Doterivanje, editovanje, razmena... conkyrc-a
Administratoroffline
@stereo:
Ovako izgleda mnogo bolje nego ona varijanta sa crvenim slovima. E sad je već fensi.
Već neko vreme nisam radio conkyrc pa sam malo i zaboravio kako se šta podešava
no ipak sam uspeo nešto da spakujem, skoro pa minimalno
A tu je i slika ekrana
background no
font Sans:size=8
#xftfont Sans:size=10
use_xft yes
xftalpha 0.9
update_interval 1.0
total_run_times 0
own_window yes
own_window_type override
own_window_transparent yes
own_window_hints decorated,below,sticky,skip_taskbar,skip_pager
double_buffer yes
minimum_size 1300 5
maximum_width 1300
draw_shades yes
draw_outline no
draw_borders no
draw_graph_borders yes
default_color white
default_shade_color black
default_outline_color green
alignment top_left
gap_x 20
gap_y 700
no_buffers yes
uppercase no
cpu_avg_samples 2
override_utf8_locale yes
TEXT
${font} ${color red}$sysname: ${color}${exec cat /etc/slackware-version}${alignc}${font} ${color red}CPU1 ${color}${alignc}${cpu cpu1}%${alignr}${font} ${color red}Ram ${color}${alignr}$mem / $memmax ($memperc%)
${font} ${color red}Hostname: ${color}$nodename${alignc}${font} ${color red}CPU2 ${color}${alignc}${cpu cpu2}%${alignr}${font} ${color red}Swap ${color}${alignr}$swap / $swapmax ($swapperc%)
${font} ${color red}Root: ${color}${fs_free /}${alignc}${font} ${color red}Home: ${color}${alignc}${fs_free /home}${alignr}${font} ${color red}Magacin: ${color}${alignr}${fs_free /mnt/magacin} / ${fs_size /mnt/magacin}
Stalni članoffline
Onaj conky se može napraviti po ovom uputstvu, http://ubuntuforums.org/showthread.php?t=1771033 ja nemam stvarno vremena danas, pa ako negde zapne uključiću se sutra nekad tokom dana, ozbiljan me posao napao.
## urosh | rev. 11-12-01 20:20 ##
## ¡PLEASE READ THE FINE PRINT! ##
## Development Platforms (current)
# Ubuntu 10.10 'Maverick Meerkat' (GNOME 2.28 - Conky 1.8.0)
# Ubuntu 12.04 'Precise Pangolin' (GNOME-SHELL - UNITY 2D/3D - Conky 1.8.1)
# Screen Resolution: 1280x1024x24 (DELL UltraSharp 1907FP)
## Prerequisites (required)
# conky-all 1.8.0 or 1.8.1
# cURL - Command Line Tool
# xsltproc - Command Line Tool
# UTF-8 Compatible Text Editor
## Installed fonts (required)
# ConkyWeather (Stanko Metodiev)
# Cut Outs for 3D FX (Fonts & Things)
# Droid Font Family (Google Android SDK)
# KR A Round (Kat's Fun Fonts)
# OpenLogos (Icoma)
# PizzaDude Bullets (Jakob Fischer)
# Radio Space (Iconian Fonts)
# StyleBats (Vinterstille)
# Ubuntu Font Family (Canonical Ltd)
# Ubuntu Title Bold (Paulo Silva - not included in link below)
# Weather (Jonathan Macagba)
## Tips n' Tricks from Mr. Peachy, djyoung4, and 42dorian (Thanks!)
## Most necessary fonts can be downloaded here: http://ompldr.org/vOHdoag
## Unzip the fonts into your font folder, for example: /home/username/.fonts
## Run this command in a terminal (rebuilds font cache file): sudo fc-cache -fv
## Use XFT? Required to Force UTF8 (see below)
use_xft yes
xftfont DroidSans:size=8.75
xftalpha 0.1
## Force UTF8? Requires XFT (see above)
## Displays degree symbol, instead of °, etc.
## This buffer is used for text, single lines, output from $exec, and other variables.
## Increasing the text buffer size (too high) will drastically reduce Conky's performance.
## Decreasing the size (too low) will truncate content and cause strange display output.
## Standard text buffer size is 256 bytes (cannot be less). Adjust YOUR buffer wisely!
text_buffer_size 6500
## Maximum number of special things, e.g. fonts, offsets, aligns, etc. (default is 512)
max_specials 600
## Daemonize Conky, aka 'fork to background'.
background yes
## Update interval in seconds.
update_interval 2.0
## The number of times Conky will update before quitting.
## Zero makes Conky run forever.
total_run_times 0
## Create own window in instead of using desktop?
own_window yes
own_window_type normal
own_window_class conky-semi
own_window_hints undecorated,below,sticky,skip_taskbar,skip_pager
## Some distros also require the following 2 lines.
own_window_argb_visual yes
own_window_argb_value 255
## Force images to redraw when they change.
imlib_cache_size 0
## Use double buffering? Reduces flicker.
double_buffer yes
## Draw shades?
draw_shades yes
default_shade_color 392421
## Draw outlines?
draw_outline no
## Draw borders around text?
draw_borders no
## Draw borders around graphs?
draw_graph_borders no
## Print text to stdout?
## Print text in console?
out_to_ncurses no
out_to_console no
## Text alignment.
alignment top_right
## Minimum size of the text area.
## Syntax: minimum_size [width] [height]
minimum_size 240 1394
## Maximum width of the text area.
## Syntax: maximum_width [width]
maximum_width 240
## Gap between text and screen borders.
gap_x 6 ## Left / Right
gap_y 32 ## Top / Bottom
## Shorten MiB/GiB to M/G in stats.
short_units yes
## Pad % symbol spacing after numbers.
pad_percents 0
## Pad spacing between text and borders.
border_inner_margin 4
## Limit the length of names in "Top Processes".
top_name_width 10
## Subtract file system -/+buffers/cache from used memory?
## Set to yes, to produce meaningful physical memory stats.
no_buffers yes
## Set to yes, if you want all text to be in UPPERCASE.
uppercase no
## Number of cpu samples to average.
## Set to 1 to disable averaging.
cpu_avg_samples 2
## Number of net samples to average.
net_avg_samples 2
## Add spaces to keep things from moving around?
## Only affects certain objects.
use_spacer right
## My colors (suit yourself)
color0 White #FFFFFF
color1 Ivory #FFFFF0
color2 Ivory2 #EEEEE0
color3 Ivory3 #CDCDC1
color4 Tan1 #FFA54F
color5 Tan2 #EE9A49
color6 Gray #7E7E7E
color7 AntiqueWhite4 #8B8378
color8 DimGray #696969
color9 Tomato #FF6347
## Load Lua for shading (optional)
## Set the path to your script here.
lua_load ~/.conky/draw_bg.lua
lua_draw_hook_pre draw_bg
## Load Lua for bargraphs (required)
lua_load ~/.conky/bargraph_small.lua
lua_draw_hook_post main_bars
TEXT
## LOGO ##
## Uncomment for hard-coded ID (static)
#${voffset -33}${font OpenLogos:size=103}${color2}v${font}${voffset -76}${goto 179}${font UbuntuTitleBold:size=19.6}${color4}1${offset 0}2${offset 0}.${offset 0}0${offset 0}4${font}
## Uncomment for soft-coded ID (dynamic)
${voffset -33}${font OpenLogos:size=103}${color2}v${font}${voffset -76}${goto 179}${font Boulder:size=23.6}${color4}${pre_exec cat /etc/*release | grep 'RELEASE' | awk -F'=' '{print $2}'}${font}
## Additional ID (branch version, code name, release date, etc.)
#${voffset 0}${goto 188}${font Ubuntu-B:size=9.1}${color4}Serbian${font}
## SYSTEM ##
${voffset 7}${font DroidSans:bold:size=8.25}${color4}SYSTEM${offset 8}${color5}${voffset -2}${hr 2}${font}
${voffset 4}${font OpenLogos:size=10}${color2}u${voffset -4}${font DroidSans:size=8.6}${color3}${offset 5}${pre_exec lsb_release -sd || cat /etc/*release} Precise Pangolin${font}
${voffset 2}${offset -2}${font OpenLogos:size=12}${color2}Z${voffset -4}${font DroidSans:size=8.6}${color3}${offset 3}${sysname}${offset 3}${kernel}${alignr}${font DroidSans:size=8.3}${machine}${font}
${voffset 2}${font StyleBats:size=10}${color2}d${voffset -2}${font DroidSans:size=8.6}${color3}${offset 5}nVidia GeForce 8800 GTS(rev a2)${alignr}${font DroidSans:size=8.3}${pre_exec dpkg --status nvidia-current-updates | grep Version | cut -f 1 -d '-' | sed 's/[^.,0-9]//g'}${font}
${voffset 2}${font StyleBats:size=10}${color2}A${voffset -1}${font DroidSans:size=8.6}${color3}${offset 5}Intel${offset 3}P4${offset 3}Extreme${offset 3}Edition${alignr 1}${font DroidSans:size=8.3}${freq_g cpu0}${offset 1}GHz${font}
${voffset 2}${font StyleBats:size=10}${color2}q${voffset -1}${font DroidSans:size=8.6}${color3}${offset 5}System${offset 3}Uptime${alignr}${font DroidSans:size=8.3}${uptime_short}${font}
## PROCESSORS ##
${voffset 4}${font DroidSans:bold:size=8}${color4}PROCESSORS${offset 8}${color5}${voffset -2}${hr 2}${font}
${voffset 4}${font StyleBats:size=9.9}${color2}k${voffset -2}${font DroidSansFallback:size=8.39}${color3}${offset 2}CPU1${offset 5}${font DroidSans:size=8.3}${cpu cpu1}%${font}
${voffset 2}${font StyleBats:size=9.9}${color2}k${voffset -2}${font DroidSansFallback:size=8.39}${color3}${offset 2}CPU2${offset 5}${font DroidSans:size=8.3}${cpu cpu2}%${font}
## MEMORY ##
${voffset 5}${font DroidSans:bold:size=8}${color4}MEMORY${offset 8}${color5}${voffset -2}${hr 2}${font}
${voffset 4}${font StyleBats:size=10}${color2}l${voffset -2}${font DroidSansFallback:size=8.3}${color3}${offset 3}RAM${goto 97}${font DroidSans:size=8.3}${mem}${goto 133}/${offset 5}${memmax}${alignr}${memperc}%${font}
## HDD ##
${voffset 15}${font DroidSans:bold:size=8}${color4}HDD${offset 8}${color5}${voffset -2}${hr 2}${font}
${voffset 6}${font StyleBats:size=9.9}${color2}x${voffset -2}${font DroidSansFallback:size=8.3}${color3}${offset 4}ROOT${goto 95}${font DroidSans:size=8.3}${fs_used /}${goto 133}/${offset 5}${fs_size /}${alignr}${fs_free_perc /}%${font}
${voffset 15}${font StyleBats:size=9.9}${color2}x${voffset -2}${font DroidSansFallback:size=8.3}${color3}${offset 4}HOME${goto 95}${font DroidSans:size=8.3}${fs_used /home}${goto 133}/${offset 5}${fs_size /home}${alignr}${fs_free_perc /home}%${font}
${voffset 15}${font StyleBats:size=9.9}${color2}4${voffset -2}${font DroidSansFallback:size=8.3}${color3}${offset 4}SWAP${goto 95}${font DroidSans:size=8.3}${swap}${goto 133}/${offset 5}${swapmax}${alignr}${swapperc}%${font}
${voffset 15}${font DroidSans:bold:size=8}${color4}TEMPERATURE ALERT${offset 8}${color5}${voffset 2}${hr 2}${font}
${goto 6}${voffset -2}${color1}${font Devil inside:size=12}1${font}${color6}${voffset -0}${goto 32}CPU Temp: ${alignr}${color6}${execi 30 sensors | grep 'Core 0' | cut -c16-17}°C / ${color6}${execi 30 sensors | grep 'Core 1' | cut -c16-17}°C
# GPU TEMPS
${goto 6}${color1}${font StyleBats:size=12}a${font}${color9}${voffset +1}${goto 32}GPU Temp: ${alignr}${execi 29 nvidia-settings -tq GPUCoreTemp} °C
#${font StyleBats:size=12}a${font} Fan Speed : $alignr$color9${execi 10 nvidia-smi -a | grep Fan}
## TOP PROCESSES ##
${voffset 4}${font DroidSans:bold:size=8}${color4}TOP PROCESSES${offset 8}${color5}${voffset -2}${hr 2}${font}
${voffset 6}${font StyleBats:size=10}${color1}h${voffset -1}${font DroidSans:size=8.65}${color3}${offset 5}${top_mem name 1}${goto 120}${font DroidSans:size=8.3}${top_mem mem_res 1}${alignr}${top_mem mem 1}%${font}
${voffset 1}${font StyleBats:size=10}${color1}h${voffset -1}${font DroidSans:size=8.65}${color3}${offset 5}${top_mem name 2}${goto 120}${font DroidSans:size=8.3}${top_mem mem_res 2}${alignr}${top_mem mem 2}%${font}
${voffset 1}${font StyleBats:size=10}${color1}h${voffset -1}${font DroidSans:size=8.65}${color3}${offset 5}${top_mem name 3}${goto 120}${font DroidSans:size=8.3}${top_mem mem_res 3}${alignr}${top_mem mem 3}%${font}
${voffset 1}${font StyleBats:size=10}${color1}h${voffset -1}${font DroidSans:size=8.65}${color3}${offset 5}${top_mem name 4}${goto 120}${font DroidSans:size=8.3}${top_mem mem_res 4}${alignr}${top_mem mem 4}%${font}
# ${voffset 1}${font StyleBats:size=10}${color1}h${voffset -1}${font DroidSans:size=8.65}${color3}${offset 5}${top_mem name 5}${goto 120}${font DroidSans:size=8.3}${top_mem mem_res 5}${alignr}${top_mem mem 5}%${font}
# ${voffset 1}${font StyleBats:size=10}${color1}h${voffset -1}${font DroidSans:size=8.65}${color3}${offset 5}${top_mem name 6}${goto 120}${font DroidSans:size=8.3}${top_mem mem_res 6}${alignr}${top_mem mem 6}%${font}
## NETWORK ##
${voffset 4}${font DroidSans:bold:size=8}${color4}NETWORK${offset 8}${color5}${voffset -2}${hr 2}${font}
${voffset 4}${font PizzaDudeBullets:size=9.5}${color6}T${font DroidSans:size=8.65}${color3}${offset 5}Download${goto 120}${font DroidSans:size=8.3}${totaldown eth0}${alignr}${font DroidSans:size=8.3}${downspeed eth0}${font}
${voffset 0}${font PizzaDudeBullets:size=9.5}${color6}N${font DroidSans:size=8.65}${color3}${offset 5}Upload${goto 120}${font DroidSans:size=8.3}${totalup eth0}${alignr}${font DroidSans:size=8.3}${upspeed eth0}${font}
${voffset 4}${font PizzaDudeBullets:size=9.5}${color6}a${font DroidSans:size=8.65}${color3}${offset 5}Private${offset 3}IP${goto 123}${font DroidSansFallback:size=8.5}LAN${alignr}${font DroidSans:size=8.3}${addr eth0}${font}
#${voffset 0}${font PizzaDudeBullets:size=9.5}${color6}a${font DroidSans:size=8.65}${color3}${offset 5}Public${offset 7}IP${goto 121}${font DroidSansFallback:size=8.5}WAN${alignr}${font DroidSans:size=8.3}${execi 1800 wget -q -O - checkip.dyndns.org | sed -e 's/[^[:digit:]\|.]//g'}${font}
## WEATHER ##
${voffset 4}${font DroidSans:bold:size=8}${color4}WEATHER${offset 8}${color4}${voffset -2}${hr 2}${font}
${execpi 900 conkywx -c /etc/conkywx/conkywx.conf -t /usr/share/conkywx/examples/wx-wu-vindsl-template|
## Windspeed [WS]
sed -e 's/Calm mph'/'\$\{offset 8\}Calm/g'|
## Moon Phases [MP]
sed -e 's/New Moon'/'\$\{offset -10\}New Moon/g'|
sed -e 's/Waxing Crescent'/'\$\{offset -3\}Waxing/g'|
sed -e 's/First Quarter'/'\$\{offset -3\}First Qtr/g'|
sed -e 's/Waxing Gibbous'/'\$\{offset -3\}Waxing/g'|
sed -e 's/Full Moon'/'\$\{offset -8\}Full Moon/g'|
sed -e 's/Waning Gibbous'/'\$\{offset -3\}Waning/g'|
sed -e 's/Last Quarter'/'\$\{offset -3\}Last Qtr/g'|
sed -e 's/Waning Crescent'/'\$\{offset -3\}Waning/g'
}${font}
## TIME ##
${voffset 4}${font DroidSans:bold:size=8}${color4}TIME${offset 8}${color5}${voffset -2}${hr 2}${font}
${voffset -4}${font Radio Space:size=36}${color3}${if_match ${time %l}<=9}${alignc 7}${time %l:%M%p}${else}${if_match ${time %l}>=10}${alignc -1}${time %l:%M%p}${endif}${endif}${font}
#${voffset 0}${font Roboto:size=6.2}${color4}${alignc 2}Izlazi${offset 2}${texeci 1800 conkyForecast --location=SRXX0005 --datatype=SR --startday=1}${color3}${offset 2}|${offset 2}${color4}Zalazi${offset 1}${texeci 1800 conkyForecast --location=SRXX0005 --datatype=SS --startday=1}${font}
## CALENDAR ##
${voffset 4}${font Roboto:bold:size=8}${color4}DATE${offset 8}${color5}${voffset -2}${hr 2}${font}
${voffset 16}${font DroidSansMono:size=7.55}${color3}${alignc 60}${time %A}${font}
${voffset -4}${font DroidSansFallback:bold:size=18}${if_match ${time %e}<=9}${color5}${alignc 65}${time %e}${font}${else}${if_match ${time %e}>=10}${color5}${alignc 60}${time %e}${endif}${endif}${font}
${voffset 0}${font DroidSansMono:size=7.55}${color3}${alignc 60}${time %B}${font}
${voffset 0}${font DroidSansMono:size=7.6}${color3}${alignc 60}${time %Y}${font}
## Uncomment for Conky 1.8.0 (use mono fonts only)
${voffset -75}${font DroidSansMono:size=7.55}${color3}${execpi 60 VinDSL_Cal_9=`date +%-d`; cal -h | sed -e 's/\r//g' -e 's/^/ /g' -e '1d' -e s/^/"\$\{offset 100"\}/ -e 's/\<'"$VinDSL_Cal_9"'\>/${color4}&${color3}/'}
## Uncomment for Conky 1.8.1 (use mono fonts only)
#${voffset -75}${offset 100}${font DroidSansMono:size=7.55}${color3}${execpi 60 VinDSL_Cal_9=`date +%-d`; cal -h | sed -e 's/\r//g' -e 's/^/ /g' -e '1d' -e 's/\<'"$VinDSL_Cal_9"'\>/${color4}&${color3}/'}
## Uncomment for "SUNDAY = First Day-of-the-Week" (use mono fonts only)
#${voffset -70}${font DroidSansMono:size=7.55}${color3}${execpi 60 VinDSL_Cal_9=`date +%-d`; cal -h | sed -e 's/\r//g' -e 's/^/ /g' -e '1d' -e s/^/"\$\{offset 100"\}/ -e 's/\<'"$VinDSL_Cal_9"'\>/${color4}&${color3}/'}
## Uncomment for "MONDAY = First Day-of-the-Week" (use mono fonts only)
# ${voffset -68}${font DroidSansMono:size=7.55}${color3}${execpi 60 VinDSL_Cal_9=`date +%-d`; ncal -M -C -h | sed -e 's/\r//g' -e 's/^/ /g' -e '1d' -e s/^/"\$\{offset 100"\}/ -e 's/\<'"$VinDSL_Cal_9"'\>/${color4}&${color3}/'}
## Uncomment for border around today's date
${voffset -98}${font CutOutsFor3DFX:size=67}${color8}${alignc 99}2${font}
## RHYTHMBOX (Experimental) ##
${if_running rhythmbox}
#${voffset -8}${font DroidSans:bold:size=7.75}${color4}RHYTHMBOX${offset 8}${color5}${voffset -2}${hr 2}${font}
#${voffset 8}${font DroidSans:size=8.25}${color3}${if_match "${execpi 2 expr length "`/usr/bin/rhythmbox-client --print-playing-format %tt | head -n 1`"}" >= "48"}${alignr 15}${scroll 38 4* ${execi 2 rhythmbox-client --print-playing-format %tt --no-start}}${font}${else}${alignc}${execi 2 rhythmbox-client --print-playing-format %tt --no-start}${font}${endif}${endif}
## BANSHEE (Experimental) ##
${if_running banshee}
#${voffset -10}${font DroidSans:bold:size=7.75}${color4}BANSHEE${offset 8}${color8}${voffset -2}${hr 2}${font}
#${voffset 4}${font DroidSans:size=8.25}${color3}${if_match "${execpi 2 expr length "`/usr/bin/banshee --query-title --no-present | cut -f1- -d " "`"}" >= "48"}${alignr 15}${scroll 38 4* ${execi 2 banshee --query-title --no-present | cut -f2- -d " "}}${font}${else}${alignc}${execi 2 banshee --query-title --no-present | cut -f2- -d " "}${font}${endif}${endif}
${voffset -10}${font Roboto:bold:size=8}${color5}FORTUNE ${hr 2}${color8}
${font FreeSans:italic:size=7.75}${color7}${execi 120 fortune -s | fold -w50}
Elitni članoffline
Moj .conkyrc fajl
Deo koji prikazuje internet treba naknadno doterati, posto je u pitanju Telenor Internet preko usb modema. Kod mene je naziv konekcije ppp0 konekcija. Kod nekoga ce to biti eth0, a kod nekoga wlan.
background yes
use_xft yes
xftfont HandelGotD:size=9
xftalpha 0.5
update_interval 1.0
total_run_times 0
own_window yes
double_buffer yes
minimum_size 200 5
maximum_width 220
draw_shades no
draw_outline no
draw_borders no
default_color grey
default_shade_color red
alignment top_right
gap_x 12
gap_y 48
no_buffers yes
uppercase no
cpu_avg_samples 2
override_utf8_locale no
TEXT
$color
${color CC9900}SYSTEM ${hr 2}$color
$sysname $kernel
${color CC9900}CPU ${hr 2}$color
Total CPU: CPU: ${freq 1} MHz
${color 597DB2} ${cpu cpu0}% ${cpubar} $color
${cpugraph 000000 597DB2}
Core 1: ${freq 1} MHz
${color 597DB2} ${cpu cpu1}% ${cpubar cpu1}$color
Core 2: ${freq 2} MHz
${color 597DB2} ${cpu cpu2}% ${cpubar cpu2}$color
${color CC9900}PROCESSES ${hr 2}$color
NAME $alignr PID% CPU% MEM%
${top name 1} ${top pid 1} ${top cpu 1} ${top mem 1}
${top name 2} ${top pid 2} ${top cpu 2} ${top mem 2}
${top name 3} ${top pid 3} ${top cpu 3} ${top mem 3}
${top name 4} ${top pid 4} ${top cpu 4} ${top mem 4}
${top name 5} ${top pid 5} ${top cpu 5} ${top mem 5}
${top name 6} ${top pid 6} ${top cpu 6} ${top mem 6}
${color CC9900}MEMORY ${hr 2}$color
RAM Used: $alignc $mem / $memmax $alignr
${color FF6600} $memperc% ${membar 6}$color
SWAP Used:$alignc $swap / $swapmax $alignr
${color FF6600} $swapperc% ${swapbar 6}$color
${color CC9900}DISK ${hr 2}$color
/ROOT Used: $alignc ${fs_used /} / ${fs_size /} $alignr
${color FFFF33} ${fs_free_perc /}% ${fs_bar /}$color
/HOME Used: $alignc ${fs_used /home} / ${fs_size /home} $alignr
${color FFFF33} ${fs_free_perc /home}% ${fs_bar /home}$color
${color CC9900}TIME & DATE ${hr 2}$color
${color 339900}${execi 30 tail -n3 /var/log/messages | fold -w50}$color
Time: ${alignr}${time %H:%M:%S}
Date: ${alignr}${time %d.%m.%y}
${color}NET
${color}ppp0 ${addr ppp0}
${color}Down: ${downspeed ppp0}
${color}Up: ${upspeed ppp0}
${color}Total Down: ${totaldown ppp0}
${color}Total Up: ${totalup ppp0}
Danas sam testirao conky i na drugim DE (Mate, XFCE, KDE) i primetio sam problem sa tamnom pozadinom u KDE okruženju (crna pozadina ispod conky prikaza iako je postavljeno "background no"). Rešenje je dodavanje linije "own_window_argb_visual true" u .conkyrc fajl u sekciji gde se definišu osobine conky prozora. Ovaj parametar je neophodan kako bi KWin (ako njega koristite kao WM) mogao da dobije podatke o alpha kanalima i postavi adekvatnu providnost prozora. Možda nekom zatreba
Eto svideo mi se LSD conky
pa da osvežimo malo temu.
lsd.png, conkyrc i lsd_rings.lua treba da budu u istom direktorijumu, kod mene je to
a svako neka postavi kako mu odgovara i da ne zaboravi da izvrši neophodne izmene.
conkyrc:
lsd_rings.lua
Meni pravi problem prikaz temperature. Rešenja ima nekoliko. Mogu da izbacim prikaz temperature jer mi zapravo i ne koristi u conky. Mogu da postavim izlaz iz lm_sensors. Tu je problem samo pozicioniranje ostalih elemenata jer se raspored poremeti. Treća opcija je da sredim acpitemp argument iz lua fajla. Ostavljam ovako jer će možda nekome acpitemp raditi upravo ovako kako jeste.
~/conky/lsd/.conky/conkyrc:
update_interval 1
total_run_times 0
net_avg_samples 1
cpu_avg_samples 1
imlib_cache_size 0
double_buffer yes
no_buffers yes
use_xft yes
xftfont Zekton:size=9
text_buffer_size 2048
own_window_class Conky
own_window yes
own_window_type desktop
own_window_hints undecorated,sticky,skip_taskbar,skip_pager
alignment tl
gap_x 40
gap_y 50
minimum_size 265 412
default_bar_size 30 8
draw_shades no
default_color ffffff
default_shade_color 000000
color0 00d9ff
color1 ffffff
color2 ffffff
lua_load ~/conky/lsd/.conky/lsd_rings.lua
TEXT
${goto 185}${voffset -8}${color0}${font Zekton:style=bold:size=12}Stereo Hi-Fi
${goto 60}${voffset 20}${color}${font}Temperature:
#${goto 90}${voffset 15}${execi 10 sensors | grep 'temp2' | cut -c16-20}C
${goto 10}${voffset 75}${font Zekton:style=bold:size=30}${time %H:%M}${font}
${goto 166}${voffset -10}${font Zekton:style=Bold:size=9}Root
${alignc -44}${font Zekton:style=Bold:size=9}${fs_used /}
${goto 49}${voffset 45}CPU${voffset -5}${color}${goto 128}RAM
${goto 130}${font Zekton:style=Bold:size=9}${memperc}%
${goto 80}${voffset 20}${font Zekton:style=Bold:size=9}Home
${goto 80}${font Zekton:style=Bold:size=9}${fs_used /home}
${image ~/conky/lsd/.conky/lsd.png -p 10,0 -s 255x412}
require 'cairo'
--guage DATA
gauge = {
name='cpu', arg='cpu0', max_value=100,
x=60, y=265,
graph_radius=30,
graph_thickness=3,
graph_start_angle=180,
graph_unit_angle=3.599, graph_unit_thickness=2.7,
graph_bg_colour=0xffffff, graph_bg_alpha=0.2,
graph_fg_colour=0x00d9ff, graph_fg_alpha=0.4,
hand_fg_colour=0x00d9ff, hand_fg_alpha=1.0,
txt_radius=20,
txt_weight=1, txt_size=7.0,
txt_fg_colour=0xffffff, txt_fg_alpha=1.0,
graduation_radius=16,
graduation_thickness=0, graduation_mark_thickness=1,
graduation_unit_angle=36,
graduation_fg_colour=0xFFFFFF, graduation_fg_alpha=0.3,
caption='',
caption_weight=1, caption_size=9.0,
caption_fg_colour=0xFFFFFF, caption_fg_alpha=0.3,
name='acpitemp', arg='temp2', max_value=100,
x=85, y=85,
txt_weight=1, txt_size=12.0,
-- rgb_to_r_g_b
-- converts color in hexa to decimal
function rgb_to_r_g_b(colour, alpha)
return ((colour / 0x10000) % 0x100) / 255., ((colour / 0x100) % 0x100) / 255., (colour % 0x100) / 255., alpha
end
-- angle_to_position
-- convert degree to rad and rotate (0 degree is top/north)
function angle_to_position(start_angle, current_angle)
local pos = current_angle + start_angle
return ( ( pos * (2 * math.pi / 360) ) - (math.pi / 2) )
end
-- draw_gauge_ring_t
-- displays gauges
function draw_gauge_ring_t(display, data, value)
local function temp_colour(value)
if value >= 65 then
return '0xff0000'
elseif value < 65 then
return '0xffffff'
end
end
local max_value = data['max_value']
local x, y = data['x'], data['y']
local txt_radius = data['txt_radius']
local txt_weight, txt_size = data['txt_weight'], data['txt_size']
local txt_fg_colour, txt_fg_alpha = temp_colour(value), data['txt_fg_alpha']
string = tostring(value)..'°C'
cairo_select_font_face (display, "zekton", CAIRO_FONT_SLANT_NORMAL, txt_weight)
cairo_set_font_size (display, txt_size)
cairo_set_source_rgba (display, rgb_to_r_g_b(txt_fg_colour, txt_fg_alpha))
cairo_move_to (display, x, y)
cairo_show_text (display, string)
cairo_stroke (display)
end
-- draw_gauge_ring
-- displays gauges
function draw_gauge_ring(display, data, value)
local graph_radius = data['graph_radius']
local graph_thickness, graph_unit_thickness = data['graph_thickness'], data['graph_unit_thickness']
local graph_start_angle = data['graph_start_angle']
local graph_unit_angle = data['graph_unit_angle']
local graph_bg_colour, graph_bg_alpha = data['graph_bg_colour'], data['graph_bg_alpha']
local graph_fg_colour, graph_fg_alpha = data['graph_fg_colour'], data['graph_fg_alpha']
local hand_fg_colour, hand_fg_alpha = data['hand_fg_colour'], data['hand_fg_alpha']
local graph_end_angle = (max_value * graph_unit_angle) % 360
-- background ring
cairo_arc(display, x, y, graph_radius, angle_to_position(graph_start_angle, 0), angle_to_position(graph_start_angle, graph_end_angle))
cairo_set_source_rgba(display, rgb_to_r_g_b(graph_bg_colour, graph_bg_alpha))
cairo_set_line_width(display, graph_thickness)
cairo_stroke(display)
-- arc of value
local val = value % (max_value + 1)
local start_arc = 0
local stop_arc = 0
local i = 1
while i <= val do
start_arc = (graph_unit_angle * i) - graph_unit_thickness
stop_arc = (graph_unit_angle * i)
cairo_arc(display, x, y, graph_radius, angle_to_position(graph_start_angle, start_arc), angle_to_position(graph_start_angle, stop_arc))
cairo_set_source_rgba(display, rgb_to_r_g_b(graph_fg_colour, graph_fg_alpha))
i = i + 1
end
local angle = start_arc
-- hand
start_arc = (graph_unit_angle * val) - (graph_unit_thickness * 2)
stop_arc = (graph_unit_angle * val)
cairo_set_source_rgba(display, rgb_to_r_g_b(hand_fg_colour, hand_fg_alpha))
-- graduations marks
local graduation_radius = data['graduation_radius']
local graduation_thickness, graduation_mark_thickness = data['graduation_thickness'], data['graduation_mark_thickness']
local graduation_unit_angle = data['graduation_unit_angle']
local graduation_fg_colour, graduation_fg_alpha = data['graduation_fg_colour'], data['graduation_fg_alpha']
if graduation_radius > 0 and graduation_thickness > 0 and graduation_unit_angle > 0 then
local nb_graduation = graph_end_angle / graduation_unit_angle
local i = 0
while i < nb_graduation do
cairo_set_line_width(display, graduation_thickness)
start_arc = (graduation_unit_angle * i) - (graduation_mark_thickness / 2)
stop_arc = (graduation_unit_angle * i) + (graduation_mark_thickness / 2)
cairo_arc(display, x, y, graduation_radius, angle_to_position(graph_start_angle, start_arc), angle_to_position(graph_start_angle, stop_arc))
cairo_set_source_rgba(display,rgb_to_r_g_b(graduation_fg_colour,graduation_fg_alpha))
i = i + 1
end
end
-- text
local txt_fg_colour, txt_fg_alpha = data['txt_fg_colour'], data['txt_fg_alpha']
local movex = txt_radius * math.cos(angle_to_position(graph_start_angle, angle))
local movey = txt_radius * math.sin(angle_to_position(graph_start_angle, angle))
cairo_move_to (display, x + movex - (txt_size / 2), y + movey + 3)
cairo_show_text (display, value)
-- caption
local caption = data['caption']
local caption_weight, caption_size = data['caption_weight'], data['caption_size']
local caption_fg_colour, caption_fg_alpha = data['caption_fg_colour'], data['caption_fg_alpha']
local tox = graph_radius * (math.cos((graph_start_angle * 2 * math.pi / 360)-(math.pi/2)))
local toy = graph_radius * (math.sin((graph_start_angle * 2 * math.pi / 360)-(math.pi/2)))
cairo_select_font_face (display, "zekton", CAIRO_FONT_SLANT_NORMAL, caption_weight);
cairo_set_font_size (display, caption_size)
cairo_set_source_rgba (display, rgb_to_r_g_b(caption_fg_colour, caption_fg_alpha))
cairo_move_to (display, x + tox + 5, y + toy + 1)
-- bad hack but not enough time !
if graph_start_angle < 105 then
cairo_move_to (display, x + tox - 30, y + toy + 1)
end
cairo_show_text (display, caption)
end
-- go_gauge_rings
-- loads data and displays gauges
function go_gauge_rings(display)
local function load_gauge_rings(display, data)
local str, value = '', 0
str = string.format('${%s %s}',data['name'], data['arg'])
str = conky_parse(str)
value = tonumber(str)
end
local function load_gauge_rings_1(display, data)
end
-- for i in pairs(gauge) do
load_gauge_rings(display, gauge[1])
load_gauge_rings_1(display, gauge[2])
-- end
-- load_gauge_rings(display, gauge)
end
-- MAIN
function conky_main()
if conky_window == nil then
return
end
local cs = cairo_xlib_surface_create(conky_window.display, conky_window.drawable, conky_window.visual, conky_window.width, conky_window.height)
local display = cairo_create(cs)
local updates = conky_parse('${updates}')
update_num = tonumber(updates)
if update_num > 5 then
end
cairo_surface_destroy(cs)
cairo_destroy(display)
end
Prijatelj forumaoffline
Ovo je namenjeno za Ubuntu/Mint, mislim na PPA, ali source može da se izvuče i da se svašta uradi, samo ko ima živaca da se petlja http://www.teejeetech.in/p/conky-manager.html" onclick="window.open(this.href);return false; a ima svašta u tom stilu koji su postavio Stereo. Recimo LSD konki tema je slična.
Evo cele LSD teme sa .conkyrc-om i fontovima
Edit, sada gledam, to je zapravo ista tema, isto se i zove, znači LSD.
Evo šta sve ima od konki tema
4 & 2 core blue clock weather cricle clock Night Drive
4 core Colors_conky Cubes Conky NInJA conky
4core blue Computer Love dark clock NvidiaPanel
4core pink conki 12.10 dark data bar octacore
arcblack Conky 8 Deep_Blue_Conky pencil
big Conky Bar dot circle Predator
big sintinel Conky Blood Emays Scratchy
bionic Conkybox future_conky sentinel
blood conky Conky Dark 4 cores Gold&Grey sentinel-reloaded
blue breaking bad conkydots Google Conky tech-mon_reloaded
Blue stats conky-equalizer Gotham Tiles
blue_vision conky_light 4core goth white Top_Bar
box conky conky max 4 Guages Torn Paper Clone
breaking Bad 2 Conky MIUI halconky Tron
cairosidebar conky_now hanging clock Tux
cali 4core conky orange Hy-lua verti-color
cali conky conky_popup kensho waves 4core
classic clock Conky Seamod love conky Weather
clear circles Cowon Conky LSD Zrradia_conky
Clock and stats CPUPanel MaxConky
clock & data Crazy cool conky Metro
Nije to loša fora sa conky menadžerom samo ja baš volim sam, ručno da nameštam. Automatizacija za neke druge stvari
Hvala za info.
Hvala za info.
Nema na čemu.
Isto je i kod mene je tako, drugčije i ne možemo nego ručno, nego sam mislio na prilagođavanje konkija iz recimo 4-5 različitih. Momentalno me baš mrzi to da radim da bih ga sredio po mojim potrebama i ukusu tj. izgledu, i ako relativno lako može sve da se dotera.
Kod mene se ispostavilo da ova conky postavka ume da troši previše ram-a. I to odjednom negde počne da troši ram. Slutim da je problem u LUA samo ne znam tačno gde. Na kraju sam odustao od ove conky postavke.
Users browsing this forum: Claude User [Bot] and 24 guests
