Novosti u *current* -u
Post Napisano: 19 Feb 2020, 08:05
Slackware 64-bit
Tue Feb 18 05:20:50 UTC 2020
l/gtk+3-3.24.14-x86_64-2.txz: Rebuilt.
       Rebuilt with -DG_ENABLE_DEBUG. Thanks to Bindestreck.
       Also built with -DG_DISABLE_CAST_CHECKS and -Dbroadway_backend=true.
l/imagemagick-7.0.9_24-x86_64-1.txz: Upgraded.
n/bind-9.14.10-x86_64-2.txz: Rebuilt.
       rc.bind: make sure it works with a non-root user specified in $NAMED_OPTIONS.
       Thanks to Luigi Trovato.
n/tin-2.4.4-x86_64-1.txz: Upgraded.
xap/blackbox-0.76-x86_64-1.txz: Upgraded.
testing/packages/PAM/libcap-2.32-x86_64-1_pam.txz: Upgraded.
Mon Feb 17 21:32:15 UTC 2020
a/shadow-4.8.1-x86_64-4.txz: Rebuilt.
       Recompiled using --with-group-name-max-length=32. Thanks to Bart van der Hall.
ap/cups-filters-1.27.1-x86_64-1.txz: Upgraded.
d/git-2.25.1-x86_64-1.txz: Upgraded.
l/gtk+3-3.24.14-x86_64-1.txz: Upgraded.
l/libcap-2.32-x86_64-1.txz: Upgraded.
l/python-idna-2.9-x86_64-1.txz: Upgraded.
testing/packages/PAM/shadow-4.8.1-x86_64-4_pam.txz: Rebuilt.
Mon Feb 17 06:03:43 UTC 2020
ap/ksh93-20200131_e4fea8c5-x86_64-1.txz: Upgraded.
ap/zsh-5.8-x86_64-1.txz: Upgraded.
l/brotli-1.0.7-x86_64-1.txz: Added.
l/gmime-3.2.6-x86_64-1.txz: Upgraded.
l/hyphen-2.8.8-x86_64-1.txz: Added.
l/openal-soft-1.20.1-x86_64-1.txz: Upgraded.
       Thanks to Skaendo and Willy Sudiarto Raharjo.
l/qt5-webkit-5.212.0_alpha3-x86_64-1.txz: Added.
       Thanks to alienBOB.
l/woff2-20180531_a0d0ed7-x86_64-1.txz: Added.
n/bluez-5.53-x86_64-1.txz: Upgraded.
n/mutt-1.13.4-x86_64-1.txz: Upgraded.
n/samba-4.11.6-x86_64-3.txz: Rebuilt.
n/socat-1.7.3.4-x86_64-1.txz: Added.
n/whois-5.5.6-x86_64-1.txz: Upgraded.
testing/packages/PAM/samba-4.11.6-x86_64-3_pam.txz: Rebuilt.
       Added patches to fix joining a DC when using krb5. Looks like the patches are
       already upstreamed in the latest 4.12.0-rc. Thanks to camerabambai.
Slackware 32-bit
l/gtk+3-3.24.14-i586-2.txz: Rebuilt.
l/imagemagick-7.0.9_24-i586-1.txz: Upgraded.
n/bind-9.14.10-i586-2.txz: Rebuilt.
n/tin-2.4.4-i586-1.txz: Upgraded.
xap/blackbox-0.76-i586-1.txz: Upgraded.
testing/packages/PAM/libcap-2.32-i586-1_pam.txz: Upgraded.
a/shadow-4.8.1-i586-4.txz: Rebuilt.
ap/cups-filters-1.27.1-i586-1.txz: Upgraded.
d/git-2.25.1-i586-1.txz: Upgraded.
l/gtk+3-3.24.14-i586-1.txz: Upgraded.
l/libcap-2.32-i586-1.txz: Upgraded.
l/python-idna-2.9-i586-1.txz: Upgraded.
testing/packages/PAM/shadow-4.8.1-i586-4_pam.txz: Rebuilt.
ap/ksh93-20200131_e4fea8c5-i586-1.txz: Upgraded.
ap/zsh-5.8-i586-1.txz: Upgraded.
l/brotli-1.0.7-i586-1.txz: Added.
l/gmime-3.2.6-i586-1.txz: Upgraded.
l/hyphen-2.8.8-i586-1.txz: Added.
l/openal-soft-1.20.1-i586-1.txz: Upgraded.
l/qt5-webkit-5.212.0_alpha3-i586-1.txz: Added.
       Thanks to alienBOB.
l/woff2-20180531_a0d0ed7-i586-1.txz: Added.
n/bluez-5.53-i586-1.txz: Upgraded.
n/mutt-1.13.4-i586-1.txz: Upgraded.
n/samba-4.11.6-i586-3.txz: Rebuilt.
n/socat-1.7.3.4-i586-1.txz: Added.
n/whois-5.5.6-i586-1.txz: Upgraded.
testing/packages/PAM/samba-4.11.6-i586-3_pam.txz: Rebuilt.
Post Napisano: 21 Feb 2020, 20:30
Slackware 64
Thu Feb 20 23:40:12 UTC 2020
a/ed-1.16-x86_64-1.txz:  Upgraded.
l/gtk+3-3.24.14-x86_64-3.txz:  Rebuilt.
  Rebuilt to add wayland backend.
l/libuv-1.34.2-x86_64-1.txz:  Added.
  This is needed by bind-9.16.0.
l/qt5-5.13.2-x86_64-2.txz:  Rebuilt.
  Rebuilt to add wayland support.
  Use the system ffmpeg, not the bundled one.
n/bind-9.16.0-x86_64-1.txz:  Upgraded.
  rc.bind: don't change file ownerships in /var/named. Thanks to voegelas.
n/proftpd-1.3.6c-x86_64-1.txz:  Upgraded.
  No CVEs assigned, but this sure looks like a security issue:
  Use-after-free vulnerability in memory pools during data transfer.
x/libinput-1.15.2-x86_64-1.txz:  Upgraded.
x/xkbcomp-1.4.3-x86_64-1.txz:  Upgraded.
testing/packages/PAM/proftpd-1.3.6c-x86_64-1_pam.txz:  Upgraded.
Thu Feb 20 04:50:54 UTC 2020
a/gptfdisk-1.0.5-x86_64-1.txz:  Upgraded.
a/kernel-firmware-20200219_2277987-noarch-1.txz:  Upgraded.
a/kernel-generic-5.4.21-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.4.21-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.4.21-x86_64-1.txz:  Upgraded.
a/shadow-4.8.1-x86_64-5.txz:  Rebuilt.
a/util-linux-2.35.1-x86_64-4.txz:  Rebuilt.
ap/cdparanoia-III_10.2-x86_64-3.txz:  Rebuilt.
  Moved man page from /usr/man/jp/man1/ to /usr/man/ja/man1/. Thanks to Xsane.
  Don't ship the static libraries.
d/kernel-headers-5.4.21-x86-1.txz:  Upgraded.
k/kernel-source-5.4.21-noarch-1.txz:  Upgraded.
   SND_SOC n -> m
   SPI n -> y
   VFIO_PCI_VGA n -> y
  +ADE7854_SPI m
  +ADT7316_SPI m
  +BMC150_ACCEL_SPI m
  +BMG160_SPI m
  +BMP280_SPI m
  +FXAS21002C_SPI m
  +HTS221_SPI m
  +IIO_ST_ACCEL_SPI_3AXIS m
  +IIO_ST_GYRO_SPI_3AXIS m
  +IIO_ST_MAGN_SPI_3AXIS m
  +IIO_ST_PRESS_SPI m
  +IIO_ST_SENSORS_SPI m
  +INPUT_AD714X_SPI m
  +INPUT_ADXL34X_SPI m
  +KXSD9_SPI m
  +REGMAP_SPI m
  +SND_COMPRESS_OFFLOAD m
  +SND_DESIGNWARE_I2S m
  +SND_DESIGNWARE_PCM y
  +SND_DMAENGINE_PCM m
  +SND_HDA_EXT_CORE m
  +SND_I2S_HI6210_I2S m
  +SND_PCM_ELD y
  +SND_PCM_IEC958 y
  +SND_SIMPLE_CARD m
  +SND_SIMPLE_CARD_UTILS m
  +SND_SOC_AC97_BUS y
  +SND_SOC_AC97_CODEC m
  +SND_SOC_ACPI m
  +SND_SOC_ACPI_INTEL_MATCH m
  +SND_SOC_ADAU1761 m
  +SND_SOC_ADAU1761_I2C m
  +SND_SOC_ADAU1761_SPI m
  +SND_SOC_ADAU17X1 m
  +SND_SOC_ADAU7002 m
  +SND_SOC_ADAU_UTILS m
  +SND_SOC_AMD_ACP m
  +SND_SOC_AMD_ACP3x m
  +SND_SOC_AMD_CZ_DA7219MX98357_MACH m
  +SND_SOC_AMD_CZ_RT5645_MACH m
  +SND_SOC_BD28623 m
  +SND_SOC_COMPRESS y
  +SND_SOC_CROS_EC_CODEC m
  +SND_SOC_CS35L34 m
  +SND_SOC_CS35L35 m
  +SND_SOC_CS35L36 m
  +SND_SOC_CS42L42 m
  +SND_SOC_CS43130 m
  +SND_SOC_CX2072X m
  +SND_SOC_DA7213 m
  +SND_SOC_DA7219 m
  +SND_SOC_DMIC m
  +SND_SOC_ES7134 m
  +SND_SOC_ES7241 m
  +SND_SOC_ES8316 m
  +SND_SOC_ES8328 m
  +SND_SOC_ES8328_I2C m
  +SND_SOC_ES8328_SPI m
  +SND_SOC_GENERIC_DMAENGINE_PCM y
  +SND_SOC_HDAC_HDA m
  +SND_SOC_HDAC_HDMI m
  +SND_SOC_HDMI_CODEC m
  +SND_SOC_I2C_AND_SPI m
  +SND_SOC_INTEL_APL m
  +SND_SOC_INTEL_BDW_RT5677_MACH m
  +SND_SOC_INTEL_BROADWELL_MACH m
  +SND_SOC_INTEL_BXT_DA7219_MAX98357A_MACH m
  +SND_SOC_INTEL_BXT_RT298_MACH m
  +SND_SOC_INTEL_BYTCR_RT5640_MACH m
  +SND_SOC_INTEL_BYTCR_RT5651_MACH m
  +SND_SOC_INTEL_BYT_CHT_CX2072X_MACH m
  +SND_SOC_INTEL_BYT_CHT_DA7213_MACH m
  +SND_SOC_INTEL_BYT_CHT_ES8316_MACH m
  +SND_SOC_INTEL_BYT_CHT_NOCODEC_MACH m
  +SND_SOC_INTEL_CFL m
  +SND_SOC_INTEL_CHT_BSW_MAX98090_TI_MACH m
  +SND_SOC_INTEL_CHT_BSW_NAU8824_MACH m
  +SND_SOC_INTEL_CHT_BSW_RT5645_MACH m
  +SND_SOC_INTEL_CHT_BSW_RT5672_MACH m
  +SND_SOC_INTEL_CML_H m
  +SND_SOC_INTEL_CML_LP m
  +SND_SOC_INTEL_CNL m
  +SND_SOC_INTEL_DA7219_MAX98357A_GENERIC m
  +SND_SOC_INTEL_GLK m
  +SND_SOC_INTEL_GLK_RT5682_MAX98357A_MACH m
  +SND_SOC_INTEL_HASWELL m
  +SND_SOC_INTEL_HASWELL_MACH m
  +SND_SOC_INTEL_KBL m
  +SND_SOC_INTEL_KBL_DA7219_MAX98357A_MACH m
  +SND_SOC_INTEL_KBL_DA7219_MAX98927_MACH m
  +SND_SOC_INTEL_KBL_RT5660_MACH m
  +SND_SOC_INTEL_KBL_RT5663_MAX98927_MACH m
  +SND_SOC_INTEL_MACH y
  +SND_SOC_INTEL_SKL m
  +SND_SOC_INTEL_SKL_NAU88L25_MAX98357A_MACH m
  +SND_SOC_INTEL_SKL_NAU88L25_SSM4567_MACH m
  +SND_SOC_INTEL_SKL_RT286_MACH m
  +SND_SOC_INTEL_SKYLAKE m
  +SND_SOC_INTEL_SKYLAKE_COMMON m
  +SND_SOC_INTEL_SKYLAKE_FAMILY m
  +SND_SOC_INTEL_SKYLAKE_HDAUDIO_CODEC y
  +SND_SOC_INTEL_SKYLAKE_SSP_CLK m
  +SND_SOC_INTEL_SST m
  +SND_SOC_INTEL_SST_ACPI m
  +SND_SOC_INTEL_SST_FIRMWARE m
  +SND_SOC_INTEL_SST_TOPLEVEL y
  +SND_SOC_MAX9759 m
  +SND_SOC_MAX98088 m
  +SND_SOC_MAX98090 m
  +SND_SOC_MAX98357A m
  +SND_SOC_MAX98373 m
  +SND_SOC_MAX9867 m
  +SND_SOC_MAX98927 m
  +SND_SOC_NAU8540 m
  +SND_SOC_NAU8824 m
  +SND_SOC_NAU8825 m
  +SND_SOC_PCM1789 m
  +SND_SOC_PCM1789_I2C m
  +SND_SOC_PCM186X m
  +SND_SOC_PCM186X_I2C m
  +SND_SOC_PCM186X_SPI m
  +SND_SOC_PCM3060 m
  +SND_SOC_PCM3060_I2C m
  +SND_SOC_PCM3060_SPI m
  +SND_SOC_RL6231 m
  +SND_SOC_RL6347A m
  +SND_SOC_RT286 m
  +SND_SOC_RT298 m
  +SND_SOC_RT5640 m
  +SND_SOC_RT5645 m
  +SND_SOC_RT5651 m
  +SND_SOC_RT5660 m
  +SND_SOC_RT5663 m
  +SND_SOC_RT5670 m
  +SND_SOC_RT5677 m
  +SND_SOC_RT5677_SPI m
  +SND_SOC_RT5682 m
  +SND_SOC_SIGMADSP m
  +SND_SOC_SIGMADSP_REGMAP m
  +SND_SOC_SIMPLE_AMPLIFIER m
  +SND_SOC_SOF m
  +SND_SOC_SOF_ACPI m
  +SND_SOC_SOF_APOLLOLAKE m
  +SND_SOC_SOF_APOLLOLAKE_SUPPORT y
  +SND_SOC_SOF_BAYTRAIL m
  +SND_SOC_SOF_BAYTRAIL_SUPPORT y
  +SND_SOC_SOF_CANNONLAKE m
  +SND_SOC_SOF_CANNONLAKE_SUPPORT y
  +SND_SOC_SOF_COFFEELAKE m
  +SND_SOC_SOF_COFFEELAKE_SUPPORT y
  +SND_SOC_SOF_COMETLAKE_H m
  +SND_SOC_SOF_COMETLAKE_H_SUPPORT y
  +SND_SOC_SOF_COMETLAKE_LP m
  +SND_SOC_SOF_COMETLAKE_LP_SUPPORT y
  +SND_SOC_SOF_ELKHARTLAKE m
  +SND_SOC_SOF_ELKHARTLAKE_SUPPORT y
  +SND_SOC_SOF_GEMINILAKE m
  +SND_SOC_SOF_GEMINILAKE_SUPPORT y
  +SND_SOC_SOF_HDA m
  +SND_SOC_SOF_HDA_AUDIO_CODEC y
  +SND_SOC_SOF_HDA_COMMON m
  +SND_SOC_SOF_HDA_LINK y
  +SND_SOC_SOF_HDA_LINK_BASELINE m
  +SND_SOC_SOF_ICELAKE m
  +SND_SOC_SOF_ICELAKE_SUPPORT y
  +SND_SOC_SOF_INTEL_ACPI m
  +SND_SOC_SOF_INTEL_ATOM_HIFI_EP m
  +SND_SOC_SOF_INTEL_COMMON m
  +SND_SOC_SOF_INTEL_HIFI_EP_IPC m
  +SND_SOC_SOF_INTEL_PCI m
  +SND_SOC_SOF_INTEL_TOPLEVEL y
  +SND_SOC_SOF_MERRIFIELD m
  +SND_SOC_SOF_MERRIFIELD_SUPPORT y
  +SND_SOC_SOF_OPTIONS m
  +SND_SOC_SOF_PCI m
  +SND_SOC_SOF_PROBE_WORK_QUEUE y
  +SND_SOC_SOF_TIGERLAKE m
  +SND_SOC_SOF_TIGERLAKE_SUPPORT y
  +SND_SOC_SOF_TOPLEVEL y
  +SND_SOC_SOF_XTENSA m
  +SND_SOC_SPDIF m
  +SND_SOC_SSM4567 m
  +SND_SOC_TAS6424 m
  +SND_SOC_TDA7419 m
  +SND_SOC_TLV320AIC32X4 m
  +SND_SOC_TLV320AIC32X4_I2C m
  +SND_SOC_TLV320AIC32X4_SPI m
  +SND_SOC_TOPOLOGY y
  +SND_SOC_TS3A227E m
  +SND_SOC_TSCS42XX m
  +SND_SOC_WM8524 m
  +SND_SPI y
  +SND_SST_ATOM_HIFI2_PLATFORM m
  +SND_SST_ATOM_HIFI2_PLATFORM_ACPI m
  +SND_SST_ATOM_HIFI2_PLATFORM_PCI m
  +SND_SST_IPC m
  +SND_SST_IPC_ACPI m
  +SND_SST_IPC_PCI m
  +SPI_MASTER y
  +ST_UVIS25_SPI m
l/gegl-0.4.22-x86_64-1.txz:  Upgraded.
l/glib2-2.62.5-x86_64-1.txz:  Upgraded.
l/python-requests-2.23.0-x86_64-1.txz:  Upgraded.
n/NetworkManager-1.22.8-x86_64-1.txz:  Upgraded.
n/openssh-8.2p1-x86_64-2.txz:  Rebuilt.
n/php-7.4.3-x86_64-1.txz:  Upgraded.
  Phar: Files added to tar with Phar::buildFromIterator have
  all-access permissions.
  Phar: heap-buffer-overflow in phar_extract_file.
  Session: Null Pointer Dereference in PHP Session Upload Progress.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-7063
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-7061
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-7062
x/mesa-20.0.0-x86_64-1.txz:  Upgraded.
  Added Wayland platform support.
x/wayland-1.18.0-x86_64-1.txz:  Added.
x/wayland-protocols-1.18-noarch-1.txz:  Added.
x/xorg-server-1.20.7-x86_64-2.txz:  Rebuilt.
x/xorg-server-xephyr-1.20.7-x86_64-2.txz:  Rebuilt.
x/xorg-server-xnest-1.20.7-x86_64-2.txz:  Rebuilt.
x/xorg-server-xvfb-1.20.7-x86_64-2.txz:  Rebuilt.
x/xorg-server-xwayland-1.20.7-x86_64-2.txz:  Added.
xap/gimp-2.10.16-x86_64-1.txz:  Upgraded.
isolinux/initrd.img:  Rebuilt.
kernels/*:  Upgraded.
testing/packages/PAM/openssh-8.2p1-x86_64-2_pam.txz:  Rebuilt.
  /etc/pam.d/sshd: add commented out pam_tally2 example.
testing/packages/PAM/shadow-4.8.1-x86_64-5_pam.txz:  Rebuilt.
  /etc/pam.d/system-auth: add support for pam_group, remove pam_tally2.
  Thanks to ivandi.
  /etc/pam.d/*: Don't use tabs.
testing/packages/PAM/util-linux-2.35.1-x86_64-4_pam.txz:  Rebuilt.
  /etc/pam.d/login: add commented out pam_tally2 example.
usb-and-pxe-installers/usbboot.img:  Rebuilt.
Slackware 32
a/ed-1.16-i586-1.txz:  Upgraded.
l/gtk+3-3.24.14-i586-3.txz:  Rebuilt.
l/libuv-1.34.2-i586-1.txz:  Added.
l/qt5-5.13.2-i586-2.txz:  Rebuilt.
n/bind-9.16.0-i586-1.txz:  Upgraded.
n/proftpd-1.3.6c-i586-1.txz:  Upgraded.
x/libinput-1.15.2-i586-1.txz:  Upgraded.
x/xkbcomp-1.4.3-i586-1.txz:  Upgraded.
testing/packages/PAM/proftpd-1.3.6c-i586-1_pam.txz:  Upgraded.
a/gptfdisk-1.0.5-i586-1.txz:  Upgraded.
a/kernel-generic-5.4.21-i586-1.txz:  Upgraded.
a/kernel-generic-smp-5.4.21_smp-i686-1.txz:  Upgraded.
a/kernel-huge-5.4.21-i586-1.txz:  Upgraded.
a/kernel-huge-smp-5.4.21_smp-i686-1.txz:  Upgraded.
a/kernel-modules-5.4.21-i586-1.txz:  Upgraded.
a/kernel-modules-smp-5.4.21_smp-i686-1.txz:  Upgraded.
a/shadow-4.8.1-i586-5.txz:  Rebuilt.
a/util-linux-2.35.1-i586-4.txz:  Rebuilt.
ap/cdparanoia-III_10.2-i586-3.txz:  Rebuilt.
d/kernel-headers-5.4.21_smp-x86-1.txz:  Upgraded.
k/kernel-source-5.4.21_smp-noarch-1.txz:  Upgraded.
   SND_SOC n -> m
   SPI n -> y
   VFIO_PCI_VGA n -> y
  +ADE7854_SPI m
  +ADT7316_SPI m
  +BMC150_ACCEL_SPI m
  +BMG160_SPI m
  +BMP280_SPI m
  +FXAS21002C_SPI m
  +HTS221_SPI m
  +IIO_ST_PRESS_SPI m
  +INPUT_AD714X_SPI m
  +KXSD9_SPI m
  +REGMAP_SPI m
  +SND_HDA_EXT_CORE m
  +SND_PCM_ELD y
  +SND_PCM_IEC958 y
  +SND_SIMPLE_CARD m
  +SND_SOC_AC97_BUS y
  +SND_SOC_ACPI m
  +SND_SOC_ADAU1761 m
  +SND_SOC_ADAU17X1 m
  +SND_SOC_ADAU7002 m
  +SND_SOC_AMD_ACP m
  +SND_SOC_BD28623 m
  +SND_SOC_COMPRESS y
  +SND_SOC_CS35L34 m
  +SND_SOC_CS35L35 m
  +SND_SOC_CS35L36 m
  +SND_SOC_CS42L42 m
  +SND_SOC_CS43130 m
  +SND_SOC_CX2072X m
  +SND_SOC_DA7213 m
  +SND_SOC_DA7219 m
  +SND_SOC_DMIC m
  +SND_SOC_ES7134 m
  +SND_SOC_ES7241 m
  +SND_SOC_ES8316 m
  +SND_SOC_ES8328 m
  +SND_SOC_HDAC_HDA m
  +SND_SOC_MAX9759 m
  +SND_SOC_MAX98088 m
  +SND_SOC_MAX98090 m
  +SND_SOC_MAX98373 m
  +SND_SOC_MAX9867 m
  +SND_SOC_MAX98927 m
  +SND_SOC_NAU8540 m
  +SND_SOC_NAU8824 m
  +SND_SOC_NAU8825 m
  +SND_SOC_PCM1789 m
  +SND_SOC_PCM186X m
  +SND_SOC_PCM3060 m
  +SND_SOC_RL6231 m
  +SND_SOC_RL6347A m
  +SND_SOC_RT286 m
  +SND_SOC_RT298 m
  +SND_SOC_RT5640 m
  +SND_SOC_RT5645 m
  +SND_SOC_RT5651 m
  +SND_SOC_RT5660 m
  +SND_SOC_RT5663 m
  +SND_SOC_RT5670 m
  +SND_SOC_RT5677 m
  +SND_SOC_RT5682 m
  +SND_SOC_SIGMADSP m
  +SND_SOC_SOF m
  +SND_SOC_SOF_ACPI m
  +SND_SOC_SOF_HDA m
  +SND_SOC_SOF_PCI m
  +SND_SOC_SPDIF m
  +SND_SOC_SSM4567 m
  +SND_SOC_TAS6424 m
  +SND_SOC_TDA7419 m
  +SND_SOC_TOPOLOGY y
  +SND_SOC_TS3A227E m
  +SND_SOC_TSCS42XX m
  +SND_SOC_WM8524 m
  +SND_SPI y
  +SND_SST_IPC m
  +SND_SST_IPC_ACPI m
  +SND_SST_IPC_PCI m
  +SPI_MASTER y
  +ST_UVIS25_SPI m
l/gegl-0.4.22-i586-1.txz:  Upgraded.
l/glib2-2.62.5-i586-1.txz:  Upgraded.
l/python-requests-2.23.0-i586-1.txz:  Upgraded.
n/NetworkManager-1.22.8-i586-1.txz:  Upgraded.
n/openssh-8.2p1-i586-2.txz:  Rebuilt.
n/php-7.4.3-i586-1.txz:  Upgraded.
x/mesa-20.0.0-i586-1.txz:  Upgraded.
x/wayland-1.18.0-i586-1.txz:  Added.
x/xorg-server-1.20.7-i586-2.txz:  Rebuilt.
x/xorg-server-xephyr-1.20.7-i586-2.txz:  Rebuilt.
x/xorg-server-xnest-1.20.7-i586-2.txz:  Rebuilt.
x/xorg-server-xvfb-1.20.7-i586-2.txz:  Rebuilt.
x/xorg-server-xwayland-1.20.7-i586-2.txz:  Added.
xap/gimp-2.10.16-i586-1.txz:  Upgraded.
extra/linux-5.4.21-nosmp-sdk/*:  Upgraded.
testing/packages/PAM/openssh-8.2p1-i586-2_pam.txz:  Rebuilt.
testing/packages/PAM/shadow-4.8.1-i586-5_pam.txz:  Rebuilt.
  Thanks to ivandi.
testing/packages/PAM/util-linux-2.35.1-i586-4_pam.txz:  Rebuilt.
Post Napisano: 23 Feb 2020, 12:56
Slackware 64bit
Sat Feb 22 19:31:36 UTC 2020
ap/lsscsi-0.31-x86_64-1.txz: Upgraded.
l/libxkbcommon-0.10.0-x86_64-2.txz: Rebuilt.
n/dnsmasq-2.80-x86_64-4.txz: Rebuilt.
       Rebuilt with: -DHAVE_DNSSEC -DHAVE_DBUS -DHAVE_LIBIDN2 -DHAVE_CONNTRACK
x/intel-vaapi-driver-2.4.0-x86_64-2.txz: Rebuilt.
x/libglvnd-1.3.1-x86_64-1.txz: Upgraded.
Sat Feb 22 05:41:50 UTC 2020
ap/alsa-utils-1.2.2-x86_64-1.txz: Upgraded.
l/alsa-lib-1.2.2-x86_64-1.txz: Upgraded.
l/alsa-plugins-1.2.2-x86_64-1.txz: Upgraded.
l/imagemagick-7.0.9_25-x86_64-1.txz: Upgraded.
x/libva-2.6.1-x86_64-2.txz: Rebuilt.
       Rebuilt to add libva-wayland. Thanks to hadack.
extra/pure-alsa-system/alsa-lib-1.2.2-x86_64-1_alsa.txz: Upgraded.
extra/pure-alsa-system/alsa-plugins-1.2.2-x86_64-1_alsa.txz: Upgraded.
Slackware 32bit
ap/lsscsi-0.31-i586-1.txz:  Upgraded.
l/libxkbcommon-0.10.0-i586-2.txz:  Rebuilt.
n/dnsmasq-2.80-i586-4.txz:  Rebuilt.
x/intel-vaapi-driver-2.4.0-i586-2.txz:  Rebuilt.
x/libglvnd-1.3.1-i586-1.txz:  Upgraded.
ap/alsa-utils-1.2.2-i586-1.txz:  Upgraded.
l/alsa-lib-1.2.2-i586-1.txz:  Upgraded.
l/alsa-plugins-1.2.2-i586-1.txz:  Upgraded.
l/imagemagick-7.0.9_25-i586-1.txz:  Upgraded.
x/libva-2.6.1-i586-2.txz:  Rebuilt.
extra/pure-alsa-system/alsa-lib-1.2.2-i586-1_alsa.txz:  Upgraded.
extra/pure-alsa-system/alsa-plugins-1.2.2-i586-1_alsa.txz:  Upgraded.
Post Napisano: 27 Feb 2020, 01:23
Slackware 64-bit
Tue Feb 25 22:23:47 UTC 2020
ap/man-db-2.9.1-x86_64-1.txz: Upgraded.
       Upgraded to libpipeline-1.5.2 and man-db-2.9.1.
ap/vim-8.2.0317-x86_64-1.txz: Upgraded.
l/xapian-core-1.4.15-x86_64-1.txz: Upgraded.
xap/vim-gvim-8.2.0317-x86_64-1.txz: Upgraded.
Mon Feb 24 20:56:07 UTC 2020
a/kernel-firmware-20200224_efcfa03-noarch-1.txz: Upgraded.
a/kernel-generic-5.4.22-x86_64-1.txz: Upgraded.
a/kernel-huge-5.4.22-x86_64-1.txz: Upgraded.
a/kernel-modules-5.4.22-x86_64-1.txz: Upgraded.
d/kernel-headers-5.4.22-x86-1.txz: Upgraded.
d/parallel-20200222-noarch-1.txz: Upgraded.
k/kernel-source-5.4.22-noarch-1.txz: Upgraded.
l/imagemagick-7.0.9_26-x86_64-1.txz: Upgraded.
l/libgphoto2-2.5.24-x86_64-1.txz: Upgraded.
n/ipset-7.6-x86_64-1.txz: Upgraded.
x/libxcb-1.14-x86_64-1.txz: Upgraded.
x/vulkan-sdk-1.2.131.1-x86_64-2.txz: Rebuilt.
       Rebuilt with -DBUILD_WSI_WAYLAND_SUPPORT=On. Thanks to mumahendras3.
x/xcb-proto-1.14-x86_64-1.txz: Upgraded.
xap/gimp-2.10.18-x86_64-1.txz: Upgraded.
Slackware 32-bit
ap/man-db-2.9.1-i586-1.txz: Upgraded.
ap/vim-8.2.0317-i586-1.txz: Upgraded.
l/xapian-core-1.4.15-i586-1.txz: Upgraded.
xap/vim-gvim-8.2.0317-i586-1.txz: Upgraded.
a/kernel-generic-5.4.22-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.4.22_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.4.22-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.4.22_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.4.22-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.4.22_smp-i686-1.txz: Upgraded.
d/kernel-headers-5.4.22_smp-x86-1.txz: Upgraded.
k/kernel-source-5.4.22_smp-noarch-1.txz: Upgraded.
l/imagemagick-7.0.9_26-i586-1.txz: Upgraded.
l/libgphoto2-2.5.24-i586-1.txz: Upgraded.
n/ipset-7.6-i586-1.txz: Upgraded.
x/libxcb-1.14-i586-1.txz: Upgraded.
x/vulkan-sdk-1.2.131.1-i586-2.txz: Rebuilt.
x/xcb-proto-1.14-i586-1.txz: Upgraded.
xap/gimp-2.10.18-i586-1.txz: Upgraded.
extra/linux-5.4.22-nosmp-sdk/*: Upgraded.
Post Napisano: 01 Mar 2020, 17:27
Slackware 64-bit
Sat Feb 29 19:20:21 UTC 2020
a/kernel-generic-5.4.23-x86_64-1.txz: Upgraded.
a/kernel-huge-5.4.23-x86_64-1.txz: Upgraded.
       DM_BUFIO y -> m
       DM_SNAPSHOT y -> m
a/kernel-modules-5.4.23-x86_64-1.txz: Upgraded.
a/logrotate-3.16.0-x86_64-1.txz: Upgraded.
ap/cups-filters-1.27.2-x86_64-1.txz: Upgraded.
d/kernel-headers-5.4.23-x86-1.txz: Upgraded.
k/kernel-source-5.4.23-noarch-1.txz: Upgraded.
testing/packages/PAM/hplip-3.20.2-x86_64-1_pam.txz: Upgraded.
Fri Feb 28 03:53:37 UTC 2020
ap/hplip-3.20.2-x86_64-1.txz: Upgraded.
d/meson-0.53.2-x86_64-1.txz: Upgraded.
d/python3-3.8.2-x86_64-1.txz: Upgraded.
d/rust-1.41.1-x86_64-1.txz: Upgraded.
l/libnotify-0.7.9-x86_64-1.txz: Upgraded.
l/libsoup-2.68.4-x86_64-1.txz: Upgraded.
n/libqmi-1.24.6-x86_64-1.txz: Upgraded.
Slackware 32-bit
a/kernel-generic-5.4.23-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.4.23_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.4.23-i586-1.txz: Upgraded.
       DM_BUFIO y -> m
       DM_SNAPSHOT y -> m
a/kernel-huge-smp-5.4.23_smp-i686-1.txz: Upgraded.
       DM_BUFIO y -> m
       DM_SNAPSHOT y -> m
a/kernel-modules-5.4.23-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.4.23_smp-i686-1.txz: Upgraded.
a/logrotate-3.16.0-i586-1.txz: Upgraded.
ap/cups-filters-1.27.2-i586-1.txz: Upgraded.
d/kernel-headers-5.4.23_smp-x86-1.txz: Upgraded.
k/kernel-source-5.4.23_smp-noarch-1.txz: Upgraded.
extra/linux-5.4.23-nosmp-sdk/*: Upgraded.
testing/packages/PAM/hplip-3.20.2-i586-1_pam.txz: Upgraded.
ap/hplip-3.20.2-i586-1.txz: Upgraded.
d/meson-0.53.2-i586-1.txz: Upgraded.
d/python3-3.8.2-i586-1.txz: Upgraded.
d/rust-1.41.1-i686-1.txz: Upgraded.
l/libnotify-0.7.9-i586-1.txz: Upgraded.
l/libsoup-2.68.4-i586-1.txz: Upgraded.
n/libqmi-1.24.6-i586-1.txz: Upgraded.
Post Napisano: 04 Mar 2020, 18:24
Slackware 64-bit
Wed Mar 4 01:39:54 UTC 2020
xap/seamonkey-2.53.1-x86_64-2.txz: Rebuilt.
       Fixed $LIBDIRSUFFIX for 32-bit. Thanks to ljb643.
Tue Mar 3 22:39:20 UTC 2020
a/hwdata-0.333-noarch-1.txz: Upgraded.
a/kernel-firmware-20200302_0148cfe-noarch-1.txz: Upgraded.
ap/ddrescue-1.25-x86_64-1.txz: Upgraded.
d/perl-5.30.1-x86_64-2.txz: Rebuilt.
       Added Parse-Yapp-1.21, needed to build the parser for the Samba compile.
d/vala-0.48.0-x86_64-1.txz: Upgraded.
l/at-spi2-atk-2.34.2-x86_64-1.txz: Upgraded.
l/fribidi-1.0.9-x86_64-1.txz: Upgraded.
l/sg3_utils-1.45-x86_64-1.txz: Upgraded.
n/samba-4.12.0-x86_64-1.txz: Upgraded.
testing/packages/PAM/samba-4.12.0-x86_64-1_pam.txz: Upgraded.
Mon Mar 2 19:05:10 UTC 2020
a/dialog-1.3_20200228-x86_64-1.txz: Upgraded.
l/Mako-1.1.2-x86_64-1.txz: Upgraded.
l/imagemagick-7.0.9_27-x86_64-1.txz: Upgraded.
l/libcap-2.33-x86_64-1.txz: Upgraded.
n/bind-9.16.0-x86_64-2.txz: Rebuilt.
       rc.bind: ensure /var/run/named exists before starting named. Thanks to MarcT.
       rc.bind: when stopping named, only kill processes in the current namespace.
x/libevdev-1.9.0-x86_64-1.txz: Upgraded.
x/wayland-protocols-1.20-noarch-1.txz: Upgraded.
xap/seamonkey-2.53.1-x86_64-1.txz: Upgraded.
       https://www.seamonkey-project.org/releases/seamonkey2.53.1
testing/packages/PAM/libcap-2.33-x86_64-1_pam.txz: Upgraded.
Slackware 32-bit
xap/seamonkey-2.53.1-i686-2.txz: Rebuilt.
ap/ddrescue-1.25-i586-1.txz: Upgraded.
d/perl-5.30.1-i586-2.txz: Rebuilt.
d/vala-0.48.0-i586-1.txz: Upgraded.
l/at-spi2-atk-2.34.2-i586-1.txz: Upgraded.
l/fribidi-1.0.9-i586-1.txz: Upgraded.
l/sg3_utils-1.45-i586-1.txz: Upgraded.
n/samba-4.12.0-i586-1.txz: Upgraded.
testing/packages/PAM/samba-4.12.0-i586-1_pam.txz: Upgraded.
a/dialog-1.3_20200228-i586-1.txz: Upgraded.
l/Mako-1.1.2-i586-1.txz: Upgraded.
l/imagemagick-7.0.9_27-i586-1.txz: Upgraded.
l/libcap-2.33-i586-1.txz: Upgraded.
n/bind-9.16.0-i586-2.txz: Rebuilt.
x/libevdev-1.9.0-i586-1.txz: Upgraded.
xap/seamonkey-2.53.1-i686-1.txz: Upgraded.
testing/packages/PAM/libcap-2.33-i586-1_pam.txz: Upgraded.
Post Napisano: 08 Mar 2020, 23:17
Slackware 64-bit
Sun Mar 8 19:42:26 UTC 2020
d/bison-3.5.3-x86_64-1.txz: Upgraded.
d/python-setuptools-45.3.0-x86_64-1.txz: Upgraded.
l/adwaita-icon-theme-3.36.0-noarch-1.txz: Upgraded.
l/at-spi2-core-2.36.0-x86_64-1.txz: Upgraded.
l/pygobject3-3.36.0-x86_64-1.txz: Upgraded.
l/python-pygments-2.6.1-x86_64-1.txz: Upgraded.
Sat Mar 7 20:25:36 UTC 2020
l/gobject-introspection-1.64.0-x86_64-1.txz: Upgraded.
l/imagemagick-7.0.10_0-x86_64-1.txz: Upgraded.
l/libical-3.0.8-x86_64-1.txz: Upgraded.
l/librsvg-2.48.0-x86_64-1.txz: Upgraded.
l/libsoup-2.70.0-x86_64-1.txz: Upgraded.
l/mozilla-nss-3.51-x86_64-1.txz: Upgraded.
xap/libnma-1.8.28-x86_64-1.txz: Added.
       This is the NetworkManager GUI client library, which was previously
       provided by network-manager-applet. It's now a standalone project, and
       is required by network-manager-applet and other NetworkManager frontends.
xap/network-manager-applet-1.16.0-x86_64-1.txz: Upgraded.
       This requires the new libnma package.
Fri Mar 6 22:10:25 UTC 2020
a/cryptsetup-2.3.0-x86_64-2.txz: Rebuilt.
       Include some additional documentation. Thanks to regdub.
a/sdparm-1.11-x86_64-1.txz: Upgraded.
ap/moc-2.5.2-x86_64-6.txz: Rebuilt.
       Fixed docs permissions. Thanks to regdub.
l/glib-networking-2.64.0-x86_64-1.txz: Upgraded.
l/glib2-2.64.0-x86_64-1.txz: Upgraded.
l/gvfs-1.44.0-x86_64-1.txz: Upgraded.
l/libnl-1.1.4-x86_64-3.txz: Rebuilt.
l/tdb-1.4.3-x86_64-3.txz: Rebuilt.
l/tevent-0.10.2-x86_64-3.txz: Rebuilt.
n/bind-9.16.0-x86_64-3.txz: Rebuilt.
       Applied upstream patch to fix a discrepancy in the quota code that can
       result in a situation where the count is not properly decremented in
       some cases.
n/dovecot-2.3.10-x86_64-1.txz: Upgraded.
n/rp-pppoe-3.13-x86_64-2.txz: Rebuilt.
       This needed a rebuild for ppp-2.4.8. Thanks to regdub.
x/libinput-1.15.3-x86_64-1.txz: Upgraded.
testing/packages/PAM/dovecot-2.3.10-x86_64-1_pam.txz: Upgraded.
Fri Mar 6 02:45:42 UTC 2020
a/coreutils-8.32-x86_64-1.txz: Upgraded.
a/kernel-generic-5.4.24-x86_64-1.txz: Upgraded.
a/kernel-huge-5.4.24-x86_64-1.txz: Upgraded.
a/kernel-modules-5.4.24-x86_64-1.txz: Upgraded.
a/kmod-27-x86_64-1.txz: Upgraded.
d/kernel-headers-5.4.24-x86-1.txz: Upgraded.
d/mercurial-5.3.1-x86_64-1.txz: Upgraded.
k/kernel-source-5.4.24-noarch-1.txz: Upgraded.
       -HEADER_TEST n
l/python-packaging-20.3-x86_64-1.txz: Upgraded.
l/vte-0.60.0-x86_64-1.txz: Upgraded.
x/mesa-20.0.1-x86_64-1.txz: Upgraded.
Wed Mar 4 22:03:30 UTC 2020
a/sdparm-1.10-x86_64-3.txz: Rebuilt.
       Recompiled against sg3_utils-1.45.
a/udisks-1.0.5-x86_64-5.txz: Rebuilt.
d/cmake-3.16.5-x86_64-1.txz: Upgraded.
l/libgpod-0.8.3-x86_64-6.txz: Rebuilt.
n/curl-7.69.0-x86_64-1.txz: Upgraded.
n/cyrus-sasl-2.1.27-x86_64-3.txz: Rebuilt.
       Added SQL support via MariaDB. Thanks to niksoggia.
n/ntp-4.2.8p14-x86_64-1.txz: Upgraded.
n/ppp-2.4.8-x86_64-1.txz: Upgraded.
       By sending an unsolicited EAP packet to a vulnerable ppp client or server,
       an unauthenticated remote attacker could cause memory corruption in the
       pppd process, which may allow for arbitrary code execution.
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-8597
testing/packages/PAM/cyrus-sasl-2.1.27-x86_64-3_pam.txz: Rebuilt.
testing/packages/PAM/ppp-2.4.8-x86_64-1_pam.txz: Upgraded.
Slackware 32-bit
d/bison-3.5.3-i586-1.txz: Upgraded.
d/python-setuptools-45.3.0-i586-1.txz: Upgraded.
l/at-spi2-core-2.36.0-i586-1.txz: Upgraded.
l/pygobject3-3.36.0-i586-1.txz: Upgraded.
l/python-pygments-2.6.1-i586-1.txz: Upgraded.
l/gobject-introspection-1.64.0-i586-1.txz: Upgraded.
l/imagemagick-7.0.10_0-i586-1.txz: Upgraded.
l/libical-3.0.8-i586-1.txz: Upgraded.
l/librsvg-2.48.0-i586-1.txz: Upgraded.
l/libsoup-2.70.0-i586-1.txz: Upgraded.
l/mozilla-nss-3.51-i586-1.txz: Upgraded.
xap/libnma-1.8.28-i586-1.txz: Added.
xap/network-manager-applet-1.16.0-i586-1.txz: Upgraded.
a/cryptsetup-2.3.0-i586-2.txz: Rebuilt.
a/sdparm-1.11-i586-1.txz: Upgraded.
ap/moc-2.5.2-i586-6.txz: Rebuilt.
l/glib-networking-2.64.0-i586-1.txz: Upgraded.
l/glib2-2.64.0-i586-1.txz: Upgraded.
l/gvfs-1.44.0-i586-1.txz: Upgraded.
l/libnl-1.1.4-i586-3.txz: Rebuilt.
l/tdb-1.4.3-i586-3.txz: Rebuilt.
l/tevent-0.10.2-i586-3.txz: Rebuilt.
n/bind-9.16.0-i586-3.txz: Rebuilt.
       some cases.
n/dovecot-2.3.10-i586-1.txz: Upgraded.
n/rp-pppoe-3.13-i586-2.txz: Rebuilt.
x/libinput-1.15.3-i586-1.txz: Upgraded.
testing/packages/PAM/dovecot-2.3.10-i586-1_pam.txz: Upgraded.
a/coreutils-8.32-i586-1.txz: Upgraded.
a/kernel-generic-5.4.24-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.4.24_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.4.24-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.4.24_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.4.24-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.4.24_smp-i686-1.txz: Upgraded.
a/kmod-27-i586-1.txz: Upgraded.
d/kernel-headers-5.4.24_smp-x86-1.txz: Upgraded.
d/mercurial-5.3.1-i586-1.txz: Upgraded.
k/kernel-source-5.4.24_smp-noarch-1.txz: Upgraded.
       -HEADER_TEST n
l/python-packaging-20.3-i586-1.txz: Upgraded.
l/vte-0.60.0-i586-1.txz: Upgraded.
x/mesa-20.0.1-i586-1.txz: Upgraded.
extra/linux-5.4.24-nosmp-sdk/*: Upgraded.
a/sdparm-1.10-i586-3.txz: Rebuilt.
a/udisks-1.0.5-i586-5.txz: Rebuilt.
d/cmake-3.16.5-i586-1.txz: Upgraded.
l/libgpod-0.8.3-i586-6.txz: Rebuilt.
n/curl-7.69.0-i586-1.txz: Upgraded.
n/cyrus-sasl-2.1.27-i586-3.txz: Rebuilt.
n/ntp-4.2.8p14-i586-1.txz: Upgraded.
n/ppp-2.4.8-i586-1.txz: Upgraded.
testing/packages/PAM/cyrus-sasl-2.1.27-i586-3_pam.txz: Rebuilt.
testing/packages/PAM/ppp-2.4.8-i586-1_pam.txz: Upgraded.
Post Napisano: 16 Mar 2020, 20:21
Slackware 64:
Sun Mar 15 19:50:24 UTC 2020
a/aaa_elflibs-15.0-x86_64-22.txz:  Rebuilt.
  Upgraded: libcap.so.2.33, libncurses.so.6.2, libncursesw.so.6.2,
  libpcre.so.1.2.12, libpcreposix.so.0.0.7, libtinfo.so.6.2, libform.so.6.2,
  libformw.so.6.2, libglib-2.0.so.0.6400.1, libgmodule-2.0.so.0.6400.1,
  libgobject-2.0.so.0.6400.1, libgthread-2.0.so.0.6400.1,
  liblber-2.4.so.2.10.12, libldap-2.4.so.2.10.12, libmenu.so.6.2,
  libmenuw.so.6.2, libpanel.so.6.2, libpanelw.so.6.2, libstdc++.so.6.0.28.
a/xfsprogs-5.5.0-x86_64-1.txz:  Upgraded.
ap/sudo-1.8.31p1-x86_64-1.txz:  Upgraded.
  This is a bugfix release:
  Sudo once again ignores a failure to restore the RLIMIT_CORE resource limit,
  as it did prior to version 1.8.29. Linux containers don't allow RLIMIT_CORE
  to be set back to RLIM_INFINITY if we set the limit to zero, even for root,
  which resulted in a warning from sudo.
d/help2man-1.47.13-x86_64-1.txz:  Upgraded.
d/perl-5.30.2-x86_64-1.txz:  Upgraded.
  Also upgraded to Devel-CheckLib-1.14, DBI-1.643, and IO-Socket-SSL-2.067.
n/ModemManager-1.12.8-x86_64-1.txz:  Upgraded.
n/bluez-5.54-x86_64-1.txz:  Upgraded.
x/vulkan-sdk-1.2.131.2-x86_64-1.txz:  Upgraded.
Fri Mar 13 20:15:29 UTC 2020
a/cryptsetup-2.3.1-x86_64-1.txz:  Upgraded.
a/kernel-firmware-20200309_3b3dd5a-noarch-1.txz:  Upgraded.
a/kernel-generic-5.4.25-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.4.25-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.4.25-x86_64-1.txz:  Upgraded.
ap/ghostscript-9.51-x86_64-1.txz:  Upgraded.
d/gcc-9.3.0-x86_64-1.txz:  Upgraded.
d/gcc-brig-9.3.0-x86_64-1.txz:  Upgraded.
d/gcc-g++-9.3.0-x86_64-1.txz:  Upgraded.
d/gcc-gdc-9.3.0-x86_64-1.txz:  Upgraded.
d/gcc-gfortran-9.3.0-x86_64-1.txz:  Upgraded.
d/gcc-gnat-9.3.0-x86_64-1.txz:  Upgraded.
d/gcc-go-9.3.0-x86_64-1.txz:  Upgraded.
d/gcc-objc-9.3.0-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.4.25-x86-1.txz:  Upgraded.
d/libtool-2.4.6-x86_64-13.txz:  Rebuilt.
  Recompiled to update embedded GCC version number.
d/rust-1.42.0-x86_64-1.txz:  Upgraded.
d/scons-3.1.2-x86_64-2.txz:  Rebuilt.
  Drop python2 support and switch to python3.
k/kernel-source-5.4.25-noarch-1.txz:  Upgraded.
  GCC_VERSION 90200 -> 90300
l/libuv-1.35.0-x86_64-1.txz:  Upgraded.
n/NetworkManager-1.22.10-x86_64-1.txz:  Upgraded.
n/postfix-3.4.10-x86_64-1.txz:  Upgraded.
xap/blueman-2.1.2-x86_64-2.txz:  Rebuilt.
  This needed a rebuild for glib2-2.64.1. Thanks to Lockywolf.
xap/mozilla-thunderbird-68.6.0-x86_64-1.txz:  Upgraded.
    https://www.mozilla.org/en-US/thunderbird/68.6.0/releasenotes/
    https://www.mozilla.org/en-US/security/advisories/mfsa2020-10/
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-6805
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-6806
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-6807
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-6811
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-20503
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-6812
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-6814
Wed Mar 11 19:54:51 UTC 2020
ap/hplip-3.20.3-x86_64-1.txz:  Upgraded.
d/vala-0.48.1-x86_64-1.txz:  Upgraded.
l/SDL2-2.0.12-x86_64-1.txz:  Upgraded.
l/gcr-3.36.0-x86_64-1.txz:  Upgraded.
l/glib2-2.64.1-x86_64-1.txz:  Upgraded.
l/gnome-keyring-3.36.0-x86_64-1.txz:  Upgraded.
l/libsecret-0.20.2-x86_64-1.txz:  Upgraded.
n/curl-7.69.1-x86_64-1.txz:  Upgraded.
testing/packages/PAM/gnome-keyring-3.36.0-x86_64-1_pam.txz:  Upgraded.
testing/packages/PAM/hplip-3.20.3-x86_64-1_pam.txz:  Upgraded.
Tue Mar 10 19:53:39 UTC 2020
d/guile-3.0.1-x86_64-1.txz:  Upgraded.
l/SDL2-2.0.10-x86_64-2.txz:  Rebuilt.
  Rebuilt to pick up wayland support. Thanks to franzen.
l/dconf-0.36.0-x86_64-1.txz:  Upgraded.
l/dconf-editor-3.36.0-x86_64-1.txz:  Upgraded.
l/gsettings-desktop-schemas-3.36.0-x86_64-1.txz:  Upgraded.
l/python-pygments-2.5.2-x86_64-1.txz:  Upgraded.
  It seems like the pragmatic thing to do here is to revert this one to fix
  the python2 programs and modules that depend on it. We'll have to do a bit
  more research to determine what the best course of action is regarding
  python2 in general, though. Certainly we shouldn't be requiring python2
  for anything important moving forward, but even that will take some work.
  Plasma 5 as currently built has multiple dependencies on python2, for
  example.
n/bind-9.16.0-x86_64-4.txz:  Rebuilt.
x/liberation-fonts-ttf-2.1.0-noarch-1.txz:  Upgraded.
xap/mozilla-firefox-68.6.0esr-x86_64-1.txz:  Upgraded.
    https://www.mozilla.org/en-US/firefox/68.6.0/releasenotes/
    https://www.mozilla.org/security/advisories/mfsa2020-09/
Slackware 32:
a/aaa_elflibs-15.0-i586-22.txz:  Rebuilt.
a/xfsprogs-5.5.0-i586-1.txz:  Upgraded.
ap/sudo-1.8.31p1-i586-1.txz:  Upgraded.
d/help2man-1.47.13-i586-1.txz:  Upgraded.
d/perl-5.30.2-i586-1.txz:  Upgraded.
n/ModemManager-1.12.8-i586-1.txz:  Upgraded.
n/bluez-5.54-i586-1.txz:  Upgraded.
x/vulkan-sdk-1.2.131.2-i586-1.txz:  Upgraded.
a/cryptsetup-2.3.1-i586-1.txz:  Upgraded.
a/kernel-generic-5.4.25-i586-1.txz:  Upgraded.
a/kernel-generic-smp-5.4.25_smp-i686-1.txz:  Upgraded.
a/kernel-huge-5.4.25-i586-1.txz:  Upgraded.
a/kernel-huge-smp-5.4.25_smp-i686-1.txz:  Upgraded.
a/kernel-modules-5.4.25-i586-1.txz:  Upgraded.
a/kernel-modules-smp-5.4.25_smp-i686-1.txz:  Upgraded.
ap/ghostscript-9.51-i586-1.txz:  Upgraded.
d/gcc-9.3.0-i586-1.txz:  Upgraded.
d/gcc-brig-9.3.0-i586-1.txz:  Upgraded.
d/gcc-g++-9.3.0-i586-1.txz:  Upgraded.
d/gcc-gdc-9.3.0-i586-1.txz:  Upgraded.
d/gcc-gfortran-9.3.0-i586-1.txz:  Upgraded.
d/gcc-gnat-9.3.0-i586-1.txz:  Upgraded.
d/gcc-go-9.3.0-i586-1.txz:  Upgraded.
d/gcc-objc-9.3.0-i586-1.txz:  Upgraded.
d/kernel-headers-5.4.25_smp-x86-1.txz:  Upgraded.
d/libtool-2.4.6-i586-13.txz:  Rebuilt.
d/rust-1.42.0-i686-1.txz:  Upgraded.
d/scons-3.1.2-i586-2.txz:  Rebuilt.
k/kernel-source-5.4.25_smp-noarch-1.txz:  Upgraded.
l/libuv-1.35.0-i586-1.txz:  Upgraded.
n/NetworkManager-1.22.10-i586-1.txz:  Upgraded.
n/postfix-3.4.10-i586-1.txz:  Upgraded.
xap/blueman-2.1.2-i586-2.txz:  Rebuilt.
xap/mozilla-thunderbird-68.6.0-i686-1.txz:  Upgraded.
extra/linux-5.4.25-nosmp-sdk/*:  Upgraded.
ap/hplip-3.20.3-i586-1.txz:  Upgraded.
d/vala-0.48.1-i586-1.txz:  Upgraded.
l/SDL2-2.0.12-i586-1.txz:  Upgraded.
l/gcr-3.36.0-i586-1.txz:  Upgraded.
l/glib2-2.64.1-i586-1.txz:  Upgraded.
l/gnome-keyring-3.36.0-i586-1.txz:  Upgraded.
l/libsecret-0.20.2-i586-1.txz:  Upgraded.
n/curl-7.69.1-i586-1.txz:  Upgraded.
testing/packages/PAM/gnome-keyring-3.36.0-i586-1_pam.txz:  Upgraded.
testing/packages/PAM/hplip-3.20.3-i586-1_pam.txz:  Upgraded.
d/guile-3.0.1-i586-1.txz:  Upgraded.
l/SDL2-2.0.10-i586-2.txz:  Rebuilt.
l/dconf-0.36.0-i586-1.txz:  Upgraded.
l/dconf-editor-3.36.0-i586-1.txz:  Upgraded.
l/gsettings-desktop-schemas-3.36.0-i586-1.txz:  Upgraded.
l/python-pygments-2.5.2-i586-1.txz:  Upgraded.
  example.
n/bind-9.16.0-i586-4.txz:  Rebuilt.
xap/mozilla-firefox-68.6.0esr-i686-1.txz:  Upgraded.
Post Napisano: 26 Mar 2020, 16:22
Slackware 64:
Wed Mar 25 22:53:06 UTC 2020
a/e2fsprogs-1.45.6-x86_64-2.txz:  Rebuilt.
  Fixed RELEASE-NOTES dangling symlink.
a/kernel-generic-5.4.28-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.4.28-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.4.28-x86_64-1.txz:  Upgraded.
ap/nano-4.9-x86_64-1.txz:  Upgraded.
d/kernel-headers-5.4.28-x86-1.txz:  Upgraded.
d/llvm-10.0.0-x86_64-1.txz:  Upgraded.
d/rust-1.42.0-x86_64-2.txz:  Rebuilt.
  Recompiled against llvm-10.0.0.
d/scons-3.1.2-x86_64-3.txz:  Rebuilt.
  Fixed shebangs for python3, removed useless .bat files.
  Thanks to teeemcee and ponce.
d/vala-0.48.2-x86_64-1.txz:  Upgraded.
k/kernel-source-5.4.28-noarch-1.txz:  Upgraded.
l/libgsf-1.14.47-x86_64-1.txz:  Upgraded.
l/neon-0.31.0-x86_64-1.txz:  Upgraded.
l/netpbm-10.89.03-x86_64-1.txz:  Upgraded.
l/qt5-5.13.2-x86_64-3.txz:  Rebuilt.
x/mesa-20.0.2-x86_64-2.txz:  Rebuilt.
xfce/thunar-1.8.14-x86_64-1.txz:  Upgraded.
Tue Mar 24 05:08:25 UTC 2020
n/curl-7.69.1-x86_64-3.txz:  Rebuilt.
  Removed --with-ca-bundle=/usr/share/curl/ca-bundle.crt and
  added --without-ca-bundle. Thanks to drgibbon and Willy Sudiarto Raharjo.
Mon Mar 23 20:03:39 UTC 2020
a/e2fsprogs-1.45.6-x86_64-1.txz:  Upgraded.
d/git-2.26.0-x86_64-1.txz:  Upgraded.
l/gd-2.3.0-x86_64-1.txz:  Upgraded.
  Potential double-free in gdImage*Ptr().
  gdImageColorMatch() out of bounds write on heap.
  Uninitialized read in gdImageCreateFromXbm().
  Double-free in gdImageBmp.
  Potential NULL pointer dereference in gdImageClone().
  Potential infinite loop in gdImageCreateFromGifCtx().
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-6978
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-6977
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-11038
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-1000222
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-14553
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-5711
l/libbluray-1.2.0-x86_64-1.txz:  Upgraded.
n/curl-7.69.1-x86_64-2.txz:  Rebuilt.
  Use --with-ca-path=/etc/ssl/certs instead of
  --with-ca-bundle=/usr/share/curl/ca-bundle.crt. Thanks to shastah.
xap/audacious-4.0-x86_64-2.txz:  Rebuilt.
  Rebuilt with autotools to fix French language support. Thanks to gmgf.
xap/audacious-plugins-4.0-x86_64-2.txz:  Rebuilt.
  Rebuilt with autotools.
extra/pure-alsa-system/audacious-plugins-4.0-x86_64-2_alsa.txz:  Rebuilt.
Sun Mar 22 19:58:16 UTC 2020
l/glibmm-2.64.2-x86_64-1.txz:  Upgraded.
l/imagemagick-7.0.10_2-x86_64-1.txz:  Upgraded.
l/libcue-2.2.1-x86_64-1.txz:  Added.
  The initial use for this is adding CUE support to audacious-plugins.
l/libdvdnav-6.1.0-x86_64-1.txz:  Upgraded.
l/libdvdread-6.1.0-x86_64-1.txz:  Upgraded.
xap/audacious-4.0-x86_64-1.txz:  Upgraded.
xap/audacious-plugins-4.0-x86_64-1.txz:  Upgraded.
extra/pure-alsa-system/audacious-plugins-4.0-x86_64-1_alsa.txz:  Upgraded.
Sun Mar 22 01:55:55 UTC 2020
a/kernel-generic-5.4.27-x86_64-1.txz:  Upgraded.
a/kernel-huge-5.4.27-x86_64-1.txz:  Upgraded.
a/kernel-modules-5.4.27-x86_64-1.txz:  Upgraded.
a/tcsh-6.22.02-x86_64-3.txz:  Rebuilt.
  Actually apply the shell history patch this time. Thanks to jmccue.
ap/cups-filters-1.27.3-x86_64-1.txz:  Upgraded.
d/automake-1.16.2-noarch-1.txz:  Upgraded.
d/kernel-headers-5.4.27-x86-1.txz:  Upgraded.
d/parallel-20200322-noarch-1.txz:  Upgraded.
k/kernel-source-5.4.27-noarch-1.txz:  Upgraded.
l/gmime-3.2.7-x86_64-1.txz:  Upgraded.
l/pangomm-2.42.1-x86_64-1.txz:  Upgraded.
n/gnupg2-2.2.20-x86_64-1.txz:  Upgraded.
xap/xaos-3.7-x86_64-1.txz:  Upgraded.
xap/xscreensaver-5.44-x86_64-1.txz:  Upgraded.
testing/packages/PAM/xscreensaver-5.44-x86_64-1_pam.txz:  Upgraded.
Fri Mar 20 18:58:08 UTC 2020
a/kernel-firmware-20200320_edf390c-noarch-1.txz:  Upgraded.
ap/vim-8.2.0418-x86_64-1.txz:  Upgraded.
d/cmake-3.17.0-x86_64-1.txz:  Upgraded.
l/fuse3-3.9.1-x86_64-1.txz:  Upgraded.
x/igt-gpu-tools-1.25-x86_64-1.txz:  Upgraded.
xap/vim-gvim-8.2.0418-x86_64-1.txz:  Upgraded.
Thu Mar 19 22:01:05 UTC 2020
ap/ghostscript-9.52-x86_64-1.txz:  Upgraded.
l/PyQt5-5.13.2-x86_64-1.txz:  Added.
l/QScintilla-2.11.4-x86_64-3.txz:  Rebuilt.
  Added PyQt5 support. Thanks to alienBOB.
l/sip-4.19.21-x86_64-2.txz:  Rebuilt.
  Recompiled to pick up Qt5 support.
n/gpgme-1.13.1-x86_64-3.txz:  Rebuilt.
  Added Qt5 bindings. Thanks to alienBOB.
Thu Mar 19 01:45:30 UTC 2020
Don't bother with 5.4.26 folks, just wait for the next one. Trust me.
a/tcsh-6.22.02-x86_64-2.txz:  Rebuilt.
  Fixed merging history from multiple shells. Thanks to jmccue.
a/xz-5.2.5-x86_64-1.txz:  Upgraded.
d/git-2.25.2-x86_64-1.txz:  Upgraded.
l/glibmm-2.64.1-x86_64-1.txz:  Upgraded.
n/bind-9.16.1-x86_64-1.txz:  Upgraded.
n/dovecot-2.3.10-x86_64-2.txz:  Rebuilt.
x/libinput-1.15.4-x86_64-1.txz:  Upgraded.
x/mesa-20.0.2-x86_64-1.txz:  Upgraded.
testing/packages/PAM/dovecot-2.3.10-x86_64-2_pam.txz:  Rebuilt.
  Recompiled using --with-pam. Thanks to HQuest.
Tue Mar 17 22:11:07 UTC 2020
Happy Feast of Saint Patrick. Stay safe everyone.
a/openssl-solibs-1.1.1e-x86_64-1.txz:  Upgraded.
d/ccache-3.7.8-x86_64-1.txz:  Upgraded.
l/glibmm-2.64.0-x86_64-1.txz:  Upgraded.
n/openssl-1.1.1e-x86_64-1.txz:  Upgraded.
  Fixed an overflow bug in the x64_64 Montgomery squaring procedure
  used in exponentiation with 512-bit moduli.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-1551
n/php-7.4.4-x86_64-1.txz:  Upgraded.
  Core: get_headers() silently truncates after a null byte
  EXIF: Use-of-uninitialized-value in exif
  MBstring: mb_strtolower: stack-buffer-overflow at php_unicode_tolower_full
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-7066
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-7064
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-7065
Mon Mar 16 21:20:17 UTC 2020
a/kernel-firmware-20200316_8eb0b28-noarch-1.txz:  Upgraded.
l/imagemagick-7.0.10_1-x86_64-1.txz:  Upgraded.
l/qt5-webkit-5.212.0_alpha4-x86_64-1.txz:  Upgraded.
n/libqmi-1.24.8-x86_64-1.txz:  Upgraded.
n/postfix-3.5.0-x86_64-1.txz:  Upgraded.
Slackware 32:
a/e2fsprogs-1.45.6-i586-2.txz:  Rebuilt.
a/kernel-generic-5.4.28-i586-1.txz:  Upgraded.
a/kernel-generic-smp-5.4.28_smp-i686-1.txz:  Upgraded.
a/kernel-huge-5.4.28-i586-1.txz:  Upgraded.
a/kernel-huge-smp-5.4.28_smp-i686-1.txz:  Upgraded.
a/kernel-modules-5.4.28-i586-1.txz:  Upgraded.
a/kernel-modules-smp-5.4.28_smp-i686-1.txz:  Upgraded.
ap/nano-4.9-i586-1.txz:  Upgraded.
d/kernel-headers-5.4.28_smp-x86-1.txz:  Upgraded.
d/llvm-10.0.0-i586-1.txz:  Upgraded.
d/rust-1.42.0-i686-2.txz:  Rebuilt.
d/scons-3.1.2-i586-3.txz:  Rebuilt.
d/vala-0.48.2-i586-1.txz:  Upgraded.
k/kernel-source-5.4.28_smp-noarch-1.txz:  Upgraded.
l/libgsf-1.14.47-i586-1.txz:  Upgraded.
l/neon-0.31.0-i586-1.txz:  Upgraded.
l/netpbm-10.89.03-i586-1.txz:  Upgraded.
l/qt5-5.13.2-i586-3.txz:  Rebuilt.
x/mesa-20.0.2-i586-2.txz:  Rebuilt.
xfce/thunar-1.8.14-i586-1.txz:  Upgraded.
extra/linux-5.4.28-nosmp-sdk/*:  Upgraded.
n/curl-7.69.1-i586-3.txz:  Rebuilt.
a/e2fsprogs-1.45.6-i586-1.txz:  Upgraded.
d/git-2.26.0-i586-1.txz:  Upgraded.
l/gd-2.3.0-i586-1.txz:  Upgraded.
l/libbluray-1.2.0-i586-1.txz:  Upgraded.
n/curl-7.69.1-i586-2.txz:  Rebuilt.
xap/audacious-4.0-i586-2.txz:  Rebuilt.
xap/audacious-plugins-4.0-i586-2.txz:  Rebuilt.
extra/pure-alsa-system/audacious-plugins-4.0-i586-2_alsa.txz:  Rebuilt.
l/glibmm-2.64.2-i586-1.txz:  Upgraded.
l/imagemagick-7.0.10_2-i586-1.txz:  Upgraded.
l/libcue-2.2.1-i586-1.txz:  Added.
l/libdvdnav-6.1.0-i586-1.txz:  Upgraded.
l/libdvdread-6.1.0-i586-1.txz:  Upgraded.
xap/audacious-4.0-i586-1.txz:  Upgraded.
xap/audacious-plugins-4.0-i586-1.txz:  Upgraded.
extra/pure-alsa-system/audacious-plugins-4.0-i586-1_alsa.txz:  Upgraded.
a/kernel-generic-5.4.27-i586-1.txz:  Upgraded.
a/kernel-generic-smp-5.4.27_smp-i686-1.txz:  Upgraded.
a/kernel-huge-5.4.27-i586-1.txz:  Upgraded.
a/kernel-huge-smp-5.4.27_smp-i686-1.txz:  Upgraded.
a/kernel-modules-5.4.27-i586-1.txz:  Upgraded.
a/kernel-modules-smp-5.4.27_smp-i686-1.txz:  Upgraded.
a/tcsh-6.22.02-i586-3.txz:  Rebuilt.
ap/cups-filters-1.27.3-i586-1.txz:  Upgraded.
d/kernel-headers-5.4.27_smp-x86-1.txz:  Upgraded.
k/kernel-source-5.4.27_smp-noarch-1.txz:  Upgraded.
l/gmime-3.2.7-i586-1.txz:  Upgraded.
l/pangomm-2.42.1-i586-1.txz:  Upgraded.
n/gnupg2-2.2.20-i586-1.txz:  Upgraded.
xap/xaos-3.7-i686-1.txz:  Upgraded.
xap/xscreensaver-5.44-i586-1.txz:  Upgraded.
extra/linux-5.4.27-nosmp-sdk/*:  Upgraded.
testing/packages/PAM/xscreensaver-5.44-i586-1_pam.txz:  Upgraded.
ap/vim-8.2.0418-i586-1.txz:  Upgraded.
d/cmake-3.17.0-i586-1.txz:  Upgraded.
l/fuse3-3.9.1-i586-1.txz:  Upgraded.
x/igt-gpu-tools-1.25-i586-1.txz:  Upgraded.
xap/vim-gvim-8.2.0418-i586-1.txz:  Upgraded.
ap/ghostscript-9.52-i586-1.txz:  Upgraded.
l/PyQt5-5.13.2-i586-1.txz:  Added.
l/QScintilla-2.11.4-i586-3.txz:  Rebuilt.
l/sip-4.19.21-i586-2.txz:  Rebuilt.
n/gpgme-1.13.1-i586-3.txz:  Rebuilt.
a/tcsh-6.22.02-i586-2.txz:  Rebuilt.
a/xz-5.2.5-i586-1.txz:  Upgraded.
d/git-2.25.2-i586-1.txz:  Upgraded.
l/glibmm-2.64.1-i586-1.txz:  Upgraded.
n/bind-9.16.1-i586-1.txz:  Upgraded.
n/dovecot-2.3.10-i586-2.txz:  Rebuilt.
x/libinput-1.15.4-i586-1.txz:  Upgraded.
x/mesa-20.0.2-i586-1.txz:  Upgraded.
testing/packages/PAM/dovecot-2.3.10-i586-2_pam.txz:  Rebuilt.
a/openssl-solibs-1.1.1e-i586-1.txz:  Upgraded.
d/ccache-3.7.8-i586-1.txz:  Upgraded.
l/glibmm-2.64.0-i586-1.txz:  Upgraded.
n/openssl-1.1.1e-i586-1.txz:  Upgraded.
n/php-7.4.4-i586-1.txz:  Upgraded.
l/imagemagick-7.0.10_1-i586-1.txz:  Upgraded.
l/qt5-webkit-5.212.0_alpha4-i586-1.txz:  Upgraded.
n/libqmi-1.24.8-i586-1.txz:  Upgraded.
n/postfix-3.5.0-i586-1.txz:  Upgraded.
Post Napisano: 29 Mar 2020, 21:56
Slackware64
Sat Mar 28 05:48:42 UTC 2020
a/lvm2-2.03.09-x86_64-1.txz: Upgraded.
d/guile-3.0.2-x86_64-1.txz: Upgraded.
l/glib-networking-2.64.1-x86_64-1.txz: Upgraded.
l/gtk+3-3.24.16-x86_64-1.txz: Upgraded.
l/gvfs-1.44.1-x86_64-1.txz: Upgraded.
l/librsvg-2.48.1-x86_64-1.txz: Upgraded.
l/vte-0.60.1-x86_64-1.txz: Upgraded.
xap/audacious-4.0-x86_64-3.txz: Rebuilt.
       Also support GTK+ interface, including a .desktop file for it.
xap/audacious-plugins-4.0-x86_64-3.txz: Rebuilt.
       Rebuilt with --enable-gtk.
extra/pure-alsa-system/audacious-plugins-4.0-x86_64-3_alsa.txz: Rebuilt.
extra/pure-alsa-system/qt5-5.13.2-x86_64-3_alsa.txz: Added.
Thu Mar 26 22:37:06 UTC 2020
x/libwacom-1.3-x86_64-1.txz: Upgraded.
Slackware32
a/lvm2-2.03.09-i586-1.txz: Upgraded.
d/guile-3.0.2-i586-1.txz: Upgraded.
l/glib-networking-2.64.1-i586-1.txz: Upgraded.
l/gtk+3-3.24.16-i586-1.txz: Upgraded.
l/gvfs-1.44.1-i586-1.txz: Upgraded.
l/librsvg-2.48.1-i586-1.txz: Upgraded.
l/vte-0.60.1-i586-1.txz: Upgraded.
xap/audacious-4.0-i586-3.txz: Rebuilt.
xap/audacious-plugins-4.0-i586-3.txz: Rebuilt.
extra/pure-alsa-system/audacious-plugins-4.0-i586-3_alsa.txz: Rebuilt.
extra/pure-alsa-system/qt5-5.13.2-i586-3_alsa.txz: Added.
x/libwacom-1.3-i586-1.txz: Upgraded.
