Ima li neko rešenje?
Hvala unapred.
[ 13.637]
X.Org X Server 1.12.2
Release Date: 2012-05-29
[ 13.637] X Protocol Version 11, Revision 0
[ 13.637] Build Operating System: Linux 3.0.32-1-lts i686
[ 13.637] Current Operating System: Linux laptopic 3.4.4-2-ARCH #1 SMP PREEMPT Sun Jun 24 17:28:37 UTC 2012 i686
[ 13.637] Kernel command line: root=/dev/disk/by-uuid/fcb6328a-6ee4-4ce0-a224-68502bb4f2db ro
[ 13.638] Build Date: 30 May 2012 07:28:16PM
[ 13.638]
[ 13.638] Current version of pixman: 0.26.0
[ 13.638] Before reporting problems, check http://wiki.x.org
[ 13.638] Markers: (--) probed, (**) from config file, (==) default setting,
[ 13.638] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Jun 30 01:45:25 2012
[ 13.688] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 13.749] (==) No Layout section. Using the first Screen section.
[ 13.749] (==) No screen section available. Using defaults.
[ 13.749] (**) |-->Screen "Default Screen Section" (0)
[ 13.749] (**) | |-->Monitor "<default monitor>"
[ 13.749] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 13.749] (==) Automatically adding devices
[ 13.749] (==) Automatically enabling devices
[ 13.827] (WW) The directory "/usr/share/fonts/OTF/" does not exist.
[ 13.827] Entry deleted from font path.
[ 13.916] (==) FontPath set to:
/usr/share/fonts/misc/,
/usr/share/fonts/TTF/,
/usr/share/fonts/Type1/,
/usr/share/fonts/100dpi/,
/usr/share/fonts/75dpi/
[ 13.916] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 13.916] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 13.916] (II) Loader magic: 0x82225a0
[ 13.916] (II) Module ABI versions:
[ 13.916] X.Org ANSI C Emulation: 0.4
[ 13.916] X.Org Video Driver: 12.0
[ 13.916] X.Org XInput driver : 16.0
[ 13.916] X.Org Server Extension : 6.0
[ 13.918] (--) PCI:*(0:0:2:0) 8086:2a02:1043:14e2 rev 3, Mem @ 0xfeb00000/1048576, 0xd0000000/268435456, I/O @ 0x0000ec00/8
[ 13.918] (--) PCI: (0:0:2:1) 8086:2a03:1043:14e2 rev 3, Mem @ 0xfe900000/1048576
[ 13.918] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 13.919] (II) LoadModule: "extmod"
[ 13.934] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
[ 13.939] (II) Module extmod: vendor="X.Org Foundation"
[ 13.939] compiled for 1.12.2, module version = 1.0.0
[ 13.939] Module class: X.Org Server Extension
[ 13.939] ABI class: X.Org Server Extension, version 6.0
[ 13.939] (II) Loading extension MIT-SCREEN-SAVER
[ 13.939] (II) Loading extension XFree86-VidModeExtension
[ 13.939] (II) Loading extension XFree86-DGA
[ 13.939] (II) Loading extension DPMS
[ 13.939] (II) Loading extension XVideo
[ 13.939] (II) Loading extension XVideo-MotionCompensation
[ 13.939] (II) Loading extension X-Resource
[ 13.939] (II) LoadModule: "dbe"
[ 13.940] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[ 13.941] (II) Module dbe: vendor="X.Org Foundation"
[ 13.941] compiled for 1.12.2, module version = 1.0.0
[ 13.941] Module class: X.Org Server Extension
[ 13.941] ABI class: X.Org Server Extension, version 6.0
[ 13.941] (II) Loading extension DOUBLE-BUFFER
[ 13.941] (II) LoadModule: "glx"
[ 13.941] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 13.949] (II) Module glx: vendor="X.Org Foundation"
[ 13.949] compiled for 1.12.2, module version = 1.0.0
[ 13.949] ABI class: X.Org Server Extension, version 6.0
[ 13.949] (==) AIGLX enabled
[ 13.949] (II) Loading extension GLX
[ 13.949] (II) LoadModule: "record"
[ 13.949] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
[ 13.950] (II) Module record: vendor="X.Org Foundation"
[ 13.950] compiled for 1.12.2, module version = 1.13.0
[ 13.950] Module class: X.Org Server Extension
[ 13.950] ABI class: X.Org Server Extension, version 6.0
[ 13.950] (II) Loading extension RECORD
[ 13.950] (II) LoadModule: "dri"
[ 13.950] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[ 13.959] (II) Module dri: vendor="X.Org Foundation"
[ 13.959] compiled for 1.12.2, module version = 1.0.0
[ 13.959] ABI class: X.Org Server Extension, version 6.0
[ 13.959] (II) Loading extension XFree86-DRI
[ 13.959] (II) LoadModule: "dri2"
[ 13.959] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[ 13.960] (II) Module dri2: vendor="X.Org Foundation"
[ 13.960] compiled for 1.12.2, module version = 1.2.0
[ 13.960] ABI class: X.Org Server Extension, version 6.0
[ 13.960] (II) Loading extension DRI2
[ 13.960] (==) Matched intel as autoconfigured driver 0
[ 13.960] (==) Matched vesa as autoconfigured driver 1
[ 13.960] (==) Matched fbdev as autoconfigured driver 2
[ 13.960] (==) Assigned the driver to the xf86ConfigLayout
[ 13.960] (II) LoadModule: "intel"
[ 13.963] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 13.982] (II) Module intel: vendor="X.Org Foundation"
[ 13.982] compiled for 1.12.2, module version = 2.19.0
[ 13.982] Module class: X.Org Video Driver
[ 13.982] ABI class: X.Org Video Driver, version 12.0
[ 13.983] (II) LoadModule: "vesa"
[ 13.983] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 13.987] (II) Module vesa: vendor="X.Org Foundation"
[ 13.987] compiled for 1.12.0, module version = 2.3.1
[ 13.987] Module class: X.Org Video Driver
[ 13.987] ABI class: X.Org Video Driver, version 12.0
[ 13.987] (II) LoadModule: "fbdev"
[ 13.987] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 14.000] (II) Module fbdev: vendor="X.Org Foundation"
[ 14.000] compiled for 1.11.99.903, module version = 0.4.2
[ 14.000] ABI class: X.Org Video Driver, version 12.0
[ 14.000] (II) intel: Driver for Intel Integrated Graphics Chipsets: i810,
i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G, 915G,
E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM, Pineview G,
965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33, GM45,
4 Series, G45/G43, Q45/Q43, G41, B43, B43, Clarkdale, Arrandale,
Sandybridge Desktop (GT1), Sandybridge Desktop (GT2),
Sandybridge Desktop (GT2+), Sandybridge Mobile (GT1),
Sandybridge Mobile (GT2), Sandybridge Mobile (GT2+),
Sandybridge Server, Ivybridge Mobile (GT1), Ivybridge Mobile (GT2),
Ivybridge Desktop (GT1), Ivybridge Desktop (GT2), Ivybridge Server,
Ivybridge Server (GT2)
[ 14.001] (II) VESA: driver for VESA chipsets: vesa
[ 14.001] (II) FBDEV: driver for framebuffer: fbdev
[ 14.001] (++) using VT number 7
[ 14.026] (WW) Falling back to old probe method for vesa
[ 14.026] (WW) Falling back to old probe method for fbdev
[ 14.026] (II) Loading sub module "fbdevhw"
[ 14.026] (II) LoadModule: "fbdevhw"
[ 14.026] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 14.037] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 14.037] compiled for 1.12.2, module version = 0.0.2
[ 14.037] ABI class: X.Org Video Driver, version 12.0
[ 14.038] drmOpenDevice: node name is /dev/dri/card0
[ 14.038] drmOpenDevice: open result is 8, (OK)
[ 14.038] drmOpenByBusid: Searching for BusID pci:0000:00:02.0
[ 14.038] drmOpenByBusid: drmOpenMinor returns 8
[ 14.038] drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
[ 14.038] (II) intel(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 14.038] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[ 14.038] (==) intel(0): RGB weight 888
[ 14.038] (==) intel(0): Default visual is TrueColor
[ 14.038] (II) intel(0): Integrated Graphics Chipset: Intel(R) 965GM
[ 14.038] (--) intel(0): Chipset: "965GM"
[ 14.038] (**) intel(0): Relaxed fencing enabled
[ 14.038] (**) intel(0): Wait on SwapBuffers? enabled
[ 14.038] (**) intel(0): Triple buffering? enabled
[ 14.038] (**) intel(0): Framebuffer tiled
[ 14.038] (**) intel(0): Pixmaps tiled
[ 14.038] (**) intel(0): 3D buffers tiled
[ 14.038] (**) intel(0): SwapBuffers wait enabled
[ 14.038] (==) intel(0): video overlay key set to 0x101fe
[ 14.039] (II) intel(0): Output LVDS1 has no monitor section
[ 14.039] (II) intel(0): found backlight control interface /sys/class/backlight/acpi_video0
[ 14.056] (II) intel(0): Output VGA1 has no monitor section
[ 14.057] (II) intel(0): EDID for output LVDS1
[ 14.057] (II) intel(0): Manufacturer: CMO Model: 1554 Serial#: 0
[ 14.057] (II) intel(0): Year: 2007 Week: 40
[ 14.057] (II) intel(0): EDID Version: 1.3
[ 14.057] (II) intel(0): Digital Display Input
[ 14.057] (II) intel(0): Max Image Size [cm]: horiz.: 33 vert.: 21
[ 14.057] (II) intel(0): Gamma: 2.20
[ 14.057] (II) intel(0): No DPMS capabilities specified
[ 14.057] (II) intel(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 14.057] (II) intel(0): First detailed timing is preferred mode
[ 14.057] (II) intel(0): redX: 0.602 redY: 0.340 greenX: 0.306 greenY: 0.530
[ 14.057] (II) intel(0): blueX: 0.151 blueY: 0.120 whiteX: 0.313 whiteY: 0.329
[ 14.057] (II) intel(0): Manufacturer's mask: 0
[ 14.057] (II) intel(0): Supported detailed timing:
[ 14.057] (II) intel(0): clock: 71.0 MHz Image Size: 331 x 207 mm
[ 14.057] (II) intel(0): h_active: 1280 h_sync: 1328 h_sync_end 1360 h_blank_end 1440 h_border: 0
[ 14.057] (II) intel(0): v_active: 800 v_sync: 803 v_sync_end 809 v_blanking: 823 v_border: 0
[ 14.057] (II) intel(0): N154I3-L03
[ 14.057] (II) intel(0): CMO
[ 14.057] (II) intel(0): EDID (in hex):
[ 14.057] (II) intel(0): 00ffffffffffff000daf541500000000
[ 14.057] (II) intel(0): 28110103802115780a07f59a574e8726
[ 14.057] (II) intel(0): 1e505400000001010101010101010101
[ 14.057] (II) intel(0): 010101010101bc1b00a0502017303020
[ 14.057] (II) intel(0): 36004bcf10000018000000fe004e3135
[ 14.057] (II) intel(0): 3449332d4c30330a2020000000fe0043
[ 14.057] (II) intel(0): 4d4f0a202020202020202020000000fe
[ 14.057] (II) intel(0): 004e31353449332d4c30330a202000a5
[ 14.057] (II) intel(0): EDID vendor "CMO", prod id 5460
[ 14.057] (II) intel(0): Printing DDC gathered Modelines:
[ 14.057] (II) intel(0): Modeline "1280x800"x0.0 71.00 1280 1328 1360 1440 800 803 809 823 -hsync -vsync (49.3 kHz eP)
[ 14.058] (II) intel(0): Not using default mode "320x240" (doublescan mode not supported)
[ 14.058] (II) intel(0): Not using default mode "400x300" (doublescan mode not supported)
[ 14.058] (II) intel(0): Not using default mode "512x384" (doublescan mode not supported)
[ 14.058] (II) intel(0): Not using default mode "640x480" (doublescan mode not supported)
[ 14.058] (II) intel(0): Not using default mode "640x512" (doublescan mode not supported)
[ 14.058] (II) intel(0): Not using default mode "800x600" (doublescan mode not supported)
[ 14.058] (II) intel(0): Not using default mode "896x672" (doublescan mode not supported)
[ 14.058] (II) intel(0): Not using default mode "928x696" (doublescan mode not supported)
[ 14.058] (II) intel(0): Not using default mode "960x720" (doublescan mode not supported)
[ 14.058] (II) intel(0): Not using default mode "700x525" (doublescan mode not supported)
[ 14.058] (II) intel(0): Not using default mode "1024x768" (doublescan mode not supported)
[ 14.058] (II) intel(0): Printing probed modes for output LVDS1
[ 14.058] (II) intel(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 -hsync -vsync (49.3 kHz eP)
[ 14.058] (II) intel(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 14.058] (II) intel(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 14.058] (II) intel(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 14.058] (II) intel(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 14.076] (II) intel(0): EDID for output VGA1
[ 14.076] (II) intel(0): Output LVDS1 connected
[ 14.076] (II) intel(0): Output VGA1 disconnected
[ 14.076] (II) intel(0): Using exact sizes for initial modes
[ 14.077] (II) intel(0): Output LVDS1 using initial mode 1280x800
[ 14.077] (II) intel(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[ 14.077] (II) intel(0): Kernel page flipping support detected, enabling
[ 14.077] (**) intel(0): Display dimensions: (330, 210) mm
[ 14.077] (**) intel(0): DPI set to (98, 96)
[ 14.077] (II) Loading sub module "fb"
[ 14.077] (II) LoadModule: "fb"
[ 14.077] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 14.079] (II) Module fb: vendor="X.Org Foundation"
[ 14.080] compiled for 1.12.2, module version = 1.0.0
[ 14.080] ABI class: X.Org ANSI C Emulation, version 0.4
[ 14.080] (II) Loading sub module "dri2"
[ 14.080] (II) LoadModule: "dri2"
[ 14.080] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[ 14.080] (II) Module dri2: vendor="X.Org Foundation"
[ 14.080] compiled for 1.12.2, module version = 1.2.0
[ 14.080] ABI class: X.Org Server Extension, version 6.0
[ 14.080] (II) UnloadModule: "vesa"
[ 14.080] (II) Unloading vesa
[ 14.080] (II) UnloadModule: "fbdev"
[ 14.080] (II) Unloading fbdev
[ 14.080] (II) UnloadSubModule: "fbdevhw"
[ 14.080] (II) Unloading fbdevhw
[ 14.080] (==) Depth 24 pixmap format is 32 bpp
[ 14.080] (II) intel(0): [DRI2] Setup complete
[ 14.080] (II) intel(0): [DRI2] DRI driver: i965
[ 14.080] (II) intel(0): Allocated new frame buffer 1280x800 stride 5120, tiled
[ 14.105] (II) UXA(0): Driver registered support for the following operations:
[ 14.105] (II) solid
[ 14.105] (II) copy
[ 14.105] (II) composite (RENDER acceleration)
[ 14.105] (II) put_image
[ 14.105] (II) get_image
[ 14.105] (==) intel(0): Backing store disabled
[ 14.105] (==) intel(0): Silken mouse enabled
[ 14.105] (II) intel(0): Initializing HW Cursor
[ 14.105] (II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 14.111] (==) intel(0): DPMS enabled
[ 14.111] (==) intel(0): Intel XvMC decoder enabled
[ 14.111] (II) intel(0): Set up textured video
[ 14.111] (II) intel(0): Set up overlay video
[ 14.111] (II) intel(0): [XvMC] i965_xvmc driver initialized.
[ 14.111] (II) intel(0): direct rendering: DRI2 Enabled
[ 14.111] (==) intel(0): hotplug detection: "enabled"
[ 14.140] (--) RandR disabled
[ 14.140] (II) Initializing built-in extension Generic Event Extension
[ 14.140] (II) Initializing built-in extension SHAPE
[ 14.140] (II) Initializing built-in extension MIT-SHM
[ 14.140] (II) Initializing built-in extension XInputExtension
[ 14.140] (II) Initializing built-in extension XTEST
[ 14.140] (II) Initializing built-in extension BIG-REQUESTS
[ 14.140] (II) Initializing built-in extension SYNC
[ 14.140] (II) Initializing built-in extension XKEYBOARD
[ 14.140] (II) Initializing built-in extension XC-MISC
[ 14.140] (II) Initializing built-in extension SECURITY
[ 14.140] (II) Initializing built-in extension XINERAMA
[ 14.140] (II) Initializing built-in extension XFIXES
[ 14.140] (II) Initializing built-in extension RENDER
[ 14.140] (II) Initializing built-in extension RANDR
[ 14.140] (II) Initializing built-in extension COMPOSITE
[ 14.140] (II) Initializing built-in extension DAMAGE
[ 14.280] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[ 14.280] (II) AIGLX: enabled GLX_INTEL_swap_event
[ 14.280] (II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control
[ 14.280] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[ 14.280] (II) AIGLX: Loaded and initialized i965
[ 14.280] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 14.281] (II) intel(0): Setting screen physical size to 338 x 211
[ 14.755] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 14.755] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 14.755] (II) LoadModule: "evdev"
[ 14.756] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 14.770] (II) Module evdev: vendor="X.Org Foundation"
[ 14.770] compiled for 1.12.0, module version = 2.7.0
[ 14.770] Module class: X.Org XInput Driver
[ 14.770] ABI class: X.Org XInput driver, version 16.0
[ 14.770] (II) Using input driver 'evdev' for 'Power Button'
[ 14.770] (**) Power Button: always reports core events
[ 14.770] (**) evdev: Power Button: Device: "/dev/input/event3"
[ 14.770] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 14.770] (--) evdev: Power Button: Found keys
[ 14.770] (II) evdev: Power Button: Configuring as keyboard
[ 14.770] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[ 14.770] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 14.770] (**) Option "xkb_rules" "evdev"
[ 14.770] (**) Option "xkb_model" "evdev"
[ 14.770] (**) Option "xkb_layout" "us"
[ 14.820] (II) config/udev: Adding input device Video Bus (/dev/input/event7)
[ 14.821] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 14.821] (II) Using input driver 'evdev' for 'Video Bus'
[ 14.821] (**) Video Bus: always reports core events
[ 14.821] (**) evdev: Video Bus: Device: "/dev/input/event7"
[ 14.821] (--) evdev: Video Bus: Vendor 0 Product 0x6
[ 14.821] (--) evdev: Video Bus: Found keys
[ 14.821] (II) evdev: Video Bus: Configuring as keyboard
[ 14.821] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0A08:00/LNXVIDEO:00/input/input7/event7"
[ 14.821] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 14.821] (**) Option "xkb_rules" "evdev"
[ 14.821] (**) Option "xkb_model" "evdev"
[ 14.821] (**) Option "xkb_layout" "us"
[ 14.822] (II) config/udev: Adding input device Lid Switch (/dev/input/event2)
[ 14.822] (II) No input driver specified, ignoring this device.
[ 14.822] (II) This device may have been added with another device file.
[ 14.822] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[ 14.822] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 14.822] (II) Using input driver 'evdev' for 'Sleep Button'
[ 14.822] (**) Sleep Button: always reports core events
[ 14.822] (**) evdev: Sleep Button: Device: "/dev/input/event1"
[ 14.822] (--) evdev: Sleep Button: Vendor 0 Product 0x3
[ 14.822] (--) evdev: Sleep Button: Found keys
[ 14.822] (II) evdev: Sleep Button: Configuring as keyboard
[ 14.822] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0E:00/input/input1/event1"
[ 14.822] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 8)
[ 14.822] (**) Option "xkb_rules" "evdev"
[ 14.822] (**) Option "xkb_model" "evdev"
[ 14.822] (**) Option "xkb_layout" "us"
[ 14.823] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event8)
[ 14.823] (II) No input driver specified, ignoring this device.
[ 14.823] (II) This device may have been added with another device file.
[ 14.824] (II) config/udev: Adding input device HDA Intel Headphone (/dev/input/event10)
[ 14.824] (II) No input driver specified, ignoring this device.
[ 14.824] (II) This device may have been added with another device file.
[ 14.824] (II) config/udev: Adding input device HDA Intel Mic (/dev/input/event9)
[ 14.824] (II) config/udev: Adding input device Asus Laptop extra buttons (/dev/input/event5)
[ 14.825] (**) Asus Laptop extra buttons: Applying InputClass "evdev keyboard catchall"
[ 14.825] (II) Using input driver 'evdev' for 'Asus Laptop extra buttons'
[ 14.825] (**) Asus Laptop extra buttons: always reports core events
[ 14.825] (**) evdev: Asus Laptop extra buttons: Device: "/dev/input/event5"
[ 14.825] (--) evdev: Asus Laptop extra buttons: Vendor 0 Product 0
[ 14.825] (--) evdev: Asus Laptop extra buttons: Found keys
[ 14.825] (II) evdev: Asus Laptop extra buttons: Configuring as keyboard
[ 14.825] (**) Option "config_info" "udev:/sys/devices/platform/asus_laptop/input/input5/event5"
[ 14.825] (II) XINPUT: Adding extended input device "Asus Laptop extra buttons" (type: KEYBOARD, id 9)
[ 14.825] (**) Option "xkb_rules" "evdev"
[ 14.825] (**) Option "xkb_model" "evdev"
[ 14.825] (**) Option "xkb_layout" "us"
[ 14.826] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[ 14.826] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 14.826] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
[ 14.826] (**) AT Translated Set 2 keyboard: always reports core events
[ 14.826] (**) evdev: AT Translated Set 2 keyboard: Device: "/dev/input/event0"
[ 14.826] (--) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[ 14.826] (--) evdev: AT Translated Set 2 keyboard: Found keys
[ 14.826] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[ 14.826] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input0/event0"
[ 14.826] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 10)
[ 14.826] (**) Option "xkb_rules" "evdev"
[ 14.826] (**) Option "xkb_model" "evdev"
[ 14.826] (**) Option "xkb_layout" "us"
[ 14.827] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event6)
[ 14.827] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[ 14.827] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "touchpad catchall"
[ 14.827] (II) LoadModule: "synaptics"
[ 14.827] (II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
[ 14.849] (II) Module synaptics: vendor="X.Org Foundation"
[ 14.849] compiled for 1.12.2, module version = 1.6.2
[ 14.849] Module class: X.Org XInput Driver
[ 14.849] ABI class: X.Org XInput driver, version 16.0
[ 14.849] (II) Using input driver 'synaptics' for 'SynPS/2 Synaptics TouchPad'
[ 14.849] (**) SynPS/2 Synaptics TouchPad: always reports core events
[ 14.849] (**) Option "Device" "/dev/input/event6"
[ 14.849] (--) synaptics: SynPS/2 Synaptics TouchPad: x-axis range 1472 - 5472
[ 14.849] (--) synaptics: SynPS/2 Synaptics TouchPad: y-axis range 1408 - 4448
[ 14.849] (--) synaptics: SynPS/2 Synaptics TouchPad: pressure range 0 - 255
[ 14.849] (--) synaptics: SynPS/2 Synaptics TouchPad: finger width range 0 - 15
[ 14.849] (--) synaptics: SynPS/2 Synaptics TouchPad: buttons: left right double triple
[ 14.849] (--) synaptics: SynPS/2 Synaptics TouchPad: Vendor 0x2 Product 0x7
[ 14.849] (**) Option "TapButton1" "1"
[ 14.849] (**) Option "TapButton2" "2"
[ 14.849] (**) Option "TapButton3" "3"
[ 14.849] (--) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[ 14.850] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio4/input/input6/event6"
[ 14.850] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 11)
[ 14.850] (**) synaptics: SynPS/2 Synaptics TouchPad: (accel) MinSpeed is now constant deceleration 2.5
[ 14.850] (**) synaptics: SynPS/2 Synaptics TouchPad: MaxSpeed is now 1.75
[ 14.850] (**) synaptics: SynPS/2 Synaptics TouchPad: AccelFactor is now 0.040
[ 14.850] (**) SynPS/2 Synaptics TouchPad: (accel) keeping acceleration scheme 1
[ 14.850] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration profile 1
[ 14.850] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[ 14.850] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[ 14.850] (--) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[ 14.851] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse0)
[ 14.851] (II) No input driver specified, ignoring this device.
[ 14.851] (II) This device may have been added with another device file.
[ 14.851] (II) config/udev: Adding input device PC Speaker (/dev/input/event4)
[ 26.041] (II) intel(0): EDID vendor "CMO", prod id 5460
[ 26.041] (II) intel(0): Printing DDC gathered Modelines:
[ 26.041] (II) intel(0): Modeline "1280x800"x0.0 71.00 1280 1328 1360 1440 800 803 809 823 -hsync -vsync (49.3 kHz eP)
[ 28.758] (II) intel(0): EDID vendor "CMO", prod id 5460
[ 28.758] (II) intel(0): Printing DDC gathered Modelines:
[ 28.758] (II) intel(0): Modeline "1280x800"x0.0 71.00 1280 1328 1360 1440 800 803 809 823 -hsync -vsync (49.3 kHz eP)
[ 28.777] (II) intel(0): EDID vendor "CMO", prod id 5460
[ 28.777] (II) intel(0): Printing DDC gathered Modelines:
[ 28.777] (II) intel(0): Modeline "1280x800"x0.0 71.00 1280 1328 1360 1440 800 803 809 823 -hsync -vsync (49.3 kHz eP)
