Novosti u *current* -u
Post Napisano: 06 Feb 2019, 17:41
Slackware 64-bit
Wed Feb 6 00:29:25 UTC 2019
ap/linuxdoc-tools-0.9.73-x86_64-1.txz: Upgraded.
       Upgraded to gtk-doc-1.29.
       Upgraded to asciidoc-8.6.10.
       Upgraded to perl-XML-SAX-1.00.
       Thanks to Stuart Winter.
d/meson-0.49.2-x86_64-1.txz: Upgraded.
d/python-setuptools-40.8.0-x86_64-1.txz: Upgraded.
d/slacktrack-2.19-x86_64-1.txz: Upgraded.
l/imagemagick-6.9.10_26-x86_64-1.txz: Upgraded.
n/dovecot-2.3.4.1-x86_64-1.txz: Upgraded.
       This update addresses security issues:
       CVE-2019-3814: If imap/pop3/managesieve/submission client has trusted
       certificate with missing username field (ssl_cert_username_field), under
       some configurations Dovecot mistakenly trusts the username provided via
       authentication instead of failing.
       ssl_cert_username_field setting was ignored with external SMTP AUTH,
       because none of the MTAs (Postfix, Exim) currently send the cert_username
       field. This may have allowed users with trusted certificate to specify any
       username in the authentication. This bug didn't affect Dovecot's
       Submission service.
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-3814
Slackware 32-bit
ap/linuxdoc-tools-0.9.73-i586-1.txz: Upgraded.
d/meson-0.49.2-i586-1.txz: Upgraded.
d/python-setuptools-40.8.0-i586-1.txz: Upgraded.
d/slacktrack-2.19-i586-1.txz: Upgraded.
l/imagemagick-6.9.10_26-i586-1.txz: Upgraded.
n/dovecot-2.3.4.1-i586-1.txz: Upgraded.
       Submission service.
Post Napisano: 07 Feb 2019, 01:05
Slackware 64-bit
Wed Feb 6 22:44:32 UTC 2019
a/hwdata-0.320-noarch-1.txz: Upgraded.
a/kernel-generic-4.19.20-x86_64-1.txz: Upgraded.
a/kernel-huge-4.19.20-x86_64-1.txz: Upgraded.
a/kernel-modules-4.19.20-x86_64-1.txz: Upgraded.
a/mcelog-162-x86_64-1.txz: Upgraded.
d/kernel-headers-4.19.20-x86-1.txz: Upgraded.
d/opencl-headers-2.2-noarch-2.txz: Rebuilt.
       Don't trigger "#pragma message" in cl_version.h when falling back on a
       default version of OpenCL to target. Applications such as ffmpeg detect
       this as an error and fail to compile.
k/kernel-source-4.19.20-noarch-1.txz: Upgraded.
l/ffmpeg-3.4.5-x86_64-2.txz: Rebuilt.
       Recompiled against libvpx-1.8.0.
       Reenabled libsmbclient support.
l/gst-plugins-good-1.14.4-x86_64-2.txz: Rebuilt.
l/libvpx-1.8.0-x86_64-1.txz: Upgraded.
n/curl-7.64.0-x86_64-1.txz: Upgraded.
       This release fixes the following security issues:
       NTLM type-2 out-of-bounds buffer read.
       NTLMv2 type-3 header stack buffer overflow.
       SMTP end-of-response out-of-bounds read.
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-16890
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-3822
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-3823
n/samba-4.9.4-x86_64-2.txz: Rebuilt.
       Added time.h to libsmbclient.h to fix ffmpeg compatibility.
       Thanks to USUARIONUEVO.
xap/xine-lib-1.2.9-x86_64-4.txz: Rebuilt.
isolinux/initrd.img: Rebuilt.
kernels/*: Upgraded.
Slackware 32-bit
a/kernel-generic-4.19.20-i586-1.txz: Upgraded.
a/kernel-generic-smp-4.19.20_smp-i686-1.txz: Upgraded.
a/kernel-huge-4.19.20-i586-1.txz: Upgraded.
a/kernel-huge-smp-4.19.20_smp-i686-1.txz: Upgraded.
a/kernel-modules-4.19.20-i586-1.txz: Upgraded.
a/kernel-modules-smp-4.19.20_smp-i686-1.txz: Upgraded.
a/mcelog-162-i586-1.txz: Upgraded.
d/kernel-headers-4.19.20_smp-x86-1.txz: Upgraded.
k/kernel-source-4.19.20_smp-noarch-1.txz: Upgraded.
l/ffmpeg-3.4.5-i586-2.txz: Rebuilt.
l/gst-plugins-good-1.14.4-i586-2.txz: Rebuilt.
l/libvpx-1.8.0-i586-1.txz: Upgraded.
n/curl-7.64.0-i586-1.txz: Upgraded.
n/samba-4.9.4-i586-2.txz: Rebuilt.
xap/xine-lib-1.2.9-i586-4.txz: Rebuilt.
extra/linux-4.19.20-nosmp-sdk/*: Upgraded.
Post Napisano: 08 Feb 2019, 10:25
Slackware 64-bit
Thu Feb 7 22:28:19 UTC 2019
n/php-7.2.15-x86_64-1.txz: Upgraded.
xap/network-manager-applet-1.8.20-x86_64-1.txz: Upgraded.
extra/pure-alsa-system/ffmpeg-3.4.5-x86_64-2_alsa.txz: Rebuilt.
extra/pure-alsa-system/gst-plugins-good-1.14.4-x86_64-2_alsa.txz: Rebuilt.
extra/pure-alsa-system/xine-lib-1.2.9-x86_64-4_alsa.txz: Rebuilt.
pasture/php-5.6.40-x86_64-1.txz: Upgraded.
       Several security bugs have been fixed in this release:
       GD:
       Fixed bug #77269 (efree() on uninitialized Heap data in imagescale leads
       to use-after-free).
       Fixed bug #77270 (imagecolormatch Out Of Bounds Write on Heap).
       Mbstring:
       Fixed bug #77370 (Buffer overflow on mb regex functions - fetch_token).
       Fixed bug #77371 (heap buffer overflow in mb regex functions -
       compile_string_node).
       Fixed bug #77381 (heap buffer overflow in multibyte match_at).
       Fixed bug #77382 (heap buffer overflow due to incorrect length in
       expand_case_fold_string).
       Fixed bug #77385 (buffer overflow in fetch_token).
       Fixed bug #77394 (Buffer overflow in multibyte case folding - unicode).
       Fixed bug #77418 (Heap overflow in utf32be_mbc_to_code).
       Phar:
       Fixed bug #77247 (heap buffer overflow in phar_detect_phar_fname_ext).
       Xmlrpc:
       Fixed bug #77242 (heap out of bounds read in xmlrpc_decode()).
       Fixed bug #77380 (Global out of bounds read in xmlrpc base64 code).
       https://php.net/ChangeLog-5.php#5.6.40
Slackware 32-bit
n/php-7.2.15-i586-1.txz: Upgraded.
xap/network-manager-applet-1.8.20-i586-1.txz: Upgraded.
extra/pure-alsa-system/ffmpeg-3.4.5-i586-2_alsa.txz: Rebuilt.
extra/pure-alsa-system/gst-plugins-good-1.14.4-i586-2_alsa.txz: Rebuilt.
extra/pure-alsa-system/xine-lib-1.2.9-i586-4_alsa.txz: Rebuilt.
pasture/php-5.6.40-i586-1.txz: Upgraded.
       GD:
       to use-after-free).
       Mbstring:
       Phar:
       Xmlrpc:
Post Napisano: 11 Feb 2019, 18:58
Slackware 64-bit
Sun Feb 10 20:55:14 UTC 2019
d/python-pip-19.0.2-x86_64-1.txz: Upgraded.
l/imagemagick-6.9.10_27-x86_64-1.txz: Upgraded.
x/xf86-video-apm-1.3.0-x86_64-1.txz: Upgraded.
x/xf86-video-s3virge-1.11.0-x86_64-1.txz: Upgraded.
Sat Feb 9 22:46:17 UTC 2019
a/kmod-26-x86_64-1.txz: Upgraded.
d/Cython-0.29.5-x86_64-1.txz: Upgraded.
l/libidn2-2.1.1a-x86_64-1.txz: Upgraded.
Fri Feb 8 22:04:46 UTC 2019
a/aaa_elflibs-15.0-x86_64-5.txz: Rebuilt.
       Upgraded: libglib-2.0.so.0.5800.3, libgmodule-2.0.so.0.5800.3,
       libgobject-2.0.so.0.5800.3, libgthread-2.0.so.0.5800.3, libidn2.so.0.3.5,
       libmpfr.so.6.0.2, libtdb.so.1.3.17
       Removed: libidn2.so.4.0.0
ap/sqlite-3.27.1-x86_64-1.txz: Upgraded.
l/libdvdread-6.0.1-x86_64-1.txz: Upgraded.
l/libidn2-2.1.1-x86_64-1.txz: Upgraded.
       This reverted back to .so.0 as the previous bump was apparently a mistake.
l/libpsl-0.20.2-x86_64-3.txz: Rebuilt.
       Recompiled against libidn2-2.1.1.
n/bind-9.12.3_P1-x86_64-3.txz: Rebuilt.
n/curl-7.64.0-x86_64-2.txz: Rebuilt.
n/dhcpcd-7.1.1-x86_64-1.txz: Upgraded.
n/dnsmasq-2.80-x86_64-3.txz: Rebuilt.
n/getmail-5.9-x86_64-1.txz: Upgraded.
n/gnutls-3.6.6-x86_64-2.txz: Rebuilt.
n/iputils-20180629-x86_64-3.txz: Rebuilt.
n/lftp-4.8.4-x86_64-3.txz: Rebuilt.
n/s-nail-14.9.11-x86_64-3.txz: Rebuilt.
n/wget-1.20.1-x86_64-3.txz: Rebuilt.
n/whois-5.4.1-x86_64-2.txz: Rebuilt.
x/ttf-tlwg-0.7.1-noarch-1.txz: Upgraded.
xfce/xfwm4-4.12.5-x86_64-1.txz: Upgraded.
Slackware 32-bit
d/python-pip-19.0.2-i586-1.txz: Upgraded.
l/imagemagick-6.9.10_27-i586-1.txz: Upgraded.
x/xf86-video-apm-1.3.0-i586-1.txz: Upgraded.
x/xf86-video-s3virge-1.11.0-i586-1.txz: Upgraded.
a/kmod-26-i586-1.txz: Upgraded.
d/Cython-0.29.5-i586-1.txz: Upgraded.
l/libidn2-2.1.1a-i586-1.txz: Upgraded.
a/aaa_elflibs-15.0-i586-5.txz: Rebuilt.
ap/sqlite-3.27.1-i586-1.txz: Upgraded.
l/libdvdread-6.0.1-i586-1.txz: Upgraded.
l/libidn2-2.1.1-i586-1.txz: Upgraded.
l/libpsl-0.20.2-i586-3.txz: Rebuilt.
n/bind-9.12.3_P1-i586-3.txz: Rebuilt.
n/curl-7.64.0-i586-2.txz: Rebuilt.
n/dhcpcd-7.1.1-i586-1.txz: Upgraded.
n/dnsmasq-2.80-i586-3.txz: Rebuilt.
n/getmail-5.9-i586-1.txz: Upgraded.
n/gnutls-3.6.6-i586-2.txz: Rebuilt.
n/iputils-20180629-i586-3.txz: Rebuilt.
n/lftp-4.8.4-i586-3.txz: Rebuilt.
n/s-nail-14.9.11-i586-3.txz: Rebuilt.
n/wget-1.20.1-i586-3.txz: Rebuilt.
n/whois-5.4.1-i586-2.txz: Rebuilt.
xfce/xfwm4-4.12.5-i586-1.txz: Upgraded.
Post Napisano: 14 Feb 2019, 22:02
Slackware 64-bit
Wed Feb 13 23:01:59 UTC 2019
l/giflib-5.1.6-x86_64-1.txz: Upgraded.
n/getmail-5.11-x86_64-1.txz: Upgraded.
x/xterm-344-x86_64-1.txz: Upgraded.
xap/mozilla-firefox-60.5.1esr-x86_64-1.txz: Upgraded.
       https://www.mozilla.org/en-US/security/advisories/mfsa2019-05/
       https://www.mozilla.org/en-US/security/advisories/mfsa2019-05/#CVE-2018-18356
       https://www.mozilla.org/en-US/security/advisories/mfsa2019-05/#CVE-2019-5785
       https://www.mozilla.org/en-US/security/advisories/mfsa2019-05/#CVE-2018-18335
Wed Feb 13 00:22:29 UTC 2019
a/kernel-firmware-20190212_28f5f7d-noarch-1.txz: Upgraded.
a/kernel-generic-4.19.21-x86_64-1.txz: Upgraded.
a/kernel-huge-4.19.21-x86_64-1.txz: Upgraded.
a/kernel-modules-4.19.21-x86_64-1.txz: Upgraded.
ap/lxc-2.0.9_d3a03247-x86_64-1.txz: Upgraded.
       This update fixes a security issue where a malicious privileged container
       could overwrite the host binary and thus gain root-level code execution on
       the host. As the LXC project considers privileged containers to be unsafe
       no CVE has been assigned for this issue for LXC. To prevent this attack,
       LXC has been patched to create a temporary copy of the calling binary
       itself when it starts or attaches to containers. To do this LXC creates an
       anonymous, in-memory file using the memfd_create() system call and copies
       itself into the temporary in-memory file, which is then sealed to prevent
       further modifications. LXC then executes this sealed, in-memory file
       instead of the original on-disk binary.
       https://seclists.org/oss-sec/2019/q1/119
d/kernel-headers-4.19.21-x86-1.txz: Upgraded.
k/kernel-source-4.19.21-noarch-1.txz: Upgraded.
l/libbluray-1.1.0-x86_64-1.txz: Upgraded.
l/libcap-2.26-x86_64-2.txz: Rebuilt.
       Don't ship static library.
l/xapian-core-1.4.10-x86_64-1.txz: Upgraded.
n/gnupg2-2.2.13-x86_64-1.txz: Upgraded.
n/irssi-1.2.0-x86_64-1.txz: Upgraded.
n/libassuan-2.5.3-x86_64-1.txz: Upgraded.
x/bitmap-1.0.9-x86_64-1.txz: Upgraded.
x/libXau-1.0.9-x86_64-1.txz: Upgraded.
x/pixman-0.38.0-x86_64-1.txz: Upgraded.
Slackware 32-bit
l/giflib-5.1.6-i586-1.txz: Upgraded.
n/getmail-5.11-i586-1.txz: Upgraded.
x/xterm-344-i586-1.txz: Upgraded.
xap/mozilla-firefox-60.5.1esr-i686-1.txz: Upgraded.
a/kernel-generic-4.19.21-i586-1.txz: Upgraded.
a/kernel-generic-smp-4.19.21_smp-i686-1.txz: Upgraded.
a/kernel-huge-4.19.21-i586-1.txz: Upgraded.
a/kernel-huge-smp-4.19.21_smp-i686-1.txz: Upgraded.
a/kernel-modules-4.19.21-i586-1.txz: Upgraded.
a/kernel-modules-smp-4.19.21_smp-i686-1.txz: Upgraded.
ap/lxc-2.0.9_d3a03247-i586-1.txz: Upgraded.
d/kernel-headers-4.19.21_smp-x86-1.txz: Upgraded.
k/kernel-source-4.19.21_smp-noarch-1.txz: Upgraded.
l/libbluray-1.1.0-i586-1.txz: Upgraded.
l/libcap-2.26-i586-2.txz: Rebuilt.
l/xapian-core-1.4.10-i586-1.txz: Upgraded.
n/gnupg2-2.2.13-i586-1.txz: Upgraded.
n/irssi-1.2.0-i586-1.txz: Upgraded.
n/libassuan-2.5.3-i586-1.txz: Upgraded.
x/bitmap-1.0.9-i586-1.txz: Upgraded.
x/libXau-1.0.9-i586-1.txz: Upgraded.
x/pixman-0.38.0-i586-1.txz: Upgraded.
extra/linux-4.19.21-nosmp-sdk/*: Upgraded.
Post Napisano: 15 Feb 2019, 11:35
Slackware 64-bit
Fri Feb 15 01:22:13 UTC 2019
extra/pure-alsa-system/fluidsynth-1.1.11-x86_64-1_alsa.txz: Upgraded.
Thu Feb 14 22:45:37 UTC 2019
l/fluidsynth-1.1.11-x86_64-1.txz: Upgraded.
xap/mozilla-thunderbird-60.5.1-x86_64-1.txz: Upgraded.
       https://www.mozilla.org/en-US/thunderbird/60.5.1/releasenotes/
       https://www.mozilla.org/security/known-vulnerabilities/thunderbird.html
       https://www.mozilla.org/en-US/security/advisories/mfsa2019-06/
       https://www.mozilla.org/en-US/security/advisories/mfsa2019-06/#CVE-2018-18356
       https://www.mozilla.org/en-US/security/advisories/mfsa2019-06/#CVE-2019-5785
       https://www.mozilla.org/en-US/security/advisories/mfsa2019-06/#CVE-2018-18335
       https://www.mozilla.org/en-US/security/advisories/mfsa2019-06/#CVE-2018-18509
Slackware 32-bit
extra/pure-alsa-system/fluidsynth-1.1.11-i586-1_alsa.txz: Upgraded.
l/fluidsynth-1.1.11-i586-1.txz: Upgraded.
xap/mozilla-thunderbird-60.5.1-i686-1.txz: Upgraded.
Post Napisano: 17 Feb 2019, 17:58
Slackware 64-bit
Sun Feb 17 01:45:20 UTC 2019
a/glibc-solibs-2.29-x86_64-3.txz: Rebuilt.
ap/texinfo-6.6-x86_64-1.txz: Upgraded.
l/elfutils-0.176-x86_64-1.txz: Upgraded.
l/glibc-2.29-x86_64-3.txz: Rebuilt.
l/glibc-i18n-2.29-x86_64-3.txz: Rebuilt.
       Go back to using the glibc.locale.no-archive.diff patch rather than the new
       built-in no-archive locale target. Avoiding hardlinks is not worth 700MB of
       useless bloat. Thanks to baldzhang.
l/glibc-profile-2.29-x86_64-3.txz: Rebuilt.
l/librsvg-2.44.13-x86_64-1.txz: Upgraded.
x/xf86-video-chips-1.4.0-x86_64-1.txz: Upgraded.
x/xf86-video-tdfx-1.5.0-x86_64-1.txz: Upgraded.
Fri Feb 15 21:02:33 UTC 2019
a/kernel-firmware-20190213_710963f-noarch-1.txz: Upgraded.
a/kernel-generic-4.19.23-x86_64-1.txz: Upgraded.
a/kernel-huge-4.19.23-x86_64-1.txz: Upgraded.
a/kernel-modules-4.19.23-x86_64-1.txz: Upgraded.
d/kernel-headers-4.19.23-x86-1.txz: Upgraded.
k/kernel-source-4.19.23-noarch-1.txz: Upgraded.
x/xcursor-themes-1.0.6-noarch-1.txz: Upgraded.
Slackware 32-bit
a/glibc-solibs-2.29-i586-3.txz: Rebuilt.
ap/texinfo-6.6-i586-1.txz: Upgraded.
l/elfutils-0.176-i586-1.txz: Upgraded.
l/glibc-2.29-i586-3.txz: Rebuilt.
l/glibc-i18n-2.29-i586-3.txz: Rebuilt.
l/glibc-profile-2.29-i586-3.txz: Rebuilt.
l/librsvg-2.44.13-i586-1.txz: Upgraded.
x/xf86-video-chips-1.4.0-i586-1.txz: Upgraded.
x/xf86-video-tdfx-1.5.0-i586-1.txz: Upgraded.
a/kernel-generic-4.19.23-i586-1.txz: Upgraded.
a/kernel-generic-smp-4.19.23_smp-i686-1.txz: Upgraded.
a/kernel-huge-4.19.23-i586-1.txz: Upgraded.
a/kernel-huge-smp-4.19.23_smp-i686-1.txz: Upgraded.
a/kernel-modules-4.19.23-i586-1.txz: Upgraded.
a/kernel-modules-smp-4.19.23_smp-i686-1.txz: Upgraded.
d/kernel-headers-4.19.23_smp-x86-1.txz: Upgraded.
k/kernel-source-4.19.23_smp-noarch-1.txz: Upgraded.
extra/linux-4.19.23-nosmp-sdk/*: Upgraded.
Post Napisano: 18 Feb 2019, 23:57
Slackware 64-bit
Sun Feb 17 23:44:53 UTC 2019
ap/cups-filters-1.22.1-x86_64-1.txz: Upgraded.
y/bsd-games-2.17-x86_64-1.txz: Upgraded.
Slackware 32-bit
ap/cups-filters-1.22.1-i586-1.txz: Upgraded.
y/bsd-games-2.17-i586-1.txz: Upgraded.
Post Napisano: 21 Feb 2019, 09:21
Slackware 64-bit
Wed Feb 20 23:59:17 UTC 2019
a/kernel-generic-4.19.24-x86_64-1.txz: Upgraded.
a/kernel-huge-4.19.24-x86_64-1.txz: Upgraded.
a/kernel-modules-4.19.24-x86_64-1.txz: Upgraded.
a/kmod-26-x86_64-2.txz: Rebuilt.
       Recompiled against python3-3.7.2.
a/util-linux-2.33.1-x86_64-2.txz: Rebuilt.
ap/hplip-3.19.1-x86_64-2.txz: Rebuilt.
ap/linuxdoc-tools-0.9.73-x86_64-2.txz: Rebuilt.
ap/lxc-2.0.9_d3a03247-x86_64-2.txz: Rebuilt.
ap/rpm-4.14.2.1-x86_64-2.txz: Rebuilt.
d/Cython-0.29.5-x86_64-2.txz: Rebuilt.
d/distcc-3.3.2-x86_64-2.txz: Rebuilt.
d/gdb-8.2.1-x86_64-2.txz: Rebuilt.
d/kernel-headers-4.19.24-x86-1.txz: Upgraded.
d/llvm-7.0.1-x86_64-2.txz: Rebuilt.
d/meson-0.49.2-x86_64-2.txz: Rebuilt.
d/python-pip-19.0.2-x86_64-2.txz: Rebuilt.
d/python-setuptools-40.8.0-x86_64-2.txz: Rebuilt.
d/python3-3.7.2-x86_64-1.txz: Upgraded.
k/kernel-source-4.19.24-noarch-1.txz: Upgraded.
kde/pykde4-4.14.3-x86_64-8.txz: Rebuilt.
l/Mako-1.0.7-x86_64-3.txz: Rebuilt.
l/PyQt-4.12.1-x86_64-3.txz: Rebuilt.
l/QScintilla-2.10.8-x86_64-2.txz: Rebuilt.
l/alsa-lib-1.1.8-x86_64-2.txz: Rebuilt.
l/dbus-python-1.2.8-x86_64-2.txz: Rebuilt.
l/gexiv2-0.10.10-x86_64-2.txz: Rebuilt.
l/libcaca-0.99.beta19-x86_64-4.txz: Rebuilt.
l/libcap-ng-0.7.9-x86_64-2.txz: Rebuilt.
l/libjpeg-turbo-2.0.2-x86_64-1.txz: Upgraded.
l/libproxy-0.4.15-x86_64-3.txz: Rebuilt.
l/libwebp-1.0.2-x86_64-2.txz: Rebuilt.
l/libxml2-2.9.9-x86_64-2.txz: Rebuilt.
l/newt-0.52.20-x86_64-4.txz: Rebuilt.
l/pycairo-1.18.0-x86_64-2.txz: Rebuilt.
l/pycups-1.9.74-x86_64-2.txz: Rebuilt.
l/pycurl-7.43.0.2-x86_64-2.txz: Rebuilt.
l/pygobject-2.28.7-x86_64-3.txz: Rebuilt.
l/pygobject3-3.30.4-x86_64-2.txz: Rebuilt.
l/pyparsing-2.3.1-x86_64-2.txz: Rebuilt.
l/python-appdirs-1.4.3-x86_64-3.txz: Rebuilt.
l/python-certifi-2018.11.29-x86_64-2.txz: Rebuilt.
l/python-chardet-3.0.4-x86_64-3.txz: Rebuilt.
l/python-docutils-0.14-x86_64-3.txz: Rebuilt.
l/python-idna-2.8-x86_64-2.txz: Rebuilt.
l/python-notify2-0.3.1-x86_64-3.txz: Rebuilt.
l/python-packaging-19.0-x86_64-2.txz: Rebuilt.
l/python-pillow-5.4.1-x86_64-2.txz: Rebuilt.
l/python-requests-2.21.0-x86_64-2.txz: Rebuilt.
l/python-sane-2.8.3-x86_64-3.txz: Rebuilt.
l/python-six-1.12.0-x86_64-3.txz: Rebuilt.
l/python-urllib3-1.24.1-x86_64-2.txz: Rebuilt.
l/sip-4.19.8-x86_64-3.txz: Rebuilt.
l/system-config-printer-1.5.11-x86_64-4.txz: Rebuilt.
l/talloc-2.1.15-x86_64-2.txz: Rebuilt.
l/tdb-1.3.17-x86_64-2.txz: Rebuilt.
l/tevent-0.9.38-x86_64-2.txz: Rebuilt.
l/urwid-1.0.3-x86_64-4.txz: Rebuilt.
n/gpgme-1.12.0-x86_64-2.txz: Rebuilt.
n/obexftp-0.24.2-x86_64-4.txz: Rebuilt.
n/openvpn-2.4.7-x86_64-1.txz: Upgraded.
n/pssh-2.3.1-x86_64-4.txz: Rebuilt.
x/libfontenc-1.1.4-x86_64-1.txz: Upgraded.
x/xcalc-1.0.7-x86_64-1.txz: Upgraded.
x/xcb-proto-1.13-x86_64-3.txz: Rebuilt.
x/xclock-1.0.8-x86_64-1.txz: Upgraded.
x/xev-1.2.3-x86_64-1.txz: Upgraded.
x/xfsinfo-1.0.6-x86_64-1.txz: Upgraded.
x/xhost-1.0.8-x86_64-1.txz: Upgraded.
x/xlsatoms-1.1.3-x86_64-1.txz: Upgraded.
x/xmodmap-1.0.10-x86_64-1.txz: Upgraded.
x/xrdb-1.2.0-x86_64-1.txz: Upgraded.
x/xstdcmap-1.0.4-x86_64-1.txz: Upgraded.
x/xvinfo-1.1.4-x86_64-1.txz: Upgraded.
xap/blueman-2.0.8-x86_64-2.txz: Rebuilt.
xap/hexchat-2.14.2-x86_64-3.txz: Rebuilt.
extra/pure-alsa-system/alsa-lib-1.1.8-x86_64-2_alsa.txz: Rebuilt.
Mon Feb 18 23:59:28 UTC 2019
l/imagemagick-6.9.10_28-x86_64-1.txz: Upgraded.
x/mesa-18.3.4-x86_64-1.txz: Upgraded.
Slackware 32-bit
a/kernel-generic-4.19.24-i586-1.txz: Upgraded.
a/kernel-generic-smp-4.19.24_smp-i686-1.txz: Upgraded.
a/kernel-huge-4.19.24-i586-1.txz: Upgraded.
a/kernel-huge-smp-4.19.24_smp-i686-1.txz: Upgraded.
a/kernel-modules-4.19.24-i586-1.txz: Upgraded.
a/kernel-modules-smp-4.19.24_smp-i686-1.txz: Upgraded.
a/kmod-26-i586-2.txz: Rebuilt.
a/util-linux-2.33.1-i586-2.txz: Rebuilt.
ap/hplip-3.19.1-i586-2.txz: Rebuilt.
ap/linuxdoc-tools-0.9.73-i586-2.txz: Rebuilt.
ap/lxc-2.0.9_d3a03247-i586-2.txz: Rebuilt.
ap/rpm-4.14.2.1-i586-2.txz: Rebuilt.
d/Cython-0.29.5-i586-2.txz: Rebuilt.
d/distcc-3.3.2-i586-2.txz: Rebuilt.
d/gdb-8.2.1-i586-2.txz: Rebuilt.
d/kernel-headers-4.19.24_smp-x86-1.txz: Upgraded.
d/llvm-7.0.1-i586-2.txz: Rebuilt.
d/meson-0.49.2-i586-2.txz: Rebuilt.
d/python-pip-19.0.2-i586-2.txz: Rebuilt.
d/python-setuptools-40.8.0-i586-2.txz: Rebuilt.
d/python3-3.7.2-i586-1.txz: Upgraded.
k/kernel-source-4.19.24_smp-noarch-1.txz: Upgraded.
kde/pykde4-4.14.3-i586-8.txz: Rebuilt.
l/Mako-1.0.7-i586-3.txz: Rebuilt.
l/PyQt-4.12.1-i586-3.txz: Rebuilt.
l/QScintilla-2.10.8-i586-2.txz: Rebuilt.
l/alsa-lib-1.1.8-i586-2.txz: Rebuilt.
l/dbus-python-1.2.8-i586-2.txz: Rebuilt.
l/gexiv2-0.10.10-i586-2.txz: Rebuilt.
l/libcaca-0.99.beta19-i586-4.txz: Rebuilt.
l/libcap-ng-0.7.9-i586-2.txz: Rebuilt.
l/libjpeg-turbo-2.0.2-i586-1.txz: Upgraded.
l/libproxy-0.4.15-i586-3.txz: Rebuilt.
l/libwebp-1.0.2-i586-2.txz: Rebuilt.
l/libxml2-2.9.9-i586-2.txz: Rebuilt.
l/newt-0.52.20-i586-4.txz: Rebuilt.
l/pycairo-1.18.0-i586-2.txz: Rebuilt.
l/pycups-1.9.74-i586-2.txz: Rebuilt.
l/pycurl-7.43.0.2-i586-2.txz: Rebuilt.
l/pygobject-2.28.7-i586-3.txz: Rebuilt.
l/pygobject3-3.30.4-i586-2.txz: Rebuilt.
l/pyparsing-2.3.1-i586-2.txz: Rebuilt.
l/python-appdirs-1.4.3-i586-3.txz: Rebuilt.
l/python-certifi-2018.11.29-i586-2.txz: Rebuilt.
l/python-chardet-3.0.4-i586-3.txz: Rebuilt.
l/python-docutils-0.14-i586-3.txz: Rebuilt.
l/python-idna-2.8-i586-2.txz: Rebuilt.
l/python-notify2-0.3.1-i586-3.txz: Rebuilt.
l/python-packaging-19.0-i586-2.txz: Rebuilt.
l/python-pillow-5.4.1-i586-2.txz: Rebuilt.
l/python-requests-2.21.0-i586-2.txz: Rebuilt.
l/python-sane-2.8.3-i586-3.txz: Rebuilt.
l/python-six-1.12.0-i586-3.txz: Rebuilt.
l/python-urllib3-1.24.1-i586-2.txz: Rebuilt.
l/sip-4.19.8-i586-3.txz: Rebuilt.
l/system-config-printer-1.5.11-i586-4.txz: Rebuilt.
l/talloc-2.1.15-i586-2.txz: Rebuilt.
l/tdb-1.3.17-i586-2.txz: Rebuilt.
l/tevent-0.9.38-i586-2.txz: Rebuilt.
l/urwid-1.0.3-i586-4.txz: Rebuilt.
n/gpgme-1.12.0-i586-2.txz: Rebuilt.
n/obexftp-0.24.2-i586-4.txz: Rebuilt.
n/openvpn-2.4.7-i586-1.txz: Upgraded.
n/pssh-2.3.1-i586-4.txz: Rebuilt.
x/libfontenc-1.1.4-i586-1.txz: Upgraded.
x/xcalc-1.0.7-i586-1.txz: Upgraded.
x/xcb-proto-1.13-i586-3.txz: Rebuilt.
x/xclock-1.0.8-i586-1.txz: Upgraded.
x/xev-1.2.3-i586-1.txz: Upgraded.
x/xfsinfo-1.0.6-i586-1.txz: Upgraded.
x/xhost-1.0.8-i586-1.txz: Upgraded.
x/xlsatoms-1.1.3-i586-1.txz: Upgraded.
x/xmodmap-1.0.10-i586-1.txz: Upgraded.
x/xrdb-1.2.0-i586-1.txz: Upgraded.
x/xstdcmap-1.0.4-i586-1.txz: Upgraded.
x/xvinfo-1.1.4-i586-1.txz: Upgraded.
xap/blueman-2.0.8-i586-2.txz: Rebuilt.
xap/hexchat-2.14.2-i586-3.txz: Rebuilt.
extra/linux-4.19.24-nosmp-sdk/*: Upgraded.
extra/pure-alsa-system/alsa-lib-1.1.8-i586-2_alsa.txz: Rebuilt.
l/imagemagick-6.9.10_28-i586-1.txz: Upgraded.
x/mesa-18.3.4-i586-1.txz: Upgraded.
Post Napisano: 23 Feb 2019, 11:59
Slackware 64-bit
Sat Feb 23 03:33:52 UTC 2019
a/file-5.36-x86_64-1.txz: Upgraded.
ap/mariadb-10.3.13-x86_64-1.txz: Upgraded.
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-2510
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-2537
d/p2c-2.01-x86_64-1.txz: Upgraded.
d/python-pip-19.0.3-x86_64-1.txz: Upgraded.
l/librsvg-2.44.13-x86_64-2.txz: Rebuilt.
       Recompiled with --enable-vala=yes.
n/bind-9.12.3_P4-x86_64-1.txz: Upgraded.
xap/mozilla-firefox-60.5.2esr-x86_64-1.txz: Upgraded.
       This is a bugfix release.
       https://www.mozilla.org/en-US/firefox/60.5.2/releasenotes/
Slackware 32-bit
a/file-5.36-i586-1.txz: Upgraded.
ap/mariadb-10.3.13-i586-1.txz: Upgraded.
d/p2c-2.01-i586-1.txz: Upgraded.
d/python-pip-19.0.3-i586-1.txz: Upgraded.
l/librsvg-2.44.13-i586-2.txz: Rebuilt.
n/bind-9.12.3_P4-i586-1.txz: Upgraded.
xap/mozilla-firefox-60.5.2esr-i686-1.txz: Upgraded.
