Novosti u *current* -u
Post Napisano: 19 Apr 2018, 07:22
Hi folks, and welcome to the third ever Slackware Mass Rebuild (and the
longest ChangeLog entry in project history). There were two primary
motivations for rebuilding everything in the main tree. The first was to
switch to the new C++ ABI. The second was to get rid of all the .la files
in the LD_LIBRARY_PATH. Really, having .la files installed has been mostly
obsolete since things began to use pkg-config instead, but it's not easy
to get rid of them unless you do it all at once. If you just take them out
of one package, any other packages containing .la files that refer to the
removed ones will be broken. We've removed a few here and there before
(and then handled any packages that had referred to them with a rebuild),
but it was time to finally remove all the ones in /lib{,64} and
/usr/lib{,64}. One of the reasons that this really needed to happen is that
many projects are starting to migrate to build systems other than autotools,
and those systems do not generate .la files. So if we didn't get rid of them
now, we might end up in a situation later on where they are being removed
by upstream and then we would have to chase down the dependency breakage and
recompile (possibly many) other pacakges. The .la files that are outside of
the LD_LIBRARY_PATH were not removed (and shouldn't be) - those ones are
often used by the lt_dlopen() function to load plugins and removing those
ones can break things. But those ones don't cause problems... they aren't
likely to try to infect .la files produced by other packages.
IMPORTANT NOTE: If you have any third party or other packages installed on
your system that don't come with Slackware, and those packages have installed
any .la files, it is very likely that they refer to some .la files which we
have just removed, and that trying to compile against these packages will no
longer work. Luckily, the solution is simple: remove them. This command will
remove any stale .la files from the LD_LIBRARY_PATH:
rm /{,usr/}lib{,64}/*.la
Moving forward, nothing shipped in Slackware will contain any .la files in
those directories, and any SlackBuilds intended to be used with Slackware 15.0
should contain this bit of script:
# Don't ship .la files:
rm -f $PKG/{,usr/}lib${LIBDIRSUFFIX}/*.la
In addition to those goals, the opportunity was taken to clean up slack-desc
files and make many trivial fixes to build scripts. We've also made it easy
to recompile everything again should there be a good reason to do so.
You'll also find various updates scattered throughout this long list.
Enjoy, and sorry about the bandwidth. ;-)
Post Napisano: 19 Apr 2018, 07:24
Slackware 64-bit
Thu Apr 19 01:04:06 UTC 2018
a/aaa_base-14.2-x86_64-4.txz: Rebuilt.
       In /etc/os-release, change PRETTY_NAME to:
       PRETTY_NAME="Slackware 14.2 $ARCH (post 14.2 -current)"
a/aaa_elflibs-14.2-x86_64-35.txz: Rebuilt.
       Removed obsolete libraries: libudev.so.0.13.1, libgdbm.so.3.0.0,
       libhistory.so.5.2, libjpeg.so.8.0.1, libmpfr.so.4.1.6, libpng14.so.14.18.0,
       libreadline.so.5.2, libstdc++.so.5.0.7, libtiff.so.3.9.7,
       and libtiffxx.so.3.9.7.
       Don't create library symlinks in the install script - let installpkg's
       ldconfig do the work.
a/aaa_terminfo-6.1_20180324-x86_64-4.txz: Rebuilt.
       Changed xterm definition as noted for the ncurses package below.
a/acl-2.2.52-x86_64-2.txz: Rebuilt.
a/acpid-2.0.29-x86_64-1.txz: Upgraded.
a/attr-2.4.47-x86_64-2.txz: Rebuilt.
a/bash-4.4.019-x86_64-3.txz: Rebuilt.
a/bin-11.1-x86_64-2.txz: Rebuilt.
a/btrfs-progs-v4.16-x86_64-2.txz: Rebuilt.
a/bzip2-1.0.6-x86_64-2.txz: Rebuilt.
a/coreutils-8.29-x86_64-2.txz: Rebuilt.
a/cpio-2.12-x86_64-2.txz: Rebuilt.
a/cpufrequtils-008-x86_64-2.txz: Rebuilt.
a/cryptsetup-1.7.5-x86_64-2.txz: Rebuilt.
a/dbus-1.12.6-x86_64-2.txz: Rebuilt.
a/dcron-4.5-x86_64-6.txz: Rebuilt.
a/dialog-1.3_20170509-x86_64-2.txz: Rebuilt.
a/dosfstools-4.1-x86_64-2.txz: Rebuilt.
a/e2fsprogs-1.44.1-x86_64-2.txz: Rebuilt.
a/ed-1.14.2-x86_64-2.txz: Rebuilt.
a/efibootmgr-0.5.4-x86_64-2.txz: Rebuilt.
a/elilo-3.16-x86_64-6.txz: Rebuilt.
a/elvis-2.2_0-x86_64-4.txz: Rebuilt.
a/etc-15.0-x86_64-4.txz: Rebuilt.
a/eudev-3.2.5-x86_64-2.txz: Rebuilt.
a/file-5.33-x86_64-1.txz: Upgraded.
a/findutils-4.4.2-x86_64-2.txz: Rebuilt.
a/floppy-5.5-x86_64-2.txz: Rebuilt.
a/gawk-4.2.1-x86_64-2.txz: Rebuilt.
a/genpower-1.0.5-x86_64-3.txz: Rebuilt.
a/gettext-0.19.8.1-x86_64-5.txz: Rebuilt.
a/getty-ps-2.1.0b-x86_64-4.txz: Rebuilt.
a/glibc-solibs-2.27-x86_64-2.txz: Rebuilt.
a/glibc-zoneinfo-2018d-noarch-2.txz: Rebuilt.
a/gpm-1.20.7-x86_64-6.txz: Rebuilt.
a/gptfdisk-1.0.3-x86_64-2.txz: Rebuilt.
a/grep-3.1-x86_64-2.txz: Rebuilt.
a/grub-2.02-x86_64-2.txz: Rebuilt.
a/gzip-1.9-x86_64-2.txz: Rebuilt.
a/hdparm-9.56-x86_64-2.txz: Rebuilt.
a/hostname-3.18-x86_64-2.txz: Rebuilt.
a/hwdata-0.304-noarch-2.txz: Rebuilt.
a/infozip-6.0-x86_64-4.txz: Rebuilt.
a/inotify-tools-3.14-x86_64-2.txz: Rebuilt.
a/jfsutils-1.1.15-x86_64-2.txz: Rebuilt.
a/kbd-1.15.3-x86_64-4.txz: Rebuilt.
a/kernel-firmware-20180409_b562d2f-noarch-1.txz: Upgraded.
a/kmod-25-x86_64-2.txz: Rebuilt.
a/lbzip2-2.5-x86_64-2.txz: Rebuilt.
a/less-530-x86_64-3.txz: Rebuilt.
a/lha-114i-x86_64-2.txz: Rebuilt.
a/libcgroup-0.41-x86_64-3.txz: Rebuilt.
a/libgudev-232-x86_64-2.txz: Rebuilt.
a/lilo-24.2-x86_64-8.txz: Rebuilt.
a/logrotate-3.14.0-x86_64-2.txz: Rebuilt.
a/lrzip-0.631-x86_64-2.txz: Rebuilt.
a/lvm2-2.02.176-x86_64-2.txz: Rebuilt.
a/lzip-1.20-x86_64-3.txz: Rebuilt.
a/lzlib-1.10-x86_64-3.txz: Rebuilt.
a/mcelog-153-x86_64-2.txz: Rebuilt.
a/mdadm-4.0-x86_64-2.txz: Rebuilt.
a/minicom-2.7.1-x86_64-2.txz: Rebuilt.
a/mkinitrd-1.4.11-x86_64-6.txz: Rebuilt.
       Improved and documented UUID support. Thanks to Xsane.
       Upgraded to busybox-1.28.3.
a/mlocate-0.26-x86_64-2.txz: Rebuilt.
a/mt-st-1.3-x86_64-2.txz: Rebuilt.
a/mtx-1.3.12-x86_64-2.txz: Rebuilt.
a/ncompress-4.2.4.4-x86_64-2.txz: Rebuilt.
a/ntfs-3g-2017.3.23-x86_64-2.txz: Rebuilt.
a/openssl-solibs-1.0.2o-x86_64-2.txz: Rebuilt.
a/os-prober-1.76-x86_64-2.txz: Rebuilt.
a/patch-2.7.6-x86_64-3.txz: Rebuilt.
a/pciutils-3.5.6-x86_64-2.txz: Rebuilt.
a/pcmciautils-018-x86_64-2.txz: Rebuilt.
a/pkgtools-15.0-noarch-8.txz: Rebuilt.
       installpkg: avoid messing with the system /install directory.
       removepkg: also run ldconfig following package removal.
a/plzip-1.7-x86_64-3.txz: Rebuilt.
a/procps-ng-3.3.14-x86_64-2.txz: Rebuilt.
a/quota-4.03-x86_64-2.txz: Rebuilt.
a/reiserfsprogs-3.6.27-x86_64-2.txz: Rebuilt.
a/rpm2tgz-1.2.2-x86_64-2.txz: Rebuilt.
a/sdparm-1.10-x86_64-2.txz: Rebuilt.
a/sed-4.5-x86_64-2.txz: Rebuilt.
a/shadow-4.2.1-x86_64-4.txz: Rebuilt.
a/sharutils-4.15.2-x86_64-2.txz: Rebuilt.
a/smartmontools-6.6-x86_64-3.txz: Rebuilt.
a/splitvt-1.6.6-x86_64-2.txz: Rebuilt.
a/sysfsutils-2.1.0-x86_64-2.txz: Rebuilt.
a/sysklogd-1.5.1-x86_64-3.txz: Rebuilt.
a/syslinux-4.07-x86_64-2.txz: Rebuilt.
a/sysvinit-2.88dsf-x86_64-5.txz: Rebuilt.
a/sysvinit-functions-8.53-x86_64-3.txz: Rebuilt.
a/sysvinit-scripts-2.1-noarch-9.txz: Rebuilt.
a/tar-1.30-x86_64-2.txz: Rebuilt.
a/tcsh-6.20.00-x86_64-2.txz: Rebuilt.
a/time-1.9-x86_64-2.txz: Rebuilt.
a/tree-1.7.0-x86_64-2.txz: Rebuilt.
a/udisks-1.0.5-x86_64-4.txz: Rebuilt.
a/udisks2-2.6.5-x86_64-2.txz: Rebuilt.
a/unarj-265-x86_64-2.txz: Rebuilt.
a/upower-0.9.23-x86_64-4.txz: Rebuilt.
a/usb_modeswitch-2.5.1-x86_64-2.txz: Rebuilt.
a/usbutils-009-x86_64-2.txz: Rebuilt.
a/utempter-1.1.6-x86_64-3.txz: Rebuilt.
a/util-linux-2.32-x86_64-2.txz: Rebuilt.
a/which-2.21-x86_64-2.txz: Rebuilt.
a/xfsprogs-4.15.1-x86_64-2.txz: Rebuilt.
a/xz-5.2.3-x86_64-2.txz: Rebuilt.
a/zoo-2.10_22-x86_64-2.txz: Rebuilt.
ap/a2ps-4.14-x86_64-7.txz: Rebuilt.
ap/acct-6.6.4-x86_64-2.txz: Rebuilt.
ap/alsa-utils-1.1.6-x86_64-2.txz: Rebuilt.
ap/amp-0.7.6-x86_64-2.txz: Rebuilt.
ap/at-3.1.20-x86_64-2.txz: Rebuilt.
ap/bc-1.07.1-x86_64-2.txz: Rebuilt.
ap/bpe-2.01.00-x86_64-4.txz: Rebuilt.
ap/cdparanoia-III_10.2-x86_64-2.txz: Rebuilt.
ap/cdrdao-1.2.3-x86_64-4.txz: Rebuilt.
ap/cdrtools-3.01-x86_64-4.txz: Rebuilt.
ap/cgmanager-0.41-x86_64-4.txz: Rebuilt.
ap/cups-2.2.7-x86_64-2.txz: Rebuilt.
ap/cups-filters-1.20.3-x86_64-1.txz: Upgraded.
       Recompiled against poppler-0.64.0.
ap/dash-0.5.9.1-x86_64-2.txz: Rebuilt.
ap/dc3dd-7.2.646-x86_64-2.txz: Rebuilt.
ap/ddrescue-1.23-x86_64-2.txz: Rebuilt.
ap/diffstat-1.61-x86_64-2.txz: Rebuilt.
ap/diffutils-3.6-x86_64-2.txz: Rebuilt.
ap/dmapi-2.2.12-x86_64-3.txz: Rebuilt.
ap/dmidecode-3.1-x86_64-2.txz: Rebuilt.
ap/dvd+rw-tools-7.1-x86_64-3.txz: Rebuilt.
ap/enscript-1.6.6-x86_64-2.txz: Rebuilt.
ap/flac-1.3.2-x86_64-2.txz: Rebuilt.
ap/ghostscript-9.23-x86_64-2.txz: Rebuilt.
ap/ghostscript-fonts-std-8.11-noarch-2.txz: Rebuilt.
ap/gphoto2-2.5.17-x86_64-1.txz: Upgraded.
ap/groff-1.22.3-x86_64-3.txz: Rebuilt.
ap/gutenprint-5.2.13-x86_64-2.txz: Rebuilt.
ap/hplip-3.18.3-x86_64-2.txz: Rebuilt.
ap/htop-2.2.0-x86_64-2.txz: Rebuilt.
ap/ispell-3.4.00-x86_64-2.txz: Rebuilt.
ap/itstool-2.0.4-x86_64-3.txz: Rebuilt.
ap/jed-0.99_19-x86_64-3.txz: Rebuilt.
ap/joe-4.6-x86_64-2.txz: Rebuilt.
ap/jove-4.16.0.73-x86_64-4.txz: Rebuilt.
ap/ksh93-20180412_71e6fdad-x86_64-1.txz: Upgraded.
ap/libx86-1.1-x86_64-3.txz: Rebuilt.
ap/linuxdoc-tools-0.9.72-x86_64-5.txz: Rebuilt.
ap/lm_sensors-3.4.0-x86_64-2.txz: Rebuilt.
ap/lsof-4.91-x86_64-2.txz: Rebuilt.
ap/lsscsi-0.28-x86_64-2.txz: Rebuilt.
ap/lxc-2.0.9-x86_64-2.txz: Rebuilt.
ap/madplay-0.15.2b-x86_64-5.txz: Rebuilt.
ap/man-db-2.8.3-x86_64-2.txz: Rebuilt.
ap/man-pages-4.15-noarch-2.txz: Rebuilt.
ap/mariadb-10.2.14-x86_64-2.txz: Rebuilt.
ap/mc-4.8.20-x86_64-2.txz: Rebuilt.
ap/moc-2.5.2-x86_64-4.txz: Rebuilt.
ap/most-5.0.0a-x86_64-3.txz: Rebuilt.
ap/mpg123-1.25.10-x86_64-2.txz: Rebuilt.
ap/nano-2.9.5-x86_64-2.txz: Rebuilt.
ap/normalize-0.7.7-x86_64-3.txz: Rebuilt.
ap/opus-tools-0.1.10-x86_64-2.txz: Rebuilt.
ap/pamixer-1.3.1-x86_64-6.txz: Rebuilt.
       Recompiled against boost-1.67.0.
ap/pm-utils-1.4.1-x86_64-6.txz: Rebuilt.
ap/powertop-2.8-x86_64-3.txz: Rebuilt.
ap/qpdf-8.0.2-x86_64-2.txz: Rebuilt.
ap/radeontool-1.6.3-x86_64-2.txz: Rebuilt.
ap/rpm-4.14.1-x86_64-2.txz: Rebuilt.
ap/rzip-2.1-x86_64-2.txz: Rebuilt.
ap/sc-7.16-x86_64-6.txz: Rebuilt.
ap/screen-4.6.2-x86_64-2.txz: Rebuilt.
ap/seejpeg-1.10-x86_64-2.txz: Rebuilt.
ap/slackpkg-2.82.2-noarch-2.txz: Rebuilt.
ap/soma-2.12.3-noarch-2.txz: Rebuilt.
ap/sox-14.4.2-x86_64-5.txz: Rebuilt.
ap/sqlite-3.23.1-x86_64-2.txz: Rebuilt.
ap/squashfs-tools-4.3-x86_64-3.txz: Rebuilt.
ap/sudo-1.8.22-x86_64-2.txz: Rebuilt.
ap/sysstat-11.6.3-x86_64-2.txz: Rebuilt.
ap/terminus-font-4.40-noarch-2.txz: Rebuilt.
ap/texinfo-6.5-x86_64-3.txz: Rebuilt.
       Recompiled against perl-5.26.2.
ap/tmux-2.7-x86_64-1.txz: Upgraded.
ap/usbmuxd-1.1.0-x86_64-2.txz: Rebuilt.
ap/vbetool-1.2.2-x86_64-2.txz: Rebuilt.
ap/vim-8.0.1733-x86_64-1.txz: Upgraded.
ap/vorbis-tools-1.4.0-x86_64-4.txz: Rebuilt.
ap/xfsdump-3.1.8-x86_64-2.txz: Rebuilt.
ap/xorriso-1.4.8-x86_64-2.txz: Rebuilt.
ap/zsh-5.5.1-x86_64-1.txz: Upgraded.
d/Cython-0.28.1-x86_64-2.txz: Rebuilt.
d/autoconf-2.69-noarch-2.txz: Rebuilt.
d/automake-1.16.1-noarch-2.txz: Rebuilt.
d/binutils-2.30-x86_64-2.txz: Rebuilt.
d/bison-3.0.4-x86_64-2.txz: Rebuilt.
d/ccache-3.4.2-x86_64-2.txz: Rebuilt.
d/clisp-2.49.20180409.0e4d38776f59-x86_64-1.txz: Upgraded.
d/cmake-3.11.1-x86_64-1.txz: Upgraded.
d/cscope-15.8b-x86_64-3.txz: Rebuilt.
d/cvs-1.11.23-x86_64-3.txz: Rebuilt.
d/dev86-0.16.21-x86_64-2.txz: Rebuilt.
d/distcc-3.3-x86_64-2.txz: Rebuilt.
d/doxygen-1.8.14-x86_64-2.txz: Rebuilt.
d/flex-2.6.4-x86_64-3.txz: Rebuilt.
d/gcc-7.3.0-x86_64-2.txz: Rebuilt.
d/gcc-brig-7.3.0-x86_64-2.txz: Rebuilt.
d/gcc-g++-7.3.0-x86_64-2.txz: Rebuilt.
d/gcc-gfortran-7.3.0-x86_64-2.txz: Rebuilt.
d/gcc-gnat-7.3.0-x86_64-2.txz: Rebuilt.
d/gcc-go-7.3.0-x86_64-2.txz: Rebuilt.
d/gcc-objc-7.3.0-x86_64-2.txz: Rebuilt.
d/gdb-8.1-x86_64-2.txz: Rebuilt.
d/gettext-tools-0.19.8.1-x86_64-5.txz: Rebuilt.
d/git-2.17.0-x86_64-2.txz: Rebuilt.
d/gnucobol-2.2-x86_64-2.txz: Rebuilt.
d/gperf-3.1-x86_64-2.txz: Rebuilt.
d/guile-2.2.3-x86_64-2.txz: Rebuilt.
d/help2man-1.47.6-x86_64-2.txz: Rebuilt.
d/indent-2.2.10-x86_64-2.txz: Rebuilt.
d/intltool-0.51.0-x86_64-4.txz: Rebuilt.
d/libtool-2.4.6-x86_64-7.txz: Rebuilt.
d/llvm-6.0.0-x86_64-2.txz: Rebuilt.
d/m4-1.4.18-x86_64-2.txz: Rebuilt.
d/make-4.2.1-x86_64-3.txz: Rebuilt.
d/mercurial-4.5.3-x86_64-2.txz: Rebuilt.
d/meson-0.45.1-x86_64-2.txz: Rebuilt.
d/nasm-2.13.03-x86_64-2.txz: Rebuilt.
d/ninja-1.8.2-x86_64-2.txz: Rebuilt.
d/opencl-headers-2.1-noarch-2.txz: Rebuilt.
d/oprofile-1.2.0-x86_64-3.txz: Rebuilt.
d/p2c-1.21alpha2-x86_64-4.txz: Rebuilt.
d/patchelf-0.9-x86_64-2.txz: Rebuilt.
d/perl-5.26.2-x86_64-1.txz: Upgraded.
       Upgraded to DBD-mysql-4.046, DBI-1.641, and XML-Simple-2.25.
d/pkg-config-0.29.2-x86_64-2.txz: Rebuilt.
d/pmake-1.111-x86_64-5.txz: Rebuilt.
d/python-2.7.14-x86_64-2.txz: Rebuilt.
d/python-pip-9.0.3-x86_64-2.txz: Rebuilt.
d/python-setuptools-39.0.1-x86_64-2.txz: Rebuilt.
d/python3-3.6.5-x86_64-2.txz: Rebuilt.
d/rcs-5.9.4-x86_64-2.txz: Rebuilt.
d/re2c-1.0.3-x86_64-2.txz: Rebuilt.
d/ruby-2.5.1-x86_64-2.txz: Rebuilt.
d/rust-1.25.0-x86_64-2.txz: Rebuilt.
d/scons-3.0.1-x86_64-2.txz: Rebuilt.
d/slacktrack-2.18-x86_64-2.txz: Rebuilt.
d/strace-4.22-x86_64-2.txz: Rebuilt.
d/subversion-1.10.0-x86_64-1.txz: Upgraded.
d/swig-3.0.12-x86_64-2.txz: Rebuilt.
d/yasm-1.3.0-x86_64-2.txz: Rebuilt.
e/emacs-25.3-x86_64-2.txz: Rebuilt.
kde/amarok-2.9.0-x86_64-2.txz: Rebuilt.
kde/amor-4.14.3-x86_64-3.txz: Rebuilt.
kde/analitza-4.14.3-x86_64-4.txz: Rebuilt.
kde/ark-4.14.3-x86_64-3.txz: Rebuilt.
kde/artikulate-4.14.3-x86_64-3.txz: Rebuilt.
kde/audiocd-kio-4.14.3-x86_64-3.txz: Rebuilt.
kde/baloo-4.14.3-x86_64-4.txz: Rebuilt.
kde/baloo-widgets-4.14.3-x86_64-3.txz: Rebuilt.
kde/blinken-4.14.3-x86_64-3.txz: Rebuilt.
kde/bluedevil-2.1.1-x86_64-4.txz: Rebuilt.
kde/bomber-4.14.3-x86_64-3.txz: Rebuilt.
kde/bovo-4.14.3-x86_64-3.txz: Rebuilt.
kde/calligra-2.9.11-x86_64-20.txz: Rebuilt.
       Recompiled against boost-1.67.0 and poppler-0.64.0.
kde/cantor-4.14.3-x86_64-3.txz: Rebuilt.
kde/cervisia-4.14.3-x86_64-3.txz: Rebuilt.
kde/dolphin-plugins-4.14.3-x86_64-3.txz: Rebuilt.
kde/dragon-4.14.3-x86_64-3.txz: Rebuilt.
kde/filelight-4.14.3-x86_64-3.txz: Rebuilt.
kde/granatier-4.14.3-x86_64-3.txz: Rebuilt.
kde/gwenview-4.14.3-x86_64-4.txz: Rebuilt.
kde/juk-4.14.3-x86_64-3.txz: Rebuilt.
kde/k3b-2.0.3-x86_64-4.txz: Rebuilt.
kde/kaccessible-4.14.3-x86_64-3.txz: Rebuilt.
kde/kactivities-4.13.3-x86_64-3.txz: Rebuilt.
kde/kajongg-4.14.3-x86_64-3.txz: Rebuilt.
kde/kalgebra-4.14.3-x86_64-3.txz: Rebuilt.
kde/kalzium-4.14.3-x86_64-3.txz: Rebuilt.
kde/kamera-4.14.3-x86_64-3.txz: Rebuilt.
kde/kanagram-4.14.3-x86_64-3.txz: Rebuilt.
kde/kapman-4.14.3-x86_64-3.txz: Rebuilt.
kde/kapptemplate-4.14.3-x86_64-3.txz: Rebuilt.
kde/kate-4.14.3-x86_64-4.txz: Rebuilt.
kde/katomic-4.14.3-x86_64-3.txz: Rebuilt.
kde/kaudiocreator-1.3-x86_64-3.txz: Rebuilt.
kde/kblackbox-4.14.3-x86_64-3.txz: Rebuilt.
kde/kblocks-4.14.3-x86_64-3.txz: Rebuilt.
kde/kbounce-4.14.3-x86_64-3.txz: Rebuilt.
kde/kbreakout-4.14.3-x86_64-3.txz: Rebuilt.
kde/kbruch-4.14.3-x86_64-3.txz: Rebuilt.
kde/kcachegrind-4.14.3-x86_64-3.txz: Rebuilt.
kde/kcalc-4.14.3-x86_64-3.txz: Rebuilt.
kde/kcharselect-4.14.3-x86_64-3.txz: Rebuilt.
kde/kcolorchooser-4.14.3-x86_64-3.txz: Rebuilt.
kde/kcron-4.14.3-x86_64-3.txz: Rebuilt.
kde/kde-base-artwork-4.14.3-x86_64-3.txz: Rebuilt.
kde/kde-baseapps-4.14.3-x86_64-3.txz: Rebuilt.
kde/kde-dev-scripts-4.14.3-x86_64-3.txz: Rebuilt.
kde/kde-dev-utils-4.14.3-x86_64-3.txz: Rebuilt.
kde/kde-runtime-4.14.3-x86_64-6.txz: Rebuilt.
kde/kde-wallpapers-4.14.3-noarch-2.txz: Rebuilt.
kde/kde-workspace-4.11.22-x86_64-5.txz: Rebuilt.
kde/kdeartwork-4.14.3-x86_64-3.txz: Rebuilt.
kde/kdeconnect-kde-0.8-x86_64-4.txz: Rebuilt.
kde/kdegraphics-mobipocket-4.14.3-x86_64-3.txz: Rebuilt.
kde/kdegraphics-strigi-analyzer-4.14.3-x86_64-3.txz: Rebuilt.
kde/kdegraphics-thumbnailers-4.14.3-x86_64-3.txz: Rebuilt.
kde/kdelibs-4.14.38-x86_64-2.txz: Rebuilt.
kde/kdenetwork-filesharing-4.14.3-x86_64-3.txz: Rebuilt.
kde/kdenetwork-strigi-analyzers-4.14.3-x86_64-3.txz: Rebuilt.
kde/kdepim-4.14.10-x86_64-3.txz: Rebuilt.
kde/kdepim-runtime-4.14.10-x86_64-2.txz: Rebuilt.
kde/kdepimlibs-4.14.10-x86_64-5.txz: Rebuilt.
kde/kdeplasma-addons-4.14.3-x86_64-3.txz: Rebuilt.
kde/kdesdk-kioslaves-4.14.3-x86_64-3.txz: Rebuilt.
kde/kdesdk-strigi-analyzers-4.14.3-x86_64-3.txz: Rebuilt.
kde/kdesdk-thumbnailers-4.14.3-x86_64-3.txz: Rebuilt.
kde/kdev-python-1.7.3-x86_64-3.txz: Rebuilt.
kde/kdevelop-4.7.4-x86_64-2.txz: Rebuilt.
kde/kdevelop-pg-qt-1.0.0-x86_64-3.txz: Rebuilt.
kde/kdevelop-php-1.7.4-x86_64-2.txz: Rebuilt.
kde/kdevelop-php-docs-1.7.4-x86_64-2.txz: Rebuilt.
kde/kdevplatform-1.7.4-x86_64-2.txz: Rebuilt.
kde/kdewebdev-4.14.3-x86_64-3.txz: Rebuilt.
kde/kdf-4.14.3-x86_64-3.txz: Rebuilt.
kde/kdiamond-4.14.3-x86_64-3.txz: Rebuilt.
kde/kfilemetadata-4.14.3-x86_64-4.txz: Rebuilt.
kde/kfloppy-4.14.3-x86_64-3.txz: Rebuilt.
kde/kfourinline-4.14.3-x86_64-3.txz: Rebuilt.
kde/kgamma-4.14.3-x86_64-3.txz: Rebuilt.
kde/kgeography-4.14.3-x86_64-3.txz: Rebuilt.
kde/kget-4.14.3-x86_64-4.txz: Rebuilt.
kde/kgoldrunner-4.14.3-x86_64-3.txz: Rebuilt.
kde/kgpg-4.14.3-x86_64-3.txz: Rebuilt.
kde/khangman-4.14.3-x86_64-3.txz: Rebuilt.
kde/kig-4.14.3-x86_64-8.txz: Rebuilt.
kde/kigo-4.14.3-x86_64-3.txz: Rebuilt.
kde/killbots-4.14.3-x86_64-3.txz: Rebuilt.
kde/kio-mtp-2063e75_20131020git-x86_64-4.txz: Rebuilt.
kde/kiriki-4.14.3-x86_64-3.txz: Rebuilt.
kde/kiten-4.14.3-x86_64-3.txz: Rebuilt.
kde/kjumpingcube-4.14.3-x86_64-3.txz: Rebuilt.
kde/klettres-4.14.3-x86_64-3.txz: Rebuilt.
kde/klickety-4.14.3-x86_64-3.txz: Rebuilt.
kde/klines-4.14.3-x86_64-3.txz: Rebuilt.
kde/kmag-4.14.3-x86_64-3.txz: Rebuilt.
kde/kmahjongg-4.14.3-x86_64-3.txz: Rebuilt.
kde/kmines-4.14.3-x86_64-3.txz: Rebuilt.
kde/kmix-4.14.3-x86_64-4.txz: Rebuilt.
kde/kmousetool-4.14.3-x86_64-3.txz: Rebuilt.
kde/kmouth-4.14.3-x86_64-3.txz: Rebuilt.
kde/kmplot-4.14.3-x86_64-3.txz: Rebuilt.
kde/knavalbattle-4.14.3-x86_64-3.txz: Rebuilt.
kde/knetwalk-4.14.3-x86_64-3.txz: Rebuilt.
kde/kolf-4.14.3-x86_64-3.txz: Rebuilt.
kde/kollision-4.14.3-x86_64-3.txz: Rebuilt.
kde/kolourpaint-4.14.3-x86_64-3.txz: Rebuilt.
kde/kompare-4.14.3-x86_64-3.txz: Rebuilt.
kde/konquest-4.14.3-x86_64-3.txz: Rebuilt.
kde/konsole-4.14.3-x86_64-5.txz: Rebuilt.
       Reverted TERM change, so by default TERM=xterm again.
kde/kopete-4.14.3-x86_64-5.txz: Rebuilt.
kde/korundum-4.14.3-x86_64-6.txz: Rebuilt.
kde/kpat-4.14.3-x86_64-3.txz: Rebuilt.
kde/kplayer-0.7.2-x86_64-3.txz: Rebuilt.
kde/kppp-4.14.3-x86_64-3.txz: Rebuilt.
kde/kqtquickcharts-4.14.3-x86_64-3.txz: Rebuilt.
kde/krdc-4.14.3-x86_64-4.txz: Rebuilt.
kde/kremotecontrol-4.14.3-x86_64-3.txz: Rebuilt.
kde/kreversi-4.14.3-x86_64-3.txz: Rebuilt.
kde/krfb-4.14.3-x86_64-3.txz: Rebuilt.
kde/kross-interpreters-4.14.3-x86_64-4.txz: Rebuilt.
kde/kruler-4.14.3-x86_64-3.txz: Rebuilt.
kde/ksaneplugin-4.14.3-x86_64-3.txz: Rebuilt.
kde/kscreen-1.0.2.1-x86_64-3.txz: Rebuilt.
kde/kshisen-4.14.3-x86_64-3.txz: Rebuilt.
kde/ksirk-4.14.3-x86_64-3.txz: Rebuilt.
kde/ksnakeduel-4.14.3-x86_64-3.txz: Rebuilt.
kde/ksnapshot-4.14.3-x86_64-3.txz: Rebuilt.
kde/kspaceduel-4.14.3-x86_64-3.txz: Rebuilt.
kde/ksquares-4.14.3-x86_64-3.txz: Rebuilt.
kde/kstars-4.14.3-x86_64-3.txz: Rebuilt.
kde/ksudoku-4.14.3-x86_64-3.txz: Rebuilt.
kde/ksystemlog-4.14.3-x86_64-3.txz: Rebuilt.
kde/kteatime-4.14.3-x86_64-3.txz: Rebuilt.
kde/ktimer-4.14.3-x86_64-3.txz: Rebuilt.
kde/ktorrent-4.3.1-x86_64-3.txz: Rebuilt.
kde/ktouch-4.14.3-x86_64-4.txz: Rebuilt.
kde/ktuberling-4.14.3-x86_64-3.txz: Rebuilt.
kde/kturtle-4.14.3-x86_64-3.txz: Rebuilt.
kde/ktux-4.14.3-x86_64-3.txz: Rebuilt.
kde/kubrick-4.14.3-x86_64-3.txz: Rebuilt.
kde/kuser-4.14.3-x86_64-3.txz: Rebuilt.
kde/kwalletmanager-4.14.3-x86_64-3.txz: Rebuilt.
kde/kwebkitpart-1.3.4-x86_64-3.txz: Rebuilt.
kde/kwordquiz-4.14.3-x86_64-3.txz: Rebuilt.
kde/libkcddb-4.14.3-x86_64-3.txz: Rebuilt.
kde/libkcompactdisc-4.14.3-x86_64-3.txz: Rebuilt.
kde/libkdcraw-4.14.3-x86_64-5.txz: Rebuilt.
kde/libkdeedu-4.14.3-x86_64-3.txz: Rebuilt.
kde/libkdegames-4.14.3-x86_64-3.txz: Rebuilt.
kde/libkexiv2-4.14.3-x86_64-4.txz: Rebuilt.
kde/libkipi-4.14.3-x86_64-3.txz: Rebuilt.
kde/libkmahjongg-4.14.3-x86_64-3.txz: Rebuilt.
kde/libkomparediff2-4.14.3-x86_64-3.txz: Rebuilt.
kde/libksane-4.14.3-x86_64-3.txz: Rebuilt.
kde/libkscreen-1.0.5-x86_64-3.txz: Rebuilt.
kde/libktorrent-1.3.1-x86_64-4.txz: Rebuilt.
kde/libmm-qt-1.0.1-x86_64-3.txz: Rebuilt.
kde/libnm-qt-0.9.8.3-x86_64-3.txz: Rebuilt.
kde/lokalize-4.14.3-x86_64-4.txz: Rebuilt.
kde/lskat-4.14.3-x86_64-4.txz: Rebuilt.
kde/marble-4.14.3-x86_64-3.txz: Rebuilt.
kde/mplayerthumbs-4.14.3-x86_64-3.txz: Rebuilt.
kde/nepomuk-core-4.14.3-x86_64-4.txz: Rebuilt.
kde/nepomuk-widgets-4.14.3-x86_64-3.txz: Rebuilt.
kde/okteta-4.14.3-x86_64-3.txz: Rebuilt.
kde/okular-4.14.3-x86_64-3.txz: Rebuilt.
kde/oxygen-gtk2-1.4.6-x86_64-3.txz: Rebuilt.
kde/oxygen-icons-4.14.3-x86_64-3.txz: Rebuilt.
kde/pairs-4.14.3-x86_64-3.txz: Rebuilt.
kde/palapeli-4.14.3-x86_64-3.txz: Rebuilt.
kde/parley-4.14.3-x86_64-3.txz: Rebuilt.
kde/partitionmanager-1.1.1-x86_64-3.txz: Rebuilt.
kde/perlkde-4.14.3-x86_64-5.txz: Rebuilt.
kde/perlqt-4.14.3-x86_64-6.txz: Rebuilt.
kde/picmi-4.14.3-x86_64-3.txz: Rebuilt.
kde/plasma-nm-0.9.3.6-x86_64-2.txz: Rebuilt.
kde/polkit-kde-agent-1-9d74ae3_20120104git-x86_64-3.txz: Rebuilt.
kde/polkit-kde-kcmodules-1-001bdf7_20120111git-x86_64-3.txz: Rebuilt.
kde/poxml-4.14.3-x86_64-3.txz: Rebuilt.
kde/print-manager-4.14.3-x86_64-3.txz: Rebuilt.
kde/pykde4-4.14.3-x86_64-7.txz: Rebuilt.
kde/qtruby-4.14.3-x86_64-8.txz: Rebuilt.
kde/rocs-4.14.3-x86_64-3.txz: Rebuilt.
kde/skanlite-1.1-x86_64-3.txz: Rebuilt.
kde/smokegen-4.14.3-x86_64-3.txz: Rebuilt.
kde/smokekde-4.14.3-x86_64-3.txz: Rebuilt.
kde/smokeqt-4.14.3-x86_64-5.txz: Rebuilt.
kde/step-4.14.3-x86_64-6.txz: Rebuilt.
kde/superkaramba-4.14.3-x86_64-4.txz: Rebuilt.
kde/svgpart-4.14.3-x86_64-3.txz: Rebuilt.
kde/sweeper-4.14.3-x86_64-3.txz: Rebuilt.
kde/umbrello-4.14.3-x86_64-3.txz: Rebuilt.
kde/wicd-kde-0.3.0_bcf27d8-x86_64-3.txz: Rebuilt.
kde/zeroconf-ioslave-4.14.3-x86_64-3.txz: Rebuilt.
l/ConsoleKit2-1.0.0-x86_64-4.txz: Rebuilt.
l/GConf-3.2.6-x86_64-4.txz: Rebuilt.
l/LibRaw-0.18.8-x86_64-2.txz: Rebuilt.
l/M2Crypto-0.27.0-x86_64-3.txz: Rebuilt.
l/Mako-1.0.7-x86_64-2.txz: Rebuilt.
l/PyQt-4.12.1-x86_64-2.txz: Rebuilt.
l/QScintilla-2.10.2-x86_64-2.txz: Rebuilt.
l/SDL2-2.0.8-x86_64-2.txz: Rebuilt.
l/SDL2_gfx-1.0.3-x86_64-2.txz: Rebuilt.
l/SDL2_image-2.0.3-x86_64-2.txz: Rebuilt.
l/SDL2_mixer-2.0.2-x86_64-3.txz: Rebuilt.
l/SDL2_net-2.0.1-x86_64-2.txz: Rebuilt.
l/SDL2_ttf-2.0.14-x86_64-2.txz: Rebuilt.
l/a52dec-0.7.4-x86_64-3.txz: Rebuilt.
l/aalib-1.4rc5-x86_64-6.txz: Rebuilt.
l/adwaita-icon-theme-3.28.0-noarch-2.txz: Rebuilt.
l/akonadi-1.13.0-x86_64-9.txz: Rebuilt.
l/alsa-lib-1.1.6-x86_64-3.txz: Rebuilt.
l/alsa-oss-1.1.6-x86_64-2.txz: Rebuilt.
l/alsa-plugins-1.1.6-x86_64-2.txz: Rebuilt.
l/apr-1.6.3-x86_64-2.txz: Rebuilt.
l/apr-util-1.6.1-x86_64-6.txz: Rebuilt.
l/aspell-0.60.6.1-x86_64-3.txz: Rebuilt.
l/aspell-en-2018.04.16_0-x86_64-1.txz: Upgraded.
l/at-spi2-atk-2.26.2-x86_64-2.txz: Rebuilt.
l/at-spi2-core-2.28.0-x86_64-2.txz: Rebuilt.
l/atk-2.28.1-x86_64-2.txz: Rebuilt.
l/atkmm-2.24.2-x86_64-2.txz: Rebuilt.
l/attica-0.4.2-x86_64-2.txz: Rebuilt.
l/audiofile-0.3.6-x86_64-2.txz: Rebuilt.
l/automoc4-0.9.88-x86_64-2.txz: Rebuilt.
l/babl-0.1.46-x86_64-1.txz: Upgraded.
l/boost-1.67.0-x86_64-1.txz: Upgraded.
l/cairo-1.15.12-x86_64-2.txz: Rebuilt.
l/cairomm-1.12.2-x86_64-2.txz: Rebuilt.
l/chmlib-0.40-x86_64-3.txz: Rebuilt.
l/clucene-2.3.3.4-x86_64-3.txz: Rebuilt.
l/db42-4.2.52-x86_64-4.txz: Rebuilt.
l/db44-4.4.20-x86_64-4.txz: Rebuilt.
l/db48-4.8.30-x86_64-3.txz: Rebuilt.
l/dbus-glib-0.110-x86_64-2.txz: Rebuilt.
l/dbus-python-1.2.6-x86_64-2.txz: Rebuilt.
l/dconf-0.26.1-x86_64-2.txz: Rebuilt.
l/dconf-editor-3.26.2-x86_64-2.txz: Rebuilt.
l/desktop-file-utils-0.23-x86_64-2.txz: Rebuilt.
l/djvulibre-3.5.27-x86_64-2.txz: Rebuilt.
l/ebook-tools-0.2.2-x86_64-5.txz: Rebuilt.
l/eigen2-2.0.17-x86_64-2.txz: Rebuilt.
l/eigen3-3.2.10-x86_64-2.txz: Rebuilt.
l/elfutils-0.170-x86_64-2.txz: Rebuilt.
l/enchant-1.6.1-x86_64-2.txz: Rebuilt.
l/esound-0.2.41-x86_64-3.txz: Rebuilt.
l/exiv2-0.26-x86_64-3.txz: Rebuilt.
l/expat-2.2.5-x86_64-2.txz: Rebuilt.
l/ffmpeg-3.4.2-x86_64-2.txz: Rebuilt.
l/fftw-3.3.7-x86_64-2.txz: Rebuilt.
l/fluidsynth-1.1.10-x86_64-2.txz: Rebuilt.
l/freetype-2.9-x86_64-2.txz: Rebuilt.
l/fribidi-0.19.7-x86_64-2.txz: Rebuilt.
l/fuse-2.9.7-x86_64-2.txz: Rebuilt.
l/gamin-0.1.10-x86_64-6.txz: Rebuilt.
l/gc-7.6.4-x86_64-2.txz: Rebuilt.
l/gcr-3.28.0-x86_64-2.txz: Rebuilt.
l/gd-2.2.5-x86_64-1.txz: Upgraded.
       Double-free in gdImagePngPtr() (denial of service).
       Buffer over-read into uninitialized memory (information leak).
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-6362
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-7890
l/gdbm-1.13-x86_64-2.txz: Rebuilt.
l/gdk-pixbuf2-2.36.12-x86_64-2.txz: Rebuilt.
l/gegl-0.2.0-x86_64-7.txz: Rebuilt.
l/giflib-5.1.4-x86_64-2.txz: Rebuilt.
l/glade3-3.8.6-x86_64-2.txz: Rebuilt.
l/glib-1.2.10-x86_64-6.txz: Rebuilt.
l/glib-networking-2.56.0-x86_64-2.txz: Rebuilt.
l/glib2-2.56.1-x86_64-2.txz: Rebuilt.
l/glibc-2.27-x86_64-2.txz: Rebuilt.
       [PATCH] Linux: use reserved name __key in pkey_get [BZ #22797]
l/glibc-i18n-2.27-x86_64-2.txz: Rebuilt.
l/glibc-profile-2.27-x86_64-2.txz: Rebuilt.
l/glibmm-2.56.0-x86_64-1.txz: Upgraded.
l/gmime-2.6.23-x86_64-3.txz: Rebuilt.
l/gmm-4.3-noarch-2.txz: Rebuilt.
l/gmp-6.1.2-x86_64-2.txz: Rebuilt.
l/gnome-keyring-3.28.0.2-x86_64-2.txz: Rebuilt.
l/gnome-themes-standard-3.22.3-x86_64-2.txz: Rebuilt.
l/gnu-efi-3.0.6-x86_64-2.txz: Rebuilt.
l/gobject-introspection-1.56.1-x86_64-2.txz: Rebuilt.
l/grantlee-0.5.1-x86_64-2.txz: Rebuilt.
l/gsettings-desktop-schemas-3.28.0-x86_64-2.txz: Rebuilt.
l/gsl-2.4-x86_64-2.txz: Rebuilt.
l/gst-plugins-base-1.14.0-x86_64-2.txz: Rebuilt.
l/gst-plugins-base0-0.10.36-x86_64-3.txz: Rebuilt.
l/gst-plugins-good-1.14.0-x86_64-2.txz: Rebuilt.
l/gst-plugins-good0-0.10.31-x86_64-3.txz: Rebuilt.
l/gst-plugins-libav-1.14.0-x86_64-2.txz: Rebuilt.
l/gstreamer-1.14.0-x86_64-2.txz: Rebuilt.
l/gstreamer0-0.10.36-x86_64-2.txz: Rebuilt.
l/gtk+-1.2.10-x86_64-7.txz: Rebuilt.
l/gtk+2-2.24.32-x86_64-2.txz: Rebuilt.
l/gtk+3-3.22.30-x86_64-1.txz: Upgraded.
l/gtkmm2-2.24.5-x86_64-2.txz: Rebuilt.
l/gtkmm3-3.22.2-x86_64-2.txz: Rebuilt.
l/gtkspell-2.0.16-x86_64-4.txz: Rebuilt.
l/gvfs-1.36.1-x86_64-2.txz: Rebuilt.
l/harfbuzz-1.7.6-x86_64-3.txz: Rebuilt.
l/hicolor-icon-theme-0.17-noarch-2.txz: Rebuilt.
l/hunspell-1.6.2-x86_64-2.txz: Rebuilt.
l/icon-naming-utils-0.8.90-x86_64-3.txz: Rebuilt.
l/icu4c-61.1-x86_64-2.txz: Rebuilt.
l/id3lib-3.8.3-x86_64-2.txz: Rebuilt.
l/ilmbase-2.2.0-x86_64-2.txz: Rebuilt.
l/imagemagick-6.9.9_40-x86_64-2.txz: Rebuilt.
       Don't use OpenCL. Thanks to EdGr.
l/iso-codes-3.76-noarch-2.txz: Rebuilt.
l/jansson-2.11-x86_64-2.txz: Rebuilt.
l/jasper-2.0.12-x86_64-2.txz: Rebuilt.
l/jemalloc-4.5.0-x86_64-2.txz: Rebuilt.
l/js185-1.0.0-x86_64-2.txz: Rebuilt.
l/judy-1.0.5-x86_64-2.txz: Rebuilt.
l/keybinder-0.3.1-x86_64-2.txz: Rebuilt.
l/keyutils-1.5.10-x86_64-2.txz: Rebuilt.
l/lame-3.100-x86_64-2.txz: Rebuilt.
l/lcms-1.19-x86_64-4.txz: Rebuilt.
l/lcms2-2.9-x86_64-2.txz: Rebuilt.
l/libaio-0.3.110-x86_64-2.txz: Rebuilt.
l/libao-1.2.2-x86_64-2.txz: Rebuilt.
l/libarchive-3.3.2-x86_64-2.txz: Rebuilt.
l/libart_lgpl-2.3.21-x86_64-2.txz: Rebuilt.
l/libasyncns-0.8-x86_64-2.txz: Rebuilt.
l/libatasmart-0.19-x86_64-3.txz: Rebuilt.
l/libbluedevil-2.1-x86_64-2.txz: Rebuilt.
l/libbluray-1.0.1-x86_64-2.txz: Rebuilt.
l/libcaca-0.99.beta19-x86_64-3.txz: Rebuilt.
l/libcanberra-0.30-x86_64-6.txz: Rebuilt.
l/libcap-2.25-x86_64-2.txz: Rebuilt.
l/libcap-ng-0.7.8-x86_64-3.txz: Rebuilt.
l/libcddb-1.3.2-x86_64-5.txz: Rebuilt.
l/libcdio-2.0.0-x86_64-2.txz: Rebuilt.
l/libcdio-paranoia-10.2+0.94+2-x86_64-3.txz: Rebuilt.
l/libclc-20180223_3554053-x86_64-2.txz: Rebuilt.
l/libcroco-0.6.12-x86_64-2.txz: Rebuilt.
l/libdbusmenu-qt-0.9.2-x86_64-3.txz: Rebuilt.
l/libdiscid-0.6.2-x86_64-2.txz: Rebuilt.
l/libdvdnav-6.0.0-x86_64-2.txz: Rebuilt.
l/libdvdread-6.0.0-x86_64-3.txz: Rebuilt.
l/libedit-20170329_3.1-x86_64-2.txz: Rebuilt.
l/libevent-2.1.8-x86_64-2.txz: Rebuilt.
l/libexif-0.6.21-x86_64-2.txz: Rebuilt.
l/libfakekey-0.3-x86_64-2.txz: Rebuilt.
l/libffi-3.2.1-x86_64-2.txz: Rebuilt.
l/libglade-2.6.4-x86_64-6.txz: Rebuilt.
l/libgnome-keyring-3.12.0-x86_64-2.txz: Rebuilt.
l/libgphoto2-2.5.17-x86_64-1.txz: Upgraded.
l/libgpod-0.8.3-x86_64-5.txz: Rebuilt.
l/libgsf-1.14.42-x86_64-2.txz: Rebuilt.
l/libical-3.0.1-x86_64-3.txz: Rebuilt.
l/libid3tag-0.15.1b-x86_64-5.txz: Rebuilt.
l/libidl-0.8.14-x86_64-2.txz: Rebuilt.
l/libidn-1.34-x86_64-2.txz: Rebuilt.
l/libidn2-2.0.4-x86_64-2.txz: Rebuilt.
l/libieee1284-0.2.11-x86_64-4.txz: Rebuilt.
l/libimobiledevice-1.2.0-x86_64-3.txz: Rebuilt.
l/libiodbc-3.52.10-x86_64-3.txz: Rebuilt.
l/libjpeg-turbo-1.5.3-x86_64-2.txz: Rebuilt.
l/libkarma-0.1.1-x86_64-3.txz: Rebuilt.
l/liblastfm-1.0.9-x86_64-2.txz: Rebuilt.
l/libmad-0.15.1b-x86_64-4.txz: Rebuilt.
l/libmcrypt-2.5.8-x86_64-2.txz: Rebuilt.
l/libmng-2.0.3-x86_64-2.txz: Rebuilt.
l/libmpc-1.1.0-x86_64-2.txz: Rebuilt.
l/libmsn-4.2.1-x86_64-3.txz: Rebuilt.
l/libmtp-1.1.15-x86_64-2.txz: Rebuilt.
l/libnih-1.0.3-x86_64-3.txz: Rebuilt.
l/libnjb-2.2.7-x86_64-2.txz: Rebuilt.
l/libnl-1.1.4-x86_64-2.txz: Rebuilt.
l/libnl3-3.4.0-x86_64-2.txz: Rebuilt.
l/libnotify-0.7.7-x86_64-2.txz: Rebuilt.
l/libodfgen-0.1.6-x86_64-2.txz: Rebuilt.
l/libogg-1.3.3-x86_64-2.txz: Rebuilt.
l/liboggz-1.1.1-x86_64-3.txz: Rebuilt.
l/liboil-0.3.17-x86_64-2.txz: Rebuilt.
l/libpcap-1.8.1-x86_64-2.txz: Rebuilt.
l/libplist-2.0.0-x86_64-2.txz: Rebuilt.
l/libpng-1.6.34-x86_64-2.txz: Rebuilt.
l/libproxy-0.4.15-x86_64-2.txz: Rebuilt.
l/libraw1394-2.1.2-x86_64-2.txz: Rebuilt.
l/librevenge-0.0.4-x86_64-2.txz: Rebuilt.
l/librsvg-2.42.3-x86_64-3.txz: Rebuilt.
l/libsamplerate-0.1.9-x86_64-2.txz: Rebuilt.
l/libsecret-0.18.6-x86_64-2.txz: Rebuilt.
l/libsigc++-2.10.0-x86_64-2.txz: Rebuilt.
l/libsigsegv-2.12-x86_64-2.txz: Rebuilt.
l/libsndfile-1.0.28-x86_64-2.txz: Rebuilt.
l/libsodium-1.0.16-x86_64-2.txz: Rebuilt.
l/libsoup-2.62.1-x86_64-2.txz: Rebuilt.
l/libspectre-0.2.8-x86_64-2.txz: Rebuilt.
l/libssh-0.7.5-x86_64-2.txz: Rebuilt.
l/libssh2-1.8.0-x86_64-2.txz: Rebuilt.
l/libtasn1-4.13-x86_64-2.txz: Rebuilt.
l/libtheora-1.1.1-x86_64-2.txz: Rebuilt.
l/libtiff-4.0.9-x86_64-2.txz: Rebuilt.
l/libunistring-0.9.9-x86_64-2.txz: Rebuilt.
l/libunwind-1.2.1-x86_64-3.txz: Rebuilt.
l/libusb-1.0.22-x86_64-2.txz: Rebuilt.
l/libusb-compat-0.1.5-x86_64-3.txz: Rebuilt.
l/libusbmuxd-1.0.10-x86_64-2.txz: Rebuilt.
l/libvisio-0.1.6-x86_64-3.txz: Rebuilt.
l/libvisual-0.4.0-x86_64-4.txz: Rebuilt.
l/libvisual-plugins-0.4.0-x86_64-3.txz: Rebuilt.
l/libvncserver-0.9.11-x86_64-3.txz: Rebuilt.
l/libvorbis-1.3.6-x86_64-2.txz: Rebuilt.
l/libvpx-1.7.0-x86_64-2.txz: Rebuilt.
l/libwebp-0.6.1-x86_64-2.txz: Rebuilt.
l/libwmf-0.2.8.4-x86_64-7.txz: Rebuilt.
l/libwmf-docs-0.2.8.4-noarch-7.txz: Rebuilt.
l/libwnck-2.31.0-x86_64-3.txz: Rebuilt.
l/libwpd-0.10.1-x86_64-2.txz: Rebuilt.
l/libwpg-0.3.1-x86_64-2.txz: Rebuilt.
l/libxklavier-5.4-x86_64-2.txz: Rebuilt.
l/libxml2-2.9.8-x86_64-2.txz: Rebuilt.
l/libxslt-1.1.32-x86_64-2.txz: Rebuilt.
l/libyaml-0.1.7-x86_64-2.txz: Rebuilt.
l/libzip-1.5.1-x86_64-2.txz: Rebuilt.
l/loudmouth-1.5.3-x86_64-2.txz: Rebuilt.
l/lzo-2.10-x86_64-2.txz: Rebuilt.
l/media-player-info-23-noarch-2.txz: Rebuilt.
l/mhash-0.9.9.9-x86_64-4.txz: Rebuilt.
l/mm-1.4.2-x86_64-3.txz: Rebuilt.
l/mozilla-nss-3.36.1-x86_64-2.txz: Rebuilt.
l/mpfr-4.0.1-x86_64-2.txz: Rebuilt.
l/ncurses-6.1_20180324-x86_64-4.txz: Rebuilt.
       Change the xterm entry in xterm.terminfo (way down at the bottom, where it
       says "customization begins here" and that we may need to change the xterm
       entry since it is used "for a variety of incompatible terminal emulations")
       to drop the use of use=rep+ansi. In addition to causing Konsole breakage, I
       have verification that rep= was causing problems with terminals connecting
       from OSX. Only the xterm entry has changed. Previously this was an alias for
       xterm-new, which has not been altered. Feel free to use xterm-new instead if
       it suits your needs better.
l/neon-0.30.1-x86_64-3.txz: Rebuilt.
l/netpbm-10.66.02-x86_64-5.txz: Rebuilt.
l/newt-0.52.20-x86_64-3.txz: Rebuilt.
l/ocl-icd-2.2.12-x86_64-2.txz: Rebuilt.
l/openexr-2.2.0-x86_64-3.txz: Rebuilt.
l/openjpeg-2.3.0-x86_64-2.txz: Rebuilt.
l/opus-1.3_beta-x86_64-2.txz: Rebuilt.
l/opusfile-0.9-x86_64-3.txz: Rebuilt.
l/orc-0.4.28-x86_64-2.txz: Rebuilt.
l/pango-1.42.1-x86_64-2.txz: Rebuilt.
l/pangomm-2.40.1-x86_64-2.txz: Rebuilt.
l/parted-3.2-x86_64-4.txz: Rebuilt.
l/pcre-8.42-x86_64-2.txz: Rebuilt.
l/pcre2-10.31-x86_64-2.txz: Rebuilt.
l/phonon-4.8.3-x86_64-3.txz: Rebuilt.
l/phonon-gstreamer-4.8.2-x86_64-2.txz: Rebuilt.
l/pilot-link-0.12.5-x86_64-13.txz: Rebuilt.
l/polkit-0.113-x86_64-4.txz: Rebuilt.
l/polkit-gnome-0.105-x86_64-2.txz: Rebuilt.
l/polkit-qt-1-0.112.0-x86_64-2.txz: Rebuilt.
l/poppler-0.64.0-x86_64-1.txz: Upgraded.
l/poppler-data-0.4.8-noarch-2.txz: Rebuilt.
l/popt-1.16-x86_64-3.txz: Rebuilt.
l/pulseaudio-11.1-x86_64-2.txz: Rebuilt.
l/pycairo-1.16.3-x86_64-2.txz: Rebuilt.
l/pycups-1.9.73-x86_64-4.txz: Rebuilt.
l/pycurl-7.43.0.1-x86_64-2.txz: Rebuilt.
l/pygobject-2.28.7-x86_64-2.txz: Rebuilt.
l/pygobject3-3.28.2-x86_64-2.txz: Rebuilt.
l/pygtk-2.24.0-x86_64-5.txz: Rebuilt.
l/pyparsing-2.2.0-x86_64-2.txz: Rebuilt.
l/python-appdirs-1.4.3-x86_64-2.txz: Rebuilt.
l/python-certifi-2018.1.18-x86_64-2.txz: Rebuilt.
l/python-chardet-3.0.4-x86_64-2.txz: Rebuilt.
l/python-docutils-0.14-x86_64-2.txz: Rebuilt.
l/python-idna-2.6-x86_64-2.txz: Rebuilt.
l/python-notify2-0.3.1-x86_64-2.txz: Rebuilt.
l/python-packaging-16.8-x86_64-2.txz: Rebuilt.
l/python-pillow-5.1.0-x86_64-2.txz: Rebuilt.
l/python-requests-2.18.4-x86_64-2.txz: Rebuilt.
l/python-sane-2.8.3-x86_64-2.txz: Rebuilt.
l/python-six-1.11.0-x86_64-2.txz: Rebuilt.
l/python-urllib3-1.22-x86_64-2.txz: Rebuilt.
l/qca-2.1.3-x86_64-2.txz: Rebuilt.
l/qimageblitz-0.0.6-x86_64-2.txz: Rebuilt.
l/qjson-0.8.1-x86_64-2.txz: Rebuilt.
l/qt-4.8.7-x86_64-9.txz: Rebuilt.
l/qt-gstreamer-1.2.0-x86_64-2.txz: Rebuilt.
l/qtscriptgenerator-0.2.0-x86_64-3.txz: Rebuilt.
l/raptor2-2.0.15-x86_64-5.txz: Rebuilt.
l/rasqal-0.9.33-x86_64-3.txz: Rebuilt.
l/readline-7.0.003-x86_64-2.txz: Rebuilt.
l/redland-1.0.17-x86_64-4.txz: Rebuilt.
l/sbc-1.3-x86_64-2.txz: Rebuilt.
l/sdl-1.2.15-x86_64-7.txz: Rebuilt.
l/seamonkey-solibs-2.49.2-x86_64-2.txz: Rebuilt.
l/serf-1.3.9-x86_64-2.txz: Rebuilt.
l/sg3_utils-1.42-x86_64-2.txz: Rebuilt.
l/shared-desktop-ontologies-0.11.0-x86_64-2.txz: Rebuilt.
l/shared-mime-info-1.9-x86_64-2.txz: Rebuilt.
l/sip-4.19.8-x86_64-2.txz: Rebuilt.
l/slang-2.3.2-x86_64-3.txz: Rebuilt.
l/slang1-1.4.9-x86_64-2.txz: Rebuilt.
l/soprano-2.9.4-x86_64-2.txz: Rebuilt.
l/sound-theme-freedesktop-0.8-noarch-2.txz: Rebuilt.
l/speex-1.2.0-x86_64-2.txz: Rebuilt.
l/speexdsp-1.2rc3-x86_64-2.txz: Rebuilt.
l/startup-notification-0.12-x86_64-3.txz: Rebuilt.
l/strigi-0.7.8-x86_64-4.txz: Rebuilt.
l/svgalib-1.9.25-x86_64-4.txz: Rebuilt.
l/system-config-printer-1.5.11-x86_64-3.txz: Rebuilt.
l/t1lib-5.1.2-x86_64-4.txz: Rebuilt.
l/taglib-1.11.1-x86_64-3.txz: Rebuilt.
l/taglib-extras-1.0.1-x86_64-2.txz: Rebuilt.
l/talloc-2.1.13-x86_64-1.txz: Upgraded.
l/tango-icon-theme-0.8.90-noarch-2.txz: Rebuilt.
l/tango-icon-theme-extras-0.1.0-noarch-2.txz: Rebuilt.
l/tdb-1.3.15-x86_64-2.txz: Rebuilt.
l/tevent-0.9.36-x86_64-2.txz: Rebuilt.
l/urwid-1.0.3-x86_64-3.txz: Rebuilt.
l/utf8proc-2.1.0-x86_64-1.txz: Added.
       This library is required by subversion-1.10.0.
l/v4l-utils-1.14.2-x86_64-2.txz: Rebuilt.
l/virtuoso-ose-6.1.8-x86_64-8.txz: Rebuilt.
l/vte-0.52.1-x86_64-2.txz: Rebuilt.
l/wavpack-5.1.0-x86_64-2.txz: Rebuilt.
l/xapian-core-1.4.5-x86_64-2.txz: Rebuilt.
l/zlib-1.2.11-x86_64-2.txz: Rebuilt.
n/ModemManager-1.6.12-x86_64-2.txz: Rebuilt.
n/NetworkManager-1.10.6-x86_64-3.txz: Rebuilt.
n/alpine-2.21-x86_64-2.txz: Rebuilt.
n/autofs-5.1.4-x86_64-2.txz: Rebuilt.
n/biff+comsat-0.17-x86_64-2.txz: Rebuilt.
n/bind-9.11.3-x86_64-2.txz: Rebuilt.
n/bluez-5.49-x86_64-3.txz: Rebuilt.
n/bluez-firmware-1.2-x86_64-2.txz: Rebuilt.
n/bootp-2.4.3-x86_64-3.txz: Rebuilt.
n/bridge-utils-1.5-x86_64-2.txz: Rebuilt.
n/bsd-finger-0.17-x86_64-3.txz: Rebuilt.
n/ca-certificates-20170717-noarch-2.txz: Rebuilt.
n/cifs-utils-6.7-x86_64-2.txz: Rebuilt.
n/conntrack-tools-1.4.4-x86_64-2.txz: Rebuilt.
n/crda-3.18-x86_64-6.txz: Rebuilt.
n/curl-7.59.0-x86_64-3.txz: Rebuilt.
n/cyrus-sasl-2.1.26-x86_64-4.txz: Rebuilt.
n/dhcp-4.4.1-x86_64-2.txz: Rebuilt.
n/dhcpcd-7.0.3-x86_64-2.txz: Rebuilt.
n/dnsmasq-2.79-x86_64-2.txz: Rebuilt.
n/dovecot-2.3.1-x86_64-3.txz: Rebuilt.
       Recompiled using --with-lucene. Thanks to kj25vm.
n/ebtables-2.0.10-x86_64-2.txz: Rebuilt.
n/elm-2.5.8-x86_64-5.txz: Rebuilt.
n/epic5-2.0.1-x86_64-4.txz: Rebuilt.
n/ethtool-4.16-x86_64-1.txz: Upgraded.
n/fetchmail-6.3.26-x86_64-3.txz: Rebuilt.
n/getmail-5.6-x86_64-2.txz: Rebuilt.
n/gnupg-1.4.22-x86_64-2.txz: Rebuilt.
n/gnupg2-2.2.6-x86_64-2.txz: Rebuilt.
n/gnutls-3.6.2-x86_64-2.txz: Rebuilt.
n/gpa-0.9.10-x86_64-2.txz: Rebuilt.
n/gpgme-1.10.0-x86_64-2.txz: Rebuilt.
n/htdig-3.2.0b6-x86_64-5.txz: Rebuilt.
n/httpd-2.4.33-x86_64-3.txz: Rebuilt.
n/icmpinfo-1.11-x86_64-3.txz: Rebuilt.
n/iftop-1.0pre4-x86_64-2.txz: Rebuilt.
n/inetd-1.79s-x86_64-11.txz: Rebuilt.
n/iproute2-4.16.0-x86_64-2.txz: Rebuilt.
n/ipset-6.38-x86_64-1.txz: Upgraded.
n/iptables-1.6.2-x86_64-2.txz: Rebuilt.
n/iptraf-ng-1.1.4-x86_64-3.txz: Rebuilt.
n/iputils-s20140519-x86_64-2.txz: Rebuilt.
n/irssi-1.1.1-x86_64-2.txz: Rebuilt.
n/iw-4.14-x86_64-2.txz: Rebuilt.
n/lftp-4.8.3-x86_64-2.txz: Rebuilt.
n/libassuan-2.5.1-x86_64-2.txz: Rebuilt.
n/libgcrypt-1.8.2-x86_64-2.txz: Rebuilt.
n/libgpg-error-1.29-x86_64-2.txz: Rebuilt.
n/libksba-1.3.5-x86_64-2.txz: Rebuilt.
n/libmbim-1.16.0-x86_64-2.txz: Rebuilt.
n/libmilter-8.15.2-x86_64-2.txz: Rebuilt.
n/libmnl-1.0.4-x86_64-3.txz: Rebuilt.
n/libndp-1.6-x86_64-2.txz: Rebuilt.
n/libnetfilter_acct-1.0.3-x86_64-2.txz: Rebuilt.
n/libnetfilter_conntrack-1.0.6-x86_64-2.txz: Rebuilt.
n/libnetfilter_cthelper-1.0.0-x86_64-2.txz: Rebuilt.
n/libnetfilter_cttimeout-1.0.0-x86_64-2.txz: Rebuilt.
n/libnetfilter_log-1.0.1-x86_64-2.txz: Rebuilt.
n/libnetfilter_queue-1.0.3-x86_64-2.txz: Rebuilt.
n/libnfnetlink-1.0.1-x86_64-2.txz: Rebuilt.
n/libnftnl-1.0.9-x86_64-2.txz: Rebuilt.
n/libqmi-1.20.0-x86_64-2.txz: Rebuilt.
n/libtirpc-1.0.3-x86_64-2.txz: Rebuilt.
n/links-2.14-x86_64-3.txz: Rebuilt.
n/lynx-2.8.9dev.16-x86_64-1.txz: Upgraded.
n/mailx-12.5-x86_64-3.txz: Rebuilt.
n/mcabber-1.0.5-x86_64-2.txz: Rebuilt.
n/metamail-2.7-x86_64-7.txz: Rebuilt.
n/mobile-broadband-provider-info-20170310-x86_64-2.txz: Rebuilt.
n/mtr-0.92-x86_64-2.txz: Rebuilt.
n/mutt-1.9.5-x86_64-1.txz: Upgraded.
n/nc-1.10-x86_64-2.txz: Rebuilt.
n/ncftp-3.2.6-x86_64-2.txz: Rebuilt.
n/net-snmp-5.7.3-x86_64-7.txz: Rebuilt.
n/net-tools-20170208_479bb4a-x86_64-2.txz: Rebuilt.
n/netatalk-2.2.3-x86_64-7.txz: Rebuilt.
n/netdate-bsd4-x86_64-2.txz: Rebuilt.
n/netkit-bootparamd-0.17-x86_64-3.txz: Rebuilt.
n/netkit-ftp-0.17-x86_64-4.txz: Rebuilt.
n/netkit-ntalk-0.17-x86_64-5.txz: Rebuilt.
n/netkit-routed-0.17-x86_64-2.txz: Rebuilt.
n/netkit-rsh-0.17-x86_64-2.txz: Rebuilt.
n/netkit-rusers-0.17-x86_64-2.txz: Rebuilt.
n/netkit-rwall-0.17-x86_64-2.txz: Rebuilt.
n/netkit-rwho-0.17-x86_64-3.txz: Rebuilt.
n/netkit-timed-0.17-x86_64-2.txz: Rebuilt.
n/netpipes-4.2-x86_64-2.txz: Rebuilt.
n/nettle-3.4-x86_64-2.txz: Rebuilt.
n/netwatch-1.3.1_2-x86_64-3.txz: Rebuilt.
n/network-scripts-15.0-noarch-7.txz: Rebuilt.
n/netwrite-0.17-x86_64-2.txz: Rebuilt.
n/newspost-2.1.1-x86_64-2.txz: Rebuilt.
n/nfacct-1.0.2-x86_64-2.txz: Rebuilt.
n/nfs-utils-2.3.1-x86_64-2.txz: Rebuilt.
n/nftables-0.8.2-x86_64-2.txz: Rebuilt.
n/nghttp2-1.31.1-x86_64-1.txz: Upgraded.
       Denial of service due to NULL pointer dereference.
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1000168
n/nmap-7.70-x86_64-2.txz: Rebuilt.
n/nn-6.7.3-x86_64-5.txz: Rebuilt.
n/npth-1.5-x86_64-2.txz: Rebuilt.
n/ntp-4.2.8p11-x86_64-2.txz: Rebuilt.
n/obexftp-0.24.2-x86_64-3.txz: Rebuilt.
n/openldap-client-2.4.46-x86_64-2.txz: Rebuilt.
n/openobex-1.7.2-x86_64-2.txz: Rebuilt.
n/openssh-7.7p1-x86_64-3.txz: Rebuilt.
n/openssl-1.0.2o-x86_64-2.txz: Rebuilt.
n/openvpn-2.4.5-x86_64-2.txz: Rebuilt.
n/p11-kit-0.23.10-x86_64-2.txz: Rebuilt.
n/php-7.2.4-x86_64-2.txz: Rebuilt.
n/pidentd-3.0.19-x86_64-3.txz: Rebuilt.
n/pinentry-1.1.0-x86_64-2.txz: Rebuilt.
n/popa3d-1.0.3-x86_64-2.txz: Rebuilt.
n/postfix-3.3.0-x86_64-3.txz: Rebuilt.
n/ppp-2.4.7-x86_64-2.txz: Rebuilt.
n/procmail-3.22-x86_64-3.txz: Rebuilt.
n/proftpd-1.3.6-x86_64-3.txz: Rebuilt.
n/pssh-2.3.1-x86_64-3.txz: Rebuilt.
n/rdist-6.1.5-x86_64-3.txz: Rebuilt.
n/rp-pppoe-3.12-x86_64-2.txz: Rebuilt.
n/rpcbind-0.2.4-x86_64-4.txz: Rebuilt.
n/rsync-3.1.3-x86_64-2.txz: Rebuilt.
n/samba-4.7.7-x86_64-1.txz: Upgraded.
n/slrn-1.0.2-x86_64-2.txz: Rebuilt.
n/snownews-1.5.12-x86_64-4.txz: Rebuilt.
n/sshfs-2.10-x86_64-2.txz: Rebuilt.
n/stunnel-5.44-x86_64-2.txz: Rebuilt.
n/tcp_wrappers-7.6-x86_64-2.txz: Rebuilt.
n/tcpdump-4.9.2-x86_64-2.txz: Rebuilt.
n/telnet-0.17-x86_64-4.txz: Rebuilt.
n/tftp-hpa-5.2-x86_64-4.txz: Rebuilt.
n/tin-2.4.2-x86_64-3.txz: Rebuilt.
n/traceroute-2.1.0-x86_64-2.txz: Rebuilt.
n/ulogd-2.0.5-x86_64-3.txz: Rebuilt.
n/uucp-1.07-x86_64-2.txz: Rebuilt.
n/vlan-1.9-x86_64-3.txz: Rebuilt.
n/vsftpd-3.0.3-x86_64-4.txz: Rebuilt.
n/wget-1.19.4-x86_64-3.txz: Rebuilt.
n/whois-5.3.0-x86_64-2.txz: Rebuilt.
n/wireless_tools-29-x86_64-12.txz: Rebuilt.
n/wpa_supplicant-2.6-x86_64-4.txz: Rebuilt.
n/yptools-2.14-x86_64-10.txz: Rebuilt.
n/ytalk-3.3.0-x86_64-4.txz: Rebuilt.
n/zd1211-firmware-1.5-fw-2.txz: Rebuilt.
t/fig2dev-3.2.7-x86_64-1.txz: Upgraded.
t/texlive-2017.171108-x86_64-5.txz: Rebuilt.
t/xfig-3.2.7-x86_64-1.txz: Upgraded.
tcl/expect-5.45.4-x86_64-2.txz: Rebuilt.
tcl/hfsutils-3.2.6-x86_64-6.txz: Rebuilt.
tcl/tcl-8.6.8-x86_64-3.txz: Rebuilt.
tcl/tclx-8.4.1-x86_64-4.txz: Rebuilt.
tcl/tix-8.4.3-x86_64-4.txz: Rebuilt.
tcl/tk-8.6.8-x86_64-2.txz: Rebuilt.
x/anthy-9100h-x86_64-2.txz: Rebuilt.
x/appres-1.0.5-x86_64-2.txz: Rebuilt.
x/bdftopcf-1.1-x86_64-2.txz: Rebuilt.
x/beforelight-1.0.5-x86_64-3.txz: Rebuilt.
x/bitmap-1.0.8-x86_64-3.txz: Rebuilt.
x/compiz-0.8.8-x86_64-5.txz: Rebuilt.
x/dejavu-fonts-ttf-2.37-noarch-3.txz: Rebuilt.
x/editres-1.0.7-x86_64-2.txz: Rebuilt.
x/encodings-1.0.4-noarch-2.txz: Rebuilt.
x/font-adobe-100dpi-1.0.3-noarch-2.txz: Rebuilt.
x/font-adobe-75dpi-1.0.3-noarch-2.txz: Rebuilt.
x/font-adobe-utopia-100dpi-1.0.4-noarch-2.txz: Rebuilt.
x/font-adobe-utopia-75dpi-1.0.4-noarch-2.txz: Rebuilt.
x/font-adobe-utopia-type1-1.0.4-noarch-2.txz: Rebuilt.
x/font-alias-1.0.3-noarch-2.txz: Rebuilt.
x/font-arabic-misc-1.0.3-noarch-2.txz: Rebuilt.
x/font-bh-100dpi-1.0.3-noarch-2.txz: Rebuilt.
x/font-bh-75dpi-1.0.3-noarch-2.txz: Rebuilt.
x/font-bh-lucidatypewriter-100dpi-1.0.3-noarch-2.txz: Rebuilt.
x/font-bh-lucidatypewriter-75dpi-1.0.3-noarch-2.txz: Rebuilt.
x/font-bh-ttf-1.0.3-noarch-2.txz: Rebuilt.
x/font-bh-type1-1.0.3-noarch-2.txz: Rebuilt.
x/font-bitstream-100dpi-1.0.3-noarch-2.txz: Rebuilt.
x/font-bitstream-75dpi-1.0.3-noarch-2.txz: Rebuilt.
x/font-bitstream-speedo-1.0.2-noarch-2.txz: Rebuilt.
x/font-bitstream-type1-1.0.3-noarch-2.txz: Rebuilt.
x/font-cronyx-cyrillic-1.0.3-noarch-2.txz: Rebuilt.
x/font-cursor-misc-1.0.3-noarch-2.txz: Rebuilt.
x/font-daewoo-misc-1.0.3-noarch-2.txz: Rebuilt.
x/font-dec-misc-1.0.3-noarch-2.txz: Rebuilt.
x/font-ibm-type1-1.0.3-noarch-2.txz: Rebuilt.
x/font-isas-misc-1.0.3-noarch-2.txz: Rebuilt.
x/font-jis-misc-1.0.3-noarch-2.txz: Rebuilt.
x/font-micro-misc-1.0.3-noarch-2.txz: Rebuilt.
x/font-misc-cyrillic-1.0.3-noarch-2.txz: Rebuilt.
x/font-misc-ethiopic-1.0.3-noarch-2.txz: Rebuilt.
x/font-misc-meltho-1.0.3-noarch-2.txz: Rebuilt.
x/font-misc-misc-1.1.2-noarch-2.txz: Rebuilt.
x/font-mutt-misc-1.0.3-noarch-2.txz: Rebuilt.
x/font-schumacher-misc-1.1.2-noarch-2.txz: Rebuilt.
x/font-screen-cyrillic-1.0.4-noarch-2.txz: Rebuilt.
x/font-sony-misc-1.0.3-noarch-2.txz: Rebuilt.
x/font-sun-misc-1.0.3-noarch-2.txz: Rebuilt.
x/font-util-1.3.1-x86_64-3.txz: Rebuilt.
x/font-winitzki-cyrillic-1.0.3-noarch-2.txz: Rebuilt.
x/font-xfree86-type1-1.0.4-noarch-2.txz: Rebuilt.
x/fontconfig-2.12.6-x86_64-2.txz: Rebuilt.
x/fonttosfnt-1.0.4-x86_64-3.txz: Rebuilt.
x/freeglut-3.0.0-x86_64-2.txz: Rebuilt.
x/fslsfonts-1.0.5-x86_64-3.txz: Rebuilt.
x/fstobdf-1.0.6-x86_64-3.txz: Rebuilt.
x/gccmakedep-1.0.3-noarch-2.txz: Rebuilt.
x/glew-2.1.0-x86_64-2.txz: Rebuilt.
x/glu-9.0.0-x86_64-2.txz: Rebuilt.
x/iceauth-1.0.8-x86_64-2.txz: Rebuilt.
x/ico-1.0.5-x86_64-2.txz: Rebuilt.
x/imake-1.0.7-x86_64-3.txz: Rebuilt.
x/intel-gpu-tools-1.22-x86_64-2.txz: Rebuilt.
x/intel-vaapi-driver-2.1.0-x86_64-2.txz: Rebuilt.
x/libFS-1.0.7-x86_64-2.txz: Rebuilt.
x/libICE-1.0.9-x86_64-3.txz: Rebuilt.
x/libSM-1.2.2-x86_64-3.txz: Rebuilt.
x/libX11-1.6.5-x86_64-2.txz: Rebuilt.
x/libXScrnSaver-1.2.2-x86_64-3.txz: Rebuilt.
x/libXau-1.0.8-x86_64-3.txz: Rebuilt.
x/libXaw-1.0.13-x86_64-2.txz: Rebuilt.
x/libXaw3d-1.6.2-x86_64-4.txz: Rebuilt.
x/libXaw3dXft-1.6.2d-x86_64-3.txz: Rebuilt.
x/libXcm-0.5.2-x86_64-3.txz: Rebuilt.
x/libXcomposite-0.4.4-x86_64-3.txz: Rebuilt.
x/libXcursor-1.1.15-x86_64-2.txz: Rebuilt.
x/libXdamage-1.1.4-x86_64-3.txz: Rebuilt.
x/libXdmcp-1.1.2-x86_64-3.txz: Rebuilt.
x/libXevie-1.0.3-x86_64-3.txz: Rebuilt.
x/libXext-1.3.3-x86_64-3.txz: Rebuilt.
x/libXfixes-5.0.3-x86_64-2.txz: Rebuilt.
x/libXfont2-2.0.3-x86_64-2.txz: Rebuilt.
x/libXfontcache-1.0.5-x86_64-3.txz: Rebuilt.
x/libXft-2.3.2-x86_64-4.txz: Rebuilt.
x/libXi-1.7.9-x86_64-2.txz: Rebuilt.
x/libXinerama-1.1.3-x86_64-3.txz: Rebuilt.
x/libXmu-1.1.2-x86_64-3.txz: Rebuilt.
x/libXp-1.0.3-x86_64-3.txz: Rebuilt.
x/libXpm-3.5.12-x86_64-2.txz: Rebuilt.
x/libXpresent-1.0.0-x86_64-2.txz: Rebuilt.
x/libXrandr-1.5.1-x86_64-2.txz: Rebuilt.
x/libXrender-0.9.10-x86_64-2.txz: Rebuilt.
x/libXres-1.2.0-x86_64-2.txz: Rebuilt.
x/libXt-1.1.5-x86_64-2.txz: Rebuilt.
x/libXtst-1.2.3-x86_64-2.txz: Rebuilt.
x/libXv-1.0.11-x86_64-2.txz: Rebuilt.
x/libXvMC-1.0.10-x86_64-2.txz: Rebuilt.
x/libXxf86dga-1.1.4-x86_64-3.txz: Rebuilt.
x/libXxf86misc-1.0.3-x86_64-3.txz: Rebuilt.
x/libXxf86vm-1.1.4-x86_64-3.txz: Rebuilt.
x/libdmx-1.1.3-x86_64-3.txz: Rebuilt.
x/libdrm-2.4.91-x86_64-2.txz: Rebuilt.
x/libepoxy-1.4.3-x86_64-2.txz: Rebuilt.
x/liberation-fonts-ttf-2.00.1-noarch-2.txz: Rebuilt.
x/libevdev-1.5.9-x86_64-2.txz: Rebuilt.
x/libfontenc-1.1.3-x86_64-2.txz: Rebuilt.
x/libhangul-0.1.0-x86_64-2.txz: Rebuilt.
x/libinput-1.10.4-x86_64-2.txz: Rebuilt.
x/libpciaccess-0.14-x86_64-2.txz: Rebuilt.
x/libpthread-stubs-0.4-noarch-2.txz: Rebuilt.
x/libva-2.1.0-x86_64-2.txz: Rebuilt.
x/libva-utils-2.1.0-x86_64-2.txz: Rebuilt.
x/libvdpau-1.1.1-x86_64-2.txz: Rebuilt.
x/libwacom-0.29-x86_64-2.txz: Rebuilt.
x/libxcb-1.13-x86_64-2.txz: Rebuilt.
x/libxkbfile-1.0.9-x86_64-2.txz: Rebuilt.
x/libxshmfence-1.3-x86_64-2.txz: Rebuilt.
x/listres-1.0.4-x86_64-2.txz: Rebuilt.
x/lndir-1.0.3-x86_64-3.txz: Rebuilt.
x/luit-1.1.1-x86_64-3.txz: Rebuilt.
x/m17n-lib-1.8.0-x86_64-2.txz: Rebuilt.
x/makedepend-1.0.5-x86_64-3.txz: Rebuilt.
x/mesa-18.0.1-x86_64-1.txz: Upgraded.
x/mkcomposecache-1.2.1-x86_64-3.txz: Rebuilt.
x/mkfontdir-1.0.7-noarch-2.txz: Rebuilt.
x/mkfontscale-1.1.3-x86_64-2.txz: Rebuilt.
x/motif-2.3.8-x86_64-2.txz: Rebuilt.
x/mtdev-1.1.5-x86_64-2.txz: Rebuilt.
x/oclock-1.0.4-x86_64-2.txz: Rebuilt.
x/pixman-0.34.0-x86_64-2.txz: Rebuilt.
x/rendercheck-1.5-x86_64-2.txz: Rebuilt.
x/rgb-1.0.6-x86_64-3.txz: Rebuilt.
x/sazanami-fonts-ttf-20040629-noarch-2.txz: Rebuilt.
x/scim-1.4.17-x86_64-2.txz: Rebuilt.
x/scim-anthy-1.2.7-x86_64-2.txz: Rebuilt.
x/scim-hangul-0.4.0-x86_64-2.txz: Rebuilt.
x/scim-input-pad-0.1.3.1-x86_64-2.txz: Rebuilt.
x/scim-m17n-0.2.3-x86_64-2.txz: Rebuilt.
x/scim-pinyin-0.5.92-x86_64-2.txz: Rebuilt.
x/scim-tables-0.5.14.1-x86_64-2.txz: Rebuilt.
x/sessreg-1.1.1-x86_64-2.txz: Rebuilt.
x/setxkbmap-1.3.1-x86_64-2.txz: Rebuilt.
x/showfont-1.0.5-x86_64-3.txz: Rebuilt.
x/sinhala_lklug-font-ttf-20060929-noarch-2.txz: Rebuilt.
x/smproxy-1.0.6-x86_64-2.txz: Rebuilt.
x/tibmachuni-font-ttf-1.901b-noarch-2.txz: Rebuilt.
x/transset-1.0.2-x86_64-2.txz: Rebuilt.
x/ttf-indic-fonts-0.5.14-noarch-2.txz: Rebuilt.
x/ttf-tlwg-0.6.4-noarch-2.txz: Rebuilt.
x/twm-1.0.10-x86_64-2.txz: Rebuilt.
x/urw-core35-fonts-otf-20160712_79bcdfb_git-noarch-2.txz: Rebuilt.
x/util-macros-1.19.2-noarch-2.txz: Rebuilt.
x/viewres-1.0.5-x86_64-2.txz: Rebuilt.
x/vulkan-sdk-1.1.70.0-x86_64-2.txz: Rebuilt.
x/wqy-zenhei-font-ttf-0.8.38_1-noarch-5.txz: Rebuilt.
x/x11-skel-7.7-x86_64-2.txz: Rebuilt.
x/x11perf-1.6.0-x86_64-2.txz: Rebuilt.
x/xauth-1.0.10-x86_64-2.txz: Rebuilt.
x/xbacklight-1.2.2-x86_64-2.txz: Rebuilt.
x/xbiff-1.0.3-x86_64-3.txz: Rebuilt.
x/xbitmaps-1.1.2-x86_64-2.txz: Rebuilt.
x/xcalc-1.0.6-x86_64-3.txz: Rebuilt.
x/xcb-proto-1.13-x86_64-2.txz: Rebuilt.
x/xcb-util-0.4.0-x86_64-3.txz: Rebuilt.
x/xcb-util-cursor-0.1.3-x86_64-2.txz: Rebuilt.
x/xcb-util-errors-1.0-x86_64-2.txz: Rebuilt.
x/xcb-util-image-0.4.0-x86_64-3.txz: Rebuilt.
x/xcb-util-keysyms-0.4.0-x86_64-3.txz: Rebuilt.
x/xcb-util-renderutil-0.3.9-x86_64-3.txz: Rebuilt.
x/xcb-util-wm-0.4.1-x86_64-3.txz: Rebuilt.
x/xclipboard-1.1.3-x86_64-3.txz: Rebuilt.
x/xclock-1.0.7-x86_64-3.txz: Rebuilt.
x/xcm-0.5.2-x86_64-3.txz: Rebuilt.
x/xcmsdb-1.0.5-x86_64-2.txz: Rebuilt.
x/xcompmgr-1.1.7-x86_64-2.txz: Rebuilt.
x/xconsole-1.0.7-x86_64-2.txz: Rebuilt.
x/xcursor-themes-1.0.5-noarch-2.txz: Rebuilt.
x/xcursorgen-1.0.6-x86_64-4.txz: Rebuilt.
x/xdbedizzy-1.1.0-x86_64-3.txz: Rebuilt.
x/xdg-user-dirs-0.15-x86_64-2.txz: Rebuilt.
x/xdg-utils-1.1.2-noarch-2.txz: Rebuilt.
x/xditview-1.0.4-x86_64-2.txz: Rebuilt.
x/xdm-1.1.11-x86_64-8.txz: Rebuilt.
x/xdpyinfo-1.3.2-x86_64-2.txz: Rebuilt.
x/xdriinfo-1.0.6-x86_64-2.txz: Rebuilt.
x/xedit-1.2.2-x86_64-3.txz: Rebuilt.
x/xev-1.2.2-x86_64-2.txz: Rebuilt.
x/xeyes-1.1.2-x86_64-2.txz: Rebuilt.
x/xf86-input-acecad-1.5.0-x86_64-11.txz: Rebuilt.
x/xf86-input-evdev-2.10.5-x86_64-2.txz: Rebuilt.
x/xf86-input-joystick-1.6.3-x86_64-2.txz: Rebuilt.
x/xf86-input-keyboard-1.9.0-x86_64-2.txz: Rebuilt.
x/xf86-input-libinput-0.27.1-x86_64-2.txz: Rebuilt.
x/xf86-input-mouse-1.9.2-x86_64-2.txz: Rebuilt.
x/xf86-input-penmount-1.5.0-x86_64-11.txz: Rebuilt.
x/xf86-input-synaptics-1.9.0-x86_64-2.txz: Rebuilt.
x/xf86-input-vmmouse-13.1.0-x86_64-6.txz: Rebuilt.
x/xf86-input-void-1.4.0-x86_64-11.txz: Rebuilt.
x/xf86-input-wacom-0.36.1-x86_64-2.txz: Rebuilt.
x/xf86-video-amdgpu-18.0.1-x86_64-2.txz: Rebuilt.
x/xf86-video-apm-1.2.5-x86_64-10.txz: Rebuilt.
x/xf86-video-ark-0.7.5-x86_64-10.txz: Rebuilt.
x/xf86-video-ast-1.1.5-x86_64-4.txz: Rebuilt.
x/xf86-video-ati-18.0.1-x86_64-2.txz: Rebuilt.
x/xf86-video-chips-1.2.7-x86_64-2.txz: Rebuilt.
x/xf86-video-cirrus-1.5.3-x86_64-4.txz: Rebuilt.
x/xf86-video-dummy-0.3.8-x86_64-2.txz: Rebuilt.
x/xf86-video-glint-1.2.9-x86_64-2.txz: Rebuilt.
x/xf86-video-i128-1.3.6-x86_64-10.txz: Rebuilt.
x/xf86-video-i740-1.3.6-x86_64-2.txz: Rebuilt.
x/xf86-video-intel-git_20180206_aa36399c-x86_64-2.txz: Rebuilt.
x/xf86-video-mach64-6.9.5-x86_64-4.txz: Rebuilt.
x/xf86-video-mga-1.6.5-x86_64-2.txz: Rebuilt.
x/xf86-video-neomagic-1.2.9-x86_64-4.txz: Rebuilt.
x/xf86-video-nouveau-1.0.15-x86_64-2.txz: Rebuilt.
x/xf86-video-nv-2.1.21-x86_64-2.txz: Rebuilt.
x/xf86-video-openchrome-0.6.0-x86_64-2.txz: Rebuilt.
x/xf86-video-r128-6.10.2-x86_64-2.txz: Rebuilt.
x/xf86-video-rendition-4.2.6-x86_64-3.txz: Rebuilt.
x/xf86-video-s3-0.6.5-x86_64-10.txz: Rebuilt.
x/xf86-video-s3virge-1.10.7-x86_64-4.txz: Rebuilt.
x/xf86-video-savage-2.3.9-x86_64-2.txz: Rebuilt.
x/xf86-video-siliconmotion-1.7.9-x86_64-2.txz: Rebuilt.
x/xf86-video-sis-0.10.9-x86_64-2.txz: Rebuilt.
x/xf86-video-sisusb-0.9.7-x86_64-2.txz: Rebuilt.
x/xf86-video-tdfx-1.4.7-x86_64-2.txz: Rebuilt.
x/xf86-video-tga-1.2.2-x86_64-10.txz: Rebuilt.
x/xf86-video-trident-1.3.8-x86_64-2.txz: Rebuilt.
x/xf86-video-tseng-1.2.5-x86_64-10.txz: Rebuilt.
x/xf86-video-v4l-0.2.0-x86_64-15.txz: Rebuilt.
x/xf86-video-vboxvideo-1.0.0-x86_64-2.txz: Rebuilt.
x/xf86-video-vesa-2.4.0-x86_64-2.txz: Rebuilt.
x/xf86-video-vmware-13.2.1-x86_64-6.txz: Rebuilt.
x/xf86-video-voodoo-1.2.5-x86_64-11.txz: Rebuilt.
x/xf86dga-1.0.3-x86_64-3.txz: Rebuilt.
x/xfd-1.1.2-x86_64-3.txz: Rebuilt.
x/xfontsel-1.0.6-x86_64-2.txz: Rebuilt.
x/xfs-1.2.0-x86_64-2.txz: Rebuilt.
x/xfsinfo-1.0.5-x86_64-3.txz: Rebuilt.
x/xgamma-1.0.6-x86_64-2.txz: Rebuilt.
x/xgc-1.0.5-x86_64-2.txz: Rebuilt.
x/xhost-1.0.7-x86_64-2.txz: Rebuilt.
x/xinit-1.4.0-x86_64-2.txz: Rebuilt.
x/xinput-1.6.2-x86_64-2.txz: Rebuilt.
x/xkbcomp-1.4.1-x86_64-2.txz: Rebuilt.
x/xkbevd-1.1.4-x86_64-2.txz: Rebuilt.
x/xkbprint-1.0.4-x86_64-2.txz: Rebuilt.
x/xkbutils-1.0.4-x86_64-3.txz: Rebuilt.
x/xkeyboard-config-2.22-noarch-2.txz: Rebuilt.
x/xkill-1.0.5-x86_64-2.txz: Rebuilt.
x/xload-1.1.3-x86_64-2.txz: Rebuilt.
x/xlogo-1.0.4-x86_64-3.txz: Rebuilt.
x/xlsatoms-1.1.2-x86_64-2.txz: Rebuilt.
x/xlsclients-1.1.4-x86_64-2.txz: Rebuilt.
x/xlsfonts-1.0.6-x86_64-2.txz: Rebuilt.
x/xmag-1.0.6-x86_64-2.txz: Rebuilt.
x/xman-1.1.4-x86_64-3.txz: Rebuilt.
x/xmessage-1.0.5-x86_64-2.txz: Rebuilt.
x/xmh-1.0.3-x86_64-2.txz: Rebuilt.
x/xmodmap-1.0.9-x86_64-2.txz: Rebuilt.
x/xmore-1.0.2-x86_64-3.txz: Rebuilt.
x/xorg-cf-files-1.0.6-x86_64-3.txz: Rebuilt.
x/xorg-docs-1.7.1-noarch-2.txz: Rebuilt.
x/xorg-server-1.19.6-x86_64-3.txz: Rebuilt.
x/xorg-server-xephyr-1.19.6-x86_64-3.txz: Rebuilt.
x/xorg-server-xnest-1.19.6-x86_64-3.txz: Rebuilt.
x/xorg-server-xvfb-1.19.6-x86_64-3.txz: Rebuilt.
x/xorg-sgml-doctools-1.11-x86_64-3.txz: Rebuilt.
x/xorgproto-2018.4-x86_64-3.txz: Rebuilt.
x/xpr-1.0.5-x86_64-2.txz: Rebuilt.
x/xprop-1.2.3-x86_64-2.txz: Rebuilt.
x/xpyb-1.3.1-x86_64-5.txz: Rebuilt.
x/xrandr-1.5.0-x86_64-2.txz: Rebuilt.
x/xrdb-1.1.1-x86_64-2.txz: Rebuilt.
x/xrefresh-1.0.6-x86_64-2.txz: Rebuilt.
x/xscope-1.4.1-x86_64-3.txz: Rebuilt.
x/xset-1.2.4-x86_64-2.txz: Rebuilt.
x/xsetroot-1.1.2-x86_64-2.txz: Rebuilt.
x/xsm-1.0.4-x86_64-2.txz: Rebuilt.
x/xstdcmap-1.0.3-x86_64-3.txz: Rebuilt.
x/xterm-332-x86_64-1.txz: Upgraded.
x/xtrans-1.3.5-noarch-2.txz: Rebuilt.
x/xvidtune-1.0.3-x86_64-3.txz: Rebuilt.
x/xvinfo-1.1.3-x86_64-2.txz: Rebuilt.
x/xwd-1.0.7-x86_64-2.txz: Rebuilt.
x/xwininfo-1.1.4-x86_64-2.txz: Rebuilt.
x/xwud-1.0.5-x86_64-2.txz: Rebuilt.
xap/MPlayer-20180208-x86_64-3.txz: Rebuilt.
xap/audacious-3.9-x86_64-2.txz: Rebuilt.
xap/audacious-plugins-3.9-x86_64-4.txz: Rebuilt.
xap/blackbox-0.70.1-x86_64-8.txz: Rebuilt.
xap/blueman-2.0.5-x86_64-2.txz: Rebuilt.
xap/ddd-3.3.12-x86_64-6.txz: Rebuilt.
xap/easytag-2.4.2-x86_64-2.txz: Rebuilt.
xap/electricsheep-20090306-x86_64-5.txz: Rebuilt.
xap/fluxbox-1.3.7-x86_64-3.txz: Rebuilt.
xap/fvwm-2.6.7-x86_64-4.txz: Rebuilt.
xap/geeqie-1.4-x86_64-2.txz: Rebuilt.
xap/gftp-2.0.19-x86_64-6.txz: Rebuilt.
xap/gimp-2.8.22-x86_64-2.txz: Rebuilt.
xap/gkrellm-2.3.10-x86_64-3.txz: Rebuilt.
xap/gnuchess-6.2.5-x86_64-2.txz: Rebuilt.
xap/gnuplot-5.2.2-x86_64-2.txz: Rebuilt.
xap/gparted-0.31.0-x86_64-2.txz: Rebuilt.
xap/gucharmap-10.0.3-x86_64-2.txz: Rebuilt.
xap/gv-3.7.4-x86_64-2.txz: Rebuilt.
xap/hexchat-2.14.1-x86_64-2.txz: Rebuilt.
xap/mozilla-firefox-59.0.2-x86_64-2.txz: Rebuilt.
xap/mozilla-thunderbird-52.7.0-x86_64-2.txz: Rebuilt.
xap/network-manager-applet-1.8.10-x86_64-5.txz: Rebuilt.
xap/pan-0.143-x86_64-4.txz: Rebuilt.
xap/pavucontrol-3.0-x86_64-2.txz: Rebuilt.
xap/pidgin-2.13.0-x86_64-2.txz: Rebuilt.
xap/rdesktop-1.8.3-x86_64-2.txz: Rebuilt.
xap/rxvt-unicode-9.22-x86_64-4.txz: Rebuilt.
xap/sane-1.0.27-x86_64-2.txz: Rebuilt.
xap/seamonkey-2.49.2-x86_64-2.txz: Rebuilt.
xap/seyon-2.20c-x86_64-4.txz: Rebuilt.
xap/vim-gvim-8.0.1733-x86_64-1.txz: Upgraded.
xap/windowmaker-0.95.8-x86_64-2.txz: Rebuilt.
xap/x11-ssh-askpass-1.2.4.1-x86_64-3.txz: Rebuilt.
xap/x3270-3.3.12ga7-x86_64-3.txz: Rebuilt.
xap/xaos-3.6-x86_64-2.txz: Rebuilt.
xap/xfractint-20.04p13-x86_64-2.txz: Rebuilt.
xap/xgames-0.3-x86_64-5.txz: Rebuilt.
xap/xine-lib-1.2.9-x86_64-2.txz: Rebuilt.
xap/xine-ui-0.99.10-x86_64-2.txz: Rebuilt.
xap/xlockmore-5.54-x86_64-3.txz: Rebuilt.
xap/xmms-1.2.11-x86_64-6.txz: Rebuilt.
xap/xpaint-2.10.2-x86_64-2.txz: Rebuilt.
xap/xpdf-4.00-x86_64-3.txz: Rebuilt.
xap/xsane-0.999-x86_64-2.txz: Rebuilt.
xap/xscreensaver-5.39-x86_64-1.txz: Upgraded.
xap/xv-3.10a-x86_64-9.txz: Rebuilt.
xfce/Thunar-1.6.15-x86_64-2.txz: Rebuilt.
xfce/exo-0.12.0-x86_64-2.txz: Rebuilt.
xfce/garcon-0.6.1-x86_64-2.txz: Rebuilt.
xfce/gtk-xfce-engine-2.10.1-x86_64-3.txz: Rebuilt.
xfce/libxfce4ui-4.12.1-x86_64-3.txz: Rebuilt.
xfce/libxfce4util-4.12.1-x86_64-4.txz: Rebuilt.
xfce/orage-4.12.1-x86_64-5.txz: Rebuilt.
xfce/thunar-volman-0.8.1-x86_64-3.txz: Rebuilt.
xfce/tumbler-0.2.1-x86_64-2.txz: Rebuilt.
xfce/xfce4-appfinder-4.12.0-x86_64-3.txz: Rebuilt.
xfce/xfce4-clipman-plugin-1.4.2-x86_64-2.txz: Rebuilt.
xfce/xfce4-dev-tools-4.12.0-x86_64-3.txz: Rebuilt.
xfce/xfce4-notifyd-0.4.2-x86_64-2.txz: Rebuilt.
xfce/xfce4-panel-4.12.2-x86_64-2.txz: Rebuilt.
xfce/xfce4-power-manager-1.4.4-x86_64-5.txz: Rebuilt.
xfce/xfce4-pulseaudio-plugin-0.4.0-x86_64-2.txz: Rebuilt.
xfce/xfce4-screenshooter-1.8.2-x86_64-5.txz: Rebuilt.
xfce/xfce4-session-4.12.1-x86_64-3.txz: Rebuilt.
xfce/xfce4-settings-4.12.2-x86_64-2.txz: Rebuilt.
xfce/xfce4-systemload-plugin-1.2.1-x86_64-2.txz: Rebuilt.
       Patched to fix tooltips. Thanks to Rod3775.
xfce/xfce4-taskmanager-1.2.0-x86_64-2.txz: Rebuilt.
xfce/xfce4-terminal-0.8.7.3-x86_64-2.txz: Rebuilt.
xfce/xfce4-weather-plugin-0.8.10-x86_64-4.txz: Rebuilt.
xfce/xfconf-4.12.1-x86_64-2.txz: Rebuilt.
xfce/xfdesktop-4.12.4-x86_64-2.txz: Rebuilt.
xfce/xfwm4-4.12.4-x86_64-2.txz: Rebuilt.
y/bsd-games-2.13-x86_64-13.txz: Rebuilt.
extra/aspell-word-lists/aspell-el-0.08_0-x86_64-1.txz: Upgraded.
extra/aspell-word-lists/aspell-hus-0.03_1-x86_64-1.txz: Added.
extra/aspell-word-lists/aspell-kn-0.01_1-x86_64-1.txz: Added.
extra/fltk/fltk-1.3.4_2-x86_64-1.txz: Upgraded.
extra/mplayerplug-in/mplayerplug-in-3.55-x86_64-1.txz: Removed.
extra/tigervnc/tigervnc-1.8.0-x86_64-4.txz: Rebuilt.
isolinux/initrd.img: Rebuilt.
Slackware 32-bit
a/aaa_base-14.2-i586-4.txz: Rebuilt.
a/aaa_elflibs-14.2-i586-35.txz: Rebuilt.
a/aaa_terminfo-6.1_20180324-i586-4.txz: Rebuilt.
a/acl-2.2.52-i586-2.txz: Rebuilt.
a/acpid-2.0.29-i586-1.txz: Upgraded.
a/attr-2.4.47-i586-2.txz: Rebuilt.
a/bash-4.4.019-i586-3.txz: Rebuilt.
a/bin-11.1-i586-2.txz: Rebuilt.
a/btrfs-progs-v4.16-i586-2.txz: Rebuilt.
a/bzip2-1.0.6-i586-2.txz: Rebuilt.
a/coreutils-8.29-i586-2.txz: Rebuilt.
a/cpio-2.12-i586-2.txz: Rebuilt.
a/cpufrequtils-008-i586-2.txz: Rebuilt.
a/cryptsetup-1.7.5-i586-2.txz: Rebuilt.
a/dbus-1.12.6-i586-2.txz: Rebuilt.
a/dcron-4.5-i586-6.txz: Rebuilt.
a/dialog-1.3_20170509-i586-2.txz: Rebuilt.
a/dosfstools-4.1-i586-2.txz: Rebuilt.
a/e2fsprogs-1.44.1-i586-2.txz: Rebuilt.
a/ed-1.14.2-i586-2.txz: Rebuilt.
a/efibootmgr-0.5.4-i586-2.txz: Rebuilt.
a/elilo-3.16-i586-6.txz: Rebuilt.
a/elvis-2.2_0-i586-4.txz: Rebuilt.
a/etc-15.0-i586-4.txz: Rebuilt.
a/eudev-3.2.5-i586-2.txz: Rebuilt.
a/file-5.33-i586-1.txz: Upgraded.
a/findutils-4.4.2-i586-2.txz: Rebuilt.
a/floppy-5.5-i586-2.txz: Rebuilt.
a/gawk-4.2.1-i586-2.txz: Rebuilt.
a/genpower-1.0.5-i586-3.txz: Rebuilt.
a/gettext-0.19.8.1-i586-5.txz: Rebuilt.
a/getty-ps-2.1.0b-i586-4.txz: Rebuilt.
a/glibc-solibs-2.27-i586-2.txz: Rebuilt.
a/gpm-1.20.7-i586-6.txz: Rebuilt.
a/gptfdisk-1.0.3-i586-2.txz: Rebuilt.
a/grep-3.1-i586-2.txz: Rebuilt.
a/grub-2.02-i586-2.txz: Rebuilt.
a/gzip-1.9-i586-2.txz: Rebuilt.
a/hdparm-9.56-i586-2.txz: Rebuilt.
a/hostname-3.18-i586-2.txz: Rebuilt.
a/infozip-6.0-i586-4.txz: Rebuilt.
a/inotify-tools-3.14-i586-2.txz: Rebuilt.
a/isapnptools-1.27-i586-2.txz: Rebuilt.
a/jfsutils-1.1.15-i586-2.txz: Rebuilt.
a/kbd-1.15.3-i586-4.txz: Rebuilt.
a/kmod-25-i586-2.txz: Rebuilt.
a/lbzip2-2.5-i586-2.txz: Rebuilt.
a/less-530-i586-3.txz: Rebuilt.
a/lha-114i-i586-2.txz: Rebuilt.
a/libcgroup-0.41-i586-3.txz: Rebuilt.
a/libgudev-232-i586-2.txz: Rebuilt.
a/lilo-24.2-i586-8.txz: Rebuilt.
a/logrotate-3.14.0-i586-2.txz: Rebuilt.
a/lrzip-0.631-i586-2.txz: Rebuilt.
a/lvm2-2.02.176-i586-2.txz: Rebuilt.
a/lzip-1.20-i586-3.txz: Rebuilt.
a/lzlib-1.10-i586-3.txz: Rebuilt.
a/mcelog-153-i586-2.txz: Rebuilt.
a/mdadm-4.0-i586-2.txz: Rebuilt.
a/minicom-2.7.1-i586-2.txz: Rebuilt.
a/mkinitrd-1.4.11-i586-6.txz: Rebuilt.
a/mlocate-0.26-i586-2.txz: Rebuilt.
a/mt-st-1.3-i586-2.txz: Rebuilt.
a/mtx-1.3.12-i586-2.txz: Rebuilt.
a/ncompress-4.2.4.4-i586-2.txz: Rebuilt.
a/ntfs-3g-2017.3.23-i586-2.txz: Rebuilt.
a/openssl-solibs-1.0.2o-i586-2.txz: Rebuilt.
a/os-prober-1.76-i586-2.txz: Rebuilt.
a/patch-2.7.6-i586-3.txz: Rebuilt.
a/pciutils-3.5.6-i586-2.txz: Rebuilt.
a/pcmciautils-018-i586-2.txz: Rebuilt.
a/plzip-1.7-i586-3.txz: Rebuilt.
a/procps-ng-3.3.14-i586-2.txz: Rebuilt.
a/quota-4.03-i586-2.txz: Rebuilt.
a/reiserfsprogs-3.6.27-i586-2.txz: Rebuilt.
a/rpm2tgz-1.2.2-i586-2.txz: Rebuilt.
a/sdparm-1.10-i586-2.txz: Rebuilt.
a/sed-4.5-i586-2.txz: Rebuilt.
a/shadow-4.2.1-i586-4.txz: Rebuilt.
a/sharutils-4.15.2-i586-2.txz: Rebuilt.
a/smartmontools-6.6-i586-3.txz: Rebuilt.
a/splitvt-1.6.6-i586-2.txz: Rebuilt.
a/sysfsutils-2.1.0-i586-2.txz: Rebuilt.
a/sysklogd-1.5.1-i586-3.txz: Rebuilt.
a/syslinux-4.07-i586-2.txz: Rebuilt.
a/sysvinit-2.88dsf-i586-5.txz: Rebuilt.
a/sysvinit-functions-8.53-i586-3.txz: Rebuilt.
a/tar-1.30-i586-2.txz: Rebuilt.
a/tcsh-6.20.00-i586-2.txz: Rebuilt.
a/time-1.9-i586-2.txz: Rebuilt.
a/tree-1.7.0-i586-2.txz: Rebuilt.
a/udisks-1.0.5-i586-4.txz: Rebuilt.
a/udisks2-2.6.5-i586-2.txz: Rebuilt.
a/unarj-265-i586-2.txz: Rebuilt.
a/upower-0.9.23-i586-4.txz: Rebuilt.
a/usb_modeswitch-2.5.1-i586-2.txz: Rebuilt.
a/usbutils-009-i586-2.txz: Rebuilt.
a/utempter-1.1.6-i586-3.txz: Rebuilt.
a/util-linux-2.32-i586-2.txz: Rebuilt.
a/which-2.21-i586-2.txz: Rebuilt.
a/xfsprogs-4.15.1-i586-2.txz: Rebuilt.
a/xz-5.2.3-i586-2.txz: Rebuilt.
a/zoo-2.10_22-i586-2.txz: Rebuilt.
ap/a2ps-4.14-i586-7.txz: Rebuilt.
ap/acct-6.6.4-i586-2.txz: Rebuilt.
ap/alsa-utils-1.1.6-i586-2.txz: Rebuilt.
ap/amp-0.7.6-i586-2.txz: Rebuilt.
ap/at-3.1.20-i586-2.txz: Rebuilt.
ap/bc-1.07.1-i586-2.txz: Rebuilt.
ap/bpe-2.01.00-i586-4.txz: Rebuilt.
ap/cdparanoia-III_10.2-i586-2.txz: Rebuilt.
ap/cdrdao-1.2.3-i586-4.txz: Rebuilt.
ap/cdrtools-3.01-i586-4.txz: Rebuilt.
ap/cgmanager-0.41-i586-4.txz: Rebuilt.
ap/cups-2.2.7-i586-2.txz: Rebuilt.
ap/cups-filters-1.20.3-i586-1.txz: Upgraded.
ap/dash-0.5.9.1-i586-2.txz: Rebuilt.
ap/dc3dd-7.2.646-i586-2.txz: Rebuilt.
ap/ddrescue-1.23-i586-2.txz: Rebuilt.
ap/diffstat-1.61-i586-2.txz: Rebuilt.
ap/diffutils-3.6-i586-2.txz: Rebuilt.
ap/dmapi-2.2.12-i586-3.txz: Rebuilt.
ap/dmidecode-3.1-i586-2.txz: Rebuilt.
ap/dvd+rw-tools-7.1-i586-3.txz: Rebuilt.
ap/enscript-1.6.6-i586-2.txz: Rebuilt.
ap/flac-1.3.2-i586-2.txz: Rebuilt.
ap/ghostscript-9.23-i586-2.txz: Rebuilt.
ap/gphoto2-2.5.17-i586-1.txz: Upgraded.
ap/groff-1.22.3-i586-3.txz: Rebuilt.
ap/gutenprint-5.2.13-i586-2.txz: Rebuilt.
ap/hplip-3.18.3-i586-2.txz: Rebuilt.
ap/htop-2.2.0-i586-2.txz: Rebuilt.
ap/ispell-3.4.00-i586-2.txz: Rebuilt.
ap/itstool-2.0.4-i586-3.txz: Rebuilt.
ap/jed-0.99_19-i586-3.txz: Rebuilt.
ap/joe-4.6-i586-2.txz: Rebuilt.
ap/jove-4.16.0.73-i586-4.txz: Rebuilt.
ap/ksh93-20180412_71e6fdad-i586-1.txz: Upgraded.
ap/libx86-1.1-i586-3.txz: Rebuilt.
ap/linuxdoc-tools-0.9.72-i586-5.txz: Rebuilt.
ap/lm_sensors-3.4.0-i586-2.txz: Rebuilt.
ap/lsof-4.91-i586-2.txz: Rebuilt.
ap/lsscsi-0.28-i586-2.txz: Rebuilt.
ap/lxc-2.0.9-i586-2.txz: Rebuilt.
ap/madplay-0.15.2b-i586-5.txz: Rebuilt.
ap/man-db-2.8.3-i586-2.txz: Rebuilt.
ap/mariadb-10.2.14-i586-2.txz: Rebuilt.
ap/mc-4.8.20-i586-2.txz: Rebuilt.
ap/moc-2.5.2-i586-4.txz: Rebuilt.
ap/most-5.0.0a-i586-3.txz: Rebuilt.
ap/mpg123-1.25.10-i586-2.txz: Rebuilt.
ap/nano-2.9.5-i586-2.txz: Rebuilt.
ap/normalize-0.7.7-i586-3.txz: Rebuilt.
ap/opus-tools-0.1.10-i586-2.txz: Rebuilt.
ap/pamixer-1.3.1-i586-6.txz: Rebuilt.
ap/pm-utils-1.4.1-i586-6.txz: Rebuilt.
ap/powertop-2.8-i586-3.txz: Rebuilt.
ap/qpdf-8.0.2-i586-2.txz: Rebuilt.
ap/radeontool-1.6.3-i586-2.txz: Rebuilt.
ap/rpm-4.14.1-i586-2.txz: Rebuilt.
ap/rzip-2.1-i586-2.txz: Rebuilt.
ap/sc-7.16-i586-6.txz: Rebuilt.
ap/screen-4.6.2-i586-2.txz: Rebuilt.
ap/seejpeg-1.10-i586-2.txz: Rebuilt.
ap/sox-14.4.2-i586-5.txz: Rebuilt.
ap/sqlite-3.23.1-i586-2.txz: Rebuilt.
ap/squashfs-tools-4.3-i586-3.txz: Rebuilt.
ap/sudo-1.8.22-i586-2.txz: Rebuilt.
ap/sysstat-11.6.3-i586-2.txz: Rebuilt.
ap/texinfo-6.5-i586-3.txz: Rebuilt.
ap/tmux-2.7-i586-1.txz: Upgraded.
ap/usbmuxd-1.1.0-i586-2.txz: Rebuilt.
ap/vbetool-1.2.2-i586-2.txz: Rebuilt.
ap/vim-8.0.1733-i586-1.txz: Upgraded.
ap/vorbis-tools-1.4.0-i586-4.txz: Rebuilt.
ap/xfsdump-3.1.8-i586-2.txz: Rebuilt.
ap/xorriso-1.4.8-i586-2.txz: Rebuilt.
ap/zsh-5.5.1-i586-1.txz: Upgraded.
d/Cython-0.28.1-i586-2.txz: Rebuilt.
d/binutils-2.30-i586-2.txz: Rebuilt.
d/bison-3.0.4-i586-2.txz: Rebuilt.
d/ccache-3.4.2-i586-2.txz: Rebuilt.
d/clisp-2.49.20180409.0e4d38776f59-i586-1.txz: Upgraded.
d/cmake-3.11.1-i586-1.txz: Upgraded.
d/cscope-15.8b-i586-3.txz: Rebuilt.
d/cvs-1.11.23-i586-3.txz: Rebuilt.
d/dev86-0.16.21-i586-2.txz: Rebuilt.
d/distcc-3.3-i586-2.txz: Rebuilt.
d/doxygen-1.8.14-i586-2.txz: Rebuilt.
d/flex-2.6.4-i586-3.txz: Rebuilt.
d/gcc-7.3.0-i586-2.txz: Rebuilt.
d/gcc-brig-7.3.0-i586-2.txz: Rebuilt.
d/gcc-g++-7.3.0-i586-2.txz: Rebuilt.
d/gcc-gfortran-7.3.0-i586-2.txz: Rebuilt.
d/gcc-gnat-7.3.0-i586-2.txz: Rebuilt.
d/gcc-go-7.3.0-i586-2.txz: Rebuilt.
d/gcc-objc-7.3.0-i586-2.txz: Rebuilt.
d/gdb-8.1-i586-2.txz: Rebuilt.
d/gettext-tools-0.19.8.1-i586-5.txz: Rebuilt.
d/git-2.17.0-i586-2.txz: Rebuilt.
d/gnucobol-2.2-i586-2.txz: Rebuilt.
d/gperf-3.1-i586-2.txz: Rebuilt.
d/guile-2.2.3-i586-2.txz: Rebuilt.
d/help2man-1.47.6-i586-2.txz: Rebuilt.
d/indent-2.2.10-i586-2.txz: Rebuilt.
d/intltool-0.51.0-i586-4.txz: Rebuilt.
d/libtool-2.4.6-i586-7.txz: Rebuilt.
d/llvm-6.0.0-i586-2.txz: Rebuilt.
d/m4-1.4.18-i586-2.txz: Rebuilt.
d/make-4.2.1-i586-3.txz: Rebuilt.
d/mercurial-4.5.3-i586-2.txz: Rebuilt.
d/meson-0.45.1-i586-2.txz: Rebuilt.
d/nasm-2.13.03-i586-2.txz: Rebuilt.
d/ninja-1.8.2-i586-2.txz: Rebuilt.
d/oprofile-1.2.0-i586-3.txz: Rebuilt.
d/p2c-1.21alpha2-i586-4.txz: Rebuilt.
d/patchelf-0.9-i586-2.txz: Rebuilt.
d/perl-5.26.2-i586-1.txz: Upgraded.
d/pkg-config-0.29.2-i586-2.txz: Rebuilt.
d/pmake-1.111-i586-5.txz: Rebuilt.
d/python-2.7.14-i586-2.txz: Rebuilt.
d/python-pip-9.0.3-i586-2.txz: Rebuilt.
d/python-setuptools-39.0.1-i586-2.txz: Rebuilt.
d/python3-3.6.5-i586-2.txz: Rebuilt.
d/rcs-5.9.4-i586-2.txz: Rebuilt.
d/re2c-1.0.3-i586-2.txz: Rebuilt.
d/ruby-2.5.1-i586-2.txz: Rebuilt.
d/rust-1.25.0-i686-2.txz: Rebuilt.
d/scons-3.0.1-i586-2.txz: Rebuilt.
d/slacktrack-2.18-i586-2.txz: Rebuilt.
d/strace-4.22-i586-2.txz: Rebuilt.
d/subversion-1.10.0-i586-1.txz: Upgraded.
d/swig-3.0.12-i586-2.txz: Rebuilt.
d/yasm-1.3.0-i586-2.txz: Rebuilt.
e/emacs-25.3-i586-2.txz: Rebuilt.
kde/amarok-2.9.0-i586-2.txz: Rebuilt.
kde/amor-4.14.3-i586-3.txz: Rebuilt.
kde/analitza-4.14.3-i586-4.txz: Rebuilt.
kde/ark-4.14.3-i586-3.txz: Rebuilt.
kde/artikulate-4.14.3-i586-3.txz: Rebuilt.
kde/audiocd-kio-4.14.3-i586-3.txz: Rebuilt.
kde/baloo-4.14.3-i586-4.txz: Rebuilt.
kde/baloo-widgets-4.14.3-i586-3.txz: Rebuilt.
kde/blinken-4.14.3-i586-3.txz: Rebuilt.
kde/bluedevil-2.1.1-i586-4.txz: Rebuilt.
kde/bomber-4.14.3-i586-3.txz: Rebuilt.
kde/bovo-4.14.3-i586-3.txz: Rebuilt.
kde/calligra-2.9.11-i586-20.txz: Rebuilt.
kde/cantor-4.14.3-i586-3.txz: Rebuilt.
kde/cervisia-4.14.3-i586-3.txz: Rebuilt.
kde/dolphin-plugins-4.14.3-i586-3.txz: Rebuilt.
kde/dragon-4.14.3-i586-3.txz: Rebuilt.
kde/filelight-4.14.3-i586-3.txz: Rebuilt.
kde/granatier-4.14.3-i586-3.txz: Rebuilt.
kde/gwenview-4.14.3-i586-4.txz: Rebuilt.
kde/juk-4.14.3-i586-3.txz: Rebuilt.
kde/k3b-2.0.3-i586-4.txz: Rebuilt.
kde/kaccessible-4.14.3-i586-3.txz: Rebuilt.
kde/kactivities-4.13.3-i586-3.txz: Rebuilt.
kde/kajongg-4.14.3-i586-3.txz: Rebuilt.
kde/kalgebra-4.14.3-i586-3.txz: Rebuilt.
kde/kalzium-4.14.3-i586-3.txz: Rebuilt.
kde/kamera-4.14.3-i586-3.txz: Rebuilt.
kde/kanagram-4.14.3-i586-3.txz: Rebuilt.
kde/kapman-4.14.3-i586-3.txz: Rebuilt.
kde/kapptemplate-4.14.3-i586-3.txz: Rebuilt.
kde/kate-4.14.3-i586-4.txz: Rebuilt.
kde/katomic-4.14.3-i586-3.txz: Rebuilt.
kde/kaudiocreator-1.3-i586-3.txz: Rebuilt.
kde/kblackbox-4.14.3-i586-3.txz: Rebuilt.
kde/kblocks-4.14.3-i586-3.txz: Rebuilt.
kde/kbounce-4.14.3-i586-3.txz: Rebuilt.
kde/kbreakout-4.14.3-i586-3.txz: Rebuilt.
kde/kbruch-4.14.3-i586-3.txz: Rebuilt.
kde/kcachegrind-4.14.3-i586-3.txz: Rebuilt.
kde/kcalc-4.14.3-i586-3.txz: Rebuilt.
kde/kcharselect-4.14.3-i586-3.txz: Rebuilt.
kde/kcolorchooser-4.14.3-i586-3.txz: Rebuilt.
kde/kcron-4.14.3-i586-3.txz: Rebuilt.
kde/kde-base-artwork-4.14.3-i586-3.txz: Rebuilt.
kde/kde-baseapps-4.14.3-i586-3.txz: Rebuilt.
kde/kde-dev-scripts-4.14.3-i586-3.txz: Rebuilt.
kde/kde-dev-utils-4.14.3-i586-3.txz: Rebuilt.
kde/kde-runtime-4.14.3-i586-6.txz: Rebuilt.
kde/kde-workspace-4.11.22-i586-5.txz: Rebuilt.
kde/kdeartwork-4.14.3-i586-3.txz: Rebuilt.
kde/kdeconnect-kde-0.8-i586-4.txz: Rebuilt.
kde/kdegraphics-mobipocket-4.14.3-i586-3.txz: Rebuilt.
kde/kdegraphics-strigi-analyzer-4.14.3-i586-3.txz: Rebuilt.
kde/kdegraphics-thumbnailers-4.14.3-i586-3.txz: Rebuilt.
kde/kdelibs-4.14.38-i586-2.txz: Rebuilt.
kde/kdenetwork-filesharing-4.14.3-i586-3.txz: Rebuilt.
kde/kdenetwork-strigi-analyzers-4.14.3-i586-3.txz: Rebuilt.
kde/kdepim-4.14.10-i586-3.txz: Rebuilt.
kde/kdepim-runtime-4.14.10-i586-2.txz: Rebuilt.
kde/kdepimlibs-4.14.10-i586-5.txz: Rebuilt.
kde/kdeplasma-addons-4.14.3-i586-3.txz: Rebuilt.
kde/kdesdk-kioslaves-4.14.3-i586-3.txz: Rebuilt.
kde/kdesdk-strigi-analyzers-4.14.3-i586-3.txz: Rebuilt.
kde/kdesdk-thumbnailers-4.14.3-i586-3.txz: Rebuilt.
kde/kdev-python-1.7.3-i586-3.txz: Rebuilt.
kde/kdevelop-4.7.4-i586-2.txz: Rebuilt.
kde/kdevelop-pg-qt-1.0.0-i586-3.txz: Rebuilt.
kde/kdevelop-php-1.7.4-i586-2.txz: Rebuilt.
kde/kdevelop-php-docs-1.7.4-i586-2.txz: Rebuilt.
kde/kdevplatform-1.7.4-i586-2.txz: Rebuilt.
kde/kdewebdev-4.14.3-i586-3.txz: Rebuilt.
kde/kdf-4.14.3-i586-3.txz: Rebuilt.
kde/kdiamond-4.14.3-i586-3.txz: Rebuilt.
kde/kfilemetadata-4.14.3-i586-4.txz: Rebuilt.
kde/kfloppy-4.14.3-i586-3.txz: Rebuilt.
kde/kfourinline-4.14.3-i586-3.txz: Rebuilt.
kde/kgamma-4.14.3-i586-3.txz: Rebuilt.
kde/kgeography-4.14.3-i586-3.txz: Rebuilt.
kde/kget-4.14.3-i586-4.txz: Rebuilt.
kde/kgoldrunner-4.14.3-i586-3.txz: Rebuilt.
kde/kgpg-4.14.3-i586-3.txz: Rebuilt.
kde/khangman-4.14.3-i586-3.txz: Rebuilt.
kde/kig-4.14.3-i586-8.txz: Rebuilt.
kde/kigo-4.14.3-i586-3.txz: Rebuilt.
kde/killbots-4.14.3-i586-3.txz: Rebuilt.
kde/kio-mtp-2063e75_20131020git-i586-4.txz: Rebuilt.
kde/kiriki-4.14.3-i586-3.txz: Rebuilt.
kde/kiten-4.14.3-i586-3.txz: Rebuilt.
kde/kjumpingcube-4.14.3-i586-3.txz: Rebuilt.
kde/klettres-4.14.3-i586-3.txz: Rebuilt.
kde/klickety-4.14.3-i586-3.txz: Rebuilt.
kde/klines-4.14.3-i586-3.txz: Rebuilt.
kde/kmag-4.14.3-i586-3.txz: Rebuilt.
kde/kmahjongg-4.14.3-i586-3.txz: Rebuilt.
kde/kmines-4.14.3-i586-3.txz: Rebuilt.
kde/kmix-4.14.3-i586-4.txz: Rebuilt.
kde/kmousetool-4.14.3-i586-3.txz: Rebuilt.
kde/kmouth-4.14.3-i586-3.txz: Rebuilt.
kde/kmplot-4.14.3-i586-3.txz: Rebuilt.
kde/knavalbattle-4.14.3-i586-3.txz: Rebuilt.
kde/knetwalk-4.14.3-i586-3.txz: Rebuilt.
kde/kolf-4.14.3-i586-3.txz: Rebuilt.
kde/kollision-4.14.3-i586-3.txz: Rebuilt.
kde/kolourpaint-4.14.3-i586-3.txz: Rebuilt.
kde/kompare-4.14.3-i586-3.txz: Rebuilt.
kde/konquest-4.14.3-i586-3.txz: Rebuilt.
kde/konsole-4.14.3-i586-5.txz: Rebuilt.
kde/kopete-4.14.3-i586-5.txz: Rebuilt.
kde/korundum-4.14.3-i586-6.txz: Rebuilt.
kde/kpat-4.14.3-i586-3.txz: Rebuilt.
kde/kplayer-0.7.2-i586-3.txz: Rebuilt.
kde/kppp-4.14.3-i586-3.txz: Rebuilt.
kde/kqtquickcharts-4.14.3-i586-3.txz: Rebuilt.
kde/krdc-4.14.3-i586-4.txz: Rebuilt.
kde/kremotecontrol-4.14.3-i586-3.txz: Rebuilt.
kde/kreversi-4.14.3-i586-3.txz: Rebuilt.
kde/krfb-4.14.3-i586-3.txz: Rebuilt.
kde/kross-interpreters-4.14.3-i586-4.txz: Rebuilt.
kde/kruler-4.14.3-i586-3.txz: Rebuilt.
kde/ksaneplugin-4.14.3-i586-3.txz: Rebuilt.
kde/kscreen-1.0.2.1-i586-3.txz: Rebuilt.
kde/kshisen-4.14.3-i586-3.txz: Rebuilt.
kde/ksirk-4.14.3-i586-3.txz: Rebuilt.
kde/ksnakeduel-4.14.3-i586-3.txz: Rebuilt.
kde/ksnapshot-4.14.3-i586-3.txz: Rebuilt.
kde/kspaceduel-4.14.3-i586-3.txz: Rebuilt.
kde/ksquares-4.14.3-i586-3.txz: Rebuilt.
kde/kstars-4.14.3-i586-3.txz: Rebuilt.
kde/ksudoku-4.14.3-i586-3.txz: Rebuilt.
kde/ksystemlog-4.14.3-i586-3.txz: Rebuilt.
kde/kteatime-4.14.3-i586-3.txz: Rebuilt.
kde/ktimer-4.14.3-i586-3.txz: Rebuilt.
kde/ktorrent-4.3.1-i586-3.txz: Rebuilt.
kde/ktouch-4.14.3-i586-4.txz: Rebuilt.
kde/ktuberling-4.14.3-i586-3.txz: Rebuilt.
kde/kturtle-4.14.3-i586-3.txz: Rebuilt.
kde/ktux-4.14.3-i586-3.txz: Rebuilt.
kde/kubrick-4.14.3-i586-3.txz: Rebuilt.
kde/kuser-4.14.3-i586-3.txz: Rebuilt.
kde/kwalletmanager-4.14.3-i586-3.txz: Rebuilt.
kde/kwebkitpart-1.3.4-i586-3.txz: Rebuilt.
kde/kwordquiz-4.14.3-i586-3.txz: Rebuilt.
kde/libkcddb-4.14.3-i586-3.txz: Rebuilt.
kde/libkcompactdisc-4.14.3-i586-3.txz: Rebuilt.
kde/libkdcraw-4.14.3-i586-5.txz: Rebuilt.
kde/libkdeedu-4.14.3-i586-3.txz: Rebuilt.
kde/libkdegames-4.14.3-i586-3.txz: Rebuilt.
kde/libkexiv2-4.14.3-i586-4.txz: Rebuilt.
kde/libkipi-4.14.3-i586-3.txz: Rebuilt.
kde/libkmahjongg-4.14.3-i586-3.txz: Rebuilt.
kde/libkomparediff2-4.14.3-i586-3.txz: Rebuilt.
kde/libksane-4.14.3-i586-3.txz: Rebuilt.
kde/libkscreen-1.0.5-i586-3.txz: Rebuilt.
kde/libktorrent-1.3.1-i586-4.txz: Rebuilt.
kde/libmm-qt-1.0.1-i586-3.txz: Rebuilt.
kde/libnm-qt-0.9.8.3-i586-3.txz: Rebuilt.
kde/lokalize-4.14.3-i586-4.txz: Rebuilt.
kde/lskat-4.14.3-i586-4.txz: Rebuilt.
kde/marble-4.14.3-i586-3.txz: Rebuilt.
kde/mplayerthumbs-4.14.3-i586-3.txz: Rebuilt.
kde/nepomuk-core-4.14.3-i586-4.txz: Rebuilt.
kde/nepomuk-widgets-4.14.3-i586-3.txz: Rebuilt.
kde/okteta-4.14.3-i586-3.txz: Rebuilt.
kde/okular-4.14.3-i586-3.txz: Rebuilt.
kde/oxygen-gtk2-1.4.6-i586-3.txz: Rebuilt.
kde/oxygen-icons-4.14.3-i586-3.txz: Rebuilt.
kde/pairs-4.14.3-i586-3.txz: Rebuilt.
kde/palapeli-4.14.3-i586-3.txz: Rebuilt.
kde/parley-4.14.3-i586-3.txz: Rebuilt.
kde/partitionmanager-1.1.1-i586-3.txz: Rebuilt.
kde/perlkde-4.14.3-i586-5.txz: Rebuilt.
       Recompiled against perl-5.26.2.
kde/perlqt-4.14.3-i586-6.txz: Rebuilt.
kde/picmi-4.14.3-i586-3.txz: Rebuilt.
kde/plasma-nm-0.9.3.6-i586-2.txz: Rebuilt.
kde/polkit-kde-agent-1-9d74ae3_20120104git-i586-3.txz: Rebuilt.
kde/polkit-kde-kcmodules-1-001bdf7_20120111git-i586-3.txz: Rebuilt.
kde/poxml-4.14.3-i586-3.txz: Rebuilt.
kde/print-manager-4.14.3-i586-3.txz: Rebuilt.
kde/pykde4-4.14.3-i586-7.txz: Rebuilt.
kde/qtruby-4.14.3-i586-8.txz: Rebuilt.
kde/rocs-4.14.3-i586-3.txz: Rebuilt.
kde/skanlite-1.1-i586-3.txz: Rebuilt.
kde/smokegen-4.14.3-i586-3.txz: Rebuilt.
kde/smokekde-4.14.3-i586-3.txz: Rebuilt.
kde/smokeqt-4.14.3-i586-5.txz: Rebuilt.
kde/step-4.14.3-i586-6.txz: Rebuilt.
kde/superkaramba-4.14.3-i586-4.txz: Rebuilt.
kde/svgpart-4.14.3-i586-3.txz: Rebuilt.
kde/sweeper-4.14.3-i586-3.txz: Rebuilt.
kde/umbrello-4.14.3-i586-3.txz: Rebuilt.
kde/wicd-kde-0.3.0_bcf27d8-i586-3.txz: Rebuilt.
kde/zeroconf-ioslave-4.14.3-i586-3.txz: Rebuilt.
l/ConsoleKit2-1.0.0-i586-4.txz: Rebuilt.
l/GConf-3.2.6-i586-4.txz: Rebuilt.
l/LibRaw-0.18.8-i586-2.txz: Rebuilt.
l/M2Crypto-0.27.0-i586-3.txz: Rebuilt.
l/Mako-1.0.7-i586-2.txz: Rebuilt.
l/PyQt-4.12.1-i586-2.txz: Rebuilt.
l/QScintilla-2.10.2-i586-2.txz: Rebuilt.
l/SDL2-2.0.8-i586-2.txz: Rebuilt.
l/SDL2_gfx-1.0.3-i586-2.txz: Rebuilt.
l/SDL2_image-2.0.3-i586-2.txz: Rebuilt.
l/SDL2_mixer-2.0.2-i586-3.txz: Rebuilt.
l/SDL2_net-2.0.1-i586-2.txz: Rebuilt.
l/SDL2_ttf-2.0.14-i586-2.txz: Rebuilt.
l/a52dec-0.7.4-i586-3.txz: Rebuilt.
l/aalib-1.4rc5-i586-6.txz: Rebuilt.
l/akonadi-1.13.0-i586-9.txz: Rebuilt.
       Recompiled against boost-1.67.0.
l/alsa-lib-1.1.6-i586-3.txz: Rebuilt.
l/alsa-oss-1.1.6-i586-2.txz: Rebuilt.
l/alsa-plugins-1.1.6-i586-2.txz: Rebuilt.
l/apr-1.6.3-i586-2.txz: Rebuilt.
l/apr-util-1.6.1-i586-6.txz: Rebuilt.
l/aspell-0.60.6.1-i586-3.txz: Rebuilt.
l/aspell-en-2018.04.16_0-i586-1.txz: Upgraded.
l/at-spi2-atk-2.26.2-i586-2.txz: Rebuilt.
l/at-spi2-core-2.28.0-i586-2.txz: Rebuilt.
l/atk-2.28.1-i586-2.txz: Rebuilt.
l/atkmm-2.24.2-i586-2.txz: Rebuilt.
l/attica-0.4.2-i586-2.txz: Rebuilt.
l/audiofile-0.3.6-i586-2.txz: Rebuilt.
l/automoc4-0.9.88-i586-2.txz: Rebuilt.
l/babl-0.1.46-i586-1.txz: Upgraded.
l/boost-1.67.0-i586-1.txz: Upgraded.
l/cairo-1.15.12-i586-2.txz: Rebuilt.
l/cairomm-1.12.2-i586-2.txz: Rebuilt.
l/chmlib-0.40-i586-3.txz: Rebuilt.
l/clucene-2.3.3.4-i586-3.txz: Rebuilt.
l/db42-4.2.52-i586-4.txz: Rebuilt.
l/db44-4.4.20-i586-4.txz: Rebuilt.
l/db48-4.8.30-i586-3.txz: Rebuilt.
l/dbus-glib-0.110-i586-2.txz: Rebuilt.
l/dbus-python-1.2.6-i586-2.txz: Rebuilt.
l/dconf-0.26.1-i586-2.txz: Rebuilt.
l/dconf-editor-3.26.2-i586-2.txz: Rebuilt.
l/desktop-file-utils-0.23-i586-2.txz: Rebuilt.
l/djvulibre-3.5.27-i586-2.txz: Rebuilt.
l/ebook-tools-0.2.2-i586-5.txz: Rebuilt.
l/eigen2-2.0.17-i586-2.txz: Rebuilt.
l/eigen3-3.2.10-i586-2.txz: Rebuilt.
l/elfutils-0.170-i586-2.txz: Rebuilt.
l/enchant-1.6.1-i586-2.txz: Rebuilt.
l/esound-0.2.41-i586-3.txz: Rebuilt.
l/exiv2-0.26-i586-3.txz: Rebuilt.
l/expat-2.2.5-i586-2.txz: Rebuilt.
l/ffmpeg-3.4.2-i586-2.txz: Rebuilt.
l/fftw-3.3.7-i586-2.txz: Rebuilt.
l/fluidsynth-1.1.10-i586-2.txz: Rebuilt.
l/freetype-2.9-i586-2.txz: Rebuilt.
l/fribidi-0.19.7-i586-2.txz: Rebuilt.
l/fuse-2.9.7-i586-2.txz: Rebuilt.
l/gamin-0.1.10-i586-6.txz: Rebuilt.
l/gc-7.6.4-i586-2.txz: Rebuilt.
l/gcr-3.28.0-i586-2.txz: Rebuilt.
l/gd-2.2.5-i586-1.txz: Upgraded.
l/gdbm-1.13-i586-2.txz: Rebuilt.
l/gdk-pixbuf2-2.36.12-i586-2.txz: Rebuilt.
l/gegl-0.2.0-i586-7.txz: Rebuilt.
l/giflib-5.1.4-i586-2.txz: Rebuilt.
l/glade3-3.8.6-i586-2.txz: Rebuilt.
l/glib-1.2.10-i586-6.txz: Rebuilt.
l/glib-networking-2.56.0-i586-2.txz: Rebuilt.
l/glib2-2.56.1-i586-2.txz: Rebuilt.
l/glibc-2.27-i586-2.txz: Rebuilt.
l/glibc-i18n-2.27-i586-2.txz: Rebuilt.
l/glibc-profile-2.27-i586-2.txz: Rebuilt.
l/glibmm-2.56.0-i586-1.txz: Upgraded.
l/gmime-2.6.23-i586-3.txz: Rebuilt.
l/gmp-6.1.2-i586-2.txz: Rebuilt.
l/gnome-keyring-3.28.0.2-i586-2.txz: Rebuilt.
l/gnome-themes-standard-3.22.3-i586-2.txz: Rebuilt.
l/gnu-efi-3.0.6-i586-2.txz: Rebuilt.
l/gobject-introspection-1.56.1-i586-2.txz: Rebuilt.
l/grantlee-0.5.1-i586-2.txz: Rebuilt.
l/gsettings-desktop-schemas-3.28.0-i586-2.txz: Rebuilt.
l/gsl-2.4-i586-2.txz: Rebuilt.
l/gst-plugins-base-1.14.0-i586-2.txz: Rebuilt.
l/gst-plugins-base0-0.10.36-i586-3.txz: Rebuilt.
l/gst-plugins-good-1.14.0-i586-2.txz: Rebuilt.
l/gst-plugins-good0-0.10.31-i586-3.txz: Rebuilt.
l/gst-plugins-libav-1.14.0-i586-2.txz: Rebuilt.
l/gstreamer-1.14.0-i586-2.txz: Rebuilt.
l/gstreamer0-0.10.36-i586-2.txz: Rebuilt.
l/gtk+-1.2.10-i586-7.txz: Rebuilt.
l/gtk+2-2.24.32-i586-2.txz: Rebuilt.
l/gtk+3-3.22.30-i586-1.txz: Upgraded.
l/gtkmm2-2.24.5-i586-2.txz: Rebuilt.
l/gtkmm3-3.22.2-i586-2.txz: Rebuilt.
l/gtkspell-2.0.16-i586-4.txz: Rebuilt.
l/gvfs-1.36.1-i586-2.txz: Rebuilt.
l/harfbuzz-1.7.6-i586-3.txz: Rebuilt.
l/hunspell-1.6.2-i586-2.txz: Rebuilt.
l/icon-naming-utils-0.8.90-i586-3.txz: Rebuilt.
l/icu4c-61.1-i586-2.txz: Rebuilt.
l/id3lib-3.8.3-i586-2.txz: Rebuilt.
l/ilmbase-2.2.0-i586-2.txz: Rebuilt.
l/imagemagick-6.9.9_40-i586-2.txz: Rebuilt.
l/jansson-2.11-i586-2.txz: Rebuilt.
l/jasper-2.0.12-i586-2.txz: Rebuilt.
l/jemalloc-4.5.0-i586-2.txz: Rebuilt.
l/js185-1.0.0-i586-2.txz: Rebuilt.
l/judy-1.0.5-i586-2.txz: Rebuilt.
l/keybinder-0.3.1-i586-2.txz: Rebuilt.
l/keyutils-1.5.10-i586-2.txz: Rebuilt.
l/lame-3.100-i586-2.txz: Rebuilt.
l/lcms-1.19-i586-4.txz: Rebuilt.
l/lcms2-2.9-i586-2.txz: Rebuilt.
l/libaio-0.3.110-i586-2.txz: Rebuilt.
l/libao-1.2.2-i586-2.txz: Rebuilt.
l/libarchive-3.3.2-i586-2.txz: Rebuilt.
l/libart_lgpl-2.3.21-i586-2.txz: Rebuilt.
l/libasyncns-0.8-i586-2.txz: Rebuilt.
l/libatasmart-0.19-i586-3.txz: Rebuilt.
l/libbluedevil-2.1-i586-2.txz: Rebuilt.
l/libbluray-1.0.1-i586-2.txz: Rebuilt.
l/libcaca-0.99.beta19-i586-3.txz: Rebuilt.
l/libcanberra-0.30-i586-6.txz: Rebuilt.
l/libcap-2.25-i586-2.txz: Rebuilt.
l/libcap-ng-0.7.8-i586-3.txz: Rebuilt.
l/libcddb-1.3.2-i586-5.txz: Rebuilt.
l/libcdio-2.0.0-i586-2.txz: Rebuilt.
l/libcdio-paranoia-10.2+0.94+2-i586-3.txz: Rebuilt.
l/libclc-20180223_3554053-i586-2.txz: Rebuilt.
l/libcroco-0.6.12-i586-2.txz: Rebuilt.
l/libdbusmenu-qt-0.9.2-i586-3.txz: Rebuilt.
l/libdiscid-0.6.2-i586-2.txz: Rebuilt.
l/libdvdnav-6.0.0-i586-2.txz: Rebuilt.
l/libdvdread-6.0.0-i586-3.txz: Rebuilt.
l/libedit-20170329_3.1-i586-2.txz: Rebuilt.
l/libevent-2.1.8-i586-2.txz: Rebuilt.
l/libexif-0.6.21-i586-2.txz: Rebuilt.
l/libfakekey-0.3-i586-2.txz: Rebuilt.
l/libffi-3.2.1-i586-2.txz: Rebuilt.
l/libglade-2.6.4-i586-6.txz: Rebuilt.
l/libgnome-keyring-3.12.0-i586-2.txz: Rebuilt.
l/libgphoto2-2.5.17-i586-1.txz: Upgraded.
l/libgpod-0.8.3-i586-5.txz: Rebuilt.
l/libgsf-1.14.42-i586-2.txz: Rebuilt.
l/libical-3.0.1-i586-3.txz: Rebuilt.
l/libid3tag-0.15.1b-i586-5.txz: Rebuilt.
l/libidl-0.8.14-i586-2.txz: Rebuilt.
l/libidn-1.34-i586-2.txz: Rebuilt.
l/libidn2-2.0.4-i586-2.txz: Rebuilt.
l/libieee1284-0.2.11-i586-4.txz: Rebuilt.
l/libimobiledevice-1.2.0-i586-3.txz: Rebuilt.
l/libiodbc-3.52.10-i586-3.txz: Rebuilt.
l/libjpeg-turbo-1.5.3-i586-2.txz: Rebuilt.
l/libkarma-0.1.1-i586-3.txz: Rebuilt.
l/liblastfm-1.0.9-i586-2.txz: Rebuilt.
l/libmad-0.15.1b-i586-4.txz: Rebuilt.
l/libmcrypt-2.5.8-i586-2.txz: Rebuilt.
l/libmng-2.0.3-i586-2.txz: Rebuilt.
l/libmpc-1.1.0-i586-2.txz: Rebuilt.
l/libmsn-4.2.1-i586-3.txz: Rebuilt.
l/libmtp-1.1.15-i586-2.txz: Rebuilt.
l/libnih-1.0.3-i586-3.txz: Rebuilt.
l/libnjb-2.2.7-i586-2.txz: Rebuilt.
l/libnl-1.1.4-i586-2.txz: Rebuilt.
l/libnl3-3.4.0-i586-2.txz: Rebuilt.
l/libnotify-0.7.7-i586-2.txz: Rebuilt.
l/libodfgen-0.1.6-i586-2.txz: Rebuilt.
l/libogg-1.3.3-i586-2.txz: Rebuilt.
l/liboggz-1.1.1-i586-3.txz: Rebuilt.
l/liboil-0.3.17-i586-2.txz: Rebuilt.
l/libpcap-1.8.1-i586-2.txz: Rebuilt.
l/libplist-2.0.0-i586-2.txz: Rebuilt.
l/libpng-1.6.34-i586-2.txz: Rebuilt.
l/libproxy-0.4.15-i586-2.txz: Rebuilt.
l/libraw1394-2.1.2-i586-2.txz: Rebuilt.
l/librevenge-0.0.4-i586-2.txz: Rebuilt.
l/librsvg-2.42.3-i586-3.txz: Rebuilt.
l/libsamplerate-0.1.9-i586-2.txz: Rebuilt.
l/libsecret-0.18.6-i586-2.txz: Rebuilt.
l/libsigc++-2.10.0-i586-2.txz: Rebuilt.
l/libsigsegv-2.12-i586-2.txz: Rebuilt.
l/libsndfile-1.0.28-i586-2.txz: Rebuilt.
l/libsodium-1.0.16-i586-2.txz: Rebuilt.
l/libsoup-2.62.1-i586-2.txz: Rebuilt.
l/libspectre-0.2.8-i586-2.txz: Rebuilt.
l/libssh-0.7.5-i586-2.txz: Rebuilt.
l/libssh2-1.8.0-i586-2.txz: Rebuilt.
l/libtasn1-4.13-i586-2.txz: Rebuilt.
l/libtheora-1.1.1-i586-2.txz: Rebuilt.
l/libtiff-4.0.9-i586-2.txz: Rebuilt.
l/libunistring-0.9.9-i586-2.txz: Rebuilt.
l/libunwind-1.2.1-i586-3.txz: Rebuilt.
l/libusb-1.0.22-i586-2.txz: Rebuilt.
l/libusb-compat-0.1.5-i586-3.txz: Rebuilt.
l/libusbmuxd-1.0.10-i586-2.txz: Rebuilt.
l/libvisio-0.1.6-i586-3.txz: Rebuilt.
l/libvisual-0.4.0-i586-4.txz: Rebuilt.
l/libvisual-plugins-0.4.0-i586-3.txz: Rebuilt.
l/libvncserver-0.9.11-i586-3.txz: Rebuilt.
l/libvorbis-1.3.6-i586-2.txz: Rebuilt.
l/libvpx-1.7.0-i586-2.txz: Rebuilt.
l/libwebp-0.6.1-i586-2.txz: Rebuilt.
l/libwmf-0.2.8.4-i586-7.txz: Rebuilt.
l/libwnck-2.31.0-i586-3.txz: Rebuilt.
l/libwpd-0.10.1-i586-2.txz: Rebuilt.
l/libwpg-0.3.1-i586-2.txz: Rebuilt.
l/libxklavier-5.4-i586-2.txz: Rebuilt.
l/libxml2-2.9.8-i586-2.txz: Rebuilt.
l/libxslt-1.1.32-i586-2.txz: Rebuilt.
l/libyaml-0.1.7-i586-2.txz: Rebuilt.
l/libzip-1.5.1-i586-2.txz: Rebuilt.
l/loudmouth-1.5.3-i586-2.txz: Rebuilt.
l/lzo-2.10-i586-2.txz: Rebuilt.
l/mhash-0.9.9.9-i586-4.txz: Rebuilt.
l/mm-1.4.2-i586-3.txz: Rebuilt.
l/mozilla-nss-3.36.1-i586-2.txz: Rebuilt.
l/mpfr-4.0.1-i586-2.txz: Rebuilt.
l/ncurses-6.1_20180324-i586-4.txz: Rebuilt.
l/neon-0.30.1-i586-3.txz: Rebuilt.
l/netpbm-10.66.02-i586-5.txz: Rebuilt.
l/newt-0.52.20-i586-3.txz: Rebuilt.
l/ocl-icd-2.2.12-i586-2.txz: Rebuilt.
l/openexr-2.2.0-i586-3.txz: Rebuilt.
l/openjpeg-2.3.0-i586-2.txz: Rebuilt.
l/opus-1.3_beta-i586-2.txz: Rebuilt.
l/opusfile-0.9-i586-3.txz: Rebuilt.
l/orc-0.4.28-i586-2.txz: Rebuilt.
l/pango-1.42.1-i586-2.txz: Rebuilt.
l/pangomm-2.40.1-i586-2.txz: Rebuilt.
l/parted-3.2-i586-4.txz: Rebuilt.
l/pcre-8.42-i586-2.txz: Rebuilt.
l/pcre2-10.31-i586-2.txz: Rebuilt.
l/phonon-4.8.3-i586-3.txz: Rebuilt.
l/phonon-gstreamer-4.8.2-i586-2.txz: Rebuilt.
l/pilot-link-0.12.5-i586-13.txz: Rebuilt.
l/polkit-0.113-i586-4.txz: Rebuilt.
l/polkit-gnome-0.105-i586-2.txz: Rebuilt.
l/polkit-qt-1-0.112.0-i586-2.txz: Rebuilt.
l/poppler-0.64.0-i586-1.txz: Upgraded.
l/popt-1.16-i586-3.txz: Rebuilt.
l/pulseaudio-11.1-i586-2.txz: Rebuilt.
l/pycairo-1.16.3-i586-2.txz: Rebuilt.
l/pycups-1.9.73-i586-4.txz: Rebuilt.
l/pycurl-7.43.0.1-i586-2.txz: Rebuilt.
l/pygobject-2.28.7-i586-2.txz: Rebuilt.
l/pygobject3-3.28.2-i586-2.txz: Rebuilt.
l/pygtk-2.24.0-i586-5.txz: Rebuilt.
l/pyparsing-2.2.0-i586-2.txz: Rebuilt.
l/python-appdirs-1.4.3-i586-2.txz: Rebuilt.
l/python-certifi-2018.1.18-i586-2.txz: Rebuilt.
l/python-chardet-3.0.4-i586-2.txz: Rebuilt.
l/python-docutils-0.14-i586-2.txz: Rebuilt.
l/python-idna-2.6-i586-2.txz: Rebuilt.
l/python-notify2-0.3.1-i586-2.txz: Rebuilt.
l/python-packaging-16.8-i586-2.txz: Rebuilt.
l/python-pillow-5.1.0-i586-2.txz: Rebuilt.
l/python-requests-2.18.4-i586-2.txz: Rebuilt.
l/python-sane-2.8.3-i586-2.txz: Rebuilt.
l/python-six-1.11.0-i586-2.txz: Rebuilt.
l/python-urllib3-1.22-i586-2.txz: Rebuilt.
l/qca-2.1.3-i586-2.txz: Rebuilt.
l/qimageblitz-0.0.6-i586-2.txz: Rebuilt.
l/qjson-0.8.1-i586-2.txz: Rebuilt.
l/qt-4.8.7-i586-9.txz: Rebuilt.
l/qt-gstreamer-1.2.0-i586-2.txz: Rebuilt.
l/qtscriptgenerator-0.2.0-i586-3.txz: Rebuilt.
l/raptor2-2.0.15-i586-5.txz: Rebuilt.
l/rasqal-0.9.33-i586-3.txz: Rebuilt.
l/readline-7.0.003-i586-2.txz: Rebuilt.
l/redland-1.0.17-i586-4.txz: Rebuilt.
l/sbc-1.3-i586-2.txz: Rebuilt.
l/sdl-1.2.15-i586-7.txz: Rebuilt.
l/seamonkey-solibs-2.49.2-i586-2.txz: Rebuilt.
l/serf-1.3.9-i586-2.txz: Rebuilt.
l/sg3_utils-1.42-i586-2.txz: Rebuilt.
l/shared-desktop-ontologies-0.11.0-i586-2.txz: Rebuilt.
l/shared-mime-info-1.9-i586-2.txz: Rebuilt.
l/sip-4.19.8-i586-2.txz: Rebuilt.
l/slang-2.3.2-i586-3.txz: Rebuilt.
l/slang1-1.4.9-i586-2.txz: Rebuilt.
l/soprano-2.9.4-i586-2.txz: Rebuilt.
l/speex-1.2.0-i586-2.txz: Rebuilt.
l/speexdsp-1.2rc3-i586-2.txz: Rebuilt.
l/startup-notification-0.12-i586-3.txz: Rebuilt.
l/strigi-0.7.8-i586-4.txz: Rebuilt.
l/svgalib-1.9.25-i586-4.txz: Rebuilt.
l/system-config-printer-1.5.11-i586-3.txz: Rebuilt.
l/t1lib-5.1.2-i586-4.txz: Rebuilt.
l/taglib-1.11.1-i586-3.txz: Rebuilt.
l/taglib-extras-1.0.1-i586-2.txz: Rebuilt.
l/talloc-2.1.13-i586-1.txz: Upgraded.
l/tdb-1.3.15-i586-2.txz: Rebuilt.
l/tevent-0.9.36-i586-2.txz: Rebuilt.
l/urwid-1.0.3-i586-3.txz: Rebuilt.
l/utf8proc-2.1.0-i586-1.txz: Added.
l/v4l-utils-1.14.2-i586-2.txz: Rebuilt.
l/virtuoso-ose-6.1.8-i586-8.txz: Rebuilt.
l/vte-0.52.1-i586-2.txz: Rebuilt.
l/wavpack-5.1.0-i586-2.txz: Rebuilt.
l/xapian-core-1.4.5-i586-2.txz: Rebuilt.
l/zlib-1.2.11-i586-2.txz: Rebuilt.
n/ModemManager-1.6.12-i586-2.txz: Rebuilt.
n/NetworkManager-1.10.6-i586-3.txz: Rebuilt.
n/alpine-2.21-i586-2.txz: Rebuilt.
n/autofs-5.1.4-i586-2.txz: Rebuilt.
n/biff+comsat-0.17-i586-2.txz: Rebuilt.
n/bind-9.11.3-i586-2.txz: Rebuilt.
n/bluez-5.49-i586-3.txz: Rebuilt.
n/bluez-firmware-1.2-i586-2.txz: Rebuilt.
n/bootp-2.4.3-i586-3.txz: Rebuilt.
n/bridge-utils-1.5-i586-2.txz: Rebuilt.
n/bsd-finger-0.17-i586-3.txz: Rebuilt.
n/cifs-utils-6.7-i586-2.txz: Rebuilt.
n/conntrack-tools-1.4.4-i586-2.txz: Rebuilt.
n/crda-3.18-i586-6.txz: Rebuilt.
n/curl-7.59.0-i586-3.txz: Rebuilt.
n/cyrus-sasl-2.1.26-i586-4.txz: Rebuilt.
n/dhcp-4.4.1-i586-2.txz: Rebuilt.
n/dhcpcd-7.0.3-i586-2.txz: Rebuilt.
n/dnsmasq-2.79-i586-2.txz: Rebuilt.
n/dovecot-2.3.1-i586-3.txz: Rebuilt.
n/ebtables-2.0.10-i586-2.txz: Rebuilt.
n/elm-2.5.8-i586-5.txz: Rebuilt.
n/epic5-2.0.1-i586-4.txz: Rebuilt.
n/ethtool-4.16-i586-1.txz: Upgraded.
n/fetchmail-6.3.26-i586-3.txz: Rebuilt.
n/getmail-5.6-i586-2.txz: Rebuilt.
n/gnupg-1.4.22-i586-2.txz: Rebuilt.
n/gnupg2-2.2.6-i586-2.txz: Rebuilt.
n/gnutls-3.6.2-i586-2.txz: Rebuilt.
n/gpa-0.9.10-i586-2.txz: Rebuilt.
n/gpgme-1.10.0-i586-2.txz: Rebuilt.
n/htdig-3.2.0b6-i586-5.txz: Rebuilt.
n/httpd-2.4.33-i586-3.txz: Rebuilt.
n/icmpinfo-1.11-i586-3.txz: Rebuilt.
n/iftop-1.0pre4-i586-2.txz: Rebuilt.
n/inetd-1.79s-i586-11.txz: Rebuilt.
n/iproute2-4.16.0-i586-2.txz: Rebuilt.
n/ipset-6.38-i586-1.txz: Upgraded.
n/iptables-1.6.2-i586-2.txz: Rebuilt.
n/iptraf-ng-1.1.4-i586-3.txz: Rebuilt.
n/iputils-s20140519-i586-2.txz: Rebuilt.
n/irssi-1.1.1-i586-2.txz: Rebuilt.
n/iw-4.14-i586-2.txz: Rebuilt.
n/lftp-4.8.3-i586-2.txz: Rebuilt.
n/libassuan-2.5.1-i586-2.txz: Rebuilt.
n/libgcrypt-1.8.2-i586-2.txz: Rebuilt.
n/libgpg-error-1.29-i586-2.txz: Rebuilt.
n/libksba-1.3.5-i586-2.txz: Rebuilt.
n/libmbim-1.16.0-i586-2.txz: Rebuilt.
n/libmilter-8.15.2-i586-2.txz: Rebuilt.
n/libmnl-1.0.4-i586-3.txz: Rebuilt.
n/libndp-1.6-i586-2.txz: Rebuilt.
n/libnetfilter_acct-1.0.3-i586-2.txz: Rebuilt.
n/libnetfilter_conntrack-1.0.6-i586-2.txz: Rebuilt.
n/libnetfilter_cthelper-1.0.0-i586-2.txz: Rebuilt.
n/libnetfilter_cttimeout-1.0.0-i586-2.txz: Rebuilt.
n/libnetfilter_log-1.0.1-i586-2.txz: Rebuilt.
n/libnetfilter_queue-1.0.3-i586-2.txz: Rebuilt.
n/libnfnetlink-1.0.1-i586-2.txz: Rebuilt.
n/libnftnl-1.0.9-i586-2.txz: Rebuilt.
n/libqmi-1.20.0-i586-2.txz: Rebuilt.
n/libtirpc-1.0.3-i586-2.txz: Rebuilt.
n/links-2.14-i586-3.txz: Rebuilt.
n/lynx-2.8.9dev.16-i586-1.txz: Upgraded.
n/mailx-12.5-i586-3.txz: Rebuilt.
n/mcabber-1.0.5-i586-2.txz: Rebuilt.
n/metamail-2.7-i586-7.txz: Rebuilt.
n/mobile-broadband-provider-info-20170310-i586-2.txz: Rebuilt.
n/mtr-0.92-i586-2.txz: Rebuilt.
n/mutt-1.9.5-i586-1.txz: Upgraded.
n/nc-1.10-i586-2.txz: Rebuilt.
n/ncftp-3.2.6-i586-2.txz: Rebuilt.
n/net-snmp-5.7.3-i586-7.txz: Rebuilt.
n/net-tools-20170208_479bb4a-i586-2.txz: Rebuilt.
n/netatalk-2.2.3-i586-7.txz: Rebuilt.
n/netdate-bsd4-i586-2.txz: Rebuilt.
n/netkit-bootparamd-0.17-i586-3.txz: Rebuilt.
n/netkit-ftp-0.17-i586-4.txz: Rebuilt.
n/netkit-ntalk-0.17-i586-5.txz: Rebuilt.
n/netkit-routed-0.17-i586-2.txz: Rebuilt.
n/netkit-rsh-0.17-i586-2.txz: Rebuilt.
n/netkit-rusers-0.17-i586-2.txz: Rebuilt.
n/netkit-rwall-0.17-i586-2.txz: Rebuilt.
n/netkit-rwho-0.17-i586-3.txz: Rebuilt.
n/netkit-timed-0.17-i586-2.txz: Rebuilt.
n/netpipes-4.2-i586-2.txz: Rebuilt.
n/nettle-3.4-i586-2.txz: Rebuilt.
n/netwatch-1.3.1_2-i586-3.txz: Rebuilt.
n/netwrite-0.17-i586-2.txz: Rebuilt.
n/newspost-2.1.1-i586-2.txz: Rebuilt.
n/nfacct-1.0.2-i586-2.txz: Rebuilt.
n/nfs-utils-2.3.1-i586-2.txz: Rebuilt.
n/nftables-0.8.2-i586-2.txz: Rebuilt.
n/nghttp2-1.31.1-i586-1.txz: Upgraded.
n/nmap-7.70-i586-2.txz: Rebuilt.
n/nn-6.7.3-i586-5.txz: Rebuilt.
n/npth-1.5-i586-2.txz: Rebuilt.
n/ntp-4.2.8p11-i586-2.txz: Rebuilt.
n/obexftp-0.24.2-i586-3.txz: Rebuilt.
n/openldap-client-2.4.46-i586-2.txz: Rebuilt.
n/openobex-1.7.2-i586-2.txz: Rebuilt.
n/openssh-7.7p1-i586-3.txz: Rebuilt.
n/openssl-1.0.2o-i586-2.txz: Rebuilt.
n/openvpn-2.4.5-i586-2.txz: Rebuilt.
n/p11-kit-0.23.10-i586-2.txz: Rebuilt.
n/php-7.2.4-i586-2.txz: Rebuilt.
n/pidentd-3.0.19-i586-3.txz: Rebuilt.
n/pinentry-1.1.0-i586-2.txz: Rebuilt.
n/popa3d-1.0.3-i586-2.txz: Rebuilt.
n/postfix-3.3.0-i586-3.txz: Rebuilt.
n/ppp-2.4.7-i586-2.txz: Rebuilt.
n/procmail-3.22-i586-3.txz: Rebuilt.
n/proftpd-1.3.6-i586-3.txz: Rebuilt.
n/pssh-2.3.1-i586-3.txz: Rebuilt.
n/rdist-6.1.5-i586-3.txz: Rebuilt.
n/rp-pppoe-3.12-i586-2.txz: Rebuilt.
n/rpcbind-0.2.4-i586-4.txz: Rebuilt.
n/rsync-3.1.3-i586-2.txz: Rebuilt.
n/samba-4.7.7-i586-1.txz: Upgraded.
n/slrn-1.0.2-i586-2.txz: Rebuilt.
n/snownews-1.5.12-i586-4.txz: Rebuilt.
n/sshfs-2.10-i586-2.txz: Rebuilt.
n/stunnel-5.44-i586-2.txz: Rebuilt.
n/tcp_wrappers-7.6-i586-2.txz: Rebuilt.
n/tcpdump-4.9.2-i586-2.txz: Rebuilt.
n/telnet-0.17-i586-4.txz: Rebuilt.
n/tftp-hpa-5.2-i586-4.txz: Rebuilt.
n/tin-2.4.2-i586-3.txz: Rebuilt.
n/traceroute-2.1.0-i586-2.txz: Rebuilt.
n/ulogd-2.0.5-i586-3.txz: Rebuilt.
n/uucp-1.07-i586-2.txz: Rebuilt.
n/vlan-1.9-i586-3.txz: Rebuilt.
n/vsftpd-3.0.3-i586-4.txz: Rebuilt.
n/wget-1.19.4-i586-3.txz: Rebuilt.
n/whois-5.3.0-i586-2.txz: Rebuilt.
n/wireless_tools-29-i586-12.txz: Rebuilt.
n/wpa_supplicant-2.6-i586-4.txz: Rebuilt.
n/yptools-2.14-i586-10.txz: Rebuilt.
n/ytalk-3.3.0-i586-4.txz: Rebuilt.
t/fig2dev-3.2.7-i586-1.txz: Upgraded.
t/texlive-2017.171108-i586-5.txz: Rebuilt.
       Recompiled against poppler-0.64.0.
t/xfig-3.2.7-i586-1.txz: Upgraded.
tcl/expect-5.45.4-i586-2.txz: Rebuilt.
tcl/hfsutils-3.2.6-i586-6.txz: Rebuilt.
tcl/tcl-8.6.8-i586-3.txz: Rebuilt.
tcl/tclx-8.4.1-i586-4.txz: Rebuilt.
tcl/tix-8.4.3-i586-4.txz: Rebuilt.
tcl/tk-8.6.8-i586-2.txz: Rebuilt.
x/anthy-9100h-i586-2.txz: Rebuilt.
x/appres-1.0.5-i586-2.txz: Rebuilt.
x/bdftopcf-1.1-i586-2.txz: Rebuilt.
x/beforelight-1.0.5-i586-3.txz: Rebuilt.
x/bitmap-1.0.8-i586-3.txz: Rebuilt.
x/compiz-0.8.8-i586-5.txz: Rebuilt.
x/editres-1.0.7-i586-2.txz: Rebuilt.
x/font-util-1.3.1-i586-3.txz: Rebuilt.
x/fontconfig-2.12.6-i586-2.txz: Rebuilt.
x/fonttosfnt-1.0.4-i586-3.txz: Rebuilt.
x/freeglut-3.0.0-i586-2.txz: Rebuilt.
x/fslsfonts-1.0.5-i586-3.txz: Rebuilt.
x/fstobdf-1.0.6-i586-3.txz: Rebuilt.
x/glew-2.1.0-i586-2.txz: Rebuilt.
x/glu-9.0.0-i586-2.txz: Rebuilt.
x/iceauth-1.0.8-i586-2.txz: Rebuilt.
x/ico-1.0.5-i586-2.txz: Rebuilt.
x/imake-1.0.7-i586-3.txz: Rebuilt.
x/intel-gpu-tools-1.22-i586-2.txz: Rebuilt.
x/intel-vaapi-driver-2.1.0-i586-2.txz: Rebuilt.
x/libFS-1.0.7-i586-2.txz: Rebuilt.
x/libICE-1.0.9-i586-3.txz: Rebuilt.
x/libSM-1.2.2-i586-3.txz: Rebuilt.
x/libX11-1.6.5-i586-2.txz: Rebuilt.
x/libXScrnSaver-1.2.2-i586-3.txz: Rebuilt.
x/libXau-1.0.8-i586-3.txz: Rebuilt.
x/libXaw-1.0.13-i586-2.txz: Rebuilt.
x/libXaw3d-1.6.2-i586-4.txz: Rebuilt.
x/libXaw3dXft-1.6.2d-i586-3.txz: Rebuilt.
x/libXcm-0.5.2-i586-3.txz: Rebuilt.
x/libXcomposite-0.4.4-i586-3.txz: Rebuilt.
x/libXcursor-1.1.15-i586-2.txz: Rebuilt.
x/libXdamage-1.1.4-i586-3.txz: Rebuilt.
x/libXdmcp-1.1.2-i586-3.txz: Rebuilt.
x/libXevie-1.0.3-i586-3.txz: Rebuilt.
x/libXext-1.3.3-i586-3.txz: Rebuilt.
x/libXfixes-5.0.3-i586-2.txz: Rebuilt.
x/libXfont2-2.0.3-i586-2.txz: Rebuilt.
x/libXfontcache-1.0.5-i586-3.txz: Rebuilt.
x/libXft-2.3.2-i586-4.txz: Rebuilt.
x/libXi-1.7.9-i586-2.txz: Rebuilt.
x/libXinerama-1.1.3-i586-3.txz: Rebuilt.
x/libXmu-1.1.2-i586-3.txz: Rebuilt.
x/libXp-1.0.3-i586-3.txz: Rebuilt.
x/libXpm-3.5.12-i586-2.txz: Rebuilt.
x/libXpresent-1.0.0-i586-2.txz: Rebuilt.
x/libXrandr-1.5.1-i586-2.txz: Rebuilt.
x/libXrender-0.9.10-i586-2.txz: Rebuilt.
x/libXres-1.2.0-i586-2.txz: Rebuilt.
x/libXt-1.1.5-i586-2.txz: Rebuilt.
x/libXtst-1.2.3-i586-2.txz: Rebuilt.
x/libXv-1.0.11-i586-2.txz: Rebuilt.
x/libXvMC-1.0.10-i586-2.txz: Rebuilt.
x/libXxf86dga-1.1.4-i586-3.txz: Rebuilt.
x/libXxf86misc-1.0.3-i586-3.txz: Rebuilt.
x/libXxf86vm-1.1.4-i586-3.txz: Rebuilt.
x/libdmx-1.1.3-i586-3.txz: Rebuilt.
x/libdrm-2.4.91-i586-2.txz: Rebuilt.
x/libepoxy-1.4.3-i586-2.txz: Rebuilt.
x/libevdev-1.5.9-i586-2.txz: Rebuilt.
x/libfontenc-1.1.3-i586-2.txz: Rebuilt.
x/libhangul-0.1.0-i586-2.txz: Rebuilt.
x/libinput-1.10.4-i586-2.txz: Rebuilt.
x/libpciaccess-0.14-i586-2.txz: Rebuilt.
x/libva-2.1.0-i586-2.txz: Rebuilt.
x/libva-utils-2.1.0-i586-2.txz: Rebuilt.
x/libvdpau-1.1.1-i586-2.txz: Rebuilt.
x/libwacom-0.29-i586-2.txz: Rebuilt.
x/libxcb-1.13-i586-2.txz: Rebuilt.
x/libxkbfile-1.0.9-i586-2.txz: Rebuilt.
x/libxshmfence-1.3-i586-2.txz: Rebuilt.
x/listres-1.0.4-i586-2.txz: Rebuilt.
x/lndir-1.0.3-i586-3.txz: Rebuilt.
x/luit-1.1.1-i586-3.txz: Rebuilt.
x/m17n-lib-1.8.0-i586-2.txz: Rebuilt.
x/makedepend-1.0.5-i586-3.txz: Rebuilt.
x/mesa-18.0.1-i586-1.txz: Upgraded.
x/mkcomposecache-1.2.1-i586-3.txz: Rebuilt.
x/mkfontscale-1.1.3-i586-2.txz: Rebuilt.
x/motif-2.3.8-i586-2.txz: Rebuilt.
x/mtdev-1.1.5-i586-2.txz: Rebuilt.
x/oclock-1.0.4-i586-2.txz: Rebuilt.
x/pixman-0.34.0-i586-2.txz: Rebuilt.
x/rendercheck-1.5-i586-2.txz: Rebuilt.
x/rgb-1.0.6-i586-3.txz: Rebuilt.
x/scim-1.4.17-i586-2.txz: Rebuilt.
x/scim-anthy-1.2.7-i586-2.txz: Rebuilt.
x/scim-hangul-0.4.0-i586-2.txz: Rebuilt.
x/scim-input-pad-0.1.3.1-i586-2.txz: Rebuilt.
x/scim-m17n-0.2.3-i586-2.txz: Rebuilt.
x/scim-pinyin-0.5.92-i586-2.txz: Rebuilt.
x/scim-tables-0.5.14.1-i586-2.txz: Rebuilt.
x/sessreg-1.1.1-i586-2.txz: Rebuilt.
x/setxkbmap-1.3.1-i586-2.txz: Rebuilt.
x/showfont-1.0.5-i586-3.txz: Rebuilt.
x/smproxy-1.0.6-i586-2.txz: Rebuilt.
x/transset-1.0.2-i586-2.txz: Rebuilt.
x/twm-1.0.10-i586-2.txz: Rebuilt.
x/viewres-1.0.5-i586-2.txz: Rebuilt.
x/vulkan-sdk-1.1.70.0-i586-2.txz: Rebuilt.
x/x11-skel-7.7-i586-2.txz: Rebuilt.
x/x11perf-1.6.0-i586-2.txz: Rebuilt.
x/xauth-1.0.10-i586-2.txz: Rebuilt.
x/xbacklight-1.2.2-i586-2.txz: Rebuilt.
x/xbiff-1.0.3-i586-3.txz: Rebuilt.
x/xbitmaps-1.1.2-i586-2.txz: Rebuilt.
x/xcalc-1.0.6-i586-3.txz: Rebuilt.
x/xcb-proto-1.13-i586-2.txz: Rebuilt.
x/xcb-util-0.4.0-i586-3.txz: Rebuilt.
x/xcb-util-cursor-0.1.3-i586-2.txz: Rebuilt.
x/xcb-util-errors-1.0-i586-2.txz: Rebuilt.
x/xcb-util-image-0.4.0-i586-3.txz: Rebuilt.
x/xcb-util-keysyms-0.4.0-i586-3.txz: Rebuilt.
x/xcb-util-renderutil-0.3.9-i586-3.txz: Rebuilt.
x/xcb-util-wm-0.4.1-i586-3.txz: Rebuilt.
x/xclipboard-1.1.3-i586-3.txz: Rebuilt.
x/xclock-1.0.7-i586-3.txz: Rebuilt.
x/xcm-0.5.2-i586-3.txz: Rebuilt.
x/xcmsdb-1.0.5-i586-2.txz: Rebuilt.
x/xcompmgr-1.1.7-i586-2.txz: Rebuilt.
x/xconsole-1.0.7-i586-2.txz: Rebuilt.
x/xcursorgen-1.0.6-i586-4.txz: Rebuilt.
x/xdbedizzy-1.1.0-i586-3.txz: Rebuilt.
x/xdg-user-dirs-0.15-i586-2.txz: Rebuilt.
x/xditview-1.0.4-i586-2.txz: Rebuilt.
x/xdm-1.1.11-i586-8.txz: Rebuilt.
x/xdpyinfo-1.3.2-i586-2.txz: Rebuilt.
x/xdriinfo-1.0.6-i586-2.txz: Rebuilt.
x/xedit-1.2.2-i586-3.txz: Rebuilt.
x/xev-1.2.2-i586-2.txz: Rebuilt.
x/xeyes-1.1.2-i586-2.txz: Rebuilt.
x/xf86-input-acecad-1.5.0-i586-11.txz: Rebuilt.
x/xf86-input-evdev-2.10.5-i586-2.txz: Rebuilt.
x/xf86-input-joystick-1.6.3-i586-2.txz: Rebuilt.
x/xf86-input-keyboard-1.9.0-i586-2.txz: Rebuilt.
x/xf86-input-libinput-0.27.1-i586-2.txz: Rebuilt.
x/xf86-input-mouse-1.9.2-i586-2.txz: Rebuilt.
x/xf86-input-penmount-1.5.0-i586-11.txz: Rebuilt.
x/xf86-input-synaptics-1.9.0-i586-2.txz: Rebuilt.
x/xf86-input-vmmouse-13.1.0-i586-6.txz: Rebuilt.
x/xf86-input-void-1.4.0-i586-11.txz: Rebuilt.
x/xf86-input-wacom-0.36.1-i586-2.txz: Rebuilt.
x/xf86-video-amdgpu-18.0.1-i586-2.txz: Rebuilt.
x/xf86-video-apm-1.2.5-i586-10.txz: Rebuilt.
x/xf86-video-ark-0.7.5-i586-10.txz: Rebuilt.
x/xf86-video-ast-1.1.5-i586-4.txz: Rebuilt.
x/xf86-video-ati-18.0.1-i586-2.txz: Rebuilt.
x/xf86-video-chips-1.2.7-i586-2.txz: Rebuilt.
x/xf86-video-cirrus-1.5.3-i586-4.txz: Rebuilt.
x/xf86-video-dummy-0.3.8-i586-2.txz: Rebuilt.
x/xf86-video-geode-2.11.19-i586-2.txz: Rebuilt.
x/xf86-video-glint-1.2.9-i586-2.txz: Rebuilt.
x/xf86-video-i128-1.3.6-i586-10.txz: Rebuilt.
x/xf86-video-i740-1.3.6-i586-2.txz: Rebuilt.
x/xf86-video-intel-git_20180206_aa36399c-i686-2.txz: Rebuilt.
x/xf86-video-mach64-6.9.5-i586-4.txz: Rebuilt.
x/xf86-video-mga-1.6.5-i586-2.txz: Rebuilt.
x/xf86-video-neomagic-1.2.9-i586-4.txz: Rebuilt.
x/xf86-video-nouveau-1.0.15-i586-2.txz: Rebuilt.
x/xf86-video-nv-2.1.21-i586-2.txz: Rebuilt.
x/xf86-video-openchrome-0.6.0-i586-2.txz: Rebuilt.
x/xf86-video-r128-6.10.2-i586-2.txz: Rebuilt.
x/xf86-video-rendition-4.2.6-i586-3.txz: Rebuilt.
x/xf86-video-s3-0.6.5-i586-10.txz: Rebuilt.
x/xf86-video-s3virge-1.10.7-i586-4.txz: Rebuilt.
x/xf86-video-savage-2.3.9-i586-2.txz: Rebuilt.
x/xf86-video-siliconmotion-1.7.9-i586-2.txz: Rebuilt.
x/xf86-video-sis-0.10.9-i586-2.txz: Rebuilt.
x/xf86-video-sisusb-0.9.7-i586-2.txz: Rebuilt.
x/xf86-video-tdfx-1.4.7-i586-2.txz: Rebuilt.
x/xf86-video-tga-1.2.2-i586-10.txz: Rebuilt.
x/xf86-video-trident-1.3.8-i586-2.txz: Rebuilt.
x/xf86-video-tseng-1.2.5-i586-10.txz: Rebuilt.
x/xf86-video-v4l-0.2.0-i586-15.txz: Rebuilt.
x/xf86-video-vboxvideo-1.0.0-i586-2.txz: Rebuilt.
x/xf86-video-vesa-2.4.0-i586-2.txz: Rebuilt.
x/xf86-video-vmware-13.2.1-i586-6.txz: Rebuilt.
x/xf86-video-voodoo-1.2.5-i586-11.txz: Rebuilt.
x/xf86dga-1.0.3-i586-3.txz: Rebuilt.
x/xfd-1.1.2-i586-3.txz: Rebuilt.
x/xfontsel-1.0.6-i586-2.txz: Rebuilt.
x/xfs-1.2.0-i586-2.txz: Rebuilt.
x/xfsinfo-1.0.5-i586-3.txz: Rebuilt.
x/xgamma-1.0.6-i586-2.txz: Rebuilt.
x/xgc-1.0.5-i586-2.txz: Rebuilt.
x/xhost-1.0.7-i586-2.txz: Rebuilt.
x/xinit-1.4.0-i586-2.txz: Rebuilt.
x/xinput-1.6.2-i586-2.txz: Rebuilt.
x/xkbcomp-1.4.1-i586-2.txz: Rebuilt.
x/xkbevd-1.1.4-i586-2.txz: Rebuilt.
x/xkbprint-1.0.4-i586-2.txz: Rebuilt.
x/xkbutils-1.0.4-i586-3.txz: Rebuilt.
x/xkill-1.0.5-i586-2.txz: Rebuilt.
x/xload-1.1.3-i586-2.txz: Rebuilt.
x/xlogo-1.0.4-i586-3.txz: Rebuilt.
x/xlsatoms-1.1.2-i586-2.txz: Rebuilt.
x/xlsclients-1.1.4-i586-2.txz: Rebuilt.
x/xlsfonts-1.0.6-i586-2.txz: Rebuilt.
x/xmag-1.0.6-i586-2.txz: Rebuilt.
x/xman-1.1.4-i586-3.txz: Rebuilt.
x/xmessage-1.0.5-i586-2.txz: Rebuilt.
x/xmh-1.0.3-i586-2.txz: Rebuilt.
x/xmodmap-1.0.9-i586-2.txz: Rebuilt.
x/xmore-1.0.2-i586-3.txz: Rebuilt.
x/xorg-cf-files-1.0.6-i586-3.txz: Rebuilt.
x/xorg-server-1.19.6-i586-3.txz: Rebuilt.
x/xorg-server-xephyr-1.19.6-i586-3.txz: Rebuilt.
x/xorg-server-xnest-1.19.6-i586-3.txz: Rebuilt.
x/xorg-server-xvfb-1.19.6-i586-3.txz: Rebuilt.
x/xorg-sgml-doctools-1.11-i586-3.txz: Rebuilt.
x/xorgproto-2018.4-i586-3.txz: Rebuilt.
x/xpr-1.0.5-i586-2.txz: Rebuilt.
x/xprop-1.2.3-i586-2.txz: Rebuilt.
x/xpyb-1.3.1-i586-5.txz: Rebuilt.
x/xrandr-1.5.0-i586-2.txz: Rebuilt.
x/xrdb-1.1.1-i586-2.txz: Rebuilt.
x/xrefresh-1.0.6-i586-2.txz: Rebuilt.
x/xscope-1.4.1-i586-3.txz: Rebuilt.
x/xset-1.2.4-i586-2.txz: Rebuilt.
x/xsetroot-1.1.2-i586-2.txz: Rebuilt.
x/xsm-1.0.4-i586-2.txz: Rebuilt.
x/xstdcmap-1.0.3-i586-3.txz: Rebuilt.
x/xterm-332-i586-1.txz: Upgraded.
x/xvidtune-1.0.3-i586-3.txz: Rebuilt.
x/xvinfo-1.1.3-i586-2.txz: Rebuilt.
x/xwd-1.0.7-i586-2.txz: Rebuilt.
x/xwininfo-1.1.4-i586-2.txz: Rebuilt.
x/xwud-1.0.5-i586-2.txz: Rebuilt.
xap/MPlayer-20180208-i586-3.txz: Rebuilt.
xap/audacious-3.9-i586-2.txz: Rebuilt.
xap/audacious-plugins-3.9-i586-4.txz: Rebuilt.
xap/blackbox-0.70.1-i586-8.txz: Rebuilt.
xap/blueman-2.0.5-i586-2.txz: Rebuilt.
xap/ddd-3.3.12-i586-6.txz: Rebuilt.
xap/easytag-2.4.2-i586-2.txz: Rebuilt.
xap/electricsheep-20090306-i586-5.txz: Rebuilt.
xap/fluxbox-1.3.7-i586-3.txz: Rebuilt.
xap/fvwm-2.6.7-i586-4.txz: Rebuilt.
xap/geeqie-1.4-i586-2.txz: Rebuilt.
xap/gftp-2.0.19-i586-6.txz: Rebuilt.
xap/gimp-2.8.22-i586-2.txz: Rebuilt.
xap/gkrellm-2.3.10-i586-3.txz: Rebuilt.
xap/gnuchess-6.2.5-i586-2.txz: Rebuilt.
xap/gnuplot-5.2.2-i586-2.txz: Rebuilt.
xap/gparted-0.31.0-i586-2.txz: Rebuilt.
xap/gucharmap-10.0.3-i586-2.txz: Rebuilt.
xap/gv-3.7.4-i586-2.txz: Rebuilt.
xap/hexchat-2.14.1-i586-2.txz: Rebuilt.
xap/mozilla-firefox-59.0.2-i686-2.txz: Rebuilt.
xap/mozilla-thunderbird-52.7.0-i586-2.txz: Rebuilt.
xap/network-manager-applet-1.8.10-i586-5.txz: Rebuilt.
xap/pan-0.143-i586-4.txz: Rebuilt.
xap/pavucontrol-3.0-i586-2.txz: Rebuilt.
xap/pidgin-2.13.0-i586-2.txz: Rebuilt.
xap/rdesktop-1.8.3-i586-2.txz: Rebuilt.
xap/rxvt-unicode-9.22-i586-4.txz: Rebuilt.
xap/sane-1.0.27-i586-2.txz: Rebuilt.
xap/seamonkey-2.49.2-i586-2.txz: Rebuilt.
xap/seyon-2.20c-i586-4.txz: Rebuilt.
xap/vim-gvim-8.0.1733-i586-1.txz: Upgraded.
xap/windowmaker-0.95.8-i586-2.txz: Rebuilt.
xap/x11-ssh-askpass-1.2.4.1-i586-3.txz: Rebuilt.
xap/x3270-3.3.12ga7-i586-3.txz: Rebuilt.
xap/xaos-3.6-i686-2.txz: Rebuilt.
xap/xfractint-20.04p13-i586-2.txz: Rebuilt.
xap/xgames-0.3-i586-5.txz: Rebuilt.
xap/xine-lib-1.2.9-i586-2.txz: Rebuilt.
xap/xine-ui-0.99.10-i686-2.txz: Rebuilt.
xap/xlockmore-5.54-i586-3.txz: Rebuilt.
xap/xmms-1.2.11-i586-6.txz: Rebuilt.
xap/xpaint-2.10.2-i586-2.txz: Rebuilt.
xap/xpdf-4.00-i586-3.txz: Rebuilt.
xap/xsane-0.999-i586-2.txz: Rebuilt.
xap/xscreensaver-5.39-i586-1.txz: Upgraded.
xap/xv-3.10a-i586-9.txz: Rebuilt.
xfce/Thunar-1.6.15-i586-2.txz: Rebuilt.
xfce/exo-0.12.0-i586-2.txz: Rebuilt.
xfce/garcon-0.6.1-i586-2.txz: Rebuilt.
xfce/gtk-xfce-engine-2.10.1-i586-3.txz: Rebuilt.
xfce/libxfce4ui-4.12.1-i586-3.txz: Rebuilt.
xfce/libxfce4util-4.12.1-i586-4.txz: Rebuilt.
xfce/orage-4.12.1-i586-5.txz: Rebuilt.
xfce/thunar-volman-0.8.1-i586-3.txz: Rebuilt.
xfce/tumbler-0.2.1-i586-2.txz: Rebuilt.
xfce/xfce4-appfinder-4.12.0-i586-3.txz: Rebuilt.
xfce/xfce4-clipman-plugin-1.4.2-i586-2.txz: Rebuilt.
xfce/xfce4-dev-tools-4.12.0-i586-3.txz: Rebuilt.
xfce/xfce4-notifyd-0.4.2-i586-2.txz: Rebuilt.
xfce/xfce4-panel-4.12.2-i586-2.txz: Rebuilt.
xfce/xfce4-power-manager-1.4.4-i586-5.txz: Rebuilt.
xfce/xfce4-pulseaudio-plugin-0.4.0-i586-2.txz: Rebuilt.
xfce/xfce4-screenshooter-1.8.2-i586-5.txz: Rebuilt.
xfce/xfce4-session-4.12.1-i586-3.txz: Rebuilt.
xfce/xfce4-settings-4.12.2-i586-2.txz: Rebuilt.
xfce/xfce4-systemload-plugin-1.2.1-i586-2.txz: Rebuilt.
xfce/xfce4-taskmanager-1.2.0-i586-2.txz: Rebuilt.
xfce/xfce4-terminal-0.8.7.3-i586-2.txz: Rebuilt.
xfce/xfce4-weather-plugin-0.8.10-i586-4.txz: Rebuilt.
xfce/xfconf-4.12.1-i586-2.txz: Rebuilt.
xfce/xfdesktop-4.12.4-i586-2.txz: Rebuilt.
xfce/xfwm4-4.12.4-i586-2.txz: Rebuilt.
y/bsd-games-2.13-i586-13.txz: Rebuilt.
extra/aspell-word-lists/aspell-el-0.08_0-i586-1.txz: Upgraded.
extra/aspell-word-lists/aspell-hus-0.03_1-i586-1.txz: Added.
extra/aspell-word-lists/aspell-kn-0.01_1-i586-1.txz: Added.
extra/fltk/fltk-1.3.4_2-i586-1.txz: Upgraded.
extra/mplayerplug-in/mplayerplug-in-3.55-i486-1.txz: Removed.
extra/tigervnc/tigervnc-1.8.0-i586-4.txz: Rebuilt.
Post Napisano: 20 Apr 2018, 21:08
Slackware 64-bit
Fri Apr 20 03:32:21 UTC 2018
a/kernel-generic-4.14.35-x86_64-1.txz: Upgraded.
a/kernel-huge-4.14.35-x86_64-1.txz: Upgraded.
       SQUASHFS m -> y
       Thanks to alienBOB.
a/kernel-modules-4.14.35-x86_64-1.txz: Upgraded.
d/kernel-headers-4.14.35-x86-1.txz: Upgraded.
k/kernel-source-4.14.35-noarch-1.txz: Upgraded.
       RCU_EXPERT n -> y
       +RCU_FANOUT 32
       +RCU_FANOUT_LEAF 16
       +RCU_FAST_NO_HZ y
       +RCU_NOCB_CPU y
       Thanks to alienBOB.
kde/kde-runtime-4.14.3-x86_64-7.txz: Rebuilt.
       Recompiled against gpgme-1.11.0.
kde/kdepim-4.14.10-x86_64-4.txz: Rebuilt.
kde/kdepimlibs-4.14.10-x86_64-6.txz: Rebuilt.
kde/kget-4.14.3-x86_64-5.txz: Rebuilt.
kde/kopete-4.14.3-x86_64-6.txz: Rebuilt.
l/gmime-2.6.23-x86_64-4.txz: Rebuilt.
n/gpa-0.9.10-x86_64-3.txz: Rebuilt.
n/gpgme-1.11.0-x86_64-1.txz: Upgraded.
n/mcabber-1.0.5-x86_64-3.txz: Rebuilt.
n/mutt-1.9.5-x86_64-2.txz: Rebuilt.
n/samba-4.7.7-x86_64-2.txz: Rebuilt.
x/libinput-1.10.5-x86_64-1.txz: Upgraded.
extra/fltk/fltk-1.3.4_2-x86_64-2.txz: Rebuilt.
       Fixed fltk-config. Thanks to Matteo Bernardini.
kernels/*: Upgraded.
Slackware 32-bit
a/kernel-generic-4.14.35-i586-1.txz: Upgraded.
a/kernel-generic-smp-4.14.35_smp-i686-1.txz: Upgraded.
a/kernel-huge-4.14.35-i586-1.txz: Upgraded.
       SQUASHFS m -> y
       Thanks to alienBOB.
a/kernel-huge-smp-4.14.35_smp-i686-1.txz: Upgraded.
       SQUASHFS m -> y
       Thanks to alienBOB.
a/kernel-modules-4.14.35-i586-1.txz: Upgraded.
a/kernel-modules-smp-4.14.35_smp-i686-1.txz: Upgraded.
d/kernel-headers-4.14.35_smp-x86-1.txz: Upgraded.
k/kernel-source-4.14.35_smp-noarch-1.txz: Upgraded.
       RCU_EXPERT n -> y
       +RCU_FANOUT 32
       +RCU_FANOUT_LEAF 16
       +RCU_FAST_NO_HZ y
       +RCU_NOCB_CPU y
       Thanks to alienBOB.
kde/kde-runtime-4.14.3-i586-7.txz: Rebuilt.
kde/kdepim-4.14.10-i586-4.txz: Rebuilt.
kde/kdepimlibs-4.14.10-i586-6.txz: Rebuilt.
kde/kget-4.14.3-i586-5.txz: Rebuilt.
kde/kopete-4.14.3-i586-6.txz: Rebuilt.
l/gmime-2.6.23-i586-4.txz: Rebuilt.
n/gpa-0.9.10-i586-3.txz: Rebuilt.
n/gpgme-1.11.0-i586-1.txz: Upgraded.
n/mcabber-1.0.5-i586-3.txz: Rebuilt.
n/mutt-1.9.5-i586-2.txz: Rebuilt.
n/samba-4.7.7-i586-2.txz: Rebuilt.
x/libinput-1.10.5-i586-1.txz: Upgraded.
extra/fltk/fltk-1.3.4_2-i586-2.txz: Rebuilt.
extra/linux-4.14.35-nosmp-sdk/*: Upgraded.
Post Napisano: 22 Apr 2018, 20:56
Slackware 64-bit
Sat Apr 21 17:39:25 UTC 2018
a/lvm2-2.02.177-x86_64-1.txz: Upgraded.
a/pkgtools-15.0-noarch-9.txz: Rebuilt.
       installpkg: fixed occasional lack of package size reported by the installer.
d/binutils-2.30-x86_64-3.txz: Rebuilt.
       Fixed /usr/$TARGET/lib directory. Thanks to GazL.
n/gpgme-1.11.1-x86_64-1.txz: Upgraded.
n/ppp-2.4.7-x86_64-3.txz: Rebuilt.
       Fixed rp-pppoe build. Thanks to voegelas for the bug report.
xfce/xfce4-settings-4.12.3-x86_64-1.txz: Upgraded.
Slackware 32-bit
a/lvm2-2.02.177-i586-1.txz: Upgraded.
d/binutils-2.30-i586-3.txz: Rebuilt.
n/gpgme-1.11.1-i586-1.txz: Upgraded.
n/ppp-2.4.7-i586-3.txz: Rebuilt.
xfce/xfce4-settings-4.12.3-i586-1.txz: Upgraded.
Post Napisano: 25 Apr 2018, 15:22
Slackware 64-bit
Wed Apr 25 04:38:51 UTC 2018
a/kernel-generic-4.14.36-x86_64-1.txz: Upgraded.
a/kernel-huge-4.14.36-x86_64-1.txz: Upgraded.
a/kernel-modules-4.14.36-x86_64-1.txz: Upgraded.
d/gcc-7.3.0-x86_64-3.txz: Rebuilt.
d/gcc-brig-7.3.0-x86_64-3.txz: Rebuilt.
d/gcc-g++-7.3.0-x86_64-3.txz: Rebuilt.
d/gcc-gfortran-7.3.0-x86_64-3.txz: Rebuilt.
d/gcc-gnat-7.3.0-x86_64-3.txz: Rebuilt.
       Rebuilt to fix missing shared libraries. Thanks to qunying.
d/gcc-go-7.3.0-x86_64-3.txz: Rebuilt.
d/gcc-objc-7.3.0-x86_64-3.txz: Rebuilt.
d/kernel-headers-4.14.36-x86-1.txz: Upgraded.
d/parallel-20180422-noarch-1.txz: Added.
d/perl-5.26.2-x86_64-2.txz: Rebuilt.
       Applied upstream patch to use net_buffer_length in DBD-mysql.
       Thanks to Iouri Kharon.
       Upgraded to URI-1.74.
k/kernel-source-4.14.36-noarch-1.txz: Upgraded.
l/imagemagick-6.9.9_40-x86_64-3.txz: Rebuilt.
       Really disable OpenCL. Thanks to orbea.
Mon Apr 23 22:17:42 UTC 2018
ap/gutenprint-5.2.14-x86_64-1.txz: Upgraded.
d/meson-0.46.0-x86_64-1.txz: Upgraded.
d/python-pip-10.0.1-x86_64-1.txz: Upgraded.
Slackware 32-bit
a/kernel-generic-4.14.36-i586-1.txz: Upgraded.
a/kernel-generic-smp-4.14.36_smp-i686-1.txz: Upgraded.
a/kernel-huge-4.14.36-i586-1.txz: Upgraded.
a/kernel-huge-smp-4.14.36_smp-i686-1.txz: Upgraded.
a/kernel-modules-4.14.36-i586-1.txz: Upgraded.
a/kernel-modules-smp-4.14.36_smp-i686-1.txz: Upgraded.
d/gcc-7.3.0-i586-3.txz: Rebuilt.
d/gcc-brig-7.3.0-i586-3.txz: Rebuilt.
d/gcc-g++-7.3.0-i586-3.txz: Rebuilt.
d/gcc-gfortran-7.3.0-i586-3.txz: Rebuilt.
d/gcc-gnat-7.3.0-i586-3.txz: Rebuilt.
d/gcc-go-7.3.0-i586-3.txz: Rebuilt.
d/gcc-objc-7.3.0-i586-3.txz: Rebuilt.
d/kernel-headers-4.14.36_smp-x86-1.txz: Upgraded.
d/perl-5.26.2-i586-2.txz: Rebuilt.
k/kernel-source-4.14.36_smp-noarch-1.txz: Upgraded.
l/imagemagick-6.9.9_40-i586-3.txz: Rebuilt.
extra/linux-4.14.36-nosmp-sdk/*: Upgraded.
ap/gutenprint-5.2.14-i586-1.txz: Upgraded.
d/meson-0.46.0-i586-1.txz: Upgraded.
d/python-pip-10.0.1-i586-1.txz: Upgraded.
Post Napisano: 27 Apr 2018, 18:02
Slackware 64-bit
Fri Apr 27 03:58:48 UTC 2018
a/kernel-generic-4.14.37-x86_64-1.txz: Upgraded.
a/kernel-huge-4.14.37-x86_64-1.txz: Upgraded.
a/kernel-modules-4.14.37-x86_64-1.txz: Upgraded.
d/kernel-headers-4.14.37-x86-1.txz: Upgraded.
k/kernel-source-4.14.37-noarch-1.txz: Upgraded.
n/openvpn-2.4.6-x86_64-1.txz: Upgraded.
       This is a security update fixing a potential double-free() in Interactive
       Service. This usually only leads to a process crash (DoS by an unprivileged
       local account) but since it could possibly lead to memory corruption if
       happening while multiple other threads are active at the same time,
       CVE-2018-9336 has been assigned to acknowledge this risk.
       https://github.com/OpenVPN/openvpn/commit/1394192b210cb3c6624a7419bcf3ff966742e79b
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-9336
n/php-7.2.5-x86_64-1.txz: Upgraded.
       https://php.net/ChangeLog-7.php#7.2.5
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-5712
Thu Apr 26 01:34:12 UTC 2018
Don't like PulseAudio? Well... I hear you. Personally, it works for me, and it
makes it easier to switch between multiple audio inputs and outputs compared
to using plain ALSA. PulseAudio got off to a rocky start in the Linux world,
where it found itself adopted before it was ready (it was even billed on its
own website at the time as "the software that currently breaks your audio").
It's my opinion that the reputation that PulseAudio acquired due to problems
back then isn't deserved any longer. If your hardware supports the sampling
rate of the audio data you're trying to play, PulseAudio will not resample it
(and if your hardware doesn't support that rate, resampling can hardly be
avoided). The increased latency has not been an issue here. Nevertheless, I
recognize that there are use cases where PulseAudio is still a detriment.
While I don't generally recommend removing PulseAudio, I'm not going to cram
it down your throat. So, if you'd like to be rid of PulseAudio, head over to
the new extra/pure-alsa-system directory and follow the instructions in the
README file there, and you'll have a PulseAudio-free pure ALSA system.
Thanks to orbea who sent me a small patch for the mpg123.SlackBuild so that
it would detect the lack of PulseAudio and not try to build in support, which
got me to thinking about all of this. Cheers! :-)
a/btrfs-progs-v4.16.1-x86_64-1.txz: Upgraded.
kde/kopete-4.14.3-x86_64-7.txz: Rebuilt.
       Dropped obsolete wlm (libmsn) protocol. Thanks to alienBOB.
l/libmsn-4.2.1-x86_64-3.txz: Removed.
l/poppler-data-0.4.9-noarch-1.txz: Upgraded.
extra/pure-alsa-system/MPlayer-20180208-x86_64-3_alsa.txz: Rebuilt.
extra/pure-alsa-system/alsa-lib-1.1.6-x86_64-3_alsa.txz: Rebuilt.
extra/pure-alsa-system/alsa-plugins-1.1.6-x86_64-2_alsa.txz: Rebuilt.
extra/pure-alsa-system/audacious-plugins-3.9-x86_64-4_alsa.txz: Rebuilt.
extra/pure-alsa-system/ffmpeg-3.4.2-x86_64-2_alsa.txz: Rebuilt.
extra/pure-alsa-system/fluidsynth-1.1.10-x86_64-2_alsa.txz: Rebuilt.
extra/pure-alsa-system/gst-plugins-good-1.14.0-x86_64-2_alsa.txz: Rebuilt.
extra/pure-alsa-system/gst-plugins-good0-0.10.31-x86_64-3_alsa.txz: Rebuilt.
extra/pure-alsa-system/kde-runtime-4.14.3-x86_64-7_alsa.txz: Rebuilt.
extra/pure-alsa-system/kmix-4.14.3-x86_64-4_alsa.txz: Rebuilt.
extra/pure-alsa-system/libao-1.2.2-x86_64-2_alsa.txz: Rebuilt.
extra/pure-alsa-system/libcanberra-0.30-x86_64-6_alsa.txz: Rebuilt.
extra/pure-alsa-system/mpg123-1.25.10-x86_64-2_alsa.txz: Rebuilt.
extra/pure-alsa-system/phonon-4.8.3-x86_64-3_alsa.txz: Rebuilt.
extra/pure-alsa-system/sox-14.4.2-x86_64-5_alsa.txz: Rebuilt.
extra/pure-alsa-system/xfce4-mixer-4.11.0-x86_64-1_alsa.txz: Upgraded.
extra/pure-alsa-system/xfce4-volumed-0.1.13-x86_64-4_alsa.txz: Rebuilt.
extra/pure-alsa-system/xine-lib-1.2.9-x86_64-2_alsa.txz: Rebuilt.
Slackware 32-bit
a/kernel-generic-4.14.37-i586-1.txz: Upgraded.
a/kernel-generic-smp-4.14.37_smp-i686-1.txz: Upgraded.
a/kernel-huge-4.14.37-i586-1.txz: Upgraded.
a/kernel-huge-smp-4.14.37_smp-i686-1.txz: Upgraded.
a/kernel-modules-4.14.37-i586-1.txz: Upgraded.
a/kernel-modules-smp-4.14.37_smp-i686-1.txz: Upgraded.
d/kernel-headers-4.14.37_smp-x86-1.txz: Upgraded.
k/kernel-source-4.14.37_smp-noarch-1.txz: Upgraded.
n/openvpn-2.4.6-i586-1.txz: Upgraded.
n/php-7.2.5-i586-1.txz: Upgraded.
extra/linux-4.14.37-nosmp-sdk/*: Upgraded.
a/btrfs-progs-v4.16.1-i586-1.txz: Upgraded.
kde/kopete-4.14.3-i586-7.txz: Rebuilt.
l/libmsn-4.2.1-i586-3.txz: Removed.
extra/pure-alsa-system/MPlayer-20180208-i586-3_alsa.txz: Rebuilt.
extra/pure-alsa-system/alsa-lib-1.1.6-i586-3_alsa.txz: Rebuilt.
extra/pure-alsa-system/alsa-plugins-1.1.6-i586-2_alsa.txz: Rebuilt.
extra/pure-alsa-system/audacious-plugins-3.9-i586-4_alsa.txz: Rebuilt.
extra/pure-alsa-system/ffmpeg-3.4.2-i586-2_alsa.txz: Rebuilt.
extra/pure-alsa-system/fluidsynth-1.1.10-i586-2_alsa.txz: Rebuilt.
extra/pure-alsa-system/gst-plugins-good-1.14.0-i586-2_alsa.txz: Rebuilt.
extra/pure-alsa-system/gst-plugins-good0-0.10.31-i586-3_alsa.txz: Rebuilt.
extra/pure-alsa-system/kde-runtime-4.14.3-i586-7_alsa.txz: Rebuilt.
extra/pure-alsa-system/kmix-4.14.3-i586-4_alsa.txz: Rebuilt.
extra/pure-alsa-system/libao-1.2.2-i586-2_alsa.txz: Rebuilt.
extra/pure-alsa-system/libcanberra-0.30-i586-6_alsa.txz: Rebuilt.
extra/pure-alsa-system/mpg123-1.25.10-i586-2_alsa.txz: Rebuilt.
extra/pure-alsa-system/phonon-4.8.3-i586-3_alsa.txz: Rebuilt.
extra/pure-alsa-system/sox-14.4.2-i586-5_alsa.txz: Rebuilt.
extra/pure-alsa-system/xfce4-mixer-4.11.0-i586-1_alsa.txz: Upgraded.
extra/pure-alsa-system/xfce4-volumed-0.1.13-i586-4_alsa.txz: Rebuilt.
extra/pure-alsa-system/xine-lib-1.2.9-i586-2_alsa.txz: Rebuilt.
Post Napisano: 29 Apr 2018, 12:34
Slackware 64-bit
Sun Apr 29 00:07:10 UTC 2018
a/glibc-zoneinfo-2018d-noarch-3.txz: Rebuilt.
       timeconfig: fixed some cosmetic issues with output spacing.
a/gpm-1.20.7-x86_64-7.txz: Rebuilt.
       setup.mouse: fixed some cosmetic issues with output spacing.
a/pkgtools-15.0-noarch-10.txz: Rebuilt.
       Fixed some cosmetic issues with output spacing.
ap/slackpkg-2.82.2-noarch-3.txz: Rebuilt.
       Edited the slack-desc to be properly formed (and more accurate).
d/doxygen-1.8.14-x86_64-3.txz: Rebuilt.
       Reverted patch that causes doxygen to segfault. Thanks to orbea.
l/libvisio-0.1.6-x86_64-4.txz: Rebuilt.
       Removed build script kludge to work around doxygen segfault.
x/mesa-18.0.2-x86_64-1.txz: Upgraded.
x/x11-skel-7.7-x86_64-3.txz: Rebuilt.
       xwmconfig: fixed some cosmetic issues with output spacing.
Fri Apr 27 23:15:41 UTC 2018
ap/nano-2.9.6-x86_64-1.txz: Upgraded.
e/emacs-25.3-x86_64-3.txz: Rebuilt.
       Provide unversioned emacs-no-x11 and emacs-with-x11 symlinks.
       Thanks to madridsecreto.
n/openssh-7.7p1-x86_64-4.txz: Rebuilt.
       Fixed tunnel forwarding with -w option. Thanks to Mario Preksavec.
x/urw-core35-fonts-otf-20170801_91edd6e_git-noarch-1.txz: Upgraded.
Slackware 32-bit
a/gpm-1.20.7-i586-7.txz: Rebuilt.
d/doxygen-1.8.14-i586-3.txz: Rebuilt.
l/libvisio-0.1.6-i586-4.txz: Rebuilt.
x/mesa-18.0.2-i586-1.txz: Upgraded.
x/x11-skel-7.7-i586-3.txz: Rebuilt.
ap/nano-2.9.6-i586-1.txz: Upgraded.
e/emacs-25.3-i586-3.txz: Rebuilt.
n/openssh-7.7p1-i586-4.txz: Rebuilt.
Post Napisano: 30 Apr 2018, 08:27
Slackware 64-bit
Mon Apr 30 01:34:10 UTC 2018
a/kernel-generic-4.14.38-x86_64-1.txz: Upgraded.
a/kernel-huge-4.14.38-x86_64-1.txz: Upgraded.
a/kernel-modules-4.14.38-x86_64-1.txz: Upgraded.
d/kernel-headers-4.14.38-x86-1.txz: Upgraded.
k/kernel-source-4.14.38-noarch-1.txz: Upgraded.
l/libwebp-1.0.0-x86_64-1.txz: Upgraded.
n/samba-4.8.1-x86_64-1.txz: Upgraded.
x/x11-skel-7.7-x86_64-4.txz: Rebuilt.
       xwmconfig: typo fix in comment. (fortune -m "only code")
Slackware 32-bit
a/kernel-generic-4.14.38-i586-1.txz: Upgraded.
a/kernel-generic-smp-4.14.38_smp-i686-1.txz: Upgraded.
a/kernel-huge-4.14.38-i586-1.txz: Upgraded.
a/kernel-huge-smp-4.14.38_smp-i686-1.txz: Upgraded.
a/kernel-modules-4.14.38-i586-1.txz: Upgraded.
a/kernel-modules-smp-4.14.38_smp-i686-1.txz: Upgraded.
d/kernel-headers-4.14.38_smp-x86-1.txz: Upgraded.
k/kernel-source-4.14.38_smp-noarch-1.txz: Upgraded.
l/libwebp-1.0.0-i586-1.txz: Upgraded.
n/samba-4.8.1-i586-1.txz: Upgraded.
x/x11-skel-7.7-i586-4.txz: Rebuilt.
extra/linux-4.14.38-nosmp-sdk/*: Upgraded.
isolinux/initrd.img: Rebuilt.
Post Napisano: 01 May 2018, 19:27
Slackware 64-bit
Mon Apr 30 22:35:43 UTC 2018
a/xz-5.2.4-x86_64-1.txz: Upgraded.
ap/sudo-1.8.23-x86_64-1.txz: Upgraded.
l/libwmf-0.2.8.4-x86_64-8.txz: Rebuilt.
       Patched denial of service and possible execution of arbitrary code
       security issues.
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2004-0941
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2006-3376
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2007-0455
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2007-2756
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2007-3472
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2007-3473
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2007-3477
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2009-3546
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-0848
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-4588
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-4695
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-4696
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-10167
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-10168
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-9011
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-9317
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-6362
       Symlink to system Type1 fonts.
l/libwmf-docs-0.2.8.4-noarch-7.txz: Removed.
       There's no good reason to split this package.
xap/mozilla-firefox-59.0.3-x86_64-1.txz: Upgraded.
       https://www.mozilla.org/security/known-vulnerabilities/firefox.html
Slackware 32-bit
a/xz-5.2.4-i586-1.txz: Upgraded.
ap/sudo-1.8.23-i586-1.txz: Upgraded.
l/libwmf-0.2.8.4-i586-8.txz: Rebuilt.
       security issues.
xap/mozilla-firefox-59.0.3-i686-1.txz: Upgraded.
