Dajte predloge i razloge zašto baš taj model koji preporučujete
Kupovina se možda odigra početkom sledeće nedelje a ako budem imao razloga, mogu da sačekam neko vreme.
Eto, navalite sa predlozima.
Misliš konkretno na Intela ili na NVMe uopšteno?ceki77 wrote:Pozdrav za brata.Moja preporuka Intel.A zašto?Vreme će kasti...
Inače, nemam konkretan savet. Tek treba da testiram kako šljakaju i koja je najbolja uloga za SSD uređaje. Najveća zamerka koju sam pročitao je u vezi trajnosti. Navodno se brže troše od hard disk uređaja. Ali u poslednje dve-tri godine nije bilo često videti da ljudi tvrde da su moderni SSD diskovi jednako ili približno jednako stabilni kao HDD. Ali onda vidiš da postoje čitave procedure za smanjenje trošenja ili izbegavanje trošenja SSD tako da je to pitanje šta je istina, a šta ne.As SSDs become more common, you'll also hear more about Non-Volatile Memory Express, a.k.a. NVM Express, or more commonly—NVMe. NVMe is a communications interface/protocol developed specially for SSDs by a consortium of vendors including Intel, Samsung, Sandisk, Dell, and Seagate.
Like SCSI and SATA, NVMe is designed to take advantage of the unique properties of pipeline-rich, random access, memory-based storage. The spec also reflects improvements in methods to lower data latency since SATA and AHCI were introduced
Advances include requiring only a single message for 4KB transfers as opposed to two, and the ability to process multiple queues instead of only one. By multiple, I mean a whopping 65,536 of them. That’s going to speed things up a lot for servers processing lots of simultaneous disk I/O requests, though it'll be of less benefit to consumer PCs. Dalje...
Tu je negde i intel i većina drugih proizvođača i modela. Međutim postoji i u toj jeftinijoj grupi jedan model koji ima ~350TBW i 2,75DWPD i to mi je trenutno kandidat.: 5 Years Limited Warranty or 75TBW Limited Warranty
TBW = DWPD * Warranty * 365 * Capacity/1,024Code: Select all
DWPD = TBW * 1024/(Capacity * Warranty * 365)
realno ne znače mnogo.stereo wrote:Mnogi ljudi ne pogledaju kakvu garanciju ima Samsung za svoju EVO 850 seriju (modeli od 120 i 240gb):5 Years Limited Warranty or75TBW Limited Warranty
Users browsing this forum: Claude User [Bot] and 6 guests
