Problemi sa zvukom
Post Napisano: 16 May 2012, 13:44
Nedavno prilikom butanja sistema sam dobijao upozorenje oko /etc/modprobe.conf i /etc/modprobe.d/ ali nisam stizao da vidim o čemu je reč.
Od pre neki dan, bilo u Xfce-u ili Gnome grafičkom okruženju, deašava mi se da nestane zvuka pa potom se pojavi i tako ide po principu vruće-hladno.
bash-4.1# lspci
00:00.0 Host bridge: Intel Corporation 82G33/G31/P35/P31 Express DRAM Controller (rev 10)
00:01.0 PCI bridge: Intel Corporation 82G33/G31/P35/P31 Express PCI Express Root Port (rev 10)
00:1b.0 Audio device: Intel Corporation N10/ICH 7 Family High Definition Audio Controller (rev 01)
00:1c.0 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 1 (rev 01)
00:1c.1 PCI bridge: Intel Corporation N10/ICH 7 Family PCI Express Port 2 (rev 01)
00:1d.0 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #1 (rev 01)
00:1d.1 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #2 (rev 01)
00:1d.2 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #3 (rev 01)
00:1d.3 USB Controller: Intel Corporation N10/ICH 7 Family USB UHCI Controller #4 (rev 01)
00:1d.7 USB Controller: Intel Corporation N10/ICH 7 Family USB2 EHCI Controller (rev 01)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev e1)
00:1f.0 ISA bridge: Intel Corporation 82801GB/GR (ICH7 Family) LPC Interface Bridge (rev 01)
00:1f.1 IDE interface: Intel Corporation 82801G (ICH7 Family) IDE Controller (rev 01)
00:1f.2 IDE interface: Intel Corporation N10/ICH7 Family SATA IDE Controller (rev 01)
00:1f.3 SMBus: Intel Corporation N10/ICH 7 Family SMBus Controller (rev 01)
01:00.0 VGA compatible controller: nVidia Corporation G94 [GeForce 9600 GT] (rev a1)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller (rev 01)
Prilikom unosa komande modprobe snd-hda-intel dobijem ovaj izlaz
bash-4.1# modprobe snd-hda-intel
WARNING: Deprecated config file /etc/modprobe.conf, all config files belong into /etc/modprobe.d/.
S tim da je fajl /etc/modprobe.conf potpuno prazan, dok u /etc/modprobe.d imam sledeće
blacklist.conf			       psmouse.conf
bluetooth.conf			       sound.conf
disable-nouveau.conf		       usb-controller.conf
isapnp.conf			       vmware-fuse.conf
nvidia-installer-disable-nouveau.conf
Možda će pomoći sadržaji fajlova blacklist.conf
bash-4.1$ cat blacklist.conf
# Listing a module here prevents the hotplug scripts from loading it.
# Usually that'd be so that some other driver will bind it instead,
# no matter which driver happens to get probed first.  Sometimes user
# mode tools can also control driver binding.
# PC Speaker support:
# This one is loaded by /etc/rc.d/rc.modules. If you don't like
# the beeps and buzz from speaker, edit /etc/rc.d/rc.modules.
blacklist pcspkr
# tulip ... de4x5, xircom_tulip_cb, dmfe (...) handle same devices
blacklist de4x5
# At least 2.4.3 and later xircom_tulip doesn't have that conflict
# xircom_tulip_cb
blacklist dmfe
#evbug is a debug tool and should be loaded explicitly
blacklist evbug
# Alternate Intel EtherExpress Pro/100 support driver.  List it
# here so it won't conflict with an already-loaded e100 module.
blacklist eepro100
# Alternate 8139 driver.  Some 8139 cards need this specific driver,
# though...
blacklist 8139cp
# Deprecated BCM4318 driver.
blacklist bcm43xx
# Modules used to run a wireless adaptor as an access point.  These
# conflict with the normal driver for the device, and so should be
# loaded manually.
blacklist hostap_cs
blacklist hostap_pci
blacklist hostap_plx
blacklist hostap
# Ethernet over IEEE1394 module.  In too many cases this will load
# when there's no eth1394 device present (just an IEEE1394 port)
blacklist eth1394
# This module has also been known to cause crashes with some hardware.
blacklist hw_random
# The kernel lists this as "experimental", but for now it's "broken"
blacklist via-ircc
# ALSA modules to support sound modems.  These should be loaded manually
# if needed.  For most people they just break sound support...
blacklist snd-atiixp-modem
blacklist snd-intel8x0m
blacklist snd-via82xx-modem
# OSS (Open Sound System) modules.  This is the old and deprecated Linux
# sound system.  If you want to use OSS, remove the alsa-driver package
# and cut out (or comment out) this list.  With these modules
# blacklisted ALSA will load by default.
blacklist ac97
blacklist ac97_codec
blacklist aci
blacklist ad1816
blacklist ad1848
blacklist ad1889
blacklist adlib_card
blacklist aedsp16
blacklist ali5455
blacklist awe_wave
blacklist btaudio
blacklist cmpci
blacklist cs4232
blacklist cs4281
blacklist cs46xx
blacklist emu10k1
blacklist es1370
blacklist es1371
blacklist esssolo1
blacklist forte
blacklist gus
blacklist i810_audio
blacklist kahlua
blacklist mad16
blacklist maestro
blacklist maestro3
blacklist maui
blacklist mpu401
blacklist msnd
blacklist msnd_classic
blacklist msnd_pinnacle
blacklist nm256_audio
blacklist opl3
blacklist opl3sa
blacklist opl3sa2
blacklist pas2
blacklist pss
blacklist rme96xx
blacklist sb
blacklist sb_lib
blacklist sgalaxy
blacklist sonicvibes
blacklist sound
blacklist sscape
blacklist trident
blacklist trix
blacklist uart401
blacklist uart6850
blacklist v_midi
blacklist via82cxxx_audio
blacklist wavefront
blacklist ymfpci
# Hardware specific video framebuffer modules.  If the user wants
# these, they can load them manually or de-blacklist them.  Having
# them load automatically may lead to funny side effects with
# certain revisions of video hardware.
blacklist arcfb
blacklist aty128fb
blacklist atyfb
blacklist cirrusfb
blacklist clgenfb
blacklist cyber2000fb
blacklist fbcon-cfb2
blacklist fbcon-cfb4
blacklist fbcon-hga
blacklist fbcon-mfb
blacklist fbcon-vga-planes
blacklist fbgen
blacklist hgafb
blacklist i2c-matroxfb
blacklist i810fb
blacklist intelfb
blacklist kyrofb
blacklist matroxfb_DAC1064
blacklist matroxfb_Ti3026
blacklist matroxfb_accel
blacklist matroxfb_base
blacklist matroxfb_crtc2
blacklist matroxfb_g450
blacklist matroxfb_maven
blacklist matroxfb_misc
blacklist neofb
blacklist nvidiafb
blacklist pm2fb
blacklist pm3fb
blacklist radeonfb
blacklist rivafb
blacklist savagefb
blacklist sisfb
blacklist sstfb
blacklist tdfxfb
blacklist tridentfb
blacklist vga16fb
# SCSI and SATA controller modules.  Typically these are either
# built into the kernel or loaded with an initrd already.
blacklist 3w-xxxx
blacklist 53c7,8xx
blacklist AM53C974
blacklist BusLogic
blacklist NCR53c406a
blacklist a100u2w
blacklist advansys
blacklist aha152x
blacklist aha1542
blacklist aha1740
blacklist aic79xx
blacklist aic7xxx
blacklist aic7xxx_old
blacklist aic94xx
blacklist ata_piix
blacklist atp870u
blacklist cpqfc
blacklist dc395x
blacklist dmx3191d
blacklist dpt_i2o
blacklist dtc
blacklist eata
blacklist eata_dma
blacklist eata_pio
blacklist fdomain
blacklist g_NCR5380
blacklist g_NCR5380_mmio
blacklist gdth
blacklist ide-scsi
blacklist imm
blacklist in2000
blacklist initio
blacklist ipr
blacklist ips
blacklist libata
blacklist megaraid
blacklist ncr53c8xx
blacklist nsp32
blacklist osst
blacklist pas16
blacklist pci2000
blacklist pci2220i
blacklist ppa
blacklist psi240i
blacklist qla1280
blacklist qla2100
blacklist qla2200
blacklist qla2300
blacklist qla2322
blacklist qla2xxx
blacklist qla6312
blacklist qla6322
blacklist qlogicfas
blacklist qlogicfas408
blacklist qlogicfc
blacklist qlogicisp
blacklist seagate
blacklist sim710
blacklist sata_promise
blacklist sata_sil
blacklist sata_sis
blacklist sata_svw
blacklist sata_sx4
blacklist sata_via
blacklist sata_vsc
blacklist scsi_debug
blacklist scsi_transport_fc
blacklist scsi_transport_spi
blacklist sym53c416
blacklist sym53c8xx
blacklist sym53c8xx
blacklist t128
blacklist tmscsim
blacklist u14-34f
# Blacklist all watchdog modules. Many motherboards hangs with them and,
# if you really need an watchdog you probably know how to load the module
blacklist acquirewdt
blacklist advantechwdt
blacklist alim1535_wdt
blacklist alim7101_wdt
blacklist cpu5wdt
blacklist eurotechwdt
blacklist hpwdt
blacklist i6300esb
blacklist iTCO_vendor_support
blacklist iTCO_wdt
blacklist ib700wdt
blacklist ibmasr
blacklist it8712f_wdt
blacklist machzwd
blacklist mixcomwd
blacklist pc87413_wdt
blacklist pcwd
blacklist pcwd_pci
blacklist pcwd_usb
blacklist sbc60xxwdt
blacklist sbc7240_wdt
blacklist sbc8360
blacklist sbc_epx_c3
blacklist sc1200wdt
blacklist sc520_wdt
blacklist scx200_wdt
blacklist smsc37b787_wdt
blacklist softdog
blacklist w83627hf_wdt
blacklist w83697hf_wdt
blacklist w83877f_wdt
blacklist w83977f_wdt
blacklist wafer5823wdt
blacklist wdt
blacklist wdt_pci
blacklist nouveau
kao i sound.conf
bash-4.1$ cat sound.conf
# --- BEGIN: Generated by ALSACONF, do not edit. ---
# --- ALSACONF version 1.0.24.2 ---
alias snd-card-0 snd-opl3sa2
alias sound-slot-0 snd-opl3sa2
options snd-opl3sa2 fm_port=-1 midi_port=-1 port=0x370 wss_port=0x530 isapnp=0 dma1=1 dma2=0 irq=5
# --- END: Generated by ALSACONF, do not edit. ---
Post Napisano: 16 May 2012, 13:47
Da nemaš možda instaliran pulseaudio?
Post Napisano: 16 May 2012, 16:06
Imam, ali on ne radi.
Connection failed: Connection refused
Pored njega imam i PluseAudio Manager kao PluseAudio Device Chooser, ali to imam duže vremena instalirano.
Odmah po instalacije Gnome grafičkog okruženja, znači ima nekih 3-4 meseca, instlirao sam i njih.
Post Napisano: 16 May 2012, 18:20
Probaj da deinstaliraš Pulseaudio i restartuj računar. Da li se nešto promenilo?
Post Napisano: 16 May 2012, 19:47
Za divno čudo danas mi se to nije javljalo. :huh:
Da vidimo još malo kako će ići ovako pa ću ih lako deinstalirati i ovako skoro ništa od toga ne radi.
