3.txz: Rebuilt.
kde/knights-21.08.1-x86_64-2.txz: Rebuilt.
kde/knotes-21.08.1-x86_64-2.txz: Rebuilt.
kde/knotifications-5.86.0-x86_64-2.txz: Rebuilt.
kde/knotifyconfig-5.86.0-x86_64-2.txz: Rebuilt.
kde/kolf-21.08.1-x86_64-2.txz: Rebuilt.
kde/kollision-21.08.1-x86_64-2.txz: Rebuilt.
kde/kolourpaint-21.08.1-x86_64-2.txz: Rebuilt.
kde/kompare-21.08.1-x86_64-2.txz: Rebuilt.
kde/konqueror-21.08.1-x86_64-2.txz: Rebuilt.
kde/konquest-21.08.1-x86_64-2.txz: Rebuilt.
kde/konsole-21.08.1-x86_64-2.txz: Rebuilt.
kde/kontact-21.08.1-x86_64-2.txz: Rebuilt.
kde/kontactinterface-21.08.1-x86_64-2.txz: Rebuilt.
kde/kontrast-21.08.1-x86_64-2.txz: Rebuilt.
kde/konversation-21.08.1-x86_64-2.txz: Rebuilt.
kde/kopeninghours-21.08.1-x86_64-2.txz: Rebuilt.
kde/kopete-21.08.1-x86_64-2.txz: Rebuilt.
kde/korganizer-21.08.1-x86_64-2.txz: Rebuilt.
kde/kosmindoormap-21.08.1-x86_64-2.txz: Rebuilt.
kde/kpackage-5.86.0-x86_64-2.txz: Rebuilt.
kde/kparts-5.86.0-x86_64-2.txz: Rebuilt.
kde/kpat-21.08.1-x86_64-2.txz: Rebuilt.
kde/kpeople-5.86.0-x86_64-2.txz: Rebuilt.
kde/kpeoplevcard-0.1-x86_64-4.txz: Rebuilt.
kde/kpimtextedit-21.08.1-x86_64-2.txz: Rebuilt.
kde/kpkpass-21.08.1-x86_64-2.txz: Rebuilt.
kde/kplotting-5.86.0-x86_64-2.txz: Rebuilt.
kde/kpmcore-21.08.1-x86_64-2.txz: Rebuilt.
kde/kpty-5.86.0-x86_64-2.txz: Rebuilt.
kde/kpublictransport-21.08.1-x86_64-2.txz: Rebuilt.
kde/kqtquickcharts-21.08.1-x86_64-2.txz: Rebuilt.
kde/kquickcharts-5.86.0-x86_64-2.txz: Rebuilt.
kde/krdc-21.08.1-x86_64-2.txz: Rebuilt.
kde/krename-5.0.1-x86_64-4.txz: Rebuilt.
kde/kreversi-21.08.1-x86_64-2.txz: Rebuilt.
kde/krfb-21.08.1-x86_64-2.txz: Rebuilt.
kde/krita-4.4.8-x86_64-3.txz: Rebuilt.
kde/kross-5.86.0-x86_64-2.txz: Rebuilt.
kde/kross-interpreters-21.08.1-x86_64-2.txz: Rebuilt.
kde/kruler-21.08.1-x86_64-2.txz: Rebuilt.
kde/krunner-5.86.0-x86_64-2.txz: Rebuilt.
kde/krusader-2.7.2-x86_64-4.txz: Rebuilt.
kde/kscreen-5.22.5-x86_64-2.txz: Rebuilt.
kde/kscreenlocker-5.22.5-x86_64-2.txz: Rebuilt.
kde/kservice-5.86.0-x86_64-2.txz: Rebuilt.
kde/kshisen-21.08.1-x86_64-2.txz: Rebuilt.
kde/ksirk-21.08.1-x86_64-2.txz: Rebuilt.
kde/ksmtp-21.08.1-x86_64-2.txz: Rebuilt.
kde/ksnakeduel-21.08.1-x86_64-2.txz: Rebuilt.
kde/kspaceduel-21.08.1-x86_64-2.txz: Rebuilt.
kde/ksquares-21.08.1-x86_64-2.txz: Rebuilt.
kde/ksshaskpass-5.22.5-x86_64-2.txz: Rebuilt.
kde/kstars-3.5.5-x86_64-2.txz: Rebuilt.
kde/ksudoku-21.08.1-x86_64-2.txz: Rebuilt.
kde/ksysguard-5.22.0-x86_64-2.txz: Rebuilt.
kde/ksystemlog-21.08.1-x86_64-2.txz: Rebuilt.
kde/ksystemstats-5.22.5-x86_64-2.txz: Rebuilt.
kde/kteatime-21.08.1-x86_64-2.txz: Rebuilt.
kde/ktexteditor-5.86.0-x86_64-2.txz: Rebuilt.
kde/ktextwidgets-5.86.0-x86_64-2.txz: Rebuilt.
kde/ktimer-21.08.1-x86_64-2.txz: Rebuilt.
kde/ktimetracker-5.0.1-x86_64-4.txz: Rebuilt.
kde/ktnef-21.08.1-x86_64-2.txz: Rebuilt.
kde/ktorrent-21.08.1-x86_64-2.txz: Rebuilt.
kde/ktouch-21.08.1-x86_64-2.txz: Rebuilt.
kde/kturtle-21.08.1-x86_64-2.txz: Rebuilt.
kde/kubrick-21.08.1-x86_64-2.txz: Rebuilt.
kde/kunitconversion-5.86.0-x86_64-2.txz: Rebuilt.
kde/kwallet-5.86.0-x86_64-2.txz: Rebuilt.
kde/kwallet-pam-5.22.5-x86_64-2.txz: Rebuilt.
kde/kwalletmanager-21.08.1-x86_64-2.txz: Rebuilt.
kde/kwave-21.08.1-x86_64-2.txz: Rebuilt.
kde/kwayland-5.86.0-x86_64-2.txz: Rebuilt.
kde/kwayland-integration-5.22.5-x86_64-2.txz: Rebuilt.
kde/kwayland-server-5.22.5-x86_64-2.txz: Rebuilt.
kde/kwidgetsaddons-5.86.0-x86_64-2.txz: Rebuilt.
kde/kwin-5.22.5-x86_64-2.txz: Rebuilt.
kde/kwindowsystem-5.86.0-x86_64-2.txz: Rebuilt.
kde/kwordquiz-21.08.1-x86_64-2.txz: Rebuilt.
kde/kwrited-5.22.5-x86_64-2.txz: Rebuilt.
kde/kxmlgui-5.86.0-x86_64-2.txz: Rebuilt.
kde/kxmlrpcclient-5.86.0-x86_64-2.txz: Rebuilt.
kde/latte-dock-0.10.2-x86_64-2.txz: Rebuilt.
kde/layer-shell-qt-5.22.5-x86_64-2.txz: Rebuilt.
kde/libgravatar-21.08.1-x86_64-2.txz: Rebuilt.
kde/libkcddb-21.08.1-x86_64-2.txz: Rebuilt.
kde/libkcompactdisc-21.08.1-x86_64-2.txz: Rebuilt.
kde/libkdcraw-21.08.1-x86_64-2.txz: Rebuilt.
kde/libkdegames-21.08.1-x86_64-2.txz: Rebuilt.
kde/libkdepim-21.08.1-x86_64-2.txz: Rebuilt.
kde/libkeduvocdocument-21.08.1-x86_64-2.txz: Rebuilt.
kde/libkexiv2-21.08.1-x86_64-2.txz: Rebuilt.
kde/libkgapi-21.08.1-x86_64-2.txz: Rebuilt.
kde/libkipi-21.08.1-x86_64-2.txz: Rebuilt.
kde/libkleo-21.08.1-x86_64-2.txz: Rebuilt.
kde/libkmahjongg-21.08.1-x86_64-2.txz: Rebuilt.
kde/libkomparediff2-21.08.1-x86_64-2.txz: Rebuilt.
kde/libksane-21.08.1-x86_64-2.txz: Rebuilt.
kde/libkscreen-5.22.5-x86_64-2.txz: Rebuilt.
kde/libksieve-21.08.1-x86_64-2.txz: Rebuilt.
kde/libksysguard-5.22.5-x86_64-2.txz: Rebuilt.
kde/libktorrent-21.08.1-x86_64-2.txz: Rebuilt.
kde/lokalize-21.08.1-x86_64-2.txz: Rebuilt.
kde/lskat-21.08.1-x86_64-2.txz: Rebuilt.
kde/mailcommon-21.08.1-x86_64-2.txz: Rebuilt.
kde/mailimporter-21.08.1-x86_64-2.txz: Rebuilt.
kde/marble-21.08.1-x86_64-2.txz: Rebuilt.
kde/markdownpart-21.08.1-x86_64-2.txz: Rebuilt.
kde/mbox-importer-21.08.1-x86_64-2.txz: Rebuilt.
kde/messagelib-21.08.1-x86_64-2.txz: Rebuilt.
kde/milou-5.22.5-x86_64-2.txz: Rebuilt.
kde/minuet-21.08.1-x86_64-2.txz: Rebuilt.
kde/modemmanager-qt-5.86.0-x86_64-2.txz: Rebuilt.
kde/networkmanager-qt-5.86.0-x86_64-2.txz: Rebuilt.
kde/okteta-0.26.6-x86_64-2.txz: Rebuilt.
kde/okular-21.08.1-x86_64-2.txz: Rebuilt.
kde/oxygen-5.22.5-x86_64-2.txz: Rebuilt.
kde/oxygen-fonts-5.4.3-noarch-4.txz: Rebuilt.
kde/oxygen-gtk2-1.4.6-x86_64-4.txz: Rebuilt.
kde/oxygen-icons5-5.86.0-noarch-2.txz: Rebuilt.
kde/palapeli-21.08.1-x86_64-2.txz: Rebuilt.
kde/parley-21.08.1-x86_64-2.txz: Rebuilt.
kde/partitionmanager-21.08.1-x86_64-2.txz: Rebuilt.
kde/picmi-21.08.1-x86_64-2.txz: Rebuilt.
kde/pim-data-exporter-21.08.1-x86_64-2.txz: Rebuilt.
kde/pim-sieve-editor-21.08.1-x86_64-2.txz: Rebuilt.
kde/pimcommon-21.08.1-x86_64-2.txz: Rebuilt.
kde/plasma-browser-integration-5.22.5-x86_64-2.txz: Rebuilt.
kde/plasma-desktop-5.22.5-x86_64-3.txz: Rebuilt.
kde/plasma-disks-5.22.5-x86_64-2.txz: Rebuilt.
kde/plasma-firewall-5.22.5-x86_64-2.txz: Rebuilt.
kde/plasma-framework-5.86.0-x86_64-2.txz: Rebuilt.
kde/plasma-integration-5.22.5-x86_64-2.txz: Rebuilt.
kde/plasma-nm-5.22.5-x86_64-2.txz: Rebuilt.
kde/plasma-pa-5.22.5-x86_64-2.txz: Rebuilt.
kde/plasma-sdk-5.22.5-x86_64-2.txz: Rebuilt.
kde/plasma-systemmonitor-5.22.5-x86_64-2.txz: Rebuilt.
kde/plasma-vault-5.22.5-x86_64-2.txz: Rebuilt.
kde/plasma-wayland-protocols-1.4.0-x86_64-2.txz: Rebuilt.
kde/plasma-workspace-5.22.5-x86_64-3.txz: Rebuilt.
kde/plasma-workspace-wallpapers-5.22.5-x86_64-2.txz: Rebuilt.
kde/polkit-kde-agent-1-5.22.5-x86_64-2.txz: Rebuilt.
kde/powerdevil-5.22.5-x86_64-2.txz: Rebuilt.
kde/poxml-21.08.1-x86_64-2.txz: Rebuilt.
kde/print-manager-21.08.1-x86_64-2.txz: Rebuilt.
kde/prison-5.86.0-x86_64-2.txz: Rebuilt.
kde/pulseaudio-qt-1.3-x86_64-2.txz: Rebuilt.
kde/purpose-5.86.0-x86_64-2.txz: Rebuilt.
kde/qqc2-breeze-style-5.22.5-x86_64-2.txz: Rebuilt.
kde/qqc2-desktop-style-5.86.0-x86_64-2.txz: Rebuilt.
kde/rocs-21.08.1-x86_64-2.txz: Rebuilt.
kde/sddm-0.19.0-x86_64-9.txz: Rebuilt.
kde/sddm-kcm-5.22.5-x86_64-2.txz: Rebuilt.
kde/skanlite-21.08.1-x86_64-2.txz: Rebuilt.
kde/solid-5.86.0-x86_64-2.txz: Rebuilt.
kde/sonnet-5.86.0-x86_64-2.txz: Rebuilt.
kde/spectacle-21.08.1-x86_64-2.txz: Rebuilt.
kde/step-21.08.1-x86_64-2.txz: Rebuilt.
kde/svgpart-21.08.1-x86_64-2.txz: Rebuilt.
kde/sweeper-21.08.1-x86_64-2.txz: Rebuilt.
kde/syndication-5.86.0-x86_64-2.txz: Rebuilt.
kde/syntax-highlighting-5.86.0-x86_64-2.txz: Rebuilt.
kde/systemsettings-5.22.5-x86_64-2.txz: Rebuilt.
kde/threadweaver-5.86.0-x86_64-2.txz: Rebuilt.
kde/umbrello-21.08.1-x86_64-2.txz: Rebuilt.
kde/wacomtablet-20201030_417d9d9-x86_64-4.txz: Rebuilt.
kde/xdg-desktop-portal-kde-5.22.5-x86_64-2.txz: Rebuilt.
kde/yakuake-21.08.1-x86_64-2.txz: Rebuilt.
kde/zeroconf-ioslave-21.08.1-x86_64-2.txz: Rebuilt.
l/mozilla-nss-3.71-x86_64-1.txz: Upgraded.
l/pipewire-0.3.38-x86_64-1.txz: Upgraded.
x/mesa-21.2.3-x86_64-1.txz: Upgraded.
Wed Sep 29 19:15:54 UTC 2021
a/kernel-firmware-20210928_7a30050-noarch-1.txz: Upgraded.
d/ccache-4.4.2-x86_64-1.txz: Upgraded.
d/meson-0.59.2-x86_64-1.txz: Upgraded.
l/gc-8.0.6-x86_64-1.txz: Upgraded.
l/mlt-7.0.1-x86_64-2.txz: Rebuilt.
       Fixed man page installation. Thanks to GazL and Markus Wiesner.
l/netpbm-10.96.00-x86_64-1.txz: Upgraded.
n/epic5-2.1.5-x86_64-2.txz: Rebuilt.
       Fixed man page installation. Thanks to GazL and kaott.
n/openssh-8.8p1-x86_64-2.txz: Rebuilt.
       Add pam_elogind.so to /etc/pam.d/sshd to track user sessions over ssh,
       properly set the XDG_ variables, and create the runtime directory.
       Thanks to davjohn.
xap/NetworkManager-openvpn-1.8.16-x86_64-1.txz: Upgraded.
Tue Sep 28 18:18:11 UTC 2021
kde/knewstuff-5.86.0-x86_64-2.txz: Rebuilt.
       [PATCH] Fix crash in DownloadWidget.
l/pygobject3-3.42.0-x86_64-1.txz: Upgraded.
n/pinentry-1.2.0-x86_64-1.txz: Upgraded.
x/libinput-1.19.1-x86_64-1.txz: Upgraded.
xap/seamonkey-2.53.9.1-x86_64-1.txz: Upgraded.
       https://www.seamonkey-project.org/releases/seamonkey2.53.9.1
Tue Sep 28 01:37:33 UTC 2021
n/nftables-1.0.0-x86_64-2.txz: Rebuilt.
       Added options --with-json and --enable-python needed for firewalld.
       Thanks to stormtracknole.
xap/mozilla-thunderbird-91.1.2-x86_64-1.txz: Upgraded.
       https://www.mozilla.org/en-US/thunderbird/91.1.2/releasenotes/
Mon Sep 27 18:50:28 UTC 2021
a/coreutils-9.0-x86_64-3.txz: Rebuilt.
       DIR_COLORS: Support .webm and .webp extensions. Thanks to madridsecreto.
       [PATCH] chmod: fix exit status when ignoring symlinks
ap/ghostscript-9.55.0-x86_64-1.txz: Upgraded.
ap/vim-8.2.3458-x86_64-1.txz: Upgraded.
d/vala-0.54.1-x86_64-1.txz: Upgraded.
l/at-spi2-core-2.42.0-x86_64-1.txz: Upgraded.
l/gexiv2-0.14.0-x86_64-1.txz: Upgraded.
l/gjs-1.70.0-x86_64-1.txz: Upgraded.
l/glib-networking-2.70.0-x86_64-1.txz: Upgraded.
l/glib2-2.70.0-x86_64-1.txz: Upgraded.
l/gobject-introspection-1.70.0-x86_64-1.txz: Upgraded.
l/libcap-2.59-x86_64-1.txz: Upgraded.
l/librsvg-2.52.0-x86_64-1.txz: Upgraded.
l/libsoup-2.74.0-x86_64-1.txz: Upgraded.
n/ModemManager-1.18.2-x86_64-1.txz: Upgraded.
n/NetworkManager-1.32.12-x86_64-1.txz: Upgraded.
n/tin-2.6.0-x86_64-1.txz: Upgraded.
xap/vim-gvim-8.2.3458-x86_64-1.txz: Upgraded.
Slackware 32-bit
a/util-linux-2.37.2-i586-3.txz: Rebuilt.
d/gdb-11.1-i586-2.txz: Rebuilt.
d/vala-0.54.2-i586-1.txz: Upgraded.
kde/artikulate-21.08.1-i586-3.txz: Rebuilt.
kde/kservice-5.86.0-i586-4.txz: Rebuilt.
       of that directory.
l/imagemagick-7.1.0_9-i586-1.txz: Upgraded.
n/bind-9.16.21-i586-4.txz: Rebuilt.
n/httpd-2.4.50-i586-1.txz: Upgraded.
xap/x3270-4.0ga14-i586-2.txz: Rebuilt.
a/mcelog-179-i586-1.txz: Upgraded.
ap/squashfs-tools-4.5-i586-2.txz: Rebuilt.
l/eigen2-2.0.17-i586-4.txz: Removed.
l/eigen3-3.4.0-i586-1.txz: Upgraded.
l/pcre2-10.38-i586-1.txz: Upgraded.
n/links-2.25-i586-1.txz: Upgraded.
n/snownews-1.9-i586-1.txz: Upgraded.
d/python-setuptools-58.2.0-i586-1.txz: Upgraded.
kde/kservice-5.86.0-i586-3.txz: Rebuilt.
l/python-cffi-1.14.6-i586-1.txz: Added.
l/python-pycparser-2.20-i586-1.txz: Added.
l/vte-0.66.0-i586-1.txz: Upgraded.
xap/hexchat-2.16.0-i586-1.txz: Upgraded.
extra/brltty/brltty-6.4-i586-1.txz: Upgraded.
kde/calligra-3.2.1-i586-13.txz: Rebuilt.
kde/cantor-21.08.1-i586-3.txz: Rebuilt.
kde/kde-cli-tools-5.22.5-i586-3.txz: Rebuilt.
kde/kdesu-5.86.0-i586-3.txz: Rebuilt.
kde/kfilemetadata-5.86.0-i586-3.txz: Rebuilt.
kde/kile-2.9.93-i586-13.txz: Rebuilt.
kde/kitinerary-21.08.1-i586-3.txz: Rebuilt.
kde/krita-4.4.8-i586-4.txz: Rebuilt.
kde/krusader-2.7.2-i586-5.txz: Rebuilt.
kde/okular-21.08.1-i586-3.txz: Rebuilt.
l/poppler-21.10.0-i586-1.txz: Upgraded.
x/libva-utils-2.13.0-i586-1.txz: Upgraded.
a/haveged-1.9.15-i586-1.txz: Upgraded.
a/kernel-generic-5.14.9-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.14.9_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.14.9-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.14.9_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.14.9-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.14.9_smp-i686-1.txz: Upgraded.
a/udisks2-2.9.4-i586-1.txz: Upgraded.
d/kernel-headers-5.14.9_smp-x86-1.txz: Upgraded.
k/kernel-source-5.14.9_smp-noarch-1.txz: Upgraded.
kde/akonadi-21.08.1-i586-2.txz: Rebuilt.
kde/akonadi-calendar-21.08.1-i586-2.txz: Rebuilt.
kde/akonadi-calendar-tools-21.08.1-i586-2.txz: Rebuilt.
kde/akonadi-contacts-21.08.1-i586-2.txz: Rebuilt.
kde/akonadi-import-wizard-21.08.1-i586-2.txz: Rebuilt.
kde/akonadi-mime-21.08.1-i586-2.txz: Rebuilt.
kde/akonadi-notes-21.08.1-i586-2.txz: Rebuilt.
kde/akonadi-search-21.08.1-i586-2.txz: Rebuilt.
kde/akonadiconsole-21.08.1-i586-2.txz: Rebuilt.
kde/akregator-21.08.1-i586-2.txz: Rebuilt.
kde/alkimia-8.1.0-i586-2.txz: Rebuilt.
kde/analitza-21.08.1-i586-2.txz: Rebuilt.
kde/ark-21.08.1-i586-2.txz: Rebuilt.
kde/artikulate-21.08.1-i586-2.txz: Rebuilt.
kde/attica-5.86.0-i586-2.txz: Rebuilt.
kde/audiocd-kio-21.08.1-i586-2.txz: Rebuilt.
kde/baloo-5.86.0-i586-2.txz: Rebuilt.
kde/baloo-widgets-21.08.1-i586-2.txz: Rebuilt.
kde/blinken-21.08.1-i586-2.txz: Rebuilt.
kde/bluedevil-5.22.5-i586-2.txz: Rebuilt.
kde/bluez-qt-5.86.0-i586-2.txz: Rebuilt.
kde/bomber-21.08.1-i586-2.txz: Rebuilt.
kde/bovo-21.08.1-i586-2.txz: Rebuilt.
kde/breeze-5.22.5-i586-2.txz: Rebuilt.
kde/breeze-grub-5.22.5-i586-2.txz: Rebuilt.
kde/breeze-gtk-5.22.5-i586-2.txz: Rebuilt.
kde/calendarsupport-21.08.1-i586-2.txz: Rebuilt.
kde/calligra-3.2.1-i586-12.txz: Rebuilt.
kde/calligraplan-3.3.0-i586-3.txz: Rebuilt.
kde/cantor-21.08.1-i586-2.txz: Rebuilt.
kde/cervisia-21.08.1-i586-2.txz: Rebuilt.
kde/digikam-7.3.0-i586-2.txz: Rebuilt.
kde/dolphin-21.08.1-i586-2.txz: Rebuilt.
kde/dolphin-plugins-21.08.1-i586-2.txz: Rebuilt.
kde/dragon-21.08.1-i586-2.txz: Rebuilt.
kde/drkonqi-5.22.5-i586-2.txz: Rebuilt.
kde/elisa-21.08.1-i586-2.txz: Rebuilt.
kde/eventviews-21.08.1-i586-2.txz: Rebuilt.
kde/extra-cmake-modules-5.86.0-i586-2.txz: Rebuilt.
kde/falkon-3.1.0-i586-4.txz: Rebuilt.
kde/ffmpegthumbs-21.08.1-i586-2.txz: Rebuilt.
kde/filelight-21.08.1-i586-2.txz: Rebuilt.
kde/frameworkintegration-5.86.0-i586-2.txz: Rebuilt.
kde/granatier-21.08.1-i586-2.txz: Rebuilt.
kde/grantlee-editor-21.08.1-i586-2.txz: Rebuilt.
kde/grantleetheme-21.08.1-i586-2.txz: Rebuilt.
kde/gwenview-21.08.1-i586-2.txz: Rebuilt.
kde/incidenceeditor-21.08.1-i586-2.txz: Rebuilt.
kde/itinerary-21.08.1-i586-2.txz: Rebuilt.
kde/juk-21.08.1-i586-2.txz: Rebuilt.
kde/k3b-21.08.1-i586-2.txz: Rebuilt.
kde/kactivities-5.86.0-i586-2.txz: Rebuilt.
kde/kactivities-stats-5.86.0-i586-2.txz: Rebuilt.
kde/kactivitymanagerd-5.22.5-i586-2.txz: Rebuilt.
kde/kaddressbook-21.08.1-i586-2.txz: Rebuilt.
kde/kalarm-21.08.1-i586-2.txz: Rebuilt.
kde/kalarmcal-21.08.1-i586-2.txz: Rebuilt.
kde/kalgebra-21.08.1-i586-2.txz: Rebuilt.
kde/kalzium-21.08.1-i586-2.txz: Rebuilt.
kde/kamera-21.08.1-i586-2.txz: Rebuilt.
kde/kamoso-21.08.1-i586-2.txz: Rebuilt.
kde/kanagram-21.08.1-i586-2.txz: Rebuilt.
kde/kapidox-5.86.0-i586-2.txz: Rebuilt.
kde/kapman-21.08.1-i586-2.txz: Rebuilt.
kde/kapptemplate-21.08.1-i586-2.txz: Rebuilt.
kde/karchive-5.86.0-i586-2.txz: Rebuilt.
kde/kate-21.08.1-i586-2.txz: Rebuilt.
kde/katomic-21.08.1-i586-2.txz: Rebuilt.
kde/kauth-5.86.0-i586-2.txz: Rebuilt.
kde/kbackup-21.08.1-i586-2.txz: Rebuilt.
kde/kblackbox-21.08.1-i586-2.txz: Rebuilt.
kde/kblocks-21.08.1-i586-2.txz: Rebuilt.
kde/kbookmarks-5.86.0-i586-2.txz: Rebuilt.
kde/kbounce-21.08.1-i586-2.txz: Rebuilt.
kde/kbreakout-21.08.1-i586-2.txz: Rebuilt.
kde/kbruch-21.08.1-i586-2.txz: Rebuilt.
kde/kcachegrind-21.08.1-i586-2.txz: Rebuilt.
kde/kcalc-21.08.1-i586-2.txz: Rebuilt.
kde/kcalendarcore-5.86.0-i586-2.txz: Rebuilt.
kde/kcalutils-21.08.1-i586-2.txz: Rebuilt.
kde/kcharselect-21.08.1-i586-2.txz: Rebuilt.
kde/kcmutils-5.86.0-i586-2.txz: Rebuilt.
kde/kcodecs-5.86.0-i586-2.txz: Rebuilt.
kde/kcolorchooser-21.08.1-i586-2.txz: Rebuilt.
kde/kcompletion-5.86.0-i586-2.txz: Rebuilt.
kde/kconfig-5.86.0-i586-2.txz: Rebuilt.
kde/kconfigwidgets-5.86.0-i586-2.txz: Rebuilt.
kde/kcontacts-5.86.0-i586-2.txz: Rebuilt.
kde/kcoreaddons-5.86.0-i586-2.txz: Rebuilt.
kde/kcrash-5.86.0-i586-2.txz: Rebuilt.
kde/kcron-21.08.1-i586-2.txz: Rebuilt.
kde/kdav-5.86.0-i586-2.txz: Rebuilt.
kde/kdbusaddons-5.86.0-i586-2.txz: Rebuilt.
kde/kde-cli-tools-5.22.5-i586-2.txz: Rebuilt.
kde/kde-dev-scripts-21.08.1-i586-2.txz: Rebuilt.
kde/kde-dev-utils-21.08.1-i586-2.txz: Rebuilt.
kde/kde-gtk-config-5.22.5-i586-2.txz: Rebuilt.
kde/kdebugsettings-21.08.1-i586-2.txz: Rebuilt.
kde/kdeclarative-5.86.0-i586-2.txz: Rebuilt.
kde/kdeconnect-kde-21.08.1-i586-2.txz: Rebuilt.
kde/kdecoration-5.22.5-i586-2.txz: Rebuilt.
kde/kded-5.86.0-i586-2.txz: Rebuilt.
kde/kdeedu-data-21.08.1-i586-2.txz: Rebuilt.
kde/kdegraphics-mobipocket-21.08.1-i586-2.txz: Rebuilt.
kde/kdegraphics-thumbnailers-21.08.1-i586-2.txz: Rebuilt.
kde/kdelibs4support-5.86.0-i586-2.txz: Rebuilt.
kde/kdenetwork-filesharing-21.08.1-i586-2.txz: Rebuilt.
kde/kdenlive-21.08.1-i586-2.txz: Rebuilt.
kde/kdepim-addons-21.08.1-i586-2.txz: Rebuilt.
kde/kdepim-runtime-21.08.1-i586-2.txz: Rebuilt.
kde/kdeplasma-addons-5.22.5-i586-2.txz: Rebuilt.
kde/kdesdk-kioslaves-21.08.1-i586-2.txz: Rebuilt.
kde/kdesdk-thumbnailers-21.08.1-i586-2.txz: Rebuilt.
kde/kdesignerplugin-5.86.0-i586-2.txz: Rebuilt.
kde/kdesu-5.86.0-i586-2.txz: Rebuilt.
kde/kdev-php-5.6.2-i586-3.txz: Rebuilt.
kde/kdev-python-5.6.2-i586-3.txz: Rebuilt.
kde/kdevelop-5.6.2-i586-5.txz: Rebuilt.
kde/kdevelop-pg-qt-2.2.1-i586-4.txz: Rebuilt.
kde/kdewebkit-5.86.0-i586-2.txz: Rebuilt.
kde/kdf-21.08.1-i586-2.txz: Rebuilt.
kde/kdiagram-2.8.0-i586-4.txz: Rebuilt.
kde/kdialog-21.08.1-i586-2.txz: Rebuilt.
kde/kdiamond-21.08.1-i586-2.txz: Rebuilt.
kde/kdnssd-5.86.0-i586-2.txz: Rebuilt.
kde/kdoctools-5.86.0-i586-2.txz: Rebuilt.
kde/keditbookmarks-21.08.1-i586-2.txz: Rebuilt.
kde/kemoticons-5.86.0-i586-2.txz: Rebuilt.
kde/kfilemetadata-5.86.0-i586-2.txz: Rebuilt.
kde/kfind-21.08.1-i586-2.txz: Rebuilt.
kde/kfloppy-21.08.1-i586-2.txz: Rebuilt.
kde/kfourinline-21.08.1-i586-2.txz: Rebuilt.
kde/kgamma5-5.22.5-i586-2.txz: Rebuilt.
kde/kgeography-21.08.1-i586-2.txz: Rebuilt.
kde/kget-21.08.1-i586-2.txz: Rebuilt.
kde/kglobalaccel-5.86.0-i586-2.txz: Rebuilt.
kde/kgoldrunner-21.08.1-i586-2.txz: Rebuilt.
kde/kgpg-21.08.1-i586-2.txz: Rebuilt.
kde/kguiaddons-5.86.0-i586-2.txz: Rebuilt.
kde/khangman-21.08.1-i586-2.txz: Rebuilt.
kde/khelpcenter-21.08.1-i586-2.txz: Rebuilt.
kde/kholidays-5.86.0-i586-2.txz: Rebuilt.
kde/khotkeys-5.22.5-i586-2.txz: Rebuilt.
kde/khtml-5.86.0-i586-2.txz: Rebuilt.
kde/ki18n-5.86.0-i586-2.txz: Rebuilt.
kde/kiconthemes-5.86.0-i586-2.txz: Rebuilt.
kde/kid3-3.8.7-i586-2.txz: Rebuilt.
kde/kidentitymanagement-21.08.1-i586-2.txz: Rebuilt.
kde/kidletime-5.86.0-i586-2.txz: Rebuilt.
kde/kig-21.08.1-i586-2.txz: Rebuilt.
kde/kigo-21.08.1-i586-2.txz: Rebuilt.
kde/kile-2.9.93-i586-12.txz: Rebuilt.
kde/killbots-21.08.1-i586-2.txz: Rebuilt.
kde/kimageformats-5.86.0-i586-2.txz: Rebuilt.
kde/kimagemapeditor-21.08.1-i586-2.txz: Rebuilt.
kde/kimap-21.08.1-i586-2.txz: Rebuilt.
kde/kinfocenter-5.22.5-i586-2.txz: Rebuilt.
kde/kinit-5.86.0-i586-2.txz: Rebuilt.
kde/kio-5.86.0-i586-2.txz: Rebuilt.
kde/kio-extras-21.08.1-i586-2.txz: Rebuilt.
kde/kio-gdrive-21.08.1-i586-2.txz: Rebuilt.
kde/kipi-plugins-21.08.1-i586-2.txz: Rebuilt.
kde/kirigami-gallery-21.08.1-i586-2.txz: Rebuilt.
kde/kirigami2-5.86.0-i586-2.txz: Rebuilt.
kde/kiriki-21.08.1-i586-2.txz: Rebuilt.
kde/kitemmodels-5.86.0-i586-2.txz: Rebuilt.
kde/kitemviews-5.86.0-i586-2.txz: Rebuilt.
kde/kiten-21.08.1-i586-2.txz: Rebuilt.
kde/kitinerary-21.08.1-i586-2.txz: Rebuilt.
kde/kjobwidgets-5.86.0-i586-2.txz: Rebuilt.
kde/kjots-20201206_f7d555c-i586-4.txz: Rebuilt.
kde/kjs-5.86.0-i586-2.txz: Rebuilt.
kde/kjsembed-5.86.0-i586-2.txz: Rebuilt.
kde/kjumpingcube-21.08.1-i586-2.txz: Rebuilt.
kde/kldap-21.08.1-i586-2.txz: Rebuilt.
kde/kleopatra-21.08.1-i586-2.txz: Rebuilt.
kde/klickety-21.08.1-i586-2.txz: Rebuilt.
kde/klines-21.08.1-i586-2.txz: Rebuilt.
kde/kmag-21.08.1-i586-2.txz: Rebuilt.
kde/kmahjongg-21.08.1-i586-2.txz: Rebuilt.
kde/kmail-21.08.1-i586-2.txz: Rebuilt.
kde/kmail-account-wizard-21.08.1-i586-2.txz: Rebuilt.
kde/kmailtransport-21.08.1-i586-2.txz: Rebuilt.
kde/kmbox-21.08.1-i586-2.txz: Rebuilt.
kde/kmediaplayer-5.86.0-i586-2.txz: Rebuilt.
kde/kmenuedit-5.22.5-i586-2.txz: Rebuilt.
kde/kmime-21.08.1-i586-2.txz: Rebuilt.
kde/kmines-21.08.1-i586-2.txz: Rebuilt.
kde/kmix-21.08.1-i586-2.txz: Rebuilt.
kde/kmousetool-21.08.1-i586-2.txz: Rebuilt.
kde/kmouth-21.08.1-i586-2.txz: Rebuilt.
kde/kmplot-21.08.1-i586-2.txz: Rebuilt.
kde/kmymoney-5.1.2-i586-2.txz: Rebuilt.
kde/knavalbattle-21.08.1-i586-2.txz: Rebuilt.
kde/knetwalk-21.08.1-i586-2.txz: Rebuilt.
kde/knewstuff-5.86.0-i586-3.txz: Rebuilt.
kde/knights-21.08.1-i586-2.txz: Rebuilt.
kde/knotes-21.08.1-i586-2.txz: Rebuilt.
kde/knotifications-5.86.0-i586-2.txz: Rebuilt.
kde/knotifyconfig-5.86.0-i586-2.txz: Rebuilt.
kde/kolf-21.08.1-i586-2.txz: Rebuilt.
kde/kollision-21.08.1-i586-2.txz: Rebuilt.
kde/kolourpaint-21.08.1-i586-2.txz: Rebuilt.
kde/kompare-21.08.1-i586-2.txz: Rebuilt.
kde/konqueror-21.08.1-i586-2.txz: Rebuilt.
kde/konquest-21.08.1-i586-2.txz: Rebuilt.
kde/konsole-21.08.1-i586-2.txz: Rebuilt.
kde/kontact-21.08.1-i586-2.txz: Rebuilt.
kde/kontactinterface-21.08.1-i586-2.txz: Rebuilt.
kde/kontrast-21.08.1-i586-2.txz: Rebuilt.
kde/konversation-21.08.1-i586-2.txz: Rebuilt.
kde/kopeninghours-21.08.1-i586-2.txz: Rebuilt.
kde/kopete-21.08.1-i586-2.txz: Rebuilt.
kde/korganizer-21.08.1-i586-2.txz: Rebuilt.
kde/kosmindoormap-21.08.1-i586-2.txz: Rebuilt.
kde/kpackage-5.86.0-i586-2.txz: Rebuilt.
kde/kparts-5.86.0-i586-2.txz: Rebuilt.
kde/kpat-21.08.1-i586-2.txz: Rebuilt.
kde/kpeople-5.86.0-i586-2.txz: Rebuilt.
kde/kpeoplevcard-0.1-i586-4.txz: Rebuilt.
kde/kpimtextedit-21.08.1-i586-2.txz: Rebuilt.
kde/kpkpass-21.08.1-i586-2.txz: Rebuilt.
kde/kplotting-5.86.0-i586-2.txz: Rebuilt.
kde/kpmcore-21.08.1-i586-2.txz: Rebuilt.
kde/kpty-5.86.0-i586-2.txz: Rebuilt.
kde/kpublictransport-21.08.1-i586-2.txz: Rebuilt.
kde/kqtquickcharts-21.08.1-i586-2.txz: Rebuilt.
kde/kquickcharts-5.86.0-i586-2.txz: Rebuilt.
kde/krdc-21.08.1-i586-2.txz: Rebuilt.
kde/krename-5.0.1-i586-4.txz: Rebuilt.
kde/kreversi-21.08.1-i586-2.txz: Rebuilt.
kde/krfb-21.08.1-i586-2.txz: Rebuilt.
kde/krita-4.4.8-i586-3.txz: Rebuilt.
kde/kross-5.86.0-i586-2.txz: Rebuilt.
kde/kross-interpreters-21.08.1-i586-2.txz: Rebuilt.
kde/kruler-21.08.1-i586-2.txz: Rebuilt.
kde/krunner-5.86.0-i586-2.txz: Rebuilt.
kde/krusader-2.7.2-i586-4.txz: Rebuilt.
kde/kscreen-5.22.5-i586-2.txz: Rebuilt.
kde/kscreenlocker-5.22.5-i586-2.txz: Rebuilt.
kde/kservice-5.86.0-i586-2.txz: Rebuilt.
kde/kshisen-21.08.1-i586-2.txz: Rebuilt.
kde/ksirk-21.08.1-i586-2.txz: Rebuilt.
kde/ksmtp-21.08.1-i586-2.txz: Rebuilt.
kde/ksnakeduel-21.08.1-i586-2.txz: Rebuilt.
kde/kspaceduel-21.08.1-i586-2.txz: Rebuilt.
kde/ksquares-21.08.1-i586-2.txz: Rebuilt.
kde/ksshaskpass-5.22.5-i586-2.txz: Rebuilt.
kde/kstars-3.5.5-i586-2.txz: Rebuilt.
kde/ksudoku-21.08.1-i586-2.txz: Rebuilt.
kde/ksysguard-5.22.0-i586-2.txz: Rebuilt.
kde/ksystemlog-21.08.1-i586-2.txz: Rebuilt.
kde/ksystemstats-5.22.5-i586-2.txz: Rebuilt.
kde/kteatime-21.08.1-i586-2.txz: Rebuilt.
kde/ktexteditor-5.86.0-i586-2.txz: Rebuilt.
kde/ktextwidgets-5.86.0-i586-2.txz: Rebuilt.
kde/ktimer-21.08.1-i586-2.txz: Rebuilt.
kde/ktimetracker-5.0.1-i586-4.txz: Rebuilt.
kde/ktnef-21.08.1-i586-2.txz: Rebuilt.
kde/ktorrent-21.08.1-i586-2.txz: Rebuilt.
kde/ktouch-21.08.1-i586-2.txz: Rebuilt.
kde/kturtle-21.08.1-i586-2.txz: Rebuilt.
kde/kubrick-21.08.1-i586-2.txz: Rebuilt.
kde/kunitconversion-5.86.0-i586-2.txz: Rebuilt.
kde/kwallet-5.86.0-i586-2.txz: Rebuilt.
kde/kwallet-pam-5.22.5-i586-2.txz: Rebuilt.
kde/kwalletmanager-21.08.1-i586-2.txz: Rebuilt.
kde/kwave-21.08.1-i586-2.txz: Rebuilt.
kde/kwayland-5.86.0-i586-2.txz: Rebuilt.
kde/kwayland-integration-5.22.5-i586-2.txz: Rebuilt.
kde/kwayland-server-5.22.5-i586-2.txz: Rebuilt.
kde/kwidgetsaddons-5.86.0-i586-2.txz: Rebuilt.
kde/kwin-5.22.5-i586-2.txz: Rebuilt.
kde/kwindowsystem-5.86.0-i586-2.txz: Rebuilt.
kde/kwordquiz-21.08.1-i586-2.txz: Rebuilt.
kde/kwrited-5.22.5-i586-2.txz: Rebuilt.
kde/kxmlgui-5.86.0-i586-2.txz: Rebuilt.
kde/kxmlrpcclient-5.86.0-i586-2.txz: Rebuilt.
kde/latte-dock-0.10.2-i586-2.txz: Rebuilt.
kde/layer-shell-qt-5.22.5-i586-2.txz: Rebuilt.
kde/libgravatar-21.08.1-i586-2.txz: Rebuilt.
kde/libkcddb-21.08.1-i586-2.txz: Rebuilt.
kde/libkcompactdisc-21.08.1-i586-2.txz: Rebuilt.
kde/libkdcraw-21.08.1-i586-2.txz: Rebuilt.
kde/libkdegames-21.08.1-i586-2.txz: Rebuilt.
kde/libkdepim-21.08.1-i586-2.txz: Rebuilt.
kde/libkeduvocdocument-21.08.1-i586-2.txz: Rebuilt.
kde/libkexiv2-21.08.1-i586-2.txz: Rebuilt.
kde/libkgapi-21.08.1-i586-2.txz: Rebuilt.
kde/libkipi-21.08.1-i586-2.txz: Rebuilt.
kde/libkleo-21.08.1-i586-2.txz: Rebuilt.
kde/libkmahjongg-21.08.1-i586-2.txz: Rebuilt.
kde/libkomparediff2-21.08.1-i586-2.txz: Rebuilt.
kde/libksane-21.08.1-i586-2.txz: Rebuilt.
kde/libkscreen-5.22.5-i586-2.txz: Rebuilt.
kde/libksieve-21.08.1-i586-2.txz: Rebuilt.
kde/libksysguard-5.22.5-i586-2.txz: Rebuilt.
kde/libktorrent-21.08.1-i586-2.txz: Rebuilt.
kde/lokalize-21.08.1-i586-2.txz: Rebuilt.
kde/lskat-21.08.1-i586-2.txz: Rebuilt.
kde/mailcommon-21.08.1-i586-2.txz: Rebuilt.
kde/mailimporter-21.08.1-i586-2.txz: Rebuilt.
kde/marble-21.08.1-i586-2.txz: Rebuilt.
kde/markdownpart-21.08.1-i586-2.txz: Rebuilt.
kde/mbox-importer-21.08.1-i586-2.txz: Rebuilt.
kde/messagelib-21.08.1-i586-2.txz: Rebuilt.
kde/milou-5.22.5-i586-2.txz: Rebuilt.
kde/minuet-21.08.1-i586-2.txz: Rebuilt.
kde/modemmanager-qt-5.86.0-i586-2.txz: Rebuilt.
kde/networkmanager-qt-5.86.0-i586-2.txz: Rebuilt.
kde/okteta-0.26.6-i586-2.txz: Rebuilt.
kde/okular-21.08.1-i586-2.txz: Rebuilt.
kde/oxygen-5.22.5-i586-2.txz: Rebuilt.
kde/oxygen-gtk2-1.4.6-i586-4.txz: Rebuilt.
kde/palapeli-21.08.1-i586-2.txz: Rebuilt.
kde/parley-21.08.1-i586-2.txz: Rebuilt.
kde/partitionmanager-21.08.1-i586-2.txz: Rebuilt.
kde/picmi-21.08.1-i586-2.txz: Rebuilt.
kde/pim-data-exporter-21.08.1-i586-2.txz: Rebuilt.
kde/pim-sieve-editor-21.08.1-i586-2.txz: Rebuilt.
kde/pimcommon-21.08.1-i586-2.txz: Rebuilt.
kde/plasma-browser-integration-5.22.5-i586-2.txz: Rebuilt.
kde/plasma-desktop-5.22.5-i586-3.txz: Rebuilt.
kde/plasma-disks-5.22.5-i586-2.txz: Rebuilt.
kde/plasma-firewall-5.22.5-i586-2.txz: Rebuilt.
kde/plasma-framework-5.86.0-i586-2.txz: Rebuilt.
kde/plasma-integration-5.22.5-i586-2.txz: Rebuilt.
kde/plasma-nm-5.22.5-i586-2.txz: Rebuilt.
kde/plasma-pa-5.22.5-i586-2.txz: Rebuilt.
kde/plasma-sdk-5.22.5-i586-2.txz: Rebuilt.
kde/plasma-systemmonitor-5.22.5-i586-2.txz: Rebuilt.
kde/plasma-vault-5.22.5-i586-2.txz: Rebuilt.
kde/plasma-wayland-protocols-1.4.0-i586-2.txz: Rebuilt.
kde/plasma-workspace-5.22.5-i586-3.txz: Rebuilt.
kde/plasma-workspace-wallpapers-5.22.5-i586-2.txz: Rebuilt.
kde/polkit-kde-agent-1-5.22.5-i586-2.txz: Rebuilt.
kde/powerdevil-5.22.5-i586-2.txz: Rebuilt.
kde/poxml-21.08.1-i586-2.txz: Rebuilt.
kde/print-manager-21.08.1-i586-2.txz: Rebuilt.
kde/prison-5.86.0-i586-2.txz: Rebuilt.
kde/pulseaudio-qt-1.3-i586-2.txz: Rebuilt.
kde/purpose-5.86.0-i586-2.txz: Rebuilt.
kde/qqc2-breeze-style-5.22.5-i586-2.txz: Rebuilt.
kde/qqc2-desktop-style-5.86.0-i586-2.txz: Rebuilt.
kde/rocs-21.08.1-i586-2.txz: Rebuilt.
kde/sddm-0.19.0-i586-9.txz: Rebuilt.
kde/sddm-kcm-5.22.5-i586-2.txz: Rebuilt.
kde/skanlite-21.08.1-i586-2.txz: Rebuilt.
kde/solid-5.86.0-i586-2.txz: Rebuilt.
kde/sonnet-5.86.0-i586-2.txz: Rebuilt.
kde/spectacle-21.08.1-i586-2.txz: Rebuilt.
kde/step-21.08.1-i586-2.txz: Rebuilt.
kde/svgpart-21.08.1-i586-2.txz: Rebuilt.
kde/sweeper-21.08.1-i586-2.txz: Rebuilt.
kde/syndication-5.86.0-i586-2.txz: Rebuilt.
kde/syntax-highlighting-5.86.0-i586-2.txz: Rebuilt.
kde/systemsettings-5.22.5-i586-2.txz: Rebuilt.
kde/threadweaver-5.86.0-i586-2.txz: Rebuilt.
kde/umbrello-21.08.1-i586-2.txz: Rebuilt.
kde/wacomtablet-20201030_417d9d9-i586-4.txz: Rebuilt.
kde/xdg-desktop-portal-kde-5.22.5-i586-2.txz: Rebuilt.
kde/yakuake-21.08.1-i586-2.txz: Rebuilt.
kde/zeroconf-ioslave-21.08.1-i586-2.txz: Rebuilt.
l/mozilla-nss-3.71-i586-1.txz: Upgraded.
l/pipewire-0.3.38-i586-1.txz: Upgraded.
x/mesa-21.2.3-i586-1.txz: Upgraded.
extra/linux-5.14.9-nosmp-sdk/*: Upgraded.
isolinux/initrd.img: Rebuilt.
kernels/*: Upgraded.
d/ccache-4.4.2-i586-1.txz: Upgraded.
d/meson-0.59.2-i586-1.txz: Upgraded.
l/gc-8.0.6-i586-1.txz: Upgraded.
l/mlt-7.0.1-i586-2.txz: Rebuilt.
l/netpbm-10.96.00-i586-1.txz: Upgraded.
n/epic5-2.1.5-i586-2.txz: Rebuilt.
n/openssh-8.8p1-i586-2.txz: Rebuilt.
       Thanks to davjohn.
xap/NetworkManager-openvpn-1.8.16-i586-1.txz: Upgraded.
kde/knewstuff-5.86.0-i586-2.txz: Rebuilt.
l/pygobject3-3.42.0-i586-1.txz: Upgraded.
n/pinentry-1.2.0-i586-1.txz: Upgraded.
x/libinput-1.19.1-i586-1.txz: Upgraded.
xap/seamonkey-2.53.9.1-i686-1.txz: Upgraded.
n/nftables-1.0.0-i586-2.txz: Rebuilt.
xap/mozilla-thunderbird-91.1.2-i686-1.txz: Upgraded.
       This is a bugfix release.
a/coreutils-9.0-i586-3.txz: Rebuilt.
       Applied upstream patch:
ap/ghostscript-9.55.0-i586-1.txz: Upgraded.
ap/vim-8.2.3458-i586-1.txz: Upgraded.
d/vala-0.54.1-i586-1.txz: Upgraded.
l/at-spi2-core-2.42.0-i586-1.txz: Upgraded.
l/gexiv2-0.14.0-i586-1.txz: Upgraded.
l/gjs-1.70.0-i586-1.txz: Upgraded.
l/glib-networking-2.70.0-i586-1.txz: Upgraded.
l/glib2-2.70.0-i586-1.txz: Upgraded.
l/gobject-introspection-1.70.0-i586-1.txz: Upgraded.
l/libcap-2.59-i586-1.txz: Upgraded.
l/librsvg-2.52.0-i586-1.txz: Upgraded.
l/libsoup-2.74.0-i586-1.txz: Upgraded.
n/ModemManager-1.18.2-i586-1.txz: Upgraded.
n/NetworkManager-1.32.12-i586-1.txz: Upgraded.
n/tin-2.6.0-i586-1.txz: Upgraded.
xap/vim-gvim-8.2.3458-i586-1.txz: Upgraded.
Post Napisano: 07 Oct 2021, 15:22
Slackware 64-bit
Wed Oct 6 19:25:04 UTC 2021
a/hwdata-0.352-noarch-1.txz: Upgraded.
ap/nano-5.9-x86_64-1.txz: Upgraded.
d/mercurial-5.9.2-x86_64-1.txz: Upgraded.
l/libgnt-2.14.3-x86_64-1.txz: Upgraded.
l/librsvg-2.52.1-x86_64-1.txz: Upgraded.
l/mozjs78-78.15.0esr-x86_64-1.txz: Upgraded.
l/netpbm-10.96.01-x86_64-1.txz: Upgraded.
l/polkit-0.120-x86_64-1.txz: Upgraded.
n/openvpn-2.5.4-x86_64-1.txz: Upgraded.
x/xkeyboard-config-2.34-noarch-1.txz: Upgraded.
xap/gftp-2.7.0b-x86_64-3.txz: Rebuilt.
       Removed broken icon symlink. Thanks to marav.
xap/mozilla-thunderbird-91.2.0-x86_64-1.txz: Upgraded.
       https://www.mozilla.org/en-US/thunderbird/91.2.0/releasenotes/
extra/fltk/fltk-1.3.7-x86_64-1.txz: Upgraded.
Wed Oct 6 00:02:15 UTC 2021
a/glibc-zoneinfo-2021c-noarch-1.txz: Upgraded.
a/util-linux-2.37.2-x86_64-4.txz: Rebuilt.
       Removed broken /usr/share/bash-completion/completions/runuser symlink.
       Thanks to marav.
n/ca-certificates-20211005-noarch-1.txz: Upgraded.
       Don't install /etc/ca-certificates.conf as a .new file - it's an auto-
       generated list that will just end up suffering a mismatch with the files
       included in the package. Thanks to Weber Kai.
xap/mozilla-firefox-91.2.0esr-x86_64-1.txz: Upgraded.
       https://www.mozilla.org/en-US/firefox/91.2.0/releasenotes/
       https://www.mozilla.org/security/advisories/mfsa2021-45/
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-38496
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-38497
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-38498
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-32810
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-38500
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-38501
Slackware 32-bit
ap/nano-5.9-i586-1.txz: Upgraded.
d/mercurial-5.9.2-i586-1.txz: Upgraded.
l/libgnt-2.14.3-i586-1.txz: Upgraded.
l/librsvg-2.52.1-i586-1.txz: Upgraded.
l/mozjs78-78.15.0esr-i586-1.txz: Upgraded.
l/netpbm-10.96.01-i586-1.txz: Upgraded.
l/polkit-0.120-i586-1.txz: Upgraded.
n/openvpn-2.5.4-i586-1.txz: Upgraded.
xap/gftp-2.7.0b-i586-3.txz: Rebuilt.
xap/mozilla-thunderbird-91.2.0-i686-1.txz: Upgraded.
extra/fltk/fltk-1.3.7-i586-1.txz: Upgraded.
a/util-linux-2.37.2-i586-4.txz: Rebuilt.
       Thanks to marav.
xap/mozilla-firefox-91.2.0esr-i686-1.txz: Upgraded.
Post Napisano: 11 Oct 2021, 11:26
Slackware 64-bit
Sun Oct 10 22:20:01 UTC 2021
a/aaa_terminfo-6.2_20211009-x86_64-1.txz: Upgraded.
a/btrfs-progs-5.14.2-x86_64-1.txz: Upgraded.
ap/sc-im-20210927_64b1a41-x86_64-1.txz: Upgraded.
ap/undervolt-20210815_e39aea1-x86_64-1.txz: Upgraded.
d/gyp-20210831_d6c5dd51-x86_64-1.txz: Upgraded.
       Patched for Python 3.10. Thanks to nobodino.
kde/attica-5.87.0-x86_64-1.txz: Upgraded.
kde/baloo-5.87.0-x86_64-1.txz: Upgraded.
kde/bluez-qt-5.87.0-x86_64-1.txz: Upgraded.
kde/breeze-icons-5.87.0-noarch-1.txz: Upgraded.
kde/digikam-7.3.0-x86_64-3.txz: Rebuilt.
       Recompiled against opencv-4.5.4.
kde/extra-cmake-modules-5.87.0-x86_64-1.txz: Upgraded.
kde/frameworkintegration-5.87.0-x86_64-1.txz: Upgraded.
kde/kactivities-5.87.0-x86_64-1.txz: Upgraded.
kde/kactivities-stats-5.87.0-x86_64-1.txz: Upgraded.
kde/kapidox-5.87.0-x86_64-1.txz: Upgraded.
kde/karchive-5.87.0-x86_64-1.txz: Upgraded.
kde/kauth-5.87.0-x86_64-1.txz: Upgraded.
kde/kbookmarks-5.87.0-x86_64-1.txz: Upgraded.
kde/kcalendarcore-5.87.0-x86_64-1.txz: Upgraded.
kde/kcmutils-5.87.0-x86_64-1.txz: Upgraded.
kde/kcodecs-5.87.0-x86_64-1.txz: Upgraded.
kde/kcompletion-5.87.0-x86_64-1.txz: Upgraded.
kde/kconfig-5.87.0-x86_64-1.txz: Upgraded.
kde/kconfigwidgets-5.87.0-x86_64-1.txz: Upgraded.
kde/kcontacts-5.87.0-x86_64-1.txz: Upgraded.
kde/kcoreaddons-5.87.0-x86_64-1.txz: Upgraded.
kde/kcrash-5.87.0-x86_64-1.txz: Upgraded.
kde/kdav-5.87.0-x86_64-1.txz: Upgraded.
kde/kdbusaddons-5.87.0-x86_64-1.txz: Upgraded.
kde/kdeclarative-5.87.0-x86_64-1.txz: Upgraded.
kde/kded-5.87.0-x86_64-1.txz: Upgraded.
kde/kdelibs4support-5.87.0-x86_64-1.txz: Upgraded.
kde/kdesignerplugin-5.87.0-x86_64-1.txz: Upgraded.
kde/kdesu-5.87.0-x86_64-1.txz: Upgraded.
kde/kdewebkit-5.87.0-x86_64-1.txz: Upgraded.
kde/kdnssd-5.87.0-x86_64-1.txz: Upgraded.
kde/kdoctools-5.87.0-x86_64-1.txz: Upgraded.
kde/kemoticons-5.87.0-x86_64-1.txz: Upgraded.
kde/kfilemetadata-5.87.0-x86_64-1.txz: Upgraded.
kde/kglobalaccel-5.87.0-x86_64-1.txz: Upgraded.
kde/kguiaddons-5.87.0-x86_64-1.txz: Upgraded.
kde/kholidays-5.87.0-x86_64-1.txz: Upgraded.
kde/khtml-5.87.0-x86_64-1.txz: Upgraded.
kde/ki18n-5.87.0-x86_64-1.txz: Upgraded.
kde/kiconthemes-5.87.0-x86_64-1.txz: Upgraded.
kde/kidletime-5.87.0-x86_64-1.txz: Upgraded.
kde/kimageformats-5.87.0-x86_64-1.txz: Upgraded.
kde/kinit-5.87.0-x86_64-1.txz: Upgraded.
kde/kio-5.87.0-x86_64-1.txz: Upgraded.
kde/kirigami2-5.87.0-x86_64-1.txz: Upgraded.
kde/kitemmodels-5.87.0-x86_64-1.txz: Upgraded.
kde/kitemviews-5.87.0-x86_64-1.txz: Upgraded.
kde/kjobwidgets-5.87.0-x86_64-1.txz: Upgraded.
kde/kjots-20211003_4109f07-x86_64-1.txz: Upgraded.
kde/kjs-5.87.0-x86_64-1.txz: Upgraded.
kde/kjsembed-5.87.0-x86_64-1.txz: Upgraded.
kde/kmediaplayer-5.87.0-x86_64-1.txz: Upgraded.
kde/knewstuff-5.87.0-x86_64-1.txz: Upgraded.
kde/knotifications-5.87.0-x86_64-1.txz: Upgraded.
kde/knotifyconfig-5.87.0-x86_64-1.txz: Upgraded.
kde/kpackage-5.87.0-x86_64-1.txz: Upgraded.
kde/kparts-5.87.0-x86_64-1.txz: Upgraded.
kde/kpeople-5.87.0-x86_64-1.txz: Upgraded.
kde/kplotting-5.87.0-x86_64-1.txz: Upgraded.
kde/kpty-5.87.0-x86_64-1.txz: Upgraded.
kde/kquickcharts-5.87.0-x86_64-1.txz: Upgraded.
kde/kross-5.87.0-x86_64-1.txz: Upgraded.
kde/krunner-5.87.0-x86_64-1.txz: Upgraded.
kde/kservice-5.87.0-x86_64-1.txz: Upgraded.
kde/ktexteditor-5.87.0-x86_64-1.txz: Upgraded.
kde/ktextwidgets-5.87.0-x86_64-1.txz: Upgraded.
kde/kunitconversion-5.87.0-x86_64-1.txz: Upgraded.
kde/kwallet-5.87.0-x86_64-1.txz: Upgraded.
kde/kwayland-5.87.0-x86_64-1.txz: Upgraded.
kde/kwidgetsaddons-5.87.0-x86_64-1.txz: Upgraded.
kde/kwindowsystem-5.87.0-x86_64-1.txz: Upgraded.
kde/kxmlgui-5.87.0-x86_64-1.txz: Upgraded.
kde/kxmlrpcclient-5.87.0-x86_64-1.txz: Upgraded.
kde/modemmanager-qt-5.87.0-x86_64-1.txz: Upgraded.
kde/networkmanager-qt-5.87.0-x86_64-1.txz: Upgraded.
kde/oxygen-icons5-5.87.0-noarch-1.txz: Upgraded.
kde/plasma-framework-5.87.0-x86_64-1.txz: Upgraded.
kde/prison-5.87.0-x86_64-1.txz: Upgraded.
kde/purpose-5.87.0-x86_64-1.txz: Upgraded.
kde/qqc2-desktop-style-5.87.0-x86_64-1.txz: Upgraded.
kde/solid-5.87.0-x86_64-1.txz: Upgraded.
kde/sonnet-5.87.0-x86_64-1.txz: Upgraded.
kde/syndication-5.87.0-x86_64-1.txz: Upgraded.
kde/syntax-highlighting-5.87.0-x86_64-1.txz: Upgraded.
kde/threadweaver-5.87.0-x86_64-1.txz: Upgraded.
kde/wacomtablet-20210906_d1e216a-x86_64-1.txz: Upgraded.
l/QtAV-20210414_305e5404-x86_64-1.txz: Upgraded.
l/ffmpeg-4.4-x86_64-2.txz: Rebuilt.
       Recompiled against vid.stab-20201110_f9166e9.
l/gst-plugins-bad-free-1.18.5-x86_64-2.txz: Rebuilt.
l/libical-3.0.11-x86_64-1.txz: Upgraded.
l/mlt-7.0.1-x86_64-3.txz: Rebuilt.
l/ncurses-6.2_20211009-x86_64-1.txz: Upgraded.
l/opencv-4.5.4-x86_64-1.txz: Upgraded.
       Changed ABI.
l/python-certifi-2021.10.8-x86_64-1.txz: Upgraded.
l/vid.stab-20201110_f9166e9-x86_64-1.txz: Upgraded.
n/wget2-2.0.0-x86_64-2.txz: Rebuilt.
       Rebuilt using --with-openssl. Thanks to walecha and marav.
t/texlive-2021.210418-x86_64-2.txz: Rebuilt.
       Removed broken texdoctk symlink. Thanks to marav, drumz, and franzen.
Sun Oct 10 00:11:13 UTC 2021
A new Python (and related rebuilds), the latest release of the KDE Gear
applications, and a new kernel. Enjoy! :-)
a/aaa_libraries-15.0-x86_64-10.txz: Rebuilt.
       Upgraded: libcap.so.2.59, libglib-2.0.so.0.7000.0,
       libgmodule-2.0.so.0.7000.0, libgobject-2.0.so.0.7000.0,
       libgthread-2.0.so.0.7000.0, libpcre2-8.so.0.10.3.
       Removed: libboost*.so.1.76.0, libicu*.so.68.2
a/kernel-generic-5.14.11-x86_64-1.txz: Upgraded.
a/kernel-huge-5.14.11-x86_64-1.txz: Upgraded.
a/kernel-modules-5.14.11-x86_64-1.txz: Upgraded.
a/libblockdev-2.26-x86_64-2.txz: Rebuilt.
a/libbytesize-2.6-x86_64-2.txz: Rebuilt.
a/libpwquality-1.4.4-x86_64-5.txz: Rebuilt.
a/util-linux-2.37.2-x86_64-5.txz: Rebuilt.
a/volume_key-0.3.12-x86_64-4.txz: Rebuilt.
ap/hplip-3.20.5-x86_64-4.txz: Rebuilt.
ap/linuxdoc-tools-0.9.82-x86_64-2.txz: Rebuilt.
ap/rpm-4.16.1.3-x86_64-2.txz: Rebuilt.
ap/undervolt-20201024_13fa33d-x86_64-4.txz: Rebuilt.
ap/vim-8.2.3487-x86_64-1.txz: Upgraded.
d/Cython-0.29.24-x86_64-2.txz: Rebuilt.
d/automake-1.16.5-noarch-1.txz: Upgraded.
       Needed to properly detect python-3.10. If you see anything detecting the
       Python version as 3.1, you'll need to run autoreconf -vif before ./configure.
d/distcc-3.4-x86_64-2.txz: Rebuilt.
d/gdb-11.1-x86_64-3.txz: Rebuilt.
d/gyp-20200512_caa60026-x86_64-5.txz: Rebuilt.
d/kernel-headers-5.14.11-x86-1.txz: Upgraded.
d/llvm-12.0.1-x86_64-2.txz: Rebuilt.
d/mercurial-5.9.2-x86_64-2.txz: Rebuilt.
d/meson-0.59.2-x86_64-2.txz: Rebuilt.
d/python-pip-21.2.4-x86_64-2.txz: Rebuilt.
d/python-setuptools-58.2.0-x86_64-2.txz: Rebuilt.
d/python3-3.10.0-x86_64-1.txz: Upgraded.
d/scons-4.0.1-x86_64-5.txz: Rebuilt.
k/kernel-source-5.14.11-noarch-1.txz: Upgraded.
kde/akonadi-21.08.2-x86_64-1.txz: Upgraded.
kde/akonadi-calendar-21.08.2-x86_64-1.txz: Upgraded.
kde/akonadi-calendar-tools-21.08.2-x86_64-1.txz: Upgraded.
kde/akonadi-contacts-21.08.2-x86_64-1.txz: Upgraded.
kde/akonadi-import-wizard-21.08.2-x86_64-1.txz: Upgraded.
kde/akonadi-mime-21.08.2-x86_64-1.txz: Upgraded.
kde/akonadi-notes-21.08.2-x86_64-1.txz: Upgraded.
kde/akonadi-search-21.08.2-x86_64-1.txz: Upgraded.
kde/akonadiconsole-21.08.2-x86_64-1.txz: Upgraded.
kde/akregator-21.08.2-x86_64-1.txz: Upgraded.
kde/analitza-21.08.2-x86_64-1.txz: Upgraded.
kde/ark-21.08.2-x86_64-1.txz: Upgraded.
kde/artikulate-21.08.2-x86_64-1.txz: Upgraded.
kde/audiocd-kio-21.08.2-x86_64-1.txz: Upgraded.
kde/baloo-widgets-21.08.2-x86_64-1.txz: Upgraded.
kde/blinken-21.08.2-x86_64-1.txz: Upgraded.
kde/bomber-21.08.2-x86_64-1.txz: Upgraded.
kde/bovo-21.08.2-x86_64-1.txz: Upgraded.
kde/calendarsupport-21.08.2-x86_64-1.txz: Upgraded.
kde/cantor-21.08.2-x86_64-1.txz: Upgraded.
kde/cervisia-21.08.2-x86_64-1.txz: Upgraded.
kde/dolphin-21.08.2-x86_64-1.txz: Upgraded.
kde/dolphin-plugins-21.08.2-x86_64-1.txz: Upgraded.
kde/dragon-21.08.2-x86_64-1.txz: Upgraded.
kde/elisa-21.08.2-x86_64-1.txz: Upgraded.
kde/eventviews-21.08.2-x86_64-1.txz: Upgraded.
kde/extra-cmake-modules-5.86.0-x86_64-3.txz: Rebuilt.
       Increment maximum python3 version.
kde/ffmpegthumbs-21.08.2-x86_64-1.txz: Upgraded.
kde/filelight-21.08.2-x86_64-1.txz: Upgraded.
kde/granatier-21.08.2-x86_64-1.txz: Upgraded.
kde/grantlee-editor-21.08.2-x86_64-1.txz: Upgraded.
kde/grantleetheme-21.08.2-x86_64-1.txz: Upgraded.
kde/gwenview-21.08.2-x86_64-1.txz: Upgraded.
kde/incidenceeditor-21.08.2-x86_64-1.txz: Upgraded.
kde/itinerary-21.08.2-x86_64-1.txz: Upgraded.
kde/juk-21.08.2-x86_64-1.txz: Upgraded.
kde/k3b-21.08.2-x86_64-1.txz: Upgraded.
kde/kaddressbook-21.08.2-x86_64-1.txz: Upgraded.
kde/kalarm-21.08.2-x86_64-1.txz: Upgraded.
kde/kalarmcal-21.08.2-x86_64-1.txz: Upgraded.
kde/kalgebra-21.08.2-x86_64-1.txz: Upgraded.
kde/kalzium-21.08.2-x86_64-1.txz: Upgraded.
kde/kamera-21.08.2-x86_64-1.txz: Upgraded.
kde/kamoso-21.08.2-x86_64-1.txz: Upgraded.
kde/kanagram-21.08.2-x86_64-1.txz: Upgraded.
kde/kapidox-5.86.0-x86_64-3.txz: Rebuilt.
kde/kapman-21.08.2-x86_64-1.txz: Upgraded.
kde/kapptemplate-21.08.2-x86_64-1.txz: Upgraded.
kde/kate-21.08.2-x86_64-1.txz: Upgraded.
kde/katomic-21.08.2-x86_64-1.txz: Upgraded.
kde/kauth-5.86.0-x86_64-3.txz: Rebuilt.
kde/kbackup-21.08.2-x86_64-1.txz: Upgraded.
kde/kblackbox-21.08.2-x86_64-1.txz: Upgraded.
kde/kblocks-21.08.2-x86_64-1.txz: Upgraded.
kde/kbounce-21.08.2-x86_64-1.txz: Upgraded.
kde/kbreakout-21.08.2-x86_64-1.txz: Upgraded.
kde/kbruch-21.08.2-x86_64-1.txz: Upgraded.
kde/kcachegrind-21.08.2-x86_64-1.txz: Upgraded.
kde/kcalc-21.08.2-x86_64-1.txz: Upgraded.
kde/kcalutils-21.08.2-x86_64-1.txz: Upgraded.
kde/kcharselect-21.08.2-x86_64-1.txz: Upgraded.
kde/kcodecs-5.86.0-x86_64-3.txz: Rebuilt.
kde/kcolorchooser-21.08.2-x86_64-1.txz: Upgraded.
kde/kcompletion-5.86.0-x86_64-3.txz: Rebuilt.
kde/kconfig-5.86.0-x86_64-3.txz: Rebuilt.
kde/kconfigwidgets-5.86.0-x86_64-3.txz: Rebuilt.
kde/kcoreaddons-5.86.0-x86_64-3.txz: Rebuilt.
kde/kcron-21.08.2-x86_64-1.txz: Upgraded.
kde/kdbusaddons-5.86.0-x86_64-3.txz: Rebuilt.
kde/kde-dev-scripts-21.08.2-x86_64-1.txz: Upgraded.
kde/kde-dev-utils-21.08.2-x86_64-1.txz: Upgraded.
kde/kdebugsettings-21.08.2-x86_64-1.txz: Upgraded.
kde/kdeconnect-kde-21.08.2-x86_64-1.txz: Upgraded.
kde/kdeedu-data-21.08.2-x86_64-1.txz: Upgraded.
kde/kdegraphics-mobipocket-21.08.2-x86_64-1.txz: Upgraded.
kde/kdegraphics-thumbnailers-21.08.2-x86_64-1.txz: Upgraded.
kde/kdenetwork-filesharing-21.08.2-x86_64-1.txz: Upgraded.
kde/kdenlive-21.08.2-x86_64-1.txz: Upgraded.
kde/kdepim-addons-21.08.2-x86_64-1.txz: Upgraded.
kde/kdepim-runtime-21.08.2-x86_64-1.txz: Upgraded.
kde/kdesdk-kioslaves-21.08.2-x86_64-1.txz: Upgraded.
kde/kdesdk-thumbnailers-21.08.2-x86_64-1.txz: Upgraded.
kde/kdev-python-5.6.2-x86_64-3.txz: Removed.
       Due to the removal of the old parser from Python 3.10, this is no longer
       compatible. We'll keep an eye on upstream to see if this changes, though.
kde/kdf-21.08.2-x86_64-1.txz: Upgraded.
kde/kdialog-21.08.2-x86_64-1.txz: Upgraded.
kde/kdiamond-21.08.2-x86_64-1.txz: Upgraded.
kde/keditbookmarks-21.08.2-x86_64-1.txz: Upgraded.
kde/kfind-21.08.2-x86_64-1.txz: Upgraded.
kde/kfloppy-21.08.2-x86_64-1.txz: Upgraded.
kde/kfourinline-21.08.2-x86_64-1.txz: Upgraded.
kde/kgeography-21.08.2-x86_64-1.txz: Upgraded.
kde/kget-21.08.2-x86_64-1.txz: Upgraded.
kde/kgoldrunner-21.08.2-x86_64-1.txz: Upgraded.
kde/kgpg-21.08.2-x86_64-1.txz: Upgraded.
kde/kguiaddons-5.86.0-x86_64-3.txz: Rebuilt.
kde/khangman-21.08.2-x86_64-1.txz: Upgraded.
kde/khelpcenter-21.08.2-x86_64-1.txz: Upgraded.
kde/ki18n-5.86.0-x86_64-3.txz: Rebuilt.
kde/kidentitymanagement-21.08.2-x86_64-1.txz: Upgraded.
kde/kig-21.08.2-x86_64-1.txz: Upgraded.
kde/kigo-21.08.2-x86_64-1.txz: Upgraded.
kde/killbots-21.08.2-x86_64-1.txz: Upgraded.
kde/kimagemapeditor-21.08.2-x86_64-1.txz: Upgraded.
kde/kimap-21.08.2-x86_64-1.txz: Upgraded.
kde/kio-extras-21.08.2-x86_64-1.txz: Upgraded.
kde/kio-gdrive-21.08.2-x86_64-1.txz: Upgraded.
kde/kipi-plugins-21.08.2-x86_64-1.txz: Upgraded.
kde/kirigami-gallery-21.08.2-x86_64-1.txz: Upgraded.
kde/kiriki-21.08.2-x86_64-1.txz: Upgraded.
kde/kitemmodels-5.86.0-x86_64-3.txz: Rebuilt.
kde/kitemviews-5.86.0-x86_64-3.txz: Rebuilt.
kde/kiten-21.08.2-x86_64-1.txz: Upgraded.
kde/kitinerary-21.08.2-x86_64-1.txz: Upgraded.
kde/kjobwidgets-5.86.0-x86_64-3.txz: Rebuilt.
kde/kjumpingcube-21.08.2-x86_64-1.txz: Upgraded.
kde/kldap-21.08.2-x86_64-1.txz: Upgraded.
kde/kleopatra-21.08.2-x86_64-1.txz: Upgraded.
kde/klickety-21.08.2-x86_64-1.txz: Upgraded.
kde/klines-21.08.2-x86_64-1.txz: Upgraded.
kde/kmag-21.08.2-x86_64-1.txz: Upgraded.
kde/kmahjongg-21.08.2-x86_64-1.txz: Upgraded.
kde/kmail-21.08.2-x86_64-1.txz: Upgraded.
kde/kmail-account-wizard-21.08.2-x86_64-1.txz: Upgraded.
kde/kmailtransport-21.08.2-x86_64-1.txz: Upgraded.
kde/kmbox-21.08.2-x86_64-1.txz: Upgraded.
kde/kmime-21.08.2-x86_64-1.txz: Upgraded.
kde/kmines-21.08.2-x86_64-1.txz: Upgraded.
kde/kmix-21.08.2-x86_64-1.txz: Upgraded.
kde/kmousetool-21.08.2-x86_64-1.txz: Upgraded.
kde/kmouth-21.08.2-x86_64-1.txz: Upgraded.
kde/kmplot-21.08.2-x86_64-1.txz: Upgraded.
kde/kmymoney-5.1.2-x86_64-3.txz: Rebuilt.
kde/knavalbattle-21.08.2-x86_64-1.txz: Upgraded.
kde/knetwalk-21.08.2-x86_64-1.txz: Upgraded.
kde/knights-21.08.2-x86_64-1.txz: Upgraded.
kde/knotes-21.08.2-x86_64-1.txz: Upgraded.
kde/kolf-21.08.2-x86_64-1.txz: Upgraded.
kde/kollision-21.08.2-x86_64-1.txz: Upgraded.
kde/kolourpaint-21.08.2-x86_64-1.txz: Upgraded.
kde/kompare-21.08.2-x86_64-1.txz: Upgraded.
kde/konqueror-21.08.2-x86_64-1.txz: Upgraded.
kde/konquest-21.08.2-x86_64-1.txz: Upgraded.
kde/konsole-21.08.2-x86_64-1.txz: Upgraded.
kde/kontact-21.08.2-x86_64-1.txz: Upgraded.
kde/kontactinterface-21.08.2-x86_64-1.txz: Upgraded.
kde/kontrast-21.08.2-x86_64-1.txz: Upgraded.
kde/konversation-21.08.2-x86_64-1.txz: Upgraded.
kde/kopeninghours-21.08.2-x86_64-1.txz: Upgraded.
kde/kopete-21.08.2-x86_64-1.txz: Upgraded.
kde/korganizer-21.08.2-x86_64-1.txz: Upgraded.
kde/kosmindoormap-21.08.2-x86_64-1.txz: Upgraded.
kde/kpat-21.08.2-x86_64-1.txz: Upgraded.
kde/kpimtextedit-21.08.2-x86_64-1.txz: Upgraded.
kde/kpkpass-21.08.2-x86_64-1.txz: Upgraded.
kde/kpmcore-21.08.2-x86_64-1.txz: Upgraded.
kde/kpublictransport-21.08.2-x86_64-1.txz: Upgraded.
kde/kqtquickcharts-21.08.2-x86_64-1.txz: Upgraded.
kde/krdc-21.08.2-x86_64-1.txz: Upgraded.
kde/kreversi-21.08.2-x86_64-1.txz: Upgraded.
kde/krfb-21.08.2-x86_64-1.txz: Upgraded.
kde/krita-4.4.8-x86_64-5.txz: Rebuilt.
kde/kross-interpreters-21.08.2-x86_64-1.txz: Upgraded.
kde/kruler-21.08.2-x86_64-1.txz: Upgraded.
kde/kshisen-21.08.2-x86_64-1.txz: Upgraded.
kde/ksirk-21.08.2-x86_64-1.txz: Upgraded.
kde/ksmtp-21.08.2-x86_64-1.txz: Upgraded.
kde/ksnakeduel-21.08.2-x86_64-1.txz: Upgraded.
kde/kspaceduel-21.08.2-x86_64-1.txz: Upgraded.
kde/ksquares-21.08.2-x86_64-1.txz: Upgraded.
kde/ksudoku-21.08.2-x86_64-1.txz: Upgraded.
kde/ksystemlog-21.08.2-x86_64-1.txz: Upgraded.
kde/kteatime-21.08.2-x86_64-1.txz: Upgraded.
kde/ktimer-21.08.2-x86_64-1.txz: Upgraded.
kde/ktnef-21.08.2-x86_64-1.txz: Upgraded.
kde/ktorrent-21.08.2-x86_64-1.txz: Upgraded.
kde/ktouch-21.08.2-x86_64-1.txz: Upgraded.
kde/kturtle-21.08.2-x86_64-1.txz: Upgraded.
kde/kubrick-21.08.2-x86_64-1.txz: Upgraded.
kde/kwalletmanager-21.08.2-x86_64-1.txz: Upgraded.
kde/kwave-21.08.2-x86_64-1.txz: Upgraded.
kde/kwidgetsaddons-5.86.0-x86_64-3.txz: Rebuilt.
kde/kwordquiz-21.08.2-x86_64-1.txz: Upgraded.
kde/libgravatar-21.08.2-x86_64-1.txz: Upgraded.
kde/libkcddb-21.08.2-x86_64-1.txz: Upgraded.
kde/libkcompactdisc-21.08.2-x86_64-1.txz: Upgraded.
kde/libkdcraw-21.08.2-x86_64-1.txz: Upgraded.
kde/libkdegames-21.08.2-x86_64-1.txz: Upgraded.
kde/libkdepim-21.08.2-x86_64-1.txz: Upgraded.
kde/libkeduvocdocument-21.08.2-x86_64-1.txz: Upgraded.
kde/libkexiv2-21.08.2-x86_64-1.txz: Upgraded.
kde/libkgapi-21.08.2-x86_64-1.txz: Upgraded.
kde/libkipi-21.08.2-x86_64-1.txz: Upgraded.
kde/libkleo-21.08.2-x86_64-1.txz: Upgraded.
kde/libkmahjongg-21.08.2-x86_64-1.txz: Upgraded.
kde/libkomparediff2-21.08.2-x86_64-1.txz: Upgraded.
kde/libksane-21.08.2-x86_64-1.txz: Upgraded.
kde/libksieve-21.08.2-x86_64-1.txz: Upgraded.
kde/libktorrent-21.08.2-x86_64-1.txz: Upgraded.
kde/lokalize-21.08.2-x86_64-1.txz: Upgraded.
kde/lskat-21.08.2-x86_64-1.txz: Upgraded.
kde/mailcommon-21.08.2-x86_64-1.txz: Upgraded.
kde/mailimporter-21.08.2-x86_64-1.txz: Upgraded.
kde/marble-21.08.2-x86_64-1.txz: Upgraded.
kde/markdownpart-21.08.2-x86_64-1.txz: Upgraded.
kde/mbox-importer-21.08.2-x86_64-1.txz: Upgraded.
kde/messagelib-21.08.2-x86_64-1.txz: Upgraded.
kde/minuet-21.08.2-x86_64-1.txz: Upgraded.
kde/okular-21.08.2-x86_64-1.txz: Upgraded.
kde/palapeli-21.08.2-x86_64-1.txz: Upgraded.
kde/parley-21.08.2-x86_64-1.txz: Upgraded.
kde/partitionmanager-21.08.2-x86_64-1.txz: Upgraded.
kde/picmi-21.08.2-x86_64-1.txz: Upgraded.
kde/pim-data-exporter-21.08.2-x86_64-1.txz: Upgraded.
kde/pim-sieve-editor-21.08.2-x86_64-1.txz: Upgraded.
kde/pimcommon-21.08.2-x86_64-1.txz: Upgraded.
kde/poxml-21.08.2-x86_64-1.txz: Upgraded.
kde/print-manager-21.08.2-x86_64-1.txz: Upgraded.
kde/rocs-21.08.2-x86_64-1.txz: Upgraded.
kde/skanlite-21.08.2-x86_64-1.txz: Upgraded.
kde/spectacle-21.08.2-x86_64-1.txz: Upgraded.
kde/step-21.08.2-x86_64-1.txz: Upgraded.
kde/svgpart-21.08.2-x86_64-1.txz: Upgraded.
kde/sweeper-21.08.2-x86_64-1.txz: Upgraded.
kde/umbrello-21.08.2-x86_64-1.txz: Upgraded.
kde/yakuake-21.08.2-x86_64-1.txz: Upgraded.
kde/zeroconf-ioslave-21.08.2-x86_64-1.txz: Upgraded.
l/M2Crypto-0.38.0-x86_64-2.txz: Rebuilt.
l/Mako-1.1.4-x86_64-4.txz: Rebuilt.
l/PyQt5-5.15.2-x86_64-4.txz: Rebuilt.
l/QScintilla-2.11.6-x86_64-4.txz: Rebuilt.
l/brotli-1.0.9-x86_64-6.txz: Rebuilt.
l/dbus-python-1.2.18-x86_64-2.txz: Rebuilt.
l/gexiv2-0.14.0-x86_64-2.txz: Rebuilt.
l/glade-3.38.2-x86_64-4.txz: Rebuilt.
l/gobject-introspection-1.70.0-x86_64-2.txz: Rebuilt.
l/lensfun-0.3.95-x86_64-4.txz: Rebuilt.
l/libcaca-0.99.beta19-x86_64-10.txz: Rebuilt.
l/libcap-ng-0.8.2-x86_64-4.txz: Rebuilt.
l/libimobiledevice-20200615_4791a82-x86_64-5.txz: Rebuilt.
l/libproxy-0.4.17-x86_64-4.txz: Rebuilt.
l/libwebp-1.2.1-x86_64-2.txz: Rebuilt.
l/libxml2-2.9.12-x86_64-2.txz: Rebuilt.
l/newt-0.52.21-x86_64-6.txz: Rebuilt.
l/openexr-2.5.7-x86_64-3.txz: Rebuilt.
l/pycairo-1.20.1-x86_64-2.txz: Rebuilt.
l/pycups-2.0.1-x86_64-5.txz: Rebuilt.
l/pycurl-7.44.1-x86_64-2.txz: Rebuilt.
l/pygobject3-3.42.0-x86_64-2.txz: Rebuilt.
l/pyparsing-2.4.7-x86_64-5.txz: Rebuilt.
l/python-appdirs-1.4.4-x86_64-5.txz: Rebuilt.
l/python-certifi-2021.5.30-x86_64-2.txz: Rebuilt.
l/python-cffi-1.14.6-x86_64-2.txz: Rebuilt.
l/python-chardet-4.0.0-x86_64-4.txz: Rebuilt.
l/python-charset-normalizer-2.0.6-x86_64-2.txz: Rebuilt.
l/python-distro-1.5.0-x86_64-5.txz: Rebuilt.
l/python-dnspython-2.1.0-x86_64-2.txz: Rebuilt.
l/python-docutils-0.17.1-x86_64-2.txz: Rebuilt.
l/python-future-0.18.2-x86_64-6.txz: Rebuilt.
l/python-idna-3.2-x86_64-2.txz: Rebuilt.
l/python-markdown-3.3.4-x86_64-2.txz: Rebuilt.
l/python-notify2-0.3.1-x86_64-9.txz: Rebuilt.
l/python-packaging-21.0-x86_64-2.txz: Rebuilt.
l/python-pillow-8.3.2-x86_64-2.txz: Rebuilt.
l/python-ply-3.11-x86_64-7.txz: Rebuilt.
l/python-pycparser-2.20-x86_64-2.txz: Rebuilt.
l/python-pygments-2.10.0-x86_64-2.txz: Rebuilt.
l/python-pysol_cards-0.10.2-x86_64-2.txz: Rebuilt.
l/python-random2-1.0.1-x86_64-4.txz: Rebuilt.
l/python-requests-2.26.0-x86_64-2.txz: Rebuilt.
l/python-sane-2.9.1-x86_64-4.txz: Rebuilt.
l/python-six-1.16.0-x86_64-2.txz: Rebuilt.
l/python-urllib3-1.26.7-x86_64-2.txz: Rebuilt.
l/sip-4.19.25-x86_64-2.txz: Rebuilt.
l/speech-dispatcher-0.10.2-x86_64-4.txz: Rebuilt.
l/system-config-printer-1.5.15-x86_64-4.txz: Rebuilt.
l/talloc-2.3.3-x86_64-2.txz: Rebuilt.
l/tdb-1.4.5-x86_64-2.txz: Rebuilt.
l/tevent-0.11.0-x86_64-2.txz: Rebuilt.
n/bind-9.16.21-x86_64-5.txz: Rebuilt.
n/epic5-2.1.6-x86_64-2.txz: Rebuilt.
n/fetchmail-6.4.22-x86_64-2.txz: Rebuilt.
n/getmail-6.18.4-x86_64-2.txz: Rebuilt.
n/gpgme-1.16.0-x86_64-2.txz: Rebuilt.
n/net-snmp-5.9.1-x86_64-2.txz: Rebuilt.
n/nftables-1.0.0-x86_64-3.txz: Rebuilt.
n/nss-pam-ldapd-0.9.11-x86_64-4.txz: Rebuilt.
n/obexftp-0.24.2-x86_64-9.txz: Rebuilt.
n/pssh-2.3.4-x86_64-5.txz: Rebuilt.
n/samba-4.15.0-x86_64-2.txz: Rebuilt.
x/ibus-1.5.25-x86_64-2.txz: Rebuilt.
x/ibus-anthy-1.5.13-x86_64-2.txz: Rebuilt.
x/ibus-hangul-1.5.4-x86_64-4.txz: Rebuilt.
x/ibus-libpinyin-1.12.1-x86_64-2.txz: Rebuilt.
x/ibus-table-1.14.1-x86_64-2.txz: Rebuilt.
x/pyxdg-0.27-x86_64-5.txz: Rebuilt.
x/xcb-proto-1.14.1-x86_64-5.txz: Rebuilt.
xap/blueman-2.2.2-x86_64-2.txz: Rebuilt.
xap/hexchat-2.16.0-x86_64-2.txz: Rebuilt.
xap/vim-gvim-8.2.3487-x86_64-1.txz: Upgraded.
extra/brltty/brltty-6.4-x86_64-2.txz: Rebuilt.
Fri Oct 8 03:23:28 UTC 2021
n/httpd-2.4.51-x86_64-1.txz: Upgraded.
       SECURITY: CVE-2021-42013: Path Traversal and Remote Code
       Execution in Apache HTTP Server 2.4.49 and 2.4.50 (incomplete
       fix of CVE-2021-41773) (cve.mitre.org)
       It was found that the fix for CVE-2021-41773 in Apache HTTP
       Server 2.4.50 was insufficient. An attacker could use a path
       traversal attack to map URLs to files outside the directories
       configured by Alias-like directives.
       If files outside of these directories are not protected by the
       usual default configuration "require all denied", these requests
       can succeed. If CGI scripts are also enabled for these aliased
       pathes, this could allow for remote code execution.
       This issue only affects Apache 2.4.49 and Apache 2.4.50 and not
       earlier versions.
       Credits: Reported by Juan Escobar from Dreamlab Technologies,
       Fernando MuA+-oz from NULL Life CTF Team, and Shungo Kumasaka
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-42013
Thu Oct 7 19:12:20 UTC 2021
a/kernel-generic-5.14.10-x86_64-1.txz: Upgraded.
a/kernel-huge-5.14.10-x86_64-1.txz: Upgraded.
a/kernel-modules-5.14.10-x86_64-1.txz: Upgraded.
d/kernel-headers-5.14.10-x86-1.txz: Upgraded.
k/kernel-source-5.14.10-noarch-1.txz: Upgraded.
kde/kio-5.86.0-x86_64-3.txz: Rebuilt.
       Allow changing panel launcher icons. Thanks to RadicalDreamer and ctrlaltca.
n/epic5-2.1.6-x86_64-1.txz: Upgraded.
n/gnupg2-2.2.32-x86_64-1.txz: Upgraded.
xap/xpaint-3.1.4-x86_64-1.txz: Upgraded.
Slackware 32-bit
a/aaa_terminfo-6.2_20211009-i586-1.txz: Upgraded.
a/btrfs-progs-5.14.2-i586-1.txz: Upgraded.
ap/sc-im-20210927_64b1a41-i586-1.txz: Upgraded.
ap/undervolt-20210815_e39aea1-i586-1.txz: Upgraded.
d/gyp-20210831_d6c5dd51-i586-1.txz: Upgraded.
kde/attica-5.87.0-i586-1.txz: Upgraded.
kde/baloo-5.87.0-i586-1.txz: Upgraded.
kde/bluez-qt-5.87.0-i586-1.txz: Upgraded.
kde/digikam-7.3.0-i586-3.txz: Rebuilt.
kde/extra-cmake-modules-5.87.0-i586-1.txz: Upgraded.
kde/frameworkintegration-5.87.0-i586-1.txz: Upgraded.
kde/kactivities-5.87.0-i586-1.txz: Upgraded.
kde/kactivities-stats-5.87.0-i586-1.txz: Upgraded.
kde/kapidox-5.87.0-i586-1.txz: Upgraded.
kde/karchive-5.87.0-i586-1.txz: Upgraded.
kde/kauth-5.87.0-i586-1.txz: Upgraded.
kde/kbookmarks-5.87.0-i586-1.txz: Upgraded.
kde/kcalendarcore-5.87.0-i586-1.txz: Upgraded.
kde/kcmutils-5.87.0-i586-1.txz: Upgraded.
kde/kcodecs-5.87.0-i586-1.txz: Upgraded.
kde/kcompletion-5.87.0-i586-1.txz: Upgraded.
kde/kconfig-5.87.0-i586-1.txz: Upgraded.
kde/kconfigwidgets-5.87.0-i586-1.txz: Upgraded.
kde/kcontacts-5.87.0-i586-1.txz: Upgraded.
kde/kcoreaddons-5.87.0-i586-1.txz: Upgraded.
kde/kcrash-5.87.0-i586-1.txz: Upgraded.
kde/kdav-5.87.0-i586-1.txz: Upgraded.
kde/kdbusaddons-5.87.0-i586-1.txz: Upgraded.
kde/kdeclarative-5.87.0-i586-1.txz: Upgraded.
kde/kded-5.87.0-i586-1.txz: Upgraded.
kde/kdelibs4support-5.87.0-i586-1.txz: Upgraded.
kde/kdesignerplugin-5.87.0-i586-1.txz: Upgraded.
kde/kdesu-5.87.0-i586-1.txz: Upgraded.
kde/kdewebkit-5.87.0-i586-1.txz: Upgraded.
kde/kdnssd-5.87.0-i586-1.txz: Upgraded.
kde/kdoctools-5.87.0-i586-1.txz: Upgraded.
kde/kemoticons-5.87.0-i586-1.txz: Upgraded.
kde/kfilemetadata-5.87.0-i586-1.txz: Upgraded.
kde/kglobalaccel-5.87.0-i586-1.txz: Upgraded.
kde/kguiaddons-5.87.0-i586-1.txz: Upgraded.
kde/kholidays-5.87.0-i586-1.txz: Upgraded.
kde/khtml-5.87.0-i586-1.txz: Upgraded.
kde/ki18n-5.87.0-i586-1.txz: Upgraded.
kde/kiconthemes-5.87.0-i586-1.txz: Upgraded.
kde/kidletime-5.87.0-i586-1.txz: Upgraded.
kde/kimageformats-5.87.0-i586-1.txz: Upgraded.
kde/kinit-5.87.0-i586-1.txz: Upgraded.
kde/kio-5.87.0-i586-1.txz: Upgraded.
kde/kirigami2-5.87.0-i586-1.txz: Upgraded.
kde/kitemmodels-5.87.0-i586-1.txz: Upgraded.
kde/kitemviews-5.87.0-i586-1.txz: Upgraded.
kde/kjobwidgets-5.87.0-i586-1.txz: Upgraded.
kde/kjots-20211003_4109f07-i586-1.txz: Upgraded.
kde/kjs-5.87.0-i586-1.txz: Upgraded.
kde/kjsembed-5.87.0-i586-1.txz: Upgraded.
kde/kmediaplayer-5.87.0-i586-1.txz: Upgraded.
kde/knewstuff-5.87.0-i586-1.txz: Upgraded.
kde/knotifications-5.87.0-i586-1.txz: Upgraded.
kde/knotifyconfig-5.87.0-i586-1.txz: Upgraded.
kde/kpackage-5.87.0-i586-1.txz: Upgraded.
kde/kparts-5.87.0-i586-1.txz: Upgraded.
kde/kpeople-5.87.0-i586-1.txz: Upgraded.
kde/kplotting-5.87.0-i586-1.txz: Upgraded.
kde/kpty-5.87.0-i586-1.txz: Upgraded.
kde/kquickcharts-5.87.0-i586-1.txz: Upgraded.
kde/kross-5.87.0-i586-1.txz: Upgraded.
kde/krunner-5.87.0-i586-1.txz: Upgraded.
kde/kservice-5.87.0-i586-1.txz: Upgraded.
kde/ktexteditor-5.87.0-i586-1.txz: Upgraded.
kde/ktextwidgets-5.87.0-i586-1.txz: Upgraded.
kde/kunitconversion-5.87.0-i586-1.txz: Upgraded.
kde/kwallet-5.87.0-i586-1.txz: Upgraded.
kde/kwayland-5.87.0-i586-1.txz: Upgraded.
kde/kwidgetsaddons-5.87.0-i586-1.txz: Upgraded.
kde/kwindowsystem-5.87.0-i586-1.txz: Upgraded.
kde/kxmlgui-5.87.0-i586-1.txz: Upgraded.
kde/kxmlrpcclient-5.87.0-i586-1.txz: Upgraded.
kde/modemmanager-qt-5.87.0-i586-1.txz: Upgraded.
kde/networkmanager-qt-5.87.0-i586-1.txz: Upgraded.
kde/plasma-framework-5.87.0-i586-1.txz: Upgraded.
kde/prison-5.87.0-i586-1.txz: Upgraded.
kde/purpose-5.87.0-i586-1.txz: Upgraded.
kde/qqc2-desktop-style-5.87.0-i586-1.txz: Upgraded.
kde/solid-5.87.0-i586-1.txz: Upgraded.
kde/sonnet-5.87.0-i586-1.txz: Upgraded.
kde/syndication-5.87.0-i586-1.txz: Upgraded.
kde/syntax-highlighting-5.87.0-i586-1.txz: Upgraded.
kde/threadweaver-5.87.0-i586-1.txz: Upgraded.
kde/wacomtablet-20210906_d1e216a-i586-1.txz: Upgraded.
l/QtAV-20210414_305e5404-i586-1.txz: Upgraded.
l/ffmpeg-4.4-i586-2.txz: Rebuilt.
l/gst-plugins-bad-free-1.18.5-i586-2.txz: Rebuilt.
l/libical-3.0.11-i586-1.txz: Upgraded.
l/mlt-7.0.1-i586-3.txz: Rebuilt.
l/ncurses-6.2_20211009-i586-1.txz: Upgraded.
l/opencv-4.5.4-i586-1.txz: Upgraded.
       Changed ABI.
l/python-certifi-2021.10.8-i586-1.txz: Upgraded.
l/vid.stab-20201110_f9166e9-i586-1.txz: Upgraded.
n/wget2-2.0.0-i586-2.txz: Rebuilt.
t/texlive-2021.210418-i586-2.txz: Rebuilt.
a/aaa_libraries-15.0-i586-10.txz: Rebuilt.
a/kernel-generic-5.14.11-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.14.11_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.14.11-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.14.11_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.14.11-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.14.11_smp-i686-1.txz: Upgraded.
a/libblockdev-2.26-i586-2.txz: Rebuilt.
a/libbytesize-2.6-i586-2.txz: Rebuilt.
a/libpwquality-1.4.4-i586-5.txz: Rebuilt.
a/util-linux-2.37.2-i586-5.txz: Rebuilt.
a/volume_key-0.3.12-i586-4.txz: Rebuilt.
ap/hplip-3.20.5-i586-4.txz: Rebuilt.
ap/linuxdoc-tools-0.9.82-i586-2.txz: Rebuilt.
ap/rpm-4.16.1.3-i586-2.txz: Rebuilt.
ap/undervolt-20201024_13fa33d-i586-4.txz: Rebuilt.
ap/vim-8.2.3487-i586-1.txz: Upgraded.
d/Cython-0.29.24-i586-2.txz: Rebuilt.
d/distcc-3.4-i586-2.txz: Rebuilt.
d/gdb-11.1-i586-3.txz: Rebuilt.
d/gyp-20200512_caa60026-i586-5.txz: Rebuilt.
d/kernel-headers-5.14.11_smp-x86-1.txz: Upgraded.
d/llvm-12.0.1-i586-2.txz: Rebuilt.
d/mercurial-5.9.2-i586-2.txz: Rebuilt.
d/meson-0.59.2-i586-2.txz: Rebuilt.
d/python-pip-21.2.4-i586-2.txz: Rebuilt.
d/python-setuptools-58.2.0-i586-2.txz: Rebuilt.
d/python3-3.10.0-i586-1.txz: Upgraded.
d/scons-4.0.1-i586-5.txz: Rebuilt.
k/kernel-source-5.14.11_smp-noarch-1.txz: Upgraded.
kde/akonadi-21.08.2-i586-1.txz: Upgraded.
kde/akonadi-calendar-21.08.2-i586-1.txz: Upgraded.
kde/akonadi-calendar-tools-21.08.2-i586-1.txz: Upgraded.
kde/akonadi-contacts-21.08.2-i586-1.txz: Upgraded.
kde/akonadi-import-wizard-21.08.2-i586-1.txz: Upgraded.
kde/akonadi-mime-21.08.2-i586-1.txz: Upgraded.
kde/akonadi-notes-21.08.2-i586-1.txz: Upgraded.
kde/akonadi-search-21.08.2-i586-1.txz: Upgraded.
kde/akonadiconsole-21.08.2-i586-1.txz: Upgraded.
kde/akregator-21.08.2-i586-1.txz: Upgraded.
kde/analitza-21.08.2-i586-1.txz: Upgraded.
kde/ark-21.08.2-i586-1.txz: Upgraded.
kde/artikulate-21.08.2-i586-1.txz: Upgraded.
kde/audiocd-kio-21.08.2-i586-1.txz: Upgraded.
kde/baloo-widgets-21.08.2-i586-1.txz: Upgraded.
kde/blinken-21.08.2-i586-1.txz: Upgraded.
kde/bomber-21.08.2-i586-1.txz: Upgraded.
kde/bovo-21.08.2-i586-1.txz: Upgraded.
kde/calendarsupport-21.08.2-i586-1.txz: Upgraded.
kde/cantor-21.08.2-i586-1.txz: Upgraded.
kde/cervisia-21.08.2-i586-1.txz: Upgraded.
kde/dolphin-21.08.2-i586-1.txz: Upgraded.
kde/dolphin-plugins-21.08.2-i586-1.txz: Upgraded.
kde/dragon-21.08.2-i586-1.txz: Upgraded.
kde/elisa-21.08.2-i586-1.txz: Upgraded.
kde/eventviews-21.08.2-i586-1.txz: Upgraded.
kde/extra-cmake-modules-5.86.0-i586-3.txz: Rebuilt.
kde/ffmpegthumbs-21.08.2-i586-1.txz: Upgraded.
kde/filelight-21.08.2-i586-1.txz: Upgraded.
kde/granatier-21.08.2-i586-1.txz: Upgraded.
kde/grantlee-editor-21.08.2-i586-1.txz: Upgraded.
kde/grantleetheme-21.08.2-i586-1.txz: Upgraded.
kde/gwenview-21.08.2-i586-1.txz: Upgraded.
kde/incidenceeditor-21.08.2-i586-1.txz: Upgraded.
kde/itinerary-21.08.2-i586-1.txz: Upgraded.
kde/juk-21.08.2-i586-1.txz: Upgraded.
kde/k3b-21.08.2-i586-1.txz: Upgraded.
kde/kaddressbook-21.08.2-i586-1.txz: Upgraded.
kde/kalarm-21.08.2-i586-1.txz: Upgraded.
kde/kalarmcal-21.08.2-i586-1.txz: Upgraded.
kde/kalgebra-21.08.2-i586-1.txz: Upgraded.
kde/kalzium-21.08.2-i586-1.txz: Upgraded.
kde/kamera-21.08.2-i586-1.txz: Upgraded.
kde/kamoso-21.08.2-i586-1.txz: Upgraded.
kde/kanagram-21.08.2-i586-1.txz: Upgraded.
kde/kapidox-5.86.0-i586-3.txz: Rebuilt.
kde/kapman-21.08.2-i586-1.txz: Upgraded.
kde/kapptemplate-21.08.2-i586-1.txz: Upgraded.
kde/kate-21.08.2-i586-1.txz: Upgraded.
kde/katomic-21.08.2-i586-1.txz: Upgraded.
kde/kauth-5.86.0-i586-3.txz: Rebuilt.
kde/kbackup-21.08.2-i586-1.txz: Upgraded.
kde/kblackbox-21.08.2-i586-1.txz: Upgraded.
kde/kblocks-21.08.2-i586-1.txz: Upgraded.
kde/kbounce-21.08.2-i586-1.txz: Upgraded.
kde/kbreakout-21.08.2-i586-1.txz: Upgraded.
kde/kbruch-21.08.2-i586-1.txz: Upgraded.
kde/kcachegrind-21.08.2-i586-1.txz: Upgraded.
kde/kcalc-21.08.2-i586-1.txz: Upgraded.
kde/kcalutils-21.08.2-i586-1.txz: Upgraded.
kde/kcharselect-21.08.2-i586-1.txz: Upgraded.
kde/kcodecs-5.86.0-i586-3.txz: Rebuilt.
kde/kcolorchooser-21.08.2-i586-1.txz: Upgraded.
kde/kcompletion-5.86.0-i586-3.txz: Rebuilt.
kde/kconfig-5.86.0-i586-3.txz: Rebuilt.
kde/kconfigwidgets-5.86.0-i586-3.txz: Rebuilt.
kde/kcoreaddons-5.86.0-i586-3.txz: Rebuilt.
kde/kcron-21.08.2-i586-1.txz: Upgraded.
kde/kdbusaddons-5.86.0-i586-3.txz: Rebuilt.
kde/kde-dev-scripts-21.08.2-i586-1.txz: Upgraded.
kde/kde-dev-utils-21.08.2-i586-1.txz: Upgraded.
kde/kdebugsettings-21.08.2-i586-1.txz: Upgraded.
kde/kdeconnect-kde-21.08.2-i586-1.txz: Upgraded.
kde/kdeedu-data-21.08.2-i586-1.txz: Upgraded.
kde/kdegraphics-mobipocket-21.08.2-i586-1.txz: Upgraded.
kde/kdegraphics-thumbnailers-21.08.2-i586-1.txz: Upgraded.
kde/kdenetwork-filesharing-21.08.2-i586-1.txz: Upgraded.
kde/kdenlive-21.08.2-i586-1.txz: Upgraded.
kde/kdepim-addons-21.08.2-i586-1.txz: Upgraded.
kde/kdepim-runtime-21.08.2-i586-1.txz: Upgraded.
kde/kdesdk-kioslaves-21.08.2-i586-1.txz: Upgraded.
kde/kdesdk-thumbnailers-21.08.2-i586-1.txz: Upgraded.
kde/kdev-python-5.6.2-i586-3.txz: Removed.
kde/kdf-21.08.2-i586-1.txz: Upgraded.
kde/kdialog-21.08.2-i586-1.txz: Upgraded.
kde/kdiamond-21.08.2-i586-1.txz: Upgraded.
kde/keditbookmarks-21.08.2-i586-1.txz: Upgraded.
kde/kfind-21.08.2-i586-1.txz: Upgraded.
kde/kfloppy-21.08.2-i586-1.txz: Upgraded.
kde/kfourinline-21.08.2-i586-1.txz: Upgraded.
kde/kgeography-21.08.2-i586-1.txz: Upgraded.
kde/kget-21.08.2-i586-1.txz: Upgraded.
kde/kgoldrunner-21.08.2-i586-1.txz: Upgraded.
kde/kgpg-21.08.2-i586-1.txz: Upgraded.
kde/kguiaddons-5.86.0-i586-3.txz: Rebuilt.
kde/khangman-21.08.2-i586-1.txz: Upgraded.
kde/khelpcenter-21.08.2-i586-1.txz: Upgraded.
kde/ki18n-5.86.0-i586-3.txz: Rebuilt.
kde/kidentitymanagement-21.08.2-i586-1.txz: Upgraded.
kde/kig-21.08.2-i586-1.txz: Upgraded.
kde/kigo-21.08.2-i586-1.txz: Upgraded.
kde/killbots-21.08.2-i586-1.txz: Upgraded.
kde/kimagemapeditor-21.08.2-i586-1.txz: Upgraded.
kde/kimap-21.08.2-i586-1.txz: Upgraded.
kde/kio-extras-21.08.2-i586-1.txz: Upgraded.
kde/kio-gdrive-21.08.2-i586-1.txz: Upgraded.
kde/kipi-plugins-21.08.2-i586-1.txz: Upgraded.
kde/kirigami-gallery-21.08.2-i586-1.txz: Upgraded.
kde/kiriki-21.08.2-i586-1.txz: Upgraded.
kde/kitemmodels-5.86.0-i586-3.txz: Rebuilt.
kde/kitemviews-5.86.0-i586-3.txz: Rebuilt.
kde/kiten-21.08.2-i586-1.txz: Upgraded.
kde/kitinerary-21.08.2-i586-1.txz: Upgraded.
kde/kjobwidgets-5.86.0-i586-3.txz: Rebuilt.
kde/kjumpingcube-21.08.2-i586-1.txz: Upgraded.
kde/kldap-21.08.2-i586-1.txz: Upgraded.
kde/kleopatra-21.08.2-i586-1.txz: Upgraded.
kde/klickety-21.08.2-i586-1.txz: Upgraded.
kde/klines-21.08.2-i586-1.txz: Upgraded.
kde/kmag-21.08.2-i586-1.txz: Upgraded.
kde/kmahjongg-21.08.2-i586-1.txz: Upgraded.
kde/kmail-21.08.2-i586-1.txz: Upgraded.
kde/kmail-account-wizard-21.08.2-i586-1.txz: Upgraded.
kde/kmailtransport-21.08.2-i586-1.txz: Upgraded.
kde/kmbox-21.08.2-i586-1.txz: Upgraded.
kde/kmime-21.08.2-i586-1.txz: Upgraded.
kde/kmines-21.08.2-i586-1.txz: Upgraded.
kde/kmix-21.08.2-i586-1.txz: Upgraded.
kde/kmousetool-21.08.2-i586-1.txz: Upgraded.
kde/kmouth-21.08.2-i586-1.txz: Upgraded.
kde/kmplot-21.08.2-i586-1.txz: Upgraded.
kde/kmymoney-5.1.2-i586-3.txz: Rebuilt.
kde/knavalbattle-21.08.2-i586-1.txz: Upgraded.
kde/knetwalk-21.08.2-i586-1.txz: Upgraded.
kde/knights-21.08.2-i586-1.txz: Upgraded.
kde/knotes-21.08.2-i586-1.txz: Upgraded.
kde/kolf-21.08.2-i586-1.txz: Upgraded.
kde/kollision-21.08.2-i586-1.txz: Upgraded.
kde/kolourpaint-21.08.2-i586-1.txz: Upgraded.
kde/kompare-21.08.2-i586-1.txz: Upgraded.
kde/konqueror-21.08.2-i586-1.txz: Upgraded.
kde/konquest-21.08.2-i586-1.txz: Upgraded.
kde/konsole-21.08.2-i586-1.txz: Upgraded.
kde/kontact-21.08.2-i586-1.txz: Upgraded.
kde/kontactinterface-21.08.2-i586-1.txz: Upgraded.
kde/kontrast-21.08.2-i586-1.txz: Upgraded.
kde/konversation-21.08.2-i586-1.txz: Upgraded.
kde/kopeninghours-21.08.2-i586-1.txz: Upgraded.
kde/kopete-21.08.2-i586-1.txz: Upgraded.
kde/korganizer-21.08.2-i586-1.txz: Upgraded.
kde/kosmindoormap-21.08.2-i586-1.txz: Upgraded.
kde/kpat-21.08.2-i586-1.txz: Upgraded.
kde/kpimtextedit-21.08.2-i586-1.txz: Upgraded.
kde/kpkpass-21.08.2-i586-1.txz: Upgraded.
kde/kpmcore-21.08.2-i586-1.txz: Upgraded.
kde/kpublictransport-21.08.2-i586-1.txz: Upgraded.
kde/kqtquickcharts-21.08.2-i586-1.txz: Upgraded.
kde/krdc-21.08.2-i586-1.txz: Upgraded.
kde/kreversi-21.08.2-i586-1.txz: Upgraded.
kde/krfb-21.08.2-i586-1.txz: Upgraded.
kde/krita-4.4.8-i586-5.txz: Rebuilt.
kde/kross-interpreters-21.08.2-i586-1.txz: Upgraded.
kde/kruler-21.08.2-i586-1.txz: Upgraded.
kde/kshisen-21.08.2-i586-1.txz: Upgraded.
kde/ksirk-21.08.2-i586-1.txz: Upgraded.
kde/ksmtp-21.08.2-i586-1.txz: Upgraded.
kde/ksnakeduel-21.08.2-i586-1.txz: Upgraded.
kde/kspaceduel-21.08.2-i586-1.txz: Upgraded.
kde/ksquares-21.08.2-i586-1.txz: Upgraded.
kde/ksudoku-21.08.2-i586-1.txz: Upgraded.
kde/ksystemlog-21.08.2-i586-1.txz: Upgraded.
kde/kteatime-21.08.2-i586-1.txz: Upgraded.
kde/ktimer-21.08.2-i586-1.txz: Upgraded.
kde/ktnef-21.08.2-i586-1.txz: Upgraded.
kde/ktorrent-21.08.2-i586-1.txz: Upgraded.
kde/ktouch-21.08.2-i586-1.txz: Upgraded.
kde/kturtle-21.08.2-i586-1.txz: Upgraded.
kde/kubrick-21.08.2-i586-1.txz: Upgraded.
kde/kwalletmanager-21.08.2-i586-1.txz: Upgraded.
kde/kwave-21.08.2-i586-1.txz: Upgraded.
kde/kwidgetsaddons-5.86.0-i586-3.txz: Rebuilt.
kde/kwordquiz-21.08.2-i586-1.txz: Upgraded.
kde/libgravatar-21.08.2-i586-1.txz: Upgraded.
kde/libkcddb-21.08.2-i586-1.txz: Upgraded.
kde/libkcompactdisc-21.08.2-i586-1.txz: Upgraded.
kde/libkdcraw-21.08.2-i586-1.txz: Upgraded.
kde/libkdegames-21.08.2-i586-1.txz: Upgraded.
kde/libkdepim-21.08.2-i586-1.txz: Upgraded.
kde/libkeduvocdocument-21.08.2-i586-1.txz: Upgraded.
kde/libkexiv2-21.08.2-i586-1.txz: Upgraded.
kde/libkgapi-21.08.2-i586-1.txz: Upgraded.
kde/libkipi-21.08.2-i586-1.txz: Upgraded.
kde/libkleo-21.08.2-i586-1.txz: Upgraded.
kde/libkmahjongg-21.08.2-i586-1.txz: Upgraded.
kde/libkomparediff2-21.08.2-i586-1.txz: Upgraded.
kde/libksane-21.08.2-i586-1.txz: Upgraded.
kde/libksieve-21.08.2-i586-1.txz: Upgraded.
kde/libktorrent-21.08.2-i586-1.txz: Upgraded.
kde/lokalize-21.08.2-i586-1.txz: Upgraded.
kde/lskat-21.08.2-i586-1.txz: Upgraded.
kde/mailcommon-21.08.2-i586-1.txz: Upgraded.
kde/mailimporter-21.08.2-i586-1.txz: Upgraded.
kde/marble-21.08.2-i586-1.txz: Upgraded.
kde/markdownpart-21.08.2-i586-1.txz: Upgraded.
kde/mbox-importer-21.08.2-i586-1.txz: Upgraded.
kde/messagelib-21.08.2-i586-1.txz: Upgraded.
kde/minuet-21.08.2-i586-1.txz: Upgraded.
kde/okular-21.08.2-i586-1.txz: Upgraded.
kde/palapeli-21.08.2-i586-1.txz: Upgraded.
kde/parley-21.08.2-i586-1.txz: Upgraded.
kde/partitionmanager-21.08.2-i586-1.txz: Upgraded.
kde/picmi-21.08.2-i586-1.txz: Upgraded.
kde/pim-data-exporter-21.08.2-i586-1.txz: Upgraded.
kde/pim-sieve-editor-21.08.2-i586-1.txz: Upgraded.
kde/pimcommon-21.08.2-i586-1.txz: Upgraded.
kde/poxml-21.08.2-i586-1.txz: Upgraded.
kde/print-manager-21.08.2-i586-1.txz: Upgraded.
kde/rocs-21.08.2-i586-1.txz: Upgraded.
kde/skanlite-21.08.2-i586-1.txz: Upgraded.
kde/spectacle-21.08.2-i586-1.txz: Upgraded.
kde/step-21.08.2-i586-1.txz: Upgraded.
kde/svgpart-21.08.2-i586-1.txz: Upgraded.
kde/sweeper-21.08.2-i586-1.txz: Upgraded.
kde/umbrello-21.08.2-i586-1.txz: Upgraded.
kde/yakuake-21.08.2-i586-1.txz: Upgraded.
kde/zeroconf-ioslave-21.08.2-i586-1.txz: Upgraded.
l/M2Crypto-0.38.0-i586-2.txz: Rebuilt.
l/Mako-1.1.4-i586-4.txz: Rebuilt.
l/PyQt5-5.15.2-i586-4.txz: Rebuilt.
l/QScintilla-2.11.6-i586-4.txz: Rebuilt.
l/brotli-1.0.9-i586-6.txz: Rebuilt.
l/dbus-python-1.2.18-i586-2.txz: Rebuilt.
l/gexiv2-0.14.0-i586-2.txz: Rebuilt.
l/glade-3.38.2-i586-4.txz: Rebuilt.
l/gobject-introspection-1.70.0-i586-2.txz: Rebuilt.
l/lensfun-0.3.95-i586-4.txz: Rebuilt.
l/libcaca-0.99.beta19-i586-10.txz: Rebuilt.
l/libcap-ng-0.8.2-i586-4.txz: Rebuilt.
l/libimobiledevice-20200615_4791a82-i586-5.txz: Rebuilt.
l/libproxy-0.4.17-i586-4.txz: Rebuilt.
l/libwebp-1.2.1-i586-2.txz: Rebuilt.
l/libxml2-2.9.12-i586-2.txz: Rebuilt.
l/newt-0.52.21-i586-6.txz: Rebuilt.
l/openexr-2.5.7-i586-3.txz: Rebuilt.
l/pycairo-1.20.1-i586-2.txz: Rebuilt.
l/pycups-2.0.1-i586-5.txz: Rebuilt.
l/pycurl-7.44.1-i586-2.txz: Rebuilt.
l/pygobject3-3.42.0-i586-2.txz: Rebuilt.
l/pyparsing-2.4.7-i586-5.txz: Rebuilt.
l/python-appdirs-1.4.4-i586-5.txz: Rebuilt.
l/python-certifi-2021.5.30-i586-2.txz: Rebuilt.
l/python-cffi-1.14.6-i586-2.txz: Rebuilt.
l/python-chardet-4.0.0-i586-4.txz: Rebuilt.
l/python-charset-normalizer-2.0.6-i586-2.txz: Rebuilt.
l/python-distro-1.5.0-i586-5.txz: Rebuilt.
l/python-dnspython-2.1.0-i586-2.txz: Rebuilt.
l/python-docutils-0.17.1-i586-2.txz: Rebuilt.
l/python-future-0.18.2-i586-6.txz: Rebuilt.
l/python-idna-3.2-i586-2.txz: Rebuilt.
l/python-markdown-3.3.4-i586-2.txz: Rebuilt.
l/python-notify2-0.3.1-i586-9.txz: Rebuilt.
l/python-packaging-21.0-i586-2.txz: Rebuilt.
l/python-pillow-8.3.2-i586-2.txz: Rebuilt.
l/python-ply-3.11-i586-7.txz: Rebuilt.
l/python-pycparser-2.20-i586-2.txz: Rebuilt.
l/python-pygments-2.10.0-i586-2.txz: Rebuilt.
l/python-pysol_cards-0.10.2-i586-2.txz: Rebuilt.
l/python-random2-1.0.1-i586-4.txz: Rebuilt.
l/python-requests-2.26.0-i586-2.txz: Rebuilt.
l/python-sane-2.9.1-i586-4.txz: Rebuilt.
l/python-six-1.16.0-i586-2.txz: Rebuilt.
l/python-urllib3-1.26.7-i586-2.txz: Rebuilt.
l/sip-4.19.25-i586-2.txz: Rebuilt.
l/speech-dispatcher-0.10.2-i586-4.txz: Rebuilt.
l/system-config-printer-1.5.15-i586-4.txz: Rebuilt.
l/talloc-2.3.3-i586-2.txz: Rebuilt.
l/tdb-1.4.5-i586-2.txz: Rebuilt.
l/tevent-0.11.0-i586-2.txz: Rebuilt.
n/bind-9.16.21-i586-5.txz: Rebuilt.
n/epic5-2.1.6-i586-2.txz: Rebuilt.
n/fetchmail-6.4.22-i586-2.txz: Rebuilt.
n/getmail-6.18.4-i586-2.txz: Rebuilt.
n/gpgme-1.16.0-i586-2.txz: Rebuilt.
n/net-snmp-5.9.1-i586-2.txz: Rebuilt.
n/nftables-1.0.0-i586-3.txz: Rebuilt.
n/nss-pam-ldapd-0.9.11-i586-4.txz: Rebuilt.
n/obexftp-0.24.2-i586-9.txz: Rebuilt.
n/pssh-2.3.4-i586-5.txz: Rebuilt.
n/samba-4.15.0-i586-2.txz: Rebuilt.
x/ibus-1.5.25-i586-2.txz: Rebuilt.
x/ibus-anthy-1.5.13-i586-2.txz: Rebuilt.
x/ibus-hangul-1.5.4-i586-4.txz: Rebuilt.
x/ibus-libpinyin-1.12.1-i586-2.txz: Rebuilt.
x/ibus-table-1.14.1-i586-2.txz: Rebuilt.
x/pyxdg-0.27-i586-5.txz: Rebuilt.
x/xcb-proto-1.14.1-i586-5.txz: Rebuilt.
xap/blueman-2.2.2-i586-2.txz: Rebuilt.
xap/hexchat-2.16.0-i586-2.txz: Rebuilt.
xap/vim-gvim-8.2.3487-i586-1.txz: Upgraded.
extra/brltty/brltty-6.4-i586-2.txz: Rebuilt.
extra/linux-5.14.11-nosmp-sdk/*: Upgraded.
n/httpd-2.4.51-i586-1.txz: Upgraded.
       earlier versions.
a/kernel-generic-5.14.10-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.14.10_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.14.10-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.14.10_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.14.10-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.14.10_smp-i686-1.txz: Upgraded.
d/kernel-headers-5.14.10_smp-x86-1.txz: Upgraded.
k/kernel-source-5.14.10_smp-noarch-1.txz: Upgraded.
kde/kio-5.86.0-i586-3.txz: Rebuilt.
n/epic5-2.1.6-i586-1.txz: Upgraded.
n/gnupg2-2.2.32-i586-1.txz: Upgraded.
xap/xpaint-3.1.4-i586-1.txz: Upgraded.
extra/linux-5.14.10-nosmp-sdk/*: Upgraded.
Post Napisano: 18 Oct 2021, 12:58
Slackware 64-bit
Sun Oct 17 18:52:33 UTC 2021
a/glibc-zoneinfo-2021d-noarch-1.txz: Upgraded.
a/kernel-generic-5.14.13-x86_64-1.txz: Upgraded.
a/kernel-huge-5.14.13-x86_64-1.txz: Upgraded.
a/kernel-modules-5.14.13-x86_64-1.txz: Upgraded.
d/kernel-headers-5.14.13-x86-1.txz: Upgraded.
k/kernel-source-5.14.13-noarch-1.txz: Upgraded.
Sat Oct 16 18:12:37 UTC 2021
ap/pamixer-1.5-x86_64-1.txz: Upgraded.
l/librsvg-2.52.2-x86_64-1.txz: Upgraded.
l/liburing-2.1-x86_64-2.txz: Rebuilt.
       Don't package the examples.
l/spirv-llvm-translator-13.0.0-x86_64-1.txz: Upgraded.
Fri Oct 15 20:47:13 UTC 2021
ap/htop-3.1.1-x86_64-1.txz: Upgraded.
d/automake-1.16.2-noarch-4.txz: Rebuilt.
       The GNU toolchain is making it increasingly impossible to use our usual
       "${ARCH}-slackware-linux" host, erroring out with a host mismatch on at
       least GTK+2. So, we'll drop back to this version of automake for now,
       with a fix applied for detecting Python 3.10. More than likely we'll be
       changing the host to "${ARCH}-slackware-linux-gnu" to satisfy upstream,
       but that will have to wait for the next devel cycle.
d/llvm-13.0.0-x86_64-1.txz: Upgraded.
d/rust-1.55.0-x86_64-2.txz: Rebuilt.
       Recompiled against llvm-13.0.0.
kde/kdevelop-5.6.2-x86_64-6.txz: Rebuilt.
kde/plasma-workspace-5.23.0-x86_64-2.txz: Rebuilt.
       [PATCH] sddm-theme: fix missing password field on "Other" page.
       Thanks to USUARIONUEVO and LuckyCyborg.
l/libclc-13.0.0-x86_64-1.txz: Upgraded.
l/python-pillow-8.4.0-x86_64-1.txz: Upgraded.
l/qt5-5.15.3_20211013_5c7c3af5-x86_64-1.txz: Upgraded.
       Upgraded to latest git (might as well) and compiled against llvm-13.0.0.
l/spirv-llvm-translator-20210920_098034ea-x86_64-1.txz: Upgraded.
x/mesa-21.2.4-x86_64-1.txz: Upgraded.
       Compiled against llvm-13.0.0.
xap/pidgin-2.14.8-x86_64-1.txz: Upgraded.
Thu Oct 14 19:39:32 UTC 2021
Huge thanks and congratulations to the KDE Community on the release of the
Plasma 25th Anniversary Edition!
kde/bluedevil-5.23.0-x86_64-1.txz: Upgraded.
kde/breeze-5.23.0-x86_64-1.txz: Upgraded.
kde/breeze-grub-5.23.0-x86_64-1.txz: Upgraded.
kde/breeze-gtk-5.23.0-x86_64-1.txz: Upgraded.
kde/drkonqi-5.23.0-x86_64-1.txz: Upgraded.
kde/kactivitymanagerd-5.23.0-x86_64-1.txz: Upgraded.
kde/kde-cli-tools-5.23.0-x86_64-1.txz: Upgraded.
kde/kde-gtk-config-5.23.0-x86_64-1.txz: Upgraded.
kde/kdecoration-5.23.0-x86_64-1.txz: Upgraded.
kde/kdeplasma-addons-5.23.0-x86_64-1.txz: Upgraded.
kde/kgamma5-5.23.0-x86_64-1.txz: Upgraded.
kde/khotkeys-5.23.0-x86_64-1.txz: Upgraded.
kde/kinfocenter-5.23.0-x86_64-1.txz: Upgraded.
kde/kmenuedit-5.23.0-x86_64-1.txz: Upgraded.
kde/kscreen-5.23.0-x86_64-1.txz: Upgraded.
kde/kscreenlocker-5.23.0-x86_64-1.txz: Upgraded.
kde/ksshaskpass-5.23.0-x86_64-1.txz: Upgraded.
kde/ksysguard-5.22.0-x86_64-2.txz: Removed.
kde/ksystemstats-5.23.0-x86_64-1.txz: Upgraded.
kde/kwallet-pam-5.23.0-x86_64-1.txz: Upgraded.
kde/kwayland-integration-5.23.0-x86_64-1.txz: Upgraded.
kde/kwayland-server-5.23.0-x86_64-1.txz: Upgraded.
kde/kwin-5.23.0-x86_64-1.txz: Upgraded.
kde/kwrited-5.23.0-x86_64-1.txz: Upgraded.
kde/layer-shell-qt-5.23.0-x86_64-1.txz: Upgraded.
kde/libkscreen-5.23.0-x86_64-1.txz: Upgraded.
kde/libksysguard-5.23.0-x86_64-1.txz: Upgraded.
kde/milou-5.23.0-x86_64-1.txz: Upgraded.
kde/oxygen-5.23.0-x86_64-1.txz: Upgraded.
kde/plasma-browser-integration-5.23.0-x86_64-1.txz: Upgraded.
kde/plasma-desktop-5.23.0-x86_64-1.txz: Upgraded.
kde/plasma-disks-5.23.0-x86_64-1.txz: Upgraded.
kde/plasma-firewall-5.23.0-x86_64-1.txz: Upgraded.
kde/plasma-integration-5.23.0-x86_64-1.txz: Upgraded.
kde/plasma-nm-5.23.0-x86_64-1.txz: Upgraded.
kde/plasma-pa-5.23.0-x86_64-1.txz: Upgraded.
kde/plasma-sdk-5.23.0-x86_64-1.txz: Upgraded.
kde/plasma-systemmonitor-5.23.0-x86_64-1.txz: Upgraded.
kde/plasma-vault-5.23.0-x86_64-1.txz: Upgraded.
kde/plasma-workspace-5.23.0-x86_64-1.txz: Upgraded.
kde/plasma-workspace-wallpapers-5.23.0-x86_64-1.txz: Upgraded.
kde/polkit-kde-agent-1-5.23.0-x86_64-1.txz: Upgraded.
kde/powerdevil-5.23.0-x86_64-1.txz: Upgraded.
kde/qqc2-breeze-style-5.23.0-x86_64-1.txz: Upgraded.
kde/sddm-kcm-5.23.0-x86_64-1.txz: Upgraded.
kde/systemsettings-5.23.0-x86_64-1.txz: Upgraded.
kde/xdg-desktop-portal-kde-5.23.0-x86_64-1.txz: Upgraded.
n/bluez-5.62-x86_64-1.txz: Upgraded.
xfce/xfce4-whiskermenu-plugin-2.6.1-x86_64-1.txz: Upgraded.
Wed Oct 13 20:16:22 UTC 2021
a/kernel-generic-5.14.12-x86_64-1.txz: Upgraded.
a/kernel-huge-5.14.12-x86_64-1.txz: Upgraded.
a/kernel-modules-5.14.12-x86_64-1.txz: Upgraded.
d/git-2.33.1-x86_64-1.txz: Upgraded.
d/kernel-headers-5.14.12-x86-1.txz: Upgraded.
k/kernel-source-5.14.12-noarch-1.txz: Upgraded.
kde/kig-21.08.2-x86_64-2.txz: Rebuilt.
       Recompiled against libboost_python310.so.1.77.0.
l/freecell-solver-6.6.0-x86_64-1.txz: Upgraded.
l/imagemagick-7.1.0_10-x86_64-1.txz: Upgraded.
l/libqalculate-3.21.0-x86_64-1.txz: Upgraded.
l/python-cffi-1.15.0-x86_64-1.txz: Upgraded.
l/python-idna-3.3-x86_64-1.txz: Upgraded.
l/python-pysol_cards-0.12.0-x86_64-1.txz: Upgraded.
xap/xscreensaver-6.02-x86_64-1.txz: Upgraded.
Tue Oct 12 19:22:20 UTC 2021
a/kernel-firmware-20211012_b563148-noarch-1.txz: Upgraded.
a/mkinitrd-1.4.11-x86_64-26.txz: Rebuilt.
       Don't include 40-usb_modeswitch.rules on the initrd. Thanks to LuckyCyborg.
d/scons-4.2.0-x86_64-1.txz: Upgraded.
l/python-charset-normalizer-2.0.7-x86_64-1.txz: Upgraded.
xfce/mousepad-0.5.7-x86_64-2.txz: Rebuilt.
       Added plugins directory. Thanks to Roman Dyaba.
Mon Oct 11 23:45:10 UTC 2021
d/python-pip-21.3-x86_64-1.txz: Upgraded.
l/aspell-en-2020.12.07_0-x86_64-1.txz: Upgraded.
l/boost-1.77.0-x86_64-2.txz: Rebuilt.
       Recompiled against python-3.10. Thanks to nobodino and ctrlaltca.
l/qt5-5.15.3_20211006_0243418f-x86_64-1.txz: Upgraded.
       Updated from the repo to get a few Wayland related fixes.
n/gnutls-3.7.2-x86_64-1.txz: Upgraded.
Slackware 32-bit
a/kernel-generic-5.14.13-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.14.13_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.14.13-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.14.13_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.14.13-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.14.13_smp-i686-1.txz: Upgraded.
d/kernel-headers-5.14.13_smp-x86-1.txz: Upgraded.
k/kernel-source-5.14.13_smp-noarch-1.txz: Upgraded.
extra/linux-5.14.13-nosmp-sdk/*: Upgraded.
ap/pamixer-1.5-i586-1.txz: Upgraded.
l/librsvg-2.52.2-i586-1.txz: Upgraded.
l/liburing-2.1-i586-2.txz: Rebuilt.
l/spirv-llvm-translator-13.0.0-i586-1.txz: Upgraded.
ap/htop-3.1.1-i586-1.txz: Upgraded.
d/llvm-13.0.0-i586-1.txz: Upgraded.
d/rust-1.55.0-i686-2.txz: Rebuilt.
kde/kdevelop-5.6.2-i586-6.txz: Rebuilt.
kde/plasma-workspace-5.23.0-i586-2.txz: Rebuilt.
l/libclc-13.0.0-i586-1.txz: Upgraded.
l/python-pillow-8.4.0-i586-1.txz: Upgraded.
l/qt5-5.15.3_20211013_5c7c3af5-i586-1.txz: Upgraded.
l/spirv-llvm-translator-20210920_098034ea-i586-1.txz: Upgraded.
x/mesa-21.2.4-i586-1.txz: Upgraded.
xap/pidgin-2.14.8-i586-1.txz: Upgraded.
kde/bluedevil-5.23.0-i586-1.txz: Upgraded.
kde/breeze-5.23.0-i586-1.txz: Upgraded.
kde/breeze-grub-5.23.0-i586-1.txz: Upgraded.
kde/breeze-gtk-5.23.0-i586-1.txz: Upgraded.
kde/drkonqi-5.23.0-i586-1.txz: Upgraded.
kde/kactivitymanagerd-5.23.0-i586-1.txz: Upgraded.
kde/kde-cli-tools-5.23.0-i586-1.txz: Upgraded.
kde/kde-gtk-config-5.23.0-i586-1.txz: Upgraded.
kde/kdecoration-5.23.0-i586-1.txz: Upgraded.
kde/kdeplasma-addons-5.23.0-i586-1.txz: Upgraded.
kde/kgamma5-5.23.0-i586-1.txz: Upgraded.
kde/khotkeys-5.23.0-i586-1.txz: Upgraded.
kde/kinfocenter-5.23.0-i586-1.txz: Upgraded.
kde/kmenuedit-5.23.0-i586-1.txz: Upgraded.
kde/kscreen-5.23.0-i586-1.txz: Upgraded.
kde/kscreenlocker-5.23.0-i586-1.txz: Upgraded.
kde/ksshaskpass-5.23.0-i586-1.txz: Upgraded.
kde/ksysguard-5.22.0-i586-2.txz: Removed.
kde/ksystemstats-5.23.0-i586-1.txz: Upgraded.
kde/kwallet-pam-5.23.0-i586-1.txz: Upgraded.
kde/kwayland-integration-5.23.0-i586-1.txz: Upgraded.
kde/kwayland-server-5.23.0-i586-1.txz: Upgraded.
kde/kwin-5.23.0-i586-1.txz: Upgraded.
kde/kwrited-5.23.0-i586-1.txz: Upgraded.
kde/layer-shell-qt-5.23.0-i586-1.txz: Upgraded.
kde/libkscreen-5.23.0-i586-1.txz: Upgraded.
kde/libksysguard-5.23.0-i586-1.txz: Upgraded.
kde/milou-5.23.0-i586-1.txz: Upgraded.
kde/oxygen-5.23.0-i586-1.txz: Upgraded.
kde/plasma-browser-integration-5.23.0-i586-1.txz: Upgraded.
kde/plasma-desktop-5.23.0-i586-1.txz: Upgraded.
kde/plasma-disks-5.23.0-i586-1.txz: Upgraded.
kde/plasma-firewall-5.23.0-i586-1.txz: Upgraded.
kde/plasma-integration-5.23.0-i586-1.txz: Upgraded.
kde/plasma-nm-5.23.0-i586-1.txz: Upgraded.
kde/plasma-pa-5.23.0-i586-1.txz: Upgraded.
kde/plasma-sdk-5.23.0-i586-1.txz: Upgraded.
kde/plasma-systemmonitor-5.23.0-i586-1.txz: Upgraded.
kde/plasma-vault-5.23.0-i586-1.txz: Upgraded.
kde/plasma-workspace-5.23.0-i586-1.txz: Upgraded.
kde/plasma-workspace-wallpapers-5.23.0-i586-1.txz: Upgraded.
kde/polkit-kde-agent-1-5.23.0-i586-1.txz: Upgraded.
kde/powerdevil-5.23.0-i586-1.txz: Upgraded.
kde/qqc2-breeze-style-5.23.0-i586-1.txz: Upgraded.
kde/sddm-kcm-5.23.0-i586-1.txz: Upgraded.
kde/systemsettings-5.23.0-i586-1.txz: Upgraded.
kde/xdg-desktop-portal-kde-5.23.0-i586-1.txz: Upgraded.
n/bluez-5.62-i586-1.txz: Upgraded.
xfce/xfce4-whiskermenu-plugin-2.6.1-i586-1.txz: Upgraded.
a/kernel-generic-5.14.12-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.14.12_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.14.12-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.14.12_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.14.12-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.14.12_smp-i686-1.txz: Upgraded.
d/git-2.33.1-i586-1.txz: Upgraded.
d/kernel-headers-5.14.12_smp-x86-1.txz: Upgraded.
k/kernel-source-5.14.12_smp-noarch-1.txz: Upgraded.
kde/kig-21.08.2-i586-2.txz: Rebuilt.
l/freecell-solver-6.6.0-i586-1.txz: Upgraded.
l/imagemagick-7.1.0_10-i586-1.txz: Upgraded.
l/libqalculate-3.21.0-i586-1.txz: Upgraded.
l/python-cffi-1.15.0-i586-1.txz: Upgraded.
l/python-idna-3.3-i586-1.txz: Upgraded.
l/python-pysol_cards-0.12.0-i586-1.txz: Upgraded.
xap/xscreensaver-6.02-i586-1.txz: Upgraded.
extra/linux-5.14.12-nosmp-sdk/*: Upgraded.
a/mkinitrd-1.4.11-i586-26.txz: Rebuilt.
d/scons-4.2.0-i586-1.txz: Upgraded.
l/python-charset-normalizer-2.0.7-i586-1.txz: Upgraded.
xfce/mousepad-0.5.7-i586-2.txz: Rebuilt.
d/python-pip-21.3-i586-1.txz: Upgraded.
l/aspell-en-2020.12.07_0-i586-1.txz: Upgraded.
l/boost-1.77.0-i586-2.txz: Rebuilt.
l/qt5-5.15.3_20211006_0243418f-i586-1.txz: Upgraded.
n/gnutls-3.7.2-i586-1.txz: Upgraded.
Post Napisano: 26 Oct 2021, 21:31
Slackware 64-bit
Mon Oct 25 19:30:42 UTC 2021
ap/slackpkg-15.0.8-noarch-1.txz: Upgraded.
       Author: piterpunk <piterpunk@slackware.com>
       To make it easier to do an unattended slackpkg update/upgrade process,
       this commit provides different exit codes for many situations:
       0 Successful slackpkg execution.
       1 Something wrong happened.
       20 No package found to be downloaded, installed, reinstalled,
       upgraded, or removed.
       50 Slackpkg itself was upgraded and you need to re-run it.
       100 There are pending updates.
       Code and the main manpage are updated accordingly.
       In addition, this commit also:
       - removes the ChangeLog.txt in doinst.sh, so the needed
       'slackpkg update' after Slackpkg upgrade won't say it's all OK
       and doesn't need to redo the package lists
       - removes AUTHORS from manpage. Nowadays there is code from many
       people in Slackpkg and it seems a bit unfair to have only my and
       Evaldo's name listed there.
       Signed-off-by: Robby Workman <rworkman@slackware.com>
d/meson-0.60.0-x86_64-1.txz: Upgraded.
l/ffmpeg-4.4.1-x86_64-1.txz: Upgraded.
l/imagemagick-7.1.0_11-x86_64-1.txz: Upgraded.
l/libcap-2.60-x86_64-1.txz: Upgraded.
l/libsoup-2.74.1-x86_64-1.txz: Upgraded.
l/sip-4.19.25-x86_64-3.txz: Rebuilt.
       Drop the Qt4 modules. Thanks to gmgf.
n/dhcpcd-9.4.1-x86_64-1.txz: Upgraded.
testing/packages/linux-5.14.x/kernel-generic-5.14.14-x86_64-3.txz: Rebuilt.
testing/packages/linux-5.14.x/kernel-headers-5.14.14-x86-3.txz: Rebuilt.
testing/packages/linux-5.14.x/kernel-huge-5.14.14-x86_64-3.txz: Rebuilt.
testing/packages/linux-5.14.x/kernel-modules-5.14.14-x86_64-3.txz: Rebuilt.
testing/packages/linux-5.14.x/kernel-source-5.14.14-noarch-3.txz: Rebuilt.
       Let's enable SCHED_AUTOGROUP, which should improve desktop latency under a
       heavy CPU load while being mostly inert on servers. It may be disabled at
       boot time with a "noautogroup" kernel parameter, or at runtime like this:
       echo 0 > /proc/sys/kernel/sched_autogroup_enabled
       Thanks to gbschenkel.
       SCHED_AUTOGROUP n -> y
Sat Oct 23 18:57:30 UTC 2021
a/aaa_terminfo-6.3-x86_64-1.txz: Upgraded.
a/glibc-zoneinfo-2021e-noarch-1.txz: Upgraded.
ap/itstool-2.0.7-x86_64-2.txz: Rebuilt.
       Rebuilt with PYTHON=/usr/bin/python3. Thanks to USUARIONUEVO.
ap/mpg123-1.29.2-x86_64-1.txz: Upgraded.
d/meson-0.59.3-x86_64-1.txz: Upgraded.
d/parallel-20211022-noarch-1.txz: Upgraded.
d/python-pip-21.3.1-x86_64-1.txz: Upgraded.
d/python-setuptools-58.3.0-x86_64-1.txz: Upgraded.
l/exiv2-0.27.5-x86_64-1.txz: Upgraded.
l/ncurses-6.3-x86_64-1.txz: Upgraded.
n/php-7.4.25-x86_64-1.txz: Upgraded.
       This update fixes bugs and a security issue:
       FPM: PHP-FPM oob R/W in root process leading to privilege escalation.
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-21703
xap/mozilla-thunderbird-91.2.1-x86_64-1.txz: Upgraded.
       https://www.mozilla.org/en-US/thunderbird/91.2.1/releasenotes/
testing/packages/linux-5.14.x/kernel-generic-5.14.14-x86_64-2.txz: Rebuilt.
testing/packages/linux-5.14.x/kernel-headers-5.14.14-x86-2.txz: Rebuilt.
testing/packages/linux-5.14.x/kernel-huge-5.14.14-x86_64-2.txz: Rebuilt.
testing/packages/linux-5.14.x/kernel-modules-5.14.14-x86_64-2.txz: Rebuilt.
testing/packages/linux-5.14.x/kernel-source-5.14.14-noarch-2.txz: Rebuilt.
       These kernels enable CONFIG_PREEMPT=y and CONFIG_PREEMPT_DYNAMIC=y allowing
       the kernel preemption model to be specified on the kernel command line
       with one of these options: preempt=none, preempt=voluntary, and preempt=full.
       Since there is no .config option to set a default, and the default in the
       kernel sources is "full" (which is probably not a good default), the
       kernel-source.SlackBuild has been modified to add support for an environment
       variable CONFIG_PREEMPT_DEFAULT_MODE which can be set to none, voluntary, or
       full to set the default kernel preemption model when a command line option
       is not provided. These kernels have been built with a preemption model of
       "none" (presumably the safest choice which will behave like the kernels we
       have shipped before.) The runtime overhead on 64-bit should be negligible.
       On 32-bit we lack support for HAVE_STATIC_CALL_INLINE, so spinlocks and
       mutexes will have to be approached through a trampoline, adding a very small
       amount of overhead. I feel this is probably worth it in order to have the
       option to run a kernel with voluntary or full preemption, especially for
       gaming or desktop purposes. The reduction in input lag with these modes is
       actually quite noticable.
       To check the current preemption model, you may use debugfs:
       mount -t debugfs none /sys/kernel/debug
       cat /sys/kernel/debug/sched/preempt
       (none) voluntary full
       You may change to a different preemption model on the fly once debugfs is
       mounted:
       echo voluntary > /sys/kernel/debug/sched/preempt
       none (voluntary) full
       Thanks to Daedra.
       -DRM_I810 n
       -INLINE_READ_UNLOCK y
       -INLINE_READ_UNLOCK_IRQ y
       -INLINE_SPIN_UNLOCK_IRQ y
       -INLINE_WRITE_UNLOCK y
       -INLINE_WRITE_UNLOCK_IRQ y
       PREEMPT n -> y
       PREEMPT_VOLUNTARY y -> n
       +CEC_GPIO n
       +DEBUG_PREEMPT y
       +PREEMPTION y
       +PREEMPT_COUNT y
       +PREEMPT_DYNAMIC y
       +PREEMPT_RCU y
       +PREEMPT_TRACER n
       +RCU_BOOST n
       +TASKS_RCU y
       +UNINLINE_SPIN_UNLOCK y
Thu Oct 21 19:36:32 UTC 2021
a/lvm2-2.03.13-x86_64-1.txz: Upgraded.
       Reverted to working version.
d/rust-1.56.0-x86_64-1.txz: Upgraded.
l/pipewire-0.3.39-x86_64-1.txz: Upgraded.
n/krb5-1.19.2-x86_64-2.txz: Rebuilt.
       [PATCH] Fix KDC null deref on TGS inner body null server.
       This fixes an issue where an authenticated attacker can cause a denial of
       service in the KDC by sending a FAST TGS request with no server field.
       Thanks to nobodino.
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-37750
x/ibus-m17n-1.4.8-x86_64-1.txz: Upgraded.
x/libinput-1.19.2-x86_64-1.txz: Upgraded.
xap/freerdp-2.4.1-x86_64-1.txz: Upgraded.
       Improper client input validation for gateway connections allows to overwrite
       memory.
       Improper region checks in all clients allow out of bound write to memory.
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-41159
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-41160
xap/gftp-2.7.1b-x86_64-1.txz: Upgraded.
extra/php8/php8-8.0.12-x86_64-1.txz: Upgraded.
Wed Oct 20 19:29:55 UTC 2021
a/kernel-generic-5.14.14-x86_64-1.txz: Upgraded.
a/kernel-huge-5.14.14-x86_64-1.txz: Upgraded.
a/kernel-modules-5.14.14-x86_64-1.txz: Upgraded.
a/lvm2-2.03.14-x86_64-1.txz: Upgraded.
d/kernel-headers-5.14.14-x86-1.txz: Upgraded.
k/kernel-source-5.14.14-noarch-1.txz: Upgraded.
n/autofs-5.1.8-x86_64-1.txz: Upgraded.
isolinux/initrd.img: Rebuilt.
kernels/*: Upgraded.
Tue Oct 19 18:10:12 UTC 2021
kde/alkimia-8.1.0-x86_64-3.txz: Rebuilt.
       Fixed data install location /usr/plasma -> /usr/share/plasma.
       Thanks to oneforall.
kde/bluedevil-5.23.1-x86_64-1.txz: Upgraded.
kde/breeze-5.23.1-x86_64-1.txz: Upgraded.
kde/breeze-grub-5.23.1-x86_64-1.txz: Upgraded.
kde/breeze-gtk-5.23.1-x86_64-1.txz: Upgraded.
kde/drkonqi-5.23.1-x86_64-1.txz: Upgraded.
kde/kactivitymanagerd-5.23.1-x86_64-1.txz: Upgraded.
kde/kde-cli-tools-5.23.1-x86_64-1.txz: Upgraded.
kde/kde-gtk-config-5.23.1-x86_64-1.txz: Upgraded.
kde/kdecoration-5.23.1-x86_64-1.txz: Upgraded.
kde/kdeplasma-addons-5.23.1-x86_64-1.txz: Upgraded.
kde/kgamma5-5.23.1-x86_64-1.txz: Upgraded.
kde/khotkeys-5.23.1-x86_64-1.txz: Upgraded.
kde/kinfocenter-5.23.1-x86_64-1.txz: Upgraded.
kde/kmenuedit-5.23.1-x86_64-1.txz: Upgraded.
kde/kscreen-5.23.1-x86_64-1.txz: Upgraded.
kde/kscreenlocker-5.23.1-x86_64-1.txz: Upgraded.
kde/ksshaskpass-5.23.1-x86_64-1.txz: Upgraded.
kde/ksystemstats-5.23.1-x86_64-1.txz: Upgraded.
kde/kwallet-pam-5.23.1-x86_64-1.txz: Upgraded.
kde/kwayland-integration-5.23.1-x86_64-1.txz: Upgraded.
kde/kwayland-server-5.23.1-x86_64-1.txz: Upgraded.
kde/kwin-5.23.1-x86_64-1.txz: Upgraded.
kde/kwrited-5.23.1-x86_64-1.txz: Upgraded.
kde/layer-shell-qt-5.23.1-x86_64-1.txz: Upgraded.
kde/libkscreen-5.23.1-x86_64-1.txz: Upgraded.
kde/libksysguard-5.23.1-x86_64-1.txz: Upgraded.
kde/milou-5.23.1-x86_64-1.txz: Upgraded.
kde/oxygen-5.23.1-x86_64-1.txz: Upgraded.
kde/plasma-browser-integration-5.23.1-x86_64-1.txz: Upgraded.
kde/plasma-desktop-5.23.1-x86_64-1.txz: Upgraded.
       Applied upstream patch:
       [PATCH] Desktop as folder: restore functionality of the "delete" action.
       Thanks to ctrlaltca.
kde/plasma-disks-5.23.1-x86_64-1.txz: Upgraded.
kde/plasma-firewall-5.23.1-x86_64-1.txz: Upgraded.
kde/plasma-integration-5.23.1-x86_64-1.txz: Upgraded.
kde/plasma-nm-5.23.1-x86_64-1.txz: Upgraded.
kde/plasma-pa-5.23.1-x86_64-1.txz: Upgraded.
kde/plasma-sdk-5.23.1-x86_64-1.txz: Upgraded.
kde/plasma-systemmonitor-5.23.1-x86_64-1.txz: Upgraded.
kde/plasma-vault-5.23.1-x86_64-1.txz: Upgraded.
kde/plasma-workspace-5.23.1-x86_64-1.txz: Upgraded.
kde/plasma-workspace-wallpapers-5.23.1-x86_64-1.txz: Upgraded.
kde/polkit-kde-agent-1-5.23.1-x86_64-1.txz: Upgraded.
kde/powerdevil-5.23.1-x86_64-1.txz: Upgraded.
kde/qqc2-breeze-style-5.23.1-x86_64-1.txz: Upgraded.
kde/sddm-kcm-5.23.1-x86_64-1.txz: Upgraded.
kde/systemsettings-5.23.1-x86_64-1.txz: Upgraded.
kde/xdg-desktop-portal-kde-5.23.1-x86_64-1.txz: Upgraded.
l/gdbm-1.22-x86_64-1.txz: Upgraded.
n/nghttp2-1.46.0-x86_64-1.txz: Upgraded.
x/ttf-tlwg-0.7.3-noarch-1.txz: Upgraded.
Tue Oct 19 01:10:06 UTC 2021
a/file-5.41-x86_64-1.txz: Upgraded.
ap/vim-8.2.3536-x86_64-1.txz: Upgraded.
kde/plasma-workspace-5.23.0-x86_64-4.txz: Rebuilt.
       Fixed applying the previous patch. Thanks to LuckyCyborg.
xap/vim-gvim-8.2.3536-x86_64-1.txz: Upgraded.
Mon Oct 18 18:40:47 UTC 2021
a/kernel-firmware-20211018_d34196f-noarch-1.txz: Upgraded.
ap/hplip-3.20.5-x86_64-5.txz: Rebuilt.
       Applied patch to fix hp-scan when using Python 3.10. Thanks to kingbeowulf.
ap/mpg123-1.29.1-x86_64-1.txz: Upgraded.
kde/plasma-workspace-5.23.0-x86_64-3.txz: Rebuilt.
       [PATCH] Revert "No icons on the desktop by default". Thanks to LuckyCyborg.
Slackware 32-bit
d/meson-0.60.0-i586-1.txz: Upgraded.
l/ffmpeg-4.4.1-i586-1.txz: Upgraded.
l/imagemagick-7.1.0_11-i586-1.txz: Upgraded.
l/libcap-2.60-i586-1.txz: Upgraded.
l/libsoup-2.74.1-i586-1.txz: Upgraded.
l/sip-4.19.25-i586-3.txz: Rebuilt.
n/dhcpcd-9.4.1-i586-1.txz: Upgraded.
testing/packages/linux-5.14.x/kernel-generic-5.14.14-i586-3.txz: Rebuilt.
testing/packages/linux-5.14.x/kernel-generic-smp-5.14.14_smp-i686-3.txz: Rebuilt.
testing/packages/linux-5.14.x/kernel-headers-5.14.14_smp-x86-3.txz: Rebuilt.
testing/packages/linux-5.14.x/kernel-huge-5.14.14-i586-3.txz: Rebuilt.
testing/packages/linux-5.14.x/kernel-huge-smp-5.14.14_smp-i686-3.txz: Rebuilt.
testing/packages/linux-5.14.x/kernel-modules-5.14.14-i586-3.txz: Rebuilt.
testing/packages/linux-5.14.x/kernel-modules-smp-5.14.14_smp-i686-3.txz: Rebuilt.
testing/packages/linux-5.14.x/kernel-source-5.14.14_smp-noarch-3.txz: Rebuilt.
a/aaa_terminfo-6.3-i586-1.txz: Upgraded.
ap/itstool-2.0.7-i586-2.txz: Rebuilt.
ap/mpg123-1.29.2-i586-1.txz: Upgraded.
d/meson-0.59.3-i586-1.txz: Upgraded.
d/python-pip-21.3.1-i586-1.txz: Upgraded.
d/python-setuptools-58.3.0-i586-1.txz: Upgraded.
l/exiv2-0.27.5-i586-1.txz: Upgraded.
l/ncurses-6.3-i586-1.txz: Upgraded.
n/php-7.4.25-i586-1.txz: Upgraded.
xap/mozilla-thunderbird-91.2.1-i686-1.txz: Upgraded.
       This is a bugfix release.
testing/packages/linux-5.14.x/kernel-generic-5.14.14-i586-2.txz: Rebuilt.
testing/packages/linux-5.14.x/kernel-generic-smp-5.14.14_smp-i686-2.txz: Rebuilt.
testing/packages/linux-5.14.x/kernel-headers-5.14.14_smp-x86-2.txz: Rebuilt.
testing/packages/linux-5.14.x/kernel-huge-5.14.14-i586-2.txz: Rebuilt.
testing/packages/linux-5.14.x/kernel-huge-smp-5.14.14_smp-i686-2.txz: Rebuilt.
testing/packages/linux-5.14.x/kernel-modules-5.14.14-i586-2.txz: Rebuilt.
testing/packages/linux-5.14.x/kernel-modules-smp-5.14.14_smp-i686-2.txz: Rebuilt.
testing/packages/linux-5.14.x/kernel-source-5.14.14_smp-noarch-2.txz: Rebuilt.
       mounted:
       Thanks to Daedra.
       -DRM_I810 n
       PREEMPT n -> y
       +CEC_GPIO n
       +DEBUG_PREEMPT y
       +PREEMPTION y
       +PREEMPT_COUNT y
       +PREEMPT_DYNAMIC y
       +PREEMPT_RCU y
       +PREEMPT_TRACER n
       +RCU_BOOST n
       +TASKS_RCU y
a/lvm2-2.03.13-i586-1.txz: Upgraded.
d/rust-1.56.0-i686-1.txz: Upgraded.
l/pipewire-0.3.39-i586-1.txz: Upgraded.
n/krb5-1.19.2-i586-2.txz: Rebuilt.
       Thanks to nobodino.
x/ibus-m17n-1.4.8-i586-1.txz: Upgraded.
x/libinput-1.19.2-i586-1.txz: Upgraded.
xap/freerdp-2.4.1-i586-1.txz: Upgraded.
       memory.
xap/gftp-2.7.1b-i586-1.txz: Upgraded.
extra/php8/php8-8.0.12-i586-1.txz: Upgraded.
a/kernel-generic-5.14.14-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.14.14_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.14.14-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.14.14_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.14.14-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.14.14_smp-i686-1.txz: Upgraded.
a/lvm2-2.03.14-i586-1.txz: Upgraded.
d/kernel-headers-5.14.14_smp-x86-1.txz: Upgraded.
k/kernel-source-5.14.14_smp-noarch-1.txz: Upgraded.
n/autofs-5.1.8-i586-1.txz: Upgraded.
extra/linux-5.14.14-nosmp-sdk/*: Upgraded.
kde/alkimia-8.1.0-i586-3.txz: Rebuilt.
kde/bluedevil-5.23.1-i586-1.txz: Upgraded.
kde/breeze-5.23.1-i586-1.txz: Upgraded.
kde/breeze-grub-5.23.1-i586-1.txz: Upgraded.
kde/breeze-gtk-5.23.1-i586-1.txz: Upgraded.
kde/drkonqi-5.23.1-i586-1.txz: Upgraded.
kde/kactivitymanagerd-5.23.1-i586-1.txz: Upgraded.
kde/kde-cli-tools-5.23.1-i586-1.txz: Upgraded.
kde/kde-gtk-config-5.23.1-i586-1.txz: Upgraded.
kde/kdecoration-5.23.1-i586-1.txz: Upgraded.
kde/kdeplasma-addons-5.23.1-i586-1.txz: Upgraded.
kde/kgamma5-5.23.1-i586-1.txz: Upgraded.
kde/khotkeys-5.23.1-i586-1.txz: Upgraded.
kde/kinfocenter-5.23.1-i586-1.txz: Upgraded.
kde/kmenuedit-5.23.1-i586-1.txz: Upgraded.
kde/kscreen-5.23.1-i586-1.txz: Upgraded.
kde/kscreenlocker-5.23.1-i586-1.txz: Upgraded.
kde/ksshaskpass-5.23.1-i586-1.txz: Upgraded.
kde/ksystemstats-5.23.1-i586-1.txz: Upgraded.
kde/kwallet-pam-5.23.1-i586-1.txz: Upgraded.
kde/kwayland-integration-5.23.1-i586-1.txz: Upgraded.
kde/kwayland-server-5.23.1-i586-1.txz: Upgraded.
kde/kwin-5.23.1-i586-1.txz: Upgraded.
kde/kwrited-5.23.1-i586-1.txz: Upgraded.
kde/layer-shell-qt-5.23.1-i586-1.txz: Upgraded.
kde/libkscreen-5.23.1-i586-1.txz: Upgraded.
kde/libksysguard-5.23.1-i586-1.txz: Upgraded.
kde/milou-5.23.1-i586-1.txz: Upgraded.
kde/oxygen-5.23.1-i586-1.txz: Upgraded.
kde/plasma-browser-integration-5.23.1-i586-1.txz: Upgraded.
kde/plasma-desktop-5.23.1-i586-1.txz: Upgraded.
kde/plasma-disks-5.23.1-i586-1.txz: Upgraded.
kde/plasma-firewall-5.23.1-i586-1.txz: Upgraded.
kde/plasma-integration-5.23.1-i586-1.txz: Upgraded.
kde/plasma-nm-5.23.1-i586-1.txz: Upgraded.
kde/plasma-pa-5.23.1-i586-1.txz: Upgraded.
kde/plasma-sdk-5.23.1-i586-1.txz: Upgraded.
kde/plasma-systemmonitor-5.23.1-i586-1.txz: Upgraded.
kde/plasma-vault-5.23.1-i586-1.txz: Upgraded.
kde/plasma-workspace-5.23.1-i586-1.txz: Upgraded.
kde/plasma-workspace-wallpapers-5.23.1-i586-1.txz: Upgraded.
kde/polkit-kde-agent-1-5.23.1-i586-1.txz: Upgraded.
kde/powerdevil-5.23.1-i586-1.txz: Upgraded.
kde/qqc2-breeze-style-5.23.1-i586-1.txz: Upgraded.
kde/sddm-kcm-5.23.1-i586-1.txz: Upgraded.
kde/systemsettings-5.23.1-i586-1.txz: Upgraded.
kde/xdg-desktop-portal-kde-5.23.1-i586-1.txz: Upgraded.
l/gdbm-1.22-i586-1.txz: Upgraded.
n/nghttp2-1.46.0-i586-1.txz: Upgraded.
a/file-5.41-i586-1.txz: Upgraded.
ap/vim-8.2.3536-i586-1.txz: Upgraded.
kde/plasma-workspace-5.23.0-i586-4.txz: Rebuilt.
xap/vim-gvim-8.2.3536-i586-1.txz: Upgraded.
ap/hplip-3.20.5-i586-5.txz: Rebuilt.
ap/mpg123-1.29.1-i586-1.txz: Upgraded.
kde/plasma-workspace-5.23.0-i586-3.txz: Rebuilt.
Post Napisano: 01 Nov 2021, 19:05
Slackware 64-bit
Sun Oct 31 19:59:15 UTC 2021
       Reverted to a version that works better for us. Thanks to nobodino.
l/imagemagick-7.1.0_13-x86_64-1.txz: Upgraded.
l/pcre2-10.39-x86_64-1.txz: Upgraded.
l/sip-4.19.25-x86_64-4.txz: Rebuilt.
       Fixed missing sip.h.
n/getmail-6.18.5-x86_64-1.txz: Upgraded.
Fri Oct 29 17:19:45 UTC 2021
a/gawk-5.1.1-x86_64-1.txz: Upgraded.
l/python-packaging-21.2-x86_64-1.txz: Upgraded.
n/pam-krb5-4.11-x86_64-1.txz: Upgraded.
x/mesa-21.2.5-x86_64-1.txz: Upgraded.
xap/blueman-2.2.3-x86_64-1.txz: Upgraded.
xap/freerdp-2.4.1-x86_64-2.txz: Rebuilt.
       Rebuilt without -DWITH_SANITIZE_ADDRESS=ON. Thanks to ctrlaltca.
Thu Oct 28 20:27:04 UTC 2021
a/kernel-firmware-20211028_b21eb26-noarch-1.txz: Upgraded.
l/glib2-2.70.1-x86_64-1.txz: Upgraded.
l/mozilla-nss-3.72-x86_64-1.txz: Upgraded.
l/python-distro-1.6.0-x86_64-1.txz: Upgraded.
l/v4l-utils-1.22.1-x86_64-1.txz: Upgraded.
n/dovecot-2.3.17-x86_64-1.txz: Upgraded.
Thu Oct 28 01:11:07 UTC 2021
a/kernel-generic-5.14.15-x86_64-1.txz: Upgraded.
a/kernel-huge-5.14.15-x86_64-1.txz: Upgraded.
a/kernel-modules-5.14.15-x86_64-1.txz: Upgraded.
d/cmake-3.21.4-x86_64-1.txz: Upgraded.
d/kernel-headers-5.14.15-x86-1.txz: Upgraded.
k/kernel-source-5.14.15-noarch-1.txz: Upgraded.
       We're going to go ahead and take both of those changes that were considered
       in /testing. GazL almost had me talked out of the autogroup change, but it's
       easy to disable if traditional "nice" behavior is important to someone.
       -DRM_I810 n
       PREEMPT n -> y
       +CEC_GPIO n
       +DEBUG_PREEMPT y
       +PREEMPTION y
       +PREEMPT_COUNT y
       +PREEMPT_DYNAMIC y
       +PREEMPT_RCU y
       +PREEMPT_TRACER n
       +RCU_BOOST n
       +TASKS_RCU y
kde/plasma-desktop-5.23.2.1-x86_64-1.txz: Upgraded.
l/imagemagick-7.1.0_12-x86_64-1.txz: Upgraded.
l/librsvg-2.52.3-x86_64-1.txz: Upgraded.
n/bind-9.16.22-x86_64-1.txz: Upgraded.
       This update fixes bugs and the following security issue:
       The "lame-ttl" option is now forcibly set to 0. This effectively disables
       the lame server cache, as it could previously be abused by an attacker to
       significantly degrade resolver performance.
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-25219
n/c-ares-1.18.1-x86_64-1.txz: Upgraded.
n/samba-4.15.1-x86_64-1.txz: Upgraded.
Tue Oct 26 22:01:32 UTC 2021
a/aaa_libraries-15.0-x86_64-11.txz: Rebuilt.
       Upgraded: libcap.so.2.60, libncurses.so.6.3, libncursesw.so.6.3,
       libtinfo.so.6.3, libcares.so.2.5.0, libform.so.6.3, libformw.so.6.3,
       libmenu.so.6.3, libmenuw.so.6.3, libpanel.so.6.3, libpanelw.so.6.3.
       Added: libvpx.so.6.4.0.
a/kernel-firmware-20211025_fc14618-noarch-1.txz: Upgraded.
d/mercurial-5.9.3-x86_64-1.txz: Upgraded.
kde/bluedevil-5.23.2-x86_64-1.txz: Upgraded.
kde/breeze-5.23.2-x86_64-1.txz: Upgraded.
kde/breeze-grub-5.23.2-x86_64-1.txz: Upgraded.
kde/breeze-gtk-5.23.2-x86_64-1.txz: Upgraded.
kde/drkonqi-5.23.2-x86_64-1.txz: Upgraded.
kde/kactivitymanagerd-5.23.2-x86_64-1.txz: Upgraded.
kde/kde-cli-tools-5.23.2-x86_64-1.txz: Upgraded.
kde/kde-gtk-config-5.23.2-x86_64-1.txz: Upgraded.
kde/kdecoration-5.23.2-x86_64-1.txz: Upgraded.
kde/kdeplasma-addons-5.23.2-x86_64-1.txz: Upgraded.
kde/kgamma5-5.23.2-x86_64-1.txz: Upgraded.
kde/khotkeys-5.23.2-x86_64-1.txz: Upgraded.
kde/kinfocenter-5.23.2-x86_64-1.txz: Upgraded.
kde/kmenuedit-5.23.2-x86_64-1.txz: Upgraded.
kde/kscreen-5.23.2-x86_64-1.txz: Upgraded.
kde/kscreenlocker-5.23.2-x86_64-1.txz: Upgraded.
kde/ksshaskpass-5.23.2-x86_64-1.txz: Upgraded.
kde/ksystemstats-5.23.2-x86_64-1.txz: Upgraded.
kde/kwallet-pam-5.23.2-x86_64-1.txz: Upgraded.
kde/kwayland-integration-5.23.2-x86_64-1.txz: Upgraded.
kde/kwayland-server-5.23.2-x86_64-1.txz: Upgraded.
kde/kwin-5.23.2-x86_64-1.txz: Upgraded.
kde/kwrited-5.23.2-x86_64-1.txz: Upgraded.
kde/latte-dock-0.10.3-x86_64-1.txz: Upgraded.
kde/layer-shell-qt-5.23.2-x86_64-1.txz: Upgraded.
kde/libkscreen-5.23.2-x86_64-1.txz: Upgraded.
kde/libksysguard-5.23.2-x86_64-1.txz: Upgraded.
kde/milou-5.23.2-x86_64-1.txz: Upgraded.
kde/oxygen-5.23.2-x86_64-1.txz: Upgraded.
kde/plasma-browser-integration-5.23.2-x86_64-1.txz: Upgraded.
kde/plasma-desktop-5.23.2-x86_64-1.txz: Upgraded.
kde/plasma-disks-5.23.2-x86_64-1.txz: Upgraded.
kde/plasma-firewall-5.23.2-x86_64-1.txz: Upgraded.
kde/plasma-integration-5.23.2-x86_64-1.txz: Upgraded.
kde/plasma-nm-5.23.2-x86_64-1.txz: Upgraded.
kde/plasma-pa-5.23.2-x86_64-1.txz: Upgraded.
kde/plasma-sdk-5.23.2-x86_64-1.txz: Upgraded.
kde/plasma-systemmonitor-5.23.2-x86_64-1.txz: Upgraded.
kde/plasma-vault-5.23.2-x86_64-1.txz: Upgraded.
kde/plasma-workspace-5.23.2-x86_64-1.txz: Upgraded.
kde/plasma-workspace-wallpapers-5.23.2-x86_64-1.txz: Upgraded.
kde/polkit-kde-agent-1-5.23.2-x86_64-1.txz: Upgraded.
kde/powerdevil-5.23.2-x86_64-1.txz: Upgraded.
kde/qqc2-breeze-style-5.23.2-x86_64-1.txz: Upgraded.
kde/sddm-kcm-5.23.2-x86_64-1.txz: Upgraded.
kde/systemsettings-5.23.2-x86_64-1.txz: Upgraded.
kde/xdg-desktop-portal-kde-5.23.2-x86_64-1.txz: Upgraded.
l/ffmpeg-4.4.1-x86_64-2.txz: Rebuilt.
       Recompiled against libvpx-1.11.0.
l/gst-plugins-good-1.18.5-x86_64-2.txz: Rebuilt.
l/libvpx-1.11.0-x86_64-1.txz: Upgraded.
l/python-docutils-0.18-x86_64-1.txz: Upgraded.
l/qt5-5.15.3_20211024_2aa0de43-x86_64-1.txz: Upgraded.
       Upgraded to latest git (might as well) and compiled against libvpx-1.11.0.
n/c-ares-1.18.0-x86_64-1.txz: Upgraded.
xap/xine-lib-1.2.11-x86_64-7.txz: Rebuilt.
Slackware 32-bit
l/imagemagick-7.1.0_13-i586-1.txz: Upgraded.
l/pcre2-10.39-i586-1.txz: Upgraded.
l/sip-4.19.25-i586-4.txz: Rebuilt.
n/getmail-6.18.5-i586-1.txz: Upgraded.
a/gawk-5.1.1-i586-1.txz: Upgraded.
l/python-packaging-21.2-i586-1.txz: Upgraded.
n/pam-krb5-4.11-i586-1.txz: Upgraded.
x/mesa-21.2.5-i586-1.txz: Upgraded.
xap/blueman-2.2.3-i586-1.txz: Upgraded.
xap/freerdp-2.4.1-i586-2.txz: Rebuilt.
l/glib2-2.70.1-i586-1.txz: Upgraded.
l/mozilla-nss-3.72-i586-1.txz: Upgraded.
l/python-distro-1.6.0-i586-1.txz: Upgraded.
l/v4l-utils-1.22.1-i586-1.txz: Upgraded.
n/dovecot-2.3.17-i586-1.txz: Upgraded.
a/kernel-generic-5.14.15-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.14.15_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.14.15-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.14.15_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.14.15-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.14.15_smp-i686-1.txz: Upgraded.
d/cmake-3.21.4-i586-1.txz: Upgraded.
d/kernel-headers-5.14.15_smp-x86-1.txz: Upgraded.
k/kernel-source-5.14.15_smp-noarch-1.txz: Upgraded.
       -DRM_I810 n
       PREEMPT n -> y
       +CEC_GPIO n
       +DEBUG_PREEMPT y
       +PREEMPTION y
       +PREEMPT_COUNT y
       +PREEMPT_DYNAMIC y
       +PREEMPT_RCU y
       +PREEMPT_TRACER n
       +RCU_BOOST n
       +TASKS_RCU y
kde/plasma-desktop-5.23.2.1-i586-1.txz: Upgraded.
l/imagemagick-7.1.0_12-i586-1.txz: Upgraded.
l/librsvg-2.52.3-i586-1.txz: Upgraded.
n/bind-9.16.22-i586-1.txz: Upgraded.
n/c-ares-1.18.1-i586-1.txz: Upgraded.
n/samba-4.15.1-i586-1.txz: Upgraded.
extra/linux-5.14.15-nosmp-sdk/*: Upgraded.
a/aaa_libraries-15.0-i586-11.txz: Rebuilt.
d/mercurial-5.9.3-i586-1.txz: Upgraded.
kde/bluedevil-5.23.2-i586-1.txz: Upgraded.
kde/breeze-5.23.2-i586-1.txz: Upgraded.
kde/breeze-grub-5.23.2-i586-1.txz: Upgraded.
kde/breeze-gtk-5.23.2-i586-1.txz: Upgraded.
kde/drkonqi-5.23.2-i586-1.txz: Upgraded.
kde/kactivitymanagerd-5.23.2-i586-1.txz: Upgraded.
kde/kde-cli-tools-5.23.2-i586-1.txz: Upgraded.
kde/kde-gtk-config-5.23.2-i586-1.txz: Upgraded.
kde/kdecoration-5.23.2-i586-1.txz: Upgraded.
kde/kdeplasma-addons-5.23.2-i586-1.txz: Upgraded.
kde/kgamma5-5.23.2-i586-1.txz: Upgraded.
kde/khotkeys-5.23.2-i586-1.txz: Upgraded.
kde/kinfocenter-5.23.2-i586-1.txz: Upgraded.
kde/kmenuedit-5.23.2-i586-1.txz: Upgraded.
kde/kscreen-5.23.2-i586-1.txz: Upgraded.
kde/kscreenlocker-5.23.2-i586-1.txz: Upgraded.
kde/ksshaskpass-5.23.2-i586-1.txz: Upgraded.
kde/ksystemstats-5.23.2-i586-1.txz: Upgraded.
kde/kwallet-pam-5.23.2-i586-1.txz: Upgraded.
kde/kwayland-integration-5.23.2-i586-1.txz: Upgraded.
kde/kwayland-server-5.23.2-i586-1.txz: Upgraded.
kde/kwin-5.23.2-i586-1.txz: Upgraded.
kde/kwrited-5.23.2-i586-1.txz: Upgraded.
kde/latte-dock-0.10.3-i586-1.txz: Upgraded.
kde/layer-shell-qt-5.23.2-i586-1.txz: Upgraded.
kde/libkscreen-5.23.2-i586-1.txz: Upgraded.
kde/libksysguard-5.23.2-i586-1.txz: Upgraded.
kde/milou-5.23.2-i586-1.txz: Upgraded.
kde/oxygen-5.23.2-i586-1.txz: Upgraded.
kde/plasma-browser-integration-5.23.2-i586-1.txz: Upgraded.
kde/plasma-desktop-5.23.2-i586-1.txz: Upgraded.
kde/plasma-disks-5.23.2-i586-1.txz: Upgraded.
kde/plasma-firewall-5.23.2-i586-1.txz: Upgraded.
kde/plasma-integration-5.23.2-i586-1.txz: Upgraded.
kde/plasma-nm-5.23.2-i586-1.txz: Upgraded.
kde/plasma-pa-5.23.2-i586-1.txz: Upgraded.
kde/plasma-sdk-5.23.2-i586-1.txz: Upgraded.
kde/plasma-systemmonitor-5.23.2-i586-1.txz: Upgraded.
kde/plasma-vault-5.23.2-i586-1.txz: Upgraded.
kde/plasma-workspace-5.23.2-i586-1.txz: Upgraded.
kde/plasma-workspace-wallpapers-5.23.2-i586-1.txz: Upgraded.
kde/polkit-kde-agent-1-5.23.2-i586-1.txz: Upgraded.
kde/powerdevil-5.23.2-i586-1.txz: Upgraded.
kde/qqc2-breeze-style-5.23.2-i586-1.txz: Upgraded.
kde/sddm-kcm-5.23.2-i586-1.txz: Upgraded.
kde/systemsettings-5.23.2-i586-1.txz: Upgraded.
kde/xdg-desktop-portal-kde-5.23.2-i586-1.txz: Upgraded.
l/ffmpeg-4.4.1-i586-2.txz: Rebuilt.
l/gst-plugins-good-1.18.5-i586-2.txz: Rebuilt.
l/libvpx-1.11.0-i586-1.txz: Upgraded.
l/python-docutils-0.18-i586-1.txz: Upgraded.
l/qt5-5.15.3_20211024_2aa0de43-i586-1.txz: Upgraded.
n/c-ares-1.18.0-i586-1.txz: Upgraded.
xap/xine-lib-1.2.11-i586-7.txz: Rebuilt.
