GMountMan is a graphical mount manager
for local devices, written in GTK+2 that uses gvfs for all mounting operations.
Jednostavno pregledan i brz.
Using GMountMan, you don't have to revert
to the terminal and mount plugged devices manually any more.
It's built using GTK+2 and it has been designed
from the beginning with keyboard navigation and usage in mind,
although it can be also used just as easily with a mouse.
http://download.salixos.org/i486/13.37/ ... gmountman/
http://slackware.org.uk/salix/x86_64/13 ... gmountman/
Salix is a linux distribution based on Slackware
and aims to be completely backwards compatible with Slackware,
so Slackware users can benefit from Salix repositories.
P.S.
Long live linux
GMountMan - graphical mount manager
Poznata ličnostoffline
Administratoroffline
Samo ako mogu da zamolim za prevod. Neki iz ekipe se ne snalaze najbolje sa engleskim.
GMountMan je graficki mount menadzer
za lokalne uredjaje, pisan u GTK +2
koji koristi gvfs za sve operacije montiranja.
Koristeci GMountMan,
ne morate se vracati u terminal i rucno montirati lokalne uredjaje.
Napisan je u GTK +2 i od pocetka je dizajniran
da se lagano i jednostavno koristi uz pomoc tastature i mis-a.
Salix je linux distribucija zasnovana na Slackware linux-u
i potpuno je kompatibilna sa Slackware linux-om,
Slackware korisnici mogu slobodno koristi Salix repozitorijum-e.
P.S.
Dug zivot linux-u (Ziveo linux)
P.S.
