Doterivanje, editovanje, razmena... conkyrc-a
Post Napisano: 16 Feb 2014, 21:14
Evo,ovako, ako nekome ne radi transparentnost conky-a na KDE-u treba da izmeni ovaj deo sto se tice samog prozora conky-a u :
own_window yes
own_window_transparent yes
own_window_argb_visual yes
own_window_type desktop
own_window_class conky-semi
own_window_hints undecorated,below,sticky,skip_taskbar,skip_pager
Post Napisano: 16 Feb 2014, 21:20
bad63r wrote:Evo,ovako, ako nekome ne radi transparentnost conky-a na KDE-u treba da izmeni ovaj deo sto se tice samog prozora conky-a u :
own_window yes
Ključni deo je
jer uključuje real transparency u novijim verzijama programa. Čini mi se od 1.8.
EDIT: bad63r daj screenshot :)
Post Napisano: 16 Feb 2014, 21:30
Evo ga :) Image
a evo i kod za conky(stereov conky sa malim ispravkama):
background no
font Sans:size=8
#xftfont Sans:size=10
use_xft yes
xftalpha 0.9
update_interval 3.0
total_run_times 0
own_window yes
double_buffer yes
minimum_size 220 5
maximum_width 220
draw_shades yes
draw_outline no
draw_borders no
draw_graph_borders yes
default_color white
default_shade_color black
default_outline_color green
alignment top_right
gap_x 12
gap_y 80
no_buffers yes
uppercase no
cpu_avg_samples 2
override_utf8_locale no
uppercase yes # set to yes if you want all text to be in uppercase
TEXT
${color white}SYSTEM ${hr 1}${color}
Hostname:             $alignr$nodename
Kernel: $alignr$kernel
Uptime: $alignr$uptime
CPU: ${alignr}${freq} MHz
Processes: ${alignr}$processes ($running_processes running)
Load: ${alignr}$loadavg
CPU1 ${alignr}${cpu cpu1}%
${cpubar 4 cpu1}
CPU2 ${alignr}${cpu cpu2}%
${cpubar 4 cpu2}
Ram ${alignr}$mem / $memmax ($memperc%)
${membar 4}
swap ${alignr}$swap / $swapmax ($swapperc%)
${swapbar 4}
Highest CPU $alignr CPU% MEM%
${top name 1}$alignr${top cpu 1}${top mem 1}
${top name 2}$alignr${top cpu 2}${top mem 2}
${top name 3}$alignr${top cpu 3}${top mem 3}
Highest MEM $alignr CPU% MEM%
${top_mem name 1}$alignr${top_mem cpu 1}${top_mem mem 1}
${top_mem name 2}$alignr${top_mem cpu 2}${top_mem mem 2}
${top_mem name 3}$alignr${top_mem cpu 3}${top_mem mem 3}
${color white}Filesystem ${hr 1}${color}
Root: ${alignr}${fs_free /} / ${fs_size /}
${fs_bar 4 /}
Home: ${alignr}${fs_free /home} / ${fs_size /home}
${fs_bar 4 /home}
${color white}NETWORK ${hr 1}${color}
Down ${downspeed wlan0} k/s ${alignr}Up ${upspeed wlan0} k/s
${downspeedgraph wlan0 25,107} ${alignr}${upspeedgraph wlan0 25,107}
Total ${totaldown wlan0} ${alignr}Total ${totalup wlan0}
Hvala @TildaTurn na resavanju problema :grlj:
Post Napisano: 16 Feb 2014, 21:43
own_window yes
drummer wrote:Danas sam testirao conky i na drugim DE (Mate, XFCE, KDE) i primetio sam problem sa tamnom pozadinom u KDE okruženju (crna pozadina ispod conky prikaza iako je postavljeno "background no"). Rešenje je dodavanje linije "own_window_argb_visual true" u .conkyrc fajl u sekciji gde se definišu osobine conky prozora. Ovaj parametar je neophodan kako bi KWin (ako njega koristite kao WM) mogao da dobije podatke o alpha kanalima i postavi adekvatnu providnost prozora. Možda nekom zatreba :)
Ponekad je dovoljno samo prelistati prethodne stranice teme u kojoj se piše...
Post Napisano: 21 Feb 2014, 13:55
@drummer... Sry
Ma veruj mi od silne nervoze sto ne radi i sto sam tolko puta preveslao forum, verovatno sam prevideo to sto si napisao...
Post Napisano: 21 Feb 2014, 14:03
Ma polako, ne polažeš ispit. :cheesy:
Manje više ono što tebi sada treba u ovom momentu to imaš već nekoliko puta pisano na forumu zajenice.
Takođe baci pogled i na Viki stranice i dokumentaciju.
Post Napisano: 10 Aug 2014, 14:08
Suuuuny_conky_by_BigRZA_mod.tar.gz
conky + pozadina (podešen za rezoluciju laptopa 1366x768)
(500.74 KiB) Downloaded 659 times
Original:
http://www.deviantart.com/art/Suuuuny-conky-153331007
Post Napisano: 10 Aug 2014, 19:00
Baš sam hteo da te pitam da ostaviš neki info u ovoj temi :)
Hvala :)
Post Napisano: 21 Sep 2014, 15:50
Malo sam se igrao :) nisam odavno pa ajde... svakako ne mogu da nađem odgovarajući cokny setup pa sam stavio samo sat i to nešto malo drugačiji ;)
conkyrc:
background no
update_interval 1
double_buffer yes
no_buffers yes
text_buffer_size 2048
imlib_cache_size 0
own_window yes
own_window_type override
border_inner_margin 0
border_outer_margin 0
minimum_size 250 250
maximum_width 250
alignment tl
gap_x 50
gap_y 50
draw_shades yes
draw_outline no
draw_borders no
draw_graph_borders no
use_xft yes
xftfont pftempestafivecondensed:size=10
xftalpha 0.5
uppercase no
default_color B0171F
color1 000000
lua_load /home/zeljko/conky/clock.lua
lua_draw_hook_pre draw_clock
TEXT
clock.lua:
require 'cairo'
function conky_draw_clock()
	if conky_window==nil then return end
	local w=conky_window.width
	local h=conky_window.height
	local cs=cairo_xlib_surface_create(conky_window.display, conky_window.drawable, conky_window.visual, w, h)
	cr=cairo_create(cs)
	-- Settings
		-- What radius should the clock face (not including border) be, in pixels?
		local clock_r=60
		-- x and y coordinates, relative to the top left corner of Conky, in pixels
		local xc=w/2
		local yc=h/2
		-- Extent of the shadow, in pixels
		shadow_width=5
		-- x and y offsets of the drop shadow, relative to the centre of the clock face, in pixels. Can be positive (downward) or negative (upward)
		shadow_xoffset=0
		shadow_yoffset=2
		-- Do you want to show the second hand? Use this if you use a Conky update_interval > 1s. Can be true or false.
		show_seconds=true
	-- Grab time
	local hours=os.date("%I")
	local mins=os.date("%M")
	local secs=os.date("%S")
	secs_arc=(2*math.pi/60)*secs
	mins_arc=(2*math.pi/60)*mins
	hours_arc=(2*math.pi/12)*hours+mins_arc/12
	-- Draw hour hand
	xh=xc+0.9*clock_r*math.sin(hours_arc)
	yh=yc-0.9*clock_r*math.cos(hours_arc)
	cairo_move_to(cr,xc,yc)
	cairo_line_to(cr,xh,yh)
	cairo_set_line_cap(cr,CAIRO_LINE_CAP_ROUND)
	cairo_set_line_width(cr,5)
	cairo_set_source_rgba(cr,1,1,1,0.5)
	cairo_stroke(cr)
	-- Draw minute hand
	xm=xc+1.3*clock_r*math.sin(mins_arc)
	ym=yc-1.3*clock_r*math.cos(mins_arc)
	cairo_line_to(cr,xm,ym)
	cairo_set_line_width(cr,3)
	cairo_stroke(cr)
	-- Draw seconds hand
	if show_seconds then
		xs=xc+1.1*clock_r*math.sin(secs_arc)
		ys=yc-1.1*clock_r*math.cos(secs_arc)
		cairo_line_to(cr,xs,ys)
		cairo_set_line_width(cr,1)
		cairo_stroke(cr)
	end
end
A evo i scrot-a
Post Napisano: 21 Sep 2014, 19:40
E ja te moram moliti za ovaj wallpaper! :)
